07-SAVI-MIB | 62.11 KB |
SAVI-MIB
About this MIB
Use this MIB to manage SAVI configuration.
MIB file name
savi.mib
Root object
iso(1).org(3).dod(devil).internet(1).mgmt(2).mib-2(1).ip(4).saviMIB(40)
Scalar objects
Tabular objects
saviObjectsSystemTable
About this table
Use this table to configure global SAVI parameters.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are saviObjectsSystemIPVersion and saviObjectsSystemTable.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
saviObjectsSystemIPVersion (1.3.6.1.2.1.4.40.1.1.1.1) |
not-accessible |
INTEGER |
unknown(0) ipv4(1) ipv6(2) |
IP version. |
As per the MIB. |
saviObjectsSystemMode (1.3.6.1.2.1.4.40.1.1.1.2) |
read-write |
INTEGER |
savi-disable(1) savi-default(2) savi-dhcp-only(3) savi-slaac-only(4) savi-dhcp-slaac-mix(5) savi-send(6) |
IP address assignment methods. |
As per the MIB. |
saviObjectsSystemMaxDhcpResponseTime (1.3.6.1.2.1.4.40.1.1.1.3) |
read-write |
INTEGER |
INTEGER (0..2147483647) |
Maximum interval between two DHCP responses. |
As per the MIB. |
saviObjectsSystemDataSnoopingInterval (1.3.6.1.2.1.4.40.1.1.1.4) |
read-create |
INTEGER |
Data snooping interval. |
As per the MIB. |
saviObjectsSystemMaxLeaseQueryDelay (1.3.6.1.2.1.4.40.1.1.1.5) |
read-create |
INTEGER |
Maximum lease query delay. |
As per the MIB. |
saviObjectsSystemOffLinkDelay (1.3.6.1.2.1.4.40.1.1.1.6) |
read-write |
INTEGER |
Off-link entry deletion delay. |
As per the MIB. |
saviObjectsSystemDetectionTimeout (1.3.6.1.2.1.4.40.1.1.1.7) |
read-write |
INTEGER |
Detection timeout. |
As per the MIB. |
saviObjectsSystemTentLT (1.3.6.1.2.1.4.40.1.1.1.8) |
read-write |
INTEGER |
ND snooping tentative entry lifetime. |
As per the MIB. |
saviObjectsSystemDefaultLT (1.3.6.1.2.1.4.40.1.1.1.9) |
read-write |
INTEGER |
ND snooping valid entry lifetime. |
As per the MIB. |
saviObjectsSystemTWAIT (1.3.6.1.2.1.4.40.1.1.1.10) |
read-write |
INTEGER |
ND snooping DAD NS transmission interval. |
As per the MIB. |
saviObjectsSystemNotifySpoofing (1.3.6.1.2.1.4.40.1.1.1.11) |
read-write |
INTEGER |
enable(1) disable(2) |
Status of packet spoofing logging. |
As per the MIB. |
saviObjectsSystemNotifyFilter (1.3.6.1.2.1.4.40.1.1.1.12) |
read-write |
INTEGER |
Status of filtering entry logging. |
As per the MIB. |
saviObjectsSystemNotifySpoofingInterval (1.3.6.1.2.1.4.40.1.1.1.13) |
read-write |
Unsigned32 |
Unsigned32 (0|5..3600) |
Log output interval for packet spoofing logging, in seconds. |
As per the MIB. |
saviObjectsSystemNotifySpoofingNumber (1.3.6.1.2.1.4.40.1.1.1.14) |
read-write |
Unsigned32 |
Unsigned32 (1..128) |
Maximum number of log messages that can be output per interval. |
As per the MIB. |
saviObjectsSystemBindingCount (1.3.6.1.2.1.4.40.1.1.1.15) |
read-only |
Unsigned32 |
Unsigned32 (0..4294967295) |
Number of binding entries. |
As per the MIB. |
saviObjectsSystemFilteringCount (1.3.6.1.2.1.4.40.1.1.1.16) |
read-only |
Unsigned32 |
Number of filtering entries. |
As per the MIB. |
saviObjectsPortTable
About this table
Use this table to configure SAVI parameters on interfaces.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are saviObjectsPortIPVersion and saviObjectsPortIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
saviObjectsPortIPVersion (1.3.6.1.2.1.4.40.1.2.1.1) |
not-accessible |
INTEGER |
IP version |
As per the MIB. |
saviObjectsPortIfIndex (1.3.6.1.2.1.4.40.1.2.1.2) |
not-accessible |
Integer32 |
Integer32 (1..2147483647) |
Interface index. |
As per the MIB. |
saviObjectsPortValidatingAttr (1.3.6.1.2.1.4.40.1.2.1.3) |
read-write |
INTEGER |
Status of SAVI on the interface. |
As per the MIB. |
saviObjectsPortDhcpTrustAttr (1.3.6.1.2.1.4.40.1.2.1.4) |
read-write |
INTEGER |
Whether the interface trusts DHCP packets. |
As per the MIB. |
saviObjectsPortTrustAttr (1.3.6.1.2.1.4.40.1.2.1.5) |
read-write |
INTEGER |
Whether the interface trusts any packets. |
As per the MIB. |
saviObjectsPortDhcpSnoopingAttr (1.3.6.1.2.1.4.40.1.2.1.6) |
read-write |
INTEGER |
