- H3C S6850&S9850&S9820-64H Config Examples-Release 655x-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 14-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 15-GRE Tunnel Configuration Examples
- 16-GRE with OSPF Configuration Examples
- 17-OSPF Configuration Examples
- 18-IS-IS Configuration Examples
- 19-BGP Configuration Examples
- 20-Policy-Based Routing Configuration Examples
- 21-OSPFv3 Configuration Examples
- 22-IPv6 IS-IS Configuration Examples
- 23-Routing Policy Configuration Examples
- 24-IGMP Snooping Configuration Examples
- 25-IGMP Configuration Examples
- 26-BIDIR-PIM Configuration Examples
- 27-MLD Snooping Configuration Examples
- 28-IPv6 Multicast VLAN Configuration Examples
- 29-Basic MPLS Configuration Examples
- 30-MPLS L3VPN Configuration Examples
- 31-ACL Configuration Examples
- 32-Control Plane-Based QoS Policy Configuration Examples
- 33-Traffic Policing Configuration Examples
- 34-GTS and Rate Limiting Configuration Examples
- 35-Priority Mapping and Queue Scheduling Configuration Examples
- 36-Traffic Filtering Configuration Examples
- 37-AAA Configuration Examples
- 38-Port Security Configuration Examples
- 39-Portal Configuration Examples
- 40-SSH Configuration Examples
- 41-IP Source Guard Configuration Examples
- 42-Ethernet OAM Configuration Examples
- 43-CFD Configuration Examples
- 44-DLDP Configuration Examples
- 45-VRRP Configuration Examples
- 46-BFD Configuration Examples
- 47-NTP Configuration Examples
- 48-SNMP Configuration Examples
- 49-NQA Configuration Examples
- 50-Mirroring Configuration Examples
- 51-sFlow Configuration Examples
- 52-FCoE Configuration Examples
- 53-OpenFlow Configuration Examples
- 54-MAC Address Table Configuration Examples
- 55-Static Multicast MAC Address Entry Configuration Examples
- 56-IP Unnumbered Configuration Examples
- 57-MVRP Configuration Examples
- 58-MCE Configuration Examples
- 59-Congestion Avoidance and Queue Scheduling Configuration Examples
- 60-Attack Protection Configuration Examples
- 61-Smart Link Configuration Examples
- 62-RRPP Configuration Examples
- 63-BGP Route Selection Configuration Examples
- 64-IS-IS Route Summarization Configuration Examples
- 65-IRF Configuration Examples
- 66-MPLS OAM Configuration Examples
- 67-MPLS TE Configuration Examples
- 68-VXLAN Configuration Examples
- 69-NetStream Configuration Examples
- 70-DRNI Configuration Examples
- 71-DRNI and EVPN Configuration Examples
- 72-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 73-VCF Fabric Configuration Examples
- 74-PTP Configuration Examples
- 75-S-MLAG Configuration Examples
- 76-Puppet Configuration Examples
47-NTP Configuration Examples | 266.07 KB |
H3C S6850 & S9850 & S9820-64H |
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring NTP client/server mode
Example: Configuring NTP broadcast mode
Configuring Device A, Device B, Device D, and Device E
Example: Configuring NTP multicast mode
Example: Configuring NTP authentication in client/server mode
Example: Configuring IPv6 NTP client/server mode
Example: Configuring IPv6 NTP multicast mode
Example: Configuring NTP authentication in broadcast mode
Introduction
This document provides NTP configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of NTP.
As shown in Figure 1, configure NTP client/server mode so that all devices can be synchronized to Device A, the NTP server.
