H3C S6850&S9850&S9820-64H Config Examples-Release 655x-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C S6850&S9850&S9820-64H Config Examples-Release 655x-6W100
Table of Contents
Related Documents
60-Attack Protection Configuration Examples
60-Attack Protection Configuration Examples 351.25 KB
H3C S6850 & S9850 & S9820-64H
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides configuration examples of link layer attack protection, ARP attack protection, network layer attack protection, and transport layer attack protection, as defined in Table 1.
Table 1 Attack protection types
Link layer attack protection
MAC address attack protection
Prevents the attack of packets with different source MAC addresses or VLANs by configuring the maximum number of MAC addresses that an interface can learn.
STP packet attack protection
Provides protection measures such as BPDU guard, root guard, loop guard, and TC-BPDU guard.
ARP source suppression
Prevents IP attack packets from fixed sources.
ARP black hole routing
Prevents IP attack packets from sources that are not fixed.
ARP active acknowledgement
Prevents user spoofing.
Source MAC-based ARP attack detection
Prevents ARP packet attacks from the same source MAC.
ARP packet source MAC consistency check
Prevents attacks from ARP packets whose source MAC address in the Ethernet header is different from the sender MAC address in the message body.
Network layer attack protection
uRPF check
Protects a network against source spoofing attacks.
TTL attack protection
Prevents an attack by disabling sending ICMP time exceeded messages.
Transport layer attack protection
SYN flood attack protection
Enables the server to return a SYN ACK message when it receives a TCP connection request, without establishing a half-open TCP connection.
This document assumes that you have basic knowledge of attack protection.
Example: Configuring link layer attack protection
As shown in Figure 1, Device A, Device B, and Device C run MSTP. Device B acts as the root bridge, and HundredGigE 1/0/1 on Device C is blocked.
Configure the following features to prevent link layer attacks:
·           Configure root guard on HundredGigE 1/0/1 and HundredGigE 1/0/2 of Device B for Device B to act as the root bridge.
·           Configure loop guard on HundredGigE 1/0/2 of Device C to prevent temporary loops. The loop guard feature keeps the port in Discarding state in all MSTIs when it receives no BPDU.
·           Configure BPDU guard on ports at the access side of Device A and Device C. The BPDU guard feature prevents the ports from performing spanning tree calculations when it receives forged BPDUs with a higher priority.
·           Enable TC-BPDU guard on Device A, Device B, and Device C. The TC-BPDU guard feature prevents a large number of TC-BPDUs from affecting the network in a short time.
·           Set the maximum number of MAC addresses that can be learned by ports at the access side of Device A and Device C. This configuration protects the devices from a large number of attack packets that have different source MAC addresses. The attack packets might cause a large MAC table and low forwarding performance.
·           Configure broadcast and multicast suppression on the designated ports of Device B and all ports on Device A and Device C. When incoming broadcast or multicast traffic exceeds the threshold (6400 pps), an interface discards broadcast or multicast packets until the traffic drops below the threshold.
Figure 1 Network diagram
Analysis
For the ports at the access side of Device A and Device C to rapidly transit to the forwarding state, use the stp edged-port command to configure these ports as edge ports.
This example uses HundredGigE 1/0/3 to illustrate the configuration on the ports at the access side on Device A and Device C.
Hardware
Software version
S6850 switch series
S9850 switch series
Release 6555P01
S9820-64H switch
Release 6555P01
When you configure link layer attack protection, follow these restrictions and guidelines:
·           On a port, the loop guard feature is mutually exclusive with the root guard feature or the edge port setting.
·           Do not configure the loop guard feature on ports at the access side. Otherwise, the ports stay in Discarding state in all MSTIs because they cannot receive BPDUs.
