01-HH3C-ACL-MIB | 252.51 KB |
hh3cAclMib2ObjectsCapabilities
hh3cAclMib2ResourceLogInterval
hh3cPfilterAclGroupRunInfoTable
hh3cPfilterAclRuleRunInfoTable
hh3cPfilter2AclGroupRunInfoTable
hh3cPfilter2AclRuleRunInfoTable
hh3cAclFirstEthernetPktCaptured
HH3C-ACL-MIB
About this MIB
This MIB provides some basic table for managing ACLs on a switch.
MIB file name
hh3c-acl.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cAcl(8)
Global objects
hh3cAclMib2Mode
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAclMib2Mode (1.3.6.1.4.1.25506.2.8.2.1.1.1) |
read-write |
INTEGER |
· linkBased(1) · ipBased(2) |
Mode in which the ACL is applied. |
Not supported. |
hh3cAclMib2Version
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAclMib2Version (1.3.6.1.4.1.25506.2.8.2.1.1.2) |
read-only |
Integer32 |
· 0..2147483647 |
Version of the ACL MIB file supported. |
Not supported. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAclMib2ObjectsCapabilities (1.3.6.1.4.1.25506.2.8.2.1.1.3) |
read-only |
BITS |
Standard MIB values. |
Non-tabular objects and tables supported. |
As per the MIB. |
hh3cAclMib2ProcessingStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAclMib2ProcessingStatus (1.3.6.1.4.1.25506.2.8.2.1.1.4) |
read-only |
INTEGER |
· processing(1) · done(2) Default: done. |
ACL processing status. |
As per the MIB. |
hh3cAclMib2ResourceThreshold
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAclMib2ResourceThreshold (1.3.6.1.4.1.25506.2.8.2.1.1.5) |
read-write |
Integer32 |
0..100 Default: 0. |
Sets the TCAM usage alarm threshold. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAclMib2ResourceLogInterval (1.3.6.1.4.1.25506.2.8.2.1.1.6) |
read-write |
Integer32 |
1..60 Default: 5. |
Sets the interval for checking the TCAM usage. |
As per the MIB. |
hh3cPfilterDefaultAction
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPfilterDefaultAction (1.3.6.1.4.1.25506.2.8.3.1.1) |
read-write |
INTEGER |
· permit(1) · deny(2) Default: permit. |
Sets the packet filtering default action. |
As per the MIB. |
hh3cPfilterProcessingStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPfilterProcessingStatus (1.3.6.1.4.1.25506.2.8.3.1.2) |
read-only |
INTEGER |
Packet filter processing status. |
As per the MIB. |
Tabular objects
hh3cAclMib2CapabilityTable
About this table
ACL capability set. Use this table to obtain product-supported ACL information for only user-defined ACLs.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are h3cAclMib2EntityType, h3cAclMib2EntityIndex, h3cAclMib2ModuleIndex, and h3cAclMib2CharacteristicsIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
h3cAclMib2EntityType (1.3.6.1.4.1.25506.2.8.2.1.2.1.1) |
not-accessible |
INTEGER |
· system(1) · interface(2) |
Type of the entity where the ACL is configured and applied. |
As per the MIB. |
h3cAclMib2EntityIndex (1.3.6.1.4.1.25506.2.8.2.1.2.1.2) |
not-accessible |
Integer32 |
0..2147483647 |
Index of the entity type. |
As per the MIB. |
h3cAclMib2ModuleIndex (1.3.6.1.4.1.25506.2.8.2.1.2.1.3) |
not-accessible |
INTEGER |
· layer3(1) · layer2(2) · userDefined(3) |
Index of the ACL type. |
As per the MIB. |
h3cAclMib2CharacteristicsIndex (1.3.6.1.4.1.25506.2.8.2.1.2.1.4) |
not-accessible |
Integer32 |
0..2147483647 |
Index of the ACL attribute. |
As per the MIB. |
h3cAclMib2CharacteristicsDesc (1.3.6.1.4.1.25506.2.8.2.1.2.1.5) |
read-only |
OCTET STRING |
SIZE (0..255) |
Description of the ACL attribute. |
Not supported. |
h3cAclMib2CharacteristicsValue (1.3.6.1.4.1.25506.2.8.2.1.2.1.6) |
read-only |
Unsigned32 |
Value of the ACL attribute. |
Not supported. |
hh3cAclNumberGroupTable
About this table
This table records numbered ACL configuration information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cAclNumberGroupType, and h3cAclNumberGroupIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAclNumberGroupType (1.3.6.1.4.1.25506.2.8.2.1.3.1.1) |
not-accessible |
INTEGER |
· ipv4(1) · ipv6(2) · mac(3) · user(4) |
ACL type. |
Implementation varies by product |
hh3cAclNumberGroupIndex (1.3.6.1.4.1.25506.2.8.2.1.3.1.2) |
not-accessible |
Integer32 |
· 2000..5999 · 10000..42767 |
ACL number index. |
hh3cAclNumberGroupRowStatus (1.3.6.1.4.1.25506.2.8.2.1.3.1.3) |
read-create |
RowStatus |
Row status. |
· active(1) · createAndGo(4) · destroy(6) |
hh3cAclNumberGroupMatchOrder (1.3.6.1.4.1.25506.2.8.2.1.3.1.4) |
read-create |
INTEGER |
· config(1) · auto(2) |
Rule match order. |
As per the MIB. |
hh3cAclNumberGroupStep (1.3.6.1.4.1.25506.2.8.2.1.3.1.5) |
read-create |
Integerd32 |
1..20 |
Rule numbering step. |
As per the MIB. |
hh3cAclNumberGroupDescription (1.3.6.1.4.1.25506.2.8.2.1.3.1.6) |
read-create |
OCTET STRING |
SIZE (0..127) |
ACL description. |
As per the MIB. |
hh3cAclNumberGroupCountClear (1.3.6.1.4.1.25506.2.8.2.1.3.1.7) |
read-write |
CounterClear |
Clear rule statistics for the ACL. |
As per the MIB. |
hh3cAclNumberGroupRuleCounter (1.3.6.1.4.1.25506.2.8.2.1.3.1.8) |
read-only |
Counter32 |
Number of rules in the ACL. |
As per the MIB. |
hh3cAclNumberGroupName (1.3.6.1.4.1.25506.2.8.2.1.3.1.9) |
read-create |
OCTET STRING |
SIZE (0..63) |
ACL name. |
As per the MIB. |
hh3cAclNamedGroupTable
About this table
This table records named ACL configuration information. Use this table to add or delete a named ACL.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cAclNumberGroupType, h3cAclNamedGroupCategory, and h3cAclNamedGroupName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
h3cAclNamedGroupCategory (1.3.6.1.4.1.25506.2.8.2.1.4.1.1) |
not-accessible |
INTEGER |
· invalid(0) · basic(1) · advanced(2) |
ACL category. |
As per the MIB. |
hh3cAclNamedGroupName (1.3.6.1.4.1.25506.2.8.2.1.4.1.2) |
not-accessible |
OCTET STRING |
SIZE (1..63) |
ACL name. |
As per the MIB. |
hh3cAclNamedGroupRowStatus (1.3.6.1.4.1.25506.2.8.2.1.4.1.3) |
read-create |
RowStatus |
Row status. |
hh3cAclNamedGroupMatchOrder (1.3.6.1.4.1.25506.2.8.2.1.4.1.4) |
read-create |
INTERGER |
Rule match order. |
As per the MIB. |
hh3cAclNamedGroupStep (1.3.6.1.4.1.25506.2.8.2.1.4.1.5) |
read-create |
Integer32 |
1..20 |
As per the MIB. |
hh3cAclNamedGroupDescription (1.3.6.1.4.1.25506.2.8.2.1.4.1.6) |
read-create |
OCTET STRING |
SIZE (0..127) |
ACL description. |
As per the MIB. |
hh3cAclNamedGroupCountClear (1.3.6.1.4.1.25506.2.8.2.1.4.1.7) |
read-write |
CounterClear |
As per the MIB. |
hh3cAclNamedGroupRuleCounter (1.3.6.1.4.1.25506.2.8.2.1.4.1.8) |
read-only |
Counter32 |
As per the MIB. |
hh3cAclIPAclBasicTable
About this table
This table records basic ACL configuration information. Use this table to add or delete a basic ACL rule.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cAclNumberGroupType, h3cAclNumberGroupIndex, and h3cAclIPAclBasicRuleIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAclIPAclBasicRuleIndex (1.3.6.1.4.1.25506.2.8.2.2.2.1.1) |
