14-WLAN Command Reference (AC)
HomeSupportResource CenterReference GuidesCommand ReferencesH3C MSR810[830][2600][3600] Routers Command Reference(V7)-R0821-6W50114-WLAN Command Reference (AC)
02-AP management commands
02-AP management commands 578.48 KB
AP management commands· 1
ac· 1
ac discovery policy ipv6· 2
ap· 3
ap-model 3
ap-name· 4
bridge-aggregation· 5
control-address· 6
control-address enable· 7
data-tunnel encryption· 8
delete file· 9
description (AP group view) 9
description (AP view) 10
description (AP's VLAN view) 11
discovery-response· 12
display wlan ap· 12
display wlan ap address· 24
display wlan ap all feature band-navigation· 25
display wlan ap all feature capwap· 26
display wlan ap connection-record· 27
display wlan ap description· 27
display wlan ap files· 28
display wlan ap gps· 29
display wlan ap group· 30
display wlan ap online-time· 32
display wlan ap reboot-log· 32
display wlan ap running-configuration· 34
display wlan ap statistics association-failure-record· 36
display wlan ap statistics image-download· 37
display wlan ap statistics online-record· 39
display wlan ap statistics tunnel-down-record· 40
display wlan ap tunnel latency· 41
display wlan ap unauthenticated· 42
display wlan ap-distribution· 52
display wlan ap-distribution ap-name· 53
display wlan ap-group· 54
display wlan ap-model 55
display wlan device role· 57
display wlan license· 57
dns domain· 58
dns server 59
download file· 60
echo-count 60
echo-interval 61
firmware-upgrade· 62
fragment-size· 63
gateway· 64
gigabitethernet 65
hybrid-remote-ap· 66
if-match ip· 66
if-match ipv6· 67
ip address· 68
ipv6 address· 69
keepalive-interval 69
led-mode· 70
mac-address (AP group view) 71
mac-address (AP view) 72
name· 72
port-isolate enable· 73
port access vlan· 75
port hybrid pvid· 76
port hybrid vlan· 78
port link-aggregation group· 80
port link-type· 82
port trunk permit vlan· 83
port trunk pvid· 85
power-level default 87
priority· 88
provision· 89
provision auto-recovery· 90
provision auto-update· 91
qos priority· 92
qos trust 93
remote-configuration· 95
remote-configuration synchronize· 96
report-interval 97
reset wlan ap· 98
reset wlan ap connection-record· 98
reset wlan ap provision· 99
reset wlan ap reboot-log· 99
reset wlan ap unauthenticated· 100
reset wlan tunnel latency ap· 100
retransmit-count 101
retransmit-interval 102
save wlan ap provision· 103
serial-id (AP group view) 103
serial-id (AP view) 104
smartrate-ethernet 105
snmp-agent trap enable wlan ap· 105
snmp-agent trap enable wlan capwap· 106
statistics-interval 107
statistics-interval fast-report 108
tunnel encryption· 108
tunnel latency-detect 109
usb· 110
vlan· 111
wlan ap· 112
wlan ap-authentication· 113
wlan ap-authentication acl 114
wlan ap-authentication domain· 115
wlan ap-authentication enable· 115
wlan ap-authentication import 116
wlan ap-authentication method· 116
wlan ap-authentication permit-unauthenticated· 117
wlan ap-certificate verification· 118
wlan ap-image-deploy· 118
wlan apdb· 119
wlan apdb file· 120
wlan ap-group· 121
wlan auto-ap enable· 121
wlan auto-ap persistent 122
wlan auto-persistent enable· 122
wlan capwap discovery-policy unicast 123
wlan capwap encryption· 123
wlan description· 124
wlan detect-anomaly enable· 125
wlan enable· 125
wlan global-configuration· 126
wlan image-load filepath· 126
wlan re-group· 127
wlan rename-ap· 128
wlan tcp mss· 128
wlan timezone-sync enable· 129
wlan vip-ap-group· 130
For information about MSR routers that can function as ACs, see "Compatibility of hardware and AC functionality."
ac
Use ac to specify an AC for an AP.
Use undo ac to delete the specified AC information.
ac { host-name hostname | ip ipv4-address }
undo ac { host-name | ip [ ipv4-address ] }
In AP provision view, an AP uses the configuration in AP group provision view. If no configuration exists in AP group provision view, the AP uses the configuration in global provision view.
In AP group provision view, an AP uses the configuration in global provision view.
In global provision view, no AC is specified for an AP.
AP provision view
Global provision view
host-name host-name: Specifies an AC by its host name, a case-insensitive string of 1 to 253 characters. The string can contain letters, digits, hyphens (-), underscores (_), and dots (.).
ip ipv4-address: Specifies an AC by its IPv4 address.
You can configure a maximum of three AC IPv4 addresses and only one host name. If you configure multiple host names, the most recent configuration takes effect.
The configuration in AP provision view takes effect only on the AP. The configuration in AP group provision view takes effect on all APs in the AP group. The configuration in global provision view takes effect on all APs.
The priorities of configurations in AP provision view, AP group provision view, and global provision view are in descending order.
The undo form of the command deletes all AC IPv4 addresses if you do not specify the ipv4-address argument.
# Specify the AC whose IP address is 192.168.100.11 in AP provision view of AP ap1.
[Sysname] wlan ap ap1 model WA4320i-ACN
[Sysname-wlan-ap-ap1] provision
[Sysname-wlan-ap-ap1-prvs] ac ip 192.168.100.11
# Specify the AC whose IP address is 192.168.100.11 in AP group provision view of AP group group1.
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] provision
[Sysname-wlan-ap-group-group1-prvs] ac ip 192.168.100.11
# Specify the AC whose IP address is 192.168.100.11 for APs in global provision view.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] provision
[Sysname-wlan-global-configuration-prvs] ac ip 192.168.100.11
Use ac discovery policy ipv6 to enable an AP to prefer discovering ACs by IPv6 address.
Use undo ac discovery policy ipv6 to restore the default.
In AP group provision view, an AP prefers to discover ACs by IPv4 address.
AP provision view
This feature enables an AP to discover ACs by using the static IP addresses, IPv6 multicast, DHCPv6 option, IPv6 DNS, DHCPv4 options, broadcast/IPv4 multicast, and IPv4 DNS successively. If the AP connects to an AC successfully with a discovered IP address, it stops AC discovery.
# Enable AP ap1 to prefer discovering ACs by IPv6 address.
[Sysname-wlan-ap-ap1-prvs] ac discovery policy ipv6
# Enable APs in AP group group1 to prefer discovering ACs by IPv6 address.
[Sysname-wlan-ap-group-group1-prvs] ac discovery policy ipv6
ap
Use ap to create an AP grouping rule by AP names.
Use undo ap to delete an AP grouping rule by AP names.
ap ap-name-list
undo ap ap-name-list
No AP grouping rules by AP names exist.
AP group view
ap-name-list: Specifies a maximum of 10 space-separated AP names. An AP name is a case-sensitive string of 1 to 64 characters that can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
This command does not identify whether the specified AP exists.
The priorities of AP grouping rules by AP names, serial IDs, MAC addresses, and IP addresses are in descending order. If an AP does not match any grouping rules, it is added to the default AP group.
If the created AP grouping rule already exists in another AP group, this command deletes the rule from that AP group.
You cannot execute this command in the view of the default AP group.
# Create an AP grouping rule by AP names to add APs ap1, ap2, and ap3 to AP group group1.
[Sysname-wlan-ap-group-group1] ap ap1 ap2 ap3
wlan ap-group
ap-model
Use ap-model to create an AP model and enter its view, or enter the view of an existing AP model.
Use undo ap-model to remove an AP model and its configuration.
ap-model ap-model
undo ap-model ap-model
No AP models exist.
AP group view
ap-model: Specifies an AP model name.
# Create an AP model named WA4320i-ACN and enter its view.
[Sysname-wlan-ap-group-group1] ap-model WA4320i-ACN
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN]
ap-name
Use ap-name to add an AP to an AP monitor group.
Use undo ap-name to remove an AP from an AP monitor group.
ap-name ap-name
undo ap-name ap-name
No APs exist in an AP monitor group.
Monitor group view
ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
APs in an AP monitor group can report client quantity, radio traffic, channel usage, and AP anomalies to the AC.
The functions and services provided by an AP are not affected after the AP is added to an AP monitor group.
You can add a maximum of 32 APs to an AP monitor group.
# Add AP ap1 to an AP monitor group.
[Sysname] wlan vip-ap-group
[Sysname-wlan-vip-ap-group] ap-name ap1
report-interval
wlan vip-ap-group
bridge-aggregation
Support for this command depends on the AP model.
Use bridge-aggregation to create a Layer 2 aggregate interface and enter its view, or enter the view of an existing Layer 2 aggregate interface.
Use undo bridge-aggregation to delete a Layer 2 aggregate interface.
bridge-aggregation interface-number
undo bridge-aggregation interface-number
In AP view, an AP uses the configuration in AP group view.
In AP group view, no Layer 2 aggregate interfaces exist.
AP view
AP group view
interface-number: Specifies a Layer 2 aggregate interface number. The value range for this argument varies by AP model.
When you create a Layer 2 aggregate interface, the system automatically creates a Layer 2 aggregation group with the same number. The aggregation group operates in static aggregation mode by default.
Deleting a Layer 2 aggregate interface also deletes the Layer 2 aggregation group. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
The configuration will be synchronized to all online APs if remote configuration synchronization is activated.
The configuration in AP view takes precedence over the configuration in AP group view.
# Create Layer 2 aggregate interface 1 for AP ap1, and enter its view.
[Sysname-wlan-ap-ap1] bridge-aggregation 1
[Sysname-wlan-ap-ap1-bridge-aggregation-1]
# Create Layer 2 aggregate interface 1 for APs with model WA4320i-ACN in AP group group1, and enter its view.
[Sysname-wlan-ap-group-1] ap-model WA4320i-ACN
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN] bridge-aggregation 1
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-bridge-aggregation-1]
control-address
Use control-address to specify the IP address to be carried in the CAPWAP Control IP Address message element.
Use undo control-address to restore the default.
control-address { ip ipv4-address | ipv6 ipv6-address }
undo control-address { ip | ipv6 }
In AP view, an AP uses the configuration in AP group view. If no configuration exists in AP group view, the AP uses the configuration in global configuration view.
In AP group view, an AP uses the configuration in global configuration view.
In global configuration view, the AC's IP address is inserted in the CAPWAP Control IP Address element.
AP view
AP group view
Global configuration view
ip ipv4-address: Specifies an IPv4 address in the CAPWAP Control IPv4 Address message element.
ipv6 ipv6-address: Specifies an IPv6 address in the CAPWAP Control IPv6 Address message element.
This command takes effect only when the AC rediscovery feature is enabled.
You can specify a maximum of three IPv4 or IPv6 addresses in the CAPWAP Control IP Address message element.
The configuration in AP view takes precedence over the configuration in AP group view. The configuration in AP group view takes precedence over the configuration in global configuration view.
# Specify 192.168.1.1 as the IPv4 address to be carried in the CAPWAP Control IPv4 Address message element in AP view.
[Sysname-wlan-ap-ap1] control-address ip 192.168.1.1
# Specify 192.168.1.1 as the IPv4 address to be carried in the CAPWAP Control IPv4 Address message element in AP group view.
[Sysname] wlan ap-group 10
[Sysname-ap-group-10] control-address ip 192.168.1.1
# Specify 192.168.1.1 as the IPv4 address to be carried in the CAPWAP Control IPv4 Address message element in global configuration view.
[Sysname-wlan-global-configuration] control-address ip 192.168.1.1
Use control-address enable to enable the AC rediscovery feature.
Use control-address disable to disable the AC rediscovery feature.
control-address { disable | enable }
In global configuration view, the AC rediscovery feature is disabled.
AP view
AP group view
An AC enabled with AC rediscovery adds the CAPWAP Control IP Address message element to the discovery responses sent to APs. Upon receiving such a discovery response, an AP establishes a CAPWAP tunnel with the IP address representing the optimal AC in the CAPWAP Control IP Address message element.
An AC disabled with AC rediscovery does not add the CAPWAP Control IP Address message element in discovery responses sent to APs. APs that receive the discovery responses will send join requests to the source IP address of the discovery responses to establish CAPWAP tunnels with the AC.
AC rediscovery applies to CMCC WLAN networks. As required by CMCC, an AC must carry the CAPWAP Control IP Address message element in discovery responses.
# Enable the AC rediscovery feature in AP view.
[Sysname-wlan-ap-ap1] control-address enable
# Enable the AC rediscovery feature in AP group view.
[Sysname-ap-group-10] control-address enable
# Enable the AC rediscovery feature in global configuration view.
[Sysname-wlan-global-configuration] control-address enable
control-address
Use data-tunnel encryption enable to enable CAPWAP data tunnel encryption.
Use data-tunnel encryption disable to disable CAPWAP data tunnel encryption.
Use undo data-tunnel encryption to restore the default.
data-tunnel encryption { disable | enable }
In AP group view, CAPWAP data tunnel encryption is disabled.
AP view
AP group view
When this feature is enabled, an AP exchanges encryption information including keys with the AC through the CAPWAP control tunnel upon receiving the first keepalive packet from the AC. After the exchange, the AC and the AP will encrypt data packets transmitted in a CAPWAP data tunnel. Keepalive packets are not encrypted.
This feature will cause an AP to reassociate with the AC.
# Enable CAPWAP data tunnel encryption for AP ap1.
[Sysname-wlan-ap-ap1] data-tunnel encryption enable
This operation will reconnect the AP. Continue? [Y/N]
# Enable CAPWAP data tunnel encryption for APs in AP group group1.
[Sysname-wlan-ap-group-group1] data-tunnel encryption enable
This operation will reconnect member APs that are not enabled with CAPWAP data tunnel encryption. Continue? [Y/N]
tunnel encryption
delete file
Use delete file to delete a file from an AP.
delete file filename
AP view
filename: Specifies a file by its file name, a string of 1 to 255 characters.
This command takes effect only after an AP establishes a CAPWAP tunnel with the master AC.
# Delete file startup.cfg from AP ap1.
[Sysname-wlan-ap-ap1] delete file startup.cfg
download file
Use description to configure a description for an AP group.
An AP group does not have a description.
AP group view
text: Specifies a description, a case-sensitive string of 1 to 64 characters.
Configure a description for an AP group for easy identification and management purposes.
You can use the display wlan ap-group command to view the configured description.
# Configure a description for AP group group1.
[Sysname-ap-group-group1] description L3-office
wlan ap-group
Use description to configure a description for an AP.
An AP does not have a description.
AP view
# Configure a description for AP ap1.
[Sysname-ap-ap1] description L3-office
display wlan ap
Use description to configure the description of an AP VLAN.
In an AP's VLAN view, a VLAN uses the configuration in an AP group's VLAN view.
In an AP group's VLAN view, the description of a VLAN is VLAN vlan-id. The vlan-id argument specifies the VLAN ID in a four-digit format. If the VLAN ID has less than four digits, leading zeros are added. For example, the default description of VLAN 100 is VLAN 0100.
AP's VLAN view
To manage VLANs efficiently, configure descriptions for them based on their functions or connections.
For this command to take effect on an AP, make sure the remote configuration assignment feature is enabled.
# Configure the description of VLAN 2 as sales-private in the VLAN view of AP ap1.
[Sysname-wlan-ap-ap1] vlan 2
[Sysname-wlan-ap-ap1-vlan2] description sales-private
# Configure the description of VLAN 2 as sales-private in the VLAN view of AP group 1.
[Sysname-wlan-ap-group-1] vlan 2
[Sysname-wlan-ap-group-1-vlan2] description sales-private
discovery-response
Use discovery-response wait-time to set the discovery-response timeout timer.
Use undo discovery-response wait-time to restore the default.
discovery-response wait-time seconds
In AP group view, the discovery-response timeout timer is 2 seconds.
AP view
AP group view
seconds: Specifies the discovery-response timeout timer in the range of 2 to 20 seconds.
The discovery-response timeout timer specifies the timeout time for an AP to wait for another discovery response. Whenever an AP receives a discovery response packet, the discovery-response timeout timer is created or refreshed. When the timeout timer expires, the AP sends a join request to the optimal AC.
If the network condition is poor, set a larger discovery-response timeout timer.
# Set the discovery-response timeout timer to 3 seconds for AP ap1.
[Sysname] wlan ap ap3
[Sysname-wlan-ap-ap3] discovery-response wait-time 3
# Set the discovery-response timeout timer to 3 seconds for all APs in AP group group1.
[Sysname-wlan-ap-group-group1] discovery-response wait-time 3
display wlan ap
Use display wlan ap to display AP information.
display wlan ap { all | name ap-name } [ verbose ]
all: Specifies all APs.
name ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
verbose: Displays detailed information.
# Display information about all APs.
<Sysname> display wlan ap all
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 2048
Remaining APs: 2047
Total AP licenses: 128
Local AP licenses: 128
Server AP licenses: 0
Remaining local AP licenses: 127
Sync AP licenses: 0
                                 AP information
 State : I = Idle,       J  = Join,       JA = JoinAck,    IL = ImageLoad
         C = Config,     DC = DataCheck,  R  = Run   M = Master,  B = Backup
AP name                        APID  State Model           Serial ID
ap1                            1     I     WA4320i-ACN     210235A1BSC123000050
Total number of connected fit APs.
