- 01-Fundamentals Command References
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-Emergency shell commands
- 09-Automatic configuration commands
- 10-Device management commands
- 11-Tcl commands
- 12-Python commands
- 13-License management commands
- 14-RAID management commands
- 15-Preprovisioning commands
07-Software upgrade commands | 218.75 KB |
As a best practice, store the startup images in the factory default file system. If you store the startup images in a hot swappable storage medium, do not remove the hot swappable storage medium during the startup process.
boot-loader file
Use boot-loader file to specify startup image files.
In standalone mode:
boot-loader file boot filename system filename [ feature filename&<1-30> ] { backup | main }
boot-loader file ipe-filename { backup | main [ undecompressed ] }
In IRF mode:
boot-loader file boot filename system filename [ feature filename&<1-30> ] { all | slot slot-number } { backup | main }
boot-loader file ipe-filename { all | slot slot-number } { backup | main [ undecompressed ] }
boot: Specifies a boot image file.
system: Specifies a system image file.
feature: Specifies a space-separated list of up to 30 feature image files.
filename: Specifies a .bin file in the filesystemname/filename.bin format. The file must be stored in the root directory of a file system on the device. Excluding the file system location section (if any), the value string can have a maximum of 63 characters. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
ipe-filename: Specifies an .ipe image package file in the filesystemname/filename.ipe format. The file must be stored in the root directory of a file system on the device. Excluding the file system location section (if any), the value string can have a maximum of 63 characters. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
all: Specifies all hardware components to which the specified images apply.
The following compatibility matrixes show the support of hardware platforms for the all keyword:
Hardware |
Parameter compatibility |
MSR610 |
No |
No |
MSR810-LMS, MSR810-LUS |
No |
MSR810-SI, MSR810-LM-SI |
No |
MSR810-LMS-EA, MSR810-LME |
No |
MSR1004S-5G, MSR1004S-5G-CN |
No |
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN |
No |
Yes |
MSR2600-10-X1 |
No |
MSR 2630 |
Yes |
MSR3600-28, MSR3600-51 |
Yes |
No |
Yes |
No |
No |
Yes |
MSR3610, MSR3620, MSR3620-DP, MSR3640, MSR3660 |
Yes |
MSR3610-G, MSR3620-G |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
MSR2600-6-WiNet |
Yes |
MSR2600-10-X1-WiNet |
No |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
No |
MSR860-6HI-XS |
No |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
slot slot-number: Specifies the IRF member ID of a member device. (In IRF mode.)
backup: Specifies the files as backup startup image files. Backup images are used only when main images are not available.
main: Specifies the files as main startup image files. The device always first attempts to start up with main startup files.
undecompressed: Specifies the IPE file as the main startup image file without decompressing it. If you do not specify this keyword, the device decompresses the IPE file and then sets the decompressed .bin files as the main startup image files. As a best practice, do not specify this keyword if the device has sufficient storage space.
The following compatibility matrixes show the support of hardware platforms for the undecompressed keyword:
Hardware |
MSR610 |
Yes |
Yes |
No |
No |
Yes |
Yes |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
Yes |
No |
Yes |
No |
No |
No |
Yes |
No |
MSR3640-G |
No |
MSR3640-X1-HI |
No |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
No |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
No |
MSR3620-XS |
Yes |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
No |
MSR3640-XS |
No |
MSR3660-XS |
No |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
The boot-loader file command overwrites the entire startup image list. To add new startup feature images, specify all feature image files in the old startup image list, including feature image files. The new startup image list will contain only the feature image files that are specified in the command.
Before you specify startup image files, register and activate a license for each upgrade image that requires a license. If a license-based software image lacks a license, the command execution result is as follows:
· If .bin files are specified, the command cannot be executed.
· If an .ipe file is specified, the command sets all images as startup images except for the image that does not have a license.
For more information about licensing, see Fundamentals Configuration Guide.
To load the specified startup software images, you must reboot the system.
If the upgrade images are not found in the file system on the slot specified to upgrade, the system automatically copies the images to that file system. The destination directory is the root directory of the file system. If the destination root directory already contains a startup image with the same name as an upgrade image, you must choose whether to overwrite the image.
Incremental patches cannot be installed by using the boot-loader file command.