not-accessible |
Integer32 |
0..65534 |
ACL rule ID. |
As per the MIB. |
hh3cAclIPAclBasicRowStatus (1.3.6.1.4.1.25506.2.8.2.2.2.1.2) |
read-create |
RowStatus |
Row status. |
hh3cAclIPAclBasicAct (1.3.6.1.4.1.25506.2.8.2.2.2.1.3) |
read-create |
RuleAction |
Action type. |
· permit(2) · deny(3) |
hh3cAclIPAclBasicSrcAddrType (1.3.6.1.4.1.25506.2.8.2.2.2.1.4) |
read-create |
InetAddressType |
Source address type. |
As per the MIB. |
hh3cAclIPAclBasicSrcAddr (1.3.6.1.4.1.25506.2.8.2.2.2.1.5) |
read-create |
InetAddress |
Source IP address. |
As per the MIB. |
hh3cAclIPAclBasicSrcPrefix (1.3.6.1.4.1.25506.2.8.2.2.2.1.6) |
read-create |
InetAddressPrefixLength |
Source IP address prefix. |
As per the MIB. |
hh3cAclIPAclBasicSrcAny (1.3.6.1.4.1.25506.2.8.2.2.2.1.7) |
read-create |
TruthValue |
· true(1) · false(2) |
Whether the source IP address can be any. |
Default: true(1). |
hh3cAclIPAclBasicSrcWild (1.3.6.1.4.1.25506.2.8.2.2.2.1.8) |
read-create |
IpAddress |
Source IP address wildcard mask. |
As per the MIB. |
hh3cAclIPAclBasicTimeRangeName (1.3.6.1.4.1.25506.2.8.2.2.2.1.9) |
read-create |
OCTET STRING |
SIZE (0..32) |
Time range name. |
As per the MIB. |
hh3cAclIPAclBasicFragmentFlag (1.3.6.1.4.1.25506.2.8.2.2.2.1.10) |
read-create |
FragmentFlag |
Fragment flag. |
Support 0 and 2. |
hh3cAclIPAclBasicLog (1.3.6.1.4.1.25506.2.8.2.2.2.1.11) |
read-create |
TruthValue |
Enabling status of the logging feature. |
As per the MIB. |
hh3cAclIPAclBasicCount (1.3.6.1.4.1.25506.2.8.2.2.2.1.12) |
read-only |
Unsigned32 |
Number of packets matching the ACL rule. |
As per the MIB. |
hh3cAclIPAclBasicCountClear (1.3.6.1.4.1.25506.2.8.2.2.2.1.13) |
read-write |
INTEGER |
Clear the rule match count. |
Not supported |
hh3cAclIPAclBasicEnable (1.3.6.1.4.1.25506.2.8.2.2.2.1.14) |
read-only |
TruthValue |
Enabling status of the rule. |
As per the MIB. |
hh3cAclIPAclBasicVpnInstanceName (1.3.6.1.4.1.25506.2.8.2.2.2.1.15) |
read-create |
OCTET STRING |
SIZE (0..32) |
VPN instance name. |
hh3cAclIPAclBasicComment (1.3.6.1.4.1.25506.2.8.2.2.2.1.16) |
read-create |
OCTET STRING |
SIZE (0..127) |
Rule description. |
Read and write. |
hh3cAclIPAclBasicCounting (1.3.6.1.4.1.25506.2.8.2.2.2.1.17) |
read-create |
TruthValue |
Enabling status of counting packets matching the rule. |
As per the MIB. |
hh3cAclIPAclBasicRouteTypeAny (1.3.6.1.4.1.25506.2.8.2.2.2.1.18) |
read-create |
TruthValue |
Whether the rule matches all types of IPv6 routing headers. |
As per the MIB. |
hh3cAclIPAclBasicRouteTypeValue (1.3.6.1.4.1.25506.2.8.2.2.2.1.19) |
read-create |
Integer32 |
· 0..255 · 65535 |
Type of IPv6 routing header. |
As per the MIB. |
hh3cAclIPAclAdvancedTable
About this table
This table records advanced ACL configuration information. Use this table to add or delete an advanced ACL rule.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cAclNumberGroupType, h3cAclNumberGroupIndex, and h3cAclIPAclAdvancedRuleIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAclIPAclAdvancedRuleIndex (1.3.6.1.4.1.25506.2.8.2.2.3.1.1) |
not-accessible |
Integer32 |
0..65534 |
ACL rule ID. |
As per the MIB. |
hh3cAclIPAclAdvancedRowStatus (1.3.6.1.4.1.25506.2.8.2.2.3.1.2) |
read-create |
RowStatus |
Row status. |
hh3cAclIPAclAdvancedAct (1.3.6.1.4.1.25506.2.8.2.2.3.1.3) |
read-create |
RuleAction |
Action type. |
hh3cAclIPAclAdvancedProtocol (1.3.6.1.4.1.25506.2.8.2.2.3.1.4) |
read-create |
INTEGER |
0..255 |
Number of a Layer 3 protocol or a protocol above Layer 3. |
As per the MIB. |
hh3cAclIPAclAdvancedAddrFlag (1.3.6.1.4.1.25506.2.8.2.2.3.1.5) |
read-create |
AddressFlag |
Address flag for the IPv6 source address and destination address. |
Not supported |
hh3cAclIPAclAdvancedSrcAddrType (1.3.6.1.4.1.25506.2.8.2.2.3.1.6) |
read-create |
InetAddressType |
Source IP address type. |
As per the MIB. |
hh3cAclIPAclAdvancedSrcAddr (1.3.6.1.4.1.25506.2.8.2.2.3.1.7) |
read-create |
InetAddress |
As per the MIB. |
hh3cAclIPAclAdvancedSrcPrefix (1.3.6.1.4.1.25506.2.8.2.2.3.1.8) |
read-create |
As per the MIB. |
hh3cAclIPAclAdvancedSrcAny (1.3.6.1.4.1.25506.2.8.2.2.3.1.9) |
read-create |
TruthValue |
Whether the source IP address can be any value. |
Default: true(1). |
hh3cAclIPAclAdvancedSrcWild (1.3.6.1.4.1.25506.2.8.2.2.3.1.10) |
read-create |
IpAddress |
As per the MIB. |
hh3cAclIPAclAdvancedSrcOp (1.3.6.1.4.1.25506.2.8.2.2.3.1.11) |
read-create |
PortOp |
Port operator. |
As per the MIB. |
hh3cAclIPAclAdvancedSrcPort1 (1.3.6.1.4.1.25506.2.8.2.2.3.1.12) |
read-create |
Integer32 |
0..65535 |
Source UDP or TCP port 1. |
As per the MIB. |
hh3cAclIPAclAdvancedSrcPort2 (1.3.6.1.4.1.25506.2.8.2.2.3.1.13) |
read-create |
Integer32 |
0..65535 |
Source UDP or TCP port 2. |
As per the MIB. |
hh3cAclIPAclAdvancedDestAddrType (1.3.6.1.4.1.25506.2.8.2.2.3.1.14) |
read-create |
InetAddressType |
Destination address type. |
As per the MIB. |
hh3cAclIPAclAdvancedDestAddr (1.3.6.1.4.1.25506.2.8.2.2.3.1.15) |
read-create |
InetAddress |
Destination IP address. |
As per the MIB. |
hh3cAclIPAclAdvancedDestPrefix (1.3.6.1.4.1.25506.2.8.2.2.3.1.16) |
read-create |
Destination address prefix. |
As per the MIB. |
hh3cAclIPAclAdvancedDestAny (1.3.6.1.4.1.25506.2.8.2.2.3.1.17) |
read-create |
TruthValue |
Whether the destination IP address can be any value. |
Default: true(1). |
hh3cAclIPAclAdvancedDestWild (1.3.6.1.4.1.25506.2.8.2.2.3.1.18) |
read-create |
IpAddress |
Destination IP address wildcard mask. |
As per the MIB. |
hh3cAclIPAclAdvancedDestOp (1.3.6.1.4.1.25506.2.8.2.2.3.1.19) |
read-create |
PortOp |
Port operator. |
As per the MIB. |
hh3cAclIPAclAdvancedDestPort1 (1.3.6.1.4.1.25506.2.8.2.2.3.1.20) |
read-create |
Integer32 |
0..65535 |
Destination UDP or TCP port 1. |
As per the MIB. |
hh3cAclIPAclAdvancedDestPort2 (1.3.6.1.4.1.25506.2.8.2.2.3.1.21) |
read-create |
Integer32 |
0..65535 |
Destination UDP or TCP port 2. |
As per the MIB. |
hh3cAclIPAclAdvancedIcmpType (1.3.6.1.4.1.25506.2.8.2.2.3.1.22) |
read-create |
Integer32 |
· 0..255 · 65535 |
ICMP message type. |
As per the MIB. |
hh3cAclIPAclAdvancedIcmpCode (1.3.6.1.4.1.25506.2.8.2.2.3.1.23) |
read-create |
Integer32 |
· 0..255 · 65535 |
ICMP message code. |
As per the MIB. |
hh3cAclIPAclAdvancedPrecedence (1.3.6.1.4.1.25506.2.8.2.2.3.1.24) |
read-create |
Integer32 |
· 0..7 · 255 |
IP precedence. |
As per the MIB. |
hh3cAclIPAclAdvancedTos (1.3.6.1.4.1.25506.2.8.2.2.3.1.25) |
read-create |
Integer32 |
· 0..15 · 255 |
ToS type |
As per the MIB. |
hh3cAclIPAclAdvancedDscp (1.3.6.1.4.1.25506.2.8.2.2.3.1.26) |
read-create |
DSCPValue |
· 0..63 · 255 |
DSCP value. |
As per the MIB. |
hh3cAclIPAclAdvancedTimeRangeName (1.3.6.1.4.1.25506.2.8.2.2.3.1.27) |
read-create |
OCTET STRING |
SIZE (0..32) |
Time range name. |
As per the MIB. |
hh3cAclIPAclAdvancedTCPFlag (1.3.6.1.4.1.25506.2.8.2.2.3.1.28) |
