Introduction
The UIS-Edge hyper-converged edge cloud industrial Internet solution is a multi-scenario solution designed for UIS in the industrial manufacturing field. In the solution, the cloud edge collaboration, lightweight, and flexible communication mode of UIS-Edge are utilized to realize unified management of devices and flexible deployment of service applications. It reduces O&M costs, improves production capacity, helps optimize quality management objectives, and empowers the transformation and upgrading of traditional industries.
UIS-Edge industrial Internet solution
The industrial Internet solution with UIS-Edge (hyper-converged edge cloud engine) as its core is a good practice for machine vision and industrial equipment management.
Application scenarios
1) Industrial vision application scenario:
The traditional manual inspection is costly and slow. The industrial vision can solve the issue through AI analysis of images. The UIS-Edge industrial Internet edge cloud solution supports the industrial vision application scenario. Based on the UIS-Edge cloud edge collaboration capability, the UIS-Edge industrial vision application is deployed to perform service reasoning, model training in the cloud, and regular and automatic model update to realize the iterative update of smart machine vision.
Take a factory in Hangzhou for example:
The traditional manual cable insertion and appearance inspection has limited recognition accuracy and requires a lot of manual support, which often causes missing inspection.
In the UIS-Edge industrial Internet edge cloud solution, the industrial vision model is trained through the cloud. The accuracy can be improved continuously with the optimization of the deep learning model. In addition, the deployment of model on the edge end of UIS-Edge can achieve efficient work for 24 hours a day without interruption, reducing labor input, and improving product inspection efficiency.
2) Device VOI cloud desktop management scenario
Benefits
Solution highlights
