- H3C S6890 Switch Series Configuration Examples-Release 27xx-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-GRE Tunnel Configuration Examples
- 14-GRE with OSPF Configuration Examples
- 15-OSPF Configuration Examples
- 16-IS-IS Configuration Examples
- 17-BGP Configuration Examples
- 18-Policy-Based Routing Configuration Examples
- 19-OSPFv3 Configuration Examples
- 20-IPv6 IS-IS Configuration Examples
- 21-Routing Policy Configuration Examples
- 22-IGMP Snooping Configuration Examples
- 23-IGMP Configuration Examples
- 24-Multicast VPN Configuration Examples
- 25-Basic MPLS Configuration Examples
- 26-MPLS L3VPN Configuration Examples
- 27-ACL Configuration Examples
- 28-Control Plane-Based QoS Policy Configuration Examples
- 29-Traffic Policing Configuration Examples
- 30-GTS and Rate Limiting Configuration Examples
- 31-Priority Mapping and Queue Scheduling Configuration Examples
- 32-Traffic Filtering Configuration Examples
- 33-AAA Configuration Examples
- 34-SSH Configuration Examples
- 35-IP Source Guard Configuration Examples
- 36-Ethernet OAM Configuration Examples
- 37-CFD Configuration Examples
- 38-DLDP Configuration Examples
- 39-VRRP Configuration Examples
- 40-BFD Configuration Examples
- 41-NTP Configuration Examples
- 42-SNMP Configuration Examples
- 43-NQA Configuration Examples
- 44-Mirroring Configuration Examples
- 45-sFlow Configuration Examples
- 46-FCoE Configuration Examples
- 47-OpenFlow Configuration Examples
- 48-MAC Address Table Configuration Examples
- 49-Static Multicast MAC Address Entry Configuration Examples
- 50-IP Unnumbered Configuration Examples
- 51-MVRP Configuration Examples
- 52-MCE Configuration Examples
- 53-Congestion Avoidance and Queue Scheduling Configuration Examples
- 54-Attack Protection Configuration Examples
- 55-Smart Link Configuration Examples
- 56-RRPP Configuration Examples
- 57-BGP Route Selection Configuration Examples
- 58-IS-IS Route Summarization Configuration Examples
- 59-IRF Configuration Examples
- 60-MPLS OAM Configuration Examples
- 61-MPLS TE Configuration Examples
- 62-VXLAN Configuration Examples
- 63-DRNI Configuration Examples
- 64-DRNI and EVPN Configuration Examples
- 65-VCF Fabric Configuration Examples
49-Static Multicast MAC Address Entry Configuration Examples | 66.48 KB |
H3C S6890 Switch Series |
Static Multicast MAC Address Entry |
Document version: 6W100-20190628
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides configuration examples of static multicast MAC address entries.
This document assumes that you have basic knowledge of multicast MAC addresses.
Example: Configuring static multicast MAC address entries
As shown in Figure 1, Router A runs IGMP and acts as the IGMP querier. Switch A does not run a Layer 2 multicast protocol.
Configure a static multicast MAC address entry on Switch A so that only Host A and Host C can receive multicast data for multicast group 224.1.1.1.
Analysis
Multicast MAC address entries guide Layer 2 multicast forwarding. They can be dynamically created through Layer 2 multicast protocols or manually configured by binding multicast MAC addresses and ports.
In this example, Switch A does not run a Layer 2 multicast protocol. To control destination ports of Layer 2 multicast data, configure a static multicast MAC address entry on Switch A.
Software versions used
This example was created and verified on S6890-CMW710-R2712.
When you configure multicast MAC address entries, follow these guidelines:
· You must specify an unused multicast MAC address in a manually configured multicast MAC address entry.
· By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
# On Switch A, create VLAN 100.
[SwitchA] vlan 100
[SwitchA-vlan100] quit
# Configure Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/4 to operate in Layer 2 mode, and assign the ports to VLAN 100.
[SwitchA] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/4
[SwitchA-if-range] port access vlan 100
[SwitchA-if-range] quit
# Translate the multicast IP address 224.1.1.1 to a multicast MAC address (0100-5e01-0101). (Details not shown.)
# Create a static entry for the multicast MAC address 0100-5e01-0101 with Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/4 in VLAN 100 as outgoing ports.
[SwitchA] mac-address multicast 0100-5e01-0101 interface ten-gigabitethernet 1/0/2 ten-gigabitethernet 1/0/4 vlan 100
# Display static multicast MAC address entries for VLAN 100 on Switch A.
[SwitchA] display mac-address multicast vlan 100
MAC Address VLAN ID State Port/NickName Aging
0100-5e01-0101 100 Multicast XGE1/0/2 N
XGE1/0/4
The output shows that Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/4 have become outgoing ports of the multicast MAC group 0100-5e01-0101.
Configuration files
vlan 100
port link-mode bridge
interface Ten-GigabitEthernet1/0/4
mac-address multicast 0100-5e01-0101 interface Ten-GigabitEthernet1/0/2 Ten-GigabitEthernet1/0/4 vlan 100
Related documentation
· H3C S6890 Switch Series IP Multicast Command Reference (Release 27xx)
· H3C S6890 Switch Series IP Multicast Configuration Guide (Release 27xx)
