03-HH3C-MACSEC-MIB | 46.61 KB |
HH3C-MACSEC-MIB
About this MIB
Use this MIB to configure MACsec.
MIB file name
hh3c-macsec.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMACsec(163)
Tabular objects
hh3cMACsecCFGPortTable
About this table
Use this table to obtain or configure preshared key settings for MACsec-capable ports.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
You must specify hh3cMACsecCFGPortPSKCKNName and hh3cMACsecCFGPortPSKCAKValue in pairs in an SNMP request.
The hh3cMACsecCFGPortPSKCAKValue object is confidential. N/A is returned for the read operation.
Columns
The table index is hh3cMACsecCFGPortIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACsecCFGPortIndex (1.3.6.1.4.1.25506.2.163.1.1.1.1) |
not-accessible |
InterfaceIndex |
Standard MIB values. |
Interface index. |
As per the MIB. |
hh3cMACsecCFGPortPSKCKNName (1.3.6.1.4.1.25506.2.163.1.1.1.2) |
read-write |
OCTET STRING |
OCTET STRING (0..128) |
CAK name. |
Octet string, 0 to 64 characters, an even number of hexadecimal characters. |
hh3cMACsecCFGPortPSKCAKValue (1.3.6.1.4.1.25506.2.163.1.1.1.3) |
read-write |
OCTET STRING |
CAK value. |
Notifications
hh3cMACsecTimeout
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.163.2.0.1 |
MACsec session timeout was detected on the interface. |
Informational |
Warning |
1.3.6.1.4.1.25506.2.163.2.0.1 (hh3cMACsecTimeoutResume) |
ON |
This notification is generated when MACsec session timeout was detected on the interface.
Status control
This notification cannot be disabled.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.2.2.1.1 (ifIndex) |
Interface index. |
No |
Integer32 |
Integer32 (1..2147483647) |
1.3.6.1.2.1.2.2.1.2 (ifDescr) |
Local interface name. |
No |
OCTET STRING |
OCTET STRING (0..255) |
1.3.6.1.4.1.25506.2.163.2.1.1 (hh3cMACsecDeviceRole) |
Local MACsec device role. |
No |
INTEGER |
unknown(0), server(1), client(2) |
Recommended action
Troubleshoot the link where the MACsec interface resides.
If the issue persists, contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
The MACsec MKA session was resumed on the interface. |
Informational |
ON |
This notification is generated when the MACsec MKA session was resumed on the interface.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
No |
Integer32 |
No |
OCTET STRING |
No |
INTEGER |
Recommended action
No action is required.