Whether the interface creates bindings based on DHCPv6 snooping. |
As per the MIB. |
saviObjectsPortDataSnoopingAttr (1.3.6.1.2.1.4.40.1.2.1.7) |
read-write |
INTEGER |
Whether the interface creates bindings based on data snooping. |
As per the MIB. |
saviObjectsPortFilteringNum (1.3.6.1.2.1.4.40.1.2.1.8) |
read-write |
Unsigned32 |
Maximum filtering entry number of the interface. |
As per the MIB. |
saviObjectsBindingTable
About this table
Use this table to configure binding entries.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are saviObjectsBindingIpAddressType, saviObjectsBindingType, saviObjectsBindingIfIndex, and saviObjectsBindingIpAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
saviObjectsBindingIpAddressType (1.3.6.1.2.1.4.40.1.3.1.1) |
not-accessible |
INTEGER |
unknown(0) ipv4(1) ipv6(2) ipv4z(3) ipv6z(4) dns(16) |
IP version. |
As per the MIB. |
saviObjectsBindingType (1.3.6.1.2.1.4.40.1.3.1.2) |
not-accessible |
INTEGER |
manual(1) slaac(2) dhcp(3) send(4) |
Binding type. |
As per the MIB. |
saviObjectsBindingIfIndex (1.3.6.1.2.1.4.40.1.3.1.3) |
not-accessible |
Integer32 |
Interface index. |
As per the MIB. |
saviObjectsBindingIpAddress (1.3.6.1.2.1.4.40.1.3.1.4) |
not-accessible |
OCTET STRING |
OCTET STRING (0..255) |
IP address. |
As per the MIB. |
saviObjectsBindingMacAddr (1.3.6.1.2.1.4.40.1.3.1.5) |
read-create |
OCTET STRING |
OCTET STRING (6) |
MAC address. |
As per the MIB. |
saviObjectsBindingState (1.3.6.1.2.1.4.40.1.3.1.6) |
read-create |
INTEGER |
nO-BIND(1) iNIT-BIND(2) bOUND(3) dETECTION(4) rECOVERY(5) vERIFY(6) tENTATIVE(7) vALID(8) tESTING-TP-LT(9) tESTING-VP(10) tESTING-VPP(11) tENTATIVE-NUD(12) tENTATIVE-DAD(13) |
Binding status. |
As per the MIB. |
saviObjectsBindingLifetime (1.3.6.1.2.1.4.40.1.3.1.7) |
read-create |
INTEGER |
Remaining lifetime of the entry. |
As per the MIB. |
saviObjectsBindingCreationtime (1.3.6.1.2.1.4.40.1.3.1.8) |
read-create |
OCTET STRING |
OCTET STRING (8 11) |
Time when the entry was created. |
As per the MIB. |
saviObjectsBindingTID (1.3.6.1.2.1.4.40.1.3.1.9) |
read-create |
INTEGER |
Standard MIB values. |
Transaction ID. |
As per the MIB. |
saviObjectsBindingRowStatus (1.3.6.1.2.1.4.40.1.3.1.10) |
read-create |
INTEGER |
active(1) notInService(2) notReady(3) createAndGo(4) createAndWait(5) destroy(6) |
Status of this row. |
As per the MIB. |
saviObjectsFilteringTable
About this table
Use this table to configure filtering entries.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are saviObjectsFilteringIpAddressType, saviObjectsFilteringIfIndex, and saviObjectsFilteringIpAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
saviObjectsFilteringIpAddressType (1.3.6.1.2.1.4.40.1.4.1.1) |
not-accessible |
INTEGER |
IP address type of the filtering source IP address. |
As per the MIB. |
saviObjectsFilteringIfIndex (1.3.6.1.2.1.4.40.1.4.1.2) |
not-accessible |
Integer32 |
Interface index. |
As per the MIB. |
saviObjectsFilteringIpAddress (1.3.6.1.2.1.4.40.1.4.1.3) |
not-accessible |
OCTET STRING |
Filtering source IP address. |
As per the MIB. |
saviObjectsFilteringMacAddr (1.3.6.1.2.1.4.40.1.4.1.4) |
read-only |
OCTET STRING |
OCTET STRING (6) |
As per the MIB. |
saviObjectsCountTable
About this table
Use this table to obtain SAVI packet filtering statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are saviObjectsCountIPVersion and saviObjectsCountIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
saviObjectsCountIPVersion (1.3.6.1.2.1.4.40.1.5.1.1) |
not-accessible |
INTEGER |
IP version. |
Only supports ipv6(2). |
saviObjectsCountIfIndex (1.3.6.1.2.1.4.40.1.5.1.2) |
not-accessible |
Integer32 |
Interface index. |
As per the MIB. |
saviObjectsCountFilterPkts (1.3.6.1.2.1.4.40.1.5.1.3) |
read-only |
Counter64 |
Counter64 (1.. 18446744073709551616) |
Number of spoofed packets filtered by SAVI. |
As per the MIB. |
saviObjectsCountFilterOctets (1.3.6.1.2.1.4.40.1.5.1.4) |
read-only |
Counter64 |
Byte count for spoofed packets filtered by SAVI. |
As per the MIB. |
