14-WLAN Command Reference (AC)
HomeSupportResource CenterReference GuidesCommand ReferencesH3C MSR810[830][2600][3600] Routers Command Reference(V7)-R0821-6W50114-WLAN Command Reference (AC)
17-WLAN probe commands
17-WLAN probe commands 121.57 KB
WLAN probe commands
For information about MSR routers that can function as ACs, see "Compatibility of hardware and AC functionality."
client-proximity-sensor
Use client-proximity-sensor enable to enable WLAN probe.
Use client-proximity-sensor disable to disable WLAN probe.
Use undo client-proximity-sensor to restore the default.
client-proximity-sensor { disable | enable }
In radio view, a radio uses the configuration in an AP group's radio view.
In an AP group's radio view, WLAN probe is disabled.
Radio view
# Enable WLAN probe for radio 1 of AP ap1.
[Sysname] wlan ap ap1 model WA4320i-ACN
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] client-proximity-sensor enable
# Enable WLAN probe for radio 1 of APs with model WA4320i-ACN in AP group aaa.
[Sysname] wlan ap-group aaa
[Sysname-wlan-ap-group-aaa] ap-model WA4320i-ACN
[Sysname -wlan-ap-group-aaa-ap-model-WA4320i-ACN] radio 1
[Sysname -wlan-ap-group-aaa-ap-model-WA4320i-ACN-radio-1] client-proximity-sensor enable
client-proximity-sensor ap-timer
Use client-proximity-sensor ap-timer to set the AP entry timers.
Use undo client-proximity-sensor ap-timer to restore the default.
client-proximity-sensor ap-timer inactive inactive-value aging aging-value
The inactivity timer and aging timer for AP entries are 300 seconds and 600 seconds, respectively.
inactive inactive-value: Specifies the inactivity timer for AP entries, in the range of 60 to 1200 seconds.
aging aging-value: Specifies the aging timer for AP entries, in the range of 120 to 86400 seconds.
# Set the inactivity timer and aging timer for AP entries to 120 seconds and 360 seconds, respectively.
[Sysname] client-proximity-sensor ap-timer inactive 120 aging 360
client-proximity-sensor ap-udp-server
Use client-proximity-sensor ap-udp-server to specify a UDP server to receive wireless device information.
Use undo client-proximity-sensor ap-udp-server to restore the default.
client-proximity-sensor ap-udp-server ip-address port port-number [ interval interval | preshared-key [ cipher | simple ] key-string ] *
No UDP server is specified.
AP view
ip-address: Specifies the IPv4 address of the UDP server.
port port-number: Specifies the port number of the UDP server, in the range of 1 to 65534.
interval interval: Specifies the interval at which the sensor sends device information to the UDP server, in the range of 1 to 600 seconds. The default interval is 30 seconds.
preshared-key: Specifies a preshared key.
simple: Specifies a key in plaintext form.
key-string: Specifies the key. Its plaintext form is a case-sensitive string of 8 to 63 characters. Its encrypted form is a case-sensitive string of 41 to 117 characters.
# Specify the UDP server with IP address 10.152.3.209 and port number 443 to receive wireless device information.
[Sysname-ap-ap1] client-proximity-sensor ap-udp-server 10.152.3.209 port 443
client-proximity-sensor client-timer
Use client-proximity-sensor client-timer to set the client entry timers.
Use undo client-proximity-sensor client-timer to restore the default.
client-proximity-sensor client-timer inactive inactive-value aging aging-value
The inactivity timer and aging timer for client entries are 300 seconds and 600 seconds, respectively.
inactive inactive-value: Specifies the inactivity timer for client entries, in the range of 60 to 1200 seconds.
aging aging-value: Specifies the aging timer for client entries, in the range of 120 to 86400 seconds.
# Set the inactivity timer and aging timer for client entries to 120 seconds and 360 seconds, respectively.
[Sysname] client-proximity-sensor client-timer inactive 120 aging 360
client-proximity-sensor coordinates
Use client-proximity-sensor coordinates to set the longitude and latitude of a sensor.
Use undo client-proximity-sensor coordinates to remove the configuration.
client-proximity-sensor coordinates longitude longitude-value latitude latitude-value
The longitude and latitude are not set for a sensor.
