08-MPLS Command Reference
HomeSupportRoutersH3C SR8800 Router SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10308-MPLS Command Reference
03-VPLS Commands
03-VPLS Commands 239.13 KB
bandwidth
bandwidth vpn-speed
undo bandwidth
View
VSI view
Default level
2: System level
vpn-speed: Upper speed limit of the VPLS instance in kbps, in the range of 64 to 4,194,303. The system automatically calculates a speed that is the greatest multiple of 64 kbps between 64 and the specified value.
Use the bandwidth command to set the upper speed limit of a VPLS instance.
Use the undo bandwidth command to restore the default.
By default, the upper speed limit of a VPLS instance is 102,400 kbps.
The bandwidth command, together with the broadcast-restrain command, defines a threshold that is used in suppressing the broadcast traffic (including broadcast, multicast, and unknown unicast traffic) of the VPLS instance. When the speed of the broadcast traffic exceeds the threshold, that is, the product of the speed limit and the broadcast suppression percentage, the extra broadcast traffic will be dropped.
This feature is available only when the system working mode is SPE. For more information about system working modes, see Fundamentals Configuration Guide.
# Set the upper speed limit of VPLS instance aaa to 10 Mbps.
[Sysname] vsi aaa static
[Sysname-vsi-aaa] bandwidth 10240
broadcast-restrain
broadcast-restrain ratio
undo broadcast-restrain
View
VSI view
Default level
2: System level
ratio: Broadcast suppression percentage of the VPLS instance, in the range of 1 to 100.
Use the broadcast-restrain command to set the broadcast suppression percentage of a VPLS instance.
Use the undo broadcast-restrain command to restore the default.
By default, the broadcast suppression percentage of a VPLS instance is 5.
This command, together with the bandwidth command, defines a threshold that is used in suppressing the broadcast traffic (including broadcast, multicast, and unknown unicast traffic) of the VPLS instance. When the speed of the broadcast traffic exceeds the product of the speed limit and this ratio, the extra broadcast traffic will be dropped.
# Set the broadcast suppression percentage of VPLS instance aaa to 10.
[Sysname-vsi-aaa] broadcast-restrain 10
description
View
VSI view
Default level
2: System level
text: Description for a VPLS instance, a string of 1 to 80 characters.
Use the description command to set a description for a VPLS instance.
Use the undo description command to remove the configuration.
By default, no description is set for a VPLS instance.
# Set the description of VPLS instance aaa to Aaa_Technologies_Co._Ltd..
[Sysname-vsi-aaa] description Aaa_Technologies_Co._Ltd.
display bgp vpls
display bgp vpls { all | group [ group-name ] | peer [ [ ip-address ] verbose ] | route-distinguisher route-distinguisher [ site-id site-id [ label-offset label-offset ] ] } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Specifies all VPLS information in the BGP routing table.
group group-name: Specifies a peer group by its name, a string of 1 to 47 characters.
ip-address: IP address of the peer.
verbose: Displays detailed information.
route-distinguisher route-distinguisher: Specifies the route distinguisher (RD), a string of 3 to 21 characters in the format of nn:nn or IP_address:nn.
site-id site-id: Specifies the site in the VPLS instance by its ID. The site ID ranges from 0 to 64.
label-offset label-offset: Specifies the label offset value, which is in the range of 0 to 65535.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display bgp vpls command to display the VPLS information in a BGP routing table.
# Display all VPLS information in the BGP routing table.
<Sysname> display bgp vpls all
 BGP Local Router ID : 2.2.2.9, Local AS number : 100
 Origin codes:i - IGP, e - EGP, ? - incomplete
 BGP.VPLS: 1 destination
 **Route Distinguisher: 100:1
 SITE ID    LB Offset    LB Size    LB Base    Nexthop    LocPref
 1          0            10         131346     3.3.3.9    100
Table 1 Output description
BGP Local Router ID
Router ID of the local BGP router
Local AS number
Number of the local AS
Origin codes
Route origin codes. Valid values include:
i - IGP (learned from within the AS)
e - EGP (learned through EGP)
? - incomplete (learned in any other way)
BGP.VPLS
Number of BGP VPLS
Route Distinguisher
Router distinguisher (RD)
SITE ID
ID of a site in the VPLS instance
LB Offset
Label offset value
LB Size
Size of the label block
LB Base
Initial label of the label block
Nexthop
Address of the next hop
LocPref
Local preference
# Display detailed information about VPLS peer 3.3.3.9 in the BGP routing table.
<Sysname> display bgp vpls peer 3.3.3.9 verbose
         Peer: 3.3.3.9   Local: 2.2.2.9
         Type: IBGP link
         BGP version 4, remote router ID 3.3.3.9
         BGP current state: Established, Up for 01h06m42s
         BGP last state: OpenConfirm
         Port:  Local - 1040      Remote - 179
         Configured: Active Hold Time: 180 sec   Keep Alive Time:60 sec
         Received  : Active Hold Time: 180 sec
         Negotiated: Active Hold Time: 180 sec   Keep Alive Time:60 sec
         Peer optional capabilities:
         Peer support bgp multi-protocol extended
         Peer support bgp route refresh capability
         Graceful Restart Capability: received
             Restart Timer Value of Peer: 150 seconds
             Forwarding State preserved by Peer for following Address families:
                 IPv4 Unicast
                 VPLS
         Address family IPv4 Unicast: advertised and received
         Address family VPLS: advertised and received
 Received: Total 26 messages, Update messages 2
 Sent: Total 28 messages, Update messages 2
 Threshold: 75%
 Minimum time between advertisement runs is 15 seconds
 Optional capabilities:
 Connect-interface has been configured
 Peer Preferred Value: 0
  BFD: Enabled
 Routing policy configured:
Table 2 Output description
Peer
Local
IP address of the local router.
BGP type.
BGP version 4
BGP version information.
remote router ID
IP address of the remote router.
BGP current state
Current status of the BGP session.
BGP current event
Current event of the BGP session.
BGP last state
State that the BGP session was in before transitioning to the current status.
Port
Local and remote port numbers of the BGP session.
Configured
Settings of the local timers
Received
Received active hold interval.
Negotiated
Negotiated timer settings.
Optional peer capabilities. In this example, the peer supports BGP multicast protocol extension and route refresh.
Information about Graceful Restart (GR) capability, including the peer restart timer and the address families for which forwarding state is preserved.
IPv4 unicast address family capability.
Address family VPLS
VPLS address family.