If the device does not have sufficient storage space, you can specify the undecompressed keyword. The device sets the IPE file as the main startup image file without decompressing it and sets the current main startup image files as the backup startup image files. The device decompresses the IPE file upon reboot, loads the decompressed .bin files as the main startup image files, and deletes the IPE file. If the device fails to decompress the IPE file or load the decompressed .bin files, it loads the backup startup image files.
NOTE: The system will verify the digital signature of the specified images before it updates the startup image list with the specified images. If the digital signature verification fails, the system will not update the startup image list and you will receive a digital signature verification failure message. |
# (In standalone mode.) Specify flash:/all.ipe as the main startup image file.
<Sysname> boot-loader file flash:/all.ipe main
Verifying the file flash:/all.ipe on the device.............Done.
H3C MSR36-10images in IPE:
boot.bin
system.bin
This command will set the main startup software images. Continue? [Y/N]:Y
Add images to the device.
File flash:/boot.bin already exists on the device.
File flash:/system.bin already exists on the device.
Overwrite or rename the new file? [Yes/No/Rename]: R
Please input the file name (*.bin)[boot_1.bin]
(To use the recommended file name, press the Enter key):
Decompressing file boot.bin to flash:/boot_1.bin........................Done.
Please input the file name (*.bin)[system_1.bin]
(To use the recommended file name, press the Enter key):system_backup.bin
Decompressing file system.bin to flash:/system_backup.bin...........................Done.
Verifying the file flash:/boot_1.bin on the device...Done.
Verifying the file flash:/system_backup.bin on the device.............Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on the device..
# (In standalone mode.) Specify flash:/boot.bin and flash:/system.bin as the main startup boot and system image files.
<Sysname> boot-loader file boot flash:/boot.bin system flash:/system.bin main
# (In IRF mode.) Specify flash:/all.ipe as the main startup image file.
<Sysname> boot-loader file flash:/all.ipe slot 1 main
Verifying the file flash:/all.ipe on slot 1..............Done.
H3C MSR36-10 images in IPE:
boot.bin
system.bin
Add images to slot 1.
File flash:/boot.bin already exists on slot 1.
File flash:/system.bin already exists on slot 1.
Overwrite or rename the new file? [Yes/No/Rename]: Y
Decompressing file boot.bin to flash:/boot.bin........................Done.
Decompressing file system.bin to flash:/system.bin...............................Done.
Verifying the file flash:/boot.bin on slot 1...Done.
Verifying the file flash:/system.bin on slot 1.............Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 1.
<Sysname> boot-loader file slot1#flash:/all.ipe all main
Verifying the file flash:/all.ipe on slot 1......................................Done.
Boot.bin
System.bin
File flash:/Boot.bin already exists on slot 1.
File flash:/System.bin already exists on slot 1.
Overwrite or rename the new file? [Yes/No/Rename]:Y
Decompressing file Boot.bin to flash:/Boot.bin........................Done.
Decompressing file System.bin to flash:/System.bin........................Done.
File flash:/Boot.bin already exists on slot 2.
Do you want to overwrite the file?
Y: Overwrite the file.
N: Not overwrite the file.
A: From now on, overwrite or not overwrite without prompt.
Please make a choice. [Y/N/A]:A
What type of overwrite operation do you want to perform?
Y: Overwrite without prompt.
N: Not overwrite or display prompt.
Q: Return to the previous step.
Please make a choice. [Y/N/Q]:Y
An existing file will be overwritten without prompt if it has the same name as any upgrade file.
Loading......................Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 2.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 3.
Decompression completed.
Do you want to delete flash:/all.ipe now? [Y/N]:N
display boot-loader
boot-loader update
Use boot-loader update to synchronize startup images.
boot-loader update { all | slot slot-number }
The following compatibility matrixes show the support of hardware platforms for this command:
Hardware |
Command compatibility |
MSR610 |
No |
No |
No |
No |
No |
No |
No |
Yes |
MSR2600-10-X1 |
No |
MSR 2630 |
Yes |
Yes |
No |
Yes |
No |
No |
Yes |
Yes |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
MSR2600-6-WiNet |
Yes |
No |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
No |
MSR860-6HI-XS |
No |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
all: Synchronizes startup images from the master to all subordinate devices.
slot slot-number: Specifies the IRF member ID of a subordinate device.
