- 01-Access Volume
 - 01-CPOS Interface Commands
 - 02-POS Interface Commands
 - 03-Ethernet Interface Commands
 - 04-WAN Interface Commands
 - 05-Frame Relay Commands
 - 06-HDLC Commands
 - 07-PPP Commands
 - 08-Logical Interface Commands
 - 09-Modem Management Commands
 - 10-ATM Interface Commands
 - 11-ATM Commands
 - 12-E-CPOS Interface Commands
 - 13-VLAN Termination Commands
 - 14-Port Mirroring Commands
| 07-PPP Commands | 173.88 KB |
Table of Contents
1 PPP and MP Configuration Commands
PPP and MP configuration commands
display interface virtual-template
ppp ipcp remote-address forced
PPP Link Efficiency Mechanism Configuration Commands
2 PPPoE Configuration Commands
PPPoE Server Configuration Commands
pppoe-server log-information off
pppoe-server max-sessions local-mac
pppoe-server max-sessions remote-mac
pppoe-server max-sessions total
broadcast-limit link
broadcast-limit link number
undo broadcast-limit link
View
Virtual template (VT) view
Default Level
2: System level
number: Maximum number of links that can be used for transmitting multicast or broadcast packets, in the range 0 to 128. A value of 0 disables the transmission of multicast packets or broadcast packets.
Use the broadcast-limit link command to set the maximum number of links that can be used for transmitting multicast packets or broadcast packets for a VT.
Use the undo broadcast-limit link command to restore the default.
By default, the maximum number of links that can be used for transmitting multicast or broadcast packets is 30.
For a VT containing multiple links, the system performance may decrease if all the links of the VT are engaged in multicast or broadcast packet transmission. You can use the broadcast-limit link command to limit the number of links that are capable of multicast or broadcast packet transmission.
# Set the maximum number of links that are capable of multicast or broadcast packets transmission to 100 for VT 1.
[Sysname] interface virtual-template 1
[Sysname-Virtual-Template1] broadcast-limit link 100
display interface mp-group
display interface mp-group [ mp-number ]
View
Default Level
1: Monitor level
mp-number: Number of an existing multilink point to point protocol group (MP-group) interface.
Use the display interface mp-group command to display the information about an existing MP-group interface. If the mp-number argument is not provided, this command displays the information about all the existing MP-group interfaces.
# Display the information about interface MP-group 12.
<Sysname> display interface mp-group 12
Mp-group12 current state: DOWN
Line protocol current state: DOWN
Description: Mp-group12 Interface
The Maximum Transmit Unit is 1500, Hold timer is 10(sec)
Internet protocol processing : disabled
Link layer protocol is PPP
LCP initial
Physical is MP
Output queue : (Urgent queue : Size/Length/Discards) 0/50/0
Output queue : (Protocol queue : Size/Length/Discards) 0/500/0
Output queue : (FIFO queuing : Size/Length/Discards) 0/75/0
Last 300 seconds input: 0 bytes/sec 0 packets/sec
Last 300 seconds output: 0 bytes/sec 0 packets/sec
0 packets input, 0 bytes, 0 drops
0 packets output, 0 bytes, 0 drops
Table 1-1 Description on the fields of the display interface mp-group command
    Field  |
    Description  |
   current state  |
   Physical state of the interface (UP or DOWN)  |
   Line protocol current state  |
   Data link layer state (UP or DOWN)  |
   Description  |
   Description string of the interface  |
   The Maximum Transmit Unit  |
   Maximum transmit unit (MTU) of the interface  |
   Hold timer  |
   Interval for the current interface to send keepalive packets  |
   Internet protocol processing  |
   Network layer state (enabled or disabled)  |
   LCP initial  |
   Link control protocol (LCP) negotiation is complete  |
   Physical  |
   Physical type of the interface  |
   Last 300 seconds input: 0 bytes/sec 0 packets/sec Last 300 seconds output: 0 bytes/sec 0 packets/sec  |
   Average rate of input packets and output packets in the last 300 seconds  |
   0 packets input, 0 bytes, 0 drops  |
   Total amount of the inbound packets of the interface (in the number of packets and in bytes), and the number of packets dropped among the inbound packets  |
   0 packets output, 0 bytes, 0 drops  |
   Total amount of outbound packets of the interface (in the number of packets and in bytes), and the number of packets dropped among the outbound packets  |
display interface virtual-template [ number ]
View
Default Level
1: Monitor level
number: Number of an existing virtual template (VT).
Use the display interface virtual-template command to display the information about a VT. If the number argument is not provided, this command displays the information about all the existing VTs.
Related commands: interface virtual-template.