Total number of connected inside APs. Inside APs are manual APs that are automatically created when anchor APs act as ACs. The name and the serial ID of an inside AP are the local MAC address and local serial ID, respectively.
Maximum number of APs supported by the AC.
Total AP licenses
Total number of AP licenses.
Local AP licenses
Number of AP licenses installed on the AC.
Server AP licenses
Number of AP licenses requested from the license server.
Number of unused AP licenses installed on the AC.
Sync AP licenses
Number of synchronized AP licenses.
APID
ID of the AP to uniquely identify the AP on the AC.
Current state of the AP:
·     I—Idle.
·     J—Join.
·     JA—Join acknowledge.
·     IL—The AP is downloading the image file.
·     C—The AP is downloading initial configurations.
·     DC—The AP is checking data.
·     R—The CAPWAP tunnel is operating. It indicates that the AP and the AC have established a CAPWAP tunnel.
·     R/M—The master CAPWAP tunnel is operating. It indicates that the AP and the master AC have established a CAPWAP tunnel.
·     R/B—The backup CAPWAP tunnel is operating. It indicates that the AP and the backup AC have established a CAPWAP tunnel.
·     M—The AP is connected to the master AC.
·     B—The AP is connected to the backup AC.
·     R/IL—The AP is online and is downloading the image file from the AC.
Serial ID
Serial ID of the AP. This field displays Not configured if the serial ID of the AP is not configured.
# Display detailed information about AP ap1.
<Sysname> display wlan ap name ap1 verbose
AP name                       : ap1
AP ID                         : 1
AP group name                 : default-group
State                         : Run
Backup type                   : Master
Online time                   : 0 days 1 hours 25 minutes 12 seconds
System uptime                 : 0 days 2 hours 22 minutes 12 seconds
Model                         : WA4320i-ACN
Region code                   : CN
Region code lock              : Disable
Serial ID                     : 219801A0CNC138011454
MAC address                   : 0AFB-423B-893C
IP address                    : 192.168.1.50
UDP control port number       : 18313
UDP data port number          : N/A
H/W version                   : Ver.C
S/W version                   : E2321
Boot version                  : 1.01
USB state                     : N/A
Power level                   : N/A
Power info                    : N/A
Description                   : wtp1
Priority                      : 4
Echo interval                 : 10 seconds
Echo count                    : 3 counts
Keepalive interval            : 10 seconds
Discovery-response wait-time  : 2 seconds
Statistics report interval    : 50 seconds
Fragment size (data)          : 1500
Fragment size (control)       : 1450
MAC type                      : Local MAC & Split MAC
Tunnel mode                   : Local Bridging & 802.3 Frame & Native Frame
CWPCAP data-tunnel status     : Down
Discovery type                : Static Configuration
Retransmission count          : 3
Retransmission interval       : 5 seconds
Firmware upgrade              : Enabled
Sent control packets          : 1
Received control packets      : 1
Echo requests                 : 147
Lost echo responses           : 0
Average echo delay            : 3
Last reboot reason            : User soft reboot
Latest IP address             : 10.1.0.2
Current AC IP                 : 192.168.1.1
Tunnel down reason            : Request wait timer expired
Connection count              : 1
Backup IPv4                   : Not configured
Backup IPv6                   : Not configured
Ctrl-tunnel encryption        : Disabled
Ctrl-tunnel encryption state  : Not encrypted
Data-tunnel encryption        : Disabled
Data-tunnel encryption state  : Not encrypted
LED mode                      : Normal
Remote configuration          : Enabled
EnergySaving Level            :0
Radio 1:
    Basic BSSID               : 7848-59f6-3940
    Admin state               : Up
    Radio type                : 802.11ac
    Antenna type              : internal
    Client dot11ac-only       : Disabled
    Client dot11n-only        : Disabled
    Channel bandwidth         : 20/40/80MHz
    Operating bandwidth       : 20/40/80MHz
    Secondary channel offset  : SCA
    Short GI for 20MHz        : Supported
    Short GI for 40MHz        : Supported
    Short GI for 80MHz        : Supported
    Short GI for 160MHz       : Not supported
    mimo                      : Not Config
    Green-Energy-Management   : Disabled
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    LDPC                      : Not Supported
    STBC                      : Supported
    Operational VHT-MCS Set:
        Mandatory             : Not configured
        Supported             : NSS1 0,1,2,3,4,5,6,7,8,9
                                NSS2 0,1,2,3,4,5,6,7,8,9
        Multicast             : Not configured
    Operational HT MCS Set:
        Supported             : 0, 1, 2, 3, 4, 5, 6, 7, 8, 9,
                                10, 11, 12, 13, 14, 15
    Channel                   : 44(auto)
    Channel usage(%)          : 15
    Max power                 : -102 dBm
    Operational rate:
        Mandatory             : 6, 12, 24 Mbps
        Multicast             : Auto
        Supported             : 9, 18, 36, 48, 54 Mbps
        Disabled              : Not configured
    Distance                  : 1 km
    ANI                       : Enabled
    Fragmentation threshold   : 2346 bytes
    Beacon interval           : 100 TU
    Protection threshold      : 2346 bytes
    Long retry threshold      : 4
    Short retry threshold     : 7
    Maximum rx duration       : 2000 ms
    Noise Floor               : 5 dBm
    Smart antenna             : Enabled
    Smart antenna policy      : Auto
    Protection mode           : rts-cts
    Continuous mode           : N/A
    HT protection mode        : No protection
Radio 2:
    Basic BSSID               : 7848-59f6-3950
    Admin state               : Down
    Radio type                : 802.11n(2.4GHz)
    Channel bandwidth         : 20/40MHz
    Channel auto-switch       : Enabled
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    STBC                      : Supported
                                10, 11, 12, 13, 14, 15, 16, 17,
                                18, 19, 20, 21, 22, 23, 24, 25,
                                26, 27, 28, 29, 30, 31
    Channel                   : 5(auto)
    Channel usage(%)          : 0
    Max power                 : 20 dBm
    Preamble type             : Short
    Operational rate:
        Mandatory             : 1, 2, 5.5, 11 Mbps
        Multicast             : Auto
        Supported             : 6, 9, 12, 18, 24, 36, 48, 54 Mbps
    Distance                  : 1 km
    ANI                       : Enabled
    Noise Floor               : 0 dBm
·     Idle—Idle.
·     Join—Join.
·     JoinAck—Join acknowledge.
·     Image—The AP is downloading the image file.
·     Config—The AP is downloading initial configurations.
·     Data Check—The AP is checking data.
·     Run—The CAPWAP tunnel is operating. It indicates that the AP and the AC have established a CAPWAP tunnel.
Backup type
CAPWAP tunnel type:
·     Idle—The AP has not established a CAPWAP tunnel with the AC.
·     Master—The CAPWAP tunnel established between the AP and the master AC.
·     Backup—The CAPWAP tunnel established between the AP and the backup AC.
Region code lock
·     Enabled.
·     Disabled.
Serial ID
Serial ID of the AP. If no serial ID is configured, this field displays Not configured.
MAC address
MAC address of the AP. If no MAC address is configured, this field displays Not configured.
Port number used by the AP to establish the CAPWAP control tunnel.
Port number used by the AP to establish the CAPWAP data tunnel.
H/W version
Hardware version of the AP.
S/W version
Software version of the AP.
USB state
USB state:
·     Enabled.
·     Disabled.
This field displays N/A if no USB state information is available.
Power level
Power level:
·     Low.
·     Middle.
·     High.
This field displays N/A if the power level is unknown.
Support for this field depends on the AP model.
Power info
Power supply information.
·     Power adapter—The AP uses local power supply.
·     PoE (port1+port2)—The AP uses PoE power supply. The port1 and port2 arguments represent the power supply status of PoE+ ports.
¡     N/A.
¡     802.3af.
¡     802.3at.
PoE status
PoE power supply state for each PI:
·     Enabled.
·     Disabled.
Description for the AP. If no description is configured, this field displays Not configured.
Priority
AP connection priority for the AC.
Echo interval
Interval for an AP to send echo requests to the AC.
Echo count
Maximum number of echo request transmission attempts.
Keepalive interval
Interval for an AP to send keepalive packets through the CAPWAP data tunnel.
Discovery-response timeout timer.
Interval for an AP to send statistics reports to the AC.
Maximum fragment size for CAPWAP data packets.
Maximum fragment size for CAPWAP control packets.
MAC type
MAC type of the AP-AC connection:
·     Local MAC—The AP encapsulates frames in 802.3 format before sending them to the AC.
·     Split MAC—The AP encapsulates frames in 802.11 format before sending them to the AC.
·     Local & Split MAC—The AP can encapsulate frames in either 802.3 format or 802.11 format before sending them to the AC.
Tunnel mode
Supported tunnel mode of the AP:
·     Local Bridging—The AP supports local bridging and does not forward data to the AC.
·     802.3 Frame—The AP encapsulates the frames in 802.3 format to send them to the AC.
·     Native Frame—The AP encapsulates the frames in 802.11 format to send them to the AC.
·     Local Bridging & 802.3 Frame—The AP supports the Local Bridging mode and the 802.3 Frame mode.
·     802.3 Frame & Native Frame—The AP supports the 802.3 Frame mode and the Native Frame mode.
·     Local Bridging & Native Frame—The AP supports the Local Bridging mode and the Native Frame mode.
Running status of the CAPWAP data tunnel:
·     Up.
·     Down.
Discovery type
Discovery method of the AP:
·     Static Configuration—The AP uses the manually configured IPv4 or IPv6 address of the AC.
·     DHCP—The AP gets the IP address of an AC through DHCP.
·     DNS—The AP gets the IP address of an AC through DNS.
·     Unknown.
Number of retransmission attempts for an AC request.
Interval at which AC requests can be retransmitted.
Firmware upgrade
AP software upgrade:
·     Enabled.
·     Disabled.
Number of sent packets, including Change State Event Response packets after the AC enters Run state. .
Number of received packets, including Change State Event Response packets after the AC enters Run state.
Echo requests
Number of echo requests sent by the AP in RUN state.
Lost echo responses
Number of echo responses not received by the AP in RUN state.
Average echo delay
Average echo delay in milliseconds.
Last reboot reason
Last reboot reason for the AP:
·     Power on.
·     Hard reboot.
·     Watchdog reboot.
·     Unknown reboot.
·     User soft reboot.
·     Kernel exception soft reboot.
·     Kernel deadloop soft reboot.
·     Auto update soft reboot.
·     Unknown soft reboot.
·     Memory exhausted.
·     Other unknown soft reboot.
Latest IP address
IP address that was most recently used by the AP.
Current AC IP
IP address of the AC that is associated with the AP.
Tunnel down reason
Cause for the CAPWAP tunnel to go down:
·     Failed to create timer.
·     Neighbor dead timer expired.
·     Request wait timer expired.
·     Data check timer expired.
·     Failed to process data channel keep-alive message.
·     Failed to process request.
·     AP was reset.
·     AP was deleted.
·     Failed to come online.
·     Serial number changed.
·     MAC address changed.
·     Number of APs exceeded the limit.
·     Processed join request in Run state.
·     Failed to create AP context.
·     Received failure result code.
·     Failed to retransmit message.
·     Failed to download image file.
·     Image file downloaded successfully.
·     File operation timer expired.
·     Failed to add tunnel.
·     Received WTP tunnel down event from AP.
·     Backup AC closed the backup tunnel.
·     Master and backup tunnel switchover.
·     Failed to inherit configuration.
·     AP authentication failed.
·     Encryption status mismatch.
·     AP was reset due to inconsistent local and reported radio statistics.
·     AP was reset due to inconsistent AP state on APMGR and lib.
·     AP was reset due to inconsistent BSS state on AC and AP.
This field displays N/A if the CAPWAP tunnel did not go down.
Connection count
Number of times that the AP connects to the AC. It is cleared in either one of the following cases:
·     The AC reboots.
·     The serial ID of the AP changes.
The reset wlan ap command does not clear the connection count.
Backup IPv4
IPv4 address of the backup AC. If no backup AC is specified, this field displays Not configured.
Backup IPv6
IPv6 address of the backup AC. If no backup AC is specified, this field displays Not configured.
CAPWAP control tunnel encryption:
·     Enabled.
·     Disabled.
CAPWAP control tunnel encryption state:
·     Encrypted.
·     Not encrypted.
CAPWAP data tunnel encryption:
·     Enabled.
·     Disabled.
CAPWAP data tunnel encryption state:
·     Encrypted.
·     Not encrypted.
LED mode
LED lighting mode:
·     quiet—All LEDs are off.
·     awake—All LEDs flash once every minute.
·     always-on—All LEDs are steady on.
·     normal—How LEDs flash in this mode varies by AP model.
Remote configuration assignment:
·     Enabled.
·     Disabled.
EnergySaving Level
Energy saving level:
·     0—Disabled.
·     1—Level 1.
·     2—Level 2.
Basic BSSID
MAC address of the radio. This field displays N/A if the AP has not established a CAPWAP tunnel with the AC.
Admin state
Radio state:
·     Up.
·     Down.
Radio type
Wireless mode:
·     5 GHz:
¡     802.11a.
¡     802.11n(5GHz).
¡     802.11ac.
·     2.4 GHz:
¡     802.11b.
¡     802.11g.
¡     802.11n(2.4GHz).
Client dot11ac-only
·     Disabled—Allows 802.11a/b/g/n/ac clients to associate with the radio.
·     Enabled—Allows only 802.11ac clients to associate with the radio.
Client dot11n-only
·     Enabled—Allows only 802.11n or 802.11ac clients to associate with the radio.
Channel bandwidth
Channel bandwidth mode:
·     20 MHz.
·     20 or 40 MHz.
·     20/40/80 MHz.
·     20/40/80/160MHz.
·     20/40/80/160/(80+80)MHz.
Operating bandwidth
Bandwidth being used by the radio.
Channel auto-switch
Current bandwidth. This field is available only when 20/40 MHz auto switching is enabled and it is the same as the bandwidth value carried in beacon frames.
Secondary channel information for the 802.11n and 802.11ac radio mode:
·     SCA (Second Channel Above)—The AP operates in 40 MHz bandwidth mode, and the secondary channel is above the primary channel.
·     SCB (Second Channel Below)—The AP operates in 40 MHz bandwidth mode, and the secondary channel is below the primary channel.
·     SCN—The AP does not operate in 40 MHz bandwidth mode.
This field is available only when the bandwidth that the radio is using is 20/40/80MHz.
Secondary channel center frequency
Center frequency information about the 80 MHz bandwidth of the secondary channel when the radio operates in 802.11ac radio mode with a channel bandwidth of 160/(80+80)MHz.
This field is available only when the bandwidth that the radio is using is 160/(80+80)MHz.
Short GI for 20MHz
Whether the radio supports short GI when it operates in 20 MHz mode.
Short GI for 40MHz
Whether the radio supports short GI when it operates in 40 MHz mode.
Short GI for 80MHz
Whether the radio supports short GI when it operates in 80 MHz mode.
Short GI for 160MHz
Whether the radio supports short GI when it operates in 160 MHz mode.
mimo
MIMO mode:
·     1x1—The radio sends and receives signals through one spatial stream.
·     2x2—The radio sends and receives signals through two spatial streams.
·     3x3—The radio sends and receives signals through three spatial streams.
·     4x4—The radio sends and receives signals through four spatial streams.
·     Not configured—The radio sends and receives signals through the maximum number of spatial streams supported by the radio.
If this field also displays (PowerLow) after any value option to indicate low power level, the radio can send and receive signals only through one spatial stream.
Energy-saving:
·     Disabled.
·     Enabled.
A-MSDU
·     Disabled.
·     Enabled.
A-MPDU
·     Disabled.
·     Enabled.
LDPC
·     Supported.
·     Not supported.
STBC
·     Supported.
·     Not supported.
Operational VHT MCS Set
·     Supported—Supported VHT MCS set.
·     Mandatory—Mandatory VHT MCS set.
·     Multicast—Multicast VHT MCS set.
·     Supported—Supported MCS set.
·     Mandatory—Mandatory MCS set.
·     Multicast—Multicast MCS set.
Channel
This field displays Number<auto> if the current channel is the optimal channel automatically selected by the AP.
This field displays Number if the current channel is manually configured.
This field displays Number<avoid radar> if the current channel is automatically selected by the AP to avoid radar signals.
Max power
Maximum transmission power of the radio.
Preamble type
Preamble type:
·     Short.
·     Long.
Operational rate
·     Mandatory.
·     Supported.
·     Multicast.
·     Disabled.
·     Not configured.
Distance
Maximum distance that the radio signal can reach.
ANI
·     Enabled.
·     Disabled.
Frame length threshold required for triggering the protection mechanism.
Maximum number of retransmission attempts for frames whose length exceeds the RTS threshold.
Maximum number of retransmission attempts for frames whose length is below the RTS threshold.
Maximum rx duration
Maximum buffer duration for frames.
Smart antenna
·     Enabled.
·     Disabled.
·     Auto.
·     High availability.
·     High throughput.
Protection mode
Conflict avoidance mode:
·     cts-to-self.
·     rts-cts.
