06-IEEE8021-CN-MIB | 90.34 KB |
IEEE8021-CN-MIB
About this MIB
Use this MIB to configure QCN to control congestion on a CP, including CND settings and congestion detection settings
MIB file name
ieee8021-cn.mib
Root object
iso(1).org(3).oid_ieee(111).oid_standards-association-numbered-series-standards(2).oid_lan-man-stds(802). oid_ieee802dot1(1).oid_ieee802dot1mibs(1).ieee8021CnMib(18)
Tabular objects
ieee8021CnGlobalTable
About this table
This table configures global QCN settings.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is ieee8021CnGlobalComponentId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021CnGlobalComponentId (1.3.111.2.802.1.1.18.1.1.1.1) |
not-accessible |
IEEE8021PbbComponentIdentifier |
Standard MIB values. |
Component ID. |
The value is fixed at 1. |
ieee8021CnGlobalMasterEnable (1.3.111.2.802.1.1.18.1.1.1.2) |
read-write |
TruthValue |
· true(1) · false(2) |
Global QCN state. |
As per the MIB. |
ieee8021CnGlobalCnmTransmitPriority (1.3.111.2.802.1.1.18.1.1.1.3) |
read-write |
IEEE8021PriorityValue |
Priority of outgoing CNMs. |
Not supported.. |
ieee8021CnGlobalDiscardedFrames (1.3.111.2.802.1.1.18.1.1.1.4) |
read-only |
Counter64 |
Number of frames discarded from full CP queues. |
Not supported.. |
ieee8021CnErroredPortTable
About this table
This table obtains the index of the interface on which a CNPV is configured as an alternate priority.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ieee8021CnEpComponentId, ieee8021CnEpPriority, and ieee8021CnEpIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021CnEpComponentId (1.3.111.2.802.1.1.18.1.2.1.1) |
not-accessible |
Component ID. |
ieee8021CnEpPriority (1.3.111.2.802.1.1.18.1.2.1.2) |
not-accessible |
Alternate priority. |
As per the MIB. |
ieee8021CnEpIfIndex (1.3.111.2.802.1.1.18.1.2.1.3) |
read-only |
InterfaceIndex |
Interface index. |
As per the MIB. |
ieee8021CnCompntPriTable
About this table
This table configures global CND settings.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are ieee8021CnComPriComponentId and ieee8021CnComPriPriority.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021CnComPriComponentId (1.3.111.2.802.1.1.18.1.3.1.1) |
not-accessible |
Component ID. |
ieee8021CnComPriPriority (1.3.111.2.802.1.1.18.1.3.1.2) |
not-accessible |
802.1p priority. |
As per the MIB. |
ieee8021CnComPriDefModeChoice (1.3.111.2.802.1.1.18.1.3.1.3) |
read-create |
Ieee8021CnControlChoice |
Defense mode choosing mode. |
As per the MIB. |
ieee8021CnComPriAlternatePriority (1.3.111.2.802.1.1.18.1.3.1.4) |
read-create |
Alternate priority in Admin mode. |
As per the MIB. |
ieee8021CnComPriAutoAltPri (1.3.111.2.802.1.1.18.1.3.1.5) |
read-only |
Alternate priority in Auto mode. |
As per the MIB. |
ieee8021CnComPriAdminDefenseMode (1.3.111.2.802.1.1.18.1.3.1.6) |
read-create |
Ieee8021CnDefenseMode |
Defense mode in Admin mode. |
As per the MIB. |
ieee8021CnComPriCreation (1.3.111.2.802.1.1.18.1.3.1.7) |
read-create |
INTEGER |
· cncpAutoEnable(1) · cncpAutoDisable(2) |
Creation method. |
Not supported. |
ieee8021CnComPriLldpInstanceChoice (1.3.111.2.802.1.1.18.1.3.1.8) |
read-create |
Ieee8021CnLldpChoice |
LLDP instance choosing mode. |
Not supported. |
ieee8021CnComPriLldpInstanceSelector (1.3.111.2.802.1.1.18.1.3.1.9) |
read-create |
LldpV2DestAddressTableIndex |
LLDP instance index. |
Not supported. |
ieee8021CnComPriRowStatus (1.3.111.2.802.1.1.18.1.3.1.10) |
