- 01-Fundamentals Command References
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-Emergency shell commands
- 09-Automatic configuration commands
- 10-Device management commands
- 11-Tcl commands
- 12-Python commands
- 13-License management commands
- 14-RAID management commands
- 15-Preprovisioning commands
15-Preprovisioning commands | 82.17 KB |
The following compatibility matrixes show the support of hardware platforms for preprovisoning:
Hardware |
Preprovisoning compatibility |
MSR610 |
No |
No |
MSR810-LMS, MSR810-LUS |
No |
MSR810-SI, MSR810-LM-SI |
No |
MSR810-LMS-EA, MSR810-LME |
No |
MSR1004S-5G、MSR1004S-5G-CN |
No |
MSR1104S-W、MSR1104S-W-CAT6、MSR1104S-5G-CN、MSR1104S-W-5G-CN |
No |
No |
MSR2600-10-X1 |
No |
MSR 2630 |
Yes |
MSR3600-28, MSR3600-51 |
Yes |
No |
No |
No |
No |
No |
MSR3610, MSR3620, MSR3620-DP, MSR3640, MSR3660 |
Yes |
MSR3610-G, MSR3620-G |
No |
MSR3640-G |
No |
MSR3640-X1-HI |
No |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
MSR2600-6-WiNet |
No |
MSR2600-10-X1-WiNet |
No |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
No |
Yes |
Hardware |
MSR860-6EI-XS |
No |
MSR860-6HI-XS |
No |
MSR2630-XS |
No |
MSR3600-28-XS |
No |
MSR3610-XS |
No |
MSR3620-XS |
Yes |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
No |
MSR3640-XS |
No |
MSR3660-XS |
No |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
No |
MSR3600-28-SI-GL |
No |
display provision failed-config
Use display provision failed-config to display preprovisioned-commands application failure records.
A preprovisioned command cannot be applied if it conflicts with the running configuration.
Use this command to verify the application result of preprovisioned commands except for the following commands:
· duplex
· location
· oc-3
· speed
· sflow
· threshold
· using oc-3c
To verify the application result of the listed commands, use the display current-configuration command. The display provision failed-config command might display incorrect application results for the listed commands.
# Display preprovisioned-commands application failure records.
<Sysname> display provision failed-config
Configuration applied at: Sat Jun 14 06:06:00 2014
Slot information: slot 1
Commands that failed to be applied:
interface FortyGigE1/1/0/1
speed 40000
provision
reset provision failed-config
provision
Use provision to enable preprovisioning.
Use undo provision to disable preprovisioning.
provision [ subslot subslot-number ] model model
undo provision [ subslot subslot-number ] model
Preprovisioning is disabled.
Slot view
subslot subslot-number: Specifies a subslot by its subslot number. If you do not specify a subslot, preprovisioning is enabled on the slot. To specify a subslot, you must first enable provisioning on the slot and make sure the provisioned slot has subslots.
model model: Specifies the card, IRF member device, or subcard model to be preprovisioned. To obtain available models, enter a question mark (?) for the model argument.
CAUTION: · When you disable preprovisioning on a slot, the device removes all preconfigured settings for the slot, including the preconfigured settings for the subslots. · When you disable preprovisioning on a subslot, the device removes preconfigured settings for the subslot. |
This command allows you to enable preprovisioning on offline modules, including interface cards, subcards, and IRF member devices.
The device automatically creates interfaces when preprovisioning is enabled for a module. The display interface command will not display these interfaces until the module comes online.
# Enable preprovisioning for the SIM3110 module on a slot.
[Sysname] slot 2
[Sysname-slot-2] provision model SIM3110
slot
Use reset provision failed-config to clear preprovisioned-commands application failure records.
Preprovisioned modules that repeatedly come online and go offline (or join and leave the IRF fabric) might leave in memory a large number of commands that were not applied. To release the occupied memory space, execute the reset provision failed-config command.
# Clear preprovisioned-commands application failure records.
<Sysname> reset provision failed-config
provision
slot
Use slot to select a slot to provision and enter slot view.
slot slot-number
slot-number: Specifies a slot number. (In standalone mode.)
slot-number: Specifies an IRF member device by its member ID. (In IRF mode.)
# Enter the view of a slot.
[Sysname] slot 2
[Sysname-slot-2]
provision