Continuous mode
Continuous mode configuration:
·     Rate.
·     MCS index.
·     NSS index.
·     VHT-MCS index.
This field displays N/A if the continuous mode is not configured.
HT protection mode
802.11n protection mode:
·     No protection.
¡     AP-associated clients and nearby wireless devices are operating in 802.11n mode and AP-associated clients are 802.11n clients with a bandwidth of 40 MHz.
¡     AP-associated clients are 802.11n clients with a bandwidth of 20 MHz.
·     Non-member protection.
In this mode, all AP-associated clients are 802.11n clients but some nearby wireless devices are non-802.11n clients.
·     20 MHz protection.
In this mode, the AP's radio has a bandwidth of 40 MHz. AP-associated clients and nearby wireless devices are operating in 802.11n mode and a minimum of one 802.11n client with a bandwidth of 20 MHz is associated with the AP's radio.
·     Non-HT mixed.
The mode applies when none of the above mentioned modes can apply.
MU-TxBF
·     Enabled.
·     Disabled.
SU-TxBF
·     Enabled.
·     Disabled.
Use display wlan ap address to display AP address information.
display wlan ap { all | name ap-name } address
# Display address information for all APs.
<Sysname> display wlan ap all address
AP name                          IP address                     MAC address
ap1                              1.1.1.5                        000b-6b8f-fc6a
Total number of APs
Total number of fit APs.
Total number of connected manual fit APs.
Total number of connected auto fit APs.
IP address
IP address of an AP.
This field displays N/A for an offline AP.
MAC address
MAC address of an AP.
Use display wlan ap all feature band-navigation to display the configuration status of the band navigation feature for all APs.
# Display the configuration status of the band navigation feature for all APs.
<Sysname> display wlan ap all feature band-navigation
AP name                        Status
ap1                            Enabled
Status
Band navigation:
·     Enabled.
·     Disabled.
Use display wlan ap all feature capwap to display configuration status of CAPWAP tunnel features.
# Display configuration status of CAPWAP tunnel features.
<Sysname> display wlan ap all feature capwap
AP name                       Upgrade   Encryption  Control-address   Switch-back
ap1                           Disabled  Both        Enabled           Disabled
Table 5 Command output
Upgrade
·     Enabled.
·     Disabled.
Encryption
CAPWAP tunnel encryption:
·     Control—Control tunnel encryption is enabled.
·     Data—Data tunnel encryption is enabled.
·     Both—Encryption is enabled for both control and data tunnels.
·     Disabled—Encryption is disabled for both control and data tunnels.
Control-address
AC rediscovery:
·     Enabled.
·     Disabled.
Switch-back
The CAPWAP tunnel switch-back feature for AC hierarchy:
·     Horizontal.
·     Vertical.
·     Disabled.
·     Both.
Use display wlan ap connection-record to display AP connection records on the AC.
display wlan ap { all | name ap-name } connection-record
# Display all AP connection records on an AC.
<Sysname> display wlan ap all connection-record
AP name                         IP address      State     Time
ap2                             192.168.100.27  Run       01-06 09:06:40
Table 6 Command output
·     Discovery—AC discovery.
·     Join—The CAPWAP tunnel is being established.
·     Offline—Offline.
·     Run—The CAPWAP tunnel is operating. It indicates that the AP and the AC have established a CAPWAP tunnel successfully.
Time
Most recent time when the AP established a CAPWAP tunnel with the AC.
Use display wlan ap description to display AP descriptions on the AC.
display wlan ap { all | name ap-name } description
name ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
This command displays descriptions only for manual APs. The description for an auto AP is Not configured.
# Display AP descriptions on the AC.
<Sysname> display wlan ap all description
AP information
AP name                       AP ID  Description
ap1                            1      Not configured
Table 7 Command description
AP ID
AP ID, a unique identifier of an AP on the AC.
AP description.
This field displays Not configured for auto APs or manual APs that are not configured with any description.
Use display wlan ap files to display information about files and file folders on an AP.
display wlan ap name ap-name files
# Display information about files and file folders on AP ap1.
<Sysname> display wlan ap name ap1 files
Directory of flash:
   0   13638656  wa4300-system.bin
   1   2573312   wa4300-boot.bin
131072 KB total (114208 KB free)
Table 8 Command output
0   13638656  xx.xx
File or file folder information:
·     0—Serial number, which is automatically assigned by the system.
·     13638656— File size in bytes. A hyphen (-) is displayed if it is a file folder.
·     xx.xx—Name of the file or file folder.
delete file
download file
display wlan ap gps
Use display wlan ap gps to display Global Positioning System (GPS) information for the specified APs.
display wlan ap { all | name ap-name } gps
This command takes effect only on APs that support the GPS module.
# Display GPS information for AP ap1.
<Sysname> display wlan ap name ap1 gps
AP name    : ap1
Serial ID  : 219801A17C817200001
Model      : WA5620
Longitude  : 117.788887
Latitude   : 30.822136
Velocity   : 25.445878
Orientation: 8.054548
Elevation  : 156.655897
Obtained at: 2017-02-20 15:32:19
Table 9 Command output
AP name
Name of the AP.
Serial ID
Model
AP model.
Longitude
Longitude rounded to six decimal places.
Latitude
Latitude rounded to six decimal places.
Velocity
Horizontal velocity rounded to six decimal places.
Orientation
Orientation rounded to six decimal places.
Elevation
Elevation rounded to six decimal places.
Obtained at
Time when the GPS information was obtained.
Use display wlan ap group to display AP groups to which the specified APs belong.
display wlan ap { all | name ap-name } group
# Display AP groups for all APs.
<Sysname> display wlan ap all group
Remaining APs: 2047
Sync AP licenses: 0
                                 AP information
 State: I = Idle,       J= Join,       JA= JoinAck,    IL= ImageLoad
         C= Config,     DC= DataCheck,  R= Run   M= Master,  B= Backup
AP name                        APID  State Model           AP group name
ap1                            1     I     WA4320i-ACN     default-group
Table 10 Command output
Total number of APs
Maximum number of fit APs supported by the AC.
Total AP licenses
local AP licenses
Server AP licenses
Sync AP licenses
APID
·     I—Idle.
·     J—Join.
Model
AP model
AP group name
Name of the AP group to which the AP belongs.
Use display wlan ap online-time to display the online duration for APs.
display wlan ap { all | name ap-name } online-time
# Display online duration for all APs.
<Sysname> display wlan ap all online-time
AP name            IP address               Time
ap1                1.1.1.2                  0 days 0 hours 2 minutes 6 seconds
ap2                1.1.1.1                  0 days 0 hours 5 minutes 6 seconds
ap3                1.1.1.6                  0 days 0 hours 2 minutes 1 seconds
Table 11 Command output
IP address
Time
Real-time association duration of an AP since the AP came online.
Use display wlan ap reboot-log to display reboot logs for an AP.
display wlan ap name ap-name reboot-log
If the AP has suffered a system crash, you can use this command to view detailed information about the crash.
To use this command, make sure the specified AP is in Run state.
# Display reboot logs for AP ap1.
<Sysname> display wlan ap name ap1 reboot-log
Debugging information is not available on the AC.
Downloading debugging data from AP. Continue? [Y/N]:y
Downloading debugging data. Please wait...
Please enter the same command again to view the log messages.
<Sysname>dis wlan ap name ap1 reboot-log
--------------------- Reboot record 1 ---------------------
Recorded at           : 2018-07-20  03:29:43.324529
Occurred at           : 2018-07-20  03:29:43.324529
Reason                : 0x8
Thread                : devd (TID: 50)
Context               : thread context
Cpu                   : 0
Kernel module info    : module name (system) module address (0xd145a000)
                        module name (addon) module address (0xd00d5000)
Last 5 thread switches : WDRVFwdKthread (3:29:43.323999)-->
                         swapper (3:29:43.324011)-->
                         WDRVFwdKthread (3:29:43.324467)-->
                         swapper (3:29:43.324478)-->
                         devd (3:29:43.324502)-->
Use display wlan ap running-configuration to display running configuration for the specified AP or all APs.
display wlan ap { all | name ap-name } running-configuration [ verbose ]
verbose: Displays detailed running configuration.
# Display detailed running configuration for all APs.
<Sysname> display wlan ap all running-configuration verbose
(i) -- Inherited from AP group
(g) -- Inherited from AP global-configuration
wlan ap ap1 model WA4320i-ACN id 5
  ap group name 1
  serial-id 210235A1BSC123000050
  region code 156
  echo interval 10 (i)
  retransmission count 3 (i)
  retransmission interval 5 (i)
  statistics interval 50 (i)
  fragment-size data 1500 (i)
  fragment-size control 1450 (i)
  tunnel-preempt disable (g)
  firmware-upgrade disable (g)
  priority 4 (i)
  radio 1
    radio type 802.11ac (i)
    radio disable (i)
    channel auto<64> (i)
    channel unlock (i)
    fragment-threshold 2346 (i)
    max-power 20 (i)
    power unlock (i)
    distance 1 kilometer (i)
    ANI Enabled (i)
  radio 2
    radio type 802.11n(2.4GHz) (i)
    radio disable (i)
    channel auto<11> (i)
    channel unlock (i)
    max-power 20 (i)
    power unlock (i)
    ANI Enabled (i)
wlan ap ap2 model WA4320i-ACN id 6
  ap group name 2
  serial-id 210235A1BSC123000055
  region code 156
  priority 4 (i)
  radio 1
    radio disable (i)
    channel auto<60> (i)
    channel unlock (i)
    max-power 20 (i)
    power unlock (i)
    ANI Enabled (i)
  radio 2
    radio disable (i)
    channel auto<13> (i)
    channel unlock (i)
    max-power 20 (i)
    power unlock (i)
    ANI Enabled (i)
Use display wlan ap statistics association-failure-record to display association failure records for APs.
# Display association failure records for APs.
<Sysname> display wlan ap statistics association-failure-record
MAC address    AP ID Last failed at   Reason
9a48-45ed-0300 12312 07-07/15:56:25   AP authentication failed
Table 12 Command output
MAC address
AP ID
ID of an AP, which uniquely identifies the AP on the AC.
Last failed at
Last time an AP associated with the AC. The format is date/hh:mm:ss.
Reason
Association failure reason:
·     Failed to create data check timer.
·     Memory is not enough.
·     The AP model doesn't exist.
·     Lack of AP license.
·     MAC address conflict.
·     Failed to add APLB.
·     AP chose another AC.
·     Reached AC max capability.
·     Received join request in Run state.
·     APLB check failed.
·     Rejected AP access in HA smooth.
·     Failed to create auto AP.
·     The AP information has already existed.
·     Failed to download AP image file.
·     Timer for waiting change state event request expired.
·     Time for waiting image data request or configuration request expired.
·     Received failure result code in change state event request.
·     AP configuration was not found.
·     Inconsistent AP IDs.
·     Failed to send query message.
·     Open image file timer expired.
Use display wlan ap statistics image-download to display AP image downloading information.
display wlan ap statistics image-download [ failed | in-progress | succeeded ]
failed: Displays APs that have failed to download the images.
in-progress: Displays APs that are downloading images.
succeeded: Displays APs that have successfully downloaded images.
If you do not specify any keyword, the command displays brief information about AP image downloading.
# Display brief information about AP image downloading.
[Sysname] display wlan ap statistics image-download
Completed : 50%
Time consumed : xxd hh:mm:ss
AP count:
 Succeeded : 152
 In-progress : 140
 Failed : 8
Table 13 Command output
Completed
Percentage of APs that have completed image downloading.
Time consumed
Time that has been consumed for image downloading.
Total to download
Total number of APs that need to be updated.
Succeeded
Number of APs that have successfully downloaded images.
In-progress
Number of APs that are downloading images.
Failed
Number of APs that have failed to download images.
# Display APs that are downloading images.
[Sysname] display wlan ap statistics image-download in-progress
AP name                       Time consumed
ap6                                xxd 00:45:11
ap7                                N/A
ap8                                xxd 00:14:05
ap9                                xxd 01:16:09
------More----
Table 14 Command output
Time consumed
Time that has been consumed for image downloading. This field displays N/A if the AP has not started image downloading.
# Display APs that have failed to download images.
[Sysname] display wlan ap statistics image-download failed
AP name                     Failure reason
ap1                         Tunnel down
ap2                         AP memory not enough
ap3                         Image file does not exist
ap5                         Others
------More----
Table 15 Command output
Time consumed
Failure reason:
·     Tunnel down.
·     AP memory not enough.
·     Image file does not exist.
·     Retransmission failed.
·     Others.
# Display APs that have downloaded images successfully.
[Sysname] display wlan ap statistics image-download succeeded
AP name                     Version
ap1                         R5220
ap2                         R5220
ap3                         R5220
ap5                         R5220
------More----
Use display wlan ap statistics online-record to display online AP quantity records.
display wlan ap statistics online-record [ datetime date time [ count count ] ]
datetime date time: Specifies the start time to display online AP quantity records. The date argument represents the date in the YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month. The time argument represents the time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. If you do not specify this option, the command displays all statistics about online AP quantity over the past 7 days in descending order of time.
count count: Specifies the number of online AP quantity records to be displayed, in the range of 1 to 256. If you do not specify this option, 10 online AP quantity records are displayed.
The online AP quantity records are displayed one by one at intervals of 1 minute. This command supports displaying records generated only over the past 7 days. If a time is specified, this command displays the specified number of online AP quantity records generated after the specified time point.
# Display 11 online AP quantity records generated after 2017/10/11 10:16.
<Sysname> display wlan ap statistics online-record datetime 2017/10/11 10:16 count 11
Time                    Manual APs       Auto APs        Total        Total delta
2017-10-11 10:16:00     20               10              30           -2
2017-10-11 10:17:00     22               10              32           +6
2017-10-11 10:18:00     16               10              26           0
2017-10-11 10:19:00     16               10              26           0
2017-10-11 10:20:00     16               10              26           0
2017-10-11 10:21:00     16               10              26           0
2017-10-11 10:22:00     16               10              26           0
2017-10-11 10:23:00     16               10              26           0
2017-10-11 10:24:00     16               10              26           0
2017-10-11 10:25:00     16               10              26           0
2017-10-11 10:26:00     16               10              26           0
Table 16 Command output
Time
Date and time when the record was generated.
Manual APs
Number of online manual APs.
Auto APs
Number of online auto APs.
Total
Total number of online APs.
Total delta
Quantity change in comparison with the last minute.
Use display wlan ap statistics tunnel-down-record to display CAPWAP tunnel down records.
# Display CAPWAP tunnel down records.
<Sysname> display wlan ap statistics tunnel-down-record
AP name                             AP ID  Tunnel down at        Tunnel down reason
9a48-45ed-0300                      123    07-07/15:56:25        Processed join request
        in Run state
Table 17 Command output
AP name
Name of an AP.
AP ID
Tunnel down at
Time when the CAPWAP tunnel between an AP and the AC went down. The format is date/hh:mm:ss.
Tunnel down reason
CAPWAP tunnel down reason:
·     AP was reset by admin.
·     AP was reset by Web.
·     Manual AP was deleted.
·     Serial ID changed.
·     Exceeded AC max capability.
·     Unauthenticated AP tunnel down.
·     Backup AP upgrade failed.
·     Board is inactive.
Use display wlan ap tunnel latency to display tunnel latency information for an AP.
display wlan ap name ap-name tunnel latency
Make sure CAPWAP tunnel latency detection is enabled before you execute this command.
# Display tunnel latency information for AP ap1.
<Sysname> display wlan ap name ap1 tunnel latency
AP name                              : ap1
Tunnel Latency                       : Enabled
Control Link Delay:
  Current Delay                      : 1ms
  Maximum Delay                      : 1ms
  Minimum Delay                      : 1ms
Data Link Delay:
  Current Delay                      : 1ms
  Maximum Delay                      : 1ms
  Minimum Delay                      : 1ms
Table 18 Command output
Tunnel Latency
·     Disabled.
·     Enabled.
Current Delay
The most recent delay.
Use display wlan ap unauthenticated to display information about unauthenticated auto APs.
display wlan ap unauthenticated [ verbose ]
verbose: Displays detailed information about unauthenticated auto APs. If you do not specify this keyword, this command displays brief information about unauthenticated auto APs.
# Display brief information about unauthenticated auto APs.
<Sysname> display wlan ap unauthenticated
Total number of connected manual APs: 0
Total number of connected auto APs: 1
Maximum supported APs: 3072
Remaining APs: 3071
Fit APs activated by license: 128
Remaining fit APs: 127
WTUs activated by license: 0
Remaining WTUs: 0
                                 AP information
         C = Config,    DC = DataCheck,  R  = Run,   M = Master,  B = Backup
6649-99be-0300                 6     R/M   WA4320i-ACN     219801A0CNC138011454
Table 19 Command output
Total number of APs
Total number of inside APs. Inside APs are manual APs that are automatically created when anchor APs act as ACs. The name and the serial ID of an inside AP are the local MAC address and local serial ID, respectively.
APID
·     I—Idle.
·     J—Join.
·     IL—The AP is downloading the software image file.