read-create |
TCPFlag |
TCP flag. |
As per the MIB. |
hh3cAclIPAclAdvancedFragmentFlag (1.3.6.1.4.1.25506.2.8.2.2.3.1.29) |
read-create |
FragmentFlag |
Fragments flag. |
Support 0 and 2. |
hh3cAclIPAclAdvancedLog (1.3.6.1.4.1.25506.2.8.2.2.3.1.30) |
read-create |
TruthValue |
As per the MIB. |
hh3cAclIPAclAdvancedCount (1.3.6.1.4.1.25506.2.8.2.2.3.1.31) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cAclIPAclAdvancedCountClear (1.3.6.1.4.1.25506.2.8.2.2.3.1.32) |
read-write |
CounterClear |
Not supported |
hh3cAclIPAclAdvancedEnable (1.3.6.1.4.1.25506.2.8.2.2.3.1.33) |
read-only |
TruthValue |
As per the MIB. |
hh3cAclIPAclAdvancedVpnInstanceName (1.3.6.1.4.1.25506.2.8.2.2.3.1.34) |
read-create |
OCTET STRING |
SIZE (0..32) |
Implementation varies by product. |
hh3cAclIPAclAdvancedComment (1.3.6.1.4.1.25506.2.8.2.2.3.1.35) |
read-create |
OCTET STRING |
SIZE (0..127) |
Rule description. |
Read and write. |
hh3cAclIPAclAdvancedReflective (1.3.6.1.4.1.25506.2.8.2.2.3.1.36) |
read-create |
TruthValue |
Whether it is a reflective rule. |
Not supported |
hh3cAclIPAclAdvancedCounting (1.3.6.1.4.1.25506.2.8.2.2.3.1.37) |
read-create |
TruthValue |
As per the MIB. |
hh3cAclIPAclAdvancedTCPFlagMask (1.3.6.1.4.1.25506.2.8.2.2.3.1.38) |
read-create |
Hh3cAlarmStatus |
· tcpack(0) · tcpfin(1) · tcppsh(2) · tcprst(3) · tcpsyn(4) · tcpurg(5) |
TCP flag bit mask. |
As per the MIB. |
hh3cAclIPAclAdvancedTCPFlagValue (1.3.6.1.4.1.25506.2.8.2.2.3.1.39) |
read-create |
Hh3cAlarmStatus |
TCP flag bit set. |
As per the MIB. |
hh3cAclIPAclAdvancedRouteTypeAny (1.3.6.1.4.1.25506.2.8.2.2.3.1.40) |
read-create |
TruthValue |
true(1) false(2) |
As per the MIB. |
hh3cAclIPAclAdvancedRouteTypeValue (1.3.6.1.4.1.25506.2.8.2.2.3.1.41) |
read-create |
Integer32 |
· 0..255 · 65535 |
Type of the IPv6 routing header. |
As per the MIB. |
hh3cAclIPAclAdvancedFlowLabel (1.3.6.1.4.1.25506.2.8.2.2.3.1.42) |
read-create |
Unsigned32 |
· 0..1048575 · 4294967295 |
Flow label. |
Default: 0. |
read-create |
Unsigned32 |
Source address suffix. |
Not supported. |
h3cAclIPAclAdvancedDestSuffix |
read-create |
Unsigned32 |
Destination address suffix. |
Not supported. |
hh3cAclIPAclNamedBscTable
About this table
This table records basic ACL configuration information. Use this table to add or delete a basic named ACL.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cAclNumberGroupType, h3cAclNamedGroupName, and h3cAclIPAclBasicRuleIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAclIPAclNamedBscRowStatus (1.3.6.1.4.1.25506.2.8.2.2.4.1.1) |
read-create |
RowStatus |
Row status. |
hh3cAclIPAclNamedBscAct (1.3.6.1.4.1.25506.2.8.2.2.4.1.2) |
read-create |
RuleAction |
Action type. |
hh3cAclIPAclNamedBscSrcAddrType (1.3.6.1.4.1.25506.2.8.2.2.4.1.3) |
read-create |
InetAddressType |
As per the MIB. |
hh3cAclIPAclNamedBscSrcAddr (1.3.6.1.4.1.25506.2.8.2.2.4.1.4) |
read-create |
InetAddress |
As per the MIB. |
hh3cAclIPAclNamedBscSrcPrefix (1.3.6.1.4.1.25506.2.8.2.2.4.1.5) |
read-create |
As per the MIB. |
hh3cAclIPAclNamedBscSrcAny (1.3.6.1.4.1.25506.2.8.2.2.4.1.6) |
read-create |
TruthValue |
Default: true(1) |
hh3cAclIPAclNamedBscSrcWild (1.3.6.1.4.1.25506.2.8.2.2.4.1.7) |
read-create |
IpAddress |
As per the MIB. |
hh3cAclIPAclNamedBscTimeRangeName (1.3.6.1.4.1.25506.2.8.2.2.4.1.8) |
read-create |
OCTET STRING |
SIZE (0..32) |
Time range name. |
As per the MIB. |
hh3cAclIPAclNamedBscFragmentFlag (1.3.6.1.4.1.25506.2.8.2.2.4.1.9) |
read-create |
FragmentFlag |
Fragments flag. |
Support 0 and 2. |
hh3cAclIPAclNamedBscLog (1.3.6.1.4.1.25506.2.8.2.2.4.1.10) |
read-create |
TruthValue |
As per the MIB. |
hh3cAclIPAclNamedBscCount (1.3.6.1.4.1.25506.2.8.2.2.4.1.11) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cAclIPAclNamedBscCountClear (1.3.6.1.4.1.25506.2.8.2.2.4.1.12) |
read-write |
CounterClear |
Not supported |
hh3cAclIPAclNamedBscEnable (1.3.6.1.4.1.25506.2.8.2.2.4.1.13) |
read-only |
TruthValue |
As per the MIB. |
hh3cAclIPAclNamedBscVpnInstName (1.3.6.1.4.1.25506.2.8.2.2.4.1.14) |
read-create |
OCTET STRING |
SIZE(0..32) |
hh3cAclIPAclNamedBscComment (1.3.6.1.4.1.25506.2.8.2.2.4.1.15) |
read-create |
OCTET STRING |
SIZE (0..127) |
Rule description. |
Read and write. |
hh3cAclIPAclNamedBscCounting (1.3.6.1.4.1.25506.2.8.2.2.4.1.16) |
read-create |
TruthValue |
As per the MIB. |
hh3cAclIPAclNamedBscRouteTypeAny (1.3.6.1.4.1.25506.2.8.2.2.4.1.17) |
read-create |
TruthValue |
As per the MIB. |
hh3cAclIPAclNamedBscRouteTypeValue (1.3.6.1.4.1.25506.2.8.2.2.4.1.18) |
read-create |
Integer32 |
· 0..255 · 65535 |
As per the MIB. |
hh3cAclIPAclNamedAdvTable
About this table
This table records advanced ACL configuration information. Use this table to add or delete an advanced named ACL.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cAclNumberGroupType, h3cAclNamedGroupName, and h3cAclIPAclAdvancedRuleIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAclIPAclNamedAdvRowStatus (1.3.6.1.4.1.25506.2.8.2.2.5.1.1) |
read-create |
RowStatus |
Row status. |
hh3cAclIPAclNamedAdvAct (1.3.6.1.4.1.25506.2.8.2.2.5.1.2) |
read-create |
RuleAction |
Action type. |
hh3cAclIPAclNamedAdvProtocol (1.3.6.1.4.1.25506.2.8.2.2.5.1.3) |
read-create |
Integer32 |
0..255 |
As per the MIB. |
hh3cAclIPAclNamedAdvAddrFlag (1.3.6.1.4.1.25506.2.8.2.2.5.1.4) |
read-create |
AddressFlag |
Not supported |
hh3cAclIPAclNamedAdvSrcAddrType (1.3.6.1.4.1.25506.2.8.2.2.5.1.5) |
read-create |
InetAddressType |
As per the MIB. |
hh3cAclIPAclNamedAdvSrcAddr (1.3.6.1.4.1.25506.2.8.2.2.5.1.6) |
read-create |
InetAddress |
As per the MIB. |
hh3cAclIPAclNamedAdvSrcPrefix (1.3.6.1.4.1.25506.2.8.2.2.5.1.7) |
read-create |
As per the MIB. |
hh3cAclIPAclNamedAdvSrcAny (1.3.6.1.4.1.25506.2.8.2.2.5.1.8) |
read-create |
TruthValue |
Default: true(1) |
hh3cAclIPAclNamedAdvSrcWild (1.3.6.1.4.1.25506.2.8.2.2.5.1.9) |
read-create |
IpAddress |
As per the MIB. |
hh3cAclIPAclNamedAdvSrcOp (1.3.6.1.4.1.25506.2.8.2.2.5.1.10) |
read-create |
PortOp |
Port operator. |
As per the MIB. |
hh3cAclIPAclNamedAdvSrcPort1 (1.3.6.1.4.1.25506.2.8.2.2.5.1.11) |
read-create |
Integer32 |
0..65535 |
Source UDP or TCP port 1 |
As per the MIB. |
hh3cAclIPAclNamedAdvSrcPort2 (1.3.6.1.4.1.25506.2.8.2.2.5.1.12) |
read-create |
Integer32 |
0..65535 |
Source UDP or TCP port 2 |
As per the MIB. |
hh3cAclIPAclNamedAdvDstAddrType (1.3.6.1.4.1.25506.2.8.2.2.5.1.13) |
read-create |
InetAddressType |
As per the MIB. |
hh3cAclIPAclNamedAdvDstAddr (1.3.6.1.4.1.25506.2.8.2.2.5.1.14) |
read-create |
InetAddress |
As per the MIB. |
hh3cAclIPAclNamedAdvDstPrefix (1.3.6.1.4.1.25506.2.8.2.2.5.1.15) |
read-create |
As per the MIB. |
hh3cAclIPAclNamedAdvDstAny (1.3.6.1.4.1.25506.2.8.2.2.5.1.16) |
read-create |
TruthValue |
Default: true(1) |
hh3cAclIPAclNamedAdvDstWild (1.3.6.1.4.1.25506.2.8.2.2.5.1.17) |
read-create |
IpAddress |
As per the MIB. |
