H3C S6890 Switch Series Configuration Examples-Release 27xx-6W100
HomeSupportSwitchesS6890 SeriesConfigure & DeployConfiguration ExamplesH3C S6890 Switch Series Configuration Examples-Release 27xx-6W100
Table of Contents
Related Documents
53-Congestion Avoidance and Queue Scheduling Configuration Examples
Document version: 6W100-20190628
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides examples for configuring congestion avoidance and queue scheduling profiles.
This document assumes that you have basic knowledge of congestion avoidance and queue scheduling profiles.
Example: Configuring congestion avoidance and queue scheduling
As shown in Figure 1, three types of traffic come from the Internet to the device through the gateway.
·          Voice trafficTransmitted in VLAN 6 and carries 802.1p priority 6.
·          Video trafficTransmitted in VLAN 4 and carries 802.1p priority 4.
·          Data trafficTransmitted in VLAN 2 and carries 802.1p priority 2.
Configure congestion avoidance and queue scheduling on the device to meet the following requirements:
·          The voice traffic, video traffic, and data traffic are scheduled in the ratio of 1:2:2 when congestion occurs.
·          WRED drop is used when serious congestion occurs.
Figure 1 Network diagram
Analysis
To configure congestion avoidance and queue scheduling, you must perform the following tasks:
·          To assign different types of traffic to different queues, configure the inbound interface to trust the 802.1p priority in packets.
·          To schedule the three types of traffic in the ratio of 1:2:2, assign their queues to one WRR group and configure weights for these queues.
·          To minimize performance degradation for different types of traffic, use the drop parameters in Table 1.
Table 1 Drop parameters
Traffic type
Packet color
Lower limit
Upper limit
Drop probability
Voice
Yellow
1000
1500
3%
Red
500
1000
30%
Video
Yellow
1000
1500
2%
Red
500
1000
20%
Data
Yellow
1000
1500
1%
Red
500
1000
10%
Software versions used
This configuration example was created and verified on S6890-CMW710-R2712.
Procedures
1.        Allow VLANs for different types of traffic to pass through:
# Create three VLANs .
[Device] vlan 2
[Device-vlan2] quit
[Device] vlan 4
[Device-vlan4] quit
[Device] vlan 6
[Device-vlan6] quit
# Assign interfaces to VLANs.
[Device] interface hundredgige 3/0/1
[Device-HundredGigE3/0/1] port link-type trunk
[Device-HundredGigE3/0/1] port trunk permit vlan 2 4 6
[Device-HundredGigE3/0/1] quit
[Device] interface ten-gigabitethernet 3/0/3
[Device-Ten-GigabitEthernet3/0/3] port link-type trunk
[Device-Ten-GigabitEthernet3/0/3] port trunk permit vlan 2 4 6
[Device-Ten-GigabitEthernet3/0/3] quit
[Device] interface ten-gigabitethernet 3/0/4
[Device-Ten-GigabitEthernet3/0/4] port link-type trunk
[Device-Ten-GigabitEthernet3/0/4] port trunk permit vlan 2 4 6
[Device-Ten-GigabitEthernet3/0/4] quit
2.        Configure interface HundredGigE 3/0/1 to trust the 802.1p priority in packets.
[Device-HundredGigE3/0/1] qos trust dot1p
3.        Configure WRR:
# Display the 802.1p-to-local precedence map to determine the local precedence for each type of traffic.
[Device] display qos map-table inbound dot1p-lp
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
# Enable weight-based WRR on Ten-GigabitEthernet 3/0/3.
[Device-Ten-GigabitEthernet3/0/3] qos wrr weight
# Configure the weights of queue 1 (for data traffic), queue 4 (for video traffic), and queue 6 (for voice traffic) as 2, 2, and 1, respectively.
