02-HH3C-CBQOS2-MIB | 220.72 KB |
hh3cCBQoSClassifierCfgInfoTable
hh3cCBQoSMatchRuleCfgInfoTable
hh3cCBQoSNestPolicyCfgInfoTable
hh3cCBQoSColoredRemarkCfgTable
hh3cCBQoSColorMapDpCfgInfoTable
hh3cCBQoSPolicyClassCfgInfoTable
hh3cCBQoSNestPolicyApplyObjectTable
hh3cCBQoSClassMatchRunInfoTable
hh3cCBQoSAccountingRunInfoTable
hh3cCBQoSPolicyAccRunInfoTable
HH3C-CBQOS2-MIB
About this MIB
Use this MIB to configure class-based QoS (CBQoS).
CBQoS applies different service quality levels to different classes of packets, enabling multiple service support on the network.
MIB file name
hh3c-cbqos2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cQos2(65)
Scalar objects
h3cCBQoSClassifierIndexNext
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSClassifierIndexNext (1.3.6.1.4.1.25506.2.65.2.1.1.1) |
read-only |
Integer32 |
Standard MIB values. |
Index of the next available traffic class. |
As per the MIB. |
h3cCBQoSBehaviorIndexNext
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSBehaviorIndexNext (1.3.6.1.4.1.25506.2.65.2.1.2.1) |
read-only |
Integer32 |
Index of the next available traffic behavior. |
As per the MIB. |
h3cCBQoSPolicyIndexNext
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSPolicyIndexNext (1.3.6.1.4.1.25506.2.65.2.1.3.1) |
read-only |
Integer32 |
Index of the next available QoS policy. |
As per the MIB. |
h3cCBQoSApplyingStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSApplyingStatus (1.3.6.1.4.1.25506.2.65.2.1.6.1) |
read-only |
INTEGER |
· idle(1) · busy(2) |
QoS policy application status. |
As per the MIB. |
Tabular objects
About this table
This table configures a traffic class.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is h3cCBQoSClassifierIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSClassifierIndex (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.1) |
not-accessible |
Integer32 |
Traffic class index. |
As per the MIB. |
hh3cCBQoSClassifierName (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.2) |
read-create |
OCTET STRING |
SIZE (1..31) |
Traffic class name. |
As per the MIB. |
hh3cCBQoSClassifierRuleCount (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.3) |
read-only |
Integer32 |
Number of match criteria. |
As per the MIB. |
hh3cCBQoSClassifierOperator (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.4) |
read-create |
INTEGER |
· and(1) · or(2) |
Relationship among match criteria. |
As per the MIB. |
hh3cCBQoSClassifierLayer (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.5) |
read-create |
INTEGER |
· unavailable(1) · l2(2) · l3(3) · both(4) |
Protocol layer for the traffic class. |
This object is not configurable and is fixed at unavailable(1). |
hh3cCBQoSClassifierType (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.6) |
read-only |
INTEGER |
· systemDefined(1) · userDefined(2) |
Traffic class type. |
Implementation varies by product. |
hh3cCBQosClassifierMatchRuleNextIndex (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.7) |
read-only |
Integer32 |
Index used to create a match criterion. |
If the value is 2147483647, the a match criterion cannot be created. |
hh3cCBQoSClassifierRowStatus (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.8) |
read-create |
RowStatus |
Row status. |
· active(1) · createAndGo(4) · destroy(6) |
About this table
This table configures match criteria for a traffic class.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are h3cCBQoSClassifierIndex and h3cCBQoSMatchRuleIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSMatchRuleIndex (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.1) |
not-accessible |
Integer32 |
Match criterion index. |
As per the MIB. |
hh3cCBQoSMatchRuleIfNot (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.2) |
read-create |
INTEGER |
· match(1) · notMatch (2) |
Match attribute. |
hh3cCBQoSMatchRuleType (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.3) |
read-create |
MatchRuleType |
Match criterion type. |
hh3cCBQoSMatchRuleStringValue (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.4) |
read-create |
OCTET STRING |
SIZE (1..255) |
Match criterion type string value. The corresponding match criterion types include: · IPv4acl · MACACL · UserACL · IPv6acl · Source-MAC · Destination-MAC · Classifier · Inbound-interface · VlanID · SourceIp · MplsLabel · SecondMplsLabel |
As per the MIB. |
hh3cCBQoSMatchRuleIntValue1 (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.5) |
read-create |
Unsigned32 |
Match criterion type integer value. The corresponding match criterion types include: · IPv4acl · MACACL · UserACL · IPv6acl · Software QoS · Hardware Qos · RtpPort · IpPrec · Dscp · Vlan8021p · Mplsexp · SourceIp · QosLocalID · AtmClp · FrDe · LocalPrecedence · DropPriority · ServiceDot1p · SecondMplsExp · PacketLength · ForwardingLayer |
