- 01-Access Volume
- 01-CPOS Interface Commands
- 02-POS Interface Commands
- 03-Ethernet Interface Commands
- 04-WAN Interface Commands
- 05-Frame Relay Commands
- 06-HDLC Commands
- 07-PPP Commands
- 08-Logical Interface Commands
- 09-Modem Management Commands
- 10-ATM Interface Commands
- 11-ATM Commands
- 12-E-CPOS Interface Commands
- 13-VLAN Termination Commands
- 14-Port Mirroring Commands
04-WAN Interface Commands | 408.37 KB |
Table of Contents
1 WAN Interface Configuration Commands
Basic Serial Interface Configuration Commands
Basic CE1 Interface Configuration Commands
error-diffusion restraint config
error-diffusion restraint enable
Basic CT1 Interface Configuration Commands
E1-F Interface Configuration Commands
T1-F Interface Configuration Commands
Basic CE3 Interface Configuration Commands
Basic CT3 Interface Configuration Commands
baudrate
baudrate baudrate
undo baudrate
View
Serial interface view
Default Level
2: System level
baudrate: Baud rate (in bps) to be set for a serial interface.
Use the baudrate command to set the baud rate for a serial interface.
Use the undo baudrate command to restore the default.
By default, the baud rate is 64,000 bps on a synchronous serial interface.
The following are the baud rates available with synchronous serial interfaces:
1,200 bps, 2,400 bps, 4,800 bps, 9,600 bps, 19,200 bps, 38,400 bps, 56,000 bps, 57,600 bps, 64,000 bps, 72,000 bps, 115,200 bps, 128,000 bps, 192,000 bps, 256,000 bps, 384,000 bps, 512,000 bps, 1,024,000 bps, 2,048,000 bps, and 4,096,000 bps.
The baud rate range available with synchronous serial interfaces depends on the applied physical electric specifications.
l For V.24 DTE/DCE, the baud rate available ranges from 1,200 bps to 64,000 bps.
l For V.35 DCE/DCE, X.21 DTE/DCE, EIA/TIA-449 DTE/DCE, and EIA-530 DTE/DCE, the baud rate available ranges from 1,200 bps to 4,096,000 bps.
After a synchronous/asynchronous serial interface makes the synchronous/asynchronous switchover, the baud rate of the interface resumes the default baud rate in the new operating mode.
l Take the physical electric specifications of the cable into consideration when setting the baud rate for a serial interface.
l The baud rate adopted by a DCE-DTE pair is determined by the DCE.
# Set the baud rate of synchronous serial interface 1/0 at DCE side to 115200 bps.
[Sysname] interface serial 1/0
[Sysname-Serial1/0] baudrate 115200
clock
clock { dteclk1 | dteclk2 | dteclk3 | dteclk4 | dteclkauto }
undo clock
View
Synchronous serial interface view
Default Level
2: System level
dteclk1: Sets the interface clock selection mode to DTE clock option 1.
dteclk2: Sets the interface clock selection mode to DTE clock option 2.
dteclk3: Sets the interface clock selection mode to DTE clock option 3.
dteclk4: Sets the interface clock selection mode to DTE clock option 4.
dteclkauto: Sets the interface clock selection mode to DTE autonegotiation.
Use the clock command to set clock selection mode for the synchronous serial interface.
Use the undo clock command to restore the default.
By default, the DTE-side clock on synchronous serial interfaces is DTE clock option 1 (dteclk1).
This command does not take effect when X.21 DTE cables are used. The DTE-side clock on synchronous serial interfaces is DTE clock option 3 (dteclk3).
A synchronous serial interface can operate as DCE or DTE.
l As DCE, the interface provides DCEclk clock to the DTE.
l As DTE, the interface accepts the clock provided by the DCE. As transmitting and receiving clocks of synchronization devices are independent, the receiving clock of a DTE device can be either the transmitting or receiving clock of the DCE device, so is the transmitting clock. Therefore, four clock options are available for a DTE device.
