- 01-Fundamentals Command References
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-Emergency shell commands
- 09-Automatic configuration commands
- 10-Device management commands
- 11-Tcl commands
- 12-Python commands
- 13-License management commands
- 14-RAID management commands
- 15-Preprovisioning commands
00-Preface | 100.03 KB |
Preface
This command reference covers the commands for logging in to and setting up the device.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