As per the MIB. |
hh3cCBQoSMatchRuleIntValue2 (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.6) |
read-create |
Unsigned32 |
Match criterion type integer value. The corresponding match criterion types include: · RTP-PORT · DSCP · PacketLength |
As per the MIB. |
hh3cCBQoSMatchIpAddressType (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.7) |
read-create |
InetAddressType |
Match criterion type integer value. The corresponding match criterion type is SourceIP. |
Not supported. The value is fixed at unknown(0). |
hh3cCBQoSMatchIpAddress (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.8) |
read-create |
InetAddress |
Match criterion type integer value. The corresponding integer value is a source IP address. |
Not supported. The value is fixed at zero length. |
hh3cCBQoSMatchRuleRowStatus (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.9) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSMatchCpProtoCfgTable
About this table
Use this MIB to configure a match criterion to match protocol traffic to a control plane.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSMatchCpProtoIfNot (1.3.6.1.4.1.25506.2.65.2.1.1.4.1.1) |
read-create |
INTEGER |
· match(1) · matchNot(2) |
Match attribute. |
hh3cCBQoSMatchCpProtoValue (1.3.6.1.4.1.25506.2.65.2.1.1.4.1.2) |
read-create |
OCTET STRING |
SIZE (0..255) |
Control plane protocol. |
hh3cCBQoSMatchCpProtoRowStatus (1.3.6.1.4.1.25506.2.65.2.1.1.4.1.3) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSMatchCpGroupCfgTable
About this table
Use this MIB to configure a match criterion to match protocol group traffic to a control plane.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSMatchCpGroupIfNot (1.3.6.1.4.1.25506.2.65.2.1.1.5.1.1) |
read-create |
INTEGER |
Match attribute. |
hh3cCBQoSMatchCpGroupValue (1.3.6.1.4.1.25506.2.65.2.1.1.5.1.2) |
read-create |
INTEGER |
· critical(1) · important(2) · management(3) · normal(4) · redirect(5) · monitor(6) · exception(7) |
Control plane protocol group. |
hh3cCBQoSMatchCpGroupRowStatus (1.3.6.1.4.1.25506.2.65.2.1.1.5.1.3) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSBehaviorCfgInfoTable
About this table
This table configures match criteria for a traffic behavior.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is h3cCBQoSBehaviorIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSBehaviorIndex (1.3.6.1.4.1.25506.2.65.2.1.2.2.1.1) |
not-accessible |
Integer32 |
Traffic behavior index. |
As per the MIB. |
hh3cCBQoSBehaviorName (1.3.6.1.4.1.25506.2.65.2.1.2.2.1.2) |
read-create |
OCTET STRING |
SIZE (1..31) |
Traffic behavior name. |
As per the MIB. |
hh3cCBQoSBehaviorType (1.3.6.1.4.1.25506.2.65.2.1.2.2.1.3) |
read-only |
INTEGER |
Traffic behavior type. |
hh3cCBQoSBehaviorRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.2.1.4) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSCarCfgInfoTable
About this table
This table configures a CAR action for a traffic behavior.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSCarCir (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.1) |
read-create |
Unsigned32 |
CIR. |
hh3cCBQoSCarCbs (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.2) |
read-create |
Unsigned32 |
CBS. |
hh3cCBQoSCarEbs (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.3) |
read-create |
Unsigned32 |
EBS. |
hh3cCBQoSCarPir (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.4) |
read-create |
Unsigned32 |
PIR. |
hh3cCBQoSCarPbs (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.5) |
read-create |
Unsigned32 |
PBS. |
Not supported. The value is fixed at 4294967295. |
hh3cCBQoSCarGreenAction (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.6) |
read-create |
CarAction |
Action to take on green packets. |
hh3cCBQoSCarGreenRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.7) |
read-create |
Integer32 |
· 0..63 · 255 |
Value to mark for green packets. |
As per the MIB. |
hh3cCBQoSCarYellowAction (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.8) |
read-create |
CarAction |
Action to take on yellow packets. |
hh3cCBQoSCarYellowRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.9) |
read-create |
Integer32 |
· 0..63 · 255 |
Value to mark for yellow packets. |
As per the MIB. |
hh3cCBQoSCarRedAction (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.10) |
read-create |
CarAction |
· For VRP: Action to take on packets exceeding the CIR. · For 10G: Action to take on packets exceeding the PIR. |
hh3cCBQoSCarRedRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.11) |
read-create |
Integer32 |
· 0..63 · 255 |
Value to mark for red packets. |
As per the MIB. |
hh3cCBQoSCarPolicedPriorityMapType (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.12) |
read-create |
INTEGER |
