H3C S6890 Switch Series Configuration Examples-Release 27xx-6W100
HomeSupportSwitchesS6890 SeriesConfigure & DeployConfiguration ExamplesH3C S6890 Switch Series Configuration Examples-Release 27xx-6W100
Table of Contents
Related Documents
42-SNMP Configuration Examples
42-SNMP Configuration Examples 389.56 KB
Document version: 6W100-20190628
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides SNMP configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of SNMP.
Example: Configuring SNMPv1 or SNMPv2c
As shown in Figure 1, an IMC server acts as the NMS and the device acts as the agent. The NMS uses SNMPv1/SNMPv2c to manage the SNMP agent, and the agent automatically sends notifications to report events to the NMS.
Figure 1 Network diagram
Software version used
This configuration example was created and verified on S6890-CMW710-R2712.
When you configure SNMPv1 or SNMPv2c, follow these restrictions and guidelines:
·          The configuration procedure is the same for SNMPv1 and SNMPv2c. This example uses SNMPv2c.
·          For the NMS to manage the SNMP agent, the SNMP settings on the agent and the NMS must match.
·          The NMS software configuration varies by vendor. This example uses the IMC PLAT 7.0 (E0202). For information about configuring the NMS, see the NMS manual.
Procedures
Configuring the SNMP agent
# Specify SNMPv2c, and create read-only community readtest and read and write community writetest.
<Agent> system-view
[Agent] snmp-agent sys-info version v2c
[Agent] snmp-agent community read readtest
[Agent] snmp-agent community write writetest
# Configure contact and physical location information for the agent.
[Agent] snmp-agent sys-info contact Mr.Wang-Tel:3306
[Agent] snmp-agent sys-info location telephone-closet,3rd-floor
# Enable SNMP notifications, specify the NMS at 192.168.100.4 as the SNMP trap destination, and use readtest as the community name.
[Agent] snmp-agent trap enable
[Agent] snmp-agent target-host trap address udp-domain 192.168.100.4 params securityname readtest
Configuring the NMS
1.        Add the device (SNMP agent) to the IMC:
a.    Click the Resource tab.
b.    From the navigation tree, select Resource Management > Add Device.
c.    On the Add Device page, configure the following parameters:
-      Enter 192.168.100.68 in the Host Name/IP field.
-      Use the default values for other parameters.
Figure 2 Adding a device
2.        Configure SNMP parameters:
a.    Expand the SNMP Settings area.
b.    Click Configure.
c.    On the page that appears, configure the following parameters:
-      Select SNMPv2c from the Parameter Type list.
-      Enter readtest in the Read-Only Community String field.
-      Enter writetest in the Read-Write Community String field.
-      Click OK.
Figure 3 Configuring SNMP parameters
3.        On the Add Device page, click OK.
The device is successfully added to the IMC, as shown in Figure 4.
Figure 4 Device added
1.        Verify that the agent sends notifications to the NMS when the link state of an interface changes:
a.    Execute the shutdown or undo shutdown command on an idle interface to shut down or bring up the interface.
b.    Click the Alarm tab.
c.    From the navigation tree, select Alarm Browse > All Alarms.
Configuration files
 snmp-agent
 snmp-agent trap enable arp
snmp-agent trap enable syslog
ame readtest
Example: Configuring SNMPv3
As shown in Figure 5, an IMC server acts as the NMS and the device acts as the agent. The NMS uses SNMPv3 to manage the SNMP agent, and the agent automatically sends notifications to report events to the NMS.
Figure 5 Network diagram
When you configure SNMPv3, follow these restrictions and guidelines:
·          SNMPv3 supports VACM and RBAC access control modes. This example provides SNMPv3 configuration procedures in both modes. See "Configuring the SNMP agent in RBAC mode" and "Configuring the SNMP agent in VACM mode"..
·          For the NMS to receive notifications from the agent, make sure the following configurations are the same on the NMS and the SNMP agent:
¡  SNMPv3 username.
¡  SNMP protocol version.
¡  Authentication algorithm.
¡  Privacy algorithm.
¡  Authentication and privacy keys.
