- 13-High Availability Configuration Guide
- 01-Interface backup configuration
- 02-Ethernet OAM configuration
- 03-CFD configuration
- 04-DLDP configuration
- 05-Monitor Link configuration
- 06-VRRP configuration
- 07-Layer 3 connection keepalive configuration
- 08-Error code detection configuration
- 09-BFD configuration
- 10-Failover group configuration
- 11-Process placement configuration
- 12-Track configuration
00-Preface | 100.64 KB |
Preface
This configuration guide describes the high availability features. The high availability technologies include fault detection and fault failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