Procedures
Configuring Device B
# Specify IP addresses for interfaces. (Details not shown.)
# Configure root guard on HundredGigE 1/0/1 and HundredGigE 1/0/2.
[DeviceB] interface range hundredgige 1/0/1 to hundredgige 1/0/2
[DeviceB-if-range] stp root-protection
[DeviceB-if-range] quit
# Configure TC-BPDU guard.
[DeviceB] stp tc-protection
[DeviceB] stp tc-protection threshold 10
# Configure broadcast and multicast suppression on HundredGigE 1/0/1 and HundredGigE 1/0/2.
[DeviceB-if-range] broadcast-suppression pps 6400
[DeviceB-if-range] multicast-suppression pps 6400
Configuring Device A
# Configure STP BPDU guard.
[DeviceA] stp bpdu-protection
# Configure HundredGigE 1/0/3 as an edge port.
[DeviceA] interface hundredgige 1/0/3
[DeviceA-HundredGigE1/0/3] stp edged-port
[DeviceA-HundredGigE1/0/3] quit
[DeviceA] stp tc-protection
[DeviceA] stp tc-protection threshold 10
# Set the maximum number of MAC addresses that HundredGigE 1/0/3 can learn.
[DeviceA-HundredGigE1/0/3] mac-address max-mac-count 1024
# Configure broadcast and multicast suppression on all ports.
[DeviceA] interface range hundredgige 1/0/1 to hundredgige 1/0/3
[DeviceA-if-range] broadcast-suppression pps 6400
[DeviceA-if-range] multicast-suppression pps 6400
[DeviceA-if-range] quit
Configuring Device C
<DeviceC> system-view
[DeviceC] stp bpdu-protection
[DeviceC] interface hundredgige 1/0/3
[DeviceC-HundredGigE1/0/3] stp edged-port
[DeviceC-HundredGigE1/0/3] quit
# Configure root guard on HundredGigE 1/0/1.
[DeviceC] interface hundredgige 1/0/1
[DeviceC-HundredGigE1/0/1] stp root-protection
[DeviceC-HundredGigE1/0/1] quit
# Configure loop guard on HundredGigE 1/0/2.
[DeviceC] interface hundredgige 1/0/2
[DeviceC-HundredGigE1/0/2] stp loop-protection
[DeviceC-HundredGigE1/0/2] quit
[DeviceC] stp tc-protection
[DeviceC] stp tc-protection threshold 10
[DeviceC-HundredGigE1/0/3] mac-address max-mac-count 1024
[DeviceC] interface range hundredgige 1/0/1 to hundredgige 1/0/3
[DeviceC-if-range] broadcast-suppression pps 6400
[DeviceC-if-range] multicast-suppression pps 6400
[DeviceC-if-range] quit
# Verify that the edge ports go down after they receives STP BPDUs. (Details not shown.)
# Bring the edge ports up by using the undo shutdown command. (Details not shown.)
# Verify that the root ports do not change and that the STP topology remains stable after STP BPDUs with higher priority are sent to the designated ports. (Details not shown.)
# Verify that the devices do not refresh the FIB table frequently and that no serious packet loss occurs after a large number of TC BPDUs are sent to the devices. (Details not shown.)
# Verify that the uplink ports are not flooded after a large number of broadcasts are sent to the edge ports on device A and Device C. (Details not shown.)
Configuration files
·           Device A:
stp bpdu-protection
interface HundredGigE 1/0/1
 port link-mode bridge
interface HundredGigE 1/0/2
interface HundredGigE 1/0/3
 stp edged-port
·           Device B:
 stp root-protection
 stp root-protection
·           Device C:
stp bpdu-protection
 stp root-protection
 stp loop-protection
 stp edged-port
Example: Configuring ARP attack protection
As shown in Figure 2, the device is the gateway for the internal network. Configure ARP attack protection on the device to prevent ARP attacks.
Figure 2 Network diagram
Hardware
Software version
S6850 switch series
S9850 switch series
Release 6555P01
S9820-64H switch
Release 6555P01
Procedures
# Enable ARP source suppression.
[Device] arp source-suppression enable
# Configure the device to accept a maximum of 8 unresolvable packets per source IP address in 5 seconds.
[Device] arp source-suppression limit 8
# Enable ARP black hole routing to prevent unresolvable IP packet attacks.
[Device] arp resolving-route enable
# Enable ARP active acknowledgment to prevent user spoofing.
[Device] arp active-ack enable
# Configure source MAC-based ARP attack detection to prevent ARP packet attacks from the same source MAC.
[Device] arp source-mac filter
[Device] arp source-mac threshold 25
# Enable ARP packet source MAC address consistency check to prevent attacks from ARP packets with different source MAC addresses in the Ethernet header and in the message body.
[Device] arp valid-check enable
1.      Verify that ARP attack protection functions on the device:
# Send ARP attack packets to the device. (Details not shown.)
# Verify that the CPU usage does not surge. (Details not shown.)
2.      Verify that each ARP attack protection feature functions on the device (this example uses the ARP source suppression feature):
# Send the device 20 forged packets with the same source IP address and unresolvable destination IP addresses. (Details not shown.)
# Verify that the device stops resolving the packets after receiving 8 forged packets within 5 seconds. (Details not shown.)
# Verify the ARP source suppression configuration.
[Device] display arp source-suppression
 ARP source suppression is enabled
 Current suppression limit: 8
 Current cache length: 16
Configuration files
Example: Configuring network layer attack protection
As shown in Figure 3, Device A is the gateway for the internal network. To protect Device A against IP packet attacks from internal and external networks, configure the following network layer attack protection features:
·           Configure strict uRPF check to prevent source address spoofing attacks.
