- H3C S6850&S9850&S9820-64H Config Examples-Release 655x-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 14-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 15-GRE Tunnel Configuration Examples
- 16-GRE with OSPF Configuration Examples
- 17-OSPF Configuration Examples
- 18-IS-IS Configuration Examples
- 19-BGP Configuration Examples
- 20-Policy-Based Routing Configuration Examples
- 21-OSPFv3 Configuration Examples
- 22-IPv6 IS-IS Configuration Examples
- 23-Routing Policy Configuration Examples
- 24-IGMP Snooping Configuration Examples
- 25-IGMP Configuration Examples
- 26-BIDIR-PIM Configuration Examples
- 27-MLD Snooping Configuration Examples
- 28-IPv6 Multicast VLAN Configuration Examples
- 29-Basic MPLS Configuration Examples
- 30-MPLS L3VPN Configuration Examples
- 31-ACL Configuration Examples
- 32-Control Plane-Based QoS Policy Configuration Examples
- 33-Traffic Policing Configuration Examples
- 34-GTS and Rate Limiting Configuration Examples
- 35-Priority Mapping and Queue Scheduling Configuration Examples
- 36-Traffic Filtering Configuration Examples
- 37-AAA Configuration Examples
- 38-Port Security Configuration Examples
- 39-Portal Configuration Examples
- 40-SSH Configuration Examples
- 41-IP Source Guard Configuration Examples
- 42-Ethernet OAM Configuration Examples
- 43-CFD Configuration Examples
- 44-DLDP Configuration Examples
- 45-VRRP Configuration Examples
- 46-BFD Configuration Examples
- 47-NTP Configuration Examples
- 48-SNMP Configuration Examples
- 49-NQA Configuration Examples
- 50-Mirroring Configuration Examples
- 51-sFlow Configuration Examples
- 52-FCoE Configuration Examples
- 53-OpenFlow Configuration Examples
- 54-MAC Address Table Configuration Examples
- 55-Static Multicast MAC Address Entry Configuration Examples
- 56-IP Unnumbered Configuration Examples
- 57-MVRP Configuration Examples
- 58-MCE Configuration Examples
- 59-Congestion Avoidance and Queue Scheduling Configuration Examples
- 60-Attack Protection Configuration Examples
- 61-Smart Link Configuration Examples
- 62-RRPP Configuration Examples
- 63-BGP Route Selection Configuration Examples
- 64-IS-IS Route Summarization Configuration Examples
- 65-IRF Configuration Examples
- 66-MPLS OAM Configuration Examples
- 67-MPLS TE Configuration Examples
- 68-VXLAN Configuration Examples
- 69-NetStream Configuration Examples
- 70-DRNI Configuration Examples
- 71-DRNI and EVPN Configuration Examples
- 72-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 73-VCF Fabric Configuration Examples
- 74-PTP Configuration Examples
- 75-S-MLAG Configuration Examples
- 76-Puppet Configuration Examples
15-GRE Tunnel Configuration Examples | 87.07 KB |
H3C S6850 & S9850 & S9820-64H |
IPv6 over IPv4 GRE Tunnel |
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring an IPv6 over IPv4 GRE tunnel
Introduction
This document provides IPv6 over IPv4 GRE tunnel configuration examples.
This document assumes that you have basic knowledge of GRE.
As shown in Figure 1, Device A, Device B, and Device C are all on an IPv4 network. Dual stack devices Device A and Device B each connect to an IPv6 host.
Configure a GRE/IPv4 tunnel between Device A and Device B, so PC A and PC B can communicate with each other over the IPv4 network.
Analysis
To meet the network requirements, perform the following tasks:
· To enable the IPv6 hosts to communicate over the IPv4 network, specify the GRE tunnel mode as GRE/IPv4 and configure IPv6 addresses for the tunnel interfaces.
· To transmit packets between PC A and PC B through the GRE tunnel, configure a route reaching the destination network through the tunnel interface on Device A and Device B. You can configure the routes by using either of the following methods:
¡ Configure static routes, using the peer tunnel interface as the next hop or using the local tunnel interface as the outgoing interface.
¡ Enable a dynamic routing protocol on both the tunnel interfaces and the Layer 3 interfaces connected to PC A and PC B.
· For both ends of the GRE tunnel to reach each other, configure a static route reaching the remote end on Device A and Device B.
Hardware |
Software version |
S6850 switch series S9850 switch series |
Release 6555P01 |
S9820-64H switch |
Release 6555P01 |
When you configure the GRE tunnel, follow these restrictions and guidelines:
· You must configure the tunnel source address and destination address at both ends of the tunnel. The tunnel source or destination address at one end must be the tunnel destination or source address at the other end.
· Encapsulated packets cannot be forwarded on Layer 3 according to the destination IP addresses and routing tables. You must create a service loopback group of the tunnel service type to loop encapsulated packets back to the forwarding module for Layer 3 forwarding.