# Display the information about VT 1.
<Sysname>display interface virtual-template 1
Virtual-Template1 current state: UP
Line protocol current state: UP (spoofing)
Description: Virtual-Template1 Interface
Internet Address is 6.1.1.2/8 Primary
LCP initial, MP opened
Physical is None, baudrate: 64000 bps
Output queue : (Urgent queuing : Length) 100
Output queue : (Protocol queuing : Length) 500
Output queue : (FIFO queuing : Length) 75
Last 300 seconds output: 6 bytes/sec 0 packets/sec
512 packets input, 43008 bytes, 0 drops
614 packets output, 49636 bytes, 0 drops
Refer to Table 1-1 for the description on the output fields.
display virtual-access
For centralized devices:
display virtual-access [ va-number | dialer dialer-number | peer peer-address | user user-name | vt vt-number ] *
For distributed devices:
display virtual-access [ va-number | peer peer-address | slot slot-number | user user-name | vt vt-number ] *
View
Default Level
1: Monitor level
va-number: VA interface number, ranging from 0 to 65535.
peer peer-address: Specifies the peer IP address of a VA interface, in dotted decimal notation.
slot slot-number: Specifies a slot by its number.
user user-name: Specifies the username of a user logging in through a VA interface. This argument is a string of 1 to 80 characters.
vt vt-number: Specifies a VT number, in the range 0 to 1023.
Use the display virtual-access command to display the information about a VA interface or the VA interfaces that are formed based on a VT.
VA interfaces are created automatically by the system. They adopt the settings of the corresponding VTs. A VA interface can be removed due to failures of lower layer connections or user intervention.
# Display the information about all the VA interfaces that are formed based on VT 1.
<Sysname> display virtual-access vt 1
Virtual-Template1:0 current state: UP
Description: Virtual-Template1:0 Interface
LCP opened, MP opened, IPCP opened, OSICP opened
Physical is MP, baudrate: 64000 bps
Output queue : (Urgent queuing : Size/Length/Discards) 0/100/0
Output queue : (Protocol queuing : Size/Length/Discards) 0/500/0
520 packets input, 44132 bytes, 0 drops
527 packets output, 44566 bytes, 4 drops
display ppp mp
display ppp mp [ interface interface-type interface-number ]
View
Default Level
1: Monitor level
Use the display ppp mp command to display the information about an MP interface.
Related commands: link-protocol ppp, ppp mp.
# Display the information about all the MP interfaces.
<Sysname> display ppp mp
Mp-group is Mp-group0
max-bind: 20, min-fragment: 128 ,LFI max-delay: 100
Bundle Multilink, 6 members, Master link is Mp-group0
Peer's endPoint descriptor: 1e9935f57c85
Sequence format: short/long rcv/sent
Bundle Up Time: 2005/03/13 19:54:23:60
0 lost fragments, 0 reordered, 0 unassigned, 0 interleaved,
sequence 0/0 rcvd/sent
The member channels bundled are:
Serial2/1:15 Up-Time:2005/03/13 19:54:23:60
Serial2/1:16 Up-Time:2005/03/13 19:54:23:60
Serial2/1:17 Up-Time:2005/03/13 19:54:23:60
Serial2/1:18 Up-Time:2005/03/13 19:54:23:60
Serial2/1:19 Up-Time:2005/03/13 19:54:23:60
Serial2/1:20 Up-Time:2005/03/13 19:54:23:60
Inactive member channels: 4 members
Serial2/1:21 (inactive)
Serial2/1:22 (inactive)
Serial2/1:23 (inactive)
Serial2/1:24 (inactive)
Table 1-2 Description on the fields of the display ppp mp command
    Field  |
    Description  |
   Mp-group is Mp-group0  |
   The information about MP-group 0 interface is displayed.  |
   max-bind  |
   Maximum number of links that can be bundled  |
   min-fragment  |
   Minimum size of an MP fragment  |
   LFI max-delay  |
   Maximum delay to transmit an LFI fragment  |
   Bundle Multilink  |
   Peer MP username is Multilink.  |
   6 members  |
   Six channels are bundled.  |
   Master link is MP-group0  |
   The master channel is MP-group 0.  |
   Peer's endPoint descriptor: 1e9935f57c85  |
   The description string of the peer is 1e9935f57c85.  |
   Sequence format: short/long rcv/sent  |
   Sequence number header format of MP: the short sequence number format is used in the incoming direction and the long sequence number format is used in the outgoing direction  |
   Bundle Up Time: 2005/03/13 19:54:23:60  |
   The MP channel went up at 19:54:23:60 on March 13, 2005.  |
   0 lost fragments  |
   Number of the lost fragments  |
   0 reordered  |
   Number of the packets reassembled  |
   0 unassigned  |
   Number of the packets waiting for being reassembled  |
   0 interleaved  |
   Number of the interleaved packets  |
   sequence 0/0 rcvd/sent  |
   Received sequence number/sent sequence number  |
   The member channels bundled are  |
   The following displays all the member channels bundled in this logical channel  |
   Serial2/1:15 Up-Time:2005/03/13 19:54:23:60  |
   Subchannel Serial2/1:15 is up at 19:54:23:60 on March 13, 2005  |
   Inactive member channels  |
   List of the inactive subchannels  |
interface mp-group
interface mp-group mp-number
undo interface mp-group mp-number
View
Default Level
2: System level
mp-number: MP group interface number.
l For a centralized device, mp-number ranges from 0 to 1023.
l For a distributed device, mp-number is in the form of X/Y/Z, in which:
X is the number of the slot that holds the service board, ranging from 2 to 5.