hh3cAclIPAclNamedAdvDstOp (1.3.6.1.4.1.25506.2.8.2.2.5.1.18) |
read-create |
PortOp |
Port operator. |
As per the MIB. |
hh3cAclIPAclNamedAdvDstPort1 (1.3.6.1.4.1.25506.2.8.2.2.5.1.19) |
read-create |
Integer32 |
0..65535 |
As per the MIB. |
hh3cAclIPAclNamedAdvDstPort2 (1.3.6.1.4.1.25506.2.8.2.2.5.1.20) |
read-create |
Integer32 |
0..65535 |
As per the MIB. |
hh3cAclIPAclNamedAdvIcmpType (1.3.6.1.4.1.25506.2.8.2.2.5.1.21) |
read-create |
Integer32 |
· 0..255 · 65535 |
As per the MIB. |
hh3cAclIPAclNamedAdvIcmpCode (1.3.6.1.4.1.25506.2.8.2.2.5.1.22) |
read-create |
Integer32 |
· 0..255 · 65535 |
As per the MIB. |
hh3cAclIPAclNamedAdvPrecedence (1.3.6.1.4.1.25506.2.8.2.2.5.1.23) |
read-create |
Integer32 |
· 0..7 · 255 |
IP precedence. |
As per the MIB. |
hh3cAclIPAclNamedAdvTos (1.3.6.1.4.1.25506.2.8.2.2.5.1.24) |
read-create |
Integer32 |
· 0..15 · 255 |
ToS. |
As per the MIB. |
hh3cAclIPAclNamedAdvDscp (1.3.6.1.4.1.25506.2.8.2.2.5.1.25) |
read-create |
Integer32 |
· 0..63 · 255 |
DSCP. |
As per the MIB. |
hh3cAclIPAclNamedAdvTRangeName (1.3.6.1.4.1.25506.2.8.2.2.5.1.26) |
read-create |
OCTET STRING |
SIZE (0..32) |
Time range name. |
As per the MIB. |
hh3cAclIPAclNamedAdvTCPFlag (1.3.6.1.4.1.25506.2.8.2.2.5.1.27) |
read-create |
TCPFlag |
TCP flag. |
As per the MIB. |
hh3cAclIPAclNamedAdvFragmentFlag (1.3.6.1.4.1.25506.2.8.2.2.5.1.28) |
read-create |
FragmentFlag |
Fragments flag. |
Support 0 and 2. |
hh3cAclIPAclNamedAdvLog (1.3.6.1.4.1.25506.2.8.2.2.5.1.29) |
read-create |
TruthValue |
As per the MIB. |
hh3cAclIPAclNamedAdvCount (1.3.6.1.4.1.25506.2.8.2.2.5.1.30) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cAclIPAclNamedAdvCountClear (1.3.6.1.4.1.25506.2.8.2.2.5.1.31) |
read-write |
CounterClear |
Not supported |
hh3cAclIPAclNamedAdvEnable (1.3.6.1.4.1.25506.2.8.2.2.5.1.32) |
read-only |
TruthValue |
As per the MIB. |
hh3cAclIPAclNamedAdvVpnInstName (1.3.6.1.4.1.25506.2.8.2.2.5.1.33) |
read-create |
OCTET STRING |
SIZE (0..32) |
hh3cAclIPAclNamedAdvComment (1.3.6.1.4.1.25506.2.8.2.2.5.1.34) |
read-create |
OCTET STRING |
SIZE (0..127) |
Rule description. |
Read and write. |
hh3cAclIPAclNamedAdvReflective (1.3.6.1.4.1.25506.2.8.2.2.5.1.35) |
read-create |
TruthValue |
Not supported |
hh3cAclIPAclNamedAdvCounting (1.3.6.1.4.1.25506.2.8.2.2.5.1.36) |
read-only |
TruthValue |
As per the MIB. |
hh3cAclIPAclNamedAdvTCPFlagMask (1.3.6.1.4.1.25506.2.8.2.2.5.1.37) |
read-create |
Hh3cAlarmStatus |
As per the MIB. |
hh3cAclIPAclNamedAdvTCPFlagValue (1.3.6.1.4.1.25506.2.8.2.2.5.1.38) |
read-create |
Hh3cAlarmStatus |
TCP flag bit set. |
As per the MIB. |
hh3cAclIPAclNamedAdvRouteTypeAny (1.3.6.1.4.1.25506.2.8.2.2.5.1.39) |
read-create |
TruthValue |
As per the MIB. |
hh3cAclIPAclNamedAdvRouteTypeValue (1.3.6.1.4.1.25506.2.8.2.2.5.1.40) |
read-create |
Integer32 |
· 0..255 · 65535 |
As per the MIB. |
hh3cAclIPAclNamedAdvFlowLabel (1.3.6.1.4.1.25506.2.8.2.2.5.1.41) |
read-create |
Unsigned32 |
Flow label. |
Default: 0. |
h3cAclIPAclNamedAdvSrcSuffix |
read-create |
Unsigned32 |
Not supported. |
h3cAclIPAclNamedAdvDstSuffix |
read-create |
Unsigned32 |
Not supported. |
hh3cAclMACTable
About this table
This table records MAC ACL (also called Layer 2 ACL) configuration information. Use this table to add or delete a MAC ACL rule.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cAclNumberGroupType, h3cAclNumberGroupIndex, and h3cAclMACRuleIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAclMACRuleIndex (1.3.6.1.4.1.25506.2.8.2.3.1.1.1) |
not-accessible |
Integer32 |
0..65534 |
ACL rule ID. |
As per the MIB. |
hh3cAclMACRowStatus (1.3.6.1.4.1.25506.2.8.2.3.1.1.2) |
read-create |
RowStatus |
Row status. |
hh3cAclMACAct (1.3.6.1.4.1.25506.2.8.2.3.1.1.3) |
read-create |
RuleAction |
Action type. |
hh3cAclMACTypeCode (1.3.6.1.4.1.25506.2.8.2.3.1.1.4) |
read-create |
OCTET STRING |
SIZE (0..32) |
Layer 2 protocol type. |
As per the MIB. |
hh3cAclMACTypeMask (1.3.6.1.4.1.25506.2.8.2.3.1.1.5) |
read-create |
OCTET STRING |
SIZE (0..32) |
Mask of the Layer 2 protocol type. |
As per the MIB. |
hh3cAclMACSrcMac (1.3.6.1.4.1.25506.2.8.2.3.1.1.6) |
read-create |
MacAddress |
Source MAC address. |
As per the MIB. |
hh3cAclMACSrcMacWild (1.3.6.1.4.1.25506.2.8.2.3.1.1.7) |
read-create |
MacAddress |
Mask of the source MAC address. |
As per the MIB. |
hh3cAclMACDestMac (1.3.6.1.4.1.25506.2.8.2.3.1.1.8) |
read-create |
MacAddress |
Destination MAC address. |
As per the MIB. |
hh3cAclMACDestMacWild (1.3.6.1.4.1.25506.2.8.2.3.1.1.9) |
read-create |
MacAddress |
Destination MAC address mask. |
As per the MIB. |
hh3cAclMACLsapCode (1.3.6.1.4.1.25506.2.8.2.3.1.1.10) |
read-create |
OCTET STRING |
SIZE (0..32) |
Encapsulation format of the frame. |
As per the MIB. |
hh3cAclMACLsapMask (1.3.6.1.4.1.25506.2.8.2.3.1.1.11) |
read-create |
OCTET STRING |
SIZE (0..32) |
LSAP mask. |
As per the MIB. |
hh3cAclMACCos (1.3.6.1.4.1.25506.2.8.2.3.1.1.12) |
read-create |
Integer32 |
· 0..7 · 255 |
802.1p priority in VLAN tags. |
As per the MIB. |
hh3cAclMACTimeRangeName (1.3.6.1.4.1.25506.2.8.2.3.1.1.13) |
read-create |
OCTET STRING |
SIZE (0..32) |
Time range name. |
As per the MIB. |
hh3cAclMACCount (1.3.6.1.4.1.25506.2.8.2.3.1.1.14) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cAclMACCountClear (1.3.6.1.4.1.25506.2.8.2.3.1.1.15) |
read-write |
CounterClear |
Not supported |
hh3cAclMACEnable (1.3.6.1.4.1.25506.2.8.2.3.1.1.16) |
read-only |
TruthValue |
As per the MIB. |
hh3cAclMACComment (1.3.6.1.4.1.25506.2.8.2.3.1.1.17) |
read-create |
OCTET STRING |
SIZE (0..127) |
Rule description. |
Read and write. |
hh3cAclMACLog (1.3.6.1.4.1.25506.2.8.2.3.1.1.18) |
read-create |
TruthValue |
Not supported |
hh3cAclMACCounting (1.3.6.1.4.1.25506.2.8.2.3.1.1.19) |
read-create |
TruthValue |
As per the MIB. |
hh3cAclNamedMACTable
About this table
This table records MAC ACL configuration information. Use this table to add or delete a rule for a named MAC ACL.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cAclNumberGroupType, h3cAclNamedGroupName, and h3cAclMACRuleIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAclNamedMACRowStatus (1.3.6.1.4.1.25506.2.8.2.3.2.1.1) |
read-create |
RowStatus |
Row status. |
hh3cAclNamedMACAct (1.3.6.1.4.1.25506.2.8.2.3.2.1.2) |
read-create |
RuleAction |
Action type. |
hh3cAclNamedMACTypeCode (1.3.6.1.4.1.25506.2.8.2.3.2.1.3) |
read-create |
OCTET STRING |
SIZE(0..32) |
As per the MIB. |
hh3cAclNamedMACTypeMask (1.3.6.1.4.1.25506.2.8.2.3.2.1.4) |
read-create |
OCTET STRING |
SIZE (0..32) |
As per the MIB. |
hh3cAclNamedMACSrcMac (1.3.6.1.4.1.25506.2.8.2.3.2.1.5) |
read-create |
MacAddress |
As per the MIB. |
hh3cAclNamedMACSrcMacWild (1.3.6.1.4.1.25506.2.8.2.3.2.1.6) |
read-create |
MacAddress |
Source MAC address mask. |
As per the MIB. |
hh3cAclNamedMACDstMac (1.3.6.1.4.1.25506.2.8.2.3.2.1.7) |