· none (0) · policed-service-map (1) · local-precedence-dot1p-map (2) · drop-precedence-map (3) |
Priority map type. |
Not supported. The value is fixed at none(0). |
hh3cCBQoSCarRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.13) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSGtsCfgInfoTable
About this table
This table contains GTS configuration information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSGtsCir (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.1) |
read-create |
Unsigned32 |
CIR. |
hh3cCBQoSGtsCbs (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.2) |
read-create |
Unsigned32 |
CBS. |
hh3cCBQoSGtsEbs (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.3) |
read-create |
Unsigned32 |
EBS. |
hh3cCBQoSGtsQueueLength (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.4) |
read-create |
Integer32 |
1..1024 |
Queue length. |
As per the MIB. |
hh3cCBQoSGtsRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.5) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSGtsPir (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.6) |
read-create |
Unsigned32 |
PIR. |
hh3cCBQoSRemarkCfgInfoTable
About this table
This table contains marking configuration information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are h3cCBQoSBehaviorIndex and h3cCBQoSRemarkType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSRemarkType (1.3.6.1.4.1.25506.2.65.2.1.2.6.1.1) |
not-accessible |
RemarkType |
Marking type. |
hh3cCBQoSRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.6.1.2) |
read-create |
Integer32 |
0..4095 |
As per the MIB. |
hh3cCBQoSRemarkRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.6.1.3) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSQueueCfgInfoTable
About this table
This table contains queuing configuration information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSQueueType (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.1) |
read-create |
QueueType |
Queuing type. |
hh3cCBQoSQueueDropType (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.2) |
read-create |
INTEGER |
· unavailable(0) · tail-drop(1) · wred(2) |
Packet drop type. |
Not supported. |
hh3cCBQoSQueueLength (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.3) |
read-create |
Integer32 |
1..2147483647 |
Queue length. |
hh3cCBQoSQueueBandwidthUnit (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.4) |
read-create |
QueueBandwidthUnit |
Bandwidth unit. |
hh3cCBQoSQueueBandwidthValue (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.5) |
read-create |
Integer32 |
· 1..100000000 · 2147483647 |
Bandwidth value. |
hh3cCBQoSQueueCbs (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.6) |
read-create |
Integer32 |
· 32..1000000000 · 2147483647 |
CBS. |
hh3cCBQoSQueueQueueNumber (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.7) |
read-create |
INTEGER |
· unavailable(0) · a16(16) · a32(32) · a64(64) · a128(128) · a256(256) · a512(512) · a1024(1024) · a2048(2048) · a4096(4096) |
Maximum number of queues. |
hh3cCBQoSQueueCbsRatio (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.8) |
read-create |
Integer32 |
· 25..500 · 2147483647 |
Allowed burst ratio. |
hh3cCBQoSQueueRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.9) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSFirewallCfgInfoTable
About this table
This table contains firewall configuration information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSFirewallAction (1.3.6.1.4.1.25506.2.65.2.1.2.12.1.1) |
read-create |
INTEGER |
· permit(1) · deny(2) |
Firewall behavior. |
As per the MIB. |
hh3cCBQoSFirewallRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.12.1.2) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cCBQoSAccountCfgInfoTable
About this table
This table contains accounting configuration information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSAccounting (1.3.6.1.4.1.25506.2.65.2.1.2.14.1.1) |
read-create |
INTEGER |
· true(1) · false(2) |
Accounting. |
Not supported. The value is fixed at true(1). |
hh3cCBQoSAccountRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.14.1.2) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSAccountingMode (1.3.6.1.4.1.25506.2.65.2.1.2.14.1.3) |
read-create |
INTEGER |
· auto(1) · packet(2) · byte(3) · both(4) |
Accounting mode. |
hh3cCBQoSRedirectCfgInfoTable
About this table
This table configures a redirecting action for a traffic behavior.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSRedirectType (1.3.6.1.4.1.25506.2.65.2.1.2.15.1.1) |
read-create |
INTEGER |
· cpu(1) · interface(2) · nextHop(3) |
Redirecting destination. |
hh3cCBQoSRedirectIfIndex (1.3.6.1.4.1.25506.2.65.2.1.2.15.1.2) |
read-create |
Integer32 |
Interface index. |
As per the MIB. |
hh3cCBQoSRedirectIpAddressType |