See the following figure:
Figure 1-1 Select a clock for a synchronous serial interface
In Figure 1-1, “TxClk” represents transmitting clock and “RxClk” receiving clock.
The following table gives the four clock selection options.
Table 1-1 Clock options available for a synchronous serial interface working as DTE
Clock selection option |
DTEclk1 |
TxClk = TxClk, RxClk = RxClk |
DTEclk2 |
TxClk = TxClk, RxClk = TxClk |
DTEclk3 |
TxClk = RxClk, RxClk = TxClk |
DTEclk4 |
TxClk = RxClk, RxClk = RxClk |
In the table, the clock ahead of the equal sign (=) is the DTE clock and the one behind is the DCE clock.
# Set the synchronous serial interface working as DTE to use the clock selection option dteclk2.
[Sysname] interface serial 2/0
[Sysname-Serial2/0] clock dteclk2
code
code { nrz | nrzi }
undo code
View
Default Level
2: System level
nrz: Specifies the encoding format as non-return-to-zero (NRZ).
nrzi: Specifies the encoding format as non-return-to-zero-inverse (NRZI).
Use the code command to set the digital signal coding format on the synchronous serial interface.
Use the undo code command to restore the default, that is, NRZ.
# Set the digital signal coding format to NRZI on synchronous serial interface 1/0.
[Sysname-Serial2/0] code nrzi
crc
crc { 16 | 32 | none }
undo crc
View
Default Level
2: System level
16: Specifies 16-bit CRC.
32: Specifies 32-bit CRC.
none: Disables CRC.
Use the crc command to set the CRC mode.
Use the undo crc command to restore the default.
By default, 16-bit CRC is adopted.
# Configure to adopt 32-bit CRC.
[Sysname-Serial2/0] crc 32
description
View
Default Level
2: System level
text: interface description, which is a string of 1 to 80 characters.
Use the description command to configure the interface description.
Use the undo description command to restore the default.
By default, the description of an interface is its interface name followed by the word interface, Serial2/0 Interface for example.
# Configure the description of Serial2/0 as router-interface.
[Sysname-Serial2/0] description router-interface
detect
detect { dcd | dsr-dtr }
undo detect { dcd | dsr-dtr }
View
Default Level
2: System level
dsr-dtr: Detects DSR (data set ready) and DTR (data terminal ready) signals of DSU/CSU (data service unit/channel service unit).
dcd: Detects the DCD (data carrier detect) signal of the DSU/CSU on the serial interface.
Use the detect command to enable data carrier detection as well as level detection on the serial interface.
Use the undo detect command to disable data carrier detection as well as level detection on the serial interface.
By default, data carrier and level detection is enabled on serial interfaces.
When determining whether a synchronous serial interface is up or down, the system by default detects the DSR signal, DCD signal, and presence of cable connection. Only when the three signals are all valid will the interface be regarded up. If level detection is disabled, the system considers that the interface is up with both DTR and DSR being up after detecting the cable connection.
# Enable data carrier detection on synchronous serial interface 2/0.
[Sysname-Serial2/0] detect dcd
display interface serial
display interface serial interface-number
View
Default Level
1: Monitor level
interface-number: Serial interface number.
Use the display interface serial command to display information about a serial interface.