AP view
longitude longitude-value: Specifies the longitude of the sensor, in XXX-XX-XX.X format. The value ranges for XXX and XX are 0 to 180 and 0 to 60, respectively. The value of X can be e or w and is case insensitive.
latitude latitude-value: Specifies the latitude of the sensor, in XXX-XX-XX.X format. The value ranges for XXX and XX are 0 to 90 and 0 to 60, respectively. The value of X can be s or n and is case insensitive.
After you configure this command for a sensor, the longitude and latitude information for the sensor is reported together with the information about wireless devices detected by the sensor.
# Set the longitude and latitude for sensor ap1 to 123-40-40.e and 80-30-30.n, respectively.
[Sysname-ap-ap1] client-proximity-sensor coordinates longitude 123-40-40.e latitude 80-30-30.n
client-proximity-sensor filter-list
Use client-proximity-sensor filter-list to configure the MAC address filtering list. The AC does not report information about devices with MAC addresses in the list.
Use undo client-proximity-sensor filter-list to remove the configuration.
client-proximity-sensor filter-list list
undo client-proximity-sensor filter-list { list | all }
No MAC address filtering list is configured.
list: Specifies a MAC address or a class of MAC addresses in H-H-H format. For example, if you specify 0400-0000-0000, you specify MAC addresses whose third bit in the first byte is 1.
all: Specifies all MAC addresses.
# Add MAC addresses whose third bit in the first byte is 1 to the MAC address filtering list.
[Sysname] client-proximity-sensor filter-list 0400-0000-0000
client-proximity-sensor random-mac-report enable
Use client-proximity-sensor random-mac-report enable to enable reporting of information about Apple terminals that use a random MAC address.
Use undo client-proximity-sensor random-mac-report enable to disable reporting of information about Apple terminals that use a random MAC address
Information about Apple terminals that use a random MAC address is not reported.
Apple terminals send probe requests by using a random MAC address whose second bit in the first byte is 1 and cause sensors to detect non-existent wireless devices. Enable or disable this command as appropriate.
# Enable reporting of information about Apple terminals that use a random MAC address.
[Sysname] client-proximity-sensor random-mac-report enable
client-proximity-sensor report-ac enable
Use client-proximity-sensor report-ac enable to enable sensors to report information about detected devices to the AC.
Use undo client-proximity-sensor report-ac enable to disable sensors from reporting information about detected devices to the AC.
Sensors do not report information about detected devices to the AC.
# Enable sensors to report information about detected devices to the AC.
[Sysname] client-proximity-sensor report-ac enable
client-proximity-sensor report-ac-interval
Use client-proximity-sensor report-ac-interval to set the interval at which sensors report information about detected devices to the AC.
Use undo client-proximity-sensor report-ac-interval to restore the default.
client-proximity-sensor report-ac-interval interval
Sensors report information about detected devices to the AC every 3000 milliseconds.
interval: Specifies the interval at which sensors report information about detected devices to the AC, in the range of 100 to 60000 milliseconds.
# Configure sensors to report information about detected devices to the AC every 2000 milliseconds.
[Sysname] client-proximity-sensor report-ac-interval 2000
client-proximity-sensor report-ap enable
Use client-proximity-sensor report-ap enable to enable reporting of AP information to the UDP server.
Use undo client-proximity-sensor report-ap enable to disable reporting of AP information to the UDP server.
AP information is not reported to the UDP server.
# Enable reporting of AP information to the UDP server.
[Sysname] client-proximity-sensor report-ap enable
client-proximity-sensor report-oasis cache
Use client-proximity-sensor report-oasis cache enable to enable the device to cache client information upon disconnection from the Oasis platform.
Use undo client-proximity-sensor report-oasis cache enable to disable the device from caching client information upon disconnection from the Oasis platform.
The device does not cache client information upon disconnection from the Oasis platform.
After you configure this command, the device caches client information received from sensors when the connection between the device and the Oasis platform goes down. After the device reconnects to the Oasis platform, the device sends the cached information to the Oasis platform.