read-create |
InetAddressType |
Next-hop address type. |
hh3cCBQoSRedirectIpAddress1 |
read-create |
InetAddress |
First next-hop address. |
Not supported. The value is fixed at zero-length. |
hh3cCBQoSRedirectIpAddress2 |
read-create |
InetAddress |
Second next-hop address. |
hh3cCBQoSRedirectRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.15.1.6) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSRedirectIpv6Interface1 |
read-create |
Integer32 |
Outgoing interface for the first next-hop IPv6 address. |
Not supported. The value is fixed at 0. |
hh3cCBQoSRedirectIpv6Interface2 |
read-create |
Integer32 |
Outgoing interface for the second next-hop IPv6 address. |
hh3cCBQoSRedirectIfVlanID (1.3.6.1.4.1.25506.2.65.2.1.2.15.1.9) |
read-create |
Integer32 |
0..4094|65535 |
VLAN ID. |
hh3cCBQoSMirrorCfgInfoTable
About this table
This table contains flow mirroring configuration information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSMirrorType (1.3.6.1.4.1.25506.2.65.2.1.2.17.1.1) |
read-create |
INTEGER |
· interface(1) · cpu(2) · vlan(3) |
Mirroring destination. |
hh3cCBQoSMirrorIfIndex (1.3.6.1.4.1.25506.2.65.2.1.2.17.1.2) |
read-create |
OCTET STRING |
SIZE (1..255) |
Destination interface index. |
hh3cCBQoSMirrorVlanID (1.3.6.1.4.1.25506.2.65.2.1.2.17.1.3) |
read-create |
Integer32 |
0..4094 |
Destination VLAN ID. |
hh3cCBQoSMirrorRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.17.1.4) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSNestCfgInfoTable
About this table
This table configures nesting for VLAN mapping.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSNestServiceVlanID (1.3.6.1.4.1.25506.2.65.2.1.2.18.1.1) |
read-create |
Integer32 |
· 1..4094 · 65535 |
Service provider VLAN ID. |
As per the MIB. |
hh3cCBQoSNestServiceDot1pValue (1.3.6.1.4.1.25506.2.65.2.1.2.18.1.2) |
read-create |
Integer32 |
· 0..7 · 65535 |
Outer 802.1p priority value. |
hh3cCBQoSNestCustomerVlanID |
read-create |
Integer32 |
· 1..4094 · 65535 |
Customer VLAN ID. |
Not supported. The value is fixed at 65535. |
hh3cCBQoSNestCustomerDot1pValue |
read-create |
Integer32 |
· 0..7 · 65535 |
Inner 802.1p priority value. |
hh3cCBQoSNestRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.18.1.5) |
read-create |
RowStatus |
Row status. |
About this table
This table nests a QoS policy.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSNestPolicyName (1.3.6.1.4.1.25506.2.65.2.1.2.19.1.1) |
read-create |
OCTET STRING |
SIZE (1..31) |
Nested policy name. |
As per the MIB. |
hh3cCBQoSNestPolicyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.19.1.2) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSMirrorIfCfgInfoTable
About this table
This table contains information about flow mirroring to an interface.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSMirrorIfMainIfIndex (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.1) |
not-accessible |
Integer32 |
As per the MIB. |
hh3cCBQoSMirrorIfMainIfStatus (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.2) |
read-only |
INTEGER |
· inactive(1) · active(2) |
Destination interface status. |
As per the MIB. |
hh3cCBQoSMirrorIfBackupIfIndex (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.3) |
read-create |
Integer32 |
Backup destination interface index. |
hh3cCBQoSMirrorIfBackupIfStatus (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.4) |
read-only |
INTEGER |
Backup destination interface status. |
As per the MIB. |
hh3cCBQoSMirrorIfRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.5) |
read-create |
RowStatus |
Row status. |
About this table
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are h3cCBQoSBehaviorIndex, h3cCBQoSColoredRemarkType, and h3cCBQoSColoredRemarkColor.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSColoredRemarkType (1.3.6.1.4.1.25506.2.65.2.1.2.21.1.1) |
not-accessible |
RemarkType |
Marking type. |
hh3cCBQoSColoredRemarkColor (1.3.6.1.4.1.25506.2.65.2.1.2.21.1.2) |
not-accessible |
INTEGER |
· green(1) · yellow(2) · red(3) |
Marking color. |
hh3cCBQoSColoredRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.21.1.3) |
read-create |
Integer32 |
0..4095 |
Value to mark for packets. |
As per the MIB. |
hh3cCBQoSColoredRemarkRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.21.1.4) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSPrimapCfgInfoTable
About this table
This table contains information about predefined priority maps. The system modifies the priority of matching packets according to the predefined priority map.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSPrimapColorType (1.3.6.1.4.1.25506.2.65.2.1.2.22.1.1) |
not-accessible |
INTEGER |
· noColorMap(1) · colorMap(2) |
Predefined priority map color attribute. |
h3cCBQoSPrePriMapTableType(1.3.6.1.4.1.25506.2.65.2.1.2.22.1.2) |