# Display information about serial interface Serial 7/1.
<Sysname> display interface serial 7/1
Serial7/1 current state: UP
Description: Serial7/1 Interface
The Maximum Transmit Unit is 1500, Hold timer is 10(sec)
Internet Address is 9.9.9.6/24 Primary
Link layer protocol is PPP
LCP opened, IPCP opened
Output queue : (Urgent queuing : Size/Length/Discards) 0/100/0
Output queue : (Protocol queuing : Size/Length/Discards) 0/500/0
Output queue : (FIFO queuing : Size/Length/Discards) 0/75/0
Physical layer is synchronous, Baudrate is 64000 bps
Interface is DCE, Cable type is V35, Clock mode is DCECLK
Last 70 seconds input rate 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec
Last 70 seconds output rate 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec
Input: 6668 packets, 80414 bytes, 0 no buffers
0 broadcasts, 0 multicasts
0 errors, 0 runts, 0 giants
0 CRC, 0 align errors, 0 overruns
0 dribbles, 0 aborts
0 frame errors
Output:6670 packets, 80446 bytes
0 errors, 0 underruns, 0 collisions
0 deferred
DCD=UP DTR=UP DSR=UP RTS=UP CTS=UP
Figure 1-2 display interface serial command output description
Serial7/1 current state |
Current physical state of the serial interface |
Line protocol current state |
Link protocol state of the serial interface |
Description of the serial interface |
The Maximum Transmit Unit is 1500, Hold timer is 10(sec) |
The default maximum transmit unit (MTU) on the serial interface is 1500 bytes, which indicates that packets larger than 1500 bytes will be fragmented before being sent. But if fragmentation is not allowed, these packets will be dropped. Hold timer refers to the lifetime of a packet in a network. It is the maximum amount of time a packet can exist in the network before being dropped. The hold timer of packets on the serial interface is set to 10 seconds. |
Internet Address is 9.9.9.6/24 Primary |
IP address of the serial interface |
Link layer protocol is PPP |
Link layer protocol of the serial interface |
LCP opened, IPCP opened |
A PPP connection is established successfully. |
Output queue : (Urgent queuing : Size/Length/Discards) 0/100/0 |
Urgent queuing: current number of packets in the queue, maximum number of packets that can stay in the queue, and number of dropped packets. Link layer protocol packets, such as PPP negotiation packets and keepalive packets enter this queue. |
Output queue : (Protocol queuing : Size/Length/Discards) 0/500/0 |
Protocol queuing: current number of packets in the queue, maximum number of packets that can stay in the queue, and number of dropped packets. IPv6 packets enter this queue. |
Output queue : (FIFO queuing : Size/Length/Discards) 0/75/0 |
FIFO queuing: current number of packets in the first-in first-out (FIFO) queue, maximum number of packets that can stay in the queue, and number of dropped packets. |
Physical layer is synchronous, Baudrate is 64000 bps |
Physical layer status and bandwidth of the serial interface |
Interface is DCE, Cable type is V35, Clock mode is DCECLK |
Synchronizes the clock mode on the DCE side of the serial interface. |
Last clearing of counters: Never |
The last time the statistics on the serial interface is cleared. |
Last 70 seconds input rate 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec |
Average input rate in the last 70 seconds: bytes/sec indicates bytes per second, bits/sec indicates bits per second, and packets/sec indicates packets per second. |
Last 70 seconds output rate 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec |
Average output rate in the last 70 seconds: bytes/sec indicates bytes per second, bits/sec indicates bits per second, and packets/sec indicates packets per second. |
Input: 6668 packets, 80414 bytes 0 broadcasts, 0 multicasts 0 errors, 0 runts, 0 giants 0 CRC, 0 align errors, 0 overruns 0 dribbles, 0 aborts, 0 no buffers 0 frame errors |
Input statistics on the serial interface: l broadcasts: Number of received broadcast packets. l multicasts: Number of received multicast packets. l errors: Number of error packets detected on the physical layer. l runts: Number of undersized packets received on the serial interface. l giants: Number of oversized packets received on the serial interface. l CRC: Number of normal-sized packets with CRC errors. l align errors: Number of align error packets. l overruns: Number of packets that the serial interface is unable to process because the port is overrun. l aborts: Number of packets that are not received successfully. l no buffers: Number of packets that are discarded because the buffer runs out. l frame errors: Number of packets with frame errors. |
Output:6670 packets, 80446 bytes 0 errors, 0 underruns, 0 collisions 0 deferred |
Output statistics on the serial interface: l errors: Number of error packets detected on the physical layer. l underruns: Number of packets that fail to be forwarded because the serial interface reads from memory slower than it forwards packets. l collisions: Number of packets with collisions detected. l deferred: Number of deferred or timeout packets. |
DCD=UP DTR=UP DSR=UP RTS=UP CTS=UP |
Data Set Ready (DSR), Data Terminal Ready (DTR), and Data Carrier Detect (DCD) signals are up. For details about DSR, DTR, and DCD, refer to the detect command. Request to Send (RST) and Clear to Send (CTS) signals are also up. |
The output of the display interface serial command varies with your device models and card types.
