Current status and challenges
Companies may face the following challenges in the information construction process. For example, the chimney-type construction of each application leads to data isolation, making it difficult to share data, and services between systems cannot be linked; it takes a long time to bring new services online; the technical architecture of each application system is different, resulting in high maintenance costs; multiple sensing devices and hardware gateways exist in the system, resulting in repeated infrastructure construction.
Solution
In the Internet of Everything era, the oasis IoT platform implements the concept of all connection through a platform. In the southward direction, the platform can be used in various device access scenarios. In the northward direction, the platform provides the data opening capability to facilitate enterprise digital transformation.
Advantages
1. Support unified management of short-distance wireless devices and low-power WAN
The oasis IoT platform supports access management of short-distance wireless devices such as Zigbee, 2.4G/433M RFID, and Bluetooth, and the unified management of long-distance and low-power WAN such as LoRa WAN and NB-IoT.
2. Support multiple positioning engines
The oasis IoT platform has built-in multiple positioning engines, including Bluetooth, RFID, and UWB. They can meet the needs of different customers for different positioning accuracy from centimeter level to room level.
3. Provide third-party open access
The IoT platform has a perfect third-party open capability, and supports obtaining device data through Mqtt subscription mode and restAPI mode.
Overall architecture
1. System management
Realize the management of user accounts, hierarchical authority management, industry application management, and the management of third-party open APIs in the system
2. Connection management
The oasis IoT platform has abundant connection protocols, including customized protocols such as TCP\UDP, MQTT, COAP, and HTTP, which can meet access requirements of most devices.
3. Link management
The oasis IoT platform has built-in multiple link services, including Modbus Server, Zigbee Server, and LoRa Server, which can meet adaptation requirements of multiple link layer protocols.
4. Device management
Complete the definition of object model, management of the device lifecycle, certification and authentication of devices, and deployment of the devices, etc.
5. Network management
Complete the survey and configuration of LoRa network, and the smart O&M and optimization of the whole network later.
6. Rule engine
Complete the linkage of devices, alarm triggering, and data forwarding to the third-party platform.
Typical cases
Hangzhou Wasu smart community
Technical solution
Complete the smart sensing data collection based on the LoRa IoT and realize multi-service linkage by using the unified scenario-based model on the IoT platform
Smart community application cloud platform
Community fire control: Wireless smoke detection, and real-time monitoring of fire water and power consumption
Community: Mobile population safety control based on smart door lock
Benefits of smart community case
A large number of terminals are connected to establish a multi-dimensional data perception system of a smart community
The IoT platform obtains real-time IoT data to lay a foundation for developing smart city services