not-accessible |
INTEGER |
· invalid(0) · dot1pToLp(1) · dot1pToDp(2) · expToLp(3) · dscpToLp(4) · expToDp(5) · dscpToDp(6) · dscpToDot1p(7) · dot1pToDscp(8) · dscpToDscp(9) · dscpToExp(10) · expToDscp(11) · expToDot1p(12) · expToExp(13) · lpToDot1p(14) · dot1pToRpr(15) · dscpToRpr(16) · expToRpr(17) · ippreToRpr(18) · upToDot1p(19) · upToDscp(20) · upToExp(21) · upToDp(22) · upToLp(23) · upToRpr(24) · upToFc(25) · lpTodscp(26) · dot11eToLp(27) · lpToDot11e(28) · lpToLp(29) · dot1pToExp(30) · lpToExp(31) · lpToDp(32) · upToUp(33) · dot1pToDot1p(34) |
Predefined priority map type. |
hh3cCBQoSPrimapRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.22.1.3) |
read-create |
RowStatus |
Row status. |
About this table
This table contains information about packet color-to-drop priority mappings. The system assigns drop priority to packets according to the packet color.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSColorMapDpEnable (1.3.6.1.4.1.25506.2.65.2.1.2.23.1.1) |
read-create |
INTEGER |
Color-to-drop priority mapping enable status. |
As per the MIB. |
hh3cCBQoSColorMapDpRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.23.1.2) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSPolicyCfgInfoTable
About this table
This table configures a QoS policy.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSPolicyIndex (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.1) |
not-accessible |
Integer32 |
Policy index. |
As per the MIB. |
hh3cCBQoSPolicyName (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.2) |
read-create |
OCTET STRING |
SIZE (1..31) |
Policy name. |
As per the MIB. |
hh3cCBQoSPolicyClassCount (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.3) |
read-only |
Integer32 |
Number of traffic classes in the QoS policy. |
As per the MIB. |
hh3cCBQoSPolicyConfigMode (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.4) |
read-create |
INTEGER |
· unavailable(0) · config(1) · auto(2) |
Policy mode. |
Not supported. The value is fixed at unavailable(0). |
hh3cCBQoSPolicyType (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.5) |
read-only |
INTEGER |
Policy type. |
hh3cCBQoSPolicyClassNextIndex (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.6) |
read-only |
Integer32 |
Traffic class index used to create a traffic class. |
If the value is 2147483647, no traffic class can be created for hh3cCBQoSPolicyClassCfgInfoTable. |
hh3cCBQoSPolicyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.7) |
read-create |
RowStatus |
Row status. |
About this table
This table describes CB association information for a QoS policy.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are h3cCBQoSPolicyIndex and h3cCBQoSPolicyClassIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSPolicyClassIndex (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.1) |
not-accessible |
Integer32 |
As per the MIB. |
hh3cCBQoSPolicyClassClassifierIndex (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.2) |
read-create |
Integer32 |
As per the MIB. |
hh3cCBQoSPolicyClassClassifierName (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.3) |
read-only |
OCTET STRING |
SIZE (1..31) |
As per the MIB. |
hh3cCBQoSPolicyClassBehaviorIndex (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.4) |
read-create |
Integer32 |
As per the MIB. |
hh3cCBQoSPolicyClassBehaviorName (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.5) |
read-only |
OCTET STRING |
SIZE (1..31) |
As per the MIB. |
hh3cCBQoSPolicyClassPrecedence (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.6) |
read-create |
Integer32 |
· 0..16383 · 2147483647 |
Traffic class priority. |
Not supported. The value is fixed at 2147483647. |
hh3cCBQoSPolicyClassRowStatus (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.7) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSPolicyClassMode (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.8) |
read-create |
INTEGER |
· modeNo(1) · modeDot1q(2) · modeQppb(3) · modeIpSourceGuard(4) · modeVoiceVlan(5) · modeDcbx(6) |
CB association mode. |
hh3cCBQoSPolicyClassCfgOrder (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.9) |
read-only |
Integer32 |
CB association configuration order. |
Not supported |
hh3cCBQoSIfApplyPolicyTable
About this table
.This table applies a QoS policy to an interface.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are h3cCBQoSIfApplyPolicyIfIndex and h3cCBQoSIfApplyPolicyDirection.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSIfApplyPolicyIfIndex (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.1) |
accessible-for-notify |
Integer32 |
Index of the interface to which a QoS policy is applied. |
As per the MIB. |
hh3cCBQoSIfApplyPolicyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.2) |