read-create |
MacAddress |
As per the MIB. |
hh3cAclNamedMACDstMacWild (1.3.6.1.4.1.25506.2.8.2.3.2.1.8) |
read-create |
MacAddress |
As per the MIB. |
hh3cAclNamedMACLsapCode (1.3.6.1.4.1.25506.2.8.2.3.2.1.9) |
read-create |
OCTET STRING |
SIZE (0..32) |
As per the MIB. |
hh3cAclNamedMACLsapMask (1.3.6.1.4.1.25506.2.8.2.3.2.1.10) |
read-create |
OCTET STRING |
SIZE (0..32) |
LSAP mask. |
As per the MIB. |
hh3cAclNamedMACCos (1.3.6.1.4.1.25506.2.8.2.3.2.1.11) |
read-create |
Integer32 |
· 0..7 · 255 |
As per the MIB. |
hh3cAclNamedMACTimeRangeName (1.3.6.1.4.1.25506.2.8.2.3.2.1.12) |
read-create |
OCTET STRING |
SIZE (0..32) |
Time range name. |
As per the MIB. |
hh3cAclNamedMACCount (1.3.6.1.4.1.25506.2.8.2.3.2.1.13) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cAclNamedMACCountClear (1.3.6.1.4.1.25506.2.8.2.3.2.1.14) |
read-write |
CounterClear |
Not supported |
hh3cAclNamedMACEnable (1.3.6.1.4.1.25506.2.8.2.3.2.1.15) |
read-only |
TruthValue |
As per the MIB. |
hh3cAclNamedMACComment (1.3.6.1.4.1.25506.2.8.2.3.2.1.16) |
read-create |
OCTET STRING |
SIZE (0..127) |
Rule description. |
Read and write. |
hh3cAclNamedMACLog (1.3.6.1.4.1.25506.2.8.2.3.2.1.17) |
read-create |
TruthValue |
Not supported |
hh3cAclNamedMACCounting (1.3.6.1.4.1.25506.2.8.2.3.2.1.18) |
read-create |
TruthValue |
As per the MIB. |
hh3cAclEnUserTable
About this table
This table records user-defined ACL configuration information. Use this table to add or delete a user-defined ACL rule.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cAclNumberGroupType, h3cAclNumberGroupIndex, and h3cAclEnUserRuleIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAclEnUserRuleIndex (1.3.6.1.4.1.25506.2.8.2.4.3.1.1) |
not-accessible |
Integer32 |
0..65534 |
ACL rule ID. |
As per the MIB. |
hh3cAclEnUserRowStatus (1.3.6.1.4.1.25506.2.8.2.4.3.1.2) |
read-create |
RowStatus |
Row status. |
hh3cAclEnUserAct (1.3.6.1.4.1.25506.2.8.2.4.3.1.3) |
read-create |
RuleAction |
Action type. |
hh3cAclEnUserStartString (1.3.6.1.4.1.25506.2.8.2.4.3.1.4) |
read-create |
OCTET STRING |
SIZE (0..255) |
String for packet matching. |
Not supported |
hh3cAclEnUserL2String (1.3.6.1.4.1.25506.2.8.2.4.3.1.5) |
read-create |
OCTET STRING |
SIZE (0..255) |
String for Layer 2 packet matching. |
Default: “0,(null),(null)” |
hh3cAclEnUserMplsString (1.3.6.1.4.1.25506.2.8.2.4.3.1.6) |
read-create |
OCTET STRING |
SIZE (0..255) |
String for MPLS packet matching. |
Not supported |
hh3cAclEnUserIPv4String (1.3.6.1.4.1.25506.2.8.2.4.3.1.7) |
read-create |
OCTET STRING |
SIZE (0..255) |
String for IPv4 packet matching. |
hh3cAclEnUserIPv6String (1.3.6.1.4.1.25506.2.8.2.4.3.1.8) |
read-create |
OCTET STRING |
SIZE (0..255) |
String for IPv6 packet matching. |
hh3cAclEnUserL4String (1.3.6.1.4.1.25506.2.8.2.4.3.1.9) |
read-create |
OCTET STRING |
SIZE (0..255) |
String for Layer 4 packet matching. |
hh3cAclEnUserL5String (1.3.6.1.4.1.25506.2.8.2.4.3.1.10) |
read-create |
OCTET STRING |
SIZE (0..255) |
String for Layer 5 packet matching. |
Not supported |
hh3cAclEnUserTimeRangeName (1.3.6.1.4.1.25506.2.8.2.4.3.1.11) |
read-create |
OCTET STRING |
SIZE (0..32) |
Time range name. |
As per the MIB. |
hh3cAclEnUserCount (1.3.6.1.4.1.25506.2.8.2.4.3.1.12) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cAclEnUserCountClear (1.3.6.1.4.1.25506.2.8.2.4.3.1.13) |
read-write |
CounterClear |
Not supported |
hh3cAclEnUserEnable (1.3.6.1.4.1.25506.2.8.2.4.3.1.14) |
read-only |
TruthValue |
As per the MIB. |
hh3cAclEnUserComment (1.3.6.1.4.1.25506.2.8.2.4.3.1.15) |
read-create |
OCTET STRING |
SIZE (0..127) |
Rule description. |
Read and write. |
hh3cAclEnUserLog (1.3.6.1.4.1.25506.2.8.2.4.3.1.16) |
read-create |
TruthValue |
Not supported |
hh3cAclEnUserCounting (1.3.6.1.4.1.25506.2.8.2.4.3.1.17) |
read-create |
TruthValue |
As per the MIB. |
hh3cAclNamedUserTable
About this table
This table records named user-defined ACL configuration information. Use this table to add or delete a rule for a named user-defined ACL rule.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cAclNumberGroupType, h3cAclNamedGroupName, and h3cAclEnUserRuleIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAclNamedUserRowStatus (1.3.6.1.4.1.25506.2.8.2.4.4.1.1) |
read-create |
RowStatus |
Row status. |
hh3cAclNamedUserAct (1.3.6.1.4.1.25506.2.8.2.4.4.1.2) |
read-create |
RuleAction |
Action type. |
hh3cAclNamedUserStartString (1.3.6.1.4.1.25506.2.8.2.4.4.1.3) |
read-create |
OCTET STRING |
SIZE (0..255) |
Not supported |
hh3cAclNamedUserL2String (1.3.6.1.4.1.25506.2.8.2.4.4.1.4) |
read-create |
OCTET STRING |
SIZE (0..255) |
hh3cAclNamedUserMplsString (1.3.6.1.4.1.25506.2.8.2.4.4.1.5) |
read-create |
OCTET STRING |
SIZE (0..255) |
Not supported |
hh3cAclNamedUserIPv4String (1.3.6.1.4.1.25506.2.8.2.4.4.1.6) |
read-create |
OCTET STRING |
SIZE (0..255) |
hh3cAclNamedUserIPv6String (1.3.6.1.4.1.25506.2.8.2.4.4.1.7) |
read-create |
OCTET STRING |
SIZE (0..255) |
hh3cAclNamedUserL4String (1.3.6.1.4.1.25506.2.8.2.4.4.1.8) |
read-create |
OCTET STRING |
SIZE (0..255) |
hh3cAclNamedUserL5String (1.3.6.1.4.1.25506.2.8.2.4.4.1.9) |
read-create |
OCTET STRING |
SIZE (0..255) |
Not supported |
hh3cAclNamedUserTimeRangeName (1.3.6.1.4.1.25506.2.8.2.4.4.1.10) |
read-create |
OCTET STRING |
SIZE (0..32) |
Time range name. |
As per the MIB. |
hh3cAclNamedUserCount (1.3.6.1.4.1.25506.2.8.2.4.4.1.11) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cAclNamedUserCountClear (1.3.6.1.4.1.25506.2.8.2.4.4.1.12) |
read-write |
CounterClear |
Not supported |
hh3cAclNamedUserEnable (1.3.6.1.4.1.25506.2.8.2.4.4.1.13) |
read-only |
TruthValue |
As per the MIB. |
hh3cAclNamedUserComment (1.3.6.1.4.1.25506.2.8.2.4.4.1.14) |
read-create |
OCTET STRING |
SIZE (0..127) |
Rule description. |
Read and write. |
hh3cAclNamedUserLog (1.3.6.1.4.1.25506.2.8.2.4.4.1.15) |
read-create |
TruthValue |
Not supported |
hh3cAclNamedUserCounting (1.3.6.1.4.1.25506.2.8.2.4.4.1.16) |
read-create |
TruthValue |
As per the MIB. |
hh3cAclResourceUsageTable
About this table
This table obtains the ACL TCAM resource usage information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are h3cAclResourceChassis, h3cAclResourceSlot, h3cAclResourceChip, and hh3cAclResourceType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAclResourceChassis (1.3.6.1.4.1.25506.2.8.2.5.1.1.1) |
not-accessible |
Unsigned32 |
Chassis number. |
As per the MIB. |
hh3cAclResourceSlot (1.3.6.1.4.1.25506.2.8.2.5.1.1.2) |
not-accessible |
Unsigned32 |
Slot number. |
As per the MIB. |
hh3cAclResourceChip (1.3.6.1.4.1.25506.2.8.2.5.1.1.3) |
not-accessible |
Unsigned32 |
Chip number that the ACL TCAM resource maps to. |
As per the MIB. |
hh3cAclResourceType (1.3.6.1.4.1.25506.2.8.2.5.1.1.4) |
not-accessible |
Integer32 |
1..255 |
Type of the ACL TCAM resources. |
As per the MIB. |