You can use this command to synchronize startup images after adding new member devices.
If any of the startup software images require a license, register and activate a license for the image on the new subordinate device before executing this command. Use the display license feature command to verify the licensing state of software images.
The startup images synchronized to the subordinate device are set as main startup images, regardless of whether the source startup images are main or backup.
· If the master device has started up with main startup images, its main startup images are synchronized to the subordinate device, regardless of whether any main startup image has been respecified on the master device.
· If the master device has started up with backup startup images, its backup startup images are synchronized to the subordinate device, regardless of whether any backup startup image has been respecified on the master device.
If a patch installation or the install command has been executed on the master, use the install commit command to update the set of main startup images on the master before software synchronization. This command ensures startup image consistency between the master and the subordinate device.
Startup image synchronization fails if any software image being synchronized is not available or is corrupted.
# Synchronize startup images from the active MPU to the standby MPU in slot 1.
<Sysname> boot-loader update slot 2
This command will update the specified standby MPU. Continue? [Y/N]:y
Updating. Please wait...
Verifying the file flash:/system.bin on slot 1....Done.
Copying main startup software images to slot 2. Please wait...
Done.
Setting copied images as main startup software images for slot 2...
Done.
Successfully updated the startup software images of slot 2.
display boot-loader
install commit
bootrom update
Use bootrom update to load the BootWare image from a file system to the Normal BootWare area.
In standalone mode:
bootrom update file file [ subslot subslot-number-list ]
In IRF mode:
bootrom update file file slot slot-number-list [ subslot subslot-number-list ]
Hardware |
MSR610 |
No |
No |
No |
No |
No |
No |
No |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
No |
MSR830-4LM-WiNet |
No |
Yes |
No |
MSR2600-6-WiNet |
Yes |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
No |
MSR860-6HI-XS |
No |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
Yes |
file file: Specifies the file that contains the BootWare image. The file argument represents the file name, a string of 1 to 63 characters.
slot slot-number-list: Specifies a space-separated list of up to seven slot number items. An item specifies an IRF member device by its member ID or a range of IRF member devices in the form of start-slot-number to end-slot-number. The end slot number must be equal to or greater than the start slot number. (In IRF mode.)
subslot subslot-number-list: Specifies a list of up to seven subslot number items. Each item specifies a subcard by its subslot number or a range of subcards in the form of start-subslot-number to end-subslot-number. If you do not specify a subcard, this command loads the BootWare image for the base card.
The following compatibility matrixes show the support of hardware platforms for the subslot subslot-number-list option:
Hardware |
MSR610 |
No |
No |
No |
No |
No |
No |
No |
Yes |
MSR2600-10-X1 |
No |
MSR 2630 |
Yes |
Yes |
No |
Yes |
No |
No |
Yes |
Yes |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
MSR2600-6-WiNet |
Yes |
No |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
No |
MSR860-6HI-XS |
No |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
BootWare images are contained in the .bin Comware boot image file or a .btw file. You can specify a Comware boot image file in this command to upgrade the BootWares in the system before you upgrade the Comware images. If you do not upgrade BootWares before upgrading Comware images, the system automatically upgrades BootWares as necessary when loading Comware images.
The new BootWare images take effect after you reboot the device.
NOTE: The system verifies a BootWare image before it loads that image to the Normal area of BootWare. If the digital signature verification fails, the system will not load the image and you will receive a digital signature verification failure message. |
# (In standalone mode.) Use the file a.bin in the root directory of the flash memory to upgrade the BootWare image.
<Sysname> bootrom update file flash:/a.bin
This command will update the Boot ROM file, Continue? [Y/N]:y
Now updating the Boot ROM, please wait................Done.
# (In IRF mode.) Use the file a.bin in the root directory of the flash memory to upgrade the BootWare image.
<Sysname> bootrom update file flash:/a.bin slot 1
This command will update the Boot ROM file on the specified board(s), Continue? [Y/N]:y
boot-loader file
display boot-loader
Use display boot-loader to display current software images and startup software images.
In standalone mode:
display boot-loader
In IRF mode:
display boot-loader [ slot slot-number ]
slot slot-number: Specifies the member ID of an IRF member device. If you do not specify a member device, this command displays the software images on each IRF member device.
