06-IEEE8021-PAE-MIB | 62.09 KB |
IEEE8021-PAE-MIB
About this MIB
Use this MIB to manage 802.1X basic settings.
MIB file name
ieee8021-pae.mib
Root object
iso(1).std(0).iso8802(8802).ieee802dot1(1).ieee802dot1mibs(1).ieee8021paeMIB(1)
Scalar objects
dot1xPaeSystemAuthControl
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1xPaeSystemAuthControl (1.0.8802.1.1.1.1.1.1) |
read-write |
INTEGER |
enabled(1), disabled(2) |
Enabling status of 802.1X |
As per the MIB. |
Tabular objects
dot1xPaePortTable
About this table
Use this table to configure or obtain information about 802.1X parameters on ports.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is dot1xPaePortNumber.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1xPaePortNumber (1.0.8802.1.1.1.1.1.2.1.1) |
not-accessible |
InterfaceIndex |
Integer32 (1..2147483647) |
Port number. |
As per the MIB. |
dot1xPaePortProtocolVersion (1.0.8802.1.1.1.1.1.2.1.2) |
read-only |
Unsigned32 |
Standard MIB values. |
Protocol version. |
As per the MIB. |
dot1xPaePortCapabilities (1.0.8802.1.1.1.1.1.2.1.3) |
read-only |
BITS |
dot1xPaePortAuthCapable(0), dot1xPaePortSuppCapable(1) |
PAE capabilities supported by the port. |
As per the MIB. |
dot1xPaePortInitialize (1.0.8802.1.1.1.1.1.2.1.4) |
read-write |
TruthValue |
true(1), false(2) |
Port initialization control. |
Not supported |
dot1xPaePortReauthenticate (1.0.8802.1.1.1.1.1.2.1.5) |
read-write |
TruthValue |
true(1), false(2) |
Port reauthentication control. |
As per the MIB. |
dot1xAuthConfigTable
About this table
Use this table to configure or obtain information about 802.1X authentication parameters.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1xAuthPaeState (1.0.8802.1.1.1.1.2.1.1.1) |
read-only |
INTEGER |
initialize(1), disconnected(2), connecting(3), authenticating(4), authenticated(5), aborting(6), held(7), forceAuth(8), forceUnauth(9) |
Current value of the Authenticator PAE state machine. |
Supports only initialize(1), forceAuth(8), and forceUnauth(9). |
dot1xAuthBackendAuthState (1.0.8802.1.1.1.1.2.1.1.2) |
read-only |
INTEGER |
request(1), response(2), success(3), fail(4), timeout(5) , idle(6), initialize(7) |
Current state of the Backend Authentication state machine. |
As per the MIB. |
dot1xAuthAdminControlledDirections (1.0.8802.1.1.1.1.2.1.1.3) |
read-write |
INTEGER |
both(0), in(1) |
Current value of the administrative controlled directions parameter for the port. |
Supports only the read operation. |
dot1xAuthOperControlledDirections (1.0.8802.1.1.1.1.2.1.1.4) |
read-only |
INTEGER |
both(0), in(1) |
Current value of the operational controlled directions parameter for the port. |
As per the MIB. |
dot1xAuthAuthControlledPortStatus (1.0.8802.1.1.1.1.2.1.1.5) |
read-only |
INTEGER |
authorized(1), unauthorized(2) |
Current value of the controlled port status parameter for the port. |
Supports only for port-based access control. |
dot1xAuthAuthControlledPortControl (1.0.8802.1.1.1.1.2.1.1.6) |
read-write |
INTEGER |
unauthforce(1), auto(2), authforce(3) |
Current value of the controlled port control parameter for the port. |
As per the MIB. |
dot1xAuthQuietPeriod (1.0.8802.1.1.1.1.2.1.1.7) |
read-write |
Unsigned32 |
Quiet period. |
Supports only the read operation. The value is fixed at 0. To modify the quiet period, use the private MIB of 802.1X. |
dot1xAuthTxPeriod (1.0.8802.1.1.1.1.2.1.1.8) |
read-write |
Unsigned32 |
Username request timeout timer. |
Supports only the read operation. The value is fixed at 0. To modify the username request timeout timer, use the private MIB of 802.1X. |
dot1xAuthSuppTimeout (1.0.8802.1.1.1.1.2.1.1.9) |
read-write |
Unsigned32 |
Client timeout timer. |
Supports only the read operation. The value is fixed at 0. To modify the client timeout timer, use the private MIB of 802.1X. |
dot1xAuthServerTimeout (1.0.8802.1.1.1.1.2.1.1.10) |
read-write |
Unsigned32 |
Server timeout timer. |
Supports only the read operation. The value is fixed at 0. To modify the server timeout timer, use the private MIB of 802.1X. |
dot1xAuthMaxReq (1.0.8802.1.1.1.1.2.1.1.11) |
read-write |
Unsigned32 |