hh3cAclPortRange (1.3.6.1.4.1.25506.2.8.2.5.1.1.5) |
read-only |
OCTET STRING |
SIZE (0..255) |
Port range of the ACL TCAM resources. |
As per the MIB. |
hh3cAclResourceTotal (1.3.6.1.4.1.25506.2.8.2.5.1.1.6) |
read-only |
Unsigned32 |
Total number of the resources of the current type. |
As per the MIB. |
hh3cAclResourceReserved (1.3.6.1.4.1.25506.2.8.2.5.1.1.7) |
read-only |
Unsigned32 |
Number of reserved resources of the current type. |
As per the MIB. |
hh3cAclResourceConfigured (1.3.6.1.4.1.25506.2.8.2.5.1.1.8) |
read-only |
Unsigned32 |
Number of allocated resources of the current type. |
As per the MIB. |
hh3cAclResourceUsagePercent (1.3.6.1.4.1.25506.2.8.2.5.1.1.9) |
read-only |
Unsigned32 |
Usage of the resources of the current type. |
As per the MIB. |
hh3cAclResourceTypeDescription (1.3.6.1.4.1.25506.2.8.2.5.1.1.10) |
read-only |
OCTET STRING |
SIZE (0..31) |
Description of the ACL resource type. |
As per the MIB. |
hh3cAclIntervalTable
About this table
This table records ACL logging and notification configuration.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is h3cAclIntervalType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAclIntervalType (1.3.6.1.4.1.25506.2.8.2.6.1.1.1) |
not-accessible |
INTEGER |
· logging(1) · trap(2) |
Object type of the interval. |
As per the MIB. |
hh3cAclIntervalValue (1.3.6.1.4.1.25506.2.8.2.6.1.1.2) |
read-create |
Integer32 |
5..1440 |
Interval value. |
As per the MIB. |
hh3cAclIntervalRowStatus (1.3.6.1.4.1.25506.2.8.2.6.1.1.3) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cPfilterApplyTable
About this table
This MIB records packet filter application configuration. You can apply or cancel the packet filter configuration on a specified entity.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cPfilterApplyObjType, h3cPfilterApplyObjIndex, h3cPfilterApplyDirection, h3cPfilterApplyAclType, and h3cPfilterApplyAclIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPfilterApplyObjType (1.3.6.1.4.1.25506.2.8.3.2.1.1) |
not-accessible |
INTEGER |
· interface (1) · vlan(2) · global(3) |
Entity type of the packet filter application. |
hh3cPfilterApplyObjIndex (1.3.6.1.4.1.25506.2.8.3.2.1.2) |
not-accessible |
Integer32 |
0..2147483647 |
Packet filter application index. |
As per the MIB. |
hh3cPfilterApplyDirection (1.3.6.1.4.1.25506.2.8.3.2.1.3) |
not-accessible |
DirectionType |
Packet filter application direction. |
As per the MIB. |
hh3cPfilterApplyAclType (1.3.6.1.4.1.25506.2.8.3.2.1.4) |
not-accessible |
INTEGER |
· ipv4(1) · ipv6(2) · default(3) · mac(4) · user(5) |
Type of the ACL in the packet filter. |
hh3cPfilterApplyAclIndex (1.3.6.1.4.1.25506.2.8.3.2.1.5) |
not-accessible |
Integer32 |
0 2000..5999 |
Number of the ACL in the packet filter. |
hh3cPfilterApplyHardCount (1.3.6.1.4.1.25506.2.8.3.2.1.6) |
read-create |
TruthValue |
Enabling status of hardware counting. |
hh3cPfilterApplySequence (1.3.6.1.4.1.25506.2.8.3.2.1.7) |
read-only |
Unsigned32 |
Packet filtering application sequence number. |
As per the MIB. |
hh3cPfilterApplyCountClear (1.3.6.1.4.1.25506.2.8.3.2.1.8) |
read-write |
CounterClear |
Clear statistics for the specified ACL. |
As per the MIB. |
hh3cPfilterApplyRowStatus (1.3.6.1.4.1.25506.2.8.3.2.1.9) |
read-create |
RowStatus |
Row status. |
About this table
This table records ACL running inforamtion in packet filter. Use this table to obtain the packet filter status and statistics from a specified entity.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are h3cPfilterRunApplyObjType, h3cPfilterRunApplyObjIndex, h3cPfilterRunApplyDirection, h3cPfilterRunApplyAclType, and h3cPfilterRunApplyAclIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPfilterRunApplyObjType (1.3.6.1.4.1.25506.2.8.3.3.1.1) |
not-accessible |
INTEGER |
Type of the entity on which the packet filter running information is obtained. |
hh3cPfilterRunApplyObjIndex (1.3.6.1.4.1.25506.2.8.3.3.1.2) |
not-accessible |
Integer32 |
0..2147483647 |
As per the MIB. |
hh3cPfilterRunApplyDirection (1.3.6.1.4.1.25506.2.8.3.3.1.3) |
not-accessible |
DirectionType |
Direction of the packet filter application. |
As per the MIB. |
hh3cPfilterRunApplyAclType (1.3.6.1.4.1.25506.2.8.3.3.1.4) |
not-accessible |
INTEGER |
Type of the ACL used in the packet filter application. |
hh3cPfilterRunApplyAclIndex (1.3.6.1.4.1.25506.2.8.3.3.1.5) |
not-accessible |
Integer32 |
· 1..3 · 2000..5999 |
Number of the ACL used in the packet filter application. |
hh3cPfilterAclGroupStatus (1.3.6.1.4.1.25506.2.8.3.3.1.6) |
read-only |
INTEGER |
· success(1) · failed(2) · partialSuccess(3) |
Application status of the ACL for the packet filter. |
As per the MIB. |
hh3cPfilterAclGroupCountStatus (1.3.6.1.4.1.25506.2.8.3.3.1.7) |
read-only |
INTEGER |
Enabling status of the hardware count for the ACL used by the packet filter. |
hh3cPfilterAclGroupPermitPkts (1.3.6.1.4.1.25506.2.8.3.3.1.8) |
read-only |
Counter64 |
Number of packets permitted by the ACL. |
hh3cPfilterAclGroupPermitBytes (1.3.6.1.4.1.25506.2.8.3.3.1.9) |
read-only |
Counter64 |
Number of bytes permitted by the ACL. |
hh3cPfilterAclGroupDenyPkts (1.3.6.1.4.1.25506.2.8.3.3.1.10) |
read-only |
Counter64 |
Number of packets dropped by the ACL. |
hh3cPfilterAclGroupDenyBytes (1.3.6.1.4.1.25506.2.8.3.3.1.11) |
read-only |
Counter64 |
Number of bytes dropped by the ACL. |
About this table
This table records the ACL rule running information for the packet filter. Use this table to obtain the packet filter status and statistics on an entity.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are h3cPfilterRunApplyObjType, h3cPfilterRunApplyObjIndex, h3cPfilterRunApplyDirection, h3cPfilterRunApplyAclType, h3cPfilterRunApplyAclIndex, and h3cPfilterAclRuleIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPfilterAclRuleIndex (1.3.6.1.4.1.25506.2.8.3.4.1.1) |
not-accessible |
Integer32 |
0..65534 |
ACL rule ID. |
As per the MIB. |
hh3cPfilterAclRuleStatus (1.3.6.1.4.1.25506.2.8.3.4.1.2) |
read-only |
INTEGER |
Application status of the ACL rule. |
As per the MIB. |
hh3cPfilterAclRuleCountStatus (1.3.6.1.4.1.25506.2.8.3.4.1.3) |
read-only |
INTEGER |
Enabling status of the rule match count. |
hh3cPfilterAclRuleMatchPackets (1.3.6.1.4.1.25506.2.8.3.4.1.4) |
read-only |
Counter64 |
hh3cPfilterAclRuleMatchBytes (1.3.6.1.4.1.25506.2.8.3.4.1.5) |
read-only |
Counter64 |
Number of bytes matching the ACL rule. |
hh3cPfilterStatisticSumTable
About this table
Use this table to obtain the accumulated packet filter statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are h3cPfilterSumDirection, h3cPfilterSumAclType, h3cPfilterSumAclIndex, and h3cPfilterSumRuleIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPfilterSumDirection (1.3.6.1.4.1.25506.2.8.3.5.1.1) |
not-accessible |
DirectionType |
Direction of the application for which the accumulated statistics is obtained. |