# (In standalone mode.) Display the current software images and startup software images.
<Sysname> display boot-loader
Software images on the device:
Current software images:
flash:/boot.bin
flash:/system.bin
Main startup software images:
flash:/boot.bin
flash:/system.bin
Backup startup software images:
flash:/boot.bin
flash:/system.bin
# (In IRF mode.) Display the current software images and startup software images.
Software images on slot 1:
flash:/boot.bin
flash:/system.bin
flash:/boot.bin
flash:/system.bin
flash:/boot.bin
flash:/system.bin
Current software images |
Comware images that have been loaded. |
Main startup software images |
Primary Comware images for the next startup. |
Backup startup software images |
Backup Comware images for the next startup. If the backup startup software images are not specified, this field displays None. |
boot-loader file
display install active
Use display install active to display active software images.
In standalone mode:
display install active [ verbose ]
In IRF mode:
display install active [ slot slot-number ] [ verbose ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for all IRF members. (In IRF mode.)
verbose: Displays detailed information. If you do not specify this keyword, the command displays only image names.
# (In standalone mode.) Display active software images.
<Sysname> display install active
Active packages on the device:
flash:/boot.bin
flash:/system.bin
flash:/feature1.bin
# (In IRF mode.) Display brief information about active software images.
Active packages on slot 1:
flash:/boot.bin
flash:/system.bin
flash:/feature1.bin
# (In standalone mode.) Display detailed information about active software images.
<Sysname> display install active verbose
flash:/boot.bin
[Package]
Vendor: H3C
Product: MSR36
Service name: boot
Platform version: 7.1.070
Product version: Test 0001015
Supported board: MSR36-10
[Component]
Component: boot
Description: boot package
flash:/system.bin
[Package]
Vendor: H3C
Product: MSR36
Service name: system
[Component]
Component: system
Description: system package
flash:/feature1.bin
[Package]
Vendor: H3C
Product: MSR36
Service name: test
[Component]
Component: test
Description: test package
[Package] |
Information about the software image. |
Service name |
Image type: · boot—Boot image. · system—System image. · boot patch—Patch image for the boot image. · system patch—Patch image for the system image. · Any other value indicates a feature image. |
Supported board |
Hardware types supported by the software image. |
[Component] |
Information about components included in the image file. |
install active
display install backup
Use display install backup to display backup startup software images.
In standalone mode:
display install backup [ verbose ]
In IRF mode:
display install backup [ slot slot-number ] [ verbose ]
Backup startup images are used only when the main boot or system image is missing or corrupt.
To modify the backup startup image list, use the boot-loader file command.
# (In standalone mode.) Display the backup startup software images.
<Sysname> display install backup
Backup startup software images on the device:
flash:/boot.bin
flash:/system.bin
# (In IRF mode.) Display the backup startup software images.
Backup startup software images on slot 1:
flash:/boot.bin
flash:/system.bin
# (In standalone mode.) Display detailed information about backup startup software images.
<Sysname> display install backup verbose
flash:/boot.bin
[Package]
Vendor: H3C
Product: MSR36
Service name: boot
[Component]
Component: boot
flash:/system.bin
[Package]
Vendor: H3C
Product: MSR36
[Component]
Component: system
# (In IRF mode.) Display detailed information about backup startup software images.
flash:/boot.bin
[Package]
Vendor: H3C
Product: MSR36
Service name: boot
[Component]
Component: boot
flash:/system.bin
[Package]
Vendor: H3C
Product: MSR36
[Component]
Component: system
boot-loader file
display install committed
Use display install committed to display main startup software images.
In standalone mode:
display install committed [ verbose ]
In IRF mode:
display install committed [ slot slot-number ] [ verbose ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for all member devices. (In IRF mode.)
Some install commands modify the current software image list but do not modify the main startup image list. For the software image changes to take effect after a reboot, you must execute the install commit command to update the main startup image list with the image changes. You can use the display install committed command to verify the operation results.
Both the install commit and boot-loader file commands modify the main startup software image list.