Serial ID
# Display detailed information about unauthenticated auto APs.
<Sysname> display wlan ap unauthenticated verbose
Total number of connected APs: 0
Remaining APs: 3071
Remaining WTUs: 0
AP name                       : ap1
AP ID                         : 1
State                         : Run
Backup Type                   : Master
System up time                : 0 days 2 hours 22 minutes 12 seconds
Model                         : WA4320i-ACN
Region code                   : CN
UDP port number               : 65488
H/W version                   : Ver.C
S/W version                   : V700R001B49D001
Boot version                  : 1.01
Description                   : wtp1
Priority                      : 4
Fragment-size data            : 1500
Fragment-size control         : 1450
Echo requests                 : 147
Tunnel encryption             : Disabled
LED mode                      : Normal
Radio 1:
    Admin state               : Up
    Channel band-width        : 20/40/80MHz
    Secondary channel offset  : SCB
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    STBC                      : Supported
    Channel                   : 44(auto)
    Max power                 : 20 dBm
    Operational rate:
        Multicast             : Auto
    Distance                  : 1 km
    ANI                       : Enabled
    Noise Floor               : 5 dBm
Protection mode           : cts-to-self
Continuous-mode           : N/A
Radio 2:
    Admin state               : Down
    Radio type                : 802.11b
    Channel band-width        : 20MHz
    Secondary channel offset  : SCN
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    STBC                      : Supported
    Channel                   : 5(auto)
    Max power                 : 20 dBm
    Operational rate:
        Multicast             : Auto
    Distance                  : 1 km
    ANI                       : Enabled
    Noise Floor               : 5 dBm
Table 20 Command output
Total number of APs
AP ID
·     Idle—Idle.
·     Join—Join.
·     Image—The AP is downloading the software image file.
Backup Type
CAPWAP tunnel type:
Region code lock
·     Enabled.
·     Disabled.
Serial ID
MAC address
UDP port number
H/W version
S/W version
Priority
Echo interval
Interval for the AP to send echo requests to the AC.
Statistics report interval for the AP to send statistics reports to the AC
Fragment-size data
MAC type
Tunnel mode
Discovery type
Discovery type of the AP:
·     Unknown.
Firmware upgrade
·     Enabled.
·     Disabled.
Echo requests
Lost echo responses
Average echo delay
Last reboot reason
·     Power on.
·     Hard reboot.
·     Watchdog reboot.
·     Unknown reboot.
·     User soft reboot.
·     Memory exhausted.
Latest IP address
Tunnel down reason
·     AP was reset.
·     AP was deleted.
Connection count
·     The AC reboots.
Backup IPv4
Backup IPv6
Tunnel encryption
·     Enabled.
·     Disabled.
·     Enabled.
·     Disabled.
LED mode
LED lighting mode:
·     Quiet—All LEDs are off.
·     Awake—All LEDs flash once every minute.
·     Always-on—All LEDs are steady on.
·     Normal—How LEDs flash in this mode varies by AP model.
·     Enabled.
·     Disabled.
Basic BSSID
Admin state
Radio state:
·     Up.
·     Down.
Radio type
Wireless mode:
·     5 GHz:
¡     802.11a.
¡     802.11n(5GHz).
¡     802.11ac.
·     2.4 GHz:
¡     802.11b.
¡     802.11g.
¡     802.11n(2.4GHz).
Client dot11ac-only
Client dot11n-only
Channel band-width
Channel bandwidth:
·     20 MHz.
·     20 or 40 MHz.
·     20/40/80 MHz.
Short GI for 20MHz
Short GI for 40MHz
Short GI for 80MHz
Short GI for 160MHz
A-MSDU
·     Disabled.
·     Enabled.
A-MPDU
·     Disabled.
·     Enabled.
LDPC
·     Supported.
·     Not supported.
STBC
·     Supported.
·     Not supported.
Channel
Max power
Preamble type
Preamble type:
·     Short.
·     Long.
Operational rate
·     Mandatory.
·     Supported.
·     Multicast.
·     Disabled.
·     Not configured.
Distance
ANI
·     Enabled.
·     Disabled.
Maximum rx duration
Smart antenna
·     Enabled.
·     Disabled.
·     Auto.
·     High throughput.
Protection mode
·     cts-to-self.
·     rts-cts.
Continuous mode
·     Rate.
·     MCS index.
·     NSS index.
·     VHT-MCS index.
Use display wlan ap-distribution to display AP distribution information.
In standalone mode:
display wlan ap-distribution all
In IRF mode:
display wlan ap-distribution { all | slot slot-number }
all: Displays distribution information for all APs.
slot slot-number: Specifies an IRF member device by its member ID. (In IRF mode.)
# Display distribution information for all APs.
<Sysname> display wlan ap-distribution all
Slot               : 1
AP name            : 722a-d561-0301
Slot 1                Total number of APs: 1
AP name               AP ID          AP IP        AC IP
ap1                   1              1.1.1.1      1.1.1.10
# On an IRF fabric, display distribution information for APs attached to the specified slot.
<Sysname> display wlan ap-distribution slot 0
                                 AP information
722a-d561-0300                 4     R/M   WA4320i-ACN     210235A1BSC123000050
Table 21 Command output
APID
·     I—Idle.
·     J—Join.
Model
AP model information.
Serial ID
Use display wlan ap-distribution ap-name to display the attachment location of an AP.
display wlan ap-distribution ap-name ap-name
# On an IRF fabric, display the attachment location of AP ap1.
<Sysname> display wlan ap-distribution ap-name ap1
The AP is attached to slot 0.
# On a non-IRF network, display the attachment location of AP ap1.
Use display wlan ap-group to display information about all AP groups or the specified AP group.
display wlan ap-group [ brief | name group-name ]
brief: Displays brief information about all AP groups.
name group-name: Displays detailed information about the specified AP group. The group-name argument represents the name of an AP group, a case-insensitive string of 1 to 31 characters.
If you do not specify any parameter, this command displays detailed information about all AP groups.
# Display detailed information about all AP groups.
[Sysname] display wlan ap-group
Total number of AP groups: 2
Description         : Not configured
AP model            : Not configured
APs                 : Not configured
AP group name       : group1
Description         : abcd
AP model            : WA4320i-ACN
AP grouping rules:
  AP name           : ap1, ap2
  IPv4 address      : Not configured
  IPv6 address      : Not configured
APs                 : ap1 (AP name)
# Display detailed information about AP group group1.
[Sysname] display wlan ap-group group1
AP grouping rules:
  AP name           : ap1, ap2
APs                 : ap1 (AP name)
# Display brief information about all AP groups.
<Sysname> display wlan ap-group brief
Total number of AP groups: 4
AP group name                  Group ID  Member APs   Online APs
default-group                  1         1            0
group1                         2         2006         1986
group2                         3         10           10
group3                         4         4            4
wlan ap-group
Use display wlan ap-model to display AP model information.
display wlan ap-model { all | name model-name }
all: Specifies all AP models.
name model-name: Specifies an AP model by its name.
# Display information about AP model WA4320i-ACN.
<Sysname> display wlan ap-model name WA4320i-ACN
Alias           : WA4320i-ACN
Vendor name     : H3C
Vendor ID       : 25506
License weight  : 100
License type    : 1
Radio count     : 2
 Radio 1:
  Mode          : 802.11a, 802.11an, 802.11ac
  Default mode  : 802.11ac
  BSS count     : 16
 Radio 2:
  Mode          : 802.11b, 802.11g, 802.11gn
  Default mode  : 802.11gn
  BSS count     : 16
Version Support List :
Hardware Version Ver.A:
  Software Version         : R2206P02
  Default Software Version : R2206P02
  Image Name               : wa4300.ipe
 Hardware Version Ver.B:
 Hardware Version Ver.C:
 Hardware Version Ver.D:
 Hardware Version Ver.E:
 Hardware Version Ver.F:
Table 22 Command output
AP model
AP model name.
Alias
AP model alias.
License weight
Weight of the AP model in using an AP license, in percentage.
License type
AP type.
1—Common AP.
Radio count
Number of radios.
Mode
Supported radio types.
Default mode
Default radio type.
BSS count
Maximum number of BSSs that the radio supports.
Software Version
AP' software version used to compare with the software version reported by the AP.
The default value is the AP software version stored in the APDB.
Image Name
Name of the AP image file.
display wlan device role
Use display wlan device role to display the WLAN device role.
# Display the role of the WLAN device.
<Sysname> display wlan device role
Current device role: Local AC.
Table 23 Command output
Current device role
Current device role. Options include:
·     AC.
·     FAT AP.
·     FIT AP.
display wlan license
Use display wlan license to display the number of installed WLAN licenses.
# Display the number of installed WLAN licenses.
<Sysname> display wlan license
Installed common AP licenses : 64
Installed WTU licenses       : 0
Table 24 Command output
Number of installed common AP licenses.
Number of installed WTU licenses.
dns domain
Use dns domain to specify a domain name for an AP.
Use undo dns domain to restore the default.
dns domain domain-name
undo dns domain
In global provision view, no domain name is specified for an AP.
AP provision view
domain-name: Specifies a domain name, a case-insensitive string of 1 to 253 characters separated by dots. The string can contain letters, digits, hyphens (-), and underscores (_).
# Set the domain name to com in AP provision view of AP ap1.
[Sysname-wlan-ap-ap1-prvs] dns domain com
# Set the domain name for APs to com in AP group provision view of AP group group1.
[Sysname-wlan-ap-group-group-prvs] dns domain com
# Set the domain name for APs to com in global provision view.
[Sysname-wlan-global-configuration-prvs] dns domain com
dns server
dns server
Use dns server to specify a DNS server for an AP.
Use undo dns server to delete the DNS server configuration.
dns server { ip ipv4-address | ipv6 ipv6-address }
undo dns server { ip | ipv6 }
In AP provision view, an AP uses the configuration in AP group provision view. If no configuration exists in AP group provision view, the AP uses the configuration in global provision view.
In AP group provision view, an AP uses the configuration in global provision view.
In global provision view, no DNS server is specified for an AP.
AP provision view
Global provision view
ip ipv4-address: Specifies a DNS server by its IPv4 address. Make sure you specify a valid IP address. Invalid IP addresses include loopback IP addresses, direct broadcast addresses, Class D IP addresses, Class E IP addresses, IP address 255.255.255.255, and IP addresses in the 0.X.X.X format.
ipv6 ipv6-address: Specifies a DNS server by its IPv6 address. This option is unavailable in global provision view.
You can specify only one IPv4 address and one IPv6 address in each view.
The configuration in AP provision view takes effect only on the AP. The configuration in AP group provision view takes effect on all APs in the AP group. The configuration in global provision view takes effect on all APs.
The priorities of configurations in AP provision view, AP group provision view, and global provision view are in descending order.
# Set the DNS server IP address to 192.168.100.123 in AP provision view of AP ap1.
[Sysname] wlan ap ap1 model WA4320i-ACN
[Sysname-wlan-ap-ap1] provision
[Sysname-wlan-ap-ap1-prvs] dns server ip 192.168.100.123
# Set the DNS server IP address to 192.168.100.123 in AP group provision view of AP group group1.
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] provision
[Sysname-wlan-ap-group-group-prvs] dns server ip 192.168.100.123
# Set the DNS server IP address to 192.168.100.123 in global provision view.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] provision
[Sysname-wlan-global-configuration-prvs] dns server ip 192.168.100.123
dns domain
download file
Use download file to download an image file to an AP.
download file filename
AP view
filename: Specifies an image file by its name, a string of 1 to 255 characters.
This feature takes effect only on the master AC after a CAPWAP tunnel is established in WLAN high availability networking. For more information about WLAN high availability, see "Configuring WLAN high availability."
# Download image file main.ipe to AP ap1.
[Sysname-wlan–ap-ap1] download file main.ipe
echo-count
Use echo-count to set the maximum number of echo request transmission attempts.
Use undo echo-interval to restore the default.
echo-count count
undo echo-count
In AP group view, the maximum number of echo request transmission attempts is 3.
AP view
AP group view
count: Specifies the maximum number of echo request transmission attempts in the range of 3 to 255.
An AP sends echo requests to the AC at the specified echo intervals to identify whether the CAPWAP control tunnel is operating correctly. The AC responds by sending echo responses. If the AP does not receive any echo responses before the keepalive timer expires, the AP terminates the connection. If the AC does not receive any echo requests before the keepalive timer expires, the AC terminates the connection. The keepalive timer is the echo interval multiplied by the maximum number of echo request transmission attempts.
# Set the maximum number of echo request transmission attempts to 5 for AP ap3.
[Sysname] wlan ap ap3 model WA4320i-ACN
[Sysname-wlan-ap-ap3] echo-count 5
# Set the maximum number of echo request transmission attempts to 5 for APs in AP group group1.
[Sysname-wlan-ap-group-group1] echo-count 5
echo-interval
Use echo-interval to set the interval for an AP to send echo requests to the AC.
echo-interval interval
undo echo-interval
In AP group view, the interval for an AP to send echo requests is 10 seconds.
AP view
AP group view
interval: Specifies the interval for sending echo requests, in seconds. The value range is 0 and 5 to 255.
CAUTION
CAUTION:
Setting the echo interval to 0 seconds disables an AP from sending echo requests. This setting is for test use only. For correct AC and AP communication, do not set the echo interval to 0 seconds.
An AP sends echo requests to the AC at the specified echo intervals to identify whether the CAPWAP control tunnel is operating correctly. If the AP does not receive any echo responses from the AC before the keepalive timer expires, the AP terminates the connection. If the AC does not receive any echo requests before the keepalive timer expires, the AC terminates the connection.
The keepalive time is the echo interval multiplied by the maximum number of echo request transmission attempts set by using the echo-count count command. If the calculated value exceeds 120 seconds, the keepalive time is rounded to 120 seconds.
# Set the echo interval for AP ap3 to 15 seconds.
[Sysname-wlan-ap-ap3] echo-interval 15
# Set the echo interval for APs in AP group group1 to 15 seconds.
[Sysname-wlan-ap-group-group1] echo-interval 15
firmware-upgrade
Use firmware-upgrade enable to enable the software upgrade feature.
Use firmware-upgrade disable to disable the software upgrade feature.
Use undo firmware-upgrade to restore the default.
firmware-upgrade { disable | enable }
In AP view, an AP uses the configuration in AP group view. If no software upgrade configuration exists in AP group view, the AP uses the configuration in global configuration view.
In global configuration view, the software upgrade feature is enabled.
AP view
AP group view
This feature enables the AC to examine whether an AP's software version matches the hardware version and software version mappings stored on the AC during CAPWAP tunnel establishment.
·     If a match is found, the AC establishes a CAPWAP tunnel with the AP.
·     If no match is found, the CAPWAP tunnel establishment proceeds as follows:
a.     The AC notifies the AP of software version inconsistency.
b.     After receiving the notification, the AP requests the software version from the AC, upgrades the software, and then establishes a CAPWAP tunnel with the AC.
When this feature is disabled, the AC does not examine the software version of an AP and establishes a CAPWAP tunnel with the AP.
# Enable the software upgrade feature for AP ap3.
[Sysname-wlan-ap-ap3] firmware-upgrade enable
# Enable the software upgrade feature for APs in AP group group1.
[Sysname-wlan-ap-group-group1] firmware-upgrade enable
# Enable the software upgrade feature globally.
[Sysname-wlan-global-configuration] firmware-upgrade enable
wlan apdb
fragment-size
Use fragment-size to set the maximum fragment size for CAPWAP control or data packets.
Use undo fragment-size to remove the configuration.
fragment-size { control control-size | data data-size }
undo fragment-size { control | data }
In AP group view, the maximum fragment size for CAPWAP control packets and data packets is 1450 bytes and 1500 bytes, respectively.
AP view
AP group view
control control-size: Specifies the maximum fragment size for CAPWAP control packets in bytes. The value range for the control-size argument is 1000 to 1450.
data data-size: Specifies the maximum fragment size for CAPWAP data packets in bytes. The value range for the control-size argument is 1000 to 1748.
This command prevents packets between AC and AP from being dropped by intermediate devices if the AP connects to the AC across the Internet.
Any maximum fragment size modification takes effect immediately on online APs.
# Set the maximum fragment size for CAPWAP data packets to 1500 bytes for AP ap1.
[Sysname-ap-ap1] fragment-size data 1500
# Set the maximum fragment size for CAPWAP data packets to 1500 bytes for APs in AP group group1.
[Sysname-wlan-ap-group-group1] fragment-size data 1500
gateway
Use gateway to specify a gateway for an AP.
Use undo gateway to delete the gateway configuration.
gateway { ip ipv4-address | ipv6 ipv6-address }
undo gateway { ip | ipv6 }
No gateway is specified for an AP.
AP provision view
ip ipv4-address: Specifies a gateway by its IPv4 address. Make sure you specify a valid IP address. Invalid IP addresses include loopback IP addresses, direct broadcast addresses, Class D IP addresses, Class E IP addresses, IP address 255.255.255.255, and IP addresses in the 0.X.X.X format.
ipv6 ipv6-address: Specifies a gateway by its IPv6 address.
You can set only one IPv4 address and one IPv6 address.
# Set the gateway IP address to 192.168.100.1 for AP ap1.
[Sysname-wlan-ap-ap1-prvs] gateway ip 192.168.100.1
gigabitethernet
Support for this command depends on the AP model.
Use gigabitethernet to enter the GigabitEthernet interface view of an AP.
gigabitethernet interface-number
AP view
AP group's AP model view
interface-number: Specifies an interface number. The value range varies by AP model.
