08-MPLS Command Reference
HomeSupportRoutersH3C SR8800 Router SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10308-MPLS Command Reference
02-MPLS TE Commands
02-MPLS TE Commands 461.05 KB
MPLS TE configuration commands 1
add hop· 1
delete hop· 1
display explicit-path· 2
display isis traffic-eng advertisements 3
display isis traffic-eng link· 6
display isis traffic-eng network· 7
display isis traffic-eng statistics 9
display isis traffic-eng sub-tlvs 10
display mpls lsp bfd te· 11
display mpls rsvp-te· 12
display mpls rsvp-te established· 14
display mpls rsvp-te peer 15
display mpls rsvp-te psb-content 16
display mpls rsvp-te request 19
display mpls rsvp-te reservation· 20
display mpls rsvp-te rsb-content 21
display mpls rsvp-te sender 23
display mpls rsvp-te statistics 24
display mpls static-cr-lsp· 27
display mpls te cspf tedb· 28
display mpls te ds-te· 33
display mpls te link-administration admission-control 35
display mpls te link-administration bandwidth-allocation· 36
display mpls te protection tunnel 37
display mpls te tunnel 39
display mpls te tunnel path· 41
display mpls te tunnel statistics 42
display mpls te tunnel-interface· 43
display ospf mpls-te· 46
display ospf traffic-adjustment 48
display tunnel-info· 49
enable traffic-adjustment 50
enable traffic-adjustment advertise· 51
explicit-path· 51
list hop· 52
modify hop· 52
mpls rsvp-te· 53
mpls rsvp-te authentication· 54
mpls rsvp-te bfd enable· 55
mpls rsvp-te blockade-multiplier 55
mpls rsvp-te graceful-restart 56
mpls rsvp-te hello· 57
mpls rsvp-te hello-lost 57
mpls rsvp-te keep-multiplier 58
mpls rsvp-te reliability· 59
mpls rsvp-te resvconfirm·· 59
mpls rsvp-te srefresh· 60
mpls rsvp-te timer graceful-restart recovery· 60
mpls rsvp-te timer graceful-restart restart 61
mpls rsvp-te timer hello· 62
mpls rsvp-te timer refresh· 62
mpls rsvp-te timer retransmission· 63
mpls te· 64
mpls te affinity property· 64
mpls te backup· 65
mpls te backup bandwidth· 66
mpls te bandwidth· 67
mpls te bandwidth change thresholds 68
mpls te bfd enable· 69
mpls te commit 69
mpls te cspf 70
mpls te cspf timer failed-link· 71
mpls te ds-te ietf bc-mode· 71
mpls te ds-te ietf te-class 72
mpls te ds-te mode· 73
mpls te failure-action teardown· 74
mpls te fast-reroute· 74
mpls te fast-reroute bypass-tunnel 75
mpls te igp advertise· 76
mpls te igp metric· 76
mpls te igp shortcut 77
mpls te link administrative group· 78
mpls te loop-detection· 78
mpls te max-link-bandwidth· 79
mpls te max-reservable-bandwidth· 79
mpls te max-reservable-bandwidth mam·· 80
mpls te max-reservable-bandwidth rdm·· 81
mpls te metric· 82
mpls te path· 82
mpls te path metric-type· 83
mpls te periodic-tracert 84
mpls te priority· 85
mpls te protection tunnel 86
mpls te protect-switch· 87
mpls te record-route· 88
mpls te reoptimization (tunnel interface view) 88
mpls te reoptimization (user view) 89
mpls te resv-style· 89
mpls te retry· 90
mpls te route-pinning· 90
mpls te signal-protocol 91
mpls te tie-breaking· 92
mpls te timer auto-bandwidth· 93
mpls te timer fast-reroute· 93
mpls te timer link-management periodic-flooding· 94
mpls te timer retry· 95
mpls te tunnel-id· 95
mpls te vpn-binding· 96
mpls-te· 97
next hop· 98
opaque-capability· 98
ping lsp te· 99
reset mpls rsvp-te statistics 100
static-cr-lsp egress 100
static-cr-lsp ingress 101
static-cr-lsp transit 102
te-set-subtlv· 103
tracert lsp te· 104
traffic-eng· 105
add hop
add hop ip-address1 [ include [ loose | strict ] | exclude ] { after | before } ip-address2
View
Explicit path view
Default level
2: System level
ip-address1: IP address or Router ID of the node to be inserted, in dotted decimal notation.
include: Includes the specified IP address ip-address1 in the explicit path.
loose: Specifies the inserted node as a loose node, which means that the inserted node and its previous hop can be connected indirectly.
strict: Specifies the inserted node as a strict node, which means that the inserted node and its previous hop must be connected directly.
exclude: Excludes the node identified by the ip-address1 argument from the explicit path. Excluded addresses are not considered in path calculation.
after: Inserts the node ip-address1 after the reference node ip-address2.
before: Inserts the node ip-address1 before the reference node ip-address2.
ip-address2: IP address of the reference node, in dotted decimal notation.
Use the add hop command to insert a node to the explicit path, and configure the node’s attributes (include or exclude, strict or loose).
·           If you specify neither include nor exclude, the include keyword is used by default.
·           If you specify neither loose nor strict, the strict keyword is used by default.
# Specify the device to not consider 3.3.29.3 as the next hop of 3.3.10.5 during path calculation for the explicit path path1.
[Sysname] explicit-path path1
[Sysname-explicit-path-path1] add hop 3.3.29.3 exclude after 3.3.10.5
delete hop
delete hop ip-address
View
Explicit path view
Default level
2: System level
ip-address: IP address of a node along the explicit path.
Use the delete hop command to remove a specific node from the explicit path.
# Remove the node identified by 10.0.0.1 from the explicit path path1.
[Sysname-explicit-path-path1] delete hop 10.0.0.1
display explicit-path [ pathname ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
pathname: Specifies a path name, a string of 1 to 31 characters.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display explicit-path command to display information about an explicit path.
If no path name is specified, information about all explicit paths is displayed.
# Display information about all explicit paths.
<Sysname> display explicit-path
Path Name : ErHop-Path1  Path Status : Enabled
 1             1.1.1.10         Strict                    Include
 2             2.1.1.10         Strict                    Include
 3             1.1.1.20         Strict                    Include
 4             2.1.1.20         Strict                    Include
 5             2.1.1.30         Strict                    Include
 6             1.1.1.30         Strict                    Include
 7             9.4.4.4          Strict                    Include
Path Name : ErHop-Path2  Path Status : Enabled
 3             1.1.1.40         Strict                    Include
 4             2.1.1.40         Strict                    Include
 5             1.1.1.50         Strict                    Include
 6             2.1.1.40         Strict                    Include
 7             2.1.1.30         Strict                    Include
 8             1.1.1.30         Strict                    Include
 9             9.4.4.4          Strict                    Include
Table 1 Output description
Path Name
Explicit path name
Path Status
Explicit path status
display isis traffic-eng advertisements [ [ level-1 | level-1-2 | level-2 ] | [ lsp-id lsp-id | local ] ] * [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
level-1: Displays the TE information of IS-IS Level-1 routers.
level-1-2: Displays the TE information of IS-IS Level-1-2 routers.
level-2: Displays the TE information of IS-IS Level-2 routers.
lsp-id lsp-id: Specifies a link state packet ID (LSP ID) to display the TE information advertised by it. For more information about IS-IS LSP, see Layer 3—IP Routing Configuration Guide.
local: Displays local TE information.
process-id: Specifies an IS-IS process ID, in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays the IS-IS TE information of the specified VPN. The vpn-instance-name argument specifies an MPLS L3VPN by its instance name, a case-sensitive string of 1 to 31 characters. To display the IS-IS TE information of the public network, do not specify this option.
Use the display isis traffic-eng advertisements command to display the latest TE information advertised by IS-IS TE.
If no IS-IS level is specified, the TE information of IS-IS Level-1-2 routers is displayed.
# Display the latest TE information advertised by IS-IS TE.
<Sysname> display isis traffic-eng advertisements
                           TE information for ISIS(1)
Level-1 Link State Database
LSPID                 LSP Seq Num  LSP Checksum  LSP Holdtime  ATT/P/OL
0000.0000.0001.00-00* 0x00000001   0x3f57        534           0/0/0
 NLPID      : IPV4
 AREA ADDR  : 00.0005
 INTF ADDR  : 10.1.1.1
 INTF ADDR  : 1.1.1.9
 INTF ADDR  : 30.1.1.1
Level-2 Link State Database
0000.0000.0001.00-00* 0x0000001c   0xf1ec        687           0/0/0
 NLPID      : IPV4
 AREA ADDR  : 00.0005
 INTF ADDR  : 1.1.1.9
 Router ID  : 1.1.1.9
+NBR        : 0000.0000.0002.02  COST: 10
    Admin Group: 0x00000000
    Interface IP Address:  10.1.1.1
    Physical BW  :      12500 Bytes/sec
    Reservable BW:       6250 Bytes/sec
    Unreserved BW for Class Type 0:
    BW Unresrv[0]:       6250 Bytes/sec BW Unresrv[1]:       6250 Bytes/sec
    BW Unresrv[2]:       6250 Bytes/sec BW Unresrv[3]:       6250 Bytes/sec
    BW Unresrv[4]:       6250 Bytes/sec BW Unresrv[5]:       6250 Bytes/sec
    BW Unresrv[6]:       6250 Bytes/sec BW Unresrv[7]:       6250 Bytes/sec
    Unreserved BW for Class Type 1:
    BW Unresrv[0]:          0 Bytes/sec BW Unresrv[1]:          0 Bytes/sec
    BW Unresrv[2]:          0 Bytes/sec BW Unresrv[3]:          0 Bytes/sec
    BW Unresrv[4]:          0 Bytes/sec BW Unresrv[5]:          0 Bytes/sec
    BW Unresrv[6]:          0 Bytes/sec BW Unresrv[7]:          0 Bytes/sec
    TE Cost      :         10
    Bandwidth Constraint Model: Russian Doll
    Bandwidth Constraints:
    BC[0]        :       6250 Bytes/sec BC[1]        :          0 Bytes/sec
+NBR        : 0000.0000.0004.00  COST: 10
    Interface IP Address:  30.1.1.1
    Peer IP Address     :  30.1.1.2
    TE Cost      :         10
Table 2 Output description
LSPID
LSP ID
LSP Seq Num
LSP sequence number
ATT/P/OL
Attach bit (ATT)
Partition bit (P)
Overload bit (OL)
NLPID
Network protocol type
AREA ADDR
IS-IS area address
INTF ADDR
Interface address
+NBR
Neighbor
COST
Cost
Admin Group
Link administrative group attribute
Physical BW
Physical bandwidth
Reservable BW
Reservable bandwidth
BW Unresrv[0]-[7]
Available subpool bandwidths at eight levels
TE Cost
TE cost
BC[0]
Global pool
BC[1]
Subpool
LOM[0]
LOM[1]
Local overbooking multiplier. The bracketed number indicates the level of bandwidth.
display isis traffic-eng link [ [ level-1 | level-1-2 | level-2 ] | verbose ] * [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
verbose: Displays details.
process-id: IS-IS process ID, in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays the IS-IS TE link information of the specified VPN.. The vpn-instance-name argument specifies an MPLS L3VPN by its instance name, a case-sensitive string of 1 to 31 characters. To display the IS-IS TE link information of the public network, do not specify this option.
Use the display isis traffic-eng link command to display information about TE links for IS-IS.
If no IS-IS level is specified, the TE link information of IS-IS Level-1-2 routers is displayed.
# Display information about TE links for IS-IS.
<Sysname> display isis traffic-eng link
Level-2 Link Information
 0000.0000.0001.00-->0000.0000.0001.01    Type: MULACC  LinkID: 10.1.1.1
 0000.0000.0002.00-->0000.0000.0003.00    Type: P2P     LinkID: 3.3.3.9
 0000.0000.0002.00-->0000.0000.0001.01    Type: MULACC  LinkID: 10.1.1.1
 0000.0000.0003.00-->0000.0000.0002.00    Type: P2P     LinkID: 2.2.2.9
 0000.0000.0003.00-->0000.0000.0004.01    Type: MULACC  LinkID: 30.1.1.2
 0000.0000.0004.00-->0000.0000.0004.01    Type: MULACC  LinkID: 30.1.1.2
 Total Number of TE Links in Level-2 Area: 6, Num Active: 6
Table 3 Output description
Type of the link
LinkID
ID of the link
Total number of TE links in the Level-2 area
Num Active
Number of active TE links
display isis traffic-eng network [ level-1 | level-1-2 | level-2 ] [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vpn-instance vpn-instance-name: Displays the IS-IS TE network information of the specified VPN. The vpn-instance-name argument specifies an MPLS L3VPN by its instance name, a case-sensitive string of 1 to 31 characters. To display the IS-IS TE network information of the public network, do not specify this option.
Use the display isis traffic-eng network command to display information about TE networks for IS-IS.
If no IS-IS level is specified, the TE network information in the IS-IS Level-1-2 area is displayed.
# Display information about TE networks for IS-IS.
<Sysname> display isis traffic-eng network
Level-1 Network Information
    DIS Router ID  : 89.1.1.1        DIS's Ip Address         : 86.1.1.1
    Status In CSPF : ACTIVE          Attached Router Count    : 2
    List of Attached Routers
 RouterId : 89.1.1.1   Nbr : 1111.1111.1111.00
 Link State : 1
 RouterId : 89.2.2.2   Nbr : 1111.1111.1113.00
 Link State : 1
 Total Number of TE Networks in Level-1 Area: 1, Num Active: 1
Level-2 Network Information
 Link State : 1
 Link State : 1
 Total Number of TE Networks in Level-2 Area: 1, Num Active: 1
Table 4 Output description
DIS's Ip Address
IP address of the DR router
Status In CSPF
CSPF state
Number of attached routers
List of attached routers
RouterId
Router ID
Nbr
Neighbors
Level-2 network information
display isis traffic-eng statistics [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vpn-instance vpn-instance-name: Displays the IS-IS TE statistics for the specified VPN. The vpn-instance-name argument specifies an MPLS L3VPN by its instance name, a case-sensitive string of 1 to 31 characters. To display the IS-IS TE statistics for the public network, do not specify this option.
Use the display isis traffic-eng statistics command to display the statistics about TE for IS-IS.
If no IS-IS level is specified, the statistics about TE in the IS-IS Level-1-2 area is displayed.
# Display statistics about TE for IS-IS.
<Sysname> display isis traffic-eng statistics
TE Statistics Information
 IS-IS System Type                          : Level-1-2
 IS-IS Cost Style Status                    : Wide
 IS-IS Level-1 Traffic Engineering Status   : Disabled
 IS-IS Level-2 Traffic Engineering Status   : Enabled
 IS-IS Router ID                            : 1.1.1.9
Table 5 Output description
IS-IS System Type
System type
Cost type of the router
TE state of Level-1 router
TE state of Level-2 router
display isis traffic-eng sub-tlvs [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vpn-instance vpn-instance-name: Displays the IS-IS sub-TLVs for TE in the specified VPN. The vpn-instance-name argument specifies an MPLS L3VPN by its VPN instance name, a case-sensitive string of 1 to 31 characters. To display TE sub-TLV information of the public network, do not specify this option.
Use the display isis traffic-eng sub-tlvs command to display information about sub-TLVs for the IS-IS TE extension.
If no IS-IS level is specified, information about TE extension sub-TLVs in the IS-IS Level-1-2 area is displayed.
Related commands: te-set-subtlv.
# Display TE sub-TLV information for IS-IS.
<Sysname> display isis traffic-eng sub-tlvs
IS-IS(1) SubTlv Information
 Unreserved sub-pool bandwidth sub-tlv value : 251
 Bandwidth constraint sub-tlv value          : 252
 LO multiplier sub-tlv value                 : 253
Table 6 Output description
Sub-TLV of unreserved subpool bandwidth
Bandwidth constraint sub-TLV
LOM sub-TLV
display mpls lsp bfd [ te tunnel tunnel-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
tunnel tunnel-number: Displays the BFD information of the specified MPLS TE tunnel. tunnel-number is the tunnel interface number.
Use the display mpls lsp bfd te command to display the BFD information for MPLS TE tunnels.
# Display the BFD information of the MPLS TE tunnel using tunnel interface Tunnel 0.
<Sysname> display mpls lsp bfd te Tunnel 0
               MPLS BFD Session(s) Information
 FEC            : Tunnel0           Type           : TE Tunnel
 Local Discr    : 3                 Remote Discr   : 3
 Tunnel ID      : 0xd2009           NextHop        : ----
 Session State  : Up                Source IP      : 1.1.1.1
 Session Role   : Active
 Total Session Num: 1
Table 7 Output description
Type of the tunnel detected by BFD, which can be LSP or TE Tunnel.
Local Discr
Local discriminator of the BFD session
Remote Discr
Remote discriminator of the BFD session
Session State
Status of the BFD session, which can be Init (initializing), Up, or Down.
Source IP
IP address of the active end (ingress LSR) of the BFD session
Session Role
Role of the LSR in the BFD session, Active or Passive
display mpls rsvp-te [ interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ] ]
View
Default level
1: Monitor level
interface: Displays RSVP-TE configuration for interfaces.
interface-type interface-number: Specifies an interface for which RSVP-TE configuration is displayed.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 80 characters.
Use the display mpls rsvp-te command to display RSVP-TE configuration.
If the interface keyword is not specified, the global RSVP-TE configuration is displayed.