# (In standalone mode.) Display the main startup software images.
<Sysname> display install committed
Committed packages on the device:
flash:/boot.bin
flash:/system.bin
flash:/feature1.bin
# (In IRF mode.) Display the main startup software images.
Committed packages on slot 1:
flash:/boot.bin
flash:/system.bin
flash:/feature1.bin
# (In standalone mode.) Display detailed information about main startup software images.
<Sysname> display install committed verbose
flash:/boot.bin
[Package]
Vendor: H3C
Product: MSR36
Service name: boot
[Component]
Component: boot
flash:/system.bin
[Package]
Vendor: H3C
Product: MSR36
[Component]
Component: system
flash:/feature1.bin
[Package]
Vendor: H3C
Product: MSR36
Service name: feature1
[Component]
Component: feature1
Description: feature1 package
# (In IRF mode.) Display detailed information about main startup software images.
flash:/boot.bin
[Package]
Vendor: H3C
Product: MSR36
Service name: boot
[Component]
Component: boot
flash:/system.bin
[Package]
Vendor: H3C
Product: MSR36
[Component]
Component: system
flash:/feature1.bin
[Package]
Vendor: H3C
Product: MSR36
[Component]
Component: feature1
boot-loader file
install commit
display install inactive
Use display install inactive to display inactive software images in the root directories of file systems.
In standalone mode:
display install inactive [ verbose ]
In IRF mode:
display install inactive [ slot slot-number ] [ verbose ]
verbose: If you do not specify a member device, this command displays information for all member devices.
# (In standalone mode.) Display brief information about inactive software images in the root directories of the file systems.
<Sysname> display install inactive
Inactive packages on the device:
flash:/feature1.bin
# (In IRF mode.) Display brief information about inactive software images in the root directories of the file systems.
Inactive packages on slot 1:
flash:/feature1.bin
# (In standalone mode.) Display detailed information about inactive software images in the root directories of the file systems.
<Sysname> display install inactive verbose
flash:/feature1.bin
[Package]
Vendor: H3C
Product: MSR36
[Component]
Component: feature1
# (In IRF mode.) Display detailed information about inactive software images in the root directories of the file systems.
flash:/feature1.bin
[Package]
Vendor: H3C
Product: MSR36
[Component]
Component: feature1
install deactivate
display install ipe-info
Use display install ipe-info to display the software images included in an .ipe file.
display install ipe-info ipe-filename
ipe-filename: Specifies an .ipe file in the filesystemname/filename.ipe format. The file must be stored in the root directory of a file system on the device. The value string excluding the file system location section (if any) can have a maximum of 63 characters. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
# (In standalone mode.) Display information about .ipe file flash:/test.ipe.
<Sysname> display install ipe-info flash:/test.ipe
Verifying the file flash:/test.ipe on the device................Done.
boot.bin
system.bin
# (In IRF mode.) Display information about .ipe file flash:/test.ipe.
Verifying the file flash:/test.ipe on slot 1................Done.
boot.bin
system.bin
display install job
Use display install job to display ongoing activate and deactivate operations.
display install job
# (In standalone mode.) Display ongoing activate and deactivate operations.
<Sysname> display install job
JobID:5
Action:install activate flash:/feature1.bin on the device
The output shows that the device is executing the install activate flash:/feature1.bin command.
# (In IRF mode.) Display ongoing activate and deactivate operations.
JobID:5
Action:install activate flash:/feature1.bin on slot 1
The output shows that the device is executing the install activate flash:/feature1.bin slot 1 command.
display install package
Use display install package to display software image file information.
display install package { filename | all } [ verbose ]
filename: Specifies a .bin file in the filesystemname/filename.bin format. The file must be stored in the root directory of a file system on the device. The value string excluding the file system location section (if any) can have a maximum of 63 characters. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
all: Specifies all software image files in the root directories of the device's file systems. (In standalone mode.)
all: Specifies all software image files in the root directories of the master's file systems. (In IRF mode.)
verbose: Displays detailed information. If you do not specify this keyword, the command displays only basic software image information
# Display information about system.bin.
<Sysname> display install package flash:/system.bin
flash:/system.bin
[Package]
Vendor: H3C
Product: MSR36
# Display detailed information about system.bin.
<Sysname> display install package flash:/system.bin verbose
flash:/system.bin
[Package]
Vendor: H3C
Product: MSR36
[Component]
Component: system
display install which
Use display install which to display all software image files that include a specific component or file.