DirectionType |
Application direction. |
As per the MIB. |
hh3cCBQoSIfApplyPolicyName (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.3) |
read-create |
OCTET STRING |
SIZE (1..31) |
Policy name. |
As per the MIB. |
hh3cCBQoSIfApplyPolicyEnableDynamic (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.4) |
read-create |
INTEGER |
· unavailable(1) · true(2) · false(3) |
Dynamic QoS |
Not supported. The value is fixed at unavailable(1). |
hh3cCBQoSIfApplyPolicyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.5) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSIfApplyPolicyStatus (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.6) |
read-only |
INTEGER |
· processing (0) · success (1) · partialItemFailed (2) |
Application status. |
As per the MIB. |
hh3cCBQoSVlanApplyPolicyTable
About this table
This table applies a QoS policy to a VLAN interface.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are h3cCBQoSVlanApplyPolicyVlanid and h3cCBQoSVlanApplyPolicyDirection.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSVlanApplyPolicyVlanid (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.1) |
Integer32 |
VLAN ID. |
As per the MIB. |
hh3cCBQoSVlanApplyPolicyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.2) |
DirectionType |
As per the MIB. |
hh3cCBQoSVlanApplyPolicyName (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.3) |
read-create |
OCTET STRING |
SIZE (1..31) |
Policy name. |
As per the MIB. |
hh3cCBQoSVlanApplyPriority (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.4) |
read-create |
Integer32 |
0..4095 |
Policy priority. |
hh3cCBQoSVlanApplyPolicyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.5) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSVlanApplyPolicyStatus (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.6) |
read-create |
INTEGER |
· processing (1) · success (2) · partialItemFailed (3) |
As per the MIB. |
hh3cCBQoSGlobalApplyTable
About this table
This table applies a QoS policy globally.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is h3cCBQoSGlobalApplyDirection.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSGlobalApplyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.6.1.1) |
not-accessible |
DirectionType |
As per the MIB. |
hh3cCBQoSGlobalApplyName (1.3.6.1.4.1.25506.2.65.2.1.4.6.1.2) |
read-create |
OCTET STRING |
SIZE (1..31) |
Policy name. |
As per the MIB. |
hh3cCBQoSGlobalApplyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.4.6.1.3) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSGlobalApplyStatus (1.3.6.1.4.1.25506.2.65.2.1.4.6.1.4) |
read-only |
INTEGER |
As per the MIB. |
hh3cCBQoSCpApplyPolicyTable
About this table
This table describes application information for a QoS policy applied to a control plane.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are h3cCBQoSCpApplyPolicyChassis, h3cCBQoSCpApplyPolicySlot, and h3cCBQoSCpApplyPolicyDirection.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSCpApplyPolicyChassis (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.1) |
not-accessible |
Unsigned32 |
Chassis number for the control plane. |
As per the MIB. |
hh3cCBQoSCpApplyPolicySlot (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.2) |
not-accessible |
Unsigned32 |
Slot number for the control plane. |
As per the MIB. |
hh3cCBQoSCpApplyPolicyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.3) |
not-accessible |
DirectionType |
As per the MIB. |
hh3cCBQoSCpApplyPolicyName (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.4) |
read-create |
OCTET STRING |
SIZE (1..31) |
Policy name. |
As per the MIB. |
hh3cCBQoSCpApplyPolicyStatus (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.5) |
read-only |
INTEGER |
As per the MIB. |
hh3cCBQoSCpApplyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.6) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSApplyObjectTable
About this table
This table obtains the application entity information for a QoS policy.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is h3cCBQoSApplyObjectIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.1) |
not-accessible |
Unsigned32 |
Application entity index. |
As per the MIB. |
hh3cCBQoSApplyObjectType (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.2) |
read-only |
ApplyObjectType |
Application entity type. |
· interface(1) · vlan(2) · controlPlane(5) |
hh3cCBQoSApplyObjectDirection (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.3) |
read-only |
DirectionType |
Application entity direction. |
As per the MIB. |
hh3cCBQoSApplyObjectMainSite (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.4) |
read-only |
Unsigned32 |
Main index of the application entity. |
As per the MIB. |
hh3cCBQoSApplyObjectSubChannel (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.5) |