# Enter the interface view of GigabitEthernet 1 from AP view.
[Sysname-wlan-ap-ap1] gigabitethernet 1
[Sysname-wlan-ap-ap1-gigabitethernet-1]
# Enter the interface view of GigabitEthernet 1 from the AP model view of AP group 1.
[Sysname-wlan-ap-group-group1] ap-model WA4320i-ACN
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN] gigabitethernet 1
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-gigabitethernet-1]
hybrid-remote-ap
Use hybrid-remote-ap enable to enable remote AP.
Use hybrid-remote-ap disable to disable remote AP.
Use undo hybrid-remote-ap to restore the default.
hybrid-remote-ap { disable | enable }
In AP group view, remote AP is disabled.
AP view
AP group view
By default, an AP stops providing services after the tunnel between the AP and the associated AC is disconnected. This command enables the AP to act as a remote AP to still provide services.
This command takes effect only on an AP that operates in local forwarding mode.
The configuration in AP view takes precedence over the configuration in AP group view.
# Enable remote AP for AP ap1.
[Sysname-wlan-ap-ap1] hybrid-remote-ap enable
# Enable remote AP for APs in AP group group1.
[Sysname-wlan-ap-group-group1] hybrid-remote-ap enable
if-match ip
Use if-match ip to create an AP grouping rule by IPv4 addresses.
Use undo if-match ip to delete AP grouping rules by IPv4 addresses.
if-match ip ip-address { mask-length | mask }
undo if-match ip [ ip-address { mask-length | mask } ]
No AP grouping rules by IPv4 addresses exist.
AP group view
ip-address: Specifies an IPv4 address in dotted decimal notation.
mask-length: Specifies the mask length in the range of 1 to 31.
mask: Specifies the mask in dotted decimal notation.
You cannot execute this command in the view of the default AP group.
AP grouping rules by IPv4 addresses for an AP group or for different AP groups cannot overlap with each other.
An AP group supports a maximum of 32 AP grouping rules by IPv4 addresses.
The priorities of AP grouping rules by AP names, serial IDs, MAC addresses, and IP addresses are in descending order. If an AP does not match any grouping rules, it is added to the default AP group.
You can create AP grouping rules by both IPv4 addresses and IPv6 addresses for an AP group.
If you do not specify any argument in the undo form of the command, the command deletes all AP grouping rules by IPv4 addresses.
# Add APs whose IP address belongs to 192.168.0.0/16 to AP group group1.
[Sysname-ap-group-group1] if-match ip 192.168.0.0 16
if-match ipv6
Use if-match ipv6 to create an AP grouping rule by IPv6 addresses.
Use undo if-match ipv6 to delete AP grouping rules by IPv6 addresses.
if-match ipv6 { ipv6-address prefix-length | ipv6-address/prefix-length }
undo if-match ip [ ipv6-address prefix-length | ipv6-address/prefix-length ]
No AP grouping rules by IPv6 addresses exist.
AP group view
ipv6-address: Specifies an IPv6 address.
prefix-length: Specifies the IPv6 address prefix length in the range of 1 to 128.
AP grouping rules by IPv6 addresses for an AP group or for different AP groups cannot overlap with each other.
An AP group supports a maximum of 32 AP grouping rules by IPv6 addresses.
If you do not specify any argument in the undo form of the command, the command deletes all AP grouping rules by IPv6 addresses.
# Add APs whose IPv6 address belongs to 2001:DB0::/28 to AP group group1.
[Sysname-ap-group-group1] if-match ipv6 2001:DB8:: 28
ip address
Use ip address to specify an IPv4 address for the management VLAN interface for an AP.
Use undo ip address to restore the default.
ip address ip-address { mask | mask-length }
undo ip address
No IPv4 address is specified for the management VLAN interface of an AP.
AP provision view
The IP address of the management VLAN interface for an AP must be different from the following IP addresses:
·     IP address of the management VLAN interface of another AP.
·     AC IP address specified in provision view of any APs.
# Set the IP address of the management VLAN interface to 10.1.1.1/24 for AP ap1.
[Sysname-wlan-ap-ap1-prvs] ip address 10.1.1.1 24
ipv6 address
Use ipv6 address to specify an IPv6 address for the management VLAN interface for an AP.
Use undo ipv6 address to restore the default.
undo ipv6 address
No IPv6 address is specified for the management VLAN interface of an AP.
AP provision view
prefix-length: Specifies the prefix length in the range of 1 to 128.
# Set the IPv6 address of the management VLAN interface to 2001::1/64 for AP ap1.
[Sysname-wlan-ap-ap1-prvs] ipv6 address 2001::1/64
keepalive-interval
Use keepalive-interval to set the data tunnel keepalive interval.
Use undo keepalive-interval to restore the default.
keepalive-interval interval
In AP group view, the data tunnel keepalive interval is 10 seconds.
AP view
AP group view
interval: Specifies the interval for an AP to send keepalive packets over the CAPWAP data tunnel. The value range is 1 to 255 seconds.
# Set the data tunnel keepalive interval for AP ap1 to 15 seconds.
[Sysname-wlan-ap-ap1] keepalive-interval 15
# Set the data tunnel keepalive interval for APs in AP group 1 to 15 seconds.
[Sysname] wlan ap-group 1
[Sysname-ap-group-1] keepalive-interval 15
led-mode
Use led-mode to set a LED lighting mode.
Use undo led-mode to restore the default.
led-mode { always-on | awake | normal | quiet }
undo led-mode
In AP group view, the LED lighting mode is normal.
AP view
AP group view
always-on: Specifies the always-on mode. Support for this keyword depends on the AP model.
awake: Specifies the awake mode. Support for this keyword depends on the AP model.
normal: Specifies the normal mode. How LEDs flash in this mode varies by AP model.
quiet: Specifies the quiet mode.
If you set the LED lighting mode to awake or always-on in AP group view, the setting takes effect only on member APs that support the specified LED lighting mode.
# Set the LED lighting mode to normal for AP ap1.
[Sysname-wlan-ap-ap1] led-mode normal
# Set the LED lighting mode to awake for APs in AP group ap1.
[Sysname] wlan ap-group g1
[Sysname-wlan-ap-group-g1] led-mode awake
mac-address (AP group view)
Use mac-address to create an AP grouping rule by MAC addresses.
Use undo mac-address to delete an AP grouping rule by MAC addresses.
mac-address mac-address
undo mac-address mac-address
No AP grouping rules by MAC addresses exist.
AP group view
mac-address: Specifies the MAC address of an AP.
This command does not identify whether the specified AP exists.
You can configure multiple AP grouping rules by MAC addresses.
If the created AP grouping rule already exists in another AP group, this command deletes the rule from that AP group.
# Create an AP grouping rule by MAC addresses for AP group group1.
[Sysname-wlan-ap-group-group1] mac-address 0AC1-F9B2-B1C2
wlan ap-group
mac-address (AP view)
Use mac-address to assign a MAC address to an AP.
Use undo mac-address to restore the default.
undo mac-address
No MAC address is assigned to an AP.
AP view
mac-address: Specifies the MAC address in H-H-H format.
Changing or deleting the MAC address of an AP terminates the CAPWAP tunnel if the AP has established a CAPWAP tunnel with the AC. Then the AP will reestablish a CAPWAP tunnel with the AC.
# Assign the MAC address 0001-0000-0000 to AP ap1.
[Sysname-wlan-ap-ap1] mac-address 0001-0000-0000
name
Use name to assign a name to an AP's VLAN.
Use undo name to restore the default.
name text
undo name
In an AP's VLAN view, a VLAN uses the configuration in an AP group's VLAN view.
In an AP group's VLAN view, the name of a VLAN is VLAN vlan-id. The vlan-id argument specifies the VLAN ID in a four-digit format. If the VLAN ID has less than four digits, leading zeros are added. For example, the name of VLAN 100 is VLAN 0100.
AP's VLAN view
text: Specifies a VLAN name, a case-sensitive string of 1 to 32 characters.
For this command to take effect on an AP, make sure the remote configuration assignment feature is enabled.
The configuration in an AP's VLAN view takes precedence over the configuration in an AP group's VLAN view.
# Assign name test vlan to VLAN 2 of AP ap1.
[Sysname-wlan-ap-ap1] vlan 2
[Sysname-wlan-ap-ap1-vlan2] name test vlan
# Assign name test vlan to VLAN 2 of all APs in AP group 1.
[Sysname-wlan-ap-group-1] vlan 2
[Sysname-wlan-ap-group-1-vlan2] name test vlan
remote-configuration
port-isolate enable
Use port-isolate enable to enable port isolation.
Use port-isolate disable to disable port isolation.
Use undo port-isolate to restore the default.
port-isolate { enable | disable }
undo port-isolate
In an AP's Layer 2 Ethernet interface view, the AP uses the configuration in an AP group's Layer 2 Ethernet interface view.
In an AP group's Layer 2 Ethernet interface view, port isolation is enabled.
In an AP's Layer 2 aggregate interface view, the AP uses the configuration in an AP group's Layer 2 aggregate interface view.
In an AP group's Layer 2 aggregate interface view, port isolation is enabled.
In an AP's 2.5G Ethernet interface view, the AP uses the configuration in an AP group's 2.5G Ethernet interface view.
In an AP group's 2.5G Ethernet interface view, port isolation is enabled.
The configuration in Layer 2 Ethernet interface view or 2.5G Ethernet interface view applies only to the interface.
The configuration in Layer 2 aggregate interface view applies to the Layer 2 aggregate interface and its aggregation member ports. If the device fails to apply the configuration to the aggregate interface, it does not assign any aggregation member port to the isolation group. If the failure occurs on an aggregation member port, the device skips the port and continues to assign other aggregation member ports to the isolation group.
The configuration will be synchronized to all online APs if remote configuration synchronization is activated.
# Enable port isolation for GigabitEthernet 1 of AP ap1.
[Sysname] wlan ap ap1 model WA5620i-ACN
[Sysname-wlan-ap-ap1-gigabitethernet-1] port-isolate enable
# Enable port isolation for GigabitEthernet 1 of APs in AP group 1.
[Sysname-wlan-ap-group-1] ap-model WA5620i-ACN
[Sysname-wlan-ap-group-1-ap-model-WA5620i-ACN] gigabitethernet 1
[Sysname-wlan-ap-group-1-ap-model-WA5620i-ACN-gigabitethernet-1] port-isolate enable
# Enable port isolation for Layer 2 aggregate interface Bridge-Aggregation 1 of AP ap1.
[Sysname-wlan-ap-ap1] bridge-aggregation 1
[Sysname-wlan-ap-ap1-bridge-aggregation-1] port-isolate enable
# Enable port isolation for Layer 2 aggregate interface Bridge-Aggregation 1 of APs in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA5620i-ACN] bridge-aggregation 1
[Sysname-wlan-ap-group-1-ap-model-WA5620i-ACN-bridge-aggregation-1] port-isolate enable
# Enable port isolation for interface 2.5GigabitEthernet 1 of AP ap1.
[Sysname-wlan-ap-ap1] smartrate-ethernet 1
[Sysname-wlan-ap-ap1-smartrate-ethernet-1] port-isolate enable
# Enable port isolation for interface 2.5GigabitEthernet 1 of APs in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA5620i-ACN] smartrate-ethernet 1
[Sysname-wlan-ap-group-1-ap-model-WA5620i-ACN-smartrate-ethernet-1] port-isolate enable
remote-configuration synchronize
port access vlan
Use port access vlan to assign an access port on an AP to the specified VLAN.
Use undo port access vlan to restore the default.
port access vlan vlan-id
In an AP's Layer 2 Ethernet interface view, an access port uses the configuration in an AP group's Layer 2 Ethernet interface view.
In an AP group's Layer 2 Ethernet interface view, all access ports on an AP belong to VLAN 1.
In an AP's 2.5G Ethernet interface view, an access port uses the configuration in an AP group's 2.5G Ethernet interface view.
In an AP group's 2.5G Ethernet interface view, all access ports on an AP belong to VLAN 1.
vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
Before assigning an access port to a VLAN, make sure the VLAN has been created.
The configuration in an AP's Layer 2 Ethernet interface view takes precedence over the configuration in an AP group's Layer 2 Ethernet interface view.
# Assign GigabitEthernet 1 to VLAN 3 in the Layer 2 Ethernet interface view of AP ap1.
[Sysname-wlan-ap-ap1-gigabitethernet-1] port access vlan 3
# Assign GigabitEthernet 1 to VLAN 3 in the Layer 2 Ethernet interface view of APs with model WA4320i-ACN in AP group 1.
[Sysname-wlan-ap-group-1] ap-model WA4320i-ACN
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN] gigabitethernet 1
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-gigabitethernet-1] port access vlan 3
# Assign interface 2.5GigabitEthernet 1 to VLAN 3 in 2.5G Ethernet interface view of AP ap1.
[Sysname-wlan-ap-ap1-smartrate-ethernet-1] port access vlan 3
# Assign interface 2.5GigabitEthernet 1 to VLAN 3 in 2.5G Ethernet interface view of APs with model WA4320i-ACN in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN] smartrate-ethernet 1
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-smartrate-ethernet-1] port access vlan 3
port hybrid pvid
Use port hybrid pvid to set the PVID of a hybrid port on an AP.
Use undo port hybrid pvid to set the PVID of a hybrid port on an AP to 1.
port hybrid pvid vlan vlan-id
In an AP's Layer 2 Ethernet interface view, a hybrid port uses the configuration in an AP group's Layer 2 Ethernet interface view.
In an AP group's Layer 2 Ethernet interface view, the PVID of a hybrid port is the ID of the VLAN to which the port belongs when its link type is access.
In an AP's 2.5G Ethernet interface view, a hybrid port uses the configuration in an AP group's 2.5G Ethernet interface view.
In an AP group's 2.5G Ethernet interface view, the PVID of a hybrid port is the ID of the VLAN to which the port belongs when its link type is access.
You can use a nonexistent VLAN as the PVID of a hybrid port. When you delete the PVID of a hybrid port by using the undo vlan command, the PVID setting of the port does not change.
For correct packet transmission, set the same PVID for a hybrid port on an AP and the hybrid port on the switch connected to the AP.
To enable a hybrid port to transmit packets from its PVID, you must assign the hybrid port to the PVID by using the port hybrid vlan command.
# Configure GigabitEthernet 1 as a hybrid port, and set its PVID to VLAN 100 in Layer 2 Ethernet interface view of AP ap1.
[Sysname-wlan-ap-ap1-gigabitethernet-1] port link-type hybrid
[Sysname-wlan-ap-ap1-gigabitethernet-1] port hybrid pvid vlan 100
# Configure GigabitEthernet 1 as a hybrid port, and set its PVID to VLAN 100 in Layer 2 Ethernet interface view of APs with model WA4320i-ACN in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-gigabitethernet-1] port link-type hybrid
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-gigabitethernet-1] port hybrid pvid vlan 100
# Configure interface 2.5GigabitEthernet 1 as a hybrid port, and set its PVID to 100 in 2.5G Ethernet interface view of AP ap1.
[Sysname-wlan-ap-ap1-smartrate-ethernet-1] port link-type hybrid
[Sysname-wlan-ap-ap1-smartrate-ethernet-1] port hybrid pvid vlan 100
# Configure interface 2.5GigabitEthernet 1 as a hybrid port, and set its PVID to 100 in 2.5G Ethernet interface view of APs with model WA4320i-ACN in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-smartrate-ethernet-1] port link-type hybrid
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-smartrate-ethernet-1] port hybrid pvid vlan 100
port hybrid vlan
port link-type
port hybrid vlan
Use port hybrid vlan to assign a hybrid port to the specified VLANs.
Use undo port hybrid vlan to remove a hybrid port from the specified VLANs
undo port hybrid vlan vlan-id-list
In an AP group's Layer 2 Ethernet interface view, a hybrid port is an untagged member of the VLAN to which the port belongs when its link type is access.
In an AP group's 2.5G Ethernet interface view, a hybrid port does not allow packets from any VLAN to pass through.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument cannot be lower than the value for the vlan-id1 argument. The specified VLANs must already exist on the device.
tagged: Configures the port as a tagged member of the specified VLANs. A tagged member of a VLAN sends packets from the VLAN without removing VLAN tags.
untagged: Configures the port as an untagged member of the specified VLANs. An untagged member of a VLAN sends packets from the VLAN after removing VLAN tags.
A hybrid port can allow multiple VLANs. If you execute this command multiple times on a hybrid port, the hybrid port allows all the specified VLANs.
# In Layer 2 Ethernet interface view of AP ap1, perform the following tasks:
1.     Configure GigabitEthernet 1 as a hybrid port.
2.     Assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100 as a tagged member.
[Sysname-wlan-ap-ap1-gigabitethernet-1] port hybrid vlan 2 4 50 to 100 tagged
# In Layer 2 Ethernet interface view of APs with model WA4320i-ACN in AP group 1, perform the following tasks:
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-gigabitethernet-1] port hybrid vlan 2 4 50 to 100 tagged
# Configure interface 2.5GigabitEthernet 1 as a hybrid port, and assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100 as a tagged member in 2.5G Ethernet interface view of AP ap1.
