Introduction to homogeneous hybrid cloud solution
The H3C UIS hyper converged homogeneous hybrid cloud solution, combined with the local H3C hyper converged private cloud data center and the UIS on Unicloud, realizes the high-speed interconnection between the local private cloud (local cloud) and UIS on Unicloud (public cloud) with the help of SD-WAN. It also realizes unified management of hybrid cloud resources, smooth migration of cloud rainbow services, disaster recovery backup and other advanced features.
Application scenarios
1) Emergency resource expansion
Since the budget is limited, the remaining hardware resources of the UIS private cloud data center cannot meet the demands of new business deployment. By investing a small amount of money to deploy UIS on Unicloud on a monthly basis, the cluster can be expanded quickly on demand, greatly shortening the expansion cycle of the resource pool, and obtaining more short-term resources in time to meet the business demands. Meanwhile, with the help of the enterprise edition of UIS hyper converged solution, unified management of resources of local and public clouds can be realized, which is easy to use and maintain. When the budget for next year is issued, it can be easily migrated back from public cloud to private cloud.
2) Smooth service migration
With sufficient budget, the local UIS hyper converged expansion will be carried out, and the services deployed on the Unicloud public cloud will be seamlessly migrated back to the local private cloud data center, making services more controllable. Based on the hyper converged architecture of UIS on Unicloud and UIS cloud rainbow service, the VM service load can be freely and smoothly migrated between the Unicloud public cloud and private cloud data center without service interruption. If the broadband network with 100M bandwidth is configured, and the migration of a 100G VM takes 2.5 hours. If a Gigabit leased line is configured, the migration of a 100G VM will take less than 15 minutes.
3) Lack of funds to build a remote disaster recovery center
Use the UIS hyper converged homogeneous hybrid cloud solution for disaster recovery on the cloud, and use the Unicloud public cloud for disaster recovery backup of the private cloud. No establishment of disaster recovery center is required; resources are purchased on demand; services are flexible and investment costs are greatly saved.
The UIS site disaster recovery service supports agent-free replication and synchronization of storage data, provides a variety of disaster recovery scenarios (planned fault recovery, test recovery plan, fault recovery and reverse recovery), one-click disaster recovery drill, one-stop management of private cloud local sites and public cloud remote sites, realizes automatic synchronization of VM configuration, and greatly improves management convenience.
Solution highlights