If no interface is specified through the interface-type interface-number argument, the RSVP-TE configuration of all RSVP-TE enabled interfaces is displayed.
# Display the global RSVP-TE configuration.
<Sysname> display mpls rsvp-te
LSR ID: 4.4.4.4
 Resv Confirmation Request: DISABLE
 RSVP Hello Extension: ENABLE
 Hello interval: 3 sec         Max Hello misses: 3
 Path and Resv message refresh interval: 30 sec
 Path and Resv message refresh retries count: 3
 Blockade Multiplier: 4
 Graceful Restart: ENABLE
 Restart Time: 200 sec       Recovery Time: 150 sec
Table 8 Output description
LSR ID
Label switched Router ID, in the format of X.X.X.X
Reserved confirmation request
State of the hello mechanism: enabled or disabled
Hello Interval
Hello interval, in seconds
Max Hello misses
Maximum number of consecutive hello losses before a neighbor is considered dead
Path and reservation message refresh interval, in seconds
Number of Path and Resv message retransmissions
Blockade Multiplier
Blockade multiplier
Graceful Restart
State of GR: enabled or disabled
Restart Time
GR restart interval in seconds
Recovery Time
GR recovery interval in seconds
# Display the RSVP-TE configuration on interface GigabitEthernet 3/1/1.
<Sysname> display mpls rsvp-te interface GigabitEthernet 3/1/1
Interface GigabitEthernet3/1/1
 Interface state: UP       BFD feature: ENABLE
 Total-BW: 80              Used-BW: 20
 Hello configured: NO      Num of Neighbors: 1
 SRefresh feature: ENABLE  SRefresh Interval: 30sec
 Authentication: DISABLE   Reliability configured: NO
 Retransmit Interval: 500msec  Increment Value: 1
Table 9 Output description
Interface state
Physical interface state
BFD feature
State of BFD: enabled or disabled
Total-BW
Total bandwidth (in kbps)
Used-BW
Used bandwidth (in kbps)
Hello configured
Num of Neighbors
Number of neighbors connected to the interface
Srefresh feature
State of the summary refresh function: enabled or disabled
Srefresh interval
Summary refresh interval (in seconds)
Authentication
State of authentication: enabled or disabled
Reliability
Whether the reliability feature is configured: yes or no
Retransmit interval
Initial retransmission interval (in milliseconds)
Increment value
Increment value delta which governs the speed at which the interface increases the retransmission interval.
Assume the retransmission interval is Rf seconds. If the interface does not receive an ACK message for a packet within this interval, it retransmits the packet after (1 + Increment value) × Rf seconds.
display mpls rsvp-te established [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays the RSVP-TE tunnel information of all interfaces.
Use the display mpls rsvp-te established command to display information about RSVP-TE tunnels.
# Display the RSVP-TE tunnel information of interface GigabitEthernet 3/1/1.
<Sysname> display mpls rsvp-te established interface GigabitEthernet 3/1/1
 Token Bucket Rate: 0.00            Peak Data Rate: 0.00
 Tunnel Dest: 2.2.2.2               Ingress LSR ID: 3.3.3.3
 Local LSP ID: 4                    Session Tunnel ID: 4
 Next Hop Addr: 80.4.1.1
 Upstream Label: 1024               Downstream Label: 3
Table 10 Output description
Token Bucket rate
Token bucket rate, a traffic parameter
Peak Data Rate
Peak rate, a traffic parameter
Tunnel Dest
Tunnel destination, in the format of X.X.X.X
Ingress LSR ID
Ingress LSR ID, in the format of X.X.X.X
Next Hop Addr
Next hop address, in the format of X.X.X.X
display mpls rsvp-te peer [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display mpls rsvp-te peer command to display information about RSVP-TE neighbors on the specified or all interfaces.
# Display information about RSVP-TE neighbors on all interfaces.
<Sysname> display mpls rsvp-te peer
 Neighbor Addr: 80.4.1.1
 SrcInstance: 841             NbrSrcInstance: 928
 PSB Count: 0                 RSB Count: 1
 Hello Type Sent: ACK         Neighbor Hello Extension: ENABLE
 SRefresh Enable: NO          Reliability Enable: YES
 Graceful Restart State: Ready
Interface GigabitEthernet4/1/1
 Neighbor Addr: 80.2.1.1
 SrcInstance: 832             NbrSrcInstance: 920
 PSB Count: 1                 RSB Count: 0
 Hello Type Sent: REQ         Neighbor Hello Extension: ENABLE
 Graceful Restart State: Not Ready
 Restart Time: ---            Recovery Time: ---
Table 11 Output description
Neighbor Addr:
Neighbor address, in the format of  X.X.X.X.
SrcInstance
Instance of source Message ID
NbrSrcInstance
Instance of neighbor Message ID
PSB Count
Number of path state blocks
RSB Count
Number of reservation state blocks
Hello Type Sent
Type of hellos sent to the neighbor: REQ, ACK, or NONE
State of hello extension: enabled or disabled. This field is displayed only when hello extension is enabled on the interface.
SRefresh Enable
State of summary refresh: YES for enabled and NO for disabled
Reliability Enable
State of the reliability function: YES for enabled and NO for disabled
Neighbor’s GR status: Not Ready, Ready, Restart, or Recovery. Displayed as --- when not supported by the router.
Restart Time
Recovery Time
display mpls rsvp-te psb-content ingress-lsr-id lspid tunnel-id egress-lsr-id [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ingress-lsr-id: Ingress LSR ID.
lspid: Local LSR ID, in the range of 1 to 65535.
tunnel-id: Tunnel ID, in the range of 0 to 65535.
egress-lsr-id: Egress LSR ID.
Use the display mpls rsvp-te psb-content command to display information about RSVP-TE PSB.
# Display PSB information.
<Sysname> display mpls rsvp-te psb-content 19.19.19.19 1 0 29.29.29.29
The PSB Content:
 Tunnel Dest: 29.29.29.29     Session Tunnel ID: 0
 Tunnel ExtID: 19.19.19.19
 Ingress LSR ID: 19.19.19.19  Local LSP ID: 1
 Previous Hop : 101.101.101.1 Next Hop : -----
 Incoming / Outgoing Interface: GigabitEthernet3/1/1  /  -----
 InLabel : 3            OutLabel : NULL
Send Message ID : 1      Recv Message ID : 0
 Session Attribute-
   SetupPrio: 7         HoldPrio: 7
   SessionFlag: SE Style desired
  ERO Information-
     L-Type          ERO-IPAddr       ERO-PrefixLen
   ERHOP_STRICT    101.101.101.2         32
 RRO Information-
   RRO-CType: IPV4   RRO-IPAddress: 101.101.101.1   RRO-IPPrefixLen: 32
 SenderTspec Information-
   Token bucket rate: 0.00
   Token bucket size: 0.00
   Peak data rate: 0.00
   Minimum policed unit: 0
   Maximum packet size: 4294967295
 Path Message arrive on GigabitEthernet3/1/1 from PHOP 101.101.101.1
 Resource Reservation OK
 Graceful Restart State: Stale
 Bandwidth Constraint Mode: IETF DS-TE RDM
Table 12 Output description
Tunnel Dest
Session Tunnel ID
Session tunnel ID
Tunnel ExtID
Tunnel extension ID, in the format of X.X.X.X
Ingress LSR ID
Local LSP ID
Local LSP ID
Next Hop
Previous Hop
Previous hop address, in the format of X.X.X.X
In Label
Incoming label
Out Label
Outgoing label
Send message ID
Instance of sent Message ID
Resv Message ID
Instance of received Message ID
Setup Prio
Session setup priority
HoldPrio
Session hold priority
Session Flag
Session flag (local protection policy, label, SE style)
ERO Information
Information about explicit routes
L-Type
Explicit routing type: strict or loose
ERO-IPAddress
IP address for an explicit route
ERO-Prefix Len
Prefix length for an explicit route
RRO Information
Information about route recording
RRO-C Type
Type of route recording
RRO-IP Address
IP address of recorded route in the format of X.X.X.X
RRO-IPPrefixLen
IP prefix length of recorded route
Sender Tspec Information
Information about sender's service specifications
Token Bucket rate
Token bucket rate (in kbps), a traffic parameter
Token Bucket size
Token bucket size, a traffic parameter
Peak Data Rate
Peak data rate (in kbps), a traffic parameter
Maximum packet size
Maximum packet size, a traffic parameter
Minimum policed unit, a traffic parameter
Path message
Path message sent from the interface to the next hop at X.X.X.X
Resource
Available when the RSVP flag is configured
State of GR: stale or normal. Displayed as --- when not supported by the router.
Bandwidth constraints model carried in the path message, which can be:
·       IETF DS-TE RDM
·       IETF DS-TE MAM
·       Prestandard DS-TE RDM
display mpls rsvp-te request [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display mpls rsvp-te request command to display information about RSVP-TE requests on the specified or all interfaces.
# Display information about RSVP-TE requests on all interfaces.
<Sysname> display mpls rsvp-te request
Interface GigabitEthernet3/1/1:
 NextHopAddr: 80.4.1.1
 SessionFlag: SE Style desired.
 Token bucket rate: 0.00             Token bucket size: 1000.00
 Out Interface: GigabitEthernet4/1/1
Table 13 Output description
RSVP-TE enabled Ethernet interface
Tunnel Dest
Ingress LSR ID
Next Hop Address
SessionFlag
Reservation style
Token Bucket rate
Token Bucket Size
Out Interface
Output interface
display mpls rsvp-te reservation [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display mpls rsvp-te reservation command to display information about RSVP-TE reservations on the specified or all interfaces.
# Display information about RSVP-TE reservations on interface GigabitEthernet 3/1/1.
<Sysname> display mpls rsvp-te reservation interface GigabitEthernet 3/1/1
 Tunnel Dest: 29.29.29.29     Ingress LSR ID: 19.19.19.19
 LSP ID: 1                    Tunnel ID: 1
 Upstream Label: -----
 Token bucket rate: 0.00       Token bucket size: 0.00
# Display information about RSVP-TE reservations on all interfaces.
 Interface: Outgoing-Interface at the Egress
 Tunnel Dest: 19.19.19.19     Ingress LSR ID: 29.29.29.29
 Upstream Label: 3
Table 14 Output description
Tunnel Dest
Ingress LSR ID
Token Bucket rate
Token Bucket Size
display mpls rsvp-te rsb-content ingress-lsr-id Ispid tunnel-id egress-lsr-id nexthop-address [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
lspid: Local LSP ID, in the range of 1 to 65535.
nexthop-address: Next hop address.
Use the display mpls rsvp-te rsb-content command to display information about RSVP-TE reservation state blocks (RSBs).
# Display information about RSVP-TE RSBs.
<Sysname> display mpls rsvp-te rsb-content 19.19.19.19 1 0 29.29.29.29 101.101.101.2
The RSB Content:
 Next Hop: 101.101.101.2    Resevation Style: SE Style
 Reservation Incoming Interface: GigabitEthernet3/1/1
 Reservation Interface: GigabitEthernet3/1/1
 Message ID : 2
 Filter Spec Information-
   The filter number: 1
   Ingress LSR ID: 19.19.19.19    Local LSP ID: 1      OutLabel: 3
 RRO Information-
 RRO-Flag is
   RRO-CType: IPV4   RRO-IPAddress: 101.101.101.2      RRO-IPPrefixLen: 32
 FlowSpec Information-
   Token bucket rate: 2500.00
   Maximum packet size: 0
   Bandwidth guarantees: 0.00
   Delay guarantees: 0
   Qos Service is Controlled
 Resv Message arrive on GigabitEthernet3/1/1 from NHOP 101.101.101.2
Table 15 Output description
Tunnel Dest
Tunnel Ext ID
Tunnel extension (ingress LSR ID), in the format of X.X.X.X
Next Hop
Reservation Style
Reservation style: SE or FF
Reservation interface name
Reserve Incoming Interface
Incoming interface where the Resv message was received
Message ID
Message ID of the Refresh Reduction message
Filter specifications
The filter number
Number of filters
Ingress LSR ID
Out Label
Outgoing label
RRO Information
RRO-C Type
RRO-IP Address
RRO-IPPrefixLen
Flow Spec information
Flow specifications
Token Bucket rate
Token Bucket size
Peak Data Rate
Maximum packet size
Guaranteed bandwidth, a reservation specifications parameter
Delay guarantees
Delay guarantee, a reservation specifications parameter
QOS service
QoS guarantee/control
Resv Message
Reservation message received on interface GigabitEthernet 3/1/1 from next hop (X.X.X.X)
display mpls rsvp-te sender [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display mpls rsvp-te sender command to display RSVP-TE sender message information.
# Display the RSVP-TE sender message information on interface GigabitEthernet 3/1/1.
<Sysname> display mpls rsvp-te sender interface GigabitEthernet 3/1/1
 LSP ID: 1                   Session Tunnel ID: 1
 Session Name: Tunnel3
 Previous Hop Address: 101.101.101.1
 Token bucket rate: 0.0      Token bucket size: 0.00
# Display the RSVP-TE sender message information on all interfaces.
 LSP ID: 1                   Session Tunnel ID: 0
 Previous Hop Address: 101.101.101.2
Interface: Incoming-Interface at the Ingress
 Session Name: Tunnel2
 Previous Hop Address: 19.19.19.19
Table 16 Output description
Tunnel Dest
Ingress LSR ID
Token Bucket rate
Token Bucket Size
display mpls rsvp-te statistics { global | interface [ interface-type interface-number ] } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
global: Display global RSVP-TE information.
interface: Displays statistics about RSVP-TE for a specific interface or, if no interface is specified, all interfaces.
interface-type interface-number: Specifies an interface for which statistics about RSVP-TE is displayed.
Use the display mpls rsvp-te statistics command to display statistics about RSVP-TE.
# Display global RSVP-TE statistics.
<Sysname> display mpls rsvp-te statistics global
LSR ID: 1.1.1.1
 PSB Count: 1                          RSB Count: 1
 RFSB Count: 0                         TCSB Count: 1
 LSP Count: 1
Total Statistics Information:
 PSB CleanupTimeOutCounter: 0          RSB CleanupTimeOutCounter: 0
 SendPacketCounter: 55                 RecPacketCounter: 54
 SendPathCounter: 5                    RecPathCounter: 0
 SendResvCounter: 0                    RecResvCounter: 4
 SendResvConfCounter: 0                RecResvConfCounter: 0
 SendHelloCounter: 2                   RecHelloCounter: 48
 SendAckCounter: 48                    RecAckCounter: 2
 SendPathErrCounter: 0                 RecPathErrCounter: 0
 SendResvErrCounter: 0                 RecResvErrCounter: 0
 SendPathTearCounter: 0                RecPathTearCounter: 0
 SendResvTearCounter: 0                RecResvTearCounter: 0
 SendSrefreshCounter: 0                RecSrefreshCounter: 0
 SendAckMsgCounter: 0                  RecAckMsgCounter: 0
 SendErrMsgCounter: 0                  RecErrMsgCounter: 0
 RecReqFaultCounter: 0
# Display the RSVP-TE statistics of interface GigabitEthernet 3/1/1.
<Sysname> display mpls rsvp-te statistics interface GigabitEthernet 3/1/1
GigabitEthernet 3/1/1:
 SendPacketCounter: 69                 RecPacketCounter: 68
 SendPathCounter: 6                    RecPathCounter: 0
 SendResvCounter: 0                    RecResvCounter: 5
 SendHelloCounter: 2                   RecHelloCounter: 61
 SendAckCounter: 61                    RecAckCounter: 2
Table 17 Output description
PSB Count
Number of PSBs
RSB Count
Number of RSBs
RFSB Count
Number of RFSBs
TCSB Count
Number of TCSBs
LSP Count
Number of LSPs
Number of PSB timeouts
Number of RSB timeouts
SendPacketCounter
Number of transmitted packets
RecPacketCounter
Number of received packets
SendPathCounter
Number of transmitted Path messages
RecPathCounter
Number of received Path messages
SendResvCounter
Number of transmitted Resv messages
RecResvCounter
Number of received Resv messages
SendResvConfCounter
Number of transmitted ResvConf messages
RecResvConfCounter
Number of received ResvConf messages
SendHelloCounter
Number of transmitted Hello messages
RecHelloCounter
Number of received Hello messages
SendAckCounter
Number of transmitted Ack messages
RecAckCounter
Number of received Ack messages
SendPathErrCounter
Number of transmitted PathErr messages
RecPathErrCounter
Number of received PathErr messages
SendResvErrCounter
Number of transmitted ResvErr messages
RecResvErrCounter
Number of received ResvErr messages
SendPathTearCounter
Number of transmitted PathTear messages
RecPathTearCounter
Number of received PathTear messages
SendResvTearCounter
Number of transmitted ResvTear messages
RecResvTearCounter
Number of received ResvTear messages
SendSrefreshCounter
Number of transmitted Srefresh messages
RecSrefreshCounter
Number of received Srefresh messages
SendAckMsgCounter
Number of transmitted AckMsg messages
RecAckMsgCounter
Number of received AckMsg messages
SendErrMsgCounter
Number of transmitted errors
RecErrMsgCounter
Number of received errors
RecReqFaultCounter
Number of request failures
display mpls static-cr-lsp [ lsp-name lsp-name ] [ { include | exclude } ip-address prefix-length ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
lsp-name lsp-name: Label switched path name comprising 1 to 15 characters.
include: Displays only CR-LSPs with the destination IP address specified by the ip-address prefix-length arguments.
exclude: Displays only CR-LSPs with destination IP addresses other than the one specified by the ip-address prefix-length arguments.
ip-address: IP address of the FEC.
prefix-length: IP address prefix length, in the range of 0 to 32.
verbose: Displays detailed information.