[Sysname-wlan-ap-ap1-smartrate-ethernet-1] port hybrid vlan 2 4 50 to 100 tagged
# Configure interface 2.5GigabitEthernet 1 as a hybrid port, and assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100 as a tagged member in 2.5G Ethernet interface view of APs with model WA4320i-ACN in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-smartrate-ethernet-1] port hybrid vlan 2 4 50 to 100 tagged
port link-type
port link-aggregation group
Use port link-aggregation group to assign an interface to an aggregation group.
Use undo port link-aggregation group to remove an interface from the aggregation group to which it belongs.
In an AP group's Layer 2 Ethernet interface view, an interface does not belong to an aggregation group.
In an AP group's 2.5G Ethernet interface view, an interface does not belong to an aggregation group.
group-id: Specifies an aggregation group by its aggregate interface number. The value range for the argument varies by AP model.
A Layer 2 Ethernet interface can be assigned only to a Layer 2 aggregation group and an Ethernet interface can belong to only one aggregation group.
After joining an aggregation group, an interface inherits the settings configured for the group.
Before you execute this command, make sure the specified aggregation group already exists and the AP supports Layer 2 aggregate interfaces.
# Assign interface GigabitEthernet 1 of AP ap1 to Layer 2 aggregation group 1.
[Sysname-wlan-ap-ap1-gigabitethernet-1] port link-aggregation group 1
# Assign interface GigabitEthernet 1 of APs in AP group 1 to Layer 2 aggregation group 1.
[Sysname-wlan-ap-group-1-ap-model-WA5620i-ACN-gigabitethernet-1] port link-aggregation group 1
# Assign interface 2.5GigabitEthernet 1 of AP ap1 to Layer 2 aggregation group 1.
[Sysname-wlan-ap-ap1-smartrate-ethernet-1] port link-aggregation group 1
# Assign interface 2.5GigabitEthernet 1 of APs in AP group 1 to Layer 2 aggregation group 1.
[Sysname-wlan-ap-group-1-ap-model-WA5620i-ACN-smartrate-ethernet-1] port link-aggregation group 1
port link-type
Use port link-type to set the link type of an Ethernet port on an AP.
Use undo port link-type to restore the default.
undo port link-type
In an AP's Layer 2 Ethernet interface view, an Ethernet port uses the configuration in an AP group's Layer 2 Ethernet interface view.
In an AP group's Layer 2 Ethernet interface view, each Ethernet port is an access port.
In an AP's 2.5G Ethernet interface view, a port uses the configuration in an AP group's 2.5G Ethernet interface view.
In an AP group's 2.5G Ethernet interface view, all ports are access ports.
access: Sets the port link type to access.
hybrid: Sets the port link type to hybrid.
trunk: Sets the port link type to trunk.
To change the link type of an Ethernet port from trunk to hybrid or vice versa, first set the link type to access.
# Configure GigabitEthernet 1 as a trunk port in Layer 2 Ethernet interface view of AP ap1.
[Sysname-wlan-ap-ap1-gigabitethernet-1] port link-type trunk
# Configure GigabitEthernet 1 as a trunk port in Layer 2 Ethernet interface view of APs with model WA4320i-ACN in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-gigabitethernet-1] port link-type trunk
# Configure interface 2.5GigabitEthernet 1 as a trunk port in 2.5G Ethernet interface view of AP ap1.
[Sysname-wlan-ap-ap1-smartrate-ethernet-1] port link-type trunk
# Configure interface 2.5GigabitEthernet 1 as a trunk port in 2.5G Ethernet interface view of APs with model WA4320i-ACN in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-smartrate-ethernet-1] port link-type trunk
port trunk permit vlan
Use port trunk permit vlan to assign a trunk port to the specified VLANs.
Use undo port trunk permit vlan to remove a trunk port from the specified VLANs.
undo port trunk permit vlan { vlan-id-list | all }
In an AP's Layer 2 Ethernet interface view, a trunk port uses the configuration in an AP group's Layer 2 Ethernet interface view.
In an AP group's Layer 2 Ethernet interface view, a trunk port allows packets only from VLAN 1 to pass through.
In an AP's 2.5G Ethernet interface view, a trunk port uses the configuration in an AP group's 2.5G Ethernet interface view.
In an AP group's 2.5G Ethernet interface view, a trunk port does not allow packets from any VLAN to pass through.
all: Specifies all VLANs.
A trunk port can allow multiple VLANs. If you execute this command multiple times on a trunk port, the trunk port allows all the specified VLANs.
On a trunk port, packets only from the PVID can pass through untagged.
To prevent unauthorized VLAN users from accessing restricted resources through the port, use the port trunk permit vlan all command with caution.
# Configure GigabitEthernet 1 as a trunk port, and assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100 in Layer 2 Ethernet interface view of AP ap1.
[Sysname-wlan-ap-ap1-gigabitethernet-1] port trunk permit vlan 2 4 50 to 100
# Configure GigabitEthernet 1 as a trunk port, and assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100 in Layer 2 Ethernet interface view of APs with model WA4320i-ACN in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-gigabitethernet-1] port trunk permit vlan 2 4 50 to 100
# Configure interface 2.5GigabitEthernet 1 as a trunk port, and assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100 in 2.5G Ethernet interface view of AP ap1.
[Sysname-wlan-ap-ap1-smartrate-ethernet-1] port trunk permit vlan 2 4 50 to 100
# Configure interface 2.5GigabitEthernet 1 as a trunk port, and assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100 in 2.5G Ethernet interface view of APs with model WA4320i-ACN in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-smartrate-ethernet-1] port trunk permit vlan 2 4 50 to 100
port link-type
port trunk pvid
Use port trunk pvid to set the PVID for a trunk port on an AP.
Use undo port trunk pvid to restore the default.
port trunk pvid vlan vlan-id
In an AP group's Layer 2 Ethernet interface view, the PVID of a trunk port is VLAN 1.
In an AP group's 2.5G Ethernet interface view, the PVID of a trunk port is 1.
You can use a nonexistent VLAN as the PVID for a trunk port. When you delete the PVID of a trunk port by using the undo vlan command, the PVID setting of the port does not change.
To enable a trunk port to transmit packets from its PVID, you must assign the trunk port to the PVID by using the port trunk permit vlan command.
# In Layer 2 Ethernet interface view of AP ap1, configure GigabitEthernet 1 as a trunk port, set its PVID to VLAN 100, and assign it to VLAN 100.
[Sysname-wlan-ap-ap1-gigabitethernet-1] port trunk pvid vlan 100
[Sysname-wlan-ap-ap1-gigabitethernet-1] port trunk permit vlan 100
# In an AP group's Layer 2 Ethernet interface view, configure GigabitEthernet 1 as a trunk port, set its PVID to VLAN 100, and assign it to VLAN 100.
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-gigabitethernet-1] port trunk pvid vlan 100
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-gigabitethernet-1] port trunk permit vlan 100
# In 2.5G Ethernet interface view of AP ap1, configure interface 2.5GigabitEthernet 1 as a trunk port, set its PVID to 100, and assign it to VLAN 100.
[Sysname-wlan-ap-ap1-smartrate-ethernet-1] port trunk pvid vlan 100
[Sysname-wlan-ap-ap1-smartrate-ethernet-1] port trunk permit vlan 100
# In an AP group's 2.5G Ethernet interface view, configure interface 2.5GigabitEthernet 1 as a trunk port, set its PVID to 100, and assign it to VLAN 100.
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-smartrate-ethernet-1] port trunk pvid vlan 100
[Sysname-wlan-ap-group-1-ap-model-WA4320i-ACN-smartrate-ethernet-1] port trunk permit vlan 100
port link-type
power-level default
Use power-level default to set the default input power level for an AP in case the AP cannot obtain its input power level.
Use undo power-level default to restore the default.
power-level default { high | low | middle }
In AP view, an AP uses the configuration in an AP group's AP model view.
In an AP group's AP model view, the default input power level of an AP is middle.
AP view
high: Specifies the high default input power level.
low: Specifies the low default input power level.
middle: Specifies the middle default input power level.
Configure this command for an AP in case the AP cannot obtain its input power level at startup.
The power level of an AP can be high, middle, or low. An AP automatically performs power supply mode detection to obtain its input power level at startup. If the AP fails to obtain the input power level, it operates at the low input power level before associating with an AC. After the association, it operates at the configured default input power level.
The following table shows the relationship between the AP's power supply mode and input power level:
Power supply mode
Input power level
·     Power adapter.
·     Multiple PoE+ ports.
·     Combination of PoE and PoE+ ports.
High
·     Single PoE+ port
·     Multiple PoE ports
Middle
Single PoE port
Low
An AP's support for MIMO modes and USB interfaces varies by power level, as shown in Table 25.
Table 25 AP's support for MIMO modes and USB interfaces
Input power level
MIMO modes
Whether USB interfaces can be enabled
High
1×1, 2×2, 3×3, and 4×4.
Yes.
Middle
Yes when the MIMO mode is 1×1 or 2×2.
Low
1×1.
No.
The configuration in AP view takes precedence over the configuration in AP group' AP model view.
# Set the default input power level to high for AP ap1 in AP view.
[Sysname-wlan-ap-ap1] power-level default high
# Set the default input power level to high in AP model view of AP group g1.
[Sysname-wlan-ap-group-g1] ap-model WA5620i-ACN
[Sysname-wlan-ap-group-g1-ap-model-WA5620i-ACN] power-level default high
priority
Use priority to set the AP connection priority for the AC.
Use undo priority to restore the default.
priority priority
undo priority
In AP group view, the AP connection priority for the AC is 4.
AP view
AP group view
priority: Specifies the AP connection priority for the AC, in the range of 0 to 7. A larger value represents a higher connection priority.
The AP prefers to establish a CAPWAP tunnel with an AC that has higher connection priority.
The AP connection priority only takes effect during AC discovery.
# Set the AP connection priority for the AC to 7 for AP ap3.
[Sysname-wlan-ap-ap3] priority 7
# Set the AP connection priority for the AC to 7 for AP group group1.
[Sysname-wlan-ap-group-group1] priority 7
provision
Use provision to enable AP preprovisioning and enter AP provision view, or enter AP provision view. if AP preprovisioning is already enabled.
Use undo provision to disable AP preprovisioning.
provision
undo provision
In AP view, an AP uses the configuration in AP group view. If no configuration exists in AP group view, the AP uses the configuration in global configuration view.
In AP group view, an AP uses the configuration in global configuration view.
In global configuration view, AP preprovisioning is disabled.
AP view
AP group view
Global configuration view
AP preprovisioning allows you to configure network settings for APs on the AC. The AC automatically assigns these settings to the APs.
If you disable AP preprovisioning, network settings configured on the AC will be deleted. However, the operation does not affect the network settings already assigned to the APs.
The priorities of configurations in AP view, AP group view, and global configuration view are in descending order.
# Enable AP preprovisioning and enter AP provision view of AP ap1.
# Enable AP preprovisioning and enter AP provision view of AP group group1.
[Sysname-wlan-ap-group-group1-prvs]
# Enable AP preprovisioning globally and enter global provision view.
provision auto-recovery
Use provision auto-recovery enable to enable auto loading of preprovisioned settings.
Use provision auto-recovery disable to disable auto loading of preprovisioned settings.
Use undo provision auto-recovery to restore the default.
provision auto-recovery { disable | enable }
In AP group view, auto loading of preprovisioned settings is enabled.
AP view
AP group view
Auto loading of preprovisioned settings ensures successful CAPWAP tunnel establishment between AP and AC. An AP uses the following procedure to discover an AC when you enable this feature:
1.     Uses the preprovisioned settings to discover an AC that has the AP's manual or auto AP configuration.
2.     Reboots and uses other methods to discover ACs if AC discovery fails.
3.     Reboots and uses the preprovisioned settings again to discover ACs if the AP still fails to discover the target AC.
This AC discovery process will be repeated until the AP discovers the target AC to establish a CAPWAP tunnel.
# Disable auto loading of preprovisioned settings for AP ap1.
[Sysname-ap-ap1] provision auto-recovery disable
# Disable auto loading of preprovisioned settings for APs in AP group group1.
[Sysname-wlan-ap-group-group1] provision auto-recovery disable
provision auto-update
Use provision auto-update enable to enable auto assignment of preprovisioned settings.
Use provision auto-update disable to disable auto assignment of preprovisioned settings.
Use undo provision auto-update to restore the default.
provision auto-update { disable | enable }
In AP group view, auto assignment of preprovisioned settings is disabled.
AP view
AP group view
This command enables the AC to automatically assign preprovisioned settings to an AP so that the AP can use the preprovisioned settings to come online.
This command applies only to offline APs. To deploy preprovisioned settings to online APs, use the save wlan ap provision command.
The configuration in AP provision view has higher priority than the configuration in AP group provision view.
# Enable auto assignment of preprovisioned settings for AP ap1.
[Sysname-ap-ap1] provision auto-update enable
# Enable auto assignment of preprovisioned settings for APs in AP group group1.
[Sysname-wlan-ap-group-group1] provision auto-update enable
qos priority
Use qos priority to set the port priority.
Use undo qos priority to restore the default.
qos priority priority-value
undo qos priority
In an AP's GigabitEthernet interface view, the AP uses the configuration in AP group view.
In an AP group's GigabitEthernet interface view, the port priority is 0.
In an AP's Layer 2 aggregate interface view, the AP uses the configuration in AP group view.
In an AP group's Layer 2 aggregate interface view, the port priority is 0.
In an AP's 2.5G Ethernet interface view, the AP uses the configuration in AP group's 2.5G Ethernet interface view.
In an AP group's 2.5G Ethernet interface view, the port priority is 0.
priority-value: Specifies the port priority in the range of 0 to 7.
The configuration will be synchronized to all online APs only if remote configuration synchronization is activated. You can activate remote configuration synchronization by using the remote-configuration synchronize command.
# Set the port priority to 2 in an AP's GigabitEthernet interface view.
[Sysname-wlan-ap-ap1-gigabitethernet-1] qos priority 2
# Set the port priority to 2 in an AP group's GigabitEthernet interface view.
[Sysname-wlan-ap-group-1-ap-model-WA5620i-ACN-gigabitethernet-1] qos priority 2
# Set the port priority to 2 in an AP's Layer 2 aggregate interface view.
[Sysname-wlan-ap-ap1] interface bridge-aggregation 1 [Sysname-wlan-ap-ap1-Bridge-Aggregation1] qos priority 2
# Set the port priority to 2 in an AP group's Layer 2 aggregate interface view.
[Sysname-wlan-ap-group-1-ap-model-WA5620i-ACN] interface bridge-aggregation 1
[Sysname-wlan-ap-group-1-ap-model-WA5620i-ACN-Bridge-Aggregation1] qos priority 2
# Set the port priority to 2 in an AP's 2.5G Ethernet interface view.
[Sysname-wlan-ap-ap1-smartrate-ethernet-1] qos priority 2
# Set the port priority to 2 in an AP group's 2.5G Ethernet interface view.
[Sysname-wlan-ap-group-1-ap-model-WA5620i-ACN-smartrate-ethernet-1] qos priority 2
remote-configuration enable
qos trust
Use qos trust to set the trusted packet priority type.
Use undo qos trust to restore the default.
qos trust { dot1p | dscp }
undo qos trust
In an AP group's GigabitEthernet interface view, no trusted packet priority type is set.
In an AP group's Layer 2 aggregate interface view, no trusted packet priority type is set.
In an AP group's 2.5G Ethernet interface view, no trusted packet priority type is set.
dot1p: Uses the 802.1e priority carried in packets for priority mapping.
dscp: Uses the DSCP priority carried in packets for priority mapping.
# Set the trusted packet priority type to dot1p in an AP's GigabitEthernet interface view.
[Sysname-wlan-ap-ap1-gigabitethernet-1] qos trust dot1p
# Set the trusted packet priority type to dot1p in an AP group's GigabitEthernet interface view.
[Sysname-wlan-ap-group-1-ap-model-WA5620i-ACN-gigabitethernet-1] qos trust dot1p
# Set the trusted packet priority type to dot1p in an AP's Layer 2 aggregate interface view.
[Sysname-wlan-ap-ap1] interface bridge-aggregation 1 [Sysname-wlan-ap-ap1-Bridge-Aggregation1] qos trust dot1p
# Set the trusted packet priority type to dot1p in an AP group's Layer 2 aggregate interface view.
[Sysname-wlan-ap-group-1-ap-model-WA5620i-ACN-Bridge-Aggregation1] qos trust dot1p
# Set the trusted packet priority type to dot1p in an AP's 2.5G Ethernet interface view.
[Sysname-wlan-ap-ap1-smartrate-ethernet-1] qos trust dot1p
# Set the trusted packet priority type to dot1p in an AP group's 2.5G Ethernet interface view.
[Sysname-wlan-ap-group-1-ap-model-WA5620i-ACN-smartrate-ethernet-1] qos trust dot1p
Use remote-configuration enable to enable the remote configuration assignment feature.
Use remote-configuration disable to disable the remote configuration assignment feature.
Use undo remote-configuration to restore the default.
remote-configuration { disable | enable }
undo remote-configuration enable
In AP group view, remote configuration assignment is disabled.
AP view
AP group view
The AC will assign related VLAN settings to APs only when the remote configuration assignment feature is enabled.