Y is the number of the subslot that holds the interface card, which can either be 0 or the physical subslot number. 0 is the number of the subslot which holds the logical interface card.
Z is the number of the interface on the interface card, ranging from 0 to 1023.
Use the interface mp-group command to create an MP group interface and enter MP group interface view.
Use the undo interface mp-group command to remove an MP-group interface.
This command needs to be used in conjunction with the ppp mp mp-group command. You can execute the two commands in either order.
MP-group interfaces do not support cross-board link bundling.
# Create MP group 3 interface on a centralized device.
[Sysname] interface mp-group 3
[Sysname-Mp-group3]
# Create MP group 5/0/0 interface on a distributed device.
[Sysname] interface mp-group 5/0/0
[Sysname-Mp-group5/0/0]
interface virtual-ethernet number
undo interface virtual-ethernet number
View
Default Level
2: System level
number: VT number, in the range 0 to 1023.
Use the interface virtual-template command to create a VT and enter VT view. If the VT already exists, you enter its view directly.
Use the undo interface virtual-template command to remove a VT.
To remove a VT, make sure that all the corresponding VA access interfaces are removed and the VT is not in use.
# Create VT 10 interface.
[Sysname] interface virtual-template 10
ip address ppp-negotiate
undo ip address ppp-negotiate
View
Interface view
Default Level
2: System level
None
Use the ip address ppp-negotiate command to enable IP address negotiation on the local interface, so that the local interface can accept the IP address allocated by the peer end.
Use the undo ip address ppp-negotiate command to disable IP address negotiation.
By default, IP address negotiation is disabled.
Related commands: remote address, ppp ipcp remote-address forced.
# Enable IP address negotiation on Serial 2/0.
[Sysname] interface serial 2/0
[Sysname-Serial2/0] ip address ppp-negotiate
link-protocol ppp
link-protocol ppp
View
Interface view
Default Level
2: System level
None
Use the link-protocol ppp command to enable PPP on an interface.
By default, PPP are enabled on all the interfaces except Ethernet interface.
# Enable PPP on Serial 2/0.
[Sysname-Serial2/0] link-protocol ppp
mtu
mtu size
undo mtu
View
VT interface view, MP group interface view
Default Level
2: System level
size: MTU in bytes, in the range of 128 to 1580.
Use the mtu command to set the MTU size of the interface.
Use the undo mtu command to restore the default.
By default, the MTU of an interface is 1500 bytes.
# Set the MTU of MP group 1 to 1200 bytes.
[Sysname] interface mp-group 1
[Sysname-Mp-group1] mtu 1200
ppp account-statistics enable
undo ppp account-statistics enable
View
Interface view
Default Level
2: System level
None
Use the ppp account-statistics enable command to enable the generating of PPP accounting statistics.
Use the undo ppp account-statistics enable command to disable the generating of PPP accounting statistics.
By default, the generating of PPP accounting statistics is disabled.
# Enable the generating of PPP accounting statistics on interface Serial 2/0.
[Sysname-Serial2/0] ppp account-statistics enable
ppp authentication-mode
ppp authentication-mode { chap | pap } [ call-in | domain isp-name ]
undo ppp authentication-mode
View
Interface view
Default Level
2: System level
chap: Adopts CHAP authentication.
pap: Adopts PAP authentication.
call-in: Authenticates the call-in users only.
domain isp-name: Specifies the domain name for authentication, a string of 1 to 24 characters.
Use the ppp authentication-mode command to configure the PPP authentication mode.
Use the undo ppp authentication-mode command to disable PPP authentication.
By default, PPP authentication is not performed.
Note that:
l If you run the ppp authentication-mode command with the domain keyword specified, you need to configure an address pool in the corresponding domain. (You can use the display domain command to display the domain configuration.)
l If you configure the ppp authentication-mode command without specifying the domain name, the system checks the username for domain information. If the username contains a domain name, the domain will be used for authentication (If the domain does not exist, the user’s access request will be denied). If not, the default domain is used (you can use the domain default command to configure the default domain; if no default domain is configured, the default domain system is used by default).
There are two types of PPP authentication: PAP authentication and CHAP authentication.
l PAP authentication is two-way handshake authentication. The password used is in plain text.
l CHAP authentication is three-way handshake authentication. The password is in cipher text.
In addition, you can also adopt the AAA authentication algorithm list (if defined) to authenticate users.
In either PPP authentication mode, AAA determines whether a user can pass the authentication through a local authentication database or an AAA server.
For information about creating a local user account, configuring its attributes, creating a domain, and configuring domain attributes, refer to AAA Configuration in the Security Volume.
Related commands: ppp chap user, ppp pap local-user, ppp chap password, local-user, domain default (the latter two commands are described in AAA Commands in the Security Volume).
# Configure to authenticate the peer device using PAP on interface Serial 2/0.
[Sysname-Serial2/0] ppp authentication-mode pap domain system
ppp chap password
ppp chap password { cipher | simple } password
undo ppp chap password
View
Interface view
Default Level
2: System level
cipher: Specifies to display the password in cipher text.
simple: Specifies to display the password in plain text.
password: Default password for CHAP authentication, a string of 1 to 48 characters. When the simple keyword is used, this password is in plain text. When the cipher keyword is used, this password can either be in cipher text or in plain text. A password in plain text is a continuous string of no more than 48 characters, such as aabbcc. A password in cipher text has a fixed length of 24 or 64 characters, such as _(TT8F]Y\5SQ=^Q`MAF4<1!!.