Received
Counts of received messages, including the total number of received messages and the number of received update messages.
Sent
Counts of sent messages, including the total number of sent messages and the number of sent update messages.
Maximum number of routes allowed.
Threshold
Threshold value. When the number of routes reaches the maximum number of routes allowed multiplied by this threshold value, an alarm is issued.
Minimum time between advertisement runs is XX seconds
Minimum advertising interval.
Optional capabilities. In this example, route refresh capability is enabled and the directly connected interface is configured.
Peer preference value.
BFD
Whether BFD is enabled for the peer.
Routing policy configured for the peer.
# Display the VPLS information for RD 100:1 in the BGP routing table.
<Sysname> display bgp vpls route-distinguisher 100:1
 BGP Local Router ID : 2.2.2.9, Local AS Number : 100
 8          0            10         524624     3.3.3.9    100
Table 3 Output description
BGP Local Router ID
Local AS Number
Origin codes
BGP.VPLS
Number of BGP VPLS
SITE ID
LB Offset
Label offset value
LB Size
LB Base
Nexthop
LocPref
Local preference
# Display the VPLS information for specified RD, CE number, and label offset in the BGP routing table.
<Sysname> display bgp vpls route-distinguisher 100:1 site-id 4 label-offset 0
 BGP Local router ID : 2.2.2.9, local AS number : 100
 *Nexthop : 3.3.3.9    ,  Locpref      : 100
 Metric   : 133        ,  Flag         : 0x85
 LB Base  : 132096     ,  LB NewBase   : 0
 LB Size  : 10         ,  Label Offset : 0
 MTU      : 1500       ,  Encap Type   : Ethernet VLAN
 Path Attribute : RefCount : 1, MED 133: , AS Path : 200
Table 4 Output description
BGP Local router ID
Router ID of the local BGP router.
local AS number
Number of the local AS.
Origin codes
·       i - IGP (learned from within the AS).
·       e - EGP (learned through EGP).
·       ? - incomplete (learned in any other way).
*Nexthop
Address of the next hop.
Locpref
Local preference.
Metric
Cost value.
Flag
Current status of the label:
·       0x0001 (BGP_VPLS_LB_NOT_SENTTO_VPLS)
·       0x0002 (BGP_VPLS_LB_SENTTO_VPLS)
·       0x0004 (BGP_VPLS_LB_SELECTED)
·       0x0008 (BGP_VPLS_LB_ASBR_TNLDOWN)
·       0x0010 (BGP_VPLS_LB_FROM_RR_IBGP)
·       0x0020 (BGP_VPLS_LB_FROM_RR_EBGP)
·       0x0040 (BGP_VPLS_LB_FROM_IBGP)
·       0x0080 (BGP_VPLS_LB_FROM_EBGP)
·       0x0085 (BGP_VPLS_LB_NOT_SENTTO_VPLS | BGP_VPLS_LB_SELECTED | BGP_VPLS_LB_FROM_EBGP)
When the VSI is in state of UP, the flag is 0x0046.
LB Offset
Label offset value.
LB Size
Size of the label block.
LB Base
Initial label of the label block.
LB NewBase
New label block.
RefCount
Label reference count.
MED
Cost value.
AS Path
AS path of the route.
MTU
Maximum transmission unit at Layer 2.
Encap Type
Encapsulation type.
display l2vpn fast-switch-group
display l2vpn fast-switch-group [ group-index ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-index: PW group index, in the range of 0 to 4095.
Use the display l2vpn fast-switch-group command to display information about one or all fast switching groups.
# Display information about all fast switching groups in user view.
<Sysname> display l2vpn fast-switch-group
Fast group index       :0
Peer router ID         :20.0.0.1
Backup-peer router ID  :20.0.0.2
In used peer router ID :20.0.0.1
Reference counter      :1
Fast group index       :1
Peer router ID         :30.0.0.1
Backup-peer router ID  :30.0.0.2
In used peer router ID  :30.0.0.1
Table 5 Output description
Fast group index
Index of the fast switching group
Peer router ID
Address of the VPLS instance peer
Address of the backup peer
Address of the peer that is in use
Reference counter
Number of times that the group has been referenced
display mac-address vsi
display mac-address vsi [ vsi-name ] [ blackhole | dynamic | static ] [ count ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vsi-name: Name of the VPLS instance, a case-insensitive string of 1 to 31 characters. Hyphens (-) are not allowed.
blackhole: Black hole MAC forwarding entries.
dynamic: Dynamic MAC forwarding entries.
static: Static MAC forwarding entries.
count: Number of MAC forwarding entries.
Use the display mac-address vsi command to display the MAC address table information of a specific VPLS instance or all VPLS instances.
Related commands: vsi; mac-address (Layer 2—LAN Switching Command Reference).
# Display information about the MAC address table.
<Sysname> display mac-address vsi
MAC ADDR         STATE            VSI ID   Peer               AGING
0000-0008-23b3   Dynamic          0        1                  AGING
0000-0008-23b2   Dynamic          0        1                  AGING
0000-0008-23b1   Dynamic          0        1                  AGING
0000-0008-23b0   Dynamic          0        1                  AGING
0000-0008-23af   Dynamic          0        1                  AGING
0000-0008-23ae   Dynamic          0        1                  AGING
0000-0008-23ad   Dynamic          0        1                  AGING
0000-0008-23ac   Dynamic          0        1                  AGING
# Display the total number of entries in the MAC address table.
<Sysname> display mac-address vsi count
 100 mac address(es) found
Table 6 Output description
MAC ADDR
MAC address
STATE
Status of the MAC address
VSI ID
ID of the VPLS instance
Peer
Sequence number of the peer in the VPLS instance
AGING
Whether the MAC address of the VPLS instance may get aged, AGING or NOAGING
display mpls l2vpn fib ac vpls
display mpls l2vpn fib ac vpls [ vsi vsi-name | interface interface-type interface-number [ service-instance service-instanceid ] [ slot slot-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vsi vsi-name: Specifies the VPLS instance name, a case-insensitive string of 1 to 31 characters. Hyphens (-) are not allowed.
interface interface-type interface-number: Specifies the interface connecting a CE by its type and number.
service-instance service-instanceid: Displays the AC information of the specified service instance. service-instanceid is the service instance ID, in the range of 1 to 4094. Currently, the router does not support this option.
slot slot-number: Displays the AC information on a card. slot-number indicates the number of the slot where the card resides.
verbose: Displays the detailed information.
Use the display mpls l2vpn fib ac vpls command to display the AC information of one or all VPLS instances.