In standalone mode:
display install which { component name | file filename }
In IRF mode:
display install which { component name | file filename } [ slot slot-number ]
component name: Specifies a component name.
file filename: Specifies a file in the filename.extension format, a case-insensitive string of up to 63 characters. It cannot contain path information.
A component is a collection of features. The features of a component are installed or uninstalled at the same time.
When the system displays a component or file error, use this command to identify the image files that include the component or file. Then, you can use the install verify command to identify image file problems.
This command searches only the root directories of the file systems at the specified location.
# (In IRF mode.) Display the software image file that includes pkg_ctr.
<Sysname> display install which file pkg_ctr
Verifying the file flash:/system-t0001015.bin on slot 1..........................Done.
Found pkg_ctr in flash:/system-t0001015.bin on slot 1.
[Package]
Vendor: H3C
Product: MSR36
Verifying the file flash:/boot-d2601007.bin on slot 1.....Done.
Verifying the file |
The system was verifying the validity of the file. |
[Package] |
Detailed information about the software image. |
Service name |
Image type: · boot—Boot image. · system—System image. · patch—Patch image. · Any other value indicates a feature image. |
Supported board |
firmware update
Use firmware update to upgrade firmware.
In standalone mode:
firmware update [ subslot subslot-number ]{ cpld cpld-number | fpga fpga-number | module module-number } file filename
In IRF mode:
firmware update slot slot-number [ subslot subslot-number ] { cpld cpld-number | fpga fpga-number | module module-number } file filename
Hardware |
MSR610 |
No |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
Yes |
MSR2600-6-WiNet |
Yes |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
No |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
Yes |
slot slot-number: Specifies an IRF member device. The slot-number argument represents its IRF member ID. In IRF mode:
subslot subslot-number: Specifies a subcard by its subslot number. If you do not specify a subcard, the command upgrades firmware for all subcards on the base card.
The following compatibility matrixes show the support of hardware platforms for the subslot subslot-number option:
Hardware |
MSR610 |
No |
No |
No |
No |
No |
No |
No |
Yes |
MSR2600-10-X1 |
No |
MSR 2630 |
Yes |
Yes |
No |
Yes |
No |
No |
Yes |
Yes |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
MSR2600-6-WiNet |
Yes |
No |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
No |
MSR860-6HI-XS |
No |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
cpld cpld-number: Specifies a complex programmable logical device (CPLD) by its number.
The following compatibility matrixes show the support of hardware platforms for the cpld cpld-number option:
Hardware |
MSR610 |
No |
No |
No |
No |
No |
Yes |
No |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
Yes |
MSR2600-6-WiNet |
Yes |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
No |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
Yes |
fpga fpga-number: Specifies a field programmable gate array (FPGA) by its number.
The following compatibility matrixes show the support of hardware platforms for the fpga fpga-number option:
Hardware |
MSR610 |
No |
No |
No |
No |
No |
No |
No |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
MSR2600-6-WiNet |
Yes |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
No |
MSR860-6HI-XS |
No |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
Yes |
module module-number: Specifies a module by its number.
The following compatibility matrixes show the support of hardware platforms for the module module-number option:
Hardware |
MSR610 |
No |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
MSR2600-6-WiNet |
Yes |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
No |
MSR860-6HI-XS |
No |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
Yes |
file filename: Specifies an upgrade file in the filesystemname/filename.extension format. The file must be stored in the root directory of a file system on the device. Excluding the file system location section (if any), the value string can have a maximum of 63 characters. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
Use this command to upgrade firmware that cannot be upgraded using the boot-loader command.
To complete the firmware upgrade, you must power cycle the card or subcard.
To power cycle a card or subcard, use one of the following methods:
· Power cycle the device.
· Remove and reinsert the card or subcard.
# (In standalone mode.) Upgrade CPLD 1.
<Sysname> firmware update cpld 1 file package.bin
Updating firmware for CPLD on the specified card or subcard. Continue?[Y/N]:y
Updating the firmware…
Please power cycle the card or subcard to activate the firmware.
# (In IRF mode.) Upgrade CPLD 1 in slot 1.
<Sysname> firmware update slot 1 cpld 1 file package.bin
install activate
Use install activate to activate software images.