Hardware |
Software version |
S6850 switch series S9850 switch series |
Release 6555P01 |
S9820-64H switch |
Release 6555P01 |
Procedures
# Assign an IP address to VLAN-interface 2.
[DeviceA] interface Vlan-interface 2
[DeviceA-Vlan-interface2] ip address 1.0.1.11 24
[DeviceA-Vlan-interface2] quit
# Enable the NTP service.
[DeviceA] ntp-service enable
# Specify the local clock as the reference source, with the stratum level 2.
[DeviceA] ntp-service refclock-master 2
Configuring Device B
# Assign an IP address to VLAN-interface 2. (Details not shown.)
[DeviceB] ntp-service enable
# Specify Device A as the NTP server of Device B so that Device B is synchronized to Device A.
[DeviceB] ntp-service unicast-server 1.0.1.11
Configuring Device C
<DeviceC> system-view
[DeviceC] ntp-service enable
# Specify Device A as the NTP server of Device C so that Device C is synchronized to Device A.
[DeviceC] ntp-service unicast-server 1.0.1.11
# Verify that Device B has synchronized to Device A, and the clock stratum level is 3 on Device B and 2 on Device A.
[DeviceB] display ntp-service status
Clock status: synchronized
Clock stratum: 3
System peer: 1.0.1.11
Local mode: client
Reference clock ID: 1.0.1.11
Leap indicator: 00
Clock jitter: 0.003479 s
Stability: 0.000 pps
Clock precision: 2^-18
Root delay: 1.95313 ms
Root dispersion: 28.38135 ms
Reference time: d5ed8cd5.577006ea Wed, Sep 5 2019 16:24:53.341
# Verify that an IPv4 NTP association has been established between Device B and Device A.
[DeviceB] display ntp-service sessions
source reference stra reach poll now offset delay disper
[12345]1.0.1.11 127.127.1.0 2 255 64 38 -10.22 1.9531 3.3416
Total sessions: 1
Configuration files
· Device A:
interface Vlan-interface2
ip address 1.0.1.11 255.255.255.0
ntp-service enable
· Device B:
ip address 1.0.1.12 255.255.255.0
ntp-service enable
· Device C:
ip address 1.0.1.13 255.255.255.0
ntp-service enable
As shown in Figure 2, the devices are on the same network segment. Configure NTP broadcast mode so that all the devices can be synchronized to Device C, the NTP server.
Hardware |
Software version |
Release 6555P01 |
S9820-64H switch |
Release 6555P01 |
Procedures
[DeviceC] ntp-service refclock-master 2
[DeviceC] interface Vlan-interface 2
[DeviceC-Vlan-interface2] ip address 3.0.1.31 24
# Configure Device C to operate in broadcast server mode and send broadcast messages from VLAN-interface 2.
[DeviceC-Vlan-interface2] ntp-service broadcast-server
# Configure Device A to operate in broadcast client mode and receive broadcast messages on VLAN-interface 2.
[DeviceA-Vlan-interface2] ntp-service broadcast-client
# Configure Device B, Device D, and Device E in the same way Device A is configured. (Details not shown.)
# Verify that Device A has synchronized to Device C, and the clock stratum level is 3 on Device A and 2 on Device C.
[DeviceA-Vlan-interface2] display ntp-service status
Clock stratum: 3
System peer: 3.0.1.31
Local mode: bclient
Reference clock ID: 3.0.1.31
Leap indicator: 00
Clock jitter: 0.000061 s
Root delay: 0.00000 ms
Root dispersion: 7951.43127 ms
Reference time: d5ee8d88.2faabed0 Thu, Sep 6 2019 10:40:08.186
# Verify that an IPv4 NTP association has been established between Device A and Device C.
[DeviceA-Vlan-interface2] display ntp-service sessions
[1234]3.0.1.31 127.127.1.0 2 254 64 82 -2.190 0.0000 7937.5
Total sessions: 1
Configuration files
· Device C:
ip address 3.0.1.31 255.255.255.0
ntp-service enable
· Device A:
ip address 3.0.1.33 255.255.255.0
ntp-service enable
· Device B:
ip address 3.0.1.30 255.255.255.0
ntp-service enable
· Device D:
ip address 3.0.1.32 255.255.255.0
ntp-service enable
· Device E:
ip address 3.0.1.34 255.255.255.0
ntp-service enable
As shown in Figure 3, the devices are on different network segments. Configure NTP multicast mode so that all the devices can be synchronized to Device C, the NTP server.