# Display the AC information of all VPLS instances.
<Sysname> display mpls l2vpn fib ac vpls
Total VSI Entry:1          Total AC Entry:1
In Interface     ServID  VSIName              VSIIndex LinkID
GE3/1/1          0        vsi1                 1        1
Table 7 Output description
Total VSI Entry
Total number of VSI entries, which is displayed only when you display all VPLS AC entries.
Total AC Entry
Total number of VPLS AC entries, which is displayed only when you display all VPLS AC entries.
In Interface
Incoming interface—the interface bound to an L2VPN.
ServID
Service instance ID. The router does not support this field and displays 0 for this field.
VSIName
VPLS instance name.
VSIIndex
VPLS instance index.
LinkID
Link ID of an AC in the VPLS instance.
# Display the detailed AC information of all VPLS instances.
<Sysname> display mpls l2vpn fib ac vpls verbose
 Total VSI Entry:2           Total AC Entry:2
  VSI Name: aaa                             VSI Index: 0
  **In Interface        : GE3/1/1
    Service Instance ID : 1
    Link ID             : 9
    Access Mode         : Vlan
    CE Type             : Independent
    AC Encapsulation    : s-vid 300 c-vid 400 to 500 600 700
    Hub Spoke Type      : ----
    GR Count            : 0
  VSI Name: bbb                             VSI Index: 1
    Service Instance ID : 2
    Link ID             : 9
    Access Mode         : Vlan
    AC Encapsulation    : s-vid 4011 4012 to 4050
    GR Count            : 0
Table 8 Output description
Total VSI Entry
Total AC Entry
VSI Name
Name of the VPLS instance.
VSI Index
Index of the VPLS instance.
In Interface
Incoming interface, that is, the interface bound to an L2VPN
Link ID
Access Mode
Access mode at the AC side.
CE Type
Interface encapsulation type at the AC side, PortVlan or Independent.
AC Encapsulation
Encapsulation VLAN information at the AC side. For more information about the values of this field, see Layer 2—LAN Switching Command Reference.
GR Count
Number of times that GR occurs.
display mpls l2vpn fib pw vpls
display mpls l2vpn fib pw vpls [ vsi vsi-name [ link link-id ] ] [ slot slot-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vsi vsi-name: Specifies the VPLS instance name, a case-insensitive string of 1 to 31 characters. Hyphens (-) are not allowed. The specified VPLS instance must have existed.
link link-id: Specifies a PW in the VPLS instance by its link ID. The specified PW must have existed.
slot slot-number: Displays the PW information on a card. slot-number indicates the number of the slot where the card resides.
Use the display mpls l2vpn fib pw vpls command to display the PW information of one or all VPLS instance.
# Display the PW information of all VPLS instances.
<Sysname> display mpls l2vpn fib pw vpls
Total VSI Entry:1          Total PW Entry:1
VSI Name   VSI Index  Link ID ServiceID InVCLabel OutVCLabel TunnelID
vsi1       1          1       0         1000      1002       0x878ad000
Table 9 Output description
Total VSI Entry
Total number of VSI entries, which is displayed only when you display all VPLS PW entries.
Total PW Entry
Total number of VPLS PW entries, which is displayed only when you display all VPLS PW entries.
VSI Name
VPLS instance name.
VSI Index
Link ID
Link ID of a PW in the VPLS instance.
ServiceID
InVCLabel
Incoming VC label.
OutVCLabel
Outgoing VC label.
TunnelID
Public tunnel ID.
# Display the detailed PW information of all VPLS instances.
<Sysname> display mpls l2vpn fib pw vpls verbose
  VSI Name : vsi1                    VSI Index: 0
  **Link ID             : 1
    In VC Label         : 1000
    Out VC Label        : 1002
    Encapsulation Type  : Ethernet
    Hub Spoke Type      : Hub
    MTU                 : 1500
    Role                : Main
    State               : Active
    Dual Link ID        : 2
    Fast Switch Group ID: 1
    Tunnel ID           : 0x878ad000(Done)
                          GrCount:1
    Tunnel ID           : 0x878ad001(Waiting)
                          GrCount:1
Table 10 Output description
Total VSI Entry
Total PW Entry
VSI Name
VPLS instance name.
VSI Index
Link ID
In Interface
In VC Label
Incoming VC label.
Out VC Label
Outgoing VC label.
MTU
Maximum transmission unit.
Role
PW role: Main, Backup, or Normal.
PW state, active or standby.
Dual Link ID
Link ID of the other PW, which is displayed when main and backup PWs exist in the VPLS instance.
PW group ID.
Tunnel ID
Public tunnel ID and entry state (Done or Waiting).
GrCount: Number of times that GR occurs.
display pw-class
display pw-class [ pw-class-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
pw-class-name: Name of a PW class template, a case-insensitive string of 1 to 19 characters.
Use the display pw-class command to display information about one or all PW class templates.
If no PW class template is specified, the command displays information about all PW class templates.
If you specify a PW class template, the output information of the display command includes an additional field to show the number of times the PW class template has been referenced.
# Display information about all PW class templates.
<Sysname> display pw-class
Total 1 PW-class(es)
PW-class name     Transport mode   Tunnel policy
1026              VLAN             default
# Display information about the PW class template named 1026.
<Sysname> display pw-class 1026
PW-class name         Transport mode  Tunnel policy       Reference count
1026                  VLAN            default             0
display service-instance interface
display service-instance interface interface-type interface-number [ service-instance service-instance-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface-type interface-number: Displays information about service instances on a specific interface. interface-type and interface-number indicate the type and number of the interface.
service-instance instance-id: Displays information about the specified service instance. The instance-id argument indicates the ID of the instance, in the range of 1 to 4096. If this option is not specified, information about all service instances on the specified interface will be displayed.
Use the display service-instance interface command to display information about one or all service instances created on an interface.
# Display information about all service instances created on GigabitEthernet 3/1/3.
<Sysname> display service-instance interface GigabitEthernet 3/1/3
Total 2 service instance(s)
Service instance     : 1000
 Encapsulation        : s-vid 100
 MTU                  : 1500
 Access-mode          : VLAN
 Service type         : VPLS
 Service instance     : 1002
 Encapsulation        : s-vid 103
 MTU                  : 1500
 Access-mode          : VLAN
 Service type         : VPLS
Table 11 Output description
Service instance
ID of the service instance.
Encapsulation
Packet matching rule, which is based on VLAN tags.