idle-mark
idle-mark
undo idle-mark
View
Default Level
2: System level
None
Use the idle-mark command to set the line idle code of the synchronous serial interface to 0xFF.
Use the undo idle-mark command to restore the default, that is, 0x7E.
In most cases, a synchronous serial interface uses 0x7E to identify the idle state of the line. You may need to set the line idle code to 0xFF however to interoperate with devices that use 0xFF (high level of all ones) as line idle code.
# Set the line idle code of synchronous serial interface 2/0 to 0xFF.
[Sysname-Serial2/0] idle-mark
invert receive-clock
undo invert receive-clock
View
Default Level
2: System level
None
Use the invert receive-clock command to invert the receive-clock signal on the DTE-side synchronous serial interface.
Use the undo invert receive-clock command to restore the default.
By default, receive-clock signal inversion is disabled on DTE-side synchronous serial interfaces.
Sometimes, you may need to invert the receive-clock signal on a DTE-side serial interface to eliminate the half clock-period delay on the line. This command is necessary only for some special DCE devices. In common applications, clock must not be inverted.
Related commands: invert transmit-clock, clock.
# Invert the receive-clock on DTE-side synchronous serial interface 2/0.
[Sysname-Serial2/0] invert receive-clock
undo invert transmit-clock
View
Default Level
2: System level
None
Use the invert transmit-clock command to invert the transmit-clock signal on the DTE-side synchronous serial interface.
Use the undo invert transmit-clock command to restore the default.
By default, transmit-clock signal inversion is disabled on DTE-side synchronous serial interfaces.
Related commands: invert receive-clock, clock.
# Invert the transmit-clock on DTE-side synchronous serial interface 2/0.
[Sysname-Serial2/0] invert transmit-clock
loopback
loopback
undo loopback
View
Synchronous serial interface view, AUX interface view
Default Level
2: System level
None
Use the loopback command to enable internal/external loopback on the serial interface.
Use the undo loopback command to restore the default.
By default, loopback is disabled.
Loopback is intended for test use. Disable it otherwise.
# Enable internal/external loopback on interface Serial 2/0.
[Sysname-Serial2/0] loopback
mtu
mtu size
undo mtu
View
Default Level
2: System level
size: Maximum transmission unit (MTU) to be set for a serial interface, in the range 128 to 1,500 (in bytes).
Use the mtu command to set the MTU for an interface.
Use the undo mtu command to restore the default.
By default, the MTU of an interface is 1,500 bytes.
Due to the length of QoS queue, a packet may be discarded if the MTU is relatively small and the packet is segmented into too many fragments. You can increase the QoS queue length to avoid this situation. To do so, use the qos fifo queue-length command in interface view. For details, refer to the QoS Configuration in QoS Volume.
The MTU setting can affect IP packets assembly and fragmentation on the interface.
For your MTU setting to take effect, re-enable the interface with the shutdown command and the undo shutdown command.
# Set the MTU of Serial 2/0 to 1200 bytes.
[Sysname-Serial2/0] mtu 1200
phy-mru
phy-mru mrusize
undo phy-mru
View
Default Level
2: System level
mrusize: Maximum receive unit (MRU) to be set, in the range 4 to 1700 (in bytes).
Use the phy-mru command to set the MRU for an interface.
Use the undo phy-mru command to restore the default.
By default, the MRU of an interface is 1700 bytes.