Maximum number of attempts for sending an authentication request to a client. |
Supports only the read operation. The value is fixed at 0. To modify the value, use the private MIB of 802.1X. |
dot1xAuthReAuthPeriod (1.0.8802.1.1.1.1.2.1.1.12) |
read-write |
Unsigned32 |
Reauthentication interval. |
Value range: 0 and 60 to 86400, in seconds. Default: 0 seconds. |
dot1xAuthReAuthEnabled (1.0.8802.1.1.1.1.2.1.1.13) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of periodic reauthentication. |
As per the MIB. |
dot1xAuthKeyTxEnabled (1.0.8802.1.1.1.1.2.1.1.14) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of key transmission. |
dot1xAuthStatsTable
About this table
This table contains 802.1X authentication statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1xAuthEapolFramesRx (1.0.8802.1.1.1.1.2.2.1.1) |
read-only |
Counter32 |
Number of received EAPOL frames. |
As per the MIB. |
dot1xAuthEapolFramesTx (1.0.8802.1.1.1.1.2.2.1.2) |
read-only |
Counter32 |
Number of sent EAPOL frames. |
As per the MIB. |
dot1xAuthEapolStartFramesRx (1.0.8802.1.1.1.1.2.2.1.3) |
read-only |
Counter32 |
Number of received EAPOL-Start frames. |
As per the MIB. |
dot1xAuthEapolLogoffFramesRx (1.0.8802.1.1.1.1.2.2.1.4) |
read-only |
Counter32 |
Number of received EAPOL-LogOff frames. |
As per the MIB. |
dot1xAuthEapolRespIdFramesRx (1.0.8802.1.1.1.1.2.2.1.5) |
read-only |
Counter32 |
Number of received EAP-Response/Identity frames. |
As per the MIB. |
dot1xAuthEapolRespFramesRx (1.0.8802.1.1.1.1.2.2.1.6) |
read-only |
Counter32 |
Number of received EAPOL-Response frames. |
As per the MIB. |
dot1xAuthEapolReqIdFramesTx (1.0.8802.1.1.1.1.2.2.1.7) |
read-only |
Counter32 |
Number of sent EAP-Request/Identity frames. |
As per the MIB. |
dot1xAuthEapolReqFramesTx (1.0.8802.1.1.1.1.2.2.1.8) |
read-only |
Counter32 |
Number of sent EAPOL-Request frames. |
As per the MIB. |
dot1xAuthInvalidEapolFramesRx (1.0.8802.1.1.1.1.2.2.1.9) |
read-only |
Counter32 |
Number of received invalid EAPOL frames. |
As per the MIB. |
dot1xAuthEapLengthErrorFramesRx (1.0.8802.1.1.1.1.2.2.1.10) |
read-only |
Counter32 |
Number of received frames with invalid length. |
Not supported. |
dot1xAuthLastEapolFrameVersion (1.0.8802.1.1.1.1.2.2.1.11) |
read-only |
Unsigned32 |
Protocol version number carried in the most recently received EAPOL frame. |
As per the MIB. |
dot1xAuthLastEapolFrameSource (1.0.8802.1.1.1.1.2.2.1.12) |
read-only |
MacAddress |
OCTET STRING (6) |
Source MAC address carried in the most recently received EAPOL frame. |
Not supported. |
dot1xAuthSessionStatsTable
About this table
Use this table to obtain 802.1X authentication session statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is dot1xAuthSessionUserName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1xAuthSessionOctetsRx (1.0.8802.1.1.1.1.2.4.1.1) |
read-only |
Counter64 |
Number of received octets. |
As per the MIB. |
dot1xAuthSessionOctetsTx (1.0.8802.1.1.1.1.2.4.1.2) |
read-only |
Counter64 |
Number of sent octets. |
As per the MIB. |
dot1xAuthSessionFramesRx (1.0.8802.1.1.1.1.2.4.1.3) |
read-only |
Counter64 |
Number of received frames. |
As per the MIB. |
dot1xAuthSessionFramesTx (1.0.8802.1.1.1.1.2.4.1.4) |
read-only |
Counter64 |
Number of sent frames. |
As per the MIB. |
dot1xAuthSessionId (1.0.8802.1.1.1.1.2.4.1.5) |
read-only |
SnmpAdminString |
OCTET STRING (0..65535) |
Session ID. |
As per the MIB. |
dot1xAuthSessionAuthenticMethod (1.0.8802.1.1.1.1.2.4.1.6) |
read-only |
INTEGER |
remoteAuthServer(1), localAuthServer(2) |
Authentication method. |
Not supported |
dot1xAuthSessionTime (1.0.8802.1.1.1.1.2.4.1.7) |
read-only |
TimeTicks |
Session duration. |
As per the MIB. |
dot1xAuthSessionTerminateCause (1.0.8802.1.1.1.1.2.4.1.8) |
read-only |
INTEGER |
supplicantLogoff(1), portFailure(2), supplicantRestart(3), reauthFailed(4), authControlForceUnauth(5), portReInit(6), portAdminDisabled(7), notTerminatedYet(999) |
Session termination cause. |
Not supported |
dot1xAuthSessionUserName (1.0.8802.1.1.1.1.2.4.1.9) |
read-only |
SnmpAdminString |
Session user name. |
As per the MIB. |