Service Type
Service type associated with the service instance, which can be VPLS and VPWS. If no L2VPN connection is associated, -- is displayed for this field.
display vpls connection
display vpls connection [ bgp | ldp | vsi vsi-name ] [ block | down | up ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
bgp: Specifies all Kompella VPLS connections.
ldp: Specifies all Martini VPLS connections.
vsi vsi-name: Specifies a VPLS instance by its name, a case-insensitive string of 1 to 31 characters. Hyphens (-) are not allowed.
block: Specifies VPLS connections that are blocked. A PW in the block state is not used for the moment.
down: Specifies VPLS connections that are down.
up: Specifies VPLS connections that are up.
Use the display vpls connection command to display information about VPLS connections.
Related commands: vsi.
# Display information about VPLS connections of VPLS instance aaa.
<Sysname> display vpls connection vsi aaa
Total 1 connection(s),
connection(s): 1 up, 0 block, 0 down, 1 ldp, 0 bgp
VSI Name: aaa                           Signaling: ldp
VsiID   VsiType   PeerAddr   InLabel   OutLabel   LinkID   VCState
500     vlan      1.1.1.9    131776     131778      1        up
Table 12 Output description
VSI Name
Signaling
Type of the PW signaling protocol used by the VPLS instance
VsiID
VsiType
Access type of the VPLS instance
PeerAddr
Address of the peer in the VPLS instance
InLabel
Incoming label of the VPLS instance
OutLabel
Outgoing label of the VPLS instance
LinkID
ID of the PW in the VPLS instance
VCState
Status of the VC
display vsi
display vsi [ vsi-name ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display vsi command to display information about a specific or all VPLS instances.
# Display information about VPLS instance aaa.
<Sysname> display vsi aaa
Vsi                             Mem    PW   Mac       Encap     Mtu   Vsi
Name                            Disc   Type Learn     Type      Value State
aaa                             static ldp  unqualify vlan      1500  up
Table 13 Output description
Vsi Name
Name of the VSI instance.
Mem Disc
Peer discovery mechanism of the VSI:
·       static—The peer must be configured manually.
·       auto—The peer automatic discovery mechanism is used.
PW Type
PW signaling protocol, ldp or bgp.
Mac Learn
MAC address learning type.
Encap Type
PW encapsulation type, vlan, ethernet, or bgp-vpls.
Mtu Value
Vsi State
Status of the VSI, up or down.
# Display detailed configuration information about VPLS instance aaa, which uses LDP as the PW signaling protocol.
<Sysname> display vsi aaa verbose
***VSI Name                  : aaa
    VSI Index                : 0
    VSI Description          : 1
    PW Signaling             : ldp
    Member Discovery Style   : static
    PW MAC Learn Style       : unqualify
    Encapsulation Type       : vlan
    MTU                      : 1500
    Bandwidth                : 102400 kbps
    BroadcastRestrain        : 5%
    Multicast Restrain       : 50%
    Unknown Unicast Restrain : 10%
    MacTabLimit              : 128
    Drop Unknown             : enabled
    MacLearnEnable           : enable
    Hub-spoke                : unspecified
    P2P                      : unspecified
    Wait to Restore Time     : 10(Min)
    VSI State                : up
    Local VCCV CC Type       : CW, RA
    Local VCCV CV Type       : LSPV
    VSI ID                   : 100
   *Peer Router ID           : 2.2.2.2
    VC Label                 : 1024
    Session                  : up
    Service                  : QoS
    Inbound CAR name         : car1
    Inbound CAR ID           : 1
    Outbound CAR name        : car1
    Outbound CAR ID          : 1
    Interface Name           : GigabitEthernet3/1/4
    State                    : up
    Service instance ID      : 100
   *Peer Ip Address          : 2.2.2.2
    PW State                 : up
    Local VC Label           : 1024
    Remote VC Label          : 1027
    PW Type                  : label
    Tunnel ID                : 0xd2008
    Remote VCCV CC Type      : RA
    Remote VCCV CV Type      : LSPV
# Display detailed configuration information about VPLS instance bbb, which uses BGP as the PW signaling protocol.
<Sysname> display vsi bbb verbose
***VSI Name                  : bbb
    VSI Index                : 1
    PW Signaling             : bgp
    Member Discovery Style   : auto
    Encapulation Type        : vlan
    MTU                      : 1500
    MacTabLimit              : 128
    Drop Unknown             : disabled
    Wait to Restore Time     : Invalid
    VSI State                : down
    BGP RD                   : 111:1
    SiteID/Range/Offset      : 100/10/0
    Import vpn target        : 111:1
    Export vpn target        : 111:1
    Local Label Block        : 8192/10/0
    Interface Name           : GigabitEthernet3/1/5
    State                    : down
    Service instance ID      : 200
Table 14 Output description
VSI Name
VSI Index
VSI Description
Description of the VPLS instance.
PW Signaling
Type of the PW signaling protocol used by the VPLS instance, ldp or bgp.
Peer discovery mechanism of the VPLS instance:
·       static—The peer must be specified manually.
PW MAC Learn Style
Encapsulation Type
IntfIndex
Index of the interface.
MTU
Bandwidth
Bandwidth threshold of the VPLS instance.
BroadcastRestrain
Broadcast suppression ratio of the VPLS instance.
Multicast Restrain
Multicast suppression ratio of the VPLS instance.
Unknown unicast suppression ratio of the VPLS instance.
MacTabLimit
Maximum number of MAC addresses for a VPLS instance.
Drop Unknown
Whether to drop packets with unknown source MAC addresses when the VPLS instance has learned the maximum number of MAC addresses allowed.
·       enabled—Drops packets with unknown source MAC addresses.
·       disabled—Forwards packets with unknown source MAC addresses.
MacLearnEnable
Whether MAC address learning is enable.
Hub-spoke
Whether Hub-Spoke capability is enabled when the peer discovery mechanism is static.
P2P
Whether P2P capability is enabled when the peer discovery mechanism is static.
PW switchback delay time, in minutes. A value of invalid means that the switchback function is disabled.
VSI State
Status of the VPLS instance, down or up.
Local VCCV CC Type
Virtual Circuit Connectivity Verification (VCCV) control channel types supported on the local peer, including:
·       CW—Control word.
·       RA—Router alert (RA) label.
VCCV is a technology like ping. It is used to check the connectivity of L2VPN PWs.
Local VCCV CV Type
VCCV connectivity verification types supported on the local peer. Currently, only LSPV is supported, indicating that MPLS LSP ping is used to check the PW connectivity.
