14-WLAN Command Reference (AC)
HomeSupportResource CenterReference GuidesCommand ReferencesH3C MSR810[830][2600][3600] Routers Command Reference(V7)-R0821-6W50114-WLAN Command Reference (AC)
09-WLAN roaming commands
09-WLAN roaming commands 46.43 KB
For information about MSR routers that can function as ACs, see "Compatibility of hardware and AC functionality."
display wlan mobility roam-count
Use display wlan mobility roam-count to display the number of roamings for each client on the AC.
# Display the number of roamings for each client on the HA.
<Sysname> display wlan mobility roam-count
MAC address              Count
5250-0012-0411           0
9cd3-6d9d-ea3c           3
8007-3fed-aa6c           8
MAC address
Client MAC address.
Count
Number of roamings.
display wlan mobility roam-track mac-address
Use display wlan mobility roam-track mac-address to display roaming information for a client on the AC.
display wlan mobility roam-track mac-address mac-address
mac-address mac-address: Specifies a client by its MAC address, in the form of H-H-H.
Roaming information is displayed in sequence. The most recent roam-track information is displayed the first.
The system can save a maximum of 128 roaming entries. To record a new entry if the maximum number has been reached, the system deletes the third oldest entry and then records the new entry.
# Display roaming information for the specified client on the HA.
<Sysname> display wlan mobility roam-track mac-address 5250-0012-0411
Total entries: 2
Current entries: 2
BSSID           Created at           Online time       AC IP address  RID  AP name
000f-e203-7777  2016-06-14 11:12:28  00hr 01min 02sec  127.0.0.1      1    ap2
000f-e200-4444  2016-06-14 11:12:04  00hr 03min 51sec  127.0.0.1      1    ap1
BSSID
BSSID of the AP with which the client is associated.
Created at
Time when a roam-track entry was created for the client.
Online time
Online time of the client.
AC IP address
IP address of the AC with which the client is associated. This field is fixed to 127.0.0.1.
RID
ID of the radio with which the client is associated.
AP name
Name of the AP with which the client is associated.
snmp-agent trap enable wlan mobility
Use snmp-agent trap enable wlan mobility to enable SNMP notifications for WLAN roaming.
Use undo snmp-agent trap enable wlan mobility to disable SNMP notifications for WLAN roaming.
SNMP notifications are disabled for WLAN roaming.
To report critical WLAN roaming events to an NMS, enable SNMP notifications for WLAN roaming. For WLAN roaming event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for WLAN roaming.
[Sysname] snmp-agent trap enable wlan mobility
  • Become a Partner
  • Partner Resources