Hardware |
Software version |
Release 6555P01 |
S9820-64H switch |
Release 6555P01 |
Procedures
# Configure Device C to operate in multicast server mode and send multicast messages from VLAN-interface 2.
[DeviceC-Vlan-interface2] ntp-service multicast-server
Configuring Device D
<DeviceD> system-view
[DeviceD] ntp-service enable
[DeviceD] interface Vlan-interface 2
[DeviceD-Vlan-interface2] ip address 3.0.1.32 24
# Configure Device D to operate in multicast client mode and receive multicast messages on VLAN-interface 2.
[DeviceD-Vlan-interface2] ntp-service multicast-client
# Configure Device B to operate in multicast client mode and receive multicast messages on VLAN-interface 2.
[DeviceB-Vlan-interface2] ntp-service multicast-client
[DeviceB-Vlan-interface2] quit
Because Device A and Device C are on different subnets, you must enable the multicast functions on Device B before Device A can receive multicast messages from Device C.
# Enable IP multicast routing and IGMP.
[DeviceB] multicast routing
[DeviceB] interface vlan-interface 2
[DeviceB-Vlan-interface2] pim dm
[DeviceB] vlan 3
[DeviceB-vlan3] port HundredGigE 1/0/1
[DeviceB-vlan3] quit
[DeviceB] interface vlan-interface 3
[DeviceB-Vlan-interface3] ip address 1.0.1.10 24
[DeviceB-Vlan-interface3] igmp enable
[DeviceB-Vlan-interface3] igmp static-group 224.0.1.1
[DeviceB-Vlan-interface3] quit
[DeviceB] igmp-snooping
[DeviceB-igmp-snooping] quit
[DeviceB] interface HundredGigE 1/0/1
[DeviceB-HundredGigE 1/0/1] igmp-snooping static-group 224.0.1.1 vlan 3
# Assign an IP address to VLAN-interface 3.
[DeviceA] interface Vlan-interface 3
[DeviceA-Vlan-interface3] ip address 1.0.1.11 24
# Configure Device A to operate in multicast client mode and receive multicast messages on VLAN-interface 3.
[DeviceA-Vlan-interface3] ntp-service multicast-client
[DeviceA-Vlan-interface3] display ntp-service status
Clock stratum: 3
Local mode: bclient
Leap indicator: 00
Root delay: 1.69373 ms
Root dispersion: 1950.18005 ms
Reference time: d5ee9b15.2f3a684d Thu, Sep 6 2019 11:37:57.184
Configuration files
· Device A:
ntp-service enable
interface Vlan-interface3
· Device B:
ntp-service enable
multicast routing
igmp-snooping
pim dm
ip address 1.0.1.10 255.255.255.0
igmp enable
port access vlan 3
· Device C:
ntp-service enable
· Device D:
ntp-service enable
As shown in Figure 4, configure NTP authentication in client/server mode so that all devices can be synchronized to Device A, the NTP server.
Hardware |
Software version |
Release 6555P01 |
S9820-64H switch |
Release 6555P01 |
Procedures
# Enable NTP authentication on Device A.
[DeviceA] ntp-service authentication enable
# Set an authentication key, and input the key in plain text.
[DeviceA] ntp-service authentication-keyid 42 authentication-mode md5 simple aNiceKey
# Specify the key as a trusted key.
[DeviceA] ntp-service reliable authentication-keyid 42
# Enable NTP authentication on Device B.
[DeviceB] ntp-service authentication enable
[DeviceB] ntp-service authentication-keyid 42 authentication-mode md5 simple aNiceKey
[DeviceB] ntp-service reliable authentication-keyid 42
# Specify Device A as the NTP server of Device B, and associate the server with key 42.
[DeviceB] ntp-service unicast-server 1.0.1.11 authentication-keyid 42
# Enable NTP authentication on Device C.
[DeviceC] ntp-service authentication enable
[DeviceC] ntp-service authentication-keyid 42 authentication-mode md5 simple aNiceKey