VSI ID
ID of the VPLS instance.
Peer Router ID
ID of the peer.
VC Label
Label of the VC.
Session
Status of the session.
Service
Enabled services:
·       Statistics—The statistics collection service.
·       QoS—The PW traffic policing service.
Inbound CAR name
Name of the CAR action applied in the inbound direction. If no CAR action is specified, this field does not appear.
Inbound CAR ID
ID of the CAR action applied in the inbound direction. If no CAR action is specified, this field does not appear.
Outbound CAR name
Name of the CAR action applied in the outbound direction. If no CAR action is specified, this field does not appear.
Outbound CAR ID
ID of the CAR action applied in the outbound direction. If no CAR action is specified, this field does not appear.
Fast Switch Group Index
BGP RD
BGP router distinguisher
SiteID/Range/Offset
Site ID/site range/CE offset of a site in the VPLS instance
Import vpn target
Incoming routing information from the destination VPN extended community
Export vpn target
Outgoing routing information to the destination VPN extended community
Interface Name
Name of the Layer 2 Ethernet interface where the service instance associated with the VPLS instance resides
Status of the Layer 2 Ethernet interface where the service instance associated with the VPLS instance resides
Service instance ID
ID of the service instance associated with the VPLS instance
PW Type
PW type:
·       label—NPW, the PW with a PE
·       MEHVPLS—UPW, the PW with a UPE
Remote VCCV CC Type
VCCV control channel types supported on the remote peer
Remote VCCV CV Type
VCCV connectivity verification types supported on the remote peer
display vsi remote
display vsi remote { bgp | ldp } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
bgp: Displays information about remote VPLS connections using the signaling protocol of BGP.
ldp: Displays information about remote VPLS connections using the signaling protocol of LDP.
Use the display vsi remote command to display information about remote VPLS connections using a specific signaling protocol.
# Display information about remote VPLS connections using LDP.
<Sysname> display vsi remote ldp
Vsi         Peer              VC      Group   Vsi          MTU      Vsi
ID          RouterID          Label   ID      Type         Value    Index
500         60.1.1.1          524688  0       vlan         1500     0
Table 15 Output description
Vsi ID
Peer Router ID
ID of the peer
VC Label
Label of the VC
Group ID
ID of the group
Vsi Type
Encapsulation type of the VPLS instance
MTU Value
Vsi Index
dual-npe revertive
dual-npe revertive [ wtr-time wtr-time ]
undo dual-npe revertive [ wtr-time ]
View
VSI LDP view
Default level
2: System level
wtr-time wtr-time: Specifies the switchback delay time. After the primary PW comes back, the system waits for a period of time dictated by the switchback delay time before switching data from the secondary PW back to the primary PW. The wtr-time argument is in the range of 1 to 720, in minutes. The default is 30 minutes.
Use the dual-npe revertive command to enable the switchback function and set the switchback delay time.
Use the undo dual-npe revertive wtr-time command to restore the default switchback delay time.
Use the undo dual-npe revertive command to disable the switchback function.
By default, the switchback function is disabled.
# Create a VPLS instance named vpna that uses the peer discovery mechanism of manual configuration and set the switchback delay time to 1 minute.
[Sysname] vsi vpna static
[Sysname-vsi-vpna] pwsignal ldp
[Sysname-vsi-vpna-ldp] dual-npe revertive wtr-time 1
encapsulation
encapsulation { bgp-vpls | ethernet | vlan }
View
VSI view
Default level
2: System level
bgp-vpls: Specifies the encapsulation type for a BGP VPLS instance as the standard encapsulation type defined in RFC 4761.
ethernet: Uses the encapsulation type of Ethernet. This type corresponds to the VPLS instance PW encapsulation type of raw.
vlan: Uses the encapsulation type of VLAN. This type corresponds to the VPLS instance PW encapsulation type of tagged.
Use the encapsulation command to specify the encapsulation type of a VPLS instance.
By default, the encapsulation type of a VPLS instance is VLAN.
# Set the VPLS instance encapsulation type to Ethernet.
[Sysname-vsi-aaa] pwsignal ldp
[Sysname-vsi-aaa-ldp] vsi-id 500
[Sysname-vsi-aaa-ldp] quit
[Sysname-vsi-aaa] encapsulation ethernet
encapsulation s-vid
encapsulation s-vid vlan-id
undo encapsulation
View
Service instance view
Default level
2: System level
s-vid vlan-id: Specifies a service VLAN ID (outer VLAN ID) in the range of 1 to 4094.
Use the encapsulation s-vid command to specify the VLAN ID to be used by the current service instance for packet matching.
Use the undo encapsulation command to remove the packet matching VLAN ID of the current service instance.
By default, no packet matching VLAN ID is specified for a service instance.
The packet matching VLAN ID you specified overwrites the previous configuration, if any.
You must specify different packet matching VLAN IDs for different service instances of the same Layer 2 Ethernet port.
# Configure service instance 100 on GigabitEthernet 3/1/3 to match packets that carry outer VLAN ID 100.
[Sysname] interface GigabitEthernet 3/1/3
[Sysname-GigabitEthernet3/1/3] service-instance 100
[Sysname-GigabitEthernet3/1/3-srv100] encapsulation s-vid 100
l2 binding vsi
l2 binding vsi vsi-name [ access-mode { ethernet | vlan } | { hub | spoke } ] *
undo l2 binding vsi vsi-name
View
Interface view
Default level
2: System level
access-mode: Specifies the access mode of the VPLS instance, which can be ethernet or vlan. If the interface bound with the VPLS instance is a Layer 3 Ethernet subinterface or a VLAN interface, the default access mode is vlan; otherwise, the default access mode is ethernet.
ethernet: Specifies the access mode of Ethernet.
vlan: Specifies the access mode of VLAN.
hub: Specifies that the attached CE is the hub-CE.
spoke: Specifies that the attached CE is a spoke-CE. This is the default when the hub-spoke feature is enabled for the instance.
Use the l2 binding vsi command to bind a VPLS instance on an interface.
Use the undo l2 binding vsi command to remove the binding.
When the hub-spoke feature is enabled for a VPLS instance, you can also specify whether the attached CE is a spoke site or the hub site.
CAUTION
CAUTION:
·       With the l2 binding vsi command configured on an interface, services bound to the interface are considered the internal VPN services of the VPLS instance.
