H3C S12500G-AF Switch Series Installation Guide-6W102
HomeSupportSwitchesH3C S12500G-AF Switch SeriesInstall & UpgradeInstallation GuidesH3C S12500G-AF Switch Series Installation Guide-6W102
07-Chapter 7 Troubleshooting
07-Chapter 7 Troubleshooting 960.09 KB
7 Troubleshooting
This chapter describes how to troubleshoot your switch.
TIP
TIP:
·     Noncompliant operating environment might cause switch failure. You need to clean your switch periodically and make sure the installation environment meets the requirements. For more information, see "Preparing for installation."
·     Periodically perform power-on test on spare switches.
Troubleshooting methods
When your switch fails, you can use the following methods to troubleshoot the switch:
·     At the CLI, you can use related commands to display hardware information, and locate hardware failures.
·     Every MPU provides LEDs for the fans, power modules, and modules. You can locate the failures according to the LED status on the MPU. For more information about the LED status on the MPU, see H3C S12500G-AF Switch Series Hardware Information and Specifications.
·     The MPUs and service modules provide port status LEDs, with which you can detect port failures. For more information about port status LEDs, see H3C S12500G-AF Switch Series Hardware Information and Specifications.
If you cannot locate failures by following the guidelines in this chapter, contact the local agents or technical support engineers. For more information, see "Technical support."
Configuration terminal display issues at startup
No display on the configuration terminal
Symptom
The configuration terminal does not have display when the switch is powered on.
Solution
To resolve the issue:
1.     Verify that the power system is operating correctly.
2.     Verify that the MPU is operating correctly.
3.     Verify that the console cable connects the console port on the MPU correctly.
4.     Verify that the console cable connects to the correct serial port on the terminal.
5.     Verify that the console cable is in good quality and is operating correctly.
6.     Verify that the following settings are configured for the terminal:
¡     Baud rate—9600.
¡     Data bits—8.
¡     Parity—None.
¡     Stop bits—1.
¡     Flow control—None.
¡     Emulation—VT100.
7.     If the issue persists, contract H3C support.
Garbled display on the configuration terminal
Symptom
The configuration terminal displays garbled text when the switch is powered on.
Solution
1.     Verify that the following settings are configured for the terminal:
¡     Baud rate—9600.
¡     Data bits—8.
¡     Parity—None.
¡     Stop bits—1.
¡     Emulation—VT100.
2.     If the issue persists, contact H3C Support.
System failures during operation
Symptom
A system failure occurs when the switch is operating.
Solution
1.     Execute related commands to locate the fault.
2.     If a configuration error is found, re-configure the switch or restore the factory-default settings.
For more information, see H3C S12500G-AF Switch Series Fundamentals Configuration Guide.
3.     If the issue persists, contact H3C Support.
Power module failure
Symptom
The LEDs for the power module are in the following states:
·     On the MPU, the power module LED is steady red.
The power module LED is steady green only when all the power modules are operating correctly. When a power module is faulty, the power module LED is steady red.
·     On the power module, the input LED is off, or the output LED is red.
For more information about the LEDs, see H3C S12500G-AF Switch Series Hardware Information and Specifications.
After a power module is disconnected from its power source, the input and output LEDs on the power module stay on for several seconds.
Solution
1.     Verify that the power module model is compatible with the switch.
The PSR2400-54A, PSR3000-54A, PSR2400-54D, and PSR3000-54AHD power modules are compatible with the switch.
2.     Remove and reconnect the power cord to verify that the power cord is connected securely.
3.     Replace the power cord.
4.     Remove and reinstall the power module to verify that it is installed securely.
For more information, see "Installing power modules."
5.     Verify that the power source is supplying power correctly and the output voltage is at the acceptable voltage range.
6.     Verify that the installed power modules can meet the system power requirements.
7.     Verify that the power module does not have issues such as output short circuit, output overcurrent, output overvoltage, input undervoltage, or overtemperature.
8.     Install the power module in another empty power module slot. If the power module operates correctly, the previous power module slot is faulty. If the power module does not operate correctly, go to the next step.
9.     Install a correctly operating power module of the same model in the same slot, and connect it to the same power source. If the new power module can operate correctly, the old power module has failed. Contact your sales agent or local service engineer to replace the old power module.
10.     If the issue persists, contact H3C Support.
Fan tray failure
Symptom
The LEDs for the fan tray are in the following states:
·     On the MPU, the fan tray LED is steady red.
·     On the fan tray, the OK LED is off and the FAIL LED is on.
Solution
1.     If all the LEDs are off, verify that the power modules are operating correctly. For more information, see "Power module failure."
2.     Execute the display fan command in any view to display the operating state of the fan tray and rectify the fault:
¡     Whether the fan tray is present.
¡     Airflow direction of the fan.
¡     Number of fans in the fan tray.
¡     Operating status of each fan.
¡     Fan speed.
3.     Verify that the air inlet and exhaust vents of the chassis are not blocked. If they are blocked, clean them to keep good ventilation.
4.     Remove and reinstall the fan tray to make sure it is installed securely in the slot.
5.     Verify that the empty module slots and power module slots are installed with filler panels. Install filler panels in empty slots.