·           begin: Displays the first line that matches the specified regular expression and all lines that follow.
·           exclude: Displays all lines that do not match the specified regular expression.
·           include: Displays all lines that match the specified regular expression.
·           regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display mpls static-cr-lsp command to display information about static CR-LSPs.
# Display brief information about all static CR-LSPs.
<Sysname> display mpls static-cr-lsp
total statics-cr-lsp : 1
Name         FEC               I/O Label  I/O If                State
Tunnel3      3.3.3.9/32        NULL/100   -/GE3/1/1             Down
Table 18 Output description
Name
Static CR-LSP name
FEC
Forwarding equivalence class (FEC) associated with the destination IP address of LSP
I/O Label
Incoming/outgoing label
I/O If
Incoming/outgoing interface
Current state of the CR-LSP
# Display detailed information about all static CR-LSPs.
<Sysname> display mpls static-cr-lsp verbose
No             : 1
LSP-Name       : Tunnel3
LSR-Type       : Transit
FEC            : -/-
In-Label       : 20
Out-Label      : 30
In-Interface   : GigabitEthernet3/1/1
Out-Interface  : GigabitEthernet4/1/1
NextHop        : 3.2.1.2
Lsp Status     : Up
Table 19 Output description
LSP-Name
Static CR-LSP name
LSR-Type
Role of the LSR in the LSP: ingress, transit, or egress
FEC
In-Label
Incoming label
Out-Label
Outgoing label
In-Interface
Incoming interface
Out-Interface
Outgoing interface
NextHop
Next hop address
Lsp Status
Status of the LSP
display mpls te cspf tedb { all | area area-id | interface ip-address | network-lsa | node [ mpls-lsr-id ] } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
area-id: Area ID. For OSPF, it ranges from 0 to 4294967295; for IS-IS, it takes the value of 1 or 2.
ip-address: IP address of an interface.
network-lsa: Displays traffic engineering database (TEDB) information in network LSAs.
node: Displays the TEDB information on nodes. If no node is specified, the TEDB information on all nodes is displayed.
mpls-lsr-id: Specifies a node by its MPLS LSR ID.
Use the display mpls te cspf tedb command to display information about CSPF-based TEDB by specified criteria.
# Display TEDB information in network LSAs.
<Sysname> display mpls te cspf tedb network-lsa
Maximum Network LSA Supported:  500
Current Total Network LSA Number:       7
Id   DR MPLS LSR-Id DR-Address       IGP   Process-Id  Area  Neighbor
1    8.1.1.2        3.0.0.2          OSPF  100         0     1.1.1.1
                                                             2.1.1.1
                                                             8.1.1.2
2    2.1.1.1        3.0.0.3          OSPF  100         0     2.1.1.1
                                                             3.1.1.1
                                                             2.1.1.2
3    3.1.1.2        3.0.0.4          OSPF  100         0     3.1.1.1
                                                             4.1.1.1
                                                             3.1.1.2
4    4.1.1.2        3.0.0.5          OSPF  100         0     4.1.1.1
                                                             5.1.1.1
                                                             4.1.1.2
5    5.1.1.2        3.0.0.6          OSPF  100         0     5.1.1.1
                                                             6.1.1.1
                                                             5.1.1.2
6    6.1.1.2        3.0.0.9          OSPF  100         0     6.1.1.1
                                                             7.1.1.1
                                                             6.1.1.2
7    7.1.1.1        12.0.0.7         OSPF  100         0     3.1.1.1
                                                             7.1.1.1
                                                             7.1.1.2
Table 20 Output description
ID
Number
DR MPLS LSR-Id
MPLS LSR ID of the designated router (DR)
DR-Address
Interface address of the DR
IGP
Interior gateway protocol: OSPF or IS-IS
Process-Id
IGP process ID
Area
Area to which the router belongs
Neighbor
Neighbor router ID
# Display all TEDB information.
<Sysname> display mpls te cspf tedb all
Maximum Node Supported: 1000            Maximum Link Supported: 4000
Current Total Node Number: 3            Current Total Link Number: 44
Id    MPLS LSR-Id     IGP     Process-Id    Area            Link-Count
1     1.1.1.1         OSPF    100           1001,1002,1003  20
                                            1004,1005,1006
                                            1007,1008,1009
                                            1010,1,2
                                            13,14,15
                                            16,17,18
                                            19,20
2     2.1.1.1         ISIS    100           Level-0,1       20
3     3.1.1.1         OSPF    100           0               4
Table 21 Output description
ID
Number
MPLS LSR-Id
MPLS LSR ID
IGP
Process-Id
IGP process ID
Area
Link-count
Total number of connected links belonging to a particular IGP protocol process
# Display the TEDB information of IGP area 1.
<Sysname> display mpls te cspf tedb area 1
Router Node Information for Area 1:
1      2.2.2.2        OSPF    100            1               1
2      3.3.3.3        OSPF    100            1               1
3      2.2.2.2        ISIS    100            Level-1         1
4      3.3.3.3        ISIS    100            Level-1         1
Network LSA Information for Area 1:
1    3.3.3.3         20.1.1.2      OSPF 100        1       2.2.2.2
                                                           3.3.3.3
2    3.3.3.3         20.1.1.2      ISIS 100        Level-1 3.3.3.3
                                                           2.2.2.2
Table 22 Output description
Id
Number
MPLS LSR-Id
MPLS LSR ID, in dotted decimal notation
IGP
Process-Id
IGP process ID
Area
Link-Count
DR MPLS LSR-Id
MPLS LSR ID of the DR
DR-Address
Neighbor
MPLS LSR ID of the neighbor
# Display the TEDB information of all nodes in prestandard DS-TE mode.
<Sysname> display mpls te cspf tedb node
MPLS LSR-Id: 1.1.1.1
  IGP Type: OSPF   Process Id: 100
  MPLS-TE Link Count: 1
  Link[1] :
    Interface IP Address: 2.0.0.33, 2.0.0.35, 2.0.0.36,
    Neighbor  IP Address: 2.0.0.2, 2.0.0.42, 2.0.0.43,
                          2.0.0.44, 2.0.0.45, 2.0.0.46,
                          2.0.0.47, 2.0.0.32,
    Neighbor  MPLS LSR-Id : 1.1.1.2
    IGP Area: 1
    Link  Type: point-to-point  Link Status: Inactive
    IGP Metric: 100             TE Metric: 100         Color: 0xff
    Maximum Bandwidth: 100 (kbps)
    Maximum Reservable Bandwidth: 20 (kbps)
    Bandwidth Constraint Mode: Prestandard DS-TE RDM
         BC[0] :  100        (kbps)
         BC[1] :  20         (kbps)
    Unreserved Bandwidth for each TE Class:
         [0] :    10         (kbps),  [1] :     10         (kbps)
         [2] :    10         (kbps),  [3] :     10         (kbps)
         [4] :    10         (kbps),  [5] :     10         (kbps)
         [6] :    10         (kbps),  [7] :     10         (kbps)
         [8] :    10         (kbps),  [9] :     10         (kbps)
         [10]:    10         (kbps),  [11]:     10         (kbps)
         [12]:    10         (kbps),  [13]:     10         (kbps)
         [14]:    10         (kbps),  [15]:     10         (kbps)
  IGP Type: ISIS   Process Id: 100
  MPLS-TE Link Count: 2
  Link[1] :
                          2.0.0.47, 2.0.0.32, 2.0.0.33
    Neighbor  MPLS LSR-Id: 1.1.1.2
    IGP Area: Level-0
    Link  Type: point-to-point  Link Status: Active
    IGP Metric: 10              TE Metric: 10          Color: 0x11
    Maximum Reservable Bandwidth: 100 (kbps)
         BC[0] :  100        (kbps)
         BC[1] :  20         (kbps)
Table 23 Output description
MPLS LSR-Id
MPLS LSR ID of node
Process Id
IGP process ID
MPLS-TE Link Count
Number of MPLS TE links
Link[1]
Information of the first link
DR Address
IGP Metric
IGP metric of link
TE Metric
TE metric of link
Color
Link administrative attribute
Maximum Bandwidth
Maximum bandwidth of the link
Maximum reservable bandwidth of link
Bandwidth constrains model
Reservable bandwidth for each TE class
# Display TEDB information of a specific interface address in IETF DS TE RDM mode.
<Sysname> display mpls te cspf tedb interface 20.1.1.1
MPLS LSR-Id: 2.2.2.2
  Link[1] :
    Interface IP Address: 20.1.1.1
    DR Address: 20.1.1.2
    IGP Area: Level-1
    Link  Type: multi-access  Link Status: Active
    IGP Metric: 10              TE Metric: 0           Color: 0x0
    Maximum Bandwidth: 0 (kbps)
    Maximum Reservable Bandwidth: 0 (kbps)
         BC[0] :  0          (kbps)
         BC[1] :  0          (kbps)
         BC[2] :  0          (kbps)
         BC[3] :  0          (kbps)
         [0] :    0          (kbps), [1] :     0          (kbps)
         [2] :    0          (kbps), [3] :     0          (kbps)
         [4] :    0          (kbps), [5] :     0          (kbps)
         [6] :    0          (kbps), [7] :     0          (kbps)
Table 24 Output description
MPLS LSR-Id
MPLS LSR ID of node
Process Id
IGP process ID
MPLS-TE Link Count
Link[1]
Interface IP address
DR Address
IGP Metric
IGP metric of link
TE Metric
TE metric of link
Color
Maximum Bandwidth
Maximum reservable bandwidth of the link
display mpls te ds-te [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display mpls te ds-te command to display information about DS-TE.
# Display information about DS-TE.
<Sysname> display mpls te ds-te
  MPLS DS-TE mode      :  Prestandard
  MPLS DS-TE BC mode   :  RDM
  TE CLASS    ClassType     Priority
  0           0             0
  1           0             1
  2           0             2
  3           0             3
  4           0             4
  5           0             5
  6           0             6
  7           0             7
  8           1             0
  9           1             1
  10          1             2
  11          1             3
  12          1             4
  13          1             5
  14          1             6
  15          1             7
Table 25 display mpls te ds-te command output information
MPLS DS-TE mode
DS-TE mode, which can be Prestandard or IETF
MPLS DS-TE BC mode
DS-TE BC model, which can be RDM or MAM
TE class-CT-priority mapping
display mpls te link-administration admission-control [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Specifies an interface by its type and a number.
Use the display mpls te link-administration admission-control command to display information about CR-LSPs carried on the link of a specific interface or links of all interfaces if no interface is specified.
# Display information about the CR-LSPs carried on the links of all interfaces.
<Sysname> display mpls te link-administration admission-control
LspID            In/Out IF           S/H Prio    CT       BW(kbps)
1.1.1.9:1024    ---/GE3/1/1          7/7         0        0
1.1.1.9:2048    ---/GE4/1/1          7/7         0        0
The following table gives the description on the fields of the display mpls te link-administration admission-control command.
Table 26 Output description
LspID
ID of an LSP carried on a link
In/Out IF
Incoming/Outgoing interface
S/H Prio
Setup and holding priorities of CR-LSP
CT
Service class type
BW(kbps)
Bandwidth (in kbps)
display mpls te link-administration bandwidth-allocation [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display mpls te link-administration bandwidth-allocation command to display bandwidth allocation on the specified or all MPLS TE enabled interfaces.
# Display bandwidth allocation on the MPLS TE enabled interface in prestandard mode.
<Sysname> display mpls te link-administration bandwidth-allocation
Link ID:  GigabitEthernet3/1/1
  Max Link Bandwidth                          :  3200000 kbits/sec
  Max Reservable Bandwidth of Prestandard RDM :  2000000 kbits/sec
  Max Reservable Bandwidth of IETF RDM        :  200000 kbits/sec
  Max Reservable Bandwidth of IETF MAM        :  300000 kbits/sec
  Downstream LSP Count       :  0
  UpStream LSP Count         :  0
  Downstream Bandwidth       :  0 kbits/sec
  Upstream Bandwidth         :  0 kbits/sec
  IPUpdown Link Status       :  UP
  PhysicalUpdown Link Status :  UP
  BC  Prestandard RDM(kbps)  IETF Mode RDM(kbps)  IETF Mode MAM(kbps)
  0   2000000                200000               2000
  1   1000000                150000               2000
  2   0                      100000               2000
  3   0                      50000                2000
  TE CLASS    CLASS TYPE    PRIORITY   BW RESERVED(kbps)  BW AVAILABLE(kbps)
      0           0             0            0            2000000
      1           0             1            0            2000000
      2           0             2            0            2000000
      3           0             3            0            2000000
      4           0             4            0            2000000
      5           0             5            0            2000000
      6           0             6            0            2000000
      7           0             7            1000         1999000
      8           1             0            0            1000000
      9           1             1            0            1000000
     10           1             2            0            1000000
     11           1             3            0            1000000
     12           1             4            0            1000000
     13           1             5            0            1000000
     14           1             6            0            1000000
     15           1             7            0            1000000
The following table gives the description on the fields of the display mpls te link-administration bandwidth-allocation command.
Table 27 Output description
Number of downstream LSPs
UpStream LSP Count
Number of upstream LSPs
IP layer link status
Physical layer link status
BC
Bandwidth constraint number
Prestandard RDM
Bandwidth constraints in prestandard RDM mode, in kbps
IETF Mode RDM
Bandwidth constraints in IETF RDM mode, in kbps
IETF Mode MAM
TE CLASS
TE class
CLASS TYPE
Service class type
BW RESERVED
Bandwidth reserved for the TE class, in kbps
BW AVAILABLE
Bandwidth available for the TE class, in kbps
display mpls te protection tunnel { tunnel-id | all } [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
tunnel-id: ID of a main tunnel.
all: Displays information about all protection groups.
verbose: Displays the detailed information.
Use the display mpls te protection tunnel command to display information about the specified tunnel or all tunnels and the corresponding protection tunnel(s).
# Display information about tunnel 100 and its protection tunnel.
<Sysname> display mpls te protection tunnel 100
Work-tunnel id     Protect-tunnel id     Switch-Result
100                101                   work-tunnel
# Display the detailed information of tunnel 100 and its protection tunnel.
<Sysname> display mpls te protection tunnel 100 verbose
Work-tunnel id                 :   100
Protect-tunnel id              :   101
Switch result                  :   work-tunnel
Work-tunnel defect state       :   No-defect
Protect-tunnel defect state    :   No-defect
Holdoff                        :   5000ms
WTR                            :   150s
Mode                           :   revertive
Holdoff timer                  :   not start
WTR timer                      :   not start
The current switch command     :   --
Table 28 Output description
Work-tunnel id
Main tunnel’s ID
Protect-tunnel id
Protection tunnel’s ID
Switch result
Tunnel in use, which can be work-tunnel or protect-tunnel
State of the main tunnel, which can be:
·       No-defect: The main tunnel is normal.
·       In-defect: The main tunnel is failed.
State of the protection tunnel, which can be:
·       No-defect: The protection tunnel is normal.
·       In-defect: The protection tunnel is failed.
Holdoff
Switching delay time, that is, time to wait before switching to the backup tunnel
WTR
Reverting delay time, that is, time to wait before switching back the main tunnel
Mode
Reverting mode, which can be revertive or non-revertive
Executed external switching command
display mpls te tunnel [ destination dest-addr ] [ lsp-id lsr-id lsp-id ] [ lsr-role { all | egress | ingress | remote | transit } ] [ name name ] [ { incoming-interface | outgoing-interface | interface } interface-type interface-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
destination address: Specifies a destination IP address to display only the tunnels with the specified destination IP address.
lsr-id: LSR ID of the ingress node, in dotted decimal notation.
lsp-id: LSP ID, in the range of 1 to 65535.
lsr-role: Displays tunnels by LSR role (ingress, transit, egress, or remote).
all: Displays all tunnels.
egress: Displays tunnels created taking current router as the egress.
ingress: Displays tunnels created taking current router as the ingress .
remote: Displays tunnels created taking the current device as the egress or a transit node.
transit: Displays tunnels created taking current router as a transit node.
name name: Displays the tunnel with a particular name. This could be a string of 1 to 63 characters configured as interface description or the interface name if no interface description is configured. The tunnel name should be signaled to all hops.
incoming-interface: Displays all tunnels that use the interface identified by the interface-type interface-number arguments as the incoming interface.
outgoing-interface: Displays all tunnels that use the interface identified by the interface-type interface-number arguments as the outgoing interface.
interface: Displays all tunnels that use the interface identified by the interface-type interface-number arguments as the incoming or outgoing interface.
Use the display mpls te tunnel command to display information about MPLS TE tunnels.