# Set the MRU of AUX 0 to 1500 bytes.
[Sysname] interface aux 0
[Sysname-Aux0] phy-mru 1500
reverse-rts
reverse-rts
undo reverse-rts
View
Default Level
2: System level
None
Use the reverse-rts command to reverse RTS signal for debugging purpose.
Use the undo reverse-rts command to restore the default.
By default, RTS signal reverse is disabled.
This command is used in hardware flow control where the remote is not allowed to send data when the local end is doing that.
# Reverse RTS signal.
[Sysname-Serial2/0] reverse-rts
shutdown
shutdown
View
Default Level
2: System level
None
Use the shutdown command to disable an interface.
Use the undo shutdown command to enable an interface.
By default, an interface is enabled.
In certain circumstances, modification to the interface parameters does not immediately take effect, and therefore, you need to re-enable the interface to make the modification work.
# Disable Serial2/0.
[Sysname-Serial2/0] shutdown
sub-interface rate-statistic
undo sub-interface rate-statistic
View
Default Level
2: System level
None
Use the sub-interface rate-statistic command to enable the collecting of rate statistics of the subinterfaces on a serial interface.
Use the undo sub-interface rate-statistic command to restore the default.
By default, the collecting of rate statistics of the subinterfaces on a serial interface is disabled.
l Because this feature may take a large amount of the system resource, use this command with caution.
l All interfaces that support subinterfaces support this feature.
# Enable the collecting of rate statistics of the subinterfaces on Serial 2/0.
[Sysname-Serial2/0] sub-interface rate-statistic
Warning: This configuration may make a negative effect on the performance. Are you sure to continue? [Y/N]: Y
[Sysname-Serial2/0]
timer hold
timer hold seconds
undo timer hold
View
Default Level
2: System level
seconds: Interval (in seconds) for the interface to send keepalive packets, in the range 0 to 32,767.
Use the timer hold command to set the link state polling interval, that is, the interval for the interface to send keepalive packets.
Use the undo timer hold command to restore the default.
By default, the polling interval is 10 seconds.
# Set the polling interval to 20 seconds for interface Serial 2/0.
[Sysname-Serial2/0] timer hold 20
virtualbaudrate
virtualbaudrate virtualbaudrate
undo virtualbaudrate
View
Default Level
2: System level
virtualbaudrate: Baud rate (in bps) to be set, which must be consistent with the one configured at the DCE side. It can be 1,200, 2,400, 4,800, 9,600, 19,200, 38,400, 56,000, 57,600, 64,000, 72,000, 115,200, 128,000, 192,000, 256,000, 384,000, 512,000, 768,000, 1024,000, 2,048,000, or 4,096,000.
Use the virtualbaudrate command to set a virtual baud rate for the DTE interface.
Use the undo virtualbaudrate command to remove the specified virtual baud rate.
When working as DTE, the serial interface determines its baud rate through negotiation with the DCE side. The virtualbaudrate command, however, allows you to configure DTE-side baudrate manually, but the configured value must be the same as the one set at the DCE side.
After executing the virtualbaudrate command, you need to shut down and then bring up the interface (using the shutdown command and the undo shutdown command) for the new setting to take effect.
l Configure the baudrate command at DCE side and the virtualbaudrate command at DTE side (only when the interface is operating in synchronous mode). Avoid configuring the two commands at the same end of a link.
l At DCE side, the display interface command displays the baud rate of the interface; whereas at the DTE end, the command displays the virtual baud rate of the interface.
Related commands: baudrate.
# Set the virtual baudrate of DTE interface Serial 2/0 to 19200 bps.
[Sysname-Serial2/0] virtualbaudrate 19200
alarm
alarm detect rai
undo alarm detect rai
View
CE1 interface view
Default Level
2: System level
detect: Enables periodical detection on the interface.
rai: Remote Alarm Indication (RAI).
Use the alarm command to enable RAI detection on the interface.
Use the undo alarm command to disable RAI detection on the interface.
By default, RAI detection is enabled on an interface.
