10-HH3C-TRAP-MIB | 59.71 KB |
HH3C-TRAP-MIB
About this MIB
Use this MIB to enable the device to send a notification to a network management station when a specific event occurs, such as a MAC address table getting full.
MIB file name
hh3c-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cTrap(38)
Scalar objects
hh3cPeriodicalTrapInterval
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPeriodicalTrapInterval (1.3.6.1.4.1.25506.2.38.1.6.1.1) |
read-write |
Integer32 |
Integer32 (0 | 10..3600) |
Interval for sending periodical traps, in seconds. |
Implementation varies by product |
hh3cPeriodicalTrapSwitch
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPeriodicalTrapSwitch (1.3.6.1.4.1.25506.2.38.1.6.1.2) |
read-write |
INTEGER |
enable(1), disable(2) |
Status of the periodical trap sending feature. |
Tabular objects
hh3cTrapDesInfoTable
About this table
Use this table to configure a trap destination host address and port number.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cTrapDesInfoIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTrapDesInfoIndex (1.3.6.1.4.1.25506.2.38.1.7.1.1.1) |
not-accessible |
Integer32 |
Integer32 (1..20) |
Index of a trap destination information entry. |
As per the MIB. |
hh3cTrapDesIPAddress (1.3.6.1.4.1.25506.2.38.1.7.1.1.2) |
read-create |
IpAddress |
Standard MIB values |
Trap destination host IP address. |
As per the MIB. |
hh3cTrapDesPort (1.3.6.1.4.1.25506.2.38.1.7.1.1.3) |
read-create |
Integer32 |
Integer32 (0..65535) |
Trap destination port number. |
As per the MIB. |
hh3cTrapDesRowStatus (1.3.6.1.4.1.25506.2.38.1.7.1.1.4) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
Supports only active(1), createAndGo(4), and destroy(6). |
hh3cTrapDesAddrTAddress (1.3.6.1.4.1.25506.2.38.1.7.1.1.5) |
read-create |
TAddress |
Transport address. |
As per the MIB. |
Notifications
This section contains the HH3C-TRAP-MIB notifications.
hh3cArpTabFullTrap
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.38.1.2.4.1 |
ARP table full |
Informational |
Major |
N/A |
ON |
This notification is generated when the ARP table gets full.
Status control
This notification cannot be disabled.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.38.1.2.3.1 (hh3cArpTabLen) |
Length of the ARP table. |
N |
Integer32 |
Standard MIB values. |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
hh3cRtTabFullTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.38.1.3.5.1 |
Routing table full |
Informational |
Major |
N/A |
ON |
This notification is generated when the routing table gets full.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.38.1.3.4.1 (hh3cRtTabLen) |
Length of the routing table. |
N |
Integer32 |
Recommended action
hh3cNdTabFullTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.38.1.5.4.1 |
ND table full |
Informational |
Major |
N/A |
ON |
This notification is generated when the ND table gets full.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.38.1.5.3.1 (hh3cNdTabLen) |
Length of the ND table. |
N |
Integer32 |
Recommended action
hh3cPeriodicalTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.38.1.6.3.0.1 |
SNMP periodical trap |
Informational |
N/A |
N/A |
ON |
If no trap occurs during the interval specified by hh3cPeriodicalTrapInterval, an hh3cPeriodicalTrap is generated. If the interval is set to 0, no hh3cPeriodicalTrap will be generated.
Status control
ON
MIB: Set hh3cPeriodicalTrapSwitch to enable(1).
OFF
MIB: Set hh3cPeriodicalTrapSwitch to disable(2).
Objects
N/A
Recommended action