# Enable the remote configuration assignment feature for AP ap1.
[Sysname-wlan-ap-ap1] remote-configuration enable
# Enable the remote configuration assignment feature for AP group group1.
[Sysname-wlan-ap-group-group1] remote-configuration enable
Use remote-configuration synchronize to activate remote configuration synchronization.
In AP group view, remote configuration synchronization is not activated.
AP view
AP group view
CAUTION
CAUTION:
This command clears all VLAN, link aggregation, and port settings (except for port isolation settings) on online APs and issues the settings on the AC to the APs. Please use it with caution.
To update APs' configuration file or configure features that require a configuration file, you can use the map-configuration command to deploy a configuration file to APs. However, you must write related commands to the configuration file before deployment. This is time-consuming and is not applicable to a network with a large number of APs to deploy.
This feature enables the AC to directly synchronize AP settings such as VLAN, link aggregation, and port isolation changes to online APs.
Make sure remote configuration assignment is enabled before you execute this command.
As a best practice, do not execute both this command and the map-configuration command on the AC. If you must use both of them on the AC, make sure the VLAN, link aggregation, and port isolation settings in the configuration file to be deployed do not conflict with the settings on the AC.
# Activate remote configuration synchronization for AP ap1.
[Sysname-wlan-ap-ap1] remote-configuration synchronize
# Activate remote configuration synchronization for APs in AP group group1.
[Sysname-wlan-ap-group-group1] remote-configuration synchronize
report-interval
Use report-interval to set the interval at which APs in an AP monitor group report statistics to the AC.
Use undo report-interval to restore the default.
report-interval interval
APs in an AP monitor group report statistics to the AC at intervals of 50 seconds.
Monitor group view
interval: Specifies the interval at which APs in an AP monitor group report statistics to the AC, in the range of 10 to 120 seconds.
# Set the interval to 30 seconds for APs in an AP monitor group to report statistics to the AC.
[Sysname] wlan vip-ap-group
[Sysname-wlan-vip-ap-group] report-interval 30
ap-name
wlan vip-ap-group
reset wlan ap
Use reset wlan ap to reset all APs or the specified APs.
reset wlan ap { all | ap-group group-name | model model-name | name ap-name | native }
all: Specifies all APs connected to the AC.
ap-group group-name: Specifies an AP group by its name, a case-sensitive string of 1 to 31 characters.
model model-name: Specifies an AP model by model name.
name ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
native: Specifies all APs that have established CAPWAP tunnels with the AC.
This command terminates the CAPWAP tunnel between an AP and the AC and deletes all connection information about the AP.
# Reset the AP ap1.
<Sysname> reset wlan ap name ap1
Resetting the APs will terminate the CAPWAP tunnels with the AC. Continue? [Y/N]:
reset wlan ap connection-record
Use reset wlan ap connection-record to clear AP connection records on the AC.
reset wlan ap { all | name ap-name } connection-record
all: Specifies all APs.
# Clear all the AP connection records on the AC.
<Sysname> reset wlan ap all connection-record
reset wlan ap provision
Use reset wlan ap provision to delete configuration file wlan_ap_prvs.xml from all APs or the specified AP.
reset wlan ap provision { all | name ap-name }
This command takes effect only on APs that have established CAPWAP tunnels with the master AC and are in Run state.
For this command to take effect on an AP, restart the AP.
# Delete configuration file wlan_ap_prvs.xml from AP ap1.
<Sysname> reset wlan ap provision name ap1
reset wlan ap reboot-log
Use reset wlan ap reboot-log to clear the reboot logs of all APs or the specified AP.
reset wlan ap reboot-log { all | name ap-name }
# Clear the reboot logs of AP ap1.
<Sysname> reset wlan ap reboot-log name ap1
display wlan ap reboot-log
reset wlan ap unauthenticated
Use reset wlan ap unauthenticated to restart unauthenticated auto APs for re-authentication.
# Restart unauthenticated auto APs.
<Sysname> reset wlan ap unauthenticated
reset wlan tunnel latency ap
Use reset wlan tunnel latency ap to clear tunnel latency information for all APs or the specified AP.
reset wlan tunnel latency ap { all | name ap-name }
This command takes effect only on APs that have established tunnels with the master AC and are in Run state.
# Clear tunnel latency information for AP ap1.
<Sysname> reset wlan tunnel latency ap name ap1
display wlan ap tunnel latency
tunnel latency-detect
retransmit-count
Use retransmit-count to set the maximum number of AC request retransmission attempts.
Use undo retransmit-count to restore the default.
retransmit-count value
In AP group view, the maximum number of AC request retransmission attempts is 3.
AP view
AP group view
value: Specifies the maximum number of AC request retransmission attempts, in the range of 2 to 5.
The AC sends a request to an AP at the retransmission interval until the maximum number of request retransmission attempts is reached or a response is received.
Requests sent by the AC to an AP include the following types:
·     Image Data Request.
·     Configuration Update Request.
·     Reset Request.
·     Data Transfer Request.
·     IEEE 802.11 WLAN Configuration Request.
·     Station Configuration Request.
# Set the maximum number of AC request retransmission attempts to 4 for AP ap3.
[Sysname-wlan-ap-ap3] retransmit-count 4
# Set the maximum number of AC request retransmission attempts to 4 for APs in AP group group1.
[Sysname-wlan-ap-group-group1] retransmit-count 4
retransmit-interval
retransmit-interval
Use retransmit-interval to set the request retransmission interval for the AC to retransmit requests to an AP.
Use undo retransmit-interval to restore the default.
retransmit-interval interval
In AP group view, the request retransmission interval is 5 seconds.
AP view
AP group view
interval: Specifies the request retransmission interval in the range of 3 to 8 seconds.
·     Reset Request.
# Set the request retransmission interval to 6 seconds for the AC to send requests to AP ap3.
[Sysname-wlan-ap-ap3] retransmit-interval 6
# Set the request retransmission interval to 6 seconds for the AC to send requests to APs in AP group group1.
[Sysname-wlan-ap-group-group1] retransmit-interval 6
retransmit-count
Use save wlan ap provision to deploy the provision configuration to all APs or the specified AP.
save wlan ap provision { all | name ap-name }
This command saves the added or modified preprovisioned settings to the wlan_ap_prvs.xml configuration file.
This command takes effect only on online APs that have established tunnels with the master AC.
This command has the same effect as the reset wlan ap provision command if no AP preprovisioned settings exist.
Preprovisioned settings configured in provision view take effect immediately when you execute the save wlan ap provision command.
Cancellations of preprovisioned settings in provision view do not take effect when you execute the save wlan ap provision command. For the cancellations to take effect on an AP, restart the AP.
# Save the configuration in AP provision view to configuration file wlan_ap_prvs.xml on AP ap1.
[Sysname-wlan-ap-ap1-prvs] ac ip 192.168.0.1
[Sysname-wlan-ap-ap1-prvs] save wlan ap provision name ap1
serial-id (AP group view)
Use serial-id to create an AP grouping rule by serial IDs.
Use undo serial-id to delete an AP grouping rule by serial IDs.
serial-id serial-id
undo serial-id serial-id
No AP grouping rules by serial IDs exist.
AP group view
serial-id: Specifies an AP serial ID, a case-insensitive string of 1 to 63 characters.
You can configure multiple AP grouping rules by serial IDs.
# Create an AP grouping rule by serial IDs for AP group group1.
[Sysname-wlan-ap-group-group1] serial-id 210235A1BSC123000037
wlan ap-group
serial-id (AP view)
Use serial-id to specify the serial ID for an AP.
Use undo serial-id to restore the default.
serial-id serial-id
undo serial-id
No serial ID is specified for an AP.
AP view
serial-id: Specifies the serial ID for an AP, a case-insensitive string of 1 to 63 characters.
Changing or deleting the serial ID of an AP terminates the CAPWAP tunnel if the AP has established a CAPWAP tunnel with an AC. Then the AP will reestablish a CAPWAP tunnel with the AC.
# Set the serial ID of AP ap1 to 210235A1BSC123000050.
[Sysname-ap-ap1] serial-id 210235A1BSC123000050
smartrate-ethernet
Use smartrate-ethernet to enter 2.5 GigabitEthernet interface view of an AP.
smartrate-ethernet interface-number
AP view
# Enter the interface view of Smartrate-Ethernet 1 from AP view.
# Enter the interface view of Smartrate-Ethernet 1 from the AP model view of AP group group1.
[Sysname-wlan-ap-group-group1] ap-model WA5620i-ACN
[Sysname-wlan-ap-group-group1-ap-model-WA5620i-ACN] smartrate-ethernet 1
[Sysname-wlan-ap-group-group1-ap-model-WA5620i-ACN-smartrate-ethernet-1]
snmp-agent trap enable wlan ap
Use snmp-agent trap enable wlan ap to enable SNMP notifications for AP management.
Use undo snmp-agent trap enable wlan ap to disable SNMP notifications for AP management.
SNMP notifications are disabled for AP management.
To report critical AP management events to an NMS, enable SNMP notifications for AP management. For AP management event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for AP management.
[Sysname] snmp-agent trap enable wlan ap
snmp-agent trap enable wlan capwap
Use snmp-agent trap enable wlan capwap to enable SNMP notifications for CAPWAP.
Use undo snmp-agent trap enable wlan capwap to disable SNMP notifications for CAPWAP.
SNMP notifications are disabled for CAPWAP.
To report critical CAPWAP events to an NMS, enable SNMP notifications for CAPWAP. For CAPWAP event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for CAPWAP.
[Sysname] snmp-agent trap enable wlan capwap
statistics-interval
Use statistics-interval to set the statistics report interval for an AP to send statistics reports to the AC.
Use undo statistics-interval to restore the default.
statistics-interval interval
In global configuration view, the statistics report interval is 50 seconds.
AP view
AP group view
interval: Specifies the statistics report interval in the range of 0 to 240 seconds.
Execute this command to change the interval for an AP to report its statistics. You can use these statistics to monitor the operating status of radios on the AP.
To disable an AP from reporting radio statistics to the AC, set the statistics report interval to 0.
# Set the statistics reports interval to 10 seconds for AP ap1.
[Sysname-wlan-ap-ap1] statistics-interval 10
# Set the statistics reports interval to 10 seconds for APs in AP group group1.
[Sysname-wlan-ap-group-group1] statistics-interval 10
# Set the statistics reports interval to 10 seconds globally.
[Sysname-wlan-global-configuration] statistics-interval 10
statistics-interval fast-report
Use statistics-interval fast-report to set the interval at which an AP fast reports specific statistics to the AC.
Use undo statistics-interval fast-report to restore the default.
statistics-interval fast-report fast-report-interval
In AP group view, the fast report interval is 0 seconds. An AP does not fast report statistics to the AC.
AP view
AP group view
fast-report-interval: Specifies the fast report interval in the range of 0 to 120 seconds.
Setting the interval to 0 disables an AP from fast reporting statistics to the AC.
APs can fast report only channel usage statistics to the AC.
# Set the fast report interval to 10 seconds for AP ap1.
[Sysname-wlan-ap-ap1] statistics-interval fast-report 10
# Set the fast report interval to 10 seconds for APs in AP group group1.
[Sysname-wlan-ap-group-group1] statistics-interval fast-report 10
statistics-interval
tunnel encryption
Use tunnel encryption enable to enable CAPWAP control tunnel encryption.
Use tunnel encryption disable to disable CAPWAP control tunnel encryption.
Use undo tunnel encryption enable to restore the default.
tunnel encryption { disable | enable }
In AP group view, CAPWAP control tunnel encryption is disabled.
AP view
AP group view
This feature will cause an AP to reassociate with the AC.
With this feature enabled, an AP performs a DTLS handshake and establishes a CAPWAP tunnel with the AC after receiving a discovery response with the encryption flag from the AC. Then, the AC and the AP encrypt control packets transmitted in the CAPWAP control tunnel after the DTLS handshake.
# Enable CAPWAP control tunnel encryption for AP ap1.
[Sysname] wlan ap ap1 model WA4320i-ACN
[Sysname-wlan-ap-ap1] tunnel encryption enable
This operation will reconnect the AP. Continue? [Y/N]
# Enable CAPWAP control tunnel encryption for APs in AP group group1.
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] tunnel encryption enable
This operation will reconnect member APs that are not enabled with CAPWAP control tunnel encryption. Continue? [Y/N]
Use tunnel latency-detect to configure CAPWAP tunnel latency detection.
tunnel latency-detect { start | stop }
CAPWAP tunnel latency detection is not started.
AP view
start: Starts CAPWAP tunnel latency detection.
stop: Stops CAPWAP tunnel latency detection.
CAPWAP tunnel latency detection enables the AC to detect the transmission latency of CAPWAP control frames or data frames from an AP to the AC and back.
When an AP goes offline, CAPWAP tunnel latency detection automatically stops. To restart CAPWAP tunnel latency detection when the AP comes online again, execute the tunnel latency-detect start command again.
The tunnel latency-detect start command takes effect only on APs that have established CAPWAP tunnels with the master AC and are in Run state.
# Start CAPWAP tunnel latency detection for AP ap1.
[Sysname-wlan-ap-ap1] tunnel latency-detect start
usb
Use usb enable to enable USB interfaces on APs.
Use usb disable to disable USB interfaces on APs.
Use undo usb to restore the default.
usb { disable | enable }
undo usb
In an AP group's AP model view, USB interfaces are disabled.
AP view
This command takes effect on an AP only when either of the following requirements is met:
·     The power level of the AP is high.
·     The power level of the AP is middle and the MIMO mode is 1×1 or 2×2.
For information about power levels, see "power-level default." For information about MIMO modes, see radio management in WLAN Configuration Guide.
# Enable USB interfaces in AP view.
[Sysname-wlan-ap-ap1] usb enable
# Enable USB interfaces in AP model view of AP group g1.
[Sysname-wlan-ap-group-g1-ap-model-WA5620i-ACN] usb enable
power-level default
vlan
Use vlan vlan-id to create a VLAN for an AP and enter the VLAN view of the AP, or enter the view of an existing VLAN of an AP.
Use vlan vlan-id1 to vlan-id2 to create VLANs vlan-id1 through vlan-id2 for an AP, except for reserved VLANs.
Use vlan all to create VLANs 1 through 4094 for an AP.
Use undo vlan to delete the specified VLANs of an AP.
vlan { vlan-id1 [ to vlan-id2 ] | all }
undo vlan { vlan-id1 [ to vlan-id2 ] | all }
In AP group view, VLAN 1 (the default VLAN) exists on an AP.
AP view
AP group view
vlan-id1: Specifies a VLAN ID in the range of 1 to 4094.
vlan-id1 to vlan-id2: Specifies a VLAN range. The vlan-id1 and vlan-id2 arguments specify VLAN IDs. The value range for each of the two arguments is 1 to 4094. The value for the vlan-id2 argument cannot be lower than the value for the vlan-id1 argument.
all: Specifies all VLANs except for reserved VLANs. The keyword is not supported when the maximum number of VLANs that can be created on an AP is less than 4094. Support for this keyword depends on the AP model.
You cannot create or delete VLAN 1 (the default VLAN) or reserved VLANs.
# Create VLAN 2 for AP ap1 and enter the VLAN view of the VLAN.
# Create VLAN 2 for AP group group1 and enter the VLAN view of the VLAN.
[Sysname-wlan-ap-group-group1] vlan 2
wlan ap
Use wlan ap to create a manual AP and enter its view, or enter the view of an existing manual AP.
Use undo wlan ap to delete an AP.
wlan ap ap-name [ model model-name ]
undo wlan ap ap-name
No manual APs exist.
model model-name: Specifies the model name of the AP. You must specify the model name when you create an AP.
If the specified AP has established a CAPWAP tunnel, the undo wlan ap command also terminates the tunnel.
# Create an AP named ap1 with model WA4320i-ACN.
wlan ap-authentication
Use wlan ap-authentication to manually authenticate unauthenticated auto APs.
wlan ap-authentication { accept | reject } ap-unauthenticated { all | name ap-name }
Manual authentication is not configured for unauthenticated auto APs.
accept: Enables unauthenticated auto APs to pass authentication and generate ACL permit rules. Authenticated auto APs can provide wireless services.
reject: Rejects unauthenticated auto APs and generates ACL deny rules. If you specify this keyword, the command logs off all online unauthenticated auto APs.
all: Specifies all unauthenticated auto APs.
name ap-name: Specifies an unauthenticated auto AP by its name, a case-sensitive string of 1 to 64 characters.
Unauthenticated auto APs can associate with the AC but cannot provide wireless services. You can execute this command to authenticate these APs.
Before you execute this command, perform the following tasks:
·     Use the acl wlan ap command to create a WLAN AP ACL.
·     Use the wlan ap-authentication acl command to specify the ACL as the ACL for authenticating unauthenticated auto APs.
The generated ACL rules will be added to the specified ACL.
# Enable unauthenticated auto APs to pass authentication and generate permit rules in ACL 200.
[Sysname] acl wlan ap 200
[Sysname-acl-ap-200] quit
[Sysname] wlan ap-authentication acl 200
[Sysname] wlan ap-authentication accept ap-unauthenticated all
acl wlan ap
permit-unauthenticated
Use wlan ap-authentication acl to specify an ACL for authenticating auto APs.