·           Disabling sending ICMP time exceeded messages. The device will not be flooded by ICMP time exceeded messages when receiving a large number of packets with TTL set to 1.
Figure 3 Network diagram
Hardware
Software version
S6850 switch series
S9850 switch series
Release 6555P01
S9820-64H switch
Release 6555P01
When you configure network layer attack protection, follow these restrictions and guidelines:
·           After you disable sending ICMP time exceeded messages, the tracert feature will not be available.
·           Enabling the uRPF check feature halves the route capacity of the switch.
·           The uRPF check feature cannot be enabled if the number of existing routes exceeds half of the route capacity on the switch. This mechanism prevents route loss, which can cause packet loss.
Procedures
# Enable strict uRPF check.
[DeviceA] ip urpf strict
# Disable sending ICMP time exceeded messages. Sending ICMP time exceeded messages is disabled by default.
[DeviceA] undo ip ttl-expires enable
1.      Verify that Device A can prevent source address spoofing attacks:
# Verify that Device A can filter out packets with forged source IP addresses. (Details not shown.)
# Verify the uRPF configuration.
[DeviceA] display ip urpf
Global uRPF configuration information:
   Check type: strict
2.      Verify that TTL attack protection functions on Device A:
# Enable ICMP debugging by executing the debugging ip icmp command on Device A. (Details not shown.)
# Use a PC to send packets in which the TTL is 1 to Device A. (Details not shown.)
# Verify that Device A does not display any debugging information and that the PC does not receive any ICMP time exceeded messages. (Details not shown.)
# Enable sending ICMP time exceeded messages and send packets in which the TTL is 1 to Device A. (Details not shown.)
# Verify that Device A responds with ICMP time exceeded messages.
<DeviceA> *Aug 14 16:43:31:068 2016 NM-3 SOCKET/7/ICMP: Slot=2;
Time(s):1371221011  ICMP Output:
 ICMP Packet: src = 6.0.0.1, dst = 202.101.0.2
              type = 11, code = 0 (ttl-exceeded)
 Original IP: src = 202.101.0.2, dst = 192.168.0.2
              proto = 253, first 8 bytes = 00000000 00000000
Configuration files
ip urpf strict
Example: Configuring transport layer attack protection
As shown in Figure 4, the device is the gateway for the internal network. Configure SYN Cookie protection on the device to protect against SYN flood attacks. With this feature enabled, the device responds to a SYN packet with a SYN ACK packet without establishing a TCP semi-connection. The device establishes a TCP connection only when it receives an ACK packet from the sender.
Figure 4 Network diagram
Hardware
Software version
S6850 switch series
S9850 switch series
Release 6555P01
S9820-64H switch
Release 6555P01
Procedures
# Enable SYN Cookie.
[Device] tcp syn-cookie enable
# Verify that the device does not have any TCP semi-connections. The state "SYN_RECEIVED" represents semi-connections.
[Device] display tcp
 *: TCP connection with authentication
 Local Addr:port       Foreign Addr:port     State       Slot  PCB
 0.0.0.0:21            0.0.0.0:0             LISTEN      1     0xffffffffffffff9
d
 0.0.0.0:23            0.0.0.0:0             LISTEN      1     0xffffffffffffff9
f
 192.168.2.88:23       192.168.2.79:2197     ESTABLISHED 1     0xffffffffffffffa
3
 192.168.2.88:23       192.168.2.89:2710     ESTABLISHED 1     0xffffffffffffffa
2
 192.168.2.88:23       192.168.2.110:50199   ESTABLISHED 1     0xffffffffffffffa
5
Configuration files
Related documentation
·           H3C S6850 & S9850 Switch Series Layer 2LAN Switching Configuration Guide-Release 655x
·           H3C S6850 & S9850 Switch Series Layer 2LAN Switching Command Reference-Release 655x
·           H3C S6850 & S9850 Switch Series Security Configuration Guide-Release 655x
·           H3C S6850 & S9850 Switch Series Security Command Reference-Release 655x
·           H3C S6850 & S9850 Switch Series Layer 3IP Services Configuration Guide-Release 655x
·           H3C S6850 & S9850 Switch Series Layer 3IP Services Command Reference-Release 655x
·           H3C S9820-64H Switch Layer 2LAN Switching Configuration Guide-Release 655x
·           H3C S9820-64H Switch Layer 2LAN Switching Command Reference-Release 655x
·           H3C S9820-64H Switch Security Configuration Guide-Release 655x
·           H3C S9820-64H Switch Security Command Reference-Release 655x
·           H3C S9820-64H Switch Layer 3IP Services Configuration Guide-Release 655x
·           H3C S9820-64H Switch Layer 3IP Services Command Reference-Release 655x
  • Become a Partner
  • Partner Resources