Use the ppp chap password command to set the default password for CHAP authentication.
Use the undo ppp chap password command to cancel the configuration.
Related commands: ppp authentication-mode chap.
# Set the default password for CHAP authentication to systemname, which is to be displayed in plain text.
[Sysname-Serial2/0] ppp chap password simple systemname
ppp chap user
ppp chap user username
undo ppp chap user
View
Interface view
Default Level
2: System level
username: Username for CHAP authentication, a string of 1 to 80 characters, which is the one sent to the peer device for the local device to be authenticated.
Use the ppp chap user command to set the username for CHAP authentication.
Use the undo ppp chap user command to cancel the configuration.
By default, the username for CHAP authentication is null.
To pass CHAP authentication, the username/password of one side needs to be the local username/password of the peer.
Related commands: ppp authentication-mode.
# Set the username for CHAP authentication as Root on Serial 2/0 interface.
[Sysname-Serial2/0] ppp chap user Root
ppp ipcp dns
ppp ipcp dns primary-dns-address [ secondary-dns-address ]
undo ppp ipcp dns primary-dns-address [ secondary-dns-address ]
View
Interface view
Default Level
2: System level
primary-dns-address: Primary DNS server IP address to be set.
secondary-dns-address: Secondary DNS server IP address to be set.
Use the ppp ipcp dns command to configure the primary and secondary DNS server IP addresses to be used in PPP negotiation.
Use the undo ppp ipcp dns command to cancel the configuration.
By default, a device does not allocate DNS server IP addresses for its peer.
When connected through PPP, a device can assign DNS server IP addresses to its peer during PPP negotiation (if the peer requests) for the peer to access the network by domain names.
If a PC is connected to the device through PPP, you can execute the winipcfg command or the ipconfig /all command on the PC to check the DNS server IP addresses assigned by the device.
A device can provide a primary DNS server IP address and a secondary DNS server IP address to its peer.
# Set the primary DNS server IP address to 100.1.1.1 and the secondary DNS server IP address to 100.1.1.2 on interface Serial 2/0.
[Sysname-Serial2/0] ppp ipcp dns 100.1.1.1 100.1.1.2
ppp ipcp dns admit-any
undo ppp ipcp dns admit-any
View
Interface view
Default Level
2: System level
None
Use the ppp ipcp dns admit-any command to configure the device to accept the DNS server IP addresses assigned by the peer even though it does not request the peer for the DNS server IP addresses.
Use the undo ppp ipcp dns admit-any command to configure the device to deny the DNS server IP addresses assigned by the peer if it does not request the peer for the DNS server IP addresses.
By default, a device does not accept the DNS server IP addresses assigned by the peer if it does not request the peer for the DNS server IP addresses.
You can configure a device to accept the DNS server IP addresses assigned by the peer, through which domain names can be resolved for the device.
Note that, before configuring this command, you need to configure the ppp ipcp dns request command first.
# Configure interface Serial 2/0 of the local device to accept the DNS server IP addresses allocated by the peer.
[Sysname-Serial2/0] ppp ipcp dns admit-any
undo ppp ipcp dns request
View
Interface view
Default Level
2: System level
None
Use the ppp ipcp dns request command to enable a device to request its peer for the DNS server IP address actively through a port.
Use the undo ppp ipcp dns request command to restore the default.
By default, a device does not request its peer for the DNS server IP address actively.
You can configure a device to request its peer (especially in cases where a device is connected to the operator’s access server through a dial-up link) for the DNS server address during PPP negotiation to enable domain names to be resolved for the device.
You can check the DNS server IP addresses of a port by displaying the information about the port.
# Enable the device to request its peer for the DNS server IP address actively through Serial 2/0 interface.
[Sysname-Serial2/0] ppp ipcp dns request
undo ppp ipcp remote-address forced
View
Interface view
Default Level
2: System level
None
Use the ppp ipcp remote-address forced command to configure a device to assign IP addresses to the peer by force. This command also disables the peer from using locally configured IP addresses.
Use the undo ppp ipcp remote-address forced command to cancel the configuration.
By default, the peer can use locally configured IP address in PPP IPCP negotiation. That is, a device assigns an IP address to its peer when the latter requests explicitly. It does not assign IP addresses to the peer when the latter already has IP addresses configured.
To disable the peer from using locally configured IP addresses, execute the ppp ipcp remote-address forced command on the local interface.
Related commands: remote address.
# Configure an optional IP address 10.0.0.1 on interface Serial 2/0 for the peer.
[Sysname-Serial2/0] remote address 10.0.0.1
# Configure IP address 10.0.0.1 on interface Serial 2/0 for the peer and assign the IP address to the peer by force.
[Sysname-Serial2/0] ppp ipcp remote-address forced
ppp mp
ppp mp
undo ppp mp
View
Interface view
Default Level
2: System level
None
Use the ppp mp command to configure an interface encapsulated with PPP to operate in MP mode.