# Enable the device to cache client information upon disconnection from the Oasis platform.
[Sysname] client-proximity-sensor report-oasis cache enable
client-proximity-sensor report-oasis client
Use client-proximity-sensor report-oasis client to set the report interval and the number of client entries that the AC sends to the Oasis platform in each report.
Use undo client-proximity-sensor report-oasis to restore the default.
client-proximity-sensor report-oasis client interval interval number number
undo client-proximity-sensor report-oasis client
The AC reports 10 client entries to the Oasis platform every 1000 milliseconds.
interval interval: Specifies the interval at which the AC reports client information to the Oasis platform, in the range of 100 to 60000 milliseconds.
number number: Specifies the number of client entries that the AC sends to the Oasis platform in each report, in the range of 1 to 100.
# Configure the AC to report 50 client entries to the Oasis platform every 500 milliseconds.
[Sysname] client-proximity-sensor report-oasis client interval 500 number 50
client-proximity-sensor report-oasis disable
Use client-proximity-sensor report-oasis disable to disable the AC from reporting wireless device information to the Oasis platform.
Use undo client-proximity-sensor report-oasis disable to restore the default.
The AC reports wireless device information to the Oasis platform.
# Disable the AC from reporting wireless device information to the Oasis platform.
[Sysname] client-proximity-sensor report-oasis disable
client-proximity-sensor report-oasis rssi-change-threshold
Use client-proximity-sensor report-oasis rssi-change-threshold to set the RSSI difference threshold for reporting client information to the Oasis platform.
Use undo client-proximity-sensor report-oasis rssi-change-threshold to restore the default.
client-proximity-sensor report-oasis rssi-change-threshold threshold-value
The RSSI difference threshold is 100.
rssi-change-threshold threshold-value: Specifies the RSSI difference threshold for reporting client information to the Oasis platform, in the range of 1 to 100.
The AC does not report the client information received from a sensor to the Oasis platform when the following conditions are met:
·     The client has already been detected before.
·     The RSSI difference of the client between the most recent two reports does not reach the specified threshold.
# Set the RSSI difference threshold to 50 for reporting client information to the Oasis platform.
[Sysname] client-proximity-sensor report-oasis rssi-change-threshold 50
client-proximity-sensor rssi-change-threshold
Use client-proximity-sensor rssi-change-threshold to set the RSSI difference threshold for wireless device detection.
Use undo client-proximity-sensor rssi-change-threshold to restore the default.
client-proximity-sensor rssi-change-threshold threshold-value
The RSSI difference threshold for wireless device detection is 100.
threshold-value: Specifies the RSSI difference threshold for wireless device detection, in the range of 1 to 100.
A sensor does not update the information about a wireless device when the following conditions are met:
·     The wireless device has been detected before.
·     The RSSI difference of the wireless device between the most recent two detections does not reach the specified threshold.
# Set the RSSI difference threshold for wireless device detection to 50.
[Sysname] client-proximity-sensor rssi-change-threshold 50
client-proximity-sensor rssi-threshold
Use client-proximity-sensor rssi-threshold to set the RSSI threshold for clients or APs.
Use undo client-proximity-sensor rssi-threshold to restore the default.
client-proximity-sensor rssi-threshold { ap ap-rssi-value | client client-rssi-value }
undo client-proximity-sensor rssi-threshold { ap | client }
The RSSI thresholds for clients and APs are not set.
ap ap-rssi-value: Specifies the RSSI threshold for APs, in the range of 1 to 100.
client client-rssi-value: Specifies the RSSI threshold for clients, in the range of 1 to 100.
Sensors do not ignore any wireless devices by default. After you configure this command, sensors will ignore wireless devices with an RSSI lower than the specified RSSI threshold.
# Configure sensors to ignore APs with an RSSI lower than 30.
[Sysname] client-proximity-sensor rssi-threshold ap 30
client-proximity-sensor rt-report enable
Use client-proximity-sensor rt-report enable to enable real-time reporting of wireless device information to the UDP server.
Use undo client-proximity-sensor rt-report enable to disable real-time reporting of wireless device information to the UDP server.
Information about wireless devices is reported to the UDP server at the specified interval.
By default, a sensor or AC reports to the UDP server at the specified intervals. After you enable this feature, the device information is reported to the UDP server in real time through the sensor or AC.