# Display information about MPLS TE tunnels. (The output may vary by signaling protocol.)
<Sysname> display mpls te tunnel
LSP-Id            Destination     In/Out-If            Name
1.1.1.9:1024      3.3.3.9         -/GE3/1/1            Tunnel3
1.1.1.9:2048      3.3.3.9         -/GE4/1/1            Tunnel2
Table 29 Output description
LSP-ID
LSP ID of tunnel
Destination
Destination router ID
In/Out-IF
Name
Tunnel name configured on the ingress node
# Display detailed information about MPLS TE tunnels.
<Sysname> display mpls te tunnel verbose
No             : 1
LSP-Id         : 1.1.1.9:1024
Tunnel-Name    : Tunnel3
Destination    : 3.3.3.9
In-Interface   : -
Out-Interface  : GigabitEthernet 3/1/1
Tunnel BW      : 0 kbps
Class Type     : CT0
Ingress LSR-Id : 1.1.1.9
Egress LSR-Id  : 3.3.3.9
Setup-Priority : 7
Hold-Priority  : 7
Sign-Protocol  : RSVP TE
Resv Style     : SE
IncludeAnyAff  : 0x0
ExcludeAllAff  : 0x0
IncludeAllAff  : 0x0
Created Time   : 2007/10/18 16:05:17
Table 30 Output description
No
Number
LSP-Id
LSP ID of tunnel
Tunnel-Name
Destination
In-Interface
Incoming interface
Out-Interface
Outgoing interface
Tunnel BW
Tunnel bandwidth
Class Type
Service class type
Ingress LSR-Id
Ingress LSR ID
Egress LSR-Id
Egress LSR-ID
Setup-Priority
Setup priority of link
Hold-Priority
Holding priority of link
Sign-Protocol
Signaling protocol
Resv Style
Reservation style
IncludeAnyAff
Any affinity properties that must be included
ExcludeAllAff
Link properties that are excluded
IncludeAllAff
All link affinity properties that must be included
Created Time
Time when the tunnel was created
display mpls te tunnel path [ lsp-id lsr-id lsp-id | tunnel-name tunnel-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
lsr-id: Ingress LSR ID, in dotted decimal notation.
tunnel-name tunnel-name: Tunnel name, a string of 1 to 63 characters.
Use the display mpls te tunnel path command to display the path or paths that the specified or all MPLS TE tunnels traverse on this node.
# Display the paths that all MPLS TE tunnels traverse.
<Sysname> display mpls te tunnel path
Tunnel Interface Name : Tunnel3
Lsp ID :  1.1.1.9:10
Hop information:
Hop 0: 192.1.1.1;
Hop 1: 12.1.1.2;
Hop 2: 10.202.2.2.
Table 31 Output description
Lsp ID
LSP ID
Hop 0
Hop 0 on the path
Hop 1
Hop 1 on the path
Hop 2
Hop 2 on the path
display mpls te tunnel statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display mpls te tunnel statistics command to display statistics about MPLS TE tunnels.
# Display statistics about MPLS TE tunnels.
<Sysname> display mpls te tunnel statistics
Ingress:   0 Tunnels,    0 Tunnels Up,    0 CRLSPs Up
           0 Modified,   0 In-Progress,   0 Failed
Transit:   0 Up
Egress :   0 Up
Table 32 Output description
Ingress
This router is the tunnel ingress.
Transit
This router is a transit node on the tunnel.
Egress
This router is the tunnel egress.
Modified
Number of CR-LSP tunnels that use this router as the ingress and are in modified state.
In-Progress
Number of CR-LSP tunnels that use this router as the ingress and are in in-progress state.
Failed
Number of CR-LSP tunnels that use this router as the ingress and are in failed state.
display mpls te tunnel-interface [ tunnel number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
tunnel number: Displays information about a specific tunnel interface.
Use the display mpls te tunnel-interface command to display information about MPLS TE tunnel interfaces on this node.
# Display information about MPLS TE tunnel interfaces on this node.
<Sysname> display mpls te tunnel-interface
  Tunnel Name         :  Tunnel3
  Tunnel Desc         :  Tunnel3 Interface
  Tunnel State Desc   :  CR-LSP is Up
  Tunnel Attributes   :
    LSP ID              :  1.1.1.9:1
    Session ID          :  10
    Admin State         :  UP                    Oper State   :  UP
    Ingress LSR ID      :  1.1.1.9               Egress LSR ID:  2.2.2.9
    Signaling Prot      :  CR LDP                Resv Style   :  -
    Class Type          :  CT0                   Tunnel BW    :  2000 kbps
    Reserved BW         :  2000 kbps
    Setup Priority      :  7                     Hold Priority:  7
    Affinity Prop/Mask  :  0/0
    Explicit Path Name  :  -
    Tie-Breaking Policy :  None
    Metric Type         :  None
    Record Route        :  Disabled          Record Label :  Disabled
    FRR Flag            :  Disabled          BackUpBW Flag:  Not Supported
    BackUpBW Type       :  -                 BackUpBW     :  -
    Route Pinning       :  Disabled
    Retry Limit         :  10                Retry Interval:  10
    Reopt               :  Disabled          Reopt Freq   :  -
    Back Up Type        :  None
    Back Up LSPID       :  -
    Auto BW             :  Disabled          Auto BW Freq :  -
    Min BW              :  -                 Max BW       :  -
    Current Collected BW:  -
    Interfaces Protected:  -
    VPN Bind Type       :  NONE
    VPN Bind Value      :  -
    Car Policy          :  Disabled
    Tunnel  Group       :  Secondary
    Primary Tunnel      :  120
    Backup  Tunnel      :  -
    Group   Status      :  -
    Oam     Status      :  -
Table 33 Output description
Tunnel Desc
Tunnel description
Tunnel State Desc
Tunnel state description
Admin State
Administrative state
Oper State
Operation state
Signaling Prot
Signaling protocol
Resv Style
Reservation style
Class Type
Service class type
Tunnel BW
Tunnel bandwidth
Reserved BW
Reserved bandwidth
Setup Priority
Setup priority of LSP
Hold Priority
Hold priority of LSP
Affinity Prop/Mask
Affinity attribute and mask
Tie-Breaking Policy
Path selection policy
Record Route
State of the route recording function
Record Label
State of the label recording function
FRR Flag
Fast reroute (FRR) flag
BackUpBW Flag
Backup bandwidth flag
BackUpBW Type
Backup bandwidth type
BackUpBW
Backup bandwidth
Route Pinning
Route pinning function
Retry Limit
Maximum number of setup retries
Retry Interval
Retry interval
Reopt
State of the reoptimization function
Reopt Freq
Reoptimization interval
Back Up Type
Backup path type
Back Up LSPID
Backup LSP ID
Auto BW
State of the automatic bandwidth adjustment function
Auto BW Freq
Automatic bandwidth adjustment interval
Min BW
Lower limit for automatic bandwidth adjustment
Max BW
Upper limit for automatic bandwidth adjustment
Bandwidth information currently collected
FRR protected interfaces
VPN Bind Type
Type of the binding, VPN or ACL
VPN Bind Value
Value of the binding, the VPN instance name or ACL number
Car Policy
Whether CAR policy is enabled
Tunnel Group
Whether the tunnel is the primary tunnel or backup tunnel in the group.
Primary Tunnel
Tunnel ID of the corresponding primary tunnel. Displayed as a hyphen (-) for a primary tunnel.
Backup Tunnel
Tunnel ID of the corresponding backup tunnel. Displayed as a hyphen (-) for a backup tunnel.
Group Status
Status of the group. Displayed as - if no protection group is configured.
Oam Status
OAM defect detection status.  A hyphen (-) means OAM is not enabled.
display ospf [ process-id ] mpls-te [ area area-id ] [ self-originated ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
process-id: OSPF process ID, in the range of 1 to 65535. If a process is specified, only the TE LSAs of this process are displayed; if no process is specified, the TE LSAs of all processes are displayed.
area area-id: Displays the TE LSAs of a specific OSPF area. The area-id argument takes an integer in the range of 0 to 4294967295 or the form of IPv4 address.
self-originated: Displays self originated TE LSAs.
Use the display ospf mpls-te command to display TE LSAs in the link state database (LSDB).
# Display all TE LSAs in the LSDB.
<Sysname> display ospf mpls-te
OSPF Process 100 with Router ID 10.0.0.1
Area ID:
 Traffic Engineering LSA’s of the database
 LSA []
   LSA  Type                 : Opq-Area
   Opaque Type              : 1
   Opaque ID                :
   Advertising Router ID  : xxx.xxx.xxx.xxx
   LSA  Age                 :
   Length                   :
   LSA  Options             :
   LS Seq Number            :
   CheckSum                 :
   Link Type               :Point to Point / Point to Multi Point /MultiAccess
   Link ID                  :
   Local Interface Address  : xxx.xxx.xxx.xxx
   Remote Interface Address : xxx.xxx.xxx.xxx
   TE Metric                :
   Maximum Bandwidth        :  bytes/sec
   Maximum Reservable BW    :  bytes/sec
   Admin Group              :
       Unreserved BW [ 0] =   0  bytes/sec
       Unreserved BW [ 1] =   0  bytes/sec
       Unreserved BW [ 2] =   0  bytes/sec
       Unreserved BW [ 3] =   0  bytes/sec
       Unreserved BW [ 4] =   0  bytes/sec
       Unreserved BW [ 5] =   0  bytes/sec
       Unreserved BW [ 6] =   0  bytes/sec
       Unreserved BW [ 7] =   0  bytes/sec
       Unreserved BW [ 8] =   0  bytes/sec
       Unreserved BW [ 9] =   0  bytes/sec
       Unreserved BW [10] =   0  bytes/sec
       Unreserved BW [11] =   0  bytes/sec
       Unreserved BW [12] =   0  bytes/sec
       Unreserved BW [13] =   0  bytes/sec
       Unreserved BW [14] =   0  bytes/sec
       Unreserved BW [15] =   0  bytes/sec
       BC [ 0] =   bytes/sec
       BC [ 1] =   bytes/sec
Table 34 Output description
Area ID
TE enabled OSPF area ID.
LSA Type
LSA type which must be Opd-Area, carried in the Opaque LSA header
Opaque Type
1 for TE, carried in the header of Opaque LSA
Opaque ID
Opaque ID, carried in the header of Opaque LSA
Router ID of the node where the LSA was generated
LSA age
LSA age, carried in  the header of Opaque LSA
Length
LSA length, carried in the header of Opaque LSA
LSA Options
LSA options, carried in the header of Opaque LSA
LS Seq Number
LSA sequence number, carried in the header of Opaque LSA
Checksum
LSA checksum, carried in the header of Opaque LSA
Link Type
Link type: point to point, point to multipoint, or multiAccess
Admin Group
Administrative group attribute
Unreserved BW [0] to [15]
Available bandwidth of the 16 TE classes
Bandwidth constraints (only significant for DS-TE LSAs)
BC 0–1
Two types of bandwidth constraints (only significant for DS-TE LSAs): BC0 and BC1
display ospf [ process-id ] traffic-adjustment [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display ospf traffic-adjustment command to display the settings of tunnel traffic adjustment (IGP shortcut and forwarding adjacency) for a specific or for all OSPF processes.
# Display the settings of tunnel traffic adjustment for all OSPF processes.
<Sysname> display ospf traffic-adjustment
OSPF Process 100 with Router ID 100.0.0.1
Traffic adjustment
Interface: 100.0.0.1 (Tunnel3)
     Type: Forwarding Adjacency  State: Up
     Neighbor ID: 100.0.0.2   Cost: 100
     Configuration:
     Neighbor Ip Address: 100.0.0.2
     Cost               : -10
     Cost Type          : Relative
     Hold time          : 10s
Table 35 Output description
Tunnel interface address and name
Approach to automatic route advertisement: IGP shortcut or forwarding adjacency
Neighbor ID
Remote neighbor ID
State: up or down
display tunnel-info
display tunnel-info { tunnel-id | all | statistics } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
tunnel-id: Specifies a tunnel ID, in the range of 1 to FFFFFFFE. If a tunnel is specified, only information about this tunnel will be displayed.
all: Display information about all tunnels.
statistics: Displays statistics about tunnels.
Use the display tunnel-info command to display information about tunnels.
# Display information about all tunnels.
<Sysname> display tunnel-info all
Tunnel ID           Type              Destination
0x1100002           lsp               2.2.2.2
# Display statistics about tunnels.
<Sysname> display tunnel-info statistics
Tunnel Allocation Method :    GLOBAL
Avail Tunnel ID Value :       65535
Total Tunnel ID Allocated :   1
LSP :                         1
GRE :                         0
CRLSP :                       0
LOCAL IFNET :                 0
MPLS LOCAL IFNET :            0
Table 36 Output description
The way that tunnels are allocated
Available tunnel ID
Total number of tunnel IDs that have been allocated
LSP
Number of LSP tunnels
GRE
Number of GRE tunnels
CRLSP
LOCAL IFNET
Number of CE-side interfaces in MPLS L2VPN
MPLS LOCAL IFNET
Number of outgoing interfaces in CCC remote mode in MPLS L2VPN
undo enable traffic-adjustment
View
OSPF view
Default level
2: System level
None
Use the enable traffic-adjustment command to enable IGP shortcut.
Use the undo enable traffic-adjustment command to disable IGP shortcut.
By default, IGP shortcut is disabled.
IGP shortcut allows OSPF to include static LSP tunnels in SPF calculation and advertise them to OSPF neighbors.
# Enable IGP shortcut when the IGP protocol is OSPF.
[Sysname] ospf 100
[Sysname-ospf-100] enable traffic-adjustment
enable traffic-adjustment advertise
undo enable traffic-adjustment advertise
View
OSPF view
Default level
2: System level
None
Use the enable traffic-adjustment advertise command to enable forwarding adjacency.
Use the undo enable traffic-adjustment advertise command to disable forwarding adjacency.
By default, forwarding adjacency is disabled.
Forwarding adjacency allows OSPF to include static LSP tunnels in SPF calculation and flooding.
# Enable forwarding adjacency when the IGP protocol is OSPF.
[Sysname] ospf 100
[Sysname-ospf-100] enable traffic-adjustment advertise
explicit-path
explicit-path pathname [ disable | enable ]
undo explicit-path pathname
View
Default level
2: System level
pathname: Name of an explicit path for a tunnel, a string of 1 to 31 characters.
disable: Disables explicit routing.
enable: Enables explicit routing.
Use the explicit-path command to create an explicit path and enter its view.
Use the undo explicit-path command to remove an explicit path.
# Create an explicit path named path1 and enter its view.
list hop
list hop [ ip-address ]
View
Explicit path view
Default level
2: System level
ip-address: Specifies the IP address of a node on the explicit path. If no IP address is specified, information about all the nodes on the explicit path is displayed.
Use the list hop command to display information about specified or all nodes on the explicit path.
# Display information about all nodes on an MPLS TE explicit path.
[Sysname-explicit-path-path1] list hop
Path Name :   path1        Path Status :  Enabled
1             1.1.1.9      Strict         Include
2             2.2.2.9      Strict         Exclude
modify hop
modify hop ip-address1 ip-address2 [ include [ loose | strict ] | exclude ]
View
Explicit path view
Default level
2: System level
ip-address1 ip-address2: Substitutes the IP address specified by the ip-address2 argument for the IP address specified by the ip-address1 argument in the explicit path. The specified IP addresses could be link IP addresses or router IDs of nodes.
include: Includes the node ip-address2 on the explicit path.
loose: Specifies the node ip-address2 as a loose node, which means that ip-address2 and its previous hop can be connected indirectly.
strict: Specifies the node ip-address2 as a strict node, which means that ip-address2 and its previous hop must be connected directly.
exclude: Excludes the node ip-address2 from subsequent path calculations for the explicit path.
Use the modify hop command to change a node on the explicit path, including the node’s IP address and other attributes (include or exclude, strict or loose).
# Replace IP address 10.0.0.125 with IP address 10.0.0.200 for the explicit path path1 and exclude this new IP address from subsequent path calculations.
[Sysname-explicit-path-path1] modify hop 10.0.0.125 10.0.0.200 exclude
mpls rsvp-te
mpls rsvp-te
undo mpls rsvp-te
View
MPLS view, interface view
Default level
2: System level
None
Use the mpls rsvp-te command to enable RSVP-TE.
Use the undo mpls rsvp-te command to disable RSVP-TE.
By default, RSVP-TE is disabled.
·           You must enable RSVP-TE before you can configure other RSVP-TE features.
·           Before enabling RSVP-TE in MPLS view on a node, you need to enable MPLS in system view and MPLS TE in MPLS view.
·           Before enabling RSVP-TE in interface view, you need to enable MPLS and MPLS TE in interface view.
·           Disabling RSVP-TE in MPLS view disables RSVP-TE on interfaces.
# Enable RSVP-TE on current node.
[Sysname] mpls
[Sysname-mpls] mpls te
[Sysname-mpls] mpls rsvp-te
# Enable RSVP-TE on interface GigabitEthernet 3/1/1.
[Sysname] interface GigabitEthernet 3/1/1
[Sysname-GigabitEthernet3/1/1] mpls
[Sysname-GigabitEthernet3/1/1] mpls te
[Sysname-GigabitEthernet3/1/1] mpls rsvp-te
mpls rsvp-te authentication
mpls rsvp-te authentication { cipher | plain } auth-key
undo mpls rsvp-te authentication
View
Interface view
Default level
2: System level
cipher: Enters and displays the authentication key in cipher text.
plain: Enters the authentication key in plain text and displays the authentication key in plain text.
auth-key: Specifies the authentication key. This argument is case sensitive. If cipher is specified, it must be a ciphertext string of 8 to 53 characters. If plain is specified, it must be a string of 8 to 16 characters.
Use the mpls rsvp-te authentication command to enable RSVP authentication on the interface.
Use the undo mpls rsvp-te authentication command to disable RSVP authentication on the interface.
By default, RSVP authentication is disabled.
The RSVP messages sent out of the interface convey a message authentication digest created using the hash algorithm and the configured authentication key. This authentication key also used by the interface to authenticate received RSVP messages. For the two interfaces at the two ends of a link to exchange RSVP messages, they must share the same authentication key.