Use the undo ppp mp command to restore the default.
By default, an interface encapsulated with PPP operates in the single PPP mode.
To obtain more bandwidth, you can bind multiple PPP links to form a logical MP interface.
# Configure interface Serial 2/0 to operate in MP mode (assuming that the interface is PPP-encapsulated).
[Sysname-Serial2/0] ppp mp
ppp mp binding-mode
ppp mp binding-mode { authentication | both | descriptor }
undo ppp mp binding-mode
View
Virtual template interface view
Default Level
2: System level
authentication: Performs MP binding by PPP authentication username.
both: Performs MP binding by both PPP authentication username and endpoint descriptor.
descriptor: Performs MP binding by endpoint descriptor.
Use the ppp mp binding-mode command to set the way in which MP binding is performed.
Use the undo ppp mp binding-mode command to restore the default.
By default, MP binding is performed by both PPP authentication username and endpoint descriptor.
The PPP authentication username is the peer username received while performing PAP or CHAP authentication. The endpoint descriptor, which uniquely identifies a device, refers to the one received during LCP negotiation. Based on the username or endpoint descriptor, the system can locate the corresponding VT interface and then create an MP binding according to the template.
Note that:
l In endpoint descriptor-based MP bindings, users cannot be differentiated. So, to bind users to different groups, use the keyword both in the command.
l In authentication username-based MP bindings, peer devices cannot be differentiated. So, when multiple peer devices exist, use the keyword both in the command.
l Related commands: ppp mp user.
# Specify to perform MP binding by PPP authentication username.
[Sysname] interface virtual-template 0
[Sysname- Virtual-Template0] ppp mp binding-mode authentication
ppp mp endpoint
ppp mp endpoint string char-string
undo ppp mp endpoint
View
Interface view
Default Level
2: System level
string char-string: Specifies the char-string argument as the endpoint option. The string specified by char-string is of 1 to 20 characters.
Use the ppp mp endpoint command to configure the endpoint option for LCP negotiation when the current interface is in an MP-group interface.
Use the undo ppp mp endpoint command to restore the default endpoint option for LCP negotiation when the current interface is in an MP-group interface.
By default, the endpoint option in the packets sent out an interface is the device name. After you use the mp-group command to add the interface to the specified MP-group interface, the endpoint option in the packets sent out the interface is the MP-group interface name. As the endpoint option is of up to 20 bytes, if the default is of more than 20 bytes, the first 20 bytes are taken as the endpoint option.
# Configure the endpoint option in the packets sent out Serial 2/0 as 123456.
[Sysname-Serial2/0] ppp mp endpoint string 123456
ppp mp max-bind
ppp mp max-bind max-bind-num
undo ppp mp max-bind
View
Virtual template interface view, MP group interface view
Default Level
2: System level
max-bind-num: Maximum number of links allowed in an MP bundle, in the range 1 to 128.
Use the ppp mp max-bind command to set the maximum number of links allowed in an MP bundle.
Use the undo ppp mp max-bind command to restore the default.
By default, the maximum number of links allowed in an MP bundle is 16.
Changing the maximum number of links allowed in an MP bundle may affect PPP performance. So, execute the ppp mp max-bind command under the guidance of technical engineers. Normally, the default is recommended.
l If the maximum number of links allowed in an MP bundle configured is less than the actual link number of an MP bundle, you will fail to bundle the links. Therefore, make sure that the maximum link number configured is larger than the actual one.
l After you change the maximum number of bundled links for an MP bundle, you need to shutdown and then bring up all the physical interfaces bound to the MP bundle for the modification to take effect.
Related commands: ppp mp.
# Set the maximum number of links allowed in an MP bundle to 12.
[Sysname-Virtual-Template0] ppp mp max-bind 12
ppp mp min-fragment
ppp mp min-fragment size
undo ppp mp min-fragment
View
Default Level
2: System level
size: Minimum MP packet size for fragmentation to be set, in the range 128 to 1500 (in bytes). MP outgoing packets smaller than this value will not be fragmented, while those larger than or equal to this value will be fragmented.
Use the ppp mp min-fragment command to set the minimum MP packet size for fragmentation.
Use the undo ppp mp min-fragment command to restore the default, 128 bytes.
l If MP bundle is implemented through hardware (CPOS chip for example), the minimum MP packet size for fragmentation varies with chips (the fragment size on certain chips can only be 128, 256, and 512 bytes). In this case, you need to make sure the setting specified by the ppp mp min-fragment command conforms to the hardware specification for the MP bundle and the sub-channel LCP link to be established successfully.
l After executing the ppp mp min-fragment command, you need to shut down and then bring up all the bundled ports for the new setting to take effect.
# Set the minimum MP packet size for fragmentation to 500 bytes.
[Sysname-Virtual-Template0] ppp mp min-fragment 500
ppp mp mp-group
ppp mp mp-group mp-number
undo ppp mp
View
Interface view
Default Level
2: System level
l On centralized devices, the mp-number argument ranges from 0 to 1023.
l On distributed devices, the mp-number argument is in the form of X/Y/Z, where:
X is the slot number of the LPU, in the range of 2 to 5.