[DeviceC] ntp-service reliable authentication-keyid 42
# Specify Device A as the NTP server of Device C, and associate the server with key 42.
[DeviceC] ntp-service unicast-server 1.0.1.11 authentication-keyid 42
Clock stratum: 3
Local mode: client
Leap indicator: 00
Clock jitter: 0.005096 s
Root delay: 0.00655 ms
Root dispersion: 1.15869 ms
Reference time: d0c62687.ab1bba7d Mon, Sep 6 2019 16:06:26.764
[1245]1.0.1.11 127.127.1.0 2 1 64 519 -0.0 0.0065 0.0
Total sessions : 1
Configuration files
· Device A:
ntp-service enable
ntp-service authentication-keyid 42 authentication-mode md5 cipher $c$3$4j3SKCgQWBK3Un41B9U0JXzJX9i7IuNoSqi
· Device B:
ntp-service enable
ntp-service authentication-keyid 42 authentication-mode md5 cipher $c$3$22eIc8l796cpudZqiaAZ2SLzIfrgzFTVYn8X
· Device C:
ntp-service enable
ntp-service authentication-keyid 42 authentication-mode md5 cipher $c$3$XJzVmJ1TJbWyYAXpPXxF7JiEOZag8CehibM8
Example: Configuring SNTP
As shown in Figure 5, configure SNTP so that all devices can be synchronized to Device A, the NTP server.
Hardware |
Software version |
Release 6555P01 |
S9820-64H switch |
Release 6555P01 |
Procedures
# Enable the SNTP service.
[DeviceB] sntp enable
# Specify Device A as the NTP server for Device B.
[DeviceB] sntp unicast-server 1.0.1.11
[DeviceC] sntp enable
# Specify Device A as the NTP server for Device C.
[DeviceC] sntp unicast-server 1.0.1.11
# Verify that an SNTP association has been established between Device B and Device A, and Device B has synchronized to Device A.
[DeviceB] display sntp sessions
SNTP server Stratum Version Last receive time
1.0.1.11 2 4 Thu, Sep 6 2019 17:25:09.121 (Synced)
Configuration files
· Device A:
ntp-service enable
· Device B:
sntp enable
· Device C:
sntp enable
As shown in Figure 1, configure IPv6 NTP client/server mode so that all devices can synchronize to Device A, the NTP server.
Figure 6 Network diagram
Hardware |
Software version |
Release 6555P01 |
S9820-64H switch |
Release 6555P01 |
Procedures
# Assign an IPv6 address to VLAN-interface 2.
[DeviceA] interface vlan-interface 2
[DeviceA-Vlan-interface2] ipv6 address 3000::34 64
# Assign an IPv6 address to each interface. (Details not shown.)
[DeviceB] ntp-service unicast-server 3000::34
[DeviceC] ntp-service unicast-server 3000::34
Clock stratum: 3
System peer: 3000::34
Local mode: client
Reference clock ID: 95.197.17.40
Leap indicator: 00
# Verify that an IPv6 NTP association has been established between Device B and Device A.
[DeviceB] display ntp-service ipv6 sessions
Source: [12345] 3000::34
Reference: 127.127.1.0 Clock stratum: 2
Reachabilities: 3 Poll interval: 64
Last receive time: 62 Offset: 0.1272
Roundtrip delay: 1.8158 Dispersion: 188.47
Total sessions: 1
Configuration files
· Device A:
ipv6 address 3000::34/64
ntp-service enable
· Device B:
ipv6 address 3000::35/64
ntp-service enable
ntp-service ipv6 unicast-server 3000::34
· Device C:
ipv6 address 3000::36/64
ntp-service enable
As shown in Figure 3, the devices are on different network segments. Configure IPv6 NTP multicast mode so that all the devices on can synchronize to Device C, the NTP server.
Figure 7 Network diagram
Hardware |
Software version |
Release 6555P01 |
S9820-64H switch |
Release 6555P01 |
Procedures
# Configure routing protocols so that all devices can reach each other. (Details not shown.)
[DeviceC-Vlan-interface2] ipv6 address 3000::2 64
# Configure Device C to operate in IPv6 multicast server mode and send multicast messages from VLAN-interface 2.
[DeviceC-Vlan-interface2] ntp-service ipv6 multicast-server ff24::1
[DeviceC-Vlan-interface2] quit
# Configure routing protocols and assign an IP address to each interface so that all devices can reach each other. (Details not shown.)
# Configure Device D to operate in IPv6 multicast client mode and receive multicast messages on VLAN-interface 2.
[DeviceD-Vlan-interface2] ntp-service ipv6 multicast-client ff24::1
[DeviceD-Vlan-interface2] quit
# Configure Device B to operate in IPv6 multicast client mode and receive multicast messages on VLAN-interface 2.
[DeviceB-Vlan-interface2] ntp-service ipv6 multicast-client ff24::1
Because Device A and Device C are on different subnets, you must enable IPv6 multicast functions on Device B before Device A can receive multicast messages from Device C.