In standalone mode:
install activate { boot filename | system filename | feature filename&<1-30> } *
install activate patch filename
In IRF mode:
install activate { boot filename | system filename | feature filename&<1-30> } * slot slot-number
install activate patch filename { all | slot slot-number }
patch: Specifies a patch image file. You can specify only one patch image file for the command at a time. However, you can execute the command multiple times to activate multiple patch image files.
filename&<1-30>: Specifies a .bin file in the filesystemname/filename.bin format. The file must be stored in the root directory of a file system on the device. The value string excluding the file system location section (if any) can have a maximum of 63 characters. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
all: Specifies all member devices. (In IRF mode.)
slot slot-number: Specifies an IRF member device by its member ID. (In IRF mode.)
Before you use this command to activate a software image, read the release notes to identify the licensing requirements for the image. If the image requires a license, make sure the device has a valid license installed for the image.
In standalone mode:
An image runs in memory immediately after it is activated. For an activated image to run after a reboot, you must commit the software change by using the install commit command.
In IRF mode:
Images run in memory immediately after they are activated. However, only images activated by using the install activate patch filename all command still run in memory after a reboot. For other images to take effect after a reboot, you must commit the software change by using the install commit command.
If the specified files are not stored on the member device to be upgraded, the command copies the images to the member device automatically.
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the install activate command on the subordinate device. To identify whether the synchronization is complete, use the display system stable state command. The synchronization is complete if the System State field displays Stable.
# (In standalone mode.) Activate the system image in system.bin and the feature images in feature1.bin.
<Sysname> install activate system flash:/system.bin feature flash:/feature1.bin
Verifying the file flash:/feature1.bin on the device.....Done.
Verifying the file flash:/system.bin on the device.....Done.
flash:/system.bin
Running Version New Version
Test 0001015 Test 0001016
flash:/feature1.bin
NONE Test 0001016
Upgrade Way: Service Upgrade
This operation might take several minutes, please wait...Done.
# (In IRF mode.) Activate the system image in system.bin and the feature images in feature1.bin on member device 2.
<Sysname> install activate system flash:/system.bin feature flash:/feature1.bin slot 2
Copying file flash:/system.bin to slot2#flash:/system.bin......Done.
Verifying the file flash:/system.bin on slot 2.....Done.
Copying file flash:/feature1.bin to slot2#flash:/feature1.bin......Done.
Verifying the file flash:/feature1.bin on slot 2.....Done.
flash:/system.bin
flash:/feature1.bin
None Test 0001016
Slot Upgrade Way
2 Service Upgrade
Verifying the file flash:/xx.bin.....Done. |
Upgrade summary according to following table |
Upgrade summary. |
Running Version |
Version number of the running software. |
New Version |
Version number of the new software. |
Upgrade Way |
This field is not supported in the current software version. Upgrade methods: · Service Upgrade. · File Upgrade. · Reboot. |
Influenced service according to following table |
Services influenced by the upgrade. |
Install command does not support incompatible upgrade. |
The install command cannot be used to upgrade incompatible versions. |
install commit
install deactivate
install add
Use install add to decompress an .ipe file.
install add ipe-filename filesystem
filesystem: Specifies the destination file system for the software images, in the filesystemname format.
To use the install activate command to activate software images, you must use .bin image files. If the upgrade file is an .ipe file, use this command to decompress the .ipe file before you start the upgrade.
To identify software images that are included in an .ipe file, use the display install ipe-info command.
# Decompress all.ipe to the flash memory.
<Sysname> install add flash:/all.ipe flash:
Verifying the file flash:/all.ipe on slot 1...Done.
Decompressing file boot.bin to flash:/boot.bin.......................Done.
Decompressing file system.bin to flash:/system.bin.................................Done.
install commit
Use install commit to commit software changes.
install commit
Before you use this command, read the release notes to identify software image licensing requirements. Make sure the device has valid licenses for all license-based images.
This command adds the patch image file to the startup software image list that the device used at startup.
· If the device used the main startup software image list at startup, this command adds the patch image file to the main startup software image list.
· If the device used the backup startup software image list at startup, this command adds the patch image file to the backup startup software image list.
Both the install commit and boot-loader file commands modify the main startup software image list. To modify the backup startup image list or add inactive images as main startup images, however, you must use the boot-loader file command.