As per the MIB. |
hh3cPfilterSumAclType (1.3.6.1.4.1.25506.2.8.3.5.1.2) |
not-accessible |
INTEGER |
Type of the ACL for which the accumulated statistics is obtained. |
hh3cPfilterSumAclIndex (1.3.6.1.4.1.25506.2.8.3.5.1.3) |
not-accessible |
Integer32 |
2000..5999 |
Number of the ACL for which the accumulated statistics is obtained. |
hh3cPfilterSumRuleIndex (1.3.6.1.4.1.25506.2.8.3.5.1.4) |
not-accessible |
Integer32 |
0..65534 |
Number of the ACL rule for which the accumulated statistics is obtained. |
As per the MIB. |
hh3cPfilterSumRuleMatchPackets (1.3.6.1.4.1.25506.2.8.3.5.1.5) |
read-only |
Counter64 |
Number of packets matching the rule in the packet filter. |
hh3cPfilterSumRuleMatchBytes (1.3.6.1.4.1.25506.2.8.3.5.1.6) |
read-only |
Counter64 |
Number of bytes matching the rule in the packet filter. |
hh3cPfilter2ApplyTable
About this table
This table records the packet filter application configuration. Use this table to apply or cancel the packet filter configuration on an entity.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cPfilter2ApplyObjType, h3cPfilter2ApplyObjIndex, h3cPfilter2ApplyDirection, h3cPfilter2ApplyAclType, and h3cPfilter2ApplyAclIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPfilter2ApplyObjType (1.3.6.1.4.1.25506.2.8.3.6.1.1) |
accessible-for-notify |
INTEGER |
Type of the application object. |
hh3cPfilter2ApplyObjIndex (1.3.6.1.4.1.25506.2.8.3.6.1.2) |
Integer32 |
0..2147483647 |
Index of the application object. |
As per the MIB. |
hh3cPfilter2ApplyDirection (1.3.6.1.4.1.25506.2.8.3.6.1.3) |
DirectionType |
As per the MIB. |
hh3cPfilter2ApplyAclType (1.3.6.1.4.1.25506.2.8.3.6.1.4) |
INTEGER |
Type of the ACL used by the packet filter. |
hh3cPfilter2ApplyAclIndex (1.3.6.1.4.1.25506.2.8.3.6.1.5) |
OCTET STRING |
SIZE (1..63) |
Number or name of the ACL used by the packet filter. |
hh3cPfilter2ApplyHardCount (1.3.6.1.4.1.25506.2.8.3.6.1.6) |
read-create |
TruthValue |
hh3cPfilter2ApplySequence (1.3.6.1.4.1.25506.2.8.3.6.1.7) |
read-only |
Unsigned32 |
Packet filter application sequence number. |
As per the MIB. |
hh3cPfilter2ApplyCountClear (1.3.6.1.4.1.25506.2.8.3.6.1.8) |
read-write |
CounterClear |
As per the MIB. |
About this table
This table records the ACL running information for the packet filter. Use this table to obtain the packet filter status and statistics from an entity. Different from h3cPfilterAclGroupRunInfoTable, hh3cPfilter2RunApplyAclIndex in this table supports obtaining statistics for numbered and named ACL.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are h3cPfilter2RunApplyObjType, h3cPfilter2RunApplyObjIndex, h3cPfilter2RunApplyDirection, h3cPfilter2RunApplyAclType, and h3cPfilter2RunApplyAclIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPfilter2RunApplyObjType (1.3.6.1.4.1.25506.2.8.3.7.1.1) |
not-accessible |
INTEGER |
Type of the entity on which the ACL running information is obtained. |
hh3cPfilter2RunApplyObjIndex (1.3.6.1.4.1.25506.2.8.3.7.1.2) |
not-accessible |
Integer32 |
0..2147483647 |
As per the MIB. |
hh3cPfilter2RunApplyDirection (1.3.6.1.4.1.25506.2.8.3.7.1.3) |
not-accessible |
DirectionType |
As per the MIB. |
hh3cPfilter2RunApplyAclType (1.3.6.1.4.1.25506.2.8.3.7.1.4) |
not-accessible |
INTEGER |
Type of the ACL used in the packet filter. |
hh3cPfilter2RunApplyAclIndex (1.3.6.1.4.1.25506.2.8.3.7.1.5) |
not-accessible |
OCTET STRING |
SIZE (1..63) |
Number of name of the ACL. |
hh3cPfilter2AclGroupStatus (1.3.6.1.4.1.25506.2.8.3.7.1.6) |
read-only |
INTEGER |
Application status of the ACL. |
As per the MIB. |
hh3cPfilter2AclGroupCountStatus (1.3.6.1.4.1.25506.2.8.3.7.1.7) |
read-only |
INTEGER |
hh3cPfilter2AclGroupPermitPkts (1.3.6.1.4.1.25506.2.8.3.7.1.8) |
read-only |
Counter64 |
hh3cPfilter2AclGroupPermitBytes (1.3.6.1.4.1.25506.2.8.3.7.1.9) |
read-only |
Counter64 |
hh3cPfilter2AclGroupDenyPkts (1.3.6.1.4.1.25506.2.8.3.7.1.10) |
read-only |
Counter64 |
hh3cPfilter2AclGroupDenyBytes (1.3.6.1.4.1.25506.2.8.3.7.1.11) |
read-only |
Counter64 |
About this table
This table records the ACL rule running information for the packet filter. Use this table to obtain the packet filter status and statistics from an entity. Different from the tableh3cPfilterAclRuleRunInfoTable, the index in this table supports obtaining statistics for numbered and named ACL.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are h3cPfilter2RunApplyObjType, h3cPfilter2RunApplyObjIndex, h3cPfilter2RunApplyDirection, h3cPfilter2RunApplyAclType, h3cPfilter2RunApplyAclIndex, and h3cPfilter2AclRuleIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPfilter2AclRuleIndex (1.3.6.1.4.1.25506.2.8.3.8.1.1) |
Integer32 |
0..65534 |
ACL rule ID. |
As per the MIB. |
hh3cPfilter2AclRuleStatus (1.3.6.1.4.1.25506.2.8.3.8.1.2) |
read-only |
INTEGER |
As per the MIB. |
hh3cPfilter2AclRuleCountStatus (1.3.6.1.4.1.25506.2.8.3.8.1.3) |
read-only |
INTEGER |
As per the MIB. |
hh3cPfilter2AclRuleMatchPkts (1.3.6.1.4.1.25506.2.8.3.8.1.4) |
read-only |
Counter64 |
As per the MIB. |
hh3cPfilterAclNameRuleMatchBytes (1.3.6.1.4.1.25506.2.8.3.8.1.5) |
read-only |
Counter64 |
Not support |
hh3cPfilter2StatisticSumTable
About this table
This table records the accumulated ACL rule statistics for the packet filter. Different from the h3cPfilterStatisticSumTable, the h3cPfilter2SumAclIndex in this table supports numbered and named ACL.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are h3cPfilter2SumDirection, h3cPfilter2SumAclType, h3cPfilter2SumAclIndex, and h3cPfilter2SumRuleIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPfilter2SumDirection (1.3.6.1.4.1.25506.2.8.3.9.1.1) |
not-accessible |
DirectionType |
Direction of packet filter. |
As per the MIB. |
hh3cPfilter2SumAclType (1.3.6.1.4.1.25506.2.8.3.9.1.2) |
not-accessible |
INTEGER |
hh3cPfilter2SumAclIndex (1.3.6.1.4.1.25506.2.8.3.9.1.3) |
not-accessible |
OCTET STRING |
SIZE (1..63) |
Number or name of the ACL. |
hh3cPfilter2SumRuleIndex (1.3.6.1.4.1.25506.2.8.3.9.1.4) |
not-accessible |
INTEGER |
0..65534 |
ACL rule ID. |
As per the MIB. |
hh3cPfilter2SumRuleMatchPackets (1.3.6.1.4.1.25506.2.8.3.9.1.5) |
read-only |
Counter64 |
Notifications
This section describes the HH3C-ACL-MIB notifications.
hh3cAclRuleMatchCount
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.8.5.0.2 |
Notification for the ACL rule matches. |
Informational |
OFF |
When a trap interval is set through the table hh3cAclIntervalTable, notifications will be generated at intervals. The notification information includes the number of rule matches in the interval.
Status control
ON
· CLI: Use the acl trap interval interval command.
· MIB: Set hh3cAclIntervalType to trap(2), set the hh3cAclIntervalValue to a value in the range of 5 to 1440, and use the table hh3cAclIntervalTable to perform a create operation.