Y is the subslot number of the interface card. Y is 0 or the subslot number of the interface card. The logical interface card is seated in subslot 0.
Z is the number of the interface on the interface card, in the range of 0 to 1023.
Use the ppp mp mp-group command to add the current interface to an MP-group.
Use the undo ppp mp mp-group command to remove the current interface from the specified MP-group it belongs to.
This command should be used along with the interface mp-group command. However, the order in which the two commands are executed can be either one. That is, you can create an MP-group interface and then add an interface to the MP-group; or add the interface to the MP-group and then create the MP-group.
Note that:
l Only physical interfaces can be added to an MP group. Logical interfaces (such as Tunnel interfaces) do not support the ppp mp mp-group command.
l MP-group interfaces on different LPUs cannot be bound together.
On a centralized device:
# Add interface Serial 2/0 to MP-group 3.
[Sysname-Serial3/0] ppp mp mp-group 3
ppp mp short-sequence
undo ppp mp short-sequence
View
Interface view
Default Level
2: System level
None
Use the ppp mp short-sequence command to trigger MP short sequence number header format negotiation. After the negotiation succeeds, the local end receives packets with short sequence numbers.
Use the undo ppp mp short-sequence command to restore the default.
By default, the long sequence number header format is used.
This command applies to the incoming direction only. To enable the local end to transmit packets with short sequence numbers, configure the remote end to receive packets with short sequence numbers.
l The sequence number format (long or short) of an MP bundle depends on the configuration of the first channel joining the MP bundle.
l To negotiate the use of short sequence numbers on a dialer MP bundle, configure the command on the dialer interfaces and the ISDN D channels; to do that on a common MP bundle, use the command on all its channels. Note that the command will cause PPP re-negotiation.
# Configure the short sequence number header format of MP in the incoming direction of interface Serial 2/0.
[Sysname-Serial2/0] ppp mp mp-group 0
ppp mp user
ppp mp user username bind virtual-template number
undo ppp mp user username
View
Default Level
2: System level
username: Username, a string of 1 to 80 characters.
virtual-template number: Specifies a virtual-template number, in the range 0 to 1023.
Use the ppp mp user command to specify to add PPP links with specific usernames to the corresponding MP bundles according to usernames.
Use the undo ppp mp user command to remove a username-based MP bundle.
In establishing a PPP connection, if PPP authentication succeeds and a virtual-template is specified, the PPP link established will be added to the corresponding MP bundle according to the configuration of the virtual-template, and a new virtual interface will be formed for data transmission.
You can configure the following parameters for a virtual-template:
l Local IP address and the peer IP address (or IP address pool)
Related commands: ppp mp, ppp mp max-bind.
# Specify the VT interface that corresponds to user 1 as VT interface 1, setting the IP address of the VT interface as 202.38.60.1/24.
[Sysname] ppp mp user user1 bind virtual-template 1
[Sysname-Virtual-Template1] ip address 202.38.60.1 255.255.255.0
ppp mp virtual-template
ppp mp virtual-template number
undo ppp mp
View
Interface view
Default Level
2: System level
number: Number of the VT interface to be bound to the interface, in the range 0 to 1023.
Use the ppp mp virtual-template command to bind an interface to a VT interface, enabling the interface to work in MP mode.
Use the undo ppp mp command to cancel an interface-VT interface binding, making the interface to work in normal PPP mode.
By default, an interface is not bound to a VT interface, and the interface works in normal PPP mode.
After binding an interface to a VT interface, you can optionally enable PAP/CHAP authentication.
Two or more interfaces bound to the same VT interface are bound together directly. Note that the ppp mp virtual-template command and the ppp mp command are mutually exclusive.
# Bind interface Serial 2/0 to VT interface 1 (assuming that the interface is encapsulated with PPP).
[Sysname-Serial2/0] ppp mp virtual-template 1
ppp pap local-user
ppp pap local-user username password { cipher | simple } password
undo ppp pap local-user
View
Interface view
Default Level
2: System level
username: Username of the local device for PAP authentication, a string of 1 to 80 characters.
cipher: Displays the password in cipher text.
simple: Displays the password in plain text.
password: Default password for PAP authentication, a string of 1 to 48 characters. When the simple keyword is used, this password is in plain text. When the cipher keyword is used, this password can either be in cipher text or in plain text. A password in plain text is a continuous string of no more than 48 characters, such as aabbcc. A password in cipher text has a fixed length of 24 or 64 characters, such as _(TT8F]Y\5SQ=^Q`MAF4<1!!.
Use the ppp pap local-user command to set the local username and password for PAP authentication.
Use the undo ppp pap local-user command to cancel the local username and password configured.
By default, the username and the password for PAP authentication are not set.
For the local device to pass PAP authentication on the remote device, make sure that the same username and password configured for the local device are also configured on the remote device with the commands local-user username and password { cipher | simple } password.