This command is applicable when the interface operates in CE1 mode.
# Disable RAI detection on CE1 interface E1 2/0.
[Sysname] controller e1 2/0
[Sysname-E1 2/0] undo alarm detect rai
cable
cable { long | short }
undo cable
View
CE1 interface view
Default Level
2: System level
long: Indicates that the attenuation of receiver is –43 dB.
short: Indicates that the attenuation of receiver is –10 dB.
Use the cable command to set the cable type for a CE1 interface.
Use the undo cable command to restore the default.
By default, the long keyword applies.
# Set the cable length matching CE1 interface E1 2/0 to short.
[Sysname-E1 2/0] cable short
channel-set (CE1 interface)
channel-set set-number timeslot-list list
undo channel-set [ set-number ]
View
CE1 interface view
Default Level
2: System level
set-number: The number of the channel set formed by bundling timeslots on the interface, in the range 0 to 30.
timeslot-list list: Specifies the timeslots to be bundled. The list argument can contain multiple timeslot numbers, each of which ranges from 1 to 31. You can specify a single timeslot by specifying a timeslot number, a range of timeslots by providing this argument in the form of { number1-number2 }, or multiple timeslots by providing this argument in the form of { number1, number2-number3 }.
Use the channel-set command to bundle timeslots on the CE1 interface into a channel-set.
Use the undo channel-set command to remove bundled timeslots.
By default, no timeslots are bundled into channel sets.
A CE1 interface in CE1 mode is physically divided into 32 timeslots numbered 0 through 31.
In actual applications, all the timeslots except timeslot 0 can be bundled into multiple channel sets. For each channel set, the system automatically creates a serial interface which is logically equivalent to a synchronous serial interface.
The serial interface is numbered in the form of serial interface-number:set-number, where, interface-number is the number of the CE1 interface, and set-number is the number of the channel set.
# Bundle timeslots 1, 2, 5, 10 through 15, and 18 on CE1 interface E1 2/0 into channel set 0.
[Sysname-E1 2/0] channel-set 0 timeslot-list 1,2,5,10-15,18
# Make the same configuration on the CE1 interface on the remote router.
clock (CE1 interface)
clock { master | slave }
undo clock
View
CE1 interface view
Default Level
2: System level
master: Adopts the internal clock as the clock source.
slave: Adopts the line clock as the clock source.
Use the clock command to configure clock source for the CE1 interface.
Use the undo clock command to restore the default clock source, that is, line clock.
When the CE1 interface is working as DCE, choose the internal clock (master) for it. When it is working as DTE, choose the line clock for it.
# Use the internal clock as the clock source on CE1 interface E1 2/0.
[Sysname-E1 2/0] clock master
clock-change auto
clock-change auto
undo clock-change auto
View
CE1 interface view
Default Level
2: System level
auto: Enables automatic clock mode change for the interface.
Use the clock-change auto command to enable the automatic clock mode change function on the interface, that is, configure the interface that uses the slave clock mode to switch to the master clock mode automatically when receiving an AIS/LOS alarm. After the alarm is cleared, the interface automatically switches back to the user-configured clock mode.
Use the undo clock-change auto command to disable the automatic clock mode change function. If the interface has already switched its clock mode, this command restores the user-configured clock mode for the interface.
By default, automatic clock mode change is disabled. This command is applicable to interfaces working in CE1 mode.
# Disable automatic clock mode change for CE1 interface E1 2/0.
[Sysname-E1 2/0] undo clock-change auto
code (CEI interface)
code { ami | hdb3 }
undo code
View
CE1 interface view
Default Level
2: System level
ami: Adopts alternate mark inversion (AMI) line code format.
hdb3: Adopts high density bipolar 3 (HDB3) line code format.
Use the code command to set the line code format for the CE1 interface.
Use the undo code command to restore the default, that is, HDB3.
Keep the line code format of the interface in consistency with that used by the remote device.