This hop-by-hop authentication of RSVP prevents fake resource reservation requests from occupying network resources.
# Enable RSVP authentication on interface GigabitEthernet 3/1/1, and configure the authentication key as userkey1 in plain text.
[Sysname-GigabitEthernet3/1/1] mpls rsvp-te authentication plain userkey1
mpls rsvp-te bfd enable
undo mpls rsvp-te bfd enable
View
Interface view
Default level
2: System level
None
Use the mpls rsvp-te bfd enable command on an RSVP-TE enabled interface to enable BFD for link detection.
Use the undo mpls rsvp-te bfd enable command to disable BFD on an RSVP-TE enabled interface.
By default, BFD for link detection is not enabled on an RSVP-TE enabled interface.
Before enabling BFD for link detection on an interface, make sure that the interface is enabled with RSVP-TE.
# Enable BFD link detection on RSVP-TE enabled interface GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] mpls rsvp-te bfd enable
mpls rsvp-te blockade-multiplier
mpls rsvp-te blockade-multiplier number
undo mpls rsvp-te blockade-multiplier
View
MPLS view
Default level
2: System level
number: Blockade multiplier, in the range of 3 to 255.
Use the mpls rsvp-te blockade-multiplier command to configure the blockade multiplier, which determines the timeout time of blockade state.
Use the undo mpls rsvp-te blockade-multiplier command to restore the default.
The default blockade multiplier is 4.
Sometimes, although a reservation request does not pass admission control on some node, you may want to store the resource reservation state for it while allowing other requests to use the resources reserved for the request. In this case, the node transits to the blockade state and a blockade state block (BSB) is created on each downstream node. When the number of non-refreshing times exceeds the blockade multiplier, the blockade state is removed. The blockade state timeout time is blockade multiplier × refresh-time. The refresh time is the refresh interval of the path/reservation messages.
Before you can configure this command, enable RSVP-TE.
Related commands: mpls rsvp-te timer refresh.
# Set the blockade multiplier to 5.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te blockade-multiplier 5
mpls rsvp-te graceful-restart
undo mpls rsvp-te graceful-restart
View
MPLS view
Default level
2: System level
None
Use the mpls rsvp-te graceful-restart command to enable the GR capability for MPLS RSVP-TE.
Use the undo mpls rsvp-te graceful-restart command to disable MPLS RSVP-TE GR.
By default, GR capability is disabled for MPLS RSVP-TE.
You need to enable RSVP-TE hello extension before enabling RSVP-TE GR.
# Enable MPLS RSVP-TE GR.
[Sysname] mpls lsr-id 1.1.1.1
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te hello
[Sysname-mpls] mpls rsvp-te graceful-restart
mpls rsvp-te hello
mpls rsvp-te hello
undo mpls rsvp-te hello
View
Default level
2: System level
None
Use the mpls rsvp-te hello command to enable RSVP hello extension.
Use the undo mpls rsvp-te hello command to disable RSVP hello extension.
By default, RSVP hello extension is disabled.
RSVP-TE uses the hello extension mechanism to check the reachability of an RSVP neighbor.
Before you can enable RSVP hello extension in interface view, enable RSVP-TE in interface view and RSVP hello extension in MPLS view.
# Enable RSVP hello extension in MPLS view.
[Sysname] mpls
# Enable RSVP hello extension on interface GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] mpls rsvp-te hello
mpls rsvp-te hello-lost
mpls rsvp-te hello-lost times
undo mpls rsvp-te hello-lost
View
MPLS view
Default level
2: System level
times: Maximum number of consecutive hello losses before an RSVP neighbor is considered dead, in the range of 3 to 10.
Use the mpls rsvp-te hello-lost command to configure the maximum number of consecutive hello losses before an RSVP neighbor is considered dead.
Use the undo mpls rsvp-te hello-lost command to restore the default.
By default, the RSVP node considers an RSVP neighbor to be dead if no response is received after sending three consecutive hellos.
An RSVP node detects whether its RSVP neighbor is still alive by sending hellos regularly. If no response is received after the number of consecutive hellos reaches the specified limit, the RSVP node considers its RSVP neighbor as dead. The failure is handled the same as a link layer communication failure.
Before configuring this command, enable RSVP-TE and RSVP hello extension in MPLS view.
Related commands: mpls rsvp-te timer hello.
# Set the maximum number of consecutive hello losses allowed on a node to 5.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te hello-lost 5
mpls rsvp-te keep-multiplier
mpls rsvp-te keep-multiplier number
undo mpls rsvp-te keep-multiplier
View
MPLS view
Default level
2: System level
number: Keep multiplier, in the range of 3 to 255.
Use the mpls rsvp-te keep-multiplier command to configure the keep multiplier, which determines the timeout time of the path state block (PSB) and reservation state block (RSB).
Use the undo mpls rsvp-te keep-multiplier command to restore default.
The default keep multiplier is 3.
The PSB and RSB timeout time is (keep-multiplier + 0.5) × 1.5 × refresh-time.
Before you can configure the keep multiplier, enable RSVP-TE.
# Set the keep multiplier for PSB and RSB to 5.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te keep-multiplier 5
mpls rsvp-te reliability
undo mpls rsvp-te reliability
View
Interface view
Default level
2: System level
None
Use the mpls rsvp-te reliability command to enable the RSVP reliability mechanism.
Use the undo mpls rsvp-te reliability command to disable the RSVP reliability mechanism.
By default, the RSVP reliability mechanism is disabled.
With RSVP reliability enabled, the device adds objects Message_ID and Message_ID_ACK into the outgoing RSVP messages. The objects will be used for RSVP message acknowledgment to improve reliability.
# Enable the reliability mechanism of RSVP-TE on interface GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] mpls rsvp-te reliability
mpls rsvp-te resvconfirm
undo mpls rsvp-te resvconfirm
View
MPLS view
Default level
2: System level
None
Use the mpls rsvp-te resvconfirm command to enable reservation confirmation on the current node.
Use the undo mpls rsvp-te resvconfirm command to disable reservation confirmation.
By default, resource reservation confirmation is disabled.
With the reservation confirmation mechanism enabled on a node, a Resv message sent by the node carries an object that requires reservation confirmation. The node that receives the Resv message must send back a ResvConf message to confirm the reservation.
# Enable reservation confirmation on your router.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te resvconfirm
mpls rsvp-te srefresh
undo mpls rsvp-te srefresh
View
Interface view
Default level
2: System level
None
Use the mpls rsvp-te srefresh command to enable summary refresh.
Use the undo mpls rsvp-te srefresh command to restore the default.
By default, summary refresh is disabled.
Summary refresh (Srefresh) messages refresh path state and reservation state. Enabling summary refresh disables conventional time-driven state refresh.
# Enable summary refresh on interface GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] mpls rsvp-te srefresh
mpls rsvp-te timer graceful-restart recovery
mpls rsvp-te timer graceful-restart recovery recovery-time
undo mpls rsvp-te timer graceful-restart recovery
View
MPLS view
Default level
2: System level
recovery-time: RSVP-TE GR recovery interval in seconds, in the range of 60 to 300.
Use the mpls rsvp-te timer graceful-restart recovery command to set the RSVP-TE GR recovery interval.
Use the undo mpls rsvp-te timer graceful-restart recovery command to restore the default.
By default, the RSVP-TE GR recovery interval is 300 seconds.
Before using this command, be sure to enable the GR capability for MPLS RSVP-TE.
# Set the RSVP-TE GR recovery interval to 100 seconds.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te timer graceful-restart recovery 100
mpls rsvp-te timer graceful-restart restart
mpls rsvp-te timer graceful-restart restart restart-time
undo mpls rsvp-te timer graceful-restart restart
View
MPLS view
Default level
2: System level
restart-time: RSVP-TE GR restart interval in seconds, in the range of 60 to 300.
Use the mpls rsvp-te timer graceful-restart restart command to set the RSVP-TE GR restart interval.
Use the undo mpls rsvp-te timer graceful-restart restart command to restore the default.
By default, the RSVP-TE GR restart interval is 120 seconds.
# Set the RSVP-TE GR restart interval to 200 seconds.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te timer graceful-restart restart 200
mpls rsvp-te timer hello timevalue
undo mpls rsvp-te timer hello
View
MPLS view
Default level
2: System level
timevalue: Hello interval, in the range of 1 to 60 seconds.
Use the mpls rsvp-te timer hello command to configure the hello interval.
Use the undo mpls rsvp-te timer hello command to restore the default.
The default hello interval is three seconds.
Before configuring this command, enable the hello mechanism in MPLS view.
Related commands: mpls rsvp-te hello and mpls rsvp-te hello-lost.
# Set the hello interval to five seconds.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te timer hello 5
mpls rsvp-te timer refresh timevalue
undo mpls rsvp-te timer refresh
View
MPLS view
Default level
2: System level
timevalue: Refresh interval, in the range of 10 to 65535 seconds.
Use the mpls rsvp-te timer refresh command to configure the path/reservation state refresh interval.
Use the undo mpls rsvp-te timer refresh command to restore the default.
The default path/reservation state refresh interval is 30 seconds.
Related commands: mpls rsvp-te keep-multiplier.
# Set the path/reservation state refresh interval to 60 seconds.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te timer refresh 60
mpls rsvp-te timer retransmission
mpls rsvp-te timer retransmission { increment-value [ increment-value ] | retransmit-value [ retrans-timer-value ] } *
undo mpls rsvp-te timer retransmission
View
Interface view
Default level
2: System level
increment-value increment-value: Increment value delta, in the range of 1 to 10. The default is 1.
retransmit-value retrans-timer-value: Initial retransmission interval, in the range of 500 to 3000 milliseconds. The default is 500 milliseconds.
Use the mpls rsvp-te timer retransmission command to enable RSVP message retransmission.
Use the undo mpls rsvp-te timer retransmission command to restore the default.
By default, RSVP message retransmission is disabled.
If a node sends a message carrying the Message_ID object, and the ACK_Desired flag in the object is set, the node expects a response that carries the Message_ID_ACK object during the initial retransmission interval (Rf). If the node does not receive the response within the Rf interval, it resends the message and sets the retransmission interval to (1+Delta) × Rf. The node repeats such retransmissions until it receives the corresponding response within the retransmission time or the number of retransmission attempts reaches the limit.
The initial value of the retransmission time is specified by retrans-timer-value in the mpls rsvp-te timer retransmission command, and the delta value is specified by increment-value in this command.
# Enable RSVP message retransmission on interface GigabitEthernet 3/1/1, setting the increment value delta to 2 and the initial retransmission interval to 1000 milliseconds.
[Sysname-GigabitEthernet3/1/1] mpls rsvp-te timer retransmission increment-value 2 retransmit-value 1000
mpls te
mpls te
undo mpls te
View
Default level
2: System level
None
Use the mpls te command to enable MPLS TE.
Use the undo mpls te command to disable MPLS TE.
By default, MPLS TE is disabled.
When performed in MPLS view, the mpls te command enables MPLS TE globally and its undo form disables MPLS TE and removes all CR-LSPs.
When performed in interface view, the mpls te command enables MPLS TE on an interface and its undo form disables MPLS TE and removes all CR-LSPs on the interface.
Before you can enable MPLS TE on an interface, enable MPLS TE globally first.
CAUTION
CAUTION:
After changing the MTU of an interface where MPLS TE is enabled, you need to perform the shutdown command and then the undo shutdown command to refresh the TE tunnels on it.
# Enable MPLS TE globally in MPLS view.
[Sysname] mpls lsr-id 1.1.1.9
[Sysname] mpls
# Enable MPLS TE on interface GigabitEthernet 3/1/1.
mpls te affinity property
mpls te affinity property properties [ mask mask-value ]
undo mpls te affinity property
View
Tunnel interface view
Default level
2: System level
properties: Link properties affinity attribute of the tunnel, a 32-bit integer in the range of 0x0 to 0xFFFFFFFF. Each affinity bit represents a property with a value of 1 or 0.
mask-value: 32-bit mask comprising 0s and 1s, in the range of 0x0 to 0xFFFFFFFF. This mask is used when ANDing the link affinity attribute with the link administrative group attribute. The affinity bits corresponding to the 1s in the mask are “do care” bits which must be considered while those corresponding to the 0s in the mask are “don’t care” bits.
Use the mpls te affinity property command to configure the link affinity attribute of the tunnel.
Use the undo mpls te affinity property command to restore the default.
The default affinity attribute of the tunnel is 0x00000000 and the mask is 0x00000000.
The affinity attribute of an MPLS TE tunnel identifies the properties of the links that the tunnel can use.
Related commands: mpls te link administrative group.
# Configure the link affinity attribute of tunnel 3.
[Sysname] interface tunnel 3
[Sysname-Tunnel3] mpls te affinity property 101 mask 303
mpls te backup
mpls te backup { hot-standby | ordinary }
undo mpls te backup
View
Default level
2: System level
hot-standby: Sets the tunnel backup mode to hot backup. In this mode, a backup CR-LSP is established immediately after the primary CR-LSP is established. When the primary CR-LSP fails, MPLS TE immediately switches services to the backup CR-LSP.
ordinary: Sets the tunnel backup mode to ordinary backup. In this mode, a backup CR-LSP is established only when the primary CR-LSP fails.
Use the mpls te backup command to enable backup for the current tunnel and configure the tunnel back mode.
Use the undo mpls te backup command to restore the default.
By default, tunnel backup is disabled.
·       With backup enabled, the record route flag is automatically set to record reroute regardless of whether the mpls te record-route command is configured.
·       The mpls te backup command cannot be used together with these commands: mpls te reoptimization, mpls te auto-bandwidth adjustment, and mpls te resv-style ff.
# Enable tunnel backup for Tunnel0 and configure the backup mode as hot backup.
[Sysname-Tunnel3] mpls te backup hot-standby
mpls te backup bandwidth
mpls te backup bandwidth { bandwidth | { ct0 | ct1 | ct2 | ct3 } { bandwidth | un-limited } }
undo mpls te backup bandwidth
View
Default level
2: System level
bandwidth: Total bandwidth that the bypass tunnel can protect, in the range of 1 to 32000000 kbps.
ct0: Indicates that only the LSPs of CT 0 can use the bypass tunnel.
ct1: Indicates that only the LSPs of CT 1 can use the bypass tunnel.
ct2: Indicates that only the LSPs of CT 2 can use the bypass tunnel.
ct3: Indicates that only the LSPs of CT 3 can use the bypass tunnel.
un-limited: Puts on limit on total protected bandwidth.
Use the mpls te backup bandwidth command to configure the total bandwidth and type of LSP that the bypass tunnel can protect.
Use the undo mpls te backup bandwidth command to remove the configuration.
By default, bypass tunnels do not protect bandwidth.
When you use the command, follow these guidelines:
·           If no CT is specified, all LSPs can use the bypass tunnel.
·           The bandwidth value specified with this command is used for only calculating and determining the bandwidth protection relationship. No bandwidth will be reserved in the bypass tunnel.
·           The specified bandwidth value must be less than the actual bandwidth of the bypass tunnel. Otherwise, the bypass tunnel may be overwhelmed after FRR switchover, causing the protected tunnel to be torn down.
This command is not supported when the signaling protocol is CR-LDP.
# Configure Tunnel 3 to provide protection for LSPs of CT 0 without constraining the bandwidth to be protected. Configure Tunnel 2 to provide protection for LSPs of CT 1 and protect up to 1000 kbps bandwidth.
[Sysname-Tunnel3] mpls te backup bandwidth ct0 un-limited
[Sysname-Tunnel3] quit
[Sysname] interface tunnel 2
[Sysname-Tunnel2] mpls te backup bandwidth ct1 1000
mpls te bandwidth
mpls te bandwidth [ ct0 | ct1 | ct2 | ct3 ] bandwidth
undo mpls te bandwidth
View
Default level
2: System level
ct0: Specifies the tunnel traffic’s CT as CT 0.
ct1: Specifies the tunnel traffic’s CT as CT 1.
ct2: Specifies the tunnel traffic’s CT as CT 2.
ct3: Specifies the tunnel traffic’s CT as CT 3.
bandwidth: Bandwidth needed by the MPLS TE tunnel, in the range of 1 to 32000000 kbps.
Use the mpls te bandwidth command to assign bandwidth to the MPLS TE tunnel and specify the service class type to which the tunnel's traffic belong.
Use the undo mpls te bandwidth command to restore the default.
By default, the bandwidth assigned to an MPLS TE tunnel is 0 and the tunnel’s traffic belongs to CT 0.
If no CT is specified, the tunnel’s traffic belongs to CT 0.
·       On the SR8800 routers, if there are multiple data streams in an MPLS TE tunnel, each data stream corresponds to one outgoing interface of the tunnel.
·       If an MPLS TE tunnel has multiple outgoing interfaces (for example, when the egress of the tunnel is an aggregation group with multiple interfaces), the mpls te bandwidth command takes effect on all the interfaces. In this case, if there are multiple data streams in the tunnel, the actual bandwidth is the product of the configured bandwidth of the tunnel and the number of outgoing interfaces servicing data streams.
·       If an MPLS TE tunnel needs a bandwidth greater than 1024 kbps, H3C recommends setting the bandwidth value to a multiple of 1024 kbps.