Procedures
Configuring Device A
# Configure VLAN-interface 20.
[DeviceA] vlan 20
[DeviceA-vlan20] port hundredgige 1/0/1
[DeviceA-vlan20] quit
[DeviceA] interface vlan-interface 20
[DeviceA-vlan-interface20] ipv6 address 1001::1 64
[DeviceA-vlan-interface20] quit
# Configure other interfaces in the same way VLAN-interface 20 is configured. (Details not shown.)
# Create service loopback group 1, and specify its service type as tunnel.
[DeviceA] service-loopback group 1 type tunnel
# Add HundredGigE 1/0/3 to service loopback group 1.
[DeviceA] interface hundredgige 1/0/3
[DeviceA-HundredGigE1/0/3] port service-loopback group 1
[DeviceA-HundredGigE1/0/3] quit
# Create a tunnel interface named Tunnel 0, and specify the tunnel mode as GRE/IPv4.
[DeviceA] interface tunnel 0 mode gre
# Configure an IPv6 address for tunnel interface Tunnel 0.
[DeviceA-Tunnel0] ipv6 address 3001::1 64
# Configure the source address of tunnel interface Tunnel 0 as the IP address of VLAN-interface 10.
[DeviceA-Tunnel0] source 192.13.2.2
# Configure the destination address of tunnel interface Tunnel 0 as the IP address of VLAN-interface 11 on Device B.
[DeviceA-Tunnel0] destination 131.108.5.2
[DeviceA-Tunnel0] quit
# Configure a static route reaching PC B through tunnel interface Tunnel 0.
[DeviceA] ipv6 route-static 2001:: 64 tunnel 0
# Configure a static route reaching the remote end of the GRE tunnel.
[DeviceA] ip route-static 131.108.5.2 255.255.255.0 192.13.2.1
Configuring Device B
[DeviceB] vlan 20
[DeviceB-vlan20] port hundredgige 1/0/1
[DeviceB] interface vlan-interface 20
[DeviceB-Vlan-interface20] ipv6 address 2001::1 64
[DeviceB-Vlan-interface20] quit
[DeviceB] service-loopback group 1 type tunnel
[DeviceB] interface hundredgige 1/0/3
[DeviceB-HundredGigE1/0/3] port service-loopback group 1
[DeviceB-HundredGigE1/0/3] quit
[DeviceB] interface tunnel 0 mode gre
[DeviceB-Tunnel0] ipv6 address 3001::2 64
# Configure the source address of tunnel interface Tunnel 0 as the IP address of VLAN-interface 11.
[DeviceB-Tunnel0] source 131.108.5.2
# Configure the destination address of tunnel interface Tunnel 0 as the IP address of VLAN-interface 10 on Device A.
[DeviceB-Tunnel0] destination 192.13.2.2
[DeviceB-Tunnel0] quit
# Configure a static route reaching PC A through tunnel interface Tunnel 0.
[DeviceB] ipv6 route-static 1001:: 64 Tunnel 0
[DeviceB] ip route-static 192.13.2.2 255.255.255.0 131.108.5.1
Configuring Device C
# Configure VLAN-interface 10.
<DeviceC> system-view
[DeviceC] vlan 10
[DeviceC-vlan10] port hundredgige 1/0/1
[DeviceC-vlan10] quit
[DeviceC] interface Vlan-interface 10
[DeviceC-Vlan-interface10] ip address 192.13.2.1 24
[DeviceC-Vlan-interface10] quit
# Configure VLAN-interface 11.
[DeviceC] vlan 11
[DeviceC-vlan11] port hundredgige 1/0/2
[DeviceC-vlan11] quit
[DeviceC] interface vlan-interface 11
[DeviceC-Vlan-interface11] ip address 131.108.5.1 24
[DeviceC-Vlan-interface11] quit
# Verify that PC A and PC B can ping each other successfully. This example uses PC A to ping PC B.
C:\>ping6 2001::2
Pinging 2001::2
from 1001::1 with 32 bytes of data:
Reply from 2001::2: bytes=32 time<1ms
Ping statistics for 2001::2:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Configuration files
· Device A:
vlan 10
vlan 20
interface Vlan-interface10
ip address 192.13.2.2 255.255.255.0
interface Vlan-interface20
ipv6 address 1001::1/64
interface HundredGigE1/0/1
port link-mode bridge
port access vlan 20
interface HundredGigE1/0/2
port access vlan 10
interface HundredGigE1/0/3
interface Tunnel0 mode gre
ipv6 address 3001::1/64
source 192.13.2.2
ipv6 route-static 2001:: 64 Tunnel 0
· Device B:
vlan 11
vlan 20
interface Vlan-interface11
ip address 131.108.5.2 255.255.255.0
ipv6 address 2001::1/64
port access vlan 20
port access vlan 11
ipv6 address 3001::2/64
source 131.108.5.2
· Device C:
vlan 10 to 11
ip address 192.13.2.1 255.255.255.0
ip address 131.108.5.1 255.255.255.0
port access vlan 10
port access vlan 11
Related documentation
· H3C S6850 & S9850 Switch Series Layer 3—IP Services Configuration Guide-Release 655x
· H3C S6850 & S9850 Switch Series Layer 3—IP Services Command Reference-Release 655x
· H3C S9820-64H Switch Layer 3—IP Services Configuration Guide-Release 655x
· H3C S9820-64H Switch Layer 3—IP Services Command Reference-Release 655x
· H3C S6850 & S9850 Switch Series Layer 3—IP Routing Configuration Guide-Release 655x
· H3C S6850 & S9850 Switch Series Layer 3—IP Routing Command Reference-Release 655x
· H3C S9820-64H Switch Layer 3—IP Routing Configuration Guide-Release 655x
· H3C S9820-64H Switch Layer 3—IP Routing Command Reference-Release 655x