6.     Replace the fan tray.
7.     If the issue persists, contact H3C Support.
MPU failure
Symptom
The LED for the MPU is steady red or flashing red.
Solution
1.     Verify that the power system is operating correctly. For more information, see "Power module failure."
2.     Remove and reinstall the MPU to make sure it is installed securely. For more information, see "Installing MPUs and service modules."
3.     Press the RESET button on the MPU to reset the MPU. After the MPU is reset, verify that the LED for the MPU is flashing green.
4.     If the switch has empty MPU slots, install the MPU in the empty MPU slot, and verify that the MPU can operate correctly.
5.     If the issue persists, contact H3C Support.
·     On the S12516G-AF and S12508G-AF, the MPU and service module slot numbers are marked on the ejector lever pillow blocks at the left and right sides of the slots. The fabric module slot number is marked above the slot.
·     On the S12504G-AF, the MPU slot number is marked at the left side of the slot. The service module slot number is marked on the ejector lever pillow blocks at the left and right sides of the slot. You can see the fabric module slot numbers through the openings in the fan trays, as shown by callout 3 in the Figure7-2.
Service module failure
Symptom
The LED for the service module is steady red or flashing red.
Solution
1.     Verify that the MPU is operating correctly. For more information, see "MPU failure."
2.     Verify that the system software is compatible with the service module. Upgrade the system software if it is not compatible with the service module.
3.     Calculate the total power consumption, and make sure your power modules can provide enough power. For more information, see H3C S12500G-AF Switch Series Hardware Information and Specifications.
4.     Remove and reinstall the service module to make sure it is installed securely. For more information about installing a service module, see "Installing MPUs and service modules."
5.     If the switch has empty service module slots, install the module in an empty service module slot. If the service module operates correctly, the previous slot is faulty.
6.     If the issue persists, contact H3C Support.
Fabric module failure
Symptom
The LEDs for a fabric module are in the following states:
·     On the MPU, the slot status LED for the fabric module is steady red or flashing red.
·     On the fan tray, the RUN LED for the fabric module is off.
¡     On the S12516G-AF and S12508G-AF fan trays, the RUN and ALM LED pairs correspond to the fabric module slots from left to right. See Figure7-1.
¡     On the S12504G-AF fan tray, the extended lines of the RUN and ALM LED pairs correspond to the fabric module slots from left to right.
Figure7-1 Corresponding relations between the LEDs on the S12508G-AF fan trays and fabric module slots
(1) LEDs for the fabric module slots 10, 11, and 12
(2) LEDs for the fabric module slot 13, 14, and 15
Figure7-2 Corresponding relations between the LEDs on the S12504G-AF fan trays and fabric module slots
(1) LEDs for the fabric module slot 6
(2) LEDs for the fabric module slot 8
(3) Fabric module slot number
(4) LEDs for the fabric module slot 9
(5) LEDs for the fabric module slot 11
·     On the fabric module, the RUN/ALM LED is red.
Solution
1.     Verify that the MPU and the fan tray are operating correctly. For more information, see "MPU failure" and "Fan tray failure."
2.     Verify that the fabric module is compatible with the system software. Upgrade the system software if it does not support the fabric module.
4.     Remove and reinstall the fabric module to make sure the module is installed securely. You also need to verify that the ejector levers are locked securely in place. For more information, see "Installing fabric modules."
5.     If the switch has empty fabric module slots, install the module in an empty fabric module slot. If the module operates correctly, the previous slot is faulty.
6.     If the issue persists, contract H3C Support.
Interface failure
Symptom
The LED for the interface is off.
A management Ethernet port has two LEDs, LINK and ACT. When the LINK LED is off, the management Ethernet port fails.
Solution
1.     Make sure the MPU or service module where the interface resides operates correctly. For more information, see "MPU failure" or "Service module failure."
2.     Verify that the cable is connected correctly. For how to correctly connect a cable, see "Connecting the switch to the network."
3.     Verify that the cable is in good condition. Use the cable to connect two interfaces of the same type that operate correctly. If the LEDs of the two interfaces are on, the cable is in good condition. Otherwise, the cable is faulty. Use a compliant cable to connect the interface. For more information, see H3C S12500G-AF Switch Series Hardware Information and Specifications.
4.     If the interface uses a transceiver module, perform the following tasks:
a.     Make sure the interface type is compatible with the transceiver and that the transceiver is compatible with the cable. For more information, see H3C S12500G-AF Switch Series Hardware Information and Specifications.
b.     Replace the transceiver module.
5.     Verify that the speed and duplex settings of the interfaces on the two ends are the same.
·     If an interface is brought down by the shutdown command, use the undo shutdown command to bring up the interface.
·     After an interface fails, if the switch has an idle interface of the same type, you can connect the cable to the idle interface.
Technical support
Before contacting H3C Support, prepare the following information:
·     Arrival time of the switch.
·     Serial number of the chassis (on the label at the right of the rear panel).
·     Software version, which you can view by using the display version command.
·     Maintenance agreement or warranty card.
·     Brief issue description.
·     Brief explanation of the troubleshooting measures that have been taken.
  • Become a Partner
  • Partner Resources
