GB0-192-Mock
    23-05-2024
1. On an MSR, you can enter the first several letters of a certain keyword of a command and then press the ______ key. The system will complement the command.
A. <Esc>
B. <Space>
C. <Enter>
D. <Tab>
2. If you want to assign an IP address to the Ethernet port on an MSR router, perform the operation in ______.
A. System view
B. User view
C. Interface view
D. Routing protocol view
3. The administrator needs to configure the Ethernet 1/0/1 port on switch A (SWA) as a trunk port according to user requirements. Which of the following commands should the administrator run?
A. [SWA]portlink-typetrunk
B. [SWA-Ethernet1/0/1]portlink-typetrunk
C. [SWA]undoportlink-typeaccess
D. [SWA-Ethernet1/0/1]undoportlink-typeaccess
4. An STP-enabled port is in the ______ state if it learns addresses and receives, processes, and sends BPDUs but does not receive or forward data.
A. Blocking
B. Listening
C. Learning
D. Forwarding
E. Waiting
F. Disable
5. IPv6 addresses are represented in ______.
A. Colon hexadecimal notation
B. Dotted decimal notation
C. Colon decimal notation
D. Dotted hexadecimal notation
6. Which of the following fields are in both the UDP header and the TCP header?
A. Source IP address
B. Flow control
C. Checksum
D. Sequence number
E. Destination port
F. Source port
7. On an MSR, we run the ______ command to configure a static route.
A. ip route-static
B. route-static
C. ip static-route
D. static-route
8. Suppose an MSR router obtains two routes to network 100.120.10.0/24, and the two routes are with costs 120 and 10, and preference values 10 and 150 respectively. Then the data packets destined for the network will ______.
A. preferentially match the route with cost 120
B. preferentially match the route with cost 10
C. preferentially match the route with preference value 10
D. preferentially match the route with preference value 150
9. The function of hello packet of OSPF is?
A. Neighbor discovery
B. Synchronization of router LSDB
C. Update of LSA information
D. Maintenance of neighboring relationship
10. The customer network is set up as follows: HostA----GE0/0--MSR-1--S1/0---------S1/0--MSR-2--GE0/0----HostB IP addresses and routes have been correctly configured in the network, and HostA and HostB can communicate with each other. Configure an ACL to prevent HostB from pinging HostA while HostA can ping HostB and all other communication between HostA and HostB are normal. Which of the following statements are TRUE?
A. Configuring the ACL only on MSR-1 cannot satisfy the requirements.
B. Configuring the ACL only on MSR-2 cannot satisfy the requirements.
C. Configuring the ACL only on MSR-1 can satisfy the requirements.
D. Configuring the ACL only on MSR-2 can satisfy the requirements.
E. When the ping command is executed, ICMP packets are transmitted bidirectionally. Therefore, the requirement for unidirectional communication cannot be satisfied.