# Enable real-time reporting of wireless device information to the UDP server.
[Sysname] client-proximity-sensor rt-report enable
client-proximity-sensor server
Use client-proximity-sensor server to specify an HTTPS server to receive wireless device information.
Use undo client-proximity-sensor server to restore the default.
client-proximity-sensor server string [ window-time window-time-value | partner partner-value ] *
No HTTPS server is specified.
string: Specifies an HTTPS server by its address, a case-sensitive string of 8 to 127 characters. The address must start with https://.
window-time window-time-value: Specifies the window time in the range of 10 to 60 seconds. The default window time is 30 seconds.
partner partner-value: Specifies the partner flag value. The default partner flag value is 11.
# Specify the HTTPS server with address https://10.152.3.209/xxx/yy to receive wireless device information.
[Sysname] client-proximity-sensor server https://10.152.3.209:443/xxx/yy
client-proximity-sensor timezone-offset
Use client-proximity-sensor timezone-offset to set the timezone offset between the AC and a sensor.
Use undo client-proximity-sensor timezone-offset to restore the default.
client-proximity-sensor timezone-offset { add | minus } timevalue
The timezone offset between the AC and a sensor is not set.
AP view
add: Configures a positive timezone offset between the sensor and the AC.
minus: Configures a negative timezone offset between the sensor and the AC.
timevalue: Specifies the timezone offset between the sensor and the AC in hh: mm: ss format.
# Configure a positive timezone offset of 11 hours between sensor ap1 and the AC, which means that the time of sensor ap1 is the AC' s time plus 11 hours.
[Sysname-ap-ap1] client-proximity-sensor timezone-offset add 11:00:00
client-proximity-sensor udp-server
Use client-proximity-sensor udp-server to specify a UDP server to receive wireless device information.
Use undo client-proximity-sensor udp-server to restore the default.
client-proximity-sensor udp-server ip-address port port-number [ interval interval | preshared-key [ cipher | simple ] key-string ] *
interval interval: Specifies the interval at which the AC sends device information to the UDP server, in the range of 1 to 600 seconds. The default interval is 30 seconds.
[Sysname] client-proximity-sensor udp-server 10.152.3.209 port 443
display client-proximity-sensor device
Use display client-proximity-sensor device to display information about wireless devices detected by sensors.
display client-proximity-sensor device [ ap | client | mac-address mac-address ] [ verbose ]
ap: Displays information about detected APs.
client: Displays information about detected clients.
mac-address mac-address: Displays information about the wireless device with the specified MAC address. The mac-address argument is in H-H-H format.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display brief information about wireless devices detected by sensors.
<Sysname> display client-proximity-sensor device
Total 3 detected devices
MAC address    Type      Duration    Sensors Channel Status
0AFB-423B-893C AP        00h 10m 46s 1       11      Active
0AFB-423B-893D AP        00h 10m 46s 1       6       Active
0AFB-423B-893E AP        00h 10m 46s 1       1       Active
MAC address
MAC address of the wireless device.
Wireless device type:
·     AP.
·     Client.
Duration
Time elapsed since the wireless device entered the current status.
Sensors
Number of sensors that detected the wireless device.
Channel
Channel on which the wireless device was most recently detected.
Status
Wireless device status:
·     Active.
·     Inactive.
# Display detailed information about wireless devices detected by sensors.
<Sysname> display client-proximity-sensor device verbose
Total 2 detected devices
 AP: 0AFB-423B-893C
   Status: Active
   Status duration: 00h 27m 57s
   Vendor: Not found
   SSID: service
   Radio type: 802.11ac
   Security: None
   Encryption method: None
   Authentication method: None
   Broadcast SSID: Yes
   QoS supported: No
   Beacon interval: 100 TU
   Up duration: 00h 27m 57s
Channel bandwidth supported: 20/40/80MHz
   Total number of reported APs: 1
     AP 1:
       AP ID: 3
       AP name: 1
       Radio ID: 1
       RSSI: 15
       Channel: 419
       First reported time: 2016-04-03/09:05:51
       Last reported time: 2016-04-03/09:05:51
   Total number of associated clients: 1
     01: 80EA-9656-AAAB
Client: 80EA-9656-AAAB
  Last detected associated AP: 0AFB-423B-893C
  Last associated AP (not detected): None
  Status: Active
  Status duration: 00h 00m 02s
  Vendor: Not found
  Radio type: 802.11a
     AP 1:
       AP ID: 2
       AP name: 1
       Radio ID: 1
       RSSI: 50
       Channel: 116
       First reported time: 2016-04-03/14:52:56
       Last reported time: 2016-04-03/14:52:56
       Reported associated AP: 0AFB-423B-893C
Total number detected devices
Number of detected wireless devices.