Related commands: local-user, password (in AAA Commands in the Security Volume)
# Set the local username and password for PAP authentication as user1 and pass1 (in plain text).
[Sysname-Serial2/0] ppp pap local-user user1 password simple pass1
ppp timer negotiate
ppp timer negotiate seconds
undo ppp timer negotiate
View
Interface view
Default Level
2: System level
seconds: Negotiation timeout time to be set, in the range 1 to 10 (in seconds). In PPP negotiation, if the local device receives no response from the peer during this period after it sends a packet, the local device sends the last packet again.
Use the ppp timer negotiate command to set the PPP negotiation timeout time.
Use the undo ppp timer negotiate command to restore the default.
By default, the PPP negotiation timeout time is three seconds.
# Set the PPP negotiation timeout time to five seconds.
[Sysname-Serial2/0] ppp timer negotiate 5
remote address
remote address { ip-address | pool [ pool-number ] }
undo remote address
View
Interface view
Default Level
2: System level
ip-address: IP address to be assigned to the peer device.
pool [ pool-number ]: Specifies the number of the address pool used for assigning an IP address to the peer. The pool-number argument ranges from 0 to 99 and defaults to 0.
Use the remote address command to set the IP address to be assigned to the peer device or specify the address pool used for assigning an IP address to the peer device.
Use undo remote address to cancel the IP address configured to be assigned to the peer device.
By default, an interface does not assign IP addresses to the peer device.
The remote address command can be used when the local device is configured with an IP address, while the peer has no IP address. To enable the peer device to accept the IP address assigned to it by the local device, you need to configure the ip address ppp-negotiate command on the peer device in addition to configuring the remote address command on the local device.
l The IP address assigned to the peer device by the local device is not mandatory on the peer device. That is, the peer device can still use a locally configured IP address even if the local device assigned one to it. To make the IP address assigned by the local device mandatory, you need to configure the ppp ipcp remote-address forced command.
l After you use the remote address command to assign an IP address for the peer device, you cannot configure the remote address/undo remote address command for the peer again unless the peer releases the assigned IP address. Therefore, you are recommended to shutdown the port to release the assigned IP address before you configure the remote address/undo remote address command for the peer. However, after you use the command to assign an IP address to the peer from the address pool of the specified domain through AAA authentication, you can configure the command for the peer again. In this case, the original assigned IP address can still work, and the newly assigned IP address is adopted when the original one is released or adopted by a new PPP access.
l This command takes effect until the next IPCP negotiation. To make the remote address command take effect, you are recommended to configure the remote address command before the ip address command.
Related commands: ip address ppp-negotiate, ppp ipcp remote-address forced.
# Set the IP address to be assigned to the peer device to 10.0.0.1 on interface Serial 2/0.
reset counters interface
reset counters interface [ interface-type [ interface-number ] ]
View
Default Level
2: System level
interface-type: Interface type.
interface-number: Interface number.
Use the reset counters interface command to clear the traffic statistics of an interface.
Before collecting traffic statistics within a specific period of time on an interface, you need to clear the existing statistics.
l If neither interface type nor interface number is specified, this command clears the statistics of all the interfaces.
l If only the interface type is specified, this command clears the statistics of the interfaces that are of the specified interface type.
l If both the interface type and interface number are specified, this command clears the statistics of the specified interface.
# Clear the statistics of interface MP-group3.
<Sysname> reset counters interface mp-group 3
# Clear the statistics of interface Virtual-template 10.
<Sysname> reset counters interface virtual-template 10
timer hold
timer hold seconds
undo timer hold
View
Interface view
Default Level
2: System level
seconds: Interval (in seconds) for sending keepalive packets, in the range 0 to 32767. A value of 0 disables keepalive packet sending.
Use the timer hold command to set the interval for sending keepalive packets.
Use the undo timer hold command to restore the default, or 10 seconds.
As on slow links, it takes long to transmit large packets (this may cause the sending and receiving of keepalive packet to be postponed) and a link is considered to be fail If an interface on one side receives no keepalive packet from the peer device for specific number of keepalive periods, set the interval for sending keepalive packets properly for slow links to prevent the links from being torn down by mistake.
On a PPP link, make sure the settings of the interval for sending keepalive packets on both sides are the same.
# Set the interval for sending keepalive packets to 20 seconds on interface Serial 2/0.
[Sysname-Serial2/0] timer hold 20
ppp mp lfi
ppp mp lfi
undo ppp mp lfi
View
Default Level
2: System level
None
Use the ppp mp lfi command to enable Link Fragmentation and Interleaving (LFI) on an interface.
Use the undo ppp mp lfi command to disable LFI.
By default, LFI is disabled.
# Enable LFI on Virtual-Template1 interface.
[Sysname-Virtual-Template1] ppp mp lfi
ppp mp lfi delay-per-frag
ppp mp lfi delay-per-frag time
undo ppp mp lfi delay-per-frag
View
Default Level
2: System level
time: Maximum delay of LFI fragment, in the range 1 to 1000 (in ms).
Use the ppp mp lfi delay-per-frag command to set the maximum delay for transmitting an LFI fragment.
Use the undo ppp mp lfi delay-per-frag command to restore the default, or 10 ms.