# Commit software changes.
<Sysname> install commit
This operation will take several minutes, please wait...........................Done.
install activate
install deactivate
install rollback
install deactivate
Use install deactivate to deactivate feature images and patch images.
In standalone mode:
install deactivate feature filename&<1-30>
install deactivate patch filename
In IRF mode:
install deactivate feature filename&<1-30> slot slot-number
install deactivate patch filename { all | slot slot-number }
patch: Specifies a patch image file. You can specify only one patch image file for the command at a time. However, you can execute the command multiple times to deactivate multiple patch image files.
filename&<1-30>: Specifies a .bin file in the filesystemname/filename.bin format. The value string can have a maximum of 63 characters. The file system name cannot contain file system location information. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
all: Specifies all member devices on which the specified patch image file has been activated. (In IRF mode.)
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the install deactivate command on the subordinate device. To identify whether the synchronization is complete, use the display system stable state command. The synchronization is complete if the System State field displays Stable.
You can deactivate only active feature and patch images.
(In standalone mode.) To prevent deactivated images from running after a reboot, you must commit the software changes by using the install commit command.
(In IRF mode.) Images deactivated by using the install deactivate patch filename all command do not run after a reboot. To prevent other deactivated images from running after a reboot, you must commit the software change by using the install commit command.
# (In standalone mode.) Deactivate the patch images in the route-patch.bin file.
<Sysname> install deactivate patch flash:/route-patch.bin
# (In IRF mode.) Deactivate the patch images in the route-patch.bin file for a slot.
<Sysname> install deactivate patch flash:/route-patch.bin slot 1
install remove
Use install remove to delete an inactive software image file.
In standalone mode:
install remove { filename | inactive }
In IRF mode:
install remove [ slot slot-number ] { filename | inactive }
filename: Specifies a .bin file in the filesystemname/filename.bin format. The value string can have a maximum of 63 characters. The file must be stored in the root directory of a file system on the device. The file system name cannot contain file system location information. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command deletes inactive software images from all IRF members. (In IRF mode.)
inactive: Deletes all inactive software image files in the root directories of the specified file systems.
This command permanently deletes the image files from the device. You cannot use the install rollback to command to revert the operation, or use the install abort command to abort the operation.
# Delete inactive software image file flash:/feature1.bin.
<Sysname> install remove flash:/feature1.bin
install verify
Use install verify to verify the software change commit status, image integrity, and image consistency.
install verify
To ensure that the system can start up and operate correctly after an upgrade, execute this command to verify the following items:
· Integrity—Verify that the boot, system, and feature images are integral.
· Consistency—Verify that the same active images are running across the entire system.
· Software commit status—Verify that the active images are committed as needed.
If a software image fails the verification, perform the following tasks to resolve the problem:
· To ensure software integrity, download and install the software images again.
· To guarantee software image consistency or change software commit status, use the install activate, install deactivate, and install commit commands as appropriate.
# (In standalone mode.) Verify the software change confirmation status and software image integrity and consistency.
<Sysname> install verify
Active packages on the device are the reference packages.
Packages will be compared with the reference packages.
Verifying packages on the device:
Start to check active package completeness.
Verifying the file flash:/boot-t0001015.bin on the device...........Done.
flash:/boot-t0001015.bin verification successful.
Verifying the file flash:/system-t0001015.bin on the device............Done.
flash:/system-t0001015.bin verification successful.
Start to check active package consistency.
Active packages are consistent with committed packages on their own board.
Active packages are consistent with the reference packages.
Verification is done.
# Verify the software change confirmation status and software image integrity and consistency.
Active packages on slot 1 are the reference packages.
Verifying packages on slot 0:
Verifying the file flash:/boot-t0001015.bin on slot 0.....................Done.
Verifying the file flash:/system-t0001015.bin on slot 0.....................Done.
Verifying packages on slot 1:
Verifying the file flash:/boot-t0001015.bin on slot 1.....................Done.
Verifying the file flash:/system-t0001015.bin on slot 1.....................Done.
# (In IRF mode.) Verify the software change confirmation status and software image integrity and consistency.
Verifying packages on slot 2:
Verifying the file flash:/boot-t0001015.bin on slot 2.....................Done.
Verifying the file flash:/system-t0001015.bin on slot 2.....................Done.