read-create |
RowStatus |
Row status. |
· active(1) · createAndGo(4) · destroy(6) |
ieee8021CnPortPriTable
About this table
This table configures CND settings on an interface.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are ieee8021CnPortPriComponentId, ieee8021CnPortPriority, and ieee8021CnPortPriIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021CnPortPriComponentId (1.3.111.2.802.1.1.18.1.4.1.1) |
not-accessible |
Component ID. |
ieee8021CnPortPriority (1.3.111.2.802.1.1.18.1.4.1.2) |
not-accessible |
802.1p priority. |
As per the MIB. |
ieee8021CnPortPriIfIndex (1.3.111.2.802.1.1.18.1.4.1.3) |
not-accessible |
InterfaceIndex |
Interface index. |
As per the MIB. |
ieee8021CnPortPriDefModeChoice (1.3.111.2.802.1.1.18.1.4.1.4) |
read-write |
Priority value choosing mode. |
As per the MIB. |
ieee8021CnPortPriAdminDefenseMode (1.3.111.2.802.1.1.18.1.4.1.5) |
read-write |
As per the MIB. |
ieee8021CnPortPriAutoDefenseMode (1.3.111.2.802.1.1.18.1.4.1.6) |
read-only |
Negotiated defense mode in Auto mode. |
As per the MIB. |
ieee8021CnPortPriLldpInstanceChoice (1.3.111.2.802.1.1.18.1.4.1.7) |
read-write |
Not supported. |
ieee8021CnPortPriLldpInstanceSelector (1.3.111.2.802.1.1.18.1.4.1.8) |
read-write |
Selected LLDP instance. |
Not supported. |
ieee8021CnPortPriAlternatePriority (1.3.111.2.802.1.1.18.1.4.1.9) |
read-write |
As per the MIB. |
ieee8021CnCpTable
About this table
This table obtains congestion detection settings.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ieee8021CnCpComponentId, ieee8021CnCpIfIndex, and ieee8021CnCpIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021CnCpComponentId (1.3.111.2.802.1.1.18.1.5.1.1 ) |
not-accessible |
Component ID. |
ieee8021CnCpIfIndex (1.3.111.2.802.1.1.18.1.5.1.2 ) |
not-accessible |
InterfaceIndex |
Interface index. |
As per the MIB. |
ieee8021CnCpIndex (1.3.111.2.802.1.1.18.1.5.1.3 ) |
not-accessible |
Unsigned32 |
1..4096 |
CP index. |
As per the MIB. |
ieee8021CnCpPriority (1.3.111.2.802.1.1.18.1.5.1.4 ) |
read-only |
802.1p priority. |
As per the MIB. |
ieee8021CnCpMacAddress (1.3.111.2.802.1.1.18.1.5.1.5 ) |
read-only |
MacAddress |
Source MAC address of outgoing CNMs. |
Not supported. |
ieee8021CnCpIdentifier (1.3.111.2.802.1.1.18.1.5.1.6 ) |
read-only |
OCTET STRING |
SIZE(8) |
CPID in CNMs. |
Not supported. |
ieee8021CnCpQueueSizeSetPoint (1.3.111.2.802.1.1.18.1.5.1.7 ) |
read-write |
Unsigned32 |
100..4294967295 |
Desired queue length. |
Supports only the read operation. |
ieee8021CnCpFeedbackWeight (1.3.111.2.802.1.1.18.1.5.1.8) |
read-write |
Integer32 |
-10..10 |
Weight value. |
ieee8021CnCpMinSampleBase (1.3.111.2.802.1.1.18.1.5.1.9) |
read-write |
Unsigned32 |
10000..4294967295 |
Minimum number of octets to enqueue in the CP's queue between transmissions of CNMs. |
Not supported. |
ieee8021CnCpDiscardedFrames (1.3.111.2.802.1.1.18.1.5.1.10) |
read-only |
Counter64 |
Number of data frames discarded. |
As per the MIB. |
ieee8021CnCpTransmittedFrames (1.3.111.2.802.1.1.18.1.5.1.11) |
read-only |
Counter64 |
Number of data frames passed on to the queue. |
As per the MIB. |
ieee8021CnCpTransmittedCnms (1.3.111.2.802.1.1.18.1.5.1.12) |
read-only |
Counter64 |
Number of CNMs transmitted. |
As per the MIB. |
ieee8021CnCpMinHeaderOctets (1.3.111.2.802.1.1.18.1.5.1.13) |
read-write |
Unsigned32 |
0..64 |
Minimum number of octets to be returned in a CNM |
Not supported. |