Use undo wlan ap-authentication acl to restore the default.
wlan ap-authentication acl acl-number
No ACL is specified for authenticating auto APs.
acl-number: Specifies a WLAN AP ACL by its number, in the range of 200 to 299.
Before you execute this command, use the acl wlan ap command to create a WLAN AP ACL and configure ACL rules. You can use either of the following methods to configure ACL rules:
·     Use the ap-authentication import command.
·     Use the rule command. If this method is used, make sure the match criterion used in the rule is consistent with the auto AP authentication method. To configure an auto AP authentication method, use the wlan ap-authentication method command.
Unauthenticated auto APs that match ACL permit rules are allowed to associate with the AC. Unauthenticated auto APs that match ACL deny rules or do not match any ACL rules are rejected to associate with the AC.
If you do not configure any ACL rules, all auto APs will become unauthenticated.
# Specify ACL 200 for authenticating auto APs by serial ID.
[Sysname-acl-ap-200] rule 0 permit serial-id 210235A42QB095000766
acl wlan ap
rule
wlan ap-authentication import
wlan ap-authentication domain
Use wlan ap-authentication domain to configure an ISP domain for auto AP authentication.
Use undo wlan ap-authentication domain to restore the default.
wlan ap-authentication domain domain-name
No ISP domain is configured for auto AP authentication.
domain-name: Specifies an ISP domain by its name, a case-insensitive string of 1 to 255 characters. For information about ISP domains, see AAA in Security Configuration Guide.
You must configure this command when remote authentication is configured. If the remote authentication succeeds, the AC accepts the AP. If it does not succeed, the AC rejects the AP.
# Configure the authentication domain as office for auto AP authentication.
[Sysname] wlan ap-authentication domain office
wlan ap-authentication enable
Use wlan ap-authentication enable to enable auto AP authentication.
Use undo wlan ap-authentication enable to disable auto AP authentication.
Auto AP authentication is disabled.
Auto AP authentication only takes effect on auto APs that have not come online. It does not take effect on online auto APs, manual APs, and manual APs converted from auto APs.
Auto AP authentication does not take effect on online auto APs.
# Enable auto AP authentication.
[Sysname] wlan ap-authentication enable
Use wlan ap-authentication import to import an authentication file and generate corresponding ACL permit rules for auto AP authentication.
wlan ap-authentication import file-name
file-name: Specifies the name of an auto AP authentication file. It is a case-insensitive string of 1 to 32 characters and must have extension .txt.
An auto AP authentication file contains either the MAC address or serial ID of auto APs but not both of them. The MAC addresses must be in the format of HH-HH-HH-HH-HH-HH. MAC addresses and serial IDs are comma-separated.
Before you execute this command, make sure the following tasks are completed:
·     Use the wlan ap-authentication acl command to specify an ACL.
The generated permit rules will be added to the ACL.
·     Use the wlan ap-authentication method command to specify an auto AP authentication method.
The ACL rules are generated according to the authentication method. Make sure the authentication file format is consistent with the authentication method.
# Import auto AP authentication file office.txt to generate ACL permit rules in ACL 200.
[Sysname] acl number 200
[Sysname] wlan ap-authentication import office.txt
Use wlan ap-authentication method to specify an auto AP authentication method.
Use undo wlan ap-authentication method to restore the default.
wlan ap-authentication method { mac-address | serial-id }
Auto APs are authenticated by MAC address.
mac-address: Specifies the MAC address authentication method.
serial-id: Specifies the serial ID authentication method.
# Authenticate auto APs by AP serial ID.
[Sysname] wlan ap-authentication method serial-id
wlan ap-authentication permit-unauthenticated
Use wlan ap-authentication permit-unauthenticated to enable unauthenticated auto APs to associate with the AC.
Use undo wlan ap-authentication permit-unauthenticated to disable unauthenticated auto APs from associating with the AC.
Unauthenticated auto APs are allowed to associate with the AC, but they cannot provide wireless services.
Unauthenticated auto APs are auto APs that do not match an ACL rule in local authentication. Unauthenticated auto APs can associate with the AC but cannot provide wireless services. You can use the undo wlan ap-authentication permit-unauthenticated command to log off all unauthenticated auto APs.
# Disable unauthenticated auto APs from associating with the AC.
[Sysname] undo wlan ap-authentication permit-unauthenticated
wlan ap-certificate verification
Use wlan ap-certificate verification to enable AP certificate verification.
Use undo wlan ap-certificate verification to restore the default.
AP certificate verification is disabled.
This feature takes effect at AP associations subsequent to feature enabling.
With this feature enabled, when an AP attempts to come online, the AC identifies whether any of its saved AP certificates uses the AP's MAC address as its CN. If a match is found, the AC permits the AP to come online. If no match is found, the AC denies the association request from the AP.
To use AP certificate verification, you must perform the following tasks:
·     Generate AP certificates with APs' MAC addresses as certificate CNs. The MAC addresses must be in the aa:bb:cc:dd:ee:ff format.
·     Upload the certificates to the AC through FTP or TFTP.
·     Execute the download file command to download the certificates to the corresponding APs.
# Enable AP certificate verification.
[Sysname] wlan ap-certificate verification
tunnel encryption
wlan capwap encryption
wlan ap-image-deploy
Use wlan ap-image-deploy to deploy an image file to all the online APs.
This feature enables you to upgrade the image of all the online APs. For the upgrade to take effect, reboot the APs after upgrade.
Before executing this command, you must upload the image file to the storage media of the AC. You can execute the wlan image-load filepath command to specify the storage media.
# Deploy an image file to all the online APs.
[Sysname] wlan ap-image-deploy
wlan apdb
Use wlan apdb to configure the mapping between a software version and a hardware version of an AP model.
Use undo wlan apdb to restore the default.
wlan apdb model-name hardware-version software-version
undo wlan apdb model-name hardware-version
The software version for a hardware version of an AP model is the software version that is stored in APDB user scripts.
model-name: Specifies an AP model name in the APDB.
hardware-version: Specifies a hardware version in the APDB.
software-version: Specifies an AP software version, a case-insensitive string of 1 to 31 characters.
CAUTION
CAUTION:
To avoid CAPWAP tunnel establishment failure, use this command under the guidance of H3C Support.
This command is used together with the software upgrade feature for software version consistency check during software upgrade.
Use this command only when the software version you expect for an AP is inconsistent with the software version specified for the AP model stored in the APDB.
# Configure the mapping between software version E2108 and hardware version Ver.C of AP model WA4320i-ACN.
[Sysname] wlan apdb WA4320i-ACN Ver.C E2108
firmware-upgrade
wlan apdb file
Use wlan apdb file to load an APDB user script.
Use undo wlan apdb file to delete an APDB user script.
wlan apdb file user.apdb
undo wlan apdb file
No APDB user script is loaded.
user.apdb: Specifies an APDB user profile by its name, a case-sensitive string of 1 to 63 characters. apdb is the filename extension.
When you load an APDB user script, follow these restrictions and guidelines:
·     If you load multiple user scripts on the AC, the most recently loaded user script overwrites the old user scripts.
·     Make sure the user script is valid. Invalid scripts can cause loading failure.
·     The AP models in the user script must be different from the AP models in the system script.
·     If you rename the user script in the file system, reload the user script to prevent AP model configuration in the user script from being lost after an AC reboot.
·     If you replace the user script with a new user script in the file system, reload the new user script. If the new user script does not include AP model information saved in the replaced user script, the AP model information will be lost after an AC reboot.
·     If you delete a user script in the file system, reload a new user script. If you do not reload a new user script, the AP model configuration in the user script will be lost after an AC reboot.
If an old user script already exists, follow these restrictions and guidelines when you load an APDB user script:
·     If a manual AP or an online auto AP whose model is listed in the old user script exists ,you can load a new user script only when you delete the corresponding AP model information on the AC.
·     If APs of an AP model listed in the old user script have been added to an AP group, you can load a new user script only when you remove the APs from the AP group.
·     If the old user script includes an AP model whose software version was already configured, you can load a new user script only when you use the wlan apdb command to restore the original software version.
# Load user script user.apdb.
[Sysname] wlan apdb file user.apdb
wlan apdb
wlan ap-group
Use wlan ap-group to create an AP group and enter its view, or enter the view of an existing AP group.
Use undo wlan ap-group to delete an AP group.
wlan ap-group group-name
undo wlan ap-group group-name
The default AP group default-group exists, and it cannot be deleted.
group-name: Specifies an AP group by its name, a case-insensitive string of 1 to 31 characters.
# Create an AP group named group1.
display wlan ap-group
wlan auto-ap enable
Use wlan auto-ap enable to enable the auto AP feature.
Use undo wlan auto-ap enable to disable the auto AP feature.
wlan auto-ap enable
The auto AP feature is disabled.
This command enables an AP to connect to an AC without manual AP configuration. It simplifies configuration when you deploy a large number of APs in a WLAN.
To configure an auto AP, you must use auto-AP persistence to convert the auto AP to a manual AP or configure it through an AP group.
# Enable the auto AP feature.
[Sysname] wlan auto-ap enable
wlan auto-ap persistent
Use wlan auto-ap persistent to convert online auto APs to manual APs.
wlan auto-ap persistent { all | name auto-ap-name [ new-ap-name ] }
all: Specifies all online auto APs. If you specify this keyword, the command converts all online auto APs to manual APs with AP names unchanged.
name auto-ap-name: Specifies an online auto AP.
new-ap-name: Specifies a new name for the AP, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-). If you do not specify this argument, the converted manual AP uses the name of the auto AP.
# Convert the auto AP whose MAC address is 0001-ab12-cd36 to manual AP ap2.
[Sysname] wlan auto-ap persistent name 0001-ab12-cd36 ap2
wlan auto-persistent enable
Use wlan auto-persistent enable to convert auto APs to manual APs after they come online.
Use undo wlan auto-persistent enable to restore the default.
Auto AP conversion is disabled.
This command takes effect only on auto APs that come online after you execute this command. For auto APs that are already online, use the wlan auto-ap persistent command to convert them to manual APs.
# Enable auto AP conversion.
[Sysname] wlan auto-persistent enable
wlan capwap discovery-policy unicast
Use wlan capwap discovery-policy unicast to enable an AC to respond only to unicast discovery requests.
Use undo wlan capwap discovery-policy to disable an AC to respond only to unicast discovery requests.
An AC can respond to unicast, multicast, and broadcast discovery requests.
# Enable the AC to respond only to unicast discovery requests.
[Sysname] wlan capwap discovery-policy unicast
Use wlan capwap encryption to specify the certificate used by CAPWAP control tunnel encryption.
Use undo wlan capwap encryption to restore the default.
wlan capwap encryption certificate cer-name key key-name ca ca-name
CAPWAP control tunnel encryption uses the built-in certificate.
certificate cer-name: Specifies the certificate name with the file suffix attached, cer-name.pem for example. The certificate must be in the .pem or .cer format.
key key-name: Specifies the key file name with the file suffix attached, key-name.pem for example. The key file must be in the .pem or .cer format.
ca ca-name: Specifies the CA certificate name with the file suffix attached, ca-name.pem for example. The CA certificate must be in the .pem or .cer format.
Before specifying a certificate, you must first save the certificate, key, and CA certificate to the file system of the AC.
For the configuration to take effect, perform this task before you enable CAPWAP control tunnel encryption.
# Specify a certificate for CAPWAP control tunnel encryption.
[Sysname] wlan capwap encryption certificate server.cer key server.key ca cacert.cer
tunnel encryption
wlan description
Use wlan description to configure a description for the AC.
Use undo wlan description to restore the default.
wlan description text
An AC does not have a description.
text: Specifies the description, a case-sensitive string of 1 to 64 characters.
If multiple ACs exist in a WLAN, you can specify a description for each AC to help identify them.
To display the description of an AC, execute the display this command.
# Configure the AC's description as test.
[Sysname] wlan description test
wlan detect-anomaly enable
Use wlan detect-anomaly enable to enable service anomaly detection.
Use undo wlan detect-anomaly enable to disable service anomaly detection.
Service anomaly detection is disabled.
This feature enables an AC to check service status and start a reboot timer (10 minutes) upon detecting that no APs are associated with the AC. When the reboot timer expires, the AC restarts. If an AP comes online before the timer expires, the AC deletes the timer.
# Enable service anomaly detection.
[Sysname] wlan detect-anomaly enable
wlan enable
Use wlan enable to enable the WLAN function.
Use undo wlan enable to disable the WLAN function.
wlan enable
undo wlan enable
The WLAN function is enabled.
CAUTION
CAUTION:
Disabling the WLAN function logs off all online APs. Please use this feature with caution.
# Disable the WLAN function.
[Sysname] undo wlan enable
Disabling the WLAN function will log off all the online APs. Continue? [Y/N]
wlan global-configuration
Use wlan global-configuration to enter global configuration view.
The configuration priorities for an AP in AP view, AP group view, and global configuration view are in descending order. If no settings are configured in one view, the settings in the view with a lower priority are used. If no settings are configured in any one of the three views, the AP uses the default configuration in the view that has the lowest priority.
# Enter global configuration view.
[Sysname] wlan global-configuration
Use wlan image-load filepath to specify the preferred location for the AC to obtain an AP image file for software version assignment.
Use undo wlan image-load filepath to restore the default.
wlan image-load filepath { local | ram }
The AC prefers the AP image file stored in the RAM when assigning a software version to APs.
local: Specifies the local folder as the preferred location to obtain an AP image file. If the local folder does not contain an AP image file, the AC obtains the AP image file from the RAM. If the RAM does not contain an AP image file, the AC fails to obtain an AP image file.
ram: Specifies the RAM as the preferred location to obtain an AP image file. If the RAM does not contain an AP image file, the AC obtains the AP image file from the local folder. If the local folder does not contain an AP image file, the AC fails to obtain an AP image file.
The AC image file contains AP image files. The AC reads the AP image files into the RAM when it starts.
Specify the local keyword only when the following conditions are met:
·     The required AP image file is not contained in the AC's image file.
·     The software version an AP uses when it comes online has been specified using the wlan apdb command.
When you specify the local keyword, make sure the AC uses a CF or flash card as the default file system and the AP image file is stored in the root directory of the file system on the AC.
The AC can assign only .ipe AP image files to APs.
# Specify the local folder as the preferred location to obtain an AP image file for AP software version assignment.
[Sysname] wlan image-load filepath local
wlan re-group
Use wlan re-group to move an AP grouping rule or a list of AP grouping rules to the specified AP group.
wlan re-group { ap ap-name | ap-group source-group-name | mac-address mac-address | serial-id serial-id } group-name
ap ap-name: Specifies an AP grouping rule by AP names.
ap-group source-group-name: Specifies the source AP group. The source AP group cannot be the default AP group.
mac-address mac-address: Specifies an AP grouping rule by MAC addresses.
serial-id serial-id: Specifies an AP grouping rule by serial IDs.
group-name: Specifies the target AP group. The target AP group cannot be the default AP group.
# Create an AP group named group1, and create AP grouping rules by AP names to add APs ap1, ap2, and ap3 to AP group group1.
[Sysname-wlan-ap-group-group1] ap ap1 ap2 ap3
[Sysname-wlan-ap-group-group1] quit
# Create an AP group named group2, and move an AP grouping rule by AP names to AP group group2.
[Sysname] wlan ap-group group2
[Sysname-wlan-ap-group-group2] quit
[Sysname] wlan re-group ap ap1 group2
wlan rename-ap
Use wlan rename-ap to rename a manual AP.
wlan rename-ap ap-name new-ap-name
ap-name: Specifies a manual AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
new-ap-name: Specifies a new AP name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
# Change the name of AP ap1 to ap1-office.
[Sysname] wlan rename-ap ap1 ap1-office
wlan tcp mss
Use wlan tcp mss to set the maximum TCP segment size (TCP MSS) for CAPWAP tunnels.
Use undo wlan tcp mss to restore the default.
wlan tcp mss value
undo wlan tcp mss
The TCP MSS is 1460 bytes for CAPWAP tunnels.
value: Specifies the TCP MSS in bytes in the range of 128 to 2048.
This command sets the value of the MSS option in SYN packets transmitted over a CAPWAP tunnel.
The MSS option informs the receiver of the largest segment that the sender can accept. Each end announces its MSS during TCP connection establishment. If the size of a TCP segment is smaller than or equal to the MSS of the receiver, TCP sends the TCP segment without fragmentation. If not, TCP fragments the segment based on the receiver's MSS.
# Set the TCP MSS to 2000 bytes for CAPWAP tunnels.
[Sysname] wlan tcp mss 2000
wlan timezone-sync enable
Use wlan timezone-sync enable to enable time zone synchronization.
Use undo wlan timezone-sync enable to restore the default.
Time zone synchronization is disabled.
# Enable time zone synchronization.
[Sysname] wlan timezone-sync enable
wlan vip-ap-group
Use wlan vip-ap-group to create an AP monitor group and enter its view or enter the view of an existing AP monitor group.
Use undo wlan vip-ap-group to delete the AP monitor group.
wlan vip-ap-group
No AP monitor group exists.
APs in an AP monitor group can report client quantity, radio traffic, channel usage, and AP anomalies to the AC.
# Create an AP monitor group.
ap-name
report-interval
  • Become a Partner
  • Partner Resources