# Set the line code format of interface E1 2/0 to AMI.
[Sysname-E1 2/0] code ami
controller e1
controller e1 number
View
Default Level
2: System level
number: CE1 interface number.
Use the controller e1 command to enter CE1 interface view.
# Enter E1 2/0 interface view.
[Sysname-E1 2/0]
crc
undo crc
View
Default Level
2: System level
16: Adopts 16-bit cyclic redundancy check (CRC).
32: Adopts 32-bit CRC.
none: Disables CRC.
Use the crc command to configure CRC mode for a synchronous serial interface formed on a CE1 interface.
Use the undo crc command to restore the default, that is, 16-bit CRC.
# Apply 32-bit CRC to a serial interface formed on interface CE1 interface 2/0 in unchannelized mode.
[Sysname-E1 2/0] using e1
[Sysname-E1 2/0] quit
[Sysname] interface serial 2/0:0
[Sysname-Serial2/0:0] crc 32
data-coding
data-coding { inverted | normal }
undo data-coding
View
CE1 interface view
Default Level
2: System level
inverted: Enables user data inversion.
normal: Disables user data inversion.
Use the data-coding inverted command to enable user data inversion on the CE1 interface.
Use the data-coding normal command to disable user data inversion on the CE1 interface.
Use the undo data-coding command to restore the default.
By default, data inversion is disabled.
To prevent 7e in valid data from being taken for stuffing characters, HDLC inserts a zero after every five ones in the data stream. Then, HDLC inverts every one bit into a zero and every zero bit into a one. This ensures at least one out of every eight bits is a one. When AMI encoding is adopted on an E1 interface, the use of data inversion can eliminate the presence of multiple consecutive zeros.
On the CE1 interfaces at two ends of an E1 line, the same data inversion setting must be adopted.
# Enable user data inversion on CE1 interface E1 2/0.
[Sysname-E1 2/0] data-coding inverted
description
View
CE1 interface view
Default Level
2: System level
Use the description command to configure the description for a CE1 interface.
By default, the description of a CE1 interface is its interface name followed by the word interface, E1 2/0 Interface, for example.
# Configure the description of E1 2/0 as E1-interface.
[Sysname-E1 2/0] description E1-interface
detect-ais
detect-ais
undo detect-ais
View
CE1 interface view
Default Level
2: System level
None
Use the detect-ais command to enable AIS (alarm indication signal) test on an interface.
Use the undo detect-ais command to disable AIS test.
By default, AIS test is performed.
# Enable AIS test on E1 2/0 interface.
[Sysname-E1 2/0] detect-ais
display controller e1
display controller e1 [ interface-number ]
View
Default Level
1: Monitor level
interface-number: Interface number. In conjunction with the e1 keyword, it specifies a CE1 interface.
Use the display controller e1 command to display information about one or all the CE1 interfaces.
The displayed information includes:
l Physical state of interface
l Clock mode (source) of interface
l Frame check mode of interface
l Line code format of interface
# Display information about interface E1 2/0.
<Sysname> display controller e1 2/0
E1 2/0 current state: UP
Description : E1 2/0 Interface
Basic Configuration:
Work mode is E1 framed, Cable type is 75 Ohm unbalanced.
Frame-format is no-crc4.
Line code is hdb3, Source clock is slave.
Idle code is 7e, Itf type is 7e, Itf number is 4.
Loop back is not set.
Alarm State:
Receiver alarm state is None.