·       After a routing interface is bound with a VPLS instance, its routing subinterfaces cannot be bound with any L2VPN or VPLS instance. After a routing subinterface is bound with a VPLS instance, the corresponding routing interface cannot be bound with any L2VPN or VPLS instance.
Related commands: peer and vsi.
# Bind VPLS instance aaa to VLAN interface GigabitEthernet 3/1/1.
[Sysname] interface GigabitEthernet 3/1/1
[Sysname-GigabitEthernet3/1/1] l2 binding vsi aaa
mac-learning
mac-learning { enable | disable }
View
VSI view
Default level
2: System level
enable: Enables MAC address learning for the VPLS instance.
disable: Disables MAC address learning for the VPLS instance.
Use the mac-learning command to enable or disable MAC address learning for a VPLS instance.
With MAC address learning disabled for a VPLS instance, the system does no learn source MAC addresses from the packets received from the VPLS instance.
By default, MAC address learning is enabled.
# Enables MAC address learning for VPLS instance aaa.
[Sysname-vsi-aaa] mac-learning enable
mac-learn-style
mac-learn-style { qualify | unqualify }
View
VSI view
Default level
2: System level
qualify: Uses the standard MAC address learning mode.
unqualify: Uses the non-standard MAC address learning mode.
Use the mac-learn-style command to specify the MAC address learning mode for a VPLS instance.
·           In standard MAC address learning mode, source MAC addresses of all VPLS instances must be globally unique.
·           In non-standard MAC address learning mode, source MAC addresses must be unique within a VPLS instance but can overlap between VPLS instances.
By default, the non-standard MAC address learning mode is used.
This router supports only the unqualify learning mode.
# Specify the MAC address learning mode for VPLS instance aaa as non-standard.
[Sysname-vsi-aaa] mac-learn-style unqualify
mac-table limit
mac-table limit mac-limit-number
undo mac-table limit
View
VSI view
Default level
2: System level
mac-limit-number: Maximum number of MAC addresses that the router can learn for the VPLS instance, in the range of 0 to 65535.
Use the mac-table limit command to specify the maximum number of MAC addresses that the router can learn for the VPLS instance.
Use the undo mac-table limit command to restore the default.
By default, the threshold is 65535.
Once the number of MAC addresses learned from a VPLS instance reaches this threshold, the system does not learn source MAC addresses any more but broadcasts the received packet in the VPLS instance.
# Set the maximum number of MAC addresses that the router can learn for the VPLS instance aaa to 1024.
[Sysname-vsi-aaa] mac-table limit 1024
mtu (VSI view)
mtu mtu
undo mtu
View
VSI view
Default level
2: System level
mtu: Maximum transmission unit (MTU) for the VPLS instance, in the range of 328 to 8192. The default is 1,500.
Use the mtu command to set the MTU of a VPLS instance.
Use the undo mtu command to restore the default.
The MTU of a VPLS instance is a global attribute and is also the MTU of the PW. In Martini VPLS, the MTUs of VPLS instances of peer PEs must be identical. In Kompella VPLS, the MTUs of VPLS instances of peer PEs can be different.
# Set the MTU of VPLS instance aaa to 1400.
[Sysname-vsi-aaa] mtu 1400
peer (VSI LDP view)
peer ip-address [ { hub | spoke } | pw-class class-name | [ pw-id pw-id ] [ upe | backup-peer ip-address [ backup-pw-id pw-id ] ] ] *
undo peer ip-address
View
VSI LDP view
Default level
2: System level
ip-address: IP address of the remote VPLS peer PE.
hub: Specifies the peer PE as the hub.
spoke: Specifies the peer PE as a spoke. This is the default when the hub-spoke feature is enabled for the instance.
pw-class class-name: References a PW class template. class-name represents the template name, a case-insensitive string of 1 to 19 characters.
pw-id pw-id: ID of the PW to the VPLS peer PE, in the range of 1 to 4294967295. The default is the VSI ID.
upe: Specifies that the peer PE is a UPE in the H-VPLS model.
backup-peer ip-address: Specifies the IP address of the backup NPE. If you specify this parameter, you create a primary NPE and a backup NPE on the UPE.
backup-pw-id pw-id: Specifies the ID of the PW to the backup NPE. The pw-id argument is in the range of 1 to 4294967295, and the default is the VSI ID.
Use the peer command to create a peer PE for a VPLS instance.
Use the undo peer command to remove a peer PE.
With the hub-spoke feature for a VPLS instance, you can specify the connection mode of the peer PE as hub or spoke.
Related commands: encapsulation, vsi, and vsi-id.
# Create a peer PE, which is of the UPE type, with the IP address of 4.4.4.4 and the PW ID of 200.
[Sysname-vsi-aaa-ldp] peer 4.4.4.4 pw-id 200 upe
# Create a primary peer PE 1.1.1.1 and a backup peer PE 2.2.2.2, and set the PW ID to the primary peer to 300 and that to the backup peer to 400.
[Sysname] vsi aaa
[Sysname-vsi-aaa-ldp] peer 1.1.1.1 pw-id 300 backup-peer 2.2.2.2 backup-pw-id 400
pw-class
pw-class pw-class-name
undo pw-class pw-class-name
View
Default level
2: System level
pw-class-name: Name of the PW class template, a case-insensitive string of 1 to 19 characters.
Use the pw-class command to create a PW class template and enter PW class template view.
Use the undo pw-class command to delete an existing PW class template.
By default, no PW class template is created.
# Create PW class template pw100 and enter its view.
[Sysname] pw-class pw100
[Sysname-pw-pw100]
pwsignal
pwsignal { bgp | ldp }
View
VSI view
Default level
2: System level
bgp: Specifies to use BGP signaling, that is, Kompella mode.
ldp: Specifies to use LDP signaling, that is, Martini mode.
Use the pwsignal command to specify the PW signaling protocol for VPLS to use, and enter VSI LDP view (Martini mode) or VSI BGP view (Kompella mode).
# Specify that VPLS instance aaa uses the connection mode of Martini and enter VSI LDP view.
pw-tunnel-policy
pw-tunnel-policy policy-name
undo pw-tunnel-policy
View
Default level
2: System level
policy-name: Name of the tunneling policy, a case-insensitive string of 1 to 19 characters.
Use the pw-tunnel-policy command to specify the tunneling policy for the PW class template.
Use the undo pw-tunnel-policy command to restore the default.
By default, the tunneling policy specified by the tnl-policy command in VSI view is used.
If you specify a non-existent tunneling policy in the pw-tunnel-policy command, the tunneling policy specified by the tnl-policy command in VSI view will be used.