read-only |
Unsigned32 |
Subchannel ID of the application entity. |
As per the MIB. |
hh3cCBQoSApplyObjectSubClass (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.6) |
read-only |
Unsigned32 |
Level-1 subclass number for level-2 nesting. |
As per the MIB. |
hh3cCBQoSApplyObjectSubClassSec (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.7) |
read-only |
Unsigned32 |
Level-2 subclass number for level-3 nesting. |
As per the MIB. |
hh3cCBQoSIntApplyObjectTable
About this table
This table obtains the application entity index for a QoS policy applied to an interface.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are h3cCBQoSIntApplyObjectIfIndex and h3cCBQoSApplyObjectDirection.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSIntApplyObjectIfIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.2.1.1) |
not-accessible |
Unsigned32 |
As per the MIB. |
hh3cCBQoSIntApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.2.1.2) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cCBQoSVlanApplyObjectTable
About this table
This table obtains the application entity index for a QoS policy applied to a VLAN or globally.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are h3cCBQoSVlanApplyObjectVlanID and h3cCBQoSApplyObjectDirection.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSVlanApplyObjectVlanID (1.3.6.1.4.1.25506.2.65.2.1.5.5.3.1.1) |
not-accessible |
Unsigned32 |
0..4094 |
ID of the VLAN to which a QoS policy is applied. |
When the value is 0, the QoS policy is applied globally. |
hh3cCBQoSVlanApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.3.1.2) |
read-only |
Unsigned32 |
As per the MIB. |
About this table
This table obtains the application entity index for a child QoS policy.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are h3cCBQoSApplyObjectIndex and h3cCBQoSNestPolicyClassIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSNestPolicyClassIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.5.1.1) |
not-accessible |
Unsigned32 |
Policy class index. |
As per the MIB. |
hh3cCBQoSNestPolicyApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.5.1.2) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cCBQoSCpApplyObjectTable
About this table
This table obtains QoS policy application information for a control plane.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are h3cCBQoSCpApplyObjectChassis, h3cCBQoSCpApplyObjectSlot, and h3cCBQoSApplyObjectDirection.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSCpApplyObjectChassis (1.3.6.1.4.1.25506.2.65.2.1.5.5.6.1.1) |
not-accessible |
Unsigned32 |
As per the MIB. |
hh3cCBQoSCpApplyObjectSlot (1.3.6.1.4.1.25506.2.65.2.1.5.5.6.1.2) |
not-accessible |
Unsigned32 |
As per the MIB. |
hh3cCBQoSCpApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.6.1.3) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cCBQoSCbqRunInfoTable
About this table
This table obtains CBQ queue statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSCbqQueueSize (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.1) |
read-only |
Integer32 |
Current CBQ queue size. |
As per the MIB. |
hh3cCBQoSCbqDiscard (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.2) |
read-only |
Counter64 |
Number of packets dropped by the CBQ queue. |
As per the MIB. |
hh3cCBQoSCbqEfQueueSize (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.3) |
read-only |
Integer32 |
EF queue size. |
As per the MIB. |
hh3cCBQoSCbqAfQueueSize (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.4) |
read-only |
Integer32 |
AF queue size. |
As per the MIB. |
hh3cCBQoSCbqBeQueueSize (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.5) |
read-only |
Integer32 |
BE queue size. |
As per the MIB. |
hh3cCBQoSCbqBeActiveQueueNum (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.6) |
read-only |
Integer32 |
Number of active BE queues. |
As per the MIB. |
hh3cCBQoSCbqBeMaxActiveQueueNum (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.7) |
read-only |
Integer32 |
Maximum number of active BE queues that have existed. |
As per the MIB. |
hh3cCBQoSCbqBeTotalQueueNum (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.8) |
read-only |
Integer32 |
Total number of BE queues. |
As per the MIB. |
hh3cCBQoSCbqAfAllocatedQueueNum (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.9) |
read-only |
Integer32 |
Number of AF queues that have been allocated. |
As per the MIB. |
About this table
This table obtains matching statistics about a traffic class.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are h3cCBQoSApplyObjectIndex and h3cCBQoSPolicyClassIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSClassMatchedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.1) |
read-only |
Counter64 |
Number of matching packets. |