# Assign 1000 kbps bandwidth to MPLS TE tunnel 3 and specify the CT of the tunnel’s traffic as CT 1.
[Sysname-Tunnel3] mpls te bandwidth ct1 1000
mpls te bandwidth change thresholds
mpls te bandwidth change thresholds { down | up } percent
undo mpls te bandwidth change thresholds { down | up }
View
Interface view
Default level
2: System level
down: Sets the threshold in percentages for IGP to flood when the bandwidth is decreasing. When the percentage of available bandwidth decrease exceeds the threshold, the change is flooded and the traffic engineering database (TEDB) is updated.
up: Sets the IGP flooding threshold in percentages that applies when the bandwidth is increasing. When the percentage of available bandwidth increase exceeds the threshold, the change is flooded and the TEDB is updated.
percent: IGP flooding threshold in percentages, in the range of 0 to 100.
Use the mpls te bandwidth change thresholds command to set the IGP flooding thresholds that apply when bandwidth resources are increasing and decreasing.
Use the undo mpls te bandwidth change thresholds command to restore the default.
The default IGP flooding thresholds in both up and down directions are 10.
# On interface GigabitEthernet 3/1/1 configure IGP to flood when the percentage of available bandwidth decrease reaches 100%.
[Sysname-GigabitEthernet3/1/1] mpls te bandwidth change thresholds down 100
mpls te bfd enable
mpls te bfd enable [ discriminator local local-id remote remote-id ]
undo mpls te bfd enable
View
Default level
2: System level
discriminator: Specifies the discriminator values of the BFD session.
local local-id: Specifies the local discriminator value of the BFD session. local-id ranges from 1 to 512.
remote remote-id: Specifies the remote discriminator value of the BFD session. The value ranges from 1 to 4294967295.
Use the mpls te bfd enable command to configure BFD to check the connectivity of the MPLS TE tunnel.
Use the undo mpls te bfd enable command to disable BFD for the MPLS TE tunnel of a TE tunnel interface.
By default, BFD is not configured for MPLS TE tunnels.
Enable LSP verification by using the mpls lspv command first before executing the mpls te bfd enable command. For details of the mpls lspv command, see the chapter “Basic MPLS configuration commands.”
BFD session parameters are those configured on the TE tunnel interface. The source address of the BFD session is the MPLS LSR ID. Therefore, before enabling BFD for an MPLS TE tunnel, make sure that there is a route on the peer router to the MPLS LSR ID, and you can also configure the BFD session parameters on the tunnel interface as needed. For information about BFD parameter configuration, see High Availability Configuration Guide.
# Enable BFD for the MPLS TE tunnel on tunnel interface Tunnel1.
[Sysname] interface tunnel 1
[Sysname-Tunnel1] mpls te bfd enable
mpls te commit
mpls te commit
View
Default level
2: System level
None
Use the mpls te commit command to submit current MPLS TE tunnel configuration.
The MPLS TE tunnel configuration you made can take effect only after you perform this command.
# Configure an MPLS TE tunnel and submit the configuration.
[Sysname-Tunnel3] tunnel-protocol mpls te
[Sysname-Tunnel3] destination 2.2.2.9
[Sysname-Tunnel3] mpls te commit
mpls te cspf
mpls te cspf
undo mpls te cspf
View
MPLS view
Default level
2: System level
None
Use the mpls te cspf command to enable CSPF on current node.
Use the undo mpls te cspf command to disable CSPF on current node.
By default, CSPF is disabled on current node.
Before enabling CSPF, enable MPLS TE in MPLS view.
CSPF provides an approach to path selection in MPLS domains. You must enable CSPF before configuring other CSPF related functions.
# Enable CSPF on the current node.
[Sysname] mpls
[Sysname-mpls] mpls te cspf
mpls te cspf timer failed-link
mpls te cspf timer failed-link timer-interval
undo mpls te cspf timer failed-link
View
MPLS view
Default level
2: System level
timer-interval: Value of the failed link timer, in the range of 0 to 300 seconds. The default is 10 seconds.
Use the mpls te cspf timer failed-link command to configure the failed link timer.
Use the undo mpls te cspf timer failed-link command to restore the default.
By default, the failed link timer is 10 seconds.
Related commands: mpls te cspf.
# Set the failed link timer to 50 seconds.
[Sysname] mpls
[Sysname-mpls] mpls te cspf timer failed-link 50
mpls te ds-te ietf bc-mode
mpls te ds-te ietf bc-mode mam
undo mpls te ds-te ietf bc-mode
View
MPLS view
Default level
2: System Level
mam: Specifies the bandwidth constraints model as MAM.
Use the mpls te ds-te ietf bc-mode command to specify the bandwidth constraints model in IETF DS-TE mode.
Use the undo mpls te ds-te ietf bc-mode command to restore the default.
By default, the bandwidth constraints model in IETF DS-TE mode is RDM.
This command is only applicable to the IETF DS-TE mode. In prestandard DS-TE mode, the bandwidth constraints model can only be RDM.
After you change the bandwidth constraints model in IETF DS-TE mode, all CR-LSPs with non-zero reserved bandwidths will be cleared on the router.
Related commands: mpls te ds-te mode.
# Configure the BC model in IETF mode as MAM.
[Sysname] mpls
[Sysname-mpls] mpls te ds-te ietf bc-mode mam
mpls te ds-te ietf te-class
mpls te ds-te ietf te-class te-class-index class-type class-type-number priority pri-number
undo mpls te ds-te ietf te-class te-class-index
View
MPLS view
Default level
2: System Level
te-class-index: Index of a TE class, in the range of 0 to 7.
class-type class-type-number: Specifies the corresponding CT of the TE class. class-type-number is the sequence number of a CT, in the range of 0 to 3. The system supports four CTs (CT 0, CT 1, CT 2, and CT 3).
priority pri-number: Specifies the corresponding preemption priority of the TE class. pri-number is the preemption priority value, in the range of 0 to 7.
Use the mpls te ds-te ietf te-class command to configure a TE class mapping, that is, the association of a TE class, CT, and priority.
Use the undo mpls te ds-te ietf te-class command to restore the default.
By default, the TE class mappings in IETF DS-TE mode are as follows:
Table 37 Default TE class mappings in IETF mode
TE Class
CT
Priority
0
0
7
1
1
7
2
2
7
3
3
7
4
0
0
5
1
0
6
2
0
7
3
0
·           When using the mpls te ds-te ietf te-class command to configure a TE class mapping, be sure to specify a CT-priority pair different from that in any existing TE class mappings.
·           When using the undo mpls te ds-te ietf te-class command, make sure that the CT and preemption priority of the TE class mapping to be restored to are not those of an existing TE class mapping.
·           After a TE class is modified, the router will notify the IGP to re-advertise the bandwidth information of all TE interfaces and will remove and then re-establish the CR-LSPs of the TE class on all TE interfaces.
# Associate TE class 7, CT 2, and preemption priority 3 in the IETF mode.
[Sysname] mpls
[Sysname-mpls] mpls te ds-te ietf te-class 7 class-type 2 priority 3
mpls te ds-te mode
mpls te ds-te mode ietf
undo mpls te ds-te mode
View
MPLS view
Default level
2: System level
ietf: Specifies the DS-TE mode as IETF.
Use the mpls te ds-te mode command to specify the DS-TE mode.
Use the undo mpls te ds-te mode command to restore the default.
By default, the DS-TE mode is prestandard.
Changing the DS-TE mode also removes all CR-LSPs on the router.
# Configure the DS-TE mode as IETF.
[Sysname] mpls
[Sysname-mpls] mpls te ds-te mode ietf
mpls te failure-action teardown
undo mpls te failure-action teardown
View
Default level
2: System level
None
Use the mpls te failure-action teardown command to enable the capability of tearing down a failed RSVP TE tunnel and then re-establishing it.
Use the undo mpls te failure-action teardown command to disable the capability.
By default, this capability is disabled.
With this capability configured, after BFD or periodic LSP tracert detects a failure of an RSVP-TE tunnel, if RSVP does not re-establish the RSVP-TE tunnel within a specific period of time, MPLS TE will remove the tunnel and re-establish it.
# On tunnel interface Tunnel 1, enable the capability of tearing down a failed MPLS TE tunnel and then re-establishing the tunnel.
[Sysname-Tunnel1] mpls te failure-action teardown
mpls te fast-reroute
undo mpls te fast-reroute
View
Default level
2: System level
None
Use the mpls te fast-reroute command to enable fast reroute (FRR).
Use the undo mpls te fast-reroute command to disable FRR.
By default, FRR is disabled.
After FRR is enabled, the record route flag is automatically set to record reroute with label whether the mpls te record-route label command is configured or not.
Disable FRR before configuring the mpls te record-route command or its undo form.
·       This command is not supported when the signaling protocol is CR-LDP.
·       Fast reroute cannot be used together with the mpls te resv-style ff command.
# Reroute MPLS TE tunnel 3 to an available bypass tunnel in case the protected link or node that it traverses fails.
[Sysname-Tunnel3] mpls te fast-reroute
mpls te fast-reroute bypass-tunnel
mpls te fast-reroute bypass-tunnel tunnel tunnel-number
undo mpls te fast-reroute bypass-tunnel tunnel tunnel-number
View
Interface view
Default level
2: System level
tunnel tunnel-number: Specifies a bypass tunnel by its tunnel number.
Use the mpls te fast-reroute bypass-tunnel command to specify a bypass tunnel for the protected interface.
Use the undo mpls te fast-reroute bypass-tunnel command to remove the specified bypass tunnel.
You may perform the mpls te fast-reroute bypass-tunnel command multiple times to specify multiple bypass tunnels for the protected interface. At present, a maximum of three bypass tunnels can be specified for a protected interface.
When specifying a bypass tunnel, consider the following:
·           The state of the tunnel must be up.
·           The protected interface is not the outgoing interface in the route entries for the LSP of the bypass tunnel.
·       A bypass tunnel cannot be used for services like VPN at the same time.
# Use Tunnel 3 as the bypass tunnel to protect the link connected to interface GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] mpls te fast-reroute bypass-tunnel tunnel 3
mpls te igp advertise
mpls te igp advertise [ hold-time value ]
undo mpls te igp advertise
 View
Default level
2: System level
hold-time value: Sets the delay that IGP waits to notify IGP neighbors of the down event of the TE tunnel. It ranges from 0 to 4294967295 milliseconds. The default is 0 milliseconds.
Use the mpls te igp advertise command to enable IGP to advertise the MPLS TE tunnel as a link to IGP neighbors.
Use the undo mpls te igp advertise command to remove the configuration.
By default, IGP does not advertise MPLS TE tunnels to IGP neighbors.
The mpls te igp advertise command cannot be used together with the mpls te igp shortcut command.
# Set the hold time to 10000 milliseconds.
[Sysname-Tunnel3] mpls te igp advertise hold-time 10000
mpls te igp metric
mpls te igp metric { absolute value | relative value }
undo mpls te igp metric
View
Default level
2: System level
absolute value: Assigns an absolute metric to the TE tunnel for path calculation. The value argument takes an integer in the range of 1 to 65535. This value is directly used for path calculation.
relative value: Assigns a relative metric to the TE tunnel for path calculation. The value argument takes an integer in the range of –10 to +10. The default is 0. The cost of the corresponding IGP path must be added to this relative metric before it can be used for path calculation.
Use the mpls te igp metric command to assign a metric to the MPLS TE tunnel.
Use the undo mpls te igp metric command to restore the default.
By default, TE tunnels take their IGP metrics.
# Assign MPLS TE tunnel 3 a relative metric of –1 for  path calculation in IGP shortcut or forwarding adjacency mechanism.
[Sysname-Tunnel3] mpls te igp metric relative -1
mpls te igp shortcut [ isis | ospf ]
undo mpls te igp shortcut
View
Default level
2: System level
isis: Sets the IGP protocol to IS-IS.
ospf: Sets the IGP protocol to OSPF.
Use the mpls te igp shortcut command to enable IS-IS or OSPF to consider the MPLS TE tunnel in its enhanced SPF calculation when the tunnel is up. If no IGP protocol is specified, the command applies to both OSPF and IS-IS.
Use the undo mpls te igp shortcut command to restore the default.
By default, IGP does not consider MPLS TE tunnels in its enhanced SPF calculation.
The mpls te igp shortcut command cannot be used together with the mpls te igp advertise command.
# Enable OSPF and IS-IS to consider TE tunnel 3 in enhanced SPF calculation when the tunnel is up.
[Sysname-Tunnel3] mpls te igp shortcut
mpls te link administrative group value
undo mpls te link administrative group
View
Interface view
Default level
2: System level
value: Link administrative group attribute, in the range of 0x00000000 to 0xFFFFFFFF. It is a set of 32 link properties. Each bit represents a property with a value of 0 or 1. By ANDing the administrative group attribute bits with the corresponding link affinity attribute bits of an MPLS TE tunnel, MPLS TE identifies the properties of the links that the MPLS TE tunnel can use.
Use the mpls te link administrative group command to configure the link administrative group attribute.
Use the undo mpls te link administrative group command to restore the default.
The default link administrative group attribute is 0x00000000.
The interface properties are propagated globally and are used for path selection at the tunnel ingress.
Related commands: mpls te affinity property.
# Assign interface GigabitEthernet 3/1/1 the link administrative group attribute of 0x00000101.
[Sysname-GigabitEthernet3/1/1] mpls te link administrative group 101
mpls te loop-detection
undo mpls te loop-detection
View
Default level
2: System level
None
Use the mpls te loop-detection command to configure the node to perform loop detection when setting up the MPLS TE tunnel.
Use the undo mpls te loop-detection command to disable loop detection.
By default, a node does not perform loop detection when setting up a tunnel.
# Configure the node to perform loop detection when setting up tunnel 3.
[Sysname-Tunnel3] mpls te loop-detection
mpls te max-link-bandwidth
mpls te max-link-bandwidth bandwidth-value
undo mpls te max-link-bandwidth
View
Interface view
Default level
2: System level
bandwidth-value: Maximum bandwidth of the link, in the range of 1 to 32000000 kbps.
Use the mpls te max-link-bandwidth command to configure the maximum bandwidth for the link to forward MPLS TE traffic.
Use the undo mpls te max-link-bandwidth command to restore the default.
By default, the maximum link bandwidth for MPLS TE traffic is 0.
The configured maximum link bandwidth is available for only MPLS TE traffic.
# On interface GigabitEthernet 3/1/1, set the maximum link bandwidth for MPLS TE traffic to 1158 kbps.
[Sysname-GigabitEthernet3/1/1] mpls te max-link-bandwidth 1158
mpls te max-reservable-bandwidth
mpls te max-reservable-bandwidth bandwidth-value [ bc1 bc1-bandwidth ]
undo mpls te max-reservable-bandwidth
View
Interface view
Default level
2: System level
bandwidth-value: Maximum reservable bandwidth of the link, that is, the value of BC 0. It is in the range of 1 to 32000000 kbps.
bc1 bc1-bandwidth: Value of BC 1, in the range of 1 to 32000000 kbps. By default, BC 1 is 0 kbps.
Use the mpls te max-reservable-bandwidth command to configure the bandwidth constraints BC 0 and BC 1 in prestandard DS-TE RDM mode.
Use the undo mpls te max-reservable-bandwidth command to restore the default.
By default, both BC 0 and BC 1 is 0 kbps.
The maximum reservable bandwidth of a link, that is, the value of BC 0 (bandwidth-value), cannot be greater than the maximum bandwidth of the link, and the value of BC 1 (bc1-bandwidth) cannot be greater than the value of BC 0 (bandwidth-value).
The bandwidth in this command is configured only for MPLS TE traffic.
# Set the maximum reservable bandwidth for MPLS TE in prestandard mode to 1158 kbps, and BC1 to 200 kbps.
[Sysname-GigabitEthernet3/1/1] mpls te max-reservable-bandwidth 1158 bc1 200
mpls te max-reservable-bandwidth mam
mpls te max-reservable-bandwidth mam bandwidth-value { bc0 bc0-bandwidth | bc1 bc1-bandwidth | bc2 bc2-bandwidth | bc3 bc3-bandwidth } *
undo mpls te max-reservable-bandwidth mam
View
Interface view
Default level
2: System level
bandwidth-value: Maximum reservable bandwidth of the link, in the range of 1 to 32000000, in kbps.
bc0 bc0-bandwidth: Value of BC 0, in the range of 1 to 32000000, in kbps. By default, BC 0 is 0.
bc1 bc1-bandwidth: Value of BC 1, in the range of 1 to 32000000, in kbps. By default, BC 1 is 0.
bc2 bc2-bandwidth: Value of BC 2, in the range of 1 to 32000000, in kbps. By default, BC 2 is 0.
bc3 bc3-bandwidth: Value of BC 3, in the range of 1 to 32000000, in kbps. By default, BC 3 is 0.
Use the mpls te max-reservable-bandwidth mam command to configure the maximum reservable bandwidth of the MPLS TE link and the BCs in IETF DS-TE MAM model.
Use the undo mpls te max-reservable-bandwidth mam command to restore the default.
By default, the maximum reservable bandwidth and each BC are 0 kbps.
The maximum reservable bandwidth of the link must be lower than or equal to the maximum bandwidth of the link. Each BC must be lower than or equal to the maximum reservable bandwidth of the link, that is, none of bc0-bandwidth, bc1-bandwidth, bc2-bandwidth and bc3-bandwidth can be greater than bandwidth-value.
The maximum reservable bandwidth and BCs configured by this command are used only for MPLS TE traffic.
# Set the maximum reservable bandwidth in IETF MAM model for MPLS TE to 1158 kbps, and set BC 0 to 500 kbps, BC 1 to 300 kbps, BC 2 to 400 kbps, and BC 3 to 100 kbps.
