GB0-901-Mock
    11-06-2024
1. In which phase of the project life cycle is the greatest uncertainty encountered?
A. Conceptual stage
B. Plan preparation stage
C. Implementation phase
D. Closing stage
2. What type of major project is required to submit a handover and maintenance report when the project is closed.
A. Engineering
B. Value-added
C. Security category
D. All
3. During the delivery of a project, a project team member initiated a project change request. This change has no impact on the quality of the project, and the workload is not large, what should the project manager do?
A. Implement the change immediately
B. Submit change request to PMO
C. Reject the change request
D. Assess the impact of the change on other aspects of the project
4. What process does the project management includes?
A. Initiating
B. Planning
C. executing
D. Monitoring
E. Closure
5. What are the general roles involved in the customer kick-off meeting?
A. Customer
B. Agent/channel
C. Customer Manager
D. SE
6. What are the key contents of the internal kick-off meeting?
A. Scheme design and implementation
B. Project's key point, risk list and solutions (from SE )
C. IM Groups for H3C and Partner Interfaces, Reporting and Upgrades
D. R&M and Partner and H3C
7. The project manager is the first responsible person for the success of the project.
A. TRUE
B. FALSE
8. The left, right, front and back of the installation equipment shall ensure a cooling space larger than ()?
A. 5CM
B. 10CM
C. 15CM
D. 20CM
9. The correct sequence of the following equipment installation steps is:
1. Connect the ground wire;
2. Install the lugs and cabling rack;
3. Check the installation;
4. Install the main control board;
5. Install the power module;
6. Wear an anti-static wrist strap;
7. Assemble the service board;
8. Assemble the equipment to the cabinet
A. 1、3、2、5、7、6、4、8
B. 6、3、8、7、4、1、5、2
C. 6、2、8、4、7、1、5、3
D. 6、8、2、4、7、5、1、3
10.How to deal with the empty slot without board in the project installation?
A. Do nothing
B. insert a false handle strip
C. insert a real handle strip
D. insert a full single board
GB0-901-Mock - Answer