As per the MIB. |
hh3cCBQoSClassMatchedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.2) |
read-only |
Counter64 |
Number of matching bytes. |
As per the MIB. |
hh3cCBQoSClassFwdPktpps (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.3) |
read-only |
Unsigned32 |
Number of packets sent per second during the last collection interval. |
Not supported |
hh3cCBQoSClassFwdPktbps (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.4) |
read-only |
Unsigned32 |
Number of bits sent per second during the last collection interval. |
Not supported |
hh3cCBQoSClassDropPktpps (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.5) |
read-only |
Unsigned32 |
Number of packets dropped per second during the last collection interval. |
Not supported |
hh3cCBQoSClassDropPktbps (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.6) |
read-only |
Unsigned32 |
Number of bits dropped per second during the last collection interval. |
Not supported |
hh3cCBQoSClassFlowStatInterval (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.7) |
read-only |
Unsigned32 |
Statistics collection interval. |
Not supported |
hh3cCBQoSClassBehaviorStatus (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.8) |
read-only |
INTEGER |
· success(1) · failure(2) · partialSuccess(3) |
CB association application status. |
As per the MIB. |
hh3cCBQoSCarRunInfoTable
About this table
This table obtains CAR statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSCarGreenPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.1) |
read-only |
Counter64 |
Number of packets matching the CAR configuration |
As per the MIB. |
hh3cCBQoSCarGreenBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.2) |
read-only |
Counter64 |
Number of bytes matching the CAR configuration |
As per the MIB. |
hh3cCBQoSCarRedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.3) |
read-only |
Counter64 |
Number of red packets. |
As per the MIB. |
hh3cCBQoSCarRedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.4) |
read-only |
Counter64 |
Number of red bytes. |
As per the MIB. |
hh3cCBQoSCarYellowPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.5) |
read-only |
Counter64 |
Number of yellow packets. |
As per the MIB. |
hh3cCBQoSCarYellowBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.6) |
read-only |
Counter64 |
Number of yellow bytes. |
As per the MIB. |
hh3cCBQoSCarClassName (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.7) |
read-only |
OCTET STRING |
SIZE (1..31) |
As per the MIB. |
hh3cCBQoSRemarkRunInfoTable
About this table
This table obtains marking statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSRemarkedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.5.1.1) |
read-only |
Counter64 |
Number of packets marked. |
As per the MIB. |
hh3cCBQoSQueueRunInfoTable
About this table
.This table obtains queue-related traffic statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSQueueMatchedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.1) |
read-only |
Counter64 |
Number of packets matching a queue. |
As per the MIB. |
hh3cCBQoSQueueMatchedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.2) |
read-only |
Counter64 |
Number of bytes matching the queue. |
As per the MIB. |
hh3cCBQoSQueueEnqueuedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.3) |
read-only |
Counter64 |
Number of packets enqueued. |
As per the MIB. |
hh3cCBQoSQueueEnqueuedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.4) |
read-only |
Counter64 |
Number of bytes enqueued. |
As per the MIB. |
hh3cCBQoSQueueDiscardedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.5) |
read-only |
Counter64 |
Number of packets dropped by the queue. |
As per the MIB. |
hh3cCBQoSQueueDiscardedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.6) |
read-only |
Counter64 |
Number of bytes dropped by the queue. |
As per the MIB. |
About this table
This table obtains traffic statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSAccountingPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1.1) |
read-only |
Counter64 |
Number of packets. |
As per the MIB. |
hh3cCBQoSAccountingBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1.2) |
read-only |
Counter64 |
Number of bytes. |
As per the MIB. |
hh3cCBQoSAccountingPktpps (1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1.3) |
read-only |
Counter64 |
Traffic rate in pps. |
As per the MIB. |
hh3cCBQoSAccountingPktbps (1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1.4) |
read-only |
Counter64 |
Traffic rate in bps. |
As per the MIB. |
About this table
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSPolicyAccPackets |
read-only |
Counter64 |
As per the MIB. |
hh3cCBQoSPolicyAccBytes |
read-only |
Counter64 |
Number of bytes. |
As per the MIB. |