[Sysname-GigabitEthernet3/1/1] mpls te max-reservable-bandwidth mam 1158 bc0 500 bc1 300 bc2 400 bc3 100
mpls te max-reservable-bandwidth rdm
mpls te max-reservable-bandwidth rdm bandwidth-value [ bc1 bc1-bandwidth ] [ bc2 bc2-bandwidth ] [ bc3 bc3-bandwidth ]
undo mpls te max-reservable-bandwidth rdm
View
Interface view
Default level
2: System level
bandwidth-value: Maximum reservable bandwidth of the link, that is, the value of BC 0, in the range of 1 to 32000000, in kbps.
bc1 bc1-bandwidth: Value of BC 1, in the range of 1 to 32000000, in kbps. By default, BC 1 is 0 kbps.
bc2 bc2-bandwidth: Value of BC 2, in the range of 1 to 32000000, in kbps. By default, BC 2 is 0 kbps.
bc3 bc3-bandwidth: Value of BC 3, in the range of 1 to 32000000, in kbps. By default, BC 3 is 0 kbps.
Use the mpls te max-reservable-bandwidth rdm command to configure the bandwidth constraints in IETF DS-TE RDM model.
Use the undo mpls te max-reservable-bandwidth rdm command to restore the default.
By default, each BC is 0 kbps.
The value of BC 0 (bandwidth-value) must be greater than or equal to that of BC 1 (bc1-bandwidth). The value of BC 1 (bc1-bandwidth) must be greater than or equal to that of BC 2 (bc2-bandwidth). The value of BC 2 (bc2-bandwidth) must be greater than or equal to that of BC 3 (bc3-bandwidth).
The bandwidth constraints configured by this command are used only for MPLS TE traffic.
# Set BC 0 in IETF RDM model to 500 kbps, BC 1 to 400 kbps, BC 2 to 300 kbps, and BC 3 to 100 kbps.
[Sysname-GigabitEthernet3/1/1] mpls te max-reservable-bandwidth rdm 500 bc1 400 bc2 300 bc3 100
mpls te metric
mpls te metric value
undo mpls te metric
View
Interface view
Default level
2: System level
value: TE metric of the link, in the range of 0 to 4294967295.
Use the mpls te metric command to assign a TE metric to the link.
Use the undo mpls te metric command to restore the default.
By default, the link uses its IGP metric as its TE metric.
Related commands: mpls te path metric-type.
# Assign a TE metric of 20 to the link on interface GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] mpls te metric 20
mpls te path
mpls te path { dynamic | explicit-path pathname } preference value
undo mpls te path { dynamic | explicit-path pathname }
View
Default level
2: System level
dynamic: Uses the path that is dynamically calculated.
explicit-path pathname: Uses an existing explicit path. The pathname argument is a case-insensitive string of 1 to 31 characters.
preference value: Specifies the preference of the path. The value argument is in the range of 1 to 10. The smaller the value, the higher the preference.
Use the mpls te path command to specify a path for the tunnel to use and set the preference of the path.
Use the undo mpls te path command to remove a path used by the tunnel.
By default, a tunnel uses the dynamically calculated path.
Up to 10 paths can be specified for an MPLS TE tunnel.
The paths for a tunnel to use must have different preferences.
A path with the highest preference is preferred for CSPF calculation.
# Configure interface Tunnel 3 to use the explicit path path1 and the dynamically calculated path, setting the preferences of the paths to 1 and 2 respectively.
[Sysname-Tunnel3] mpls te path explicit-path path1 preference 1
[Sysname-Tunnel3] mpls te path dynamic preference 2
mpls te path metric-type { igp | te }
undo mpls te path metric-type
View
MPLS view, tunnel interface view
Default level
2: System level
igp: Uses IGP metrics for tunnel path calculation.
te: Uses TE metrics for tunnel path calculation.
Use the mpls te path metric-type command in MPLS view to specify the link metric type used for path calculation when a metric type was not explicitly configured for a tunnel.
Use the mpls te path metric-type command in tunnel interface view to specify the link metric type used for path calculation.
Use the undo mpls te path metric-type command to restore the default. This undo form is only available in tunnel interface view.
In MPLS view, TE metrics of links are used in path calculation for TE tunnels by default.
In tunnel interface view, no link metric type is specified for path calculation by default.
A tunnel prefers the link metric type specified in the tunnel interface view. If no link metric type is specified in tunnel interface view, the configuration in MPLS view is used.
Related commands: mpls te metric.
In MPLS view:
# Configure TE tunnels that were not explicitly specified with a metric type to use IGP metric for path calculation.
[Sysname] mpls
[Sysname-mpls] mpls te path metric-type igp
In tunnel interface view:
# Configure tunnel 3 to use IGP metrics for path calculation.
[Sysname-Tunnel3] mpls te path metric-type igp
mpls te periodic-tracert
mpls te periodic-tracert [ -a source-ip | -exp exp-value | -h ttl-value  | -m wait-time | -t time-out | -u retry-attempt ] *
undo mpls te periodic-tracert
View
Default level
2: System level
-a source-ip: Specifies the source IP address of MPLS Echo Request messages. By default, the MPLS LSR ID is used as the source address of MPLS Echo Request messages.
-exp exp-value: Specifies the EXP value of the label. exp-value ranges from 0 to 7 and defaults to 0.
-h ttl-value: Specifies the TTL value to be carried by an MPLS Echo Request message. ttl-number is in the range of 1 to 255 and defaults to 30.
-m wait-time: Specifies the interval for performing LSP tracert. wait-time is in the range of 15 to 120 and defaults to 60, in minutes.
-t time-out: Specifies the timeout time for waiting for the response of an MPLS Echo Request message. time-out is in the range of 0 to 65535 and defaults to 2000, in milliseconds.
-u retry-attempt: Specifies the maximum number of times that MPLS Echo Request messages can be sent if no response is received. retry-attempt ranges from 1 to 9 and defaults to 3.
Use the mpls te periodic-tracert command to enable periodic LSP tracert for the MPLS TE tunnels on a tunnel interface.
Use the undo mpls te periodic-tracert command to disable periodic LSP tracert for MPLS TE tunnels on a tunnel interface.
By default, periodic LSP tracert is disabled for MPLS TE tunnels.
The periodic LSP tracert function for an MPLS TE tunnel is for locating faults of the MPLS TE tunnel periodically. It detects the consistency of the forwarding and control plane and records detection results into logs. You can know whether an MPLS TE tunnel has failed by checking the logs.
If you configure BFD as well as periodical tracert for an MPLS TE tunnel, once the tracert function detects a data plane failure or an inconsistency between the data plane and control plane, the existing BFD session is deleted and a new BFD session is then re-established based on the control plane.
You need to enable LSP verification by using the mpls lspv command before executing the mpls te periodic-tracert command.
# Enable periodic LSP tracert for the MPLS TE tunnels on tunnel interface Tunnel 3.
[Sysname-Tunnel3] mpls te periodic-tracert
mpls te priority
mpls te priority setup-priority [ hold-priority ]
undo mpls te priority
View
Default level
2: System level
setup-priority: Setup priority of the tunnel, in the range of 0 to 7. A lower numerical number indicates a higher priority.
hold-priority: Holding priority of the tunnel, in the range of 0 to 7. A lower numerical number indicates a higher priority. If not configured, it is the same as the setup priority.
Use the mpls te priority command to assign a setup priority and holding priority to the MPLS TE tunnel.
Use the undo mpls te priority command to restore the default.
By default, both setup and holding priorities of TE tunnels are 7.
To avoid flapping caused by improper preemptions between TE tunnels, the setup priority of an MPLS TE tunnel should not be set higher than its holding priority.
# Set the setup and holding priorities of TE tunnel 3 to 1.
[Sysname-Tunnel3] mpls te priority 1
mpls te protection tunnel
mpls te protection tunnel tunnel-id [ holdoff holdoff-time ] [ mode { non-revertive | revertive [ wtr wtr-time ] } ]
undo mpls te protection tunnel
View
Default level
2: System level
tunnel-id: ID of the tunnel to be specified as the protection tunnel.
holdoff holdoff-time: Specifies the switching delay time. After detecting that the main tunnel fails, the router will not switch data to the protection tunnel immediately but wait for a period of time (the holdoff time). If the protection tunnel keeps in no-defect state during this period of time, the router will switch data to the protection tunnel. The holdoff-time is the holdoff time factor, which ranges from 0 to 20 and defaults to 0. Holdoff time = holdoff time factor × 500 milliseconds. Therefore, the maximum holdoff time is 10 seconds.
mode: Specifies the reverting mode, non-revertive or revertive. The default reverting mode is revertive.
non-revertive: Specifies the non-revertive mode, that is, data will not be switched back from the protection tunnel to the main tunnel even if the main tunnel recovers.
revertive: Specifies the revertive mode, that is, data will be switched back from the protection tunnel to the main tunnel when the main tunnel recovers.
wtr wtr-time: Specifies the reverting delay time, that is, the time to wait before switching back to the main tunnel. wtr-time is the WTR time factor, which is in the range of 0 to 60 and defaults to 24. WTR time = WTR time factor × 30 seconds. Therefore, the default WTR time is 12 minutes.
Use the mpls te protection tunnel command to configure a protection tunnel for the main tunnel.
Use the undo mpls te protection tunnel command to remove the protection tunnel of a main tunnel.
By default, no protection tunnel is configured for the main tunnel.
Before configuring the mpls te protection tunnel command, you need to execute the tunnel-protocol mpls te command in tunnel interface view.
The configured protection tunnel takes effect only after you execute the mpls te commit command in the tunnel interface view.
Because the bypass tunnel configured in TE FRR cannot be applied in VPN applications, do not configure a protection tunnel for the bypass tunnel of TE FRR.
# Configure a protection tunnel for tunnel 1.
[Sysname-Tunnel1] mpls te protection tunnel 102 holdoff 20 mode revertive
wtr 30
[Sysname-Tunnel1] mpls te commit
mpls te protect-switch
mpls te protect-switch { clear | force | lock | manual { protect-lsp | work-lsp } }
View
Default level
2: System level
clear: Clears all configured switching actions.
force: Forces data to travel on the backup LSP.
lock: Always uses the main LSP to transfer data.
manual: Switches data from the main LSP to the backup LSP or vice versa.
protect-lsp: Switches data from the main LSP to the backup LSP.
work-lsp: Switches data from the backup LSP to the main LSP.
Use the mpls te protect-switch command to configure a switching action for a tunnel.
By default, no switching action is configured.
The following shows the priority of the externally configured switching actions and the signal fail switching, in the descending order:
·           Clear
·           Lockout of protection
·           Forced switch
·           Signal fail
·           Manual switch
# Specify to always use the main LSP to transfer data.
[Sysname-Tunnel1] mpls te protect-switch lock
mpls te record-route [ label ]
undo mpls te record-route
View
Default level
2: System level
label: Includes the record of labels in the route record. This keyword is not supported when the signaling protocol is CR-LDP.
Use the mpls te record-route command to enable route recording or label recording for the tunnel.
Use the undo mpls te record-route command to restore the default.
By default, a tunnel does not support route recording and label recording.
# Enable route recording on MPLS TE tunnel 3.
[Sysname-Tunnel3] mpls te record-route
mpls te reoptimization (tunnel interface view)
mpls te reoptimization [ frequency seconds ]
undo mpls te reoptimization
View
Default level
2: System level
frequency seconds: Specifies reoptimization frequency, in the range of 1 to 604800 seconds. The default is 3600 seconds, or 1 hour.
Use the mpls te reoptimization command to enable reoptimization on the tunnel.
Use the undo mpls te reoptimization command to disable reoptimization on the tunnel.
Reoptimization is disabled by default.
The reoptimization function cannot be used together with these commands:
mpls te auto-bandwidth adjustment, mpls te route-pinning, mpls te backup, and mpls te resv-style ff.
# Enable reoptimization, setting the reoptimization (automatic rerouting) frequency to 43200 seconds (12 hours).
[Sysname-Tunnel3] mpls te reoptimization frequency 43200
mpls te reoptimization (user view)
View
Default level
2: System level
None
Use the mpls te reoptimization command to start reoptimizing all reoptimization-enabled TE tunnels.
# Start reoptimizing all reoptimization-enabled TE tunnels.
<Sysname> mpls te reoptimization
mpls te resv-style
mpls te resv-style { ff | se }
undo mpls te resv-style
View
Default level
2: System level
ff: Sets the resource reservation style to fixed filter (FF).
se: Sets the resource reservation style to shared explicit (SE).
Use the mpls te resv-style command to set the resource reservation style for the MPLS TE tunnel.
Use the undo mpls te resv-style command to restore the default.
The default resource reservation style is SE.
You may configure FF and SE only when the signaling protocol is set to RSVP-TE.
# Adopt the FF reservation style when setting up the CR-LSP tunnel for TE tunnel 3.
[Sysname-Tunnel3] mpls te resv-style ff
mpls te retry
mpls te retry times
undo mpls te retry
View
Default level
2: System level
times: Number of tunnel setup retries, in the range of 10 to 4294967295.
Use the mpls te retry command to configure the maximum number of tunnel setup retries.
Use the undo mpls te retry command to restore the default.
The default maximum number of tunnel setup retries is 10.
You may configure the system to attempt setting up a tunnel multiple times until it is established successfully or until the number of attempts reaches the upper limit.
Related commands: mpls te timer retry.
# Set the maximum number of tunnel setup retries to 20.
[Sysname-Tunnel3] mpls te retry 20
undo mpls te route-pinning
View
Default level
2: System level
None
Use the mpls te route-pinning command to enable route pinning.
Use the undo mpls te route-pinning command to restore the default.
By default, route pinning is disabled.
The mpls te route-pinning command cannot be used together with the mpls te reoptimization command and the mpls te auto-bandwidth adjustment command.
# Enable route pinning.
[Sysname-Tunnel3] mpls te route-pinning
mpls te signal-protocol
mpls te signal-protocol { crldp | rsvp-te | static }
View
Default level
2: System level
crldp: Sets the signaling protocol for MPLS TE tunnel establishment to CR-LDP.
rsvp-te: Sets the signaling protocol for MPLS TE tunnel establishment to RSVP-TE.
static: Sets up the tunnel using a static CR-LSP.
Use the mpls te signal-protocol command to configure the signaling protocol for MPLS TE tunnel establishment.
The default signaling protocol for MPLS TE tunnel establishment is RSVP-TE.
CAUTION
CAUTION:
·       To use RSVP-TE as the signaling protocol for setting up the MPLS TE tunnel, you must enable both MPLS TE and RSVP-TE on the interface for the tunnel to use.
·       To use CR-LDP as the signaling protocol for setting up the MPLS TE tunnel, you must enable both MPLS TE and LDP on the interface for the tunnel to use.
# Adopt CR-LDP as the signaling protocol for establishing MPLS TE tunnel 3.
[Sysname-Tunnel3] mpls te signal-protocol crldp
mpls te tie-breaking
mpls te tie-breaking { least-fill | most-fill | random }
undo mpls te tie-breaking
View
Default level
2: System level
least-fill: Selects a path with the least bandwidth usage ratio (the used bandwidth to the maximum reservable link bandwidth).
most-fill: Selects a path with the most bandwidth usage ratio (the used bandwidth to the maximum reserved bandwidth).
random: Selects a path randomly.
Use the mpls te tie-breaking command to specify a tie breaker that a tunnel uses to select a path when multiple paths with the same metric are present.
Use the undo mpls te tie-breaking command to restore the default.
In MPLS view, the default tie breaker is random. In tunnel interface view, no tie breaker is specified by default.
·       A tunnel prefers the tie breaker specified in the tunnel interface view. If no tie breaker is specified in tunnel interface view, the tunnel uses the tie breaker specified in MPLS view to select a path.
·       The IETF DS-TE supports only random path selection.
# Configure tunnels to use the path with the least bandwidth usage ratio.
[Sysname] mpls
[Sysname-mpls] mpls te tie-breaking least-fill
# Configure tunnel 3 to use the path with the least bandwidth usage ratio.
[Sysname-Tunnel3] mpls te tie-breaking least-fill
mpls te timer auto-bandwidth
mpls te timer auto-bandwidth [ seconds ]
undo mpls te timer auto-bandwidth
View
MPLS view
Default level
2: System level
seconds: Interval for output rate sampling for tunnels configured with automatic bandwidth adjustment, in the range of 1 to 604800 seconds. If it is not configured, the default of 300 seconds applies. H3C recommends using the default in normal cases.
Use the mpls te timer auto-bandwidth command to enable automatic bandwidth adjustment and set the interval for output rate sampling for tunnels governed by automatic bandwidth adjustment.
Use the undo mpls te timer auto-bandwidth command to restore the default.
By default, automatic bandwidth adjustment is disabled.
To change the output rate sampling interval, use the undo mpls te timer auto-bandwidth command to disable automatic bandwidth adjustment first and then use the mpls te timer auto-bandwidth command to re-configure it.
Related commands: mpls te auto-bandwidth.
# Collect the output rates of MPLS TE tunnels automatically every 10 seconds or 600 seconds.
[Sysname] mpls
[Sysname-mpls] mpls te timer auto-bandwidth 600
mpls te timer fast-reroute
mpls te timer fast-reroute [ seconds]
undo mpls te timer fast-reroute
View
MPLS view
Default level
2: System level
seconds: FRR polling timer setting for the point of local repair (PLR) to poll available bypass tunnels for the best one. It ranges from 0 to 604800 seconds, with 0 disabling the PLR to poll available bypass tunnels regularly for the best one. The default is 300 seconds or 5 minutes.