Related commands: tnl-policy, tunnel select-seq load-balance-number.
# Specify tunneling policy tp100 for PW class template pw100.
[Sysname-pw-pw100] pw-tunnel-policy tp100
reset bgp vpls
reset bgp vpls { as-number | ip-address | all | external | internal }
View
Default level
2: System level
as-number: Resets VPLS BGP connections to peers in a specific AS. as-number is in the range of 1 to 65535.
ip-address: Resets the VPLS BGP connection to a specific peer.
all: Resets all VPLS BGP connections.
external: Resets VPLS EBGP session.
internal: Resets VPLS IBGP session.
Use the reset bgp vpls command to reset a specific or all VPLS BGP connections.
# Reset all VPLS BGP connections.
<Sysname> reset bgp vpls all
reset mac-address vsi
reset mac-address vsi [ vsi-name ]
View
Default level
1: Monitor level
vsi-name: Name of a VPLS instance, a case-insensitive string of 1 to 31 characters. Hyphens (-) are not allowed.
Use the reset mac-address vsi command to clear the MAC address table of a specific VPLS instance or all VPLS instances.
# Clear the MAC address table of VPLS instance aaa.
<Sysname>reset mac-address vsi aaa
route-distinguisher (VSI BGP view)
View
VSI BGP view
Default level
2: System level
route-distinguisher: Route distinguisher (RD), a string of 3 to 21 characters in the format of nn:nn or IP_address:nn.
An RD can be one of these formats:
·           16-bit AS number:32-bit user-defined number. For example, 101:3.
·           32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
·           32-bit AS number:16-bit user-defined number, where the AS number must be equal to or greater than 65536. For example, 65536:1.
Use the route-distinguisher command to configure an RD for a VPLS instance.
Different VPLS instances on a PE must have different RDs. A VPLS instance can have the same RD or different RDs on different PEs.
·       RD has no default value. You must configure an RD for a VPLS instance to make the instance take effect.
·       To change the RD of a VPLS instance, you must remove the VPLS instance and then reconfigure the VPLS instance and RD.
# Set the RD to 111:1.
[Sysname] vsi aaa auto
[Sysname-vsi-aaa] pwsignal bgp
[Sysname-vsi-aaa-bgp] route-distinguisher 111:1
service-instance
undo service-instance service-instance-id
View
Layer 2 Ethernet port view, aggregate interface view
Default level
2: System level
service-instance-id: Service instance ID in the range of 1 to 4094. A service instance ID uniquely identifies a service instance on a Layer 2 Ethernet port.
Use the service-instance command to create a service instance on the current port and enter service instance view.
Use the undo service-instance command to delete a service instance on the current port.
By default, no service instances have been created on any port.
Service instance IDs of the service instances created on different Layer 2 Ethernet ports can be the same.
# Create service instance 100 on Layer 2 port GigabitEthernet 3/1/3 and enter service instance view.
shutdown (VSI view)
shutdown
View
VSI view
Default level
2: System level
None
Use the shutdown command to shut down the VPLS service of a VPLS instance.
Use the undo shutdown command to restart the VPLS service of a VPLS instance.
By default, the VPLS service of a VPLS instance is started.
When a VPLS instance is disabled, the system does not handle any service of the VPLS instance.
# Shut down the VPLS service of VPLS instance aaa.
[Sysname-vsi-aaa] shutdown
site
site site-id [ range site-range ] [ default-offset { 0 | 1 } ]
undo site site-id
View
VSI BGP view
Default level
2: System level
site-id: ID of a site of the VPLS instance. The valid values range from 0 to 64.
range site-range: Specifies the site range on a PE. site-range is the total number of sites of a VPLS instance. The value ranges from 1 to 65.
default-offset { 0 | 1 }: Default initial CE offset. It can be 0 or 1 and defaults to 0.
Use the site command to create sites for a VPLS instance.
Use the undo site command to remove sites of a VPLS instance.
Sites of a VPLS instance use natural numbers as the site IDs. In a VPN, each site ID must be unique.
For a VPLS instance, you are not allowed to execute the site command repeatedly.
# Create sites for VPLS instance aaa and set the site range to 20.
[Sysname-vsi-aaa-bgp] route-distinguisher 101:3
[Sysname-vsi-aaa-bgp] site 1 range 20
tnl-policy
tnl-policy tunnel-policy-name
undo tnl-policy
View
VSI view
Default level
2: System level
tunnel-policy-name: Name of the tunneling policy for the VPLS instance, a string of 1 to 19 characters without any blank space.
Use the tnl-policy command to specify a tunneling policy for a VPLS instance.
Use the undo tnl-policy command to remove the configuration.
By default, no tunneling policy is specified for a VPLS instance and the default tunneling policy is used. The default tunneling policy selects only one tunnel (no load balancing) in this order: LSP tunnel, CR-LSP tunnel.
If you specify a tunneling policy name but the tunneling policy is not configured, the default tunneling policy is used.
Related commands: tunnel select-seq load-balance-number.
# Specify that VPLS instance aaa uses the tunneling policy of policy1.
[Sysname-vsi-aaa] tnl-policy policy1
trans-mode
trans-mode { ethernet | vlan }
undo trans-mode
View
Default level
2: System Level
ethernet: Specifies the PW transport mode as Ethernet.
vlan: Specifies the PW transport mode as VLAN.
Use the trans-mode command to specify the PW transport mode.
Use the undo trans-mode command to restore the default.
By default, the PW transport mode is VLAN.
In Ethernet mode, P-Tag is not transferred on the PW. For a packet from a CE, if it contains the service delimiter, the PE removes the service delimiter and adds a PW label and tunnel label into the packet before forwarding the packet. Otherwise, the PE directly adds a PW label and tunnel label into the packet and then forwards the packet. For a packet to be sent downstream, whether the PE adds the service delimiter into the packet depends on your configuration. However, rewriting and removing of existing tags are not allowed.
In VLAN mode, packets transmitted over the PW must carry a P-Tag. For a packet from a CE, if it contains the service delimiter, the PE keeps the P-Tag unchanged or changes the P-tag to the VLAN tag expected by the peer PE or to a null tag (the tag value is 0), and then adds a PW label and a tunnel label into the packet before sending the packet out. If the packet contains no service delimiter, the PE adds the VLAN tag expected by the peer PE or a null tag, and then a PW label and a tunnel label into the packet before sending the packet out. For a packet to be sent downstream, the PE rewrites, removes, or retains the service delimiter depending on your configuration.