# Enable IPv6 multicast functions.
[DeviceB] ipv6 multicast routing
[DeviceB-mrib6] quit
[DeviceB-Vlan-interface2] ipv6 pim dm
[DeviceB] vlan 3
[DeviceB-Vlan-interface3] mld enable
[DeviceB-Vlan-interface3] mld static-group ff24::1
[DeviceB] mld-snooping
[DeviceB-mld-snooping] quit
[DeviceB-HundredGigE 1/0/1] mld-snooping static-group ff24::1 vlan 3
# Configure Device A to operate in IPv6 multicast client mode and receive multicast messages on VLAN-interface 3.
[DeviceA-Vlan-interface3] ntp-service ipv6 multicast-client ff24::1
[DeviceA-Vlan-interface3] quit
[DeviceA] display ntp-service status
Clock stratum: 3
System peer: 3000::2
Local mode: bclient
Reference clock ID: 165.84.121.65
Leap indicator: 00
Configuration files
· Device A:
ntp-service enable
ipv6 address 2000::1/64
· Device B:
ntp-service enable
mld-snooping
ipv6 address 3000::1/64
ipv6 pim dm
ipv6 address 2000::2/64
mld enable
port access vlan 3
· Device C:
ntp-service enable
ipv6 address 3000::2/64
· Device D:
ntp-service enable
ipv6 address 3000::3/64
As shown in Figure 4, all devices are on the same network segment. Configure NTP authentication in broadcast mode so that all devices can synchronize to Device A, the NTP server.
Figure 8 Network diagram
Hardware |
Software version |
Release 6555P01 |
S9820-64H switch |
Release 6555P01 |
Procedures
Configure Device C
# Specify the local clock as the reference source, with the stratum level 2 on Device C.
# Enable NTP authentication on Device C. Configure an NTP authentication key, with the key ID of 88 and key value of 123456. Input the key in plain text, and specify it as a trusted key.
[DeviceC] ntp-service authentication-keyid 88 authentication-mode md5 simple 123456
[DeviceC] ntp-service reliable authentication-keyid 88
# Specify Device C as an NTP broadcast server, and associate key 88 with Device C.
[DeviceC] interface vlan-interface 2
[DeviceC-Vlan-interface2] ntp-service broadcast-server authentication-keyid 88
Configure Device A
# Enable NTP authentication on Device A. Configure an NTP authentication key, with the key ID of 88 and key value of 123456. Input the key in plain text, and specify it as a trusted key.
[DeviceA] ntp-service authentication-keyid 88 authentication-mode md5 simple 123456
[DeviceA] ntp-service reliable authentication-keyid 88
# Configure Device A to operate in NTP broadcast client mode and receive NTP broadcast messages on VLAN-interface 2.
[DeviceA-Vlan-interface2] ip address 3.0.1.33 24
Clock stratum: 3
Local mode: bclient
Leap indicator: 00
Clock jitter: 0.000092 s
Root delay: 2.42615 ms
Root dispersion: 1950.98877 ms
Reference time: d5eed631.2f498d71 Thu, Sep 6 2019 15:50:09.184
Configuration files
· Device A, Device B, Device D, and Device E:
ntp-service enable
ntp-service authentication-keyid 88 authentication-mode md5 cipher $c$3$pU6KvpS80MadhM2zM
CCSR07HX4qEbJhHvQ==
· Device C:
ntp-service enable
ntp-service authentication-keyid 88 authentication-mode md5 cipher $c$3$iJudDKiqCVO+gOaG53
63/fz4M3dQvHo2Fw==
ntp-service refclock-master 3
Related documentation
· H3C S6850 & S9850 Switch Series Network Management and Monitoring Configuration Guide-Release 655x
· H3C S6850 & S9850 Switch Series Network Management and Monitoring Command Reference-Release 655x
· H3C S9820-64H Switch Network Management and Monitoring Configuration Guide-Release 655x
· H3C S9820-64H Switch Network Management and Monitoring Command Reference-Release 655x