OFF
· MIB: Use the table hh3cAclIntervalTable to perform a destroy operation.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.8.3.6.1.1 (hh3cPfilter2ApplyObjType) |
Object to which the ACL is applied. |
Yes |
INTEGER |
· interface(1) · vlan(2) · global(3) |
1.3.6.1.4.1.25506.2.8.3.6.1.2 (hh3cPfilter2ApplyObjIndex) |
Object index. |
Yes |
Integer32 |
0 to 2147483647 |
1.3.6.1.4.1.25506.2.8.3.6.1.3 (hh3cPfilter2ApplyDirection) |
Direction of the packet filter. |
Yes |
INTEGER |
· inbound(1) · outbound(2) |
1.3.6.1.4.1.25506.2.8.3.6.1.4 (hh3cPfilter2ApplyAclType) |
Type of the ACL. |
No |
INTEGER |
1.3.6.1.4.1.25506.2.8.3.6.1.5 (hh3cPfilter2ApplyAclIndex) |
ACL index. |
Yes |
OCTET STRING |
SIZE (1 to 63) |
1.3.6.1.4.1.25506.2.8.3.8.1.1 (hh3cPfilter2AclRuleIndex) |
ACL rule index |
Yes |
Integer32 |
0 to 65534. |
1.3.6.1.4.1.25506.2.8.3.8.1.4 (hh3cPfilter2AclRuleMatchPackets) |
ACL rule match count. |
No |
Counter64 |
0 to 18446744073709551615. |
Recommended action
No action is required.
hh3cAclFirstIPv4PktCaptured
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.8.5.0.3 |
Notification for the first IPv4 packet of a flow that match the ACL. |
Informational |
OFF |
After a trap interval is set through hh3cAclIntervalTable, a notification is generated when the first packet of a flow matches an ACL rule in the packet filter. The notification information includes the first packet information.
Status control
ON
· MIB: Set hh3cAclIntervalType to trap(2), set hh3cAclIntervalValue to a value in the range of 5 to 1440, and use the table hh3cAclIntervalTable to perform a create operation.
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
ACL index. |
Yes |
OCTET STRING |
SIZE (1 to 63) |
ACL rule index. |
Yes |
Integer32 |
0 to 65534 |
1.3.6.1.4.1.25506.2.8.4.9 (hh3cAclPacketIfName) |
Interface name. |
Yes |
OCTET STRING |
SIZE (0 to 255) |
1.3.6.1.4.1.25506.2.8.4.10 (hh3cAclPacketDirection) |
Application direction. |
Yes |
INTEGER |
1.3.6.1.4.1.25506.2.8.4.11 (hh3cAclPacketBAGG) |
Aggregation group ID. |
No |
Integer32 |
0 to 2048 |
1.3.6.1.4.1.25506.2.8. 4.12 (hh3cAclPacketVlanID) |
VLAN ID |
No |
Integer32 |
0 to 4094 |
1.3.6.1.4.1.25506.2.8.4.13 (hh3cAclPacketSrcIP) |
Packet source IP address. |
No |
OCTET STRING |
SIZE (1 to 255) |
1.3.6.1.4.1.25506.2.8.4.14 (hh3cAclPacketDstIP) |
Packet destination IP address. |
No |
OCTET STRING |
SIZE (1 to 255) |
1.3.6.1.4.1.25506.2.8.4.15 (hh3cAclPacketProtocol) |
Protocol. |
No |
Integer32 |
0 to 255 |
1.3.6.1.4.1.25506.2.8.4.16 (hh3cAclPacketDscp) |
DSCP priority. |
No |
Integer32 |
0 to 2147483647 |
1.3.6.1.4.1.25506.2.8.4.18 (hh3cAclPacketIcmpIgmpType) |
No |
Integer32 |
0 to 255 |
1.3.6.1.4.1.25506.2.8.4.19 (hh3cAclPacketIcmpIgmpCode) |
No |
Integer32 |
0 to 255 |
1.3.6.1.4.1.25506.2.8.4.20 (hh3cAclPacketTcpFlags) |
Packet TCP flag. |
No |
INTEGER |
· tcpack(1) · tcpfin(2) · tcppsh(3) · tcprst(4) · tcpsyn(5) · tcpurg(6) · invalid(255) |
1.3.6.1.4.1.25506.2.8.4.21 (hh3cAclPacketSrcPort) |
Source port number of the packet. |
No |
Integer32 |
0 to 65535 |
1.3.6.1.4.1.25506.2.8.4.22 (hh3cAclPacketDstPort) |
Destination port number of the packet. |
No |
Integer32 |
0 to 65535 |
Recommended action
hh3cAclFirstIPv6PktCaptured
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.8.5.0.4 |
Notification for the first IPv6 packet of a flow that match the ACL. |
Informational |
OFF |
Status control
ON
OFF
· MIB: Use the table hh3cAclIntervalTable to perform a destroy action.
Objects
OID (object name) |
Index |
Type |
Value range |
ACL index. |
Yes |
OCTET STRING |
SIZE (1 to 63) |
ACL rule index. |
Yes |
Integer32 |
0 to 65534 |
Interface name. |
Yes |
OCTET STRING |
SIZE (0 to 255) |
Yes |
INTEGER |
No |
Integer32 |
0 to 2048 |
VLAN ID |
No |
Integer32 |
0 to 4094 |
No |
OCTET STRING |
SIZE (1 to 255) |
Packet Destination IP address. |
No |
OCTET STRING |
SIZE (1 to 255) |
Packet protocol. |
No |
Integer32 |
0 to 255 |
Packet DSCP value. |
No |
Integer32 |
0 to 2147483647 |
1.3.6.1.4.1.25506.2.8.4.17 (hh3cAclPacketFlowLabel) |
Packet flow label. |
No |
Unsigned32 |
· 0 to 1048575 · 4294967295 |
IGMP message type. |
No |
Integer32 |
0 to 255 |
IGMP message code. |
No |
Integer32 |
0 to 255 |
TCP flag. |
No |
INTEGER |
Packet source port number. |
No |
Integer32 |
0 to 65535 |
Packet destination port number. |
No |
Integer32 |
0 to 65535 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.8.5.0.5 |
Notification for the first Layer 2 packet of a flow that match the ACL. |
Informational |
OFF |
Status control
ON
· MIB: Set hh3cAclIntervalType to trap(2), set hh3cAclIntervalValue to a value range of 5 to 1440, and use the table hh3cAclIntervalTable to perform a create operation.
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
ACL index. |
Yes |
OCTET STRING |
SIZE (1 to 63) |
ACL rule index. |
Yes |
Integer32 |
0 to 65534 |
Interface name. |
Yes |
OCTET STRING |
SIZE (0 to 255) |
Yes |
INTEGER |
No |
Integer32 |
0 to 2048 |
1.3.6.1.4.1.25506.2.8.4.12 (hh3cAclPacketVlanID) |
VLAN ID |
No |
Integer32 |
0 to 4094 |
1.3.6.1.4.1.25506.2.8.4.23 (hh3cAclPacketSrcMacAddr) |
Packet source MAC address. |
No |
MacAddress |
OCTET STRING (SIZE (6)) |
1.3.6.1.4.1.25506.2.8.4.24 (hh3cAclPacketDstMacAddr) |
Packet destination MAC address. |
No |
MacAddress |
1.3.6.1.4.1.25506.2.8.4.25 (hh3cAclPacketMacTypeLen) |
Link layer protocol type. |
No |
Integer32 |
0 to 65535 |
1.3.6.1.4.1.25506.2.8.4.26 (hh3cAclPacketVlanPCP) |
VLAN priority. |
No |
Integer32 |
· 0 to 7 · 255 |
Recommended action
hh3cAclResourceTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.8.7.0.1 |
TCAM resource usage notification. |
Informational |
OFF |
Notifications will be generated for violations of threshold set by hh3cAclMib2ResourceThreshold at intervals set by hh3cAclMib2ResourceLogInterval. The notification information includes the Ternary Content Addressable Memory (TCAM) resource usage for each card.
Status control
ON
· CLI: Use the commands:
¡ acl resource threshold percent percent
¡ acl resource log interval interval
· MIB: Set hh3cAclMib2ResourceThreshold to a value in the range of 1 to 100, and set hh3cAclMib2ResourceLogInterval to a value in the range of 1 to 60.
OFF
¡ undo acl resource threshold percent
¡ undo acl log threshold interval
· MIB: Set hh3cAclMib2ResourceThreshold to 0, and set hh3cAclMib2ResourceLogInterval to 0.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.8.6.1 (hh3cAclResourceTypeName) |
Resource type. |
No |
OCTET STRING |
SIZE (1 to 255) |
1.3.6.1.4.1.25506.2.8.6.2 (hh3cAclResourceUsage) |
Resource usage. |
No |
Integer32 |
0 to 100 |
1.3.6.1.4.1.25506.2.8.6.3 (hh3cAclResourceUsedEntries) |
Number of used resources. |
No |
Integer32 |
1.3.6.1.4.1.25506.2.8.6.4 (hh3cAclResourceTotalEntries) |
Total number of resources. |
No |
INTEGER |
1.3.6.1.4.1.25506.2.8.2.1.1.5 (hh3cAclMib2ResourceThreshold) |
Resource usage alarm threshold. |
No |
Integer32 |
0 to 100 |
1.3.6.1.4.1.25506.2.8.6.5 (hh3cAclResourceChassisID) |
Chassis number. |
Yes |
Integer32 |
1.3.6.1.4.1.25506.2.8.6.6 (hh3cAclResourceSlotID) |
Slot number. |
Yes |
Integer32 |
Recommended action