Procedures
# Enable SNMPv3.
<Agent> system-view
[Agent] snmp-agent sys-info version v3
# Create user role test, and assign test read and write access to the objects under the internet subtree (OID: 1.3.6.1).
[Agent] role name test
[Agent-role-test] rule 1 permit read write oid 1.3.6.1
[Agent-role-test] quit
# Create SNMPv3 user managev3user. Assign user role test to managev3user. Set the authentication algorithm to sha, authentication key to 123456TESTauth&!, encryption algorithm to aes128, and encyption key to 123456TESTencr&!.
[Agent] snmp-agent usm-user v3 managev3user user-role test simple authentication-mode sha 123456TESTauth&! privacy-mode aes128 123456TESTencr&!
# Enable SNMP notifications.
# Specify the NMS at 192.168.100.4 as the trap destination, and set the username to managev3user for the traps.
[Agent] snmp-agent target-host trap address udp-domain 192.168.100.4 params securityname managev3user v3 privacy
# Enable SNMPv3.
<Agent> system-view
# Include the mib-2 (OID 1.3.6.1) subtree in the mibtest view.
[Agent] snmp-agent mib-view included mibtest 1.3.6.1
# Create SNMPv3 group managev3group, and specify the authentication with privacy security model for the group. Assign the group read, write, and notification accesses to the mibtest view.
[Agent] snmp-agent group v3 managev3group privacy read-view mibtest write-view mibtest notify-view mibtest
# Add user managev3user to SNMPv3 group managev3group, and set the authentication algorithm to sha, authentication key to 123456TESTauth&!, encryption algorithm to aes128, and encryption key to 123456TESTencr&!.
[Agent] snmp-agent usm-user v3 managev3user managev3group simple authentication-mode sha 123456TESTauth&! privacy-mode aes128 123456TESTencr&!
Configuring the NMS
1.        Add an SNMP template:
a.    Click the System tab.
b.    From the navigation tree, select Resource Management > SNMP Template.
c.    On the SNMP Template page, click Add.
d.    On the Add SNMP Template page, configure the following parameters:
-      Enter SNMPv3 in the Name field.
-      Select SNMPv3 Priv-Aes128 Auth-Sha from the Parameter Type list.
-      Enter managev3user in the Username field.
-      Enter 123456TESTauth&! in the Authentication Password field.
-      Enter 123456TESTencr&! in the Encryption Password field.
-      Click OK.
Figure 6 Adding an SNMP template
2.        Add the device (SNMP agent) to IMC:
Figure 7 Adding a device
3.        Configure SNMP parameters:
b.    Click Configure.
c.    Select the Select an Existing Template option.
d.    Select template name SNMPv3.
e.    Click OK.
Figure 8 Selecting an existing template
4.        On the Add Device page, click OK.
The device is successfully added to IMC, as shown in Figure 9.
Figure 9 Device added
Configuration files
SNMPv3 configuration in RBAC mode
 snmp-agent
 snmp-agent usm-user v3 managev3user user-role test cipher authentication-mode sha $c$3$5JaJZ6gNXlyNRq2FR2ELDT3QQH1exwJRWdYYq7eLfcBewuM5ncM= privacy-mode aes128 $c$3$+bbXZS4+PnsLDyr16OogzBckaLzR6XMDwZQuLBU8RM+dpw==
role name test
 rule 1 permit read oid 1.3.6.1
SNMPv3 configuration in VACM mode
 snmp-agent
notify-view mibtest
 snmp-agent mib-view included mibtest internet
 snmp-agent usm-user v3 managev3user managev3group cipher authentication-mode sha $c$3$5JaJZ6gNXlyNRq2FR2ELDT3QQH1exwJRWdYYq7eLfcBewuM5ncM= privacy-mode aes128 $c$3$+bbXZS4+PnsLDyr16OogzBckaLzR6XMDwZQuLBU8RM+dpw==
Related documentation
·          H3C S6890 Switch Series Network Management and Monitoring Command Reference (R27xx)
·          H3C S6890 Switch Series Network Management and Monitoring Configuration Guide (R27xx)
  • Become a Partner
  • Partner Resources