# Set the maximum delay for transmitting an LFI fragment to 20 ms on Virtual-Template1 interface.
display pppoe-server session
display pppoe-server session all
View
Default Level
1: Monitor level
all: Displays all the information about PPPoE sessions.
Use the display pppoe-server session command to display the information about PPPoE sessions on a device operating as a PPPoE server.
# Display all the information about PPPoE sessions (assuming that the current device operates as a PPPoE server).
<Sysname> display pppoe-server session all
Total PPPoE Session(s): 1
SID Intf State OIntf RemMAC LocMAC
2 Virtual-Template1:0 UP GigabitEthernet1/0 0050.ba22.7369 00e0.fc08.f4de
Table 2-1 Description on the fields of the display pppoe-server session all command
    Field  |
    Description  |
   SID  |
   PPPoE session identifier  |
   Intf  |
   Virtual-Template interface  |
   State  |
   PPPoE session state  |
   OIntf  |
   Corresponding Ethernet interface  |
   RemMAC  |
   Peer MAC address  |
   LocMAC  |
   Local MAC address  |
pppoe-server bind
pppoe-server bind virtual-template number
undo pppoe-server bind
View
Ethernet interface view
Default Level
2: System level
virtual template number: Specifies a virtual-template interface number, in the range 0 to 1023.
Use the pppoe-server bind command to enable PPPoE on an Ethernet interface and bind the Ethernet interface to a virtual-template interface.
Use the undo pppoe-server bind command to disable PPPoE on an Ethernet interface.
By default, PPPoE is disabled.
# Enable PPPoE on interface GigabitEthernet 1/0 and bind the Ethernet interface to Virtual-Template1.
[Sysname] interface gigabitethernet 1/0
[Sysname-GigabitEthernet1/0] pppoe-server bind virtual-template 1
undo pppoe-server log-information off
View
Default Level
2: System level
None
Use the pppoe-server log-information off command to disable PPP log displaying on a device operating as a PPPoE server.
Use the undo pppoe-server log-information off command to enable PPP log displaying on a device operating as a PPPoE server.
By default, PPP log displaying is enabled on a PPPoE server.
With PPP log displaying enabled, large amount of log information can affect device performance and can be a nuisance to user during configuration. You can disable PPP log displaying by using the pppoe-server log-information off command.
# Disable PPP log displaying.
[Sysname] pppoe-server log-information off
pppoe-server max-sessions local-mac number
undo pppoe-server max-sessions local-mac
View
Default Level
2: System level
number: Maximum number of sessions allowed with regard to the local MAC address, in the range 1 to 4069.
Use the pppoe-server max-sessions local-mac command to set the maximum number of PPPoE sessions allowed with regard to the local MAC address on a device operating as a PPPoE server.
Use the undo pppoe-server max-sessions local-mac command to restore the default.
By default, the maximum number of PPPoE sessions allowed with regard to the local MAC address is 100.
# Set the maximum number of PPPoE sessions allowed with regard to the local MAC address to 50 (assuming that the device operates as a PPPoE server).
[Sysname] pppoe-server max-sessions local-mac 50
pppoe-server max-sessions remote-mac number
undo pppoe-server max-sessions remote-mac
View
Default Level
2: System level
number: Maximum number of PPPoE sessions allowed by the entire system with regard to a peer MAC address (for centralized devices) or allowed by each I/O card with regard to a peer MAC address, in the range 1 to 4096.
Use the pppoe-server max-sessions remote-mac command to set the maximum number of PPPoE sessions allowed with regard to a peer MAC address.
Use the undo pppoe-server max-sessions remote-mac command to restore the default.
By default, the maximum number of PPPoE sessions allowed with regard to a peer MAC address is 100.
# Set the maximum number of PPPoE sessions allowed with regard to a peer MAC address to 50.
[Sysname] pppoe-server max-sessions remote-mac 50
pppoe-server max-sessions total number
undo pppoe-server max-sessions total
pppoe-server max-sessions slot slot-number total number
undo pppoe-server max-sessions slot slot-number
View
Default Level
2: System level
slot slot-number: Specifies a board by its slot number.
number: Maximum number of PPPoE sessions allowed, in the range 1 to 18000.
Use the pppoe-server max-sessions total command to set the maximum number of PPPoE sessions.
Use the undo pppoe-server max-sessions total command to restore the default.
By default, a maximum of 18000 PPPoE sessions are allowed.
# Set the maximum number of PPPoE sessions allowed to 3000 (assuming that the current device is a centralized device).
[Sysname] pppoe-server max-sessions total 3000
# Set the maximum number of PPPoE sessions supported on card 3 to 1500.
[Sysname] pppoe-server max-sessions slot 3 total 1500
reset pppoe-server
reset pppoe-server { all | interface interface-type interface-number | virtual-template number }
View
Default Level
2: System level
all: Terminates all the PPPoE sessions.
interface interface-type interface-number: Specifies a port by its type and number.
virtual-template number: Specifies a virtual template interface number, in the range 0 to 1023.
Use the reset pppoe-server command to terminate a PPPoE session on the server side.
This command can be used only on centralized devices.
# Terminate the session established based on Virtual-template 1 interface.
<Sysname> reset pppoe-server virtual-template 1