# Configure the PW transport mode as Ethernet.
[Sysname-pw-pw100] trans-mode ethernet
vpls-family
vpls-family
View
BGP view
Default level
2: System level
None
Use the vpls-family command to enter VPLS address family view.
# Enter VPLS address family view.
[Sysname] bgp 100
[Sysname-bgp] vpls-family
[Sysname-bgp-af-vpls]
vpn-target (VSI BGP view)
vpn-target vpn-target &<1-16> [ both | export-extcommunity | import-extcommunity ]
undo vpn-target { all | vpn-target &<1-16> } [ both | export-extcommunity | import-extcommunity ]
View
VSI BGP view
Default level
2: System level
vpn-target&<1-16>: Adds VPN target extended community attributes to the import VPN target extended community attribute list (Import Target) or export VPN target extended community attribute list (Export Target). &<1-16> means that you can add up to 16 VPN targets.
A VPN target attribute can be a string of 3 to 21 characters in one the following formats:
·           16-bit AS number:32-bit user-defined number, such as 101:3.
·           32-bit IP address:16-bit user-defined number, such as 192.168.122.15:1.
both: Uses the specified VPN target values as both import targets and export targets. The both keyword is also used when you do not specify any of both, export-extcommunity, and import-extcommunity.
export-extcommunity: Uses the specified VPN targets as export targets.
import-extcommunity: Uses the specified VPN targets as import targets.
all: Removes all VPN targets.
Use the vpn-target command to configure one or more VPN targets for a VPLS instance.
Use the undo vpn-target command to remove the specified or all VPN targets of a VPLS instance.
By default, no VPN targets are configured and you must configure VPN targets when creating a VPLS instance.
# Configure VPN targets for the VPLS instance aaa.
[Sysname-vsi-aaa-bgp] vpn-target 100:1
[Sysname-vsi-aaa-bgp] vpn-target 1:1 2:2 export-extcommunity
[Sysname-vsi-aaa-bgp] vpn-target 1.2.3.4:11 12:12 import-extcommunity
vsi
vsi vsi-name [ { auto | static [ hub-spoke | p2p ] } | minm i-sid i-sid ] *
undo vsi vsi-name
View
Default level
2: System level
vsi-name: Name of the VSI, a case-insensitive string of 1 to 31 characters. Hyphens (-) are not allowed.
auto: Configures the peer discovery mechanism as dynamic. This corresponds to BGP mode.
static: Configures the peer discovery mechanism as static. This corresponds to LDP mode.
hub-spoke: Enables the hub-spoke capability for the instance whose peer discovery mechanism is static.
p2p: Enables the P2P (PW to PW) capability for the VSI whose peer discovery mechanism is static. The P2P feature is used to associate two PWs to set up a multi-hop PW.
The router does not support the minm i-sid i-sid option.
Use the vsi command to create a VSI and enter VSI view. If the specified VSI already exits, you enter the VSI view directly.
Use the undo vsi command to remove a VSI.
Note the following when using this command:
·           To create a VSI, specify a globally unique name for it, and specify the peer discovery mechanism. If you specify the peer discovery mechanism as static, you can also enable hub-spoke or P2P for the VPLS instance as needed.
·           To enter the view of an existing VSI, use the vsi vsi-name command without specifying any other parameters.
·           Before creating a VPLS instance, you need to enable L2VPN and MPLS L2VPN by using the l2vpn command and the mpls l2vpn command.
Related commands: display vsi, mpls l2vpn, and l2vpn.
# Create VPLS instance aaa and specify the peer discovery mechanism of the VPLS instance as static.
[Sysname-vsi-aaa]
# Create VPLS instance bbb, specify the peer discovery mechanism of the VPLS instance as static, and enable the P2P capability.
[Sysname] vsi bbb static p2p
[Sysname-vsi-bbb]
vsi-id
vsi-id vsi-id
View
VSI LDP view
Default level
2: System level
vsi-id: ID for the VPLS instance, in the range of 1 to 4294967295.
Use the vsi-id command to specify the ID of a VPLS instance.
On PEs in the same VPN, be sure to specify the same VSI ID for the VPLS instances that correspond to the VPN.
# Set the VSI ID of VPLS instance aaa to 100.
[Sysname-vsi-aaa-ldp] vsi-id 100
xconnect vsi
xconnect vsi vsi-name [ access-mode { ethernet | vlan } | { hub | spoke } ] *
undo xconnect vsi
View
Default level
2: System level
access-mode: Specifies the access mode of the service instance as Ethernet or VLAN. The default access mode is VLAN.
ethernet: Specifies the Ethernet access mode.
vlan: Specifies the VLAN access mode.
hub: Specifies the access mode of the VPLS instance as hub.
spoke: Specifies the access mode of the VPLS instance as spoke, which is also the default when the VPLS instance is enabled with the hub-spoke capability.
Use the xconnect vsi command to associate a VPLS instance with the service instance on a specific interface.
Use the undo xconnect vsi command to remove the association.
By default, a service instance is not associated with any VPLS instance.
The access mode of a service instance can be either of the following:
·           VLAN: The Ethernet header of a packet sent from a CE to a PE or from a PE to a CE includes a VLAN tag that is added in the header as a service delimiter for the service provider network to identify the user. The tag is called a P-Tag.
·           Ethernet: The Ethernet header of a packet sent from a CE to a PE or from a PE to a CE does not contain any service delimiter. If the header contains a VLAN tag, it is the internal VLAN tag of the user and means nothing to the PE. Such an internal VLAN tag of a user is called a U-Tag.
Note the following:
·           Only when the VPLS instance is enabled with the Hub-Spoke capability, can you further specify the access mode as Hub or Spoke. The default is Spoke.
·           In Hub-Spoke networking mode of VPLS, data between Spoke sites must be exchanged through Hub sites. Direct data exchange between Spoke sites is not allowed.
·           For VPLS, signaling advertisement uses the MTU of the VPLS instance.
·           The xconnect vsi command is available for service instances with the ID in the range of 1 to 4094.
Related commands: service-instance.
# Associate service instance 200 of GigabitEthernet 3/1/3 with VPLS instance vsi200 and specify the matching external VLAN tag as 200.
[Sysname-GigabitEthernet3/1/3] service-instance 200
[Sysname-GigabitEthernet3/1/3-srv200] encapsulation s-vid 200
[Sysname-GigabitEthernet3/1/3-srv200] xconnect vsi vsi200