AP
MAC address of the detected AP.
Client
MAC address of the detected client.
MAC address of the AP with which the client most recently associated. The MAC address is the BSSID of the AP.
MAC address of the AP with which the client most recently communicated. This AP has not been detected, and the MAC address of the AP is obtained from packets exchanged between the client and the AP.
Status
·     Active.
·     Inactive.
Status duration
Vendor
OUI of the wireless device. This field displays Not found if no OUIs are imported or the OUI of the device does not match any of the imported OUIs.
Security
Security method:
·     WEP.
·     WPA.
·     WPA2.
·     None.
Encryption method
Encryption method:
·     TKIP.
·     CCMP.
·     WEP.
·     None.
·     PSK.
·     802.1X.
·     Others—Authentication methods except for PSK authentication and 802.1X authentication.
·     None.
Broadcast SSID
Whether the AP broadcasts SSIDs. If the AP does not broadcast SSIDs, the SSID field in the output is null.
Beacon interval
Beacon interval in TU. One TU is equal to 1024 microseconds.
Up duration
Time elapsed since the AP started.
Number of sensors that detected the client.
AP n
Sensor that detected the wireless device. n represents the number of the sensor and is automatically assigned by the system.
AP ID
AP ID of the sensor.
AP name
Name of the sensor that detected the wireless device.
Radio ID
ID of the radio that detected the wireless device.
RSSI
RSSI of the sensor.
Channel
Channel on which the sensor most recently detected the wireless device.
First reported time
Time when the sensor detected the wireless device for the first time.
Last reported time
Time when the sensor most recently detected the wireless device.
Number of clients that are associated with the AP.
n:H-H-H
MAC address of the wireless client associated with the AP. n is the number of the wireless client and is automatically assigned by the system.
AP with which the wireless client is associated.
display client-proximity-sensor sensor
Use display client-proximity-sensor sensor to display information about sensors.
# Display information about sensors.
<Sysname> display client-proximity-sensor sensor
Total number of sensors: 1
Sensor ID    Sensor name                Radio ID
3            ap1                        1
display client-proximity-sensor statistics receive
Use display client-proximity-sensor statistics receive to display statistics received from sensors.
# Display statistics received from sensors
<Sysname> display client-proximity-sensor statistics receive
Information from sensor 1
 Statistics information for received messages:
   Detected AP updated messages: 7
   Detected client updated messages: 5
   Detected AP deleted messages: 3
   Detected client deleted messages: 0
   Detected all device deleted messages: 0
Information from sensor 2
   Detected AP updated messages: 6
   Detected client deleted messages: 2
Information from sensor n
Information collected from sensor n, where n represents the ID of the sensor.
Number of AP update messages.
Number of client update messages.
Number of AP delete messages.
Number of client delete messages.
Number of device delete messages
reset client-proximity-sensor statistics receive
reset client-proximity-sensor device
Use reset client-proximity-sensor device to clear wireless device information.
reset client-proximity-sensor device { ap | client | mac-address mac-address | all }
ap: Specifies detected APs.
client: Specifies detected clients.
mac-address mac-address: Specifies a wireless device by its MAC address, in H-H-H format.
all: Specifies all detected devices.
# Clear information about detected clients.
<Sysname> reset client-proximity-sensor device client
# Clear information about the wireless device with MAC address 0023-1212-2323.
<Sysname> reset client-proximity-sensor device mac-address 0023-1212-2323
display client-proximity-sensor entry
Use reset client-proximity-sensor statistics receive to clear statistics received from sensors.
# Clear statistics received from sensors.
<Sysname> reset client-proximity-sensor statistics receive
  • Become a Partner
  • Partner Resources