[Device-Ten-GigabitEthernet3/0/3] qos wrr 1 group 1 weight 2
[Device-Ten-GigabitEthernet3/0/3] qos wrr 4 group 1 weight 2
[Device-Ten-GigabitEthernet3/0/3] qos wrr 6 group 1 weight 1
# Enable weight-based WRR on Ten-GigabitEthernet 3/0/4.
[Device-Ten-GigabitEthernet3/0/4] qos wrr weight
[Device-Ten-GigabitEthernet3/0/4] qos wrr 1 group 1 weight 2
[Device-Ten-GigabitEthernet3/0/4] qos wrr 4 group 1 weight 2
[Device-Ten-GigabitEthernet3/0/4] qos wrr 6 group 1 weight 1
4.        Configure congestion avoidance:
# Configure a WRED table.
[Device] qos wred queue table droppolicy
[Device-wred-table-droppolicy] queue 6 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 3
[Device-wred-table-droppolicy] queue 6 drop-level 2 low-limit 500 high-limit 1000 discard-probability 30
[Device-wred-table-droppolicy] queue 4 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 2
[Device-wred-table-droppolicy] queue 4 drop-level 2 low-limit 500 high-limit 1000 discard-probability 20
[Device-wred-table-droppolicy] queue 1 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 1
[Device-wred-table-droppolicy] queue 1 drop-level 2 low-limit 500 high-limit 1000 discard-probability 10
[Device-wred-table-droppolicy] quit
# Apply the WRED table to interfaces Ten-GigabitEthernet 3/0/3 and Ten-GigabitEthernet 3/0/4.
[Device-Ten-GigabitEthernet3/0/3] qos wred apply droppolicy
[Device-Ten-GigabitEthernet3/0/4] qos wred apply droppolicy
# Verify the WRR configuration on interfaces Ten-GigabitEthernet 3/0/3 and Ten-GigabitEthernet 3/0/4.
[Device] display qos queue wrr interface
Interface: Ten-GigabitEthernet3/0/3
 Output queue: Weighted Round Robin queuing
 Queue ID     Queue name     Group     Weight
 0            be             1         1
 1            af1            1         2
 2            af2            1         3
 3            af3            1         4
 4            af4            1         2
 5            ef             1         6
 6            cs6            1         1
 7            cs7            1         8
Interface: Ten-GigabitEthernet3/0/4
 0            be             1         1
 1            af1            1         2
 2            af2            1         3
 3            af3            1         4
 4            af4            1         2
 5            ef             1         6
 6            cs6            1         1
 7            cs7            1         8
# Display the WRED table configuration.
Table name: droppolicy
Table type: Queue based WRED
QID   gmin  gmax  gprob  ymin  ymax  yprob  rmin  rmax  rprob  exponent  ECN
0     100   1000  10     100   1000  10     100   1000  10     9         N
1     100   1000  10     1000  1500  1      500   1000  10     9         N
2     100   1000  10     100   1000  10     100   1000  10     9         N
3     100   1000  10     100   1000  10     100   1000  10     9         N
4     100   1000  10     1000  1500  2      500   1000  20     9         N
5     100   1000  10     100   1000  10     100   1000  10     9         N
6     100   1000  10     1000  1500  3      500   1000  30     9         N
7     100   1000  10     100   1000  10     100   1000  10     9         N
Configuration files
vlan 1
vlan 2
vlan 4
vlan 6
interface Ten-GigabitEthernet3/0/3
 port link-mode bridge
 port trunk permit vlan 1 to 2 4 6
 qos wrr weight
 qos wrr af1 group 1 weight 2
 qos wrr af4 group 1 weight 2
 qos wrr cs6 group 1 weight 1
interface Ten-GigabitEthernet3/0/4
 qos wrr weight
interface HundredGigE3/0/1
return
Related documentation
·          H3C S6890 Switch Series ACL and QoS Command Reference (R27xx)
·          H3C S6890 Switch Series  ACL and QoS Configuration Guide (R27xx)
  • Become a Partner
  • Partner Resources