Use the mpls te timer fast-reroute command to set the FRR polling timer.
Use the undo mpls te timer fast-reroute command to restore the default setting.
The default FRR polling timer is 300 seconds.
# Set the FRR polling timer to 120 seconds or 2 minutes.
[Sysname] mpls
[Sysname-mpls] mpls te timer fast-reroute 120
mpls te timer link-management periodic-flooding
mpls te timer link-management periodic-flooding interval
undo mpls te timer link-management periodic-flooding
View
MPLS view
Default level
2: System level
Interval: Interval for advertising bandwidth, in the range of 0 to 3600, in seconds.
Use the mpls te timer link-management periodic-flooding command to configure the interval for advertising updated bandwidth.
Use the undo mpls te timer link-management periodic-flooding command to restore the default.
By default, the bandwidth advertisement interval is 180 seconds.
The interval specified by this command is that at which the system will periodically advertise interface bandwidth if the bandwidth changes are within the specified threshold. Setting the interval to 0 means to disable the bandwidth advertisement function. The minimal valid interval is 30 seconds, that is, if you set the interval to a value less than 30, the system will take 30 seconds as the interval. If you change the interval before the current interval elapses, the new setting will take effect. For example, if you set the interval to 30 seconds, and then, within 30 seconds, set the interval to 3600 seconds, the interval of 3600 seconds will take effect.
# Set the bandwidth advertising interval to 100 seconds.
[Sysname] mpls
[Sysname- mpls] mpls te timer link-management periodic-flooding 100
mpls te timer retry
mpls te timer retry second
undo mpls te timer retry
View
Default level
2: System level
second: Interval for re-establishing the tunnel, in the range of 1 to 4294967295 seconds.
Use the mpls te timer retry command to configure the interval for re-establishing the tunnel.
Use the undo mpls te timer retry command to restore the default.
The default interval for re-establishing a tunnel is 2 seconds.
Related commands: mpls te retry.
# Set the interval for re-establishing tunnel 0 to 20 seconds.
[Sysname-Tunnel3] mpls te timer retry 20
mpls te tunnel-id
mpls te tunnel-id tunnel-id
View
Default level
2: System level
tunnel-id: Tunnel ID.
Use the mpls te tunnel-id command to configure the tunnel ID.
Configure the tunnel ID before issuing the mpls te commit command for the first time. Otherwise, the tunnel cannot be created.
Once configured, a tunnel ID cannot be removed. To change a tunnel ID, remove the tunnel and then reconfigure the tunnel, giving it a new tunnel ID.
# Configure the tunnel ID as 100.
[Sysname-Tunnel3] mpls te tunnel-id 100
mpls te vpn-binding
mpls te vpn-binding { acl acl-number | vpn-instance vpn-instance-name }
undo mpls te vpn-binding
View
Default level
2: System level
acl acl-number: Configures the MPLS TE tunnel to forward only VPN traffic that matches the specified ACL. The ACL number is in the range of 3000 to 3999.
vpn-instance vpn-instance-name: Configures the MPLS TE tunnel to forward only traffic of the specified VPN. The vpn-instance-name argument specifies an MPLS L3VPN by its instance name, a case-sensitive string of 1 to 31 characters.
Only ACLs with VPN instances specified in the rules can be referenced in the mpls te vpn-binding command.
Use the mpls te vpn-binding command to define the traffic that can travel the MPLS TE tunnel. You can specify the tunnel to forward only the VPN traffic that matches the specified ACL or forward only the traffic of the specified VPN.
Use the undo mpls te vpn-binding command to restore the default.
By default, no restriction is defined about what traffic can travel down a TE tunnel.
The router selects a TE tunnel for forwarding VPN traffic in this order: the TE tunnel specified with an ACL, the TE tunnel specified with a VPN instance, the TE tunnel with no restriction on what traffic to be forwarded. The router does not perform load sharing over different types of TE tunnels.
# Configure tunnel 3 to forward only traffic of the VPN vpn1.
[Sysname-Tunnel3] mpls te vpn-binding vpn-instance vpn1
# Configure tunnel 3 to forward only the VPN traffic that matches ACL 3001.
[Sysname] acl number 3001
[Sysname-acl-adv-3001] rule 0 permit ip vpn-instance vpn1
[Sysname-acl-adv-3001] quit
[Sysname-Tunnel3] mpls te vpn-binding acl 3001
mpls-te
mpls-te enable
undo mpls-te
View
OSPF area view
Default level
2: System level
enable: Enables the MPLS TE capability in the OSPF area.
Use the mpls-te command to enable the MPLS TE capability in current OSPF area.
Use the undo mpls-te command to disable the MPLS TE capability in current OSPF area.
By default, the MPLS TE capability is disabled in OSPF areas.
For an OSPF area to support the MPLS TE capability, its OSPF process must be available with the opaque LSA capability.
Related commands: opaque-capability.
# Enable the MPLS TE capability in OSPF area 1.
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] mpls-te enable
next hop
next hop ip-address [ include [ loose | strict ] | exclude ]
View
Explicit path view
Default level
2: System level
ip-address: Defines a node by its link IP address or router ID in dotted decimal notation. In the strict routing approach, this IP address must be a link IP address. In the loose routing approach, this IP address can be either a link IP address or router ID.
loose: Specifies the node as a loose node, which means that the ip-address and its previous hop can be connected indirectly.
strict: Specifies the node as a strict node, which means that the ip-address and its previous hop must be connected directly.
exclude: Excludes the specified IP address from the explicit path.
Use the next hop command to define a node on the explicit path. By performing this command multiple times, you may define all nodes that the explicit path must traverse in sequence.
·           If you specify neither include nor exclude, the include keyword is used by default.
·           If you specify neither loose nor strict, the strict keyword is used by default.
Related commands: delete hop.
# Specify the device to not consider the IP address 10.0.0.125 in path calculation for the explicit path path1.
[Sysname] explicit-path path1
[Sysname-explicit-path-path1] next hop 10.0.0.125 exclude
opaque-capability
opaque-capability enable
undo opaque-capability
View
OSPF view
Default level
2: System level
enable: Enables the opaque LSA capability.
Use the opaque-capability command to enable the opaque LSA capability for the OSPF process to generate and receive from its neighbors Opaque LSAs.
Use the undo opaque-capability command to restore the default.
By default, the opaque LSA capability of OSPF is disabled.
# Enable the opaque LSA capability of OSPF.
[Sysname] ospf 100
[Sysname-ospf-100] opaque-capability enable
ping lsp te
ping lsp [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -s packet-size | -t time-out | -v ] * te interface-type interface-number
View
Default level
0: Visit level
-a source-ip: Specifies the source IP address of the Echo Request messages to be sent.
-c count: Specifies the number of Echo Request messages to be sent. The count argument ranges from 1 to 4294967295 and defaults to 5.
-exp exp-value: Specifies the EXP value for the Echo Request messages. The exp-value argument ranges from 0 to 7 and default to 0.
-h ttl-value: Specifies the TTL value for the Echo Request messages. The ttl-value argument ranges from 1 to 255 and defaults to 255.
-m wait-time: Specifies the interval for sending Echo Request messages. The wait-time argument ranges from 1 to 10000 and default to 200, in milliseconds.
-r reply-mode: Specifies the reply mode of the receiver in response to an Echo Request message. The reply-mode argument can be 1 or 2, where 1 means “Do not response” and 2 means “Respond using a UDP packet”. The default is 2.
-s packet-size: Specifies the payload length of the Echo Request messages. The packet-size argument ranges from 65 to 8100 and defaults to 100, in bytes.
-t time-out: Specifies the timeout interval for waiting for the response to an echo request message. The time-out argument ranges from 0 to 65535 and defaults to 2000, in milliseconds.
-v: Displays detailed response information.
te interface-type interface-number: Specifies a tunnel interface.
Use the ping lsp te command to check MPLS TE tunnel connectivity.
# Use the ping function to check the connectivity of the MPLS TE tunnel Tunnel1.
<Sysname> ping lsp te tunnel 1
LSP Ping FEC: TE TUNNEL IPV4 SESSION QUERY Tunnel1 : 100  data bytes, press CTRL_C to break
    Reply from 100.1.2.1: bytes=100 Sequence=0 time = 31 ms
    Reply from 100.1.2.1: bytes=100 Sequence=1 time = 62 ms
    Reply from 100.1.2.1: bytes=100 Sequence=2 time = 62 ms
    Reply from 100.1.2.1: bytes=100 Sequence=3 time = 62 ms
    Reply from 100.1.2.1: bytes=100 Sequence=4 time = 62 ms
  --- FEC: TE TUNNEL IPV4 SESSION QUERY Tunnel1 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 31/55/62 ms
reset mpls rsvp-te statistics
reset mpls rsvp-te statistics { global | interface [ interface-type interface-number ]
View
Default level
1: Monitor level
global: Clears statistics about global RSVP-TE.
interface: Clears statistics about RSVP-TE for all interfaces.
interface interface-type interface-number: Specifies an interface by its type and number. If an interface is specified, the command clears the statistics about RSVP-TE for the interface.
Use the reset mpls rsvp-te statistics command to clear statistics about RSVP-TE.
# Clear statistics about global RSVP-TE.
<Sysname> reset mpls rsvp-te statistics global
static-cr-lsp egress
static-cr-lsp egress tunnel-name incoming-interface interface-type interface-number in-label in-label-value [ bandwidth [ ct0 | ct1 | ct2 | ct3 ] bandwidth-value ]
undo static-cr-lsp egress tunnel-name
View
Default level
2: System level
tunnel-name: Tunnel name, a case-sensitive string of 1 to 15 characters.
incoming-interface interface-type interface-number: Specifies the incoming interface.
in-label in-label-value: Specifies the incoming label, which can be a value of 0, 3, 16 through 1023.
bandwidth: Specifies the class type (CT) for static CR-LSP traffic. By default, static CR-LSP traffic belongs to CT 0.
ct0: Specifies CT 0 for static CR-LSP traffic.
ct1: Specifies CT 1 for static CR-LSP traffic.
ct2: Specifies CT 2 for static CR-LSP traffic.
ct3: Specifies CT 3 for static CR-LSP traffic.
bandwidth-value: Bandwidth assigned to static CR-LSP traffic, in the range of 1 to 32000000, in kbps.
Use the static-cr-lsp egress command to configure a static CR-LSP on the egress node.
Use the undo static-cr-lsp egress command to remove the static CR-LSP.
CT 2 and CT 3 can be used in only IETF DS-TE mode. In prestandard DS-TE mode, the configuration of CT 2 or CT 3 is invalid, and thus the tunnel cannot be established.
Related commands: mpls te tunnel-id.
# Configure a static CR-LSP on the egress node, setting its name to tunnel3, incoming interface to GigabitEthernet 3/1/1, and incoming label to 233.
[Sysname] static-cr-lsp egress tunnel3 incoming-interface GigabitEthernet 3/1/1 in-label 233
static-cr-lsp ingress
static-cr-lsp ingress tunnel-name destination dest-addr { nexthop next-hop-addr | outgoing-interface interface-type interface-number } out-label out-label-value [ bandwidth [ ct0 | ct1 | ct2 | ct3 ] bandwidth-value ]
undo static-cr-lsp ingress tunnel-name
View
Default level
2: System level
tunnel-name: Tunnel name, a case-sensitive string of 1 to 15 characters. It must be an exact reference to a tunnel interface created by the interface tunnel command. For example, if the tunnel interface created is Tunnel2, the tunnel name referenced here must be Tunnel2.
destination dest-addr: Specifies the IP address of the tunnel destination.
nexthop next-hop-addr: Specifies the next hop address.
outgoing-interface interface-type interface-number: Specifies an outgoing interface for the static CR-LSP.
out-label out-label-value: Specifies the outgoing label, which can be a value of 0, 3, and 16 through 1023.
bandwidth-value: Bandwidth assigned to the static CR-LSP, in the range of 1 to 32000000 kbps.
Use the static-cr-lsp ingress command to configure a static CR-LSP at the ingress node.
Use the undo static-cr-lsp ingress command to remove the static CR-LSP.
The next hop address cannot be a local public address when configuring the static CR-LSP on the ingress or a transit node.
# Configure a static CR-LSP on the ingress node, setting its name to Tunnel3, destination IP address to 202.25.38.1, destination address mask length to 24, next hop IP address to 202.55.25.33, outgoing label to 237, CT of traffic to CT 0, and required bandwidth to 20 kbps.
[Sysname] static-cr-lsp ingress Tunnel3 destination 202.25.38.1 nexthop 202.55.25.33 out-label 237 bandwidth ct0 20
static-cr-lsp transit
static-cr-lsp transit tunnel-name incoming-interface interface-type interface-number in-label in-label-value { nexthop next-hop-addr | outgoing-interface interface-type interface-number } out-label out-label-value [ bandwidth [ ct0 | ct1 | ct2 | ct3 ] bandwidth-value ]
undo static-cr-lsp transit tunnel-name
View
Default level
2: System level
incoming-interface interface-type interface-number: Specifies an incoming interface for the static CR-LSP.
in-label in-label-value: Specifies the incoming label, which ranges from 16 to 1023.
out-label out-label-value: Specifies the outgoing label, which can be a value of 0, 3, 16 through 1023.
Use the static-cr-lsp transit command to configure a static CR-LSP on a transit node.
Use the undo static-cr-lsp transit command to remove the static CR-LSP.
# Configure a static CR-LSP on the transit node, setting its name to tunnel3, incoming interface to GigabitEthernet 3/1/1, incoming label to 123, outgoing interface to GigabitEthernet 4/1/1, outgoing label to 253, CT of traffic to CT 0, and required bandwidth to 20 kbps.
[Sysname] static-cr-lsp transit tunnel3 incoming-interface GigabitEthernet3/1/1 in-label 123 outgoing-interface GigabitEthernet 4/1/1 out-label 253 bandwidth ct0 20
te-set-subtlv
te-set-subtlv { bw-constraint value | lo-multiplier value | unreserved-bw-sub-pool value } *
undo te-set-subtlv { bw-constraint | lo-multiplier | unreserved-bw-sub-pool } *
View
IS-IS view
Default level
2: System level
bw-constraint value: Sets the bandwidth constraint sub-TLV. value is the sub-TLV value in the range of 19 to 254.
lo-multiplier value: Sets the sub-TLV of local overbooking multiplier (LOM). value is the sub-TLV value in the range of 19 to 254.
unreserved-bw-sub-pool value: Sets the sub-TLV of unreserved subpool bandwidth. value is the sub-TLV value in the range of 19 to 254.
Use the te-set-subtlv command to configure the sub-TLVs carrying the DS-TE parameters. As no standard is available for these sub-TLVs, you need to configure them manually for interoperability with other vendors' routers.
Use the undo te-set-subtlv command to restore the default.
By default, the bandwidth constraint sub-TLV is 252, the sub-TLV of LOM is 253, and the sub-TLV of unreserved subpool bandwidth is 251.
Related commands: display isis traffic-eng sub-tlvs.
# Configure sub-TLVs for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] te-set-subtlv bw-constraint 200 lo-multiplier 201 unreserved-bw-sub-pool 202
tracert lsp te
tracert lsp [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode |-t time-out ] * te interface-type interface-number
View
Default level
0: Visit level
-a source-ip: Specifies the source IP address of the Echo Request messages.
-exp exp-value: Specifies the EXP value for the Echo Request messages. The exp-value argument ranges from 0 to 7 and defaults to 0.
-h ttl-value: Specifies the TTL value for the Echo Request messages. The ttl-value argument ranges from 1 to 255 and defaults to 30.
Use the tracert lsp te command to locate errors of MPLS TE tunnels.
# Tracert the MPLS TE tunnel of tunnel interface Tunnel 1.
<Sysname> tracert lsp te tunnel 1
LSP Trace Route FEC: TE TUNNEL IPV4 SESSION QUERY Tunnel1 , press CTRL_C to break.
  TTL   Replier            Time    Type      Downstream
  0                                Ingress   10.4.5.1/[1025]
  1     10.4.5.1           1       Transit   100.3.4.1/[1024]
  2     100.3.4.1          63      Transit   100.1.2.1/[3]
  3     100.1.2.1          129     Egress
Table 38 Output description
Replier
Address of the LSR that replies to the request
Time
Time when the reply was received, in milliseconds
Role of the LSR in the LSP, Ingress, Transit, or Egress
Downstream
Address of the downstream LSR and the outgoing label
traffic-eng
traffic-eng [ level-1 | level-1-2 | level-2 ]
undo traffic-eng [ level-1 | level-1-2 | level-2 ]
View
IS-IS view
Default level
2: System level
level-1: Enables Level-1 IS-IS TE.
level-1-2: Enables Level-1-2 IS-IS TE.
level-2: Enables Level-2 IS-IS TE.
If no level is specified, IS-IS TE applies to Level-1-2.
Use the traffic-eng command to enable IS-IS TE.
Use the undo traffic-eng command to restore the default.
By default, IS-IS TE is disabled.
In order to enable IS-IS TE, you must use the cost-style command to configure the cost style of the IS-IS packet to wide, compatible or wide-compatible. For more information about the cost-style command, see Layer 3—IP Routing Command Reference.
# Enable TE for Level-2 IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] cost-style compatible
[Sysname-isis-1] traffic-eng level-2
