H3C S12500G-AF Switch Series Installation Guide-6W102
HomeSupportSwitchesH3C S12500G-AF Switch SeriesInstall & UpgradeInstallation GuidesH3C S12500G-AF Switch Series Installation Guide-6W102
10-Appendix B Cabling Recommendations
10-Appendix B Cabling Recommendations 552.89 KB
Appendix B     Cabling recommendations
Routing signal cables
The cable management brackets are installed on the two sides of the service module section. As a best practice, route signal cables as shown in FigureB-1.
FigureB-1 Routing signal cables (S12508G-AF switch)
Routing power cords
When you route power cords, take consideration of the layout of the equipment room, including the locations of the power distribution cabinet, AC power receptacles, and lightning protection box. Place all re-connecting facilities, such as receptacles, at the rack bottom (Do not place them at a location out of the rack and easy to reach.)
The power modules are located at the left and right of the rear panel. As a best practice, route power cords from the left and right of the rear panel.
General cabling requirements
Minimum curvature radius of cables
·     Attached power cord, communication cable, or ribbon cableA minimum of five times the cable's outer diameter. If the cable is frequently bent, plugged and unplugged, the curvature radius should be a minimum of seven times the cable's outer diameter.
·     Ordinary attached coaxial cableA minimum of seven times of the cable's outer diameter. If the coaxial cable is frequently bent, plugged and unplugged, the curvature radius should be a minimum of 10 times the cable's outer diameter.
·     High-speed cable (SFP+ cable for example)A minimum of five times of the cable's outer diameter. If the coaxial cable is frequently bent, plugged and unplugged, the curvature radius should be a minimum of 10 times the cable's outer diameter.
Minimum curvature radius of fibers
·     When the fiber is wrapped up around the cabling plate, the diameter of the cabling plate should be a minimum of 25 times the fiber's diameter.
·     When the fiber is being moved, the curvature radius of the fiber should be a minimum of 20 times the fiber's diameter.
·     When the fiber is attached, the curvature radius of the fiber should be a minimum of 10 times the fiber's diameter.
The fiber's diameter refers to the outer diameter of the fiber jacket. Typically, the diameter of a single-core fiber is 0.9 mm (0.04 in), 2.0 mm (0.08 in), or 3.0 mm (0.12 in).
Label cables before you route or bundle them.
Cable management guidelines
When you route and bundle up cables, follow these guidelines:
·     Bind and route the cables neatly inside the rack, and make sure they are not kinked or bent.
FigureB-2 Correct and incorrect cable binding
·     The cable bend radius at connectors must be a minimum of 5 times the cable diameter, and must be a minimum of twice the cable diameter away from the connectors.
·     Route different types of cables (for example, power cords and signal cables) separately. If they are close to one another, cross them over one another. If you route them in parallel, make sure the space between a power cord bundle and a signal cable bundle is a minimum of 30 mm (1.18 in).
·     The cable management brackets and cable routing slots, inside or outside the rack, are smooth and do not have sharp edges or tips.
·     When you route cables through sharp sheet metal penetration points or along sharp edges of mechanical parts, use bushings or take any other action to protect the cables from being cut or abraded. The sheet metal penetration points must be smooth and fully rounded.
·     Use the correct type of ties to bind the cables. Do not bind cables with joined ties. The following types of ties are available: 100 × 2.5 mm (3.94 × 0.10 in), 150 × 3.6 mm (5.91 × 0.14 in), 300 × 3.6 mm (11.81 × 0.14 in), 530 × 9 mm (20.87 × 0.35 in), and 580 × 13 mm (22.83 × 0.51 in).
·     After binding the cables, cut the excess from the ties, leaving no sharp or angular tips. See FigureB-3.
FigureB-3 Cutting cable ties
电缆捆扎示范2
·     When you bend cables, bind them as shown in FigureB-4. To avoid excessive stress causing cable core break, do not tie up the cables in the bending area.
FigureB-4 Binding cables where they must be bent
电缆捆扎示范3
·     Route, bind, and attach excess cables for easy, safe maintenance activities and correct operations.
·     Do not tie power cords to slide rails.
·     When you connect a cable to an articulated part, for example, when you connect a grounding cable to a cabinet door, leave enough slack in cables and make sure they are not stressed from any movement of the part.
·     Cables must be protected at points where they might rub or come in contact with sharp edges or heated areas. Use high temperature cables near heat sources.
·     Securely fasten cables and take adequate measures to prevent loose connections.
FigureB-5 Securely fastening cables
(1) Flat washer
(2) Spring washer
(3) Nut
·     Fasten heavy or rigid power cords at the connectors to relief stress.
·     Do not use tapping screws to fasten the connecting terminals.
·     Bind together cables that are the same type and routed in the same direction.
TableB-1 lists the cable bundling specifications.
TableB-1 Tie-binding parameters
Cable bundle diameter (mm)
Space between bundles (mm)
10
80 to 150
10 to 30
150 to 200
30
200 to 300
·     Do not tie cables or bundles in a knot.
·     The metal parts of the crimped cold-pressed terminal blocks (such as air switch) cannot protrude beyond the blocks.
  • Become a Partner
  • Partner Resources
