10-RADIUS-AUTH-CLIENT-MIB | 44.33 KB |
About this MIB
Use this MIB to collect statistics about authentication packets of different types that a RADIUS client receives from RADIUS servers.
MIB file name
radius-auth-client.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).radiusMIB(67).radiusAuthentication(1).radiusAuthClientMIB(2)
Scalar objects
radiusAuthClient
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
radiusAuthClientInvalidServerAddresses (1.3.6.1.2.1.67.1.2.1.1.1) |
read-only |
Counter32 |
Standard MIB values. |
Number of unrecognizable IP addresses of authentication servers. |
As per the MIB. |
radiusAuthClientIdentifier (1.3.6.1.2.1.67.1.2.1.1.2) |
read-only |
SnmpAdminString |
OCTET STRING (SIZE (0..255)) |
ID of a client. |
As per the MIB. |
Tabular objects
radiusAuthServerTable
About this table
This table contains the statistics about authentication packets that a RADIUS client receives from a RADIUS server.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is radiusAuthServerIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
radiusAuthServerIndex (1.3.6.1.2.1.67.1.2.1.1.3.1.1) |
not-accessible |
Integer32 |
1..2147483647 |
Index of an authentication server. |
As per the MIB. |
radiusAuthServerAddress (1.3.6.1.2.1.67.1.2.1.1.3.1.2) |
read-only |
IpAddress |
IP address of the authentication server. |
As per the MIB. |
radiusAuthClientServerPortNumber (1.3.6.1.2.1.67.1.2.1.1.3.1.3) |
read-only |
Integer32 |
0..65535 |
Port number of the authentication server. |
As per the MIB. |
radiusAuthClientRoundTripTime (1.3.6.1.2.1.67.1.2.1.1.3.1.4) |
read-only
TimeTicks |
TimeTick |
Round trip time. |
As per the MIB. |
radiusAuthClientAccessRequests (1.3.6.1.2.1.67.1.2.1.1.3.1.5) |
read-only |
Counter32 |
Number of access requests sent to the server. |
As per the MIB. |
radiusAuthClientAccessRetransmissions (1.3.6.1.2.1.67.1.2.1.1.3.1.6) |
read-only |
Counter32 |
Number of access requests retransmitted. |
As per the MIB. |
radiusAuthClientAccessAccepts (1.3.6.1.2.1.67.1.2.1.1.3.1.7) |
read-only |
Counter32 |
Number of Access-Accept packets received. |
As per the MIB. |
radiusAuthClientAccessRejects (1.3.6.1.2.1.67.1.2.1.1.3.1.8) |
read-only |
Counter32 |
Number of Access-Reject packets received. |
As per the MIB. |
radiusAuthClientAccessChallenges (1.3.6.1.2.1.67.1.2.1.1.3.1.9) |
read-only |
Counter32 |
Number of Access-Challenge packets received. |
As per the MIB. |
radiusAuthClientMalformedAccessResponses (1.3.6.1.2.1.67.1.2.1.1.3.1.10) |
read-only |
Counter32 |
Number of malformed access responses received. |
As per the MIB. |
radiusAuthClientBadAuthenticators (1.3.6.1.2.1.67.1.2.1.1.3.1.11) |
read-only |
Counter32 |
Number of bad authenticators. |
As per the MIB. |
radiusAuthClientPendingRequests (1.3.6.1.2.1.67.1.2.1.1.3.1.12) |
read-only |
Gauge32 |
Number of pending authentication requests. |
As per the MIB. |
radiusAuthClientTimeouts (1.3.6.1.2.1.67.1.2.1.1.3.1.13) |
read-only |
Counter32 |
Number of timed out access requests. |
As per the MIB. |
radiusAuthClientUnknownTypes (1.3.6.1.2.1.67.1.2.1.1.3.1.14) |
read-only |
Counter32 |
Number of packets with unknown types. |
As per the MIB. |
radiusAuthClientPacketsDropped (1.3.6.1.2.1.67.1.2.1.1.3.1.15) |
read-only |
Counter32 |
Number of packets discarded. |
As per the MIB. |