Historical Statistics:
Data in current interval (150 seconds elapsed):
0 Loss Frame Alignment Secs, 0 Framing Error Secs,
0 CRC Error Secs, 0 Alarm Indication Secs, 0 Loss-of-signals Secs,
0 Code Violations Secs, 0 Slip Secs, 0 E-Bit error Secs.
Table 1-2 Description on the fields of the command
E1 2/0 current state: UP |
State of the interface |
Description : E1 2/0 Interface |
Description of the interface |
Work mode |
Work mode of the interface, which can be E1 or CE1. |
Cable type |
Cable type of the interface |
Frame-format |
Frame format of the interface, which can be CRC4 or non-CRC4. |
Source Clock |
Work mode of the source clock of the interface, which can be master or slave. |
Line Code |
Line code, which can be AMI or HDB3. |
Idle Code |
Idle code, which can be 0x7E or 0xFF. |
Itf type |
Interframe filling tag, which can be 0x7E or 0xFF. |
Itf number |
Number of interframe filling tags between two successive frames. |
Loopback |
Loopback state |
Alarm State |
Alarm state |
Historical Statistics |
Statistics on the interface |
Last clearing of counters |
Indicates whether or not the counters are cleared periodically |
Data in current interval (150 seconds elapsed): 0 Loss Frame Alignment Secs, 0 Framing Error Secs, 0 CRC Error Secs, 0 Alarm Indication Secs, 0 Loss-of-signals Secs, 0 Code Violations Secs, 0 Slip Secs, 0 E-Bit error Secs |
Statistics on the errors during the current interval |
error-diffusion restraint config detect-timer renew-timer threshold
undo error-diffusion restraint config
View
Default Level
2: System level
detect-timer: Period to check error packets, in the range 30 to 600 (in seconds).
renew-timer: Period after which an interface resumes its function, in the range 120 to 2,400 (in seconds).
threshold: Packet error rate, in the range 5 to 100 (in percentage).
Use the error-diffusion restraint config command to set the three parameters in error packets diffusion restraint.
Use the undo error-diffusion restraint config command to restore the default values of the three parameters.
The default value for detect-timer is 30 seconds, the default value for renew-timer is 600 seconds, and the default value for threshold is 20%.
The value of renew-timer must be at least four times of detect-timer. If the number of error packets received during detect-timer is less than 100, they will be ignored by the system.
These two commands apply to CT1 and CE1 interfaces only.
# Set the detect-timer to 100 seconds, renew-timer to 2400 seconds, and threshold to 15%.
[Sysname] error-diffusion restraint cofing 100 2400 15
undo error-diffusion restraint enable
View
Default Level
2: System level
None
Use the error-diffusion restraint enable command to enable error packets diffusion restraint.
Use the undo error-diffusion restraint enable command to disable this function.
By default, error packets diffusion restraint is enabled.
# Enable error packets diffusion restraint.
[Sysname] error-diffusion restraint enable
frame-format (CE1 interface)
frame-format { crc4 | no-crc4 }
undo frame-format
View
CE1 interface view
Default Level
2: System level
crc4: Sets framing format to CRC4.
no-crc4: Sets framing format to no-CRC4.
Use the frame-format command to set the framing format on the CE1 interface.
Use the undo frame-format command to restore the default, that is, no-CRC4.
A CE1 interface in CE1 mode supports both CRC4 and no-CRC4 framing formats, where CRC4 supports four-bit CRC on physical frames while no-CRC4 does not.
# Set the framing format on interface E1 2/0 to CRC4.
[Sysname-E1 2/0] frame-format crc4
idlecode (CE1 interface)
idlecode { 7e | ff }
undo idlecode
View
CE1 interface view
Default Level
2: System level
7e: Sets line idle code to 0x7e.
ff: Sets line idle code to 0xff.
Use the idlecode command to set the line idle code on the CE1 interface. Two types of line idle code are available: 0x7E and 0xFF.
Use the undo idlecode command to restore the default, that is, 0x7E.
The line idle code is sent in the timeslots that are not bundled into logical channels.
# Set the line idle code to 0x7E on CE1 interface E1 2/0.
[Sysname-E1 2/0] idlecode 7e
itf (CE1 interface)
itf { number number | type { 7e | ff } }
undo itf { number | type }
View
CE1 interface view
Default Level
2: System level
number number: Sets the number of interframe filling tags, which ranges from 0 to 14.
type { 7e | ff }: Sets the type of interframe filling tag to 0x7E by specifying the 7e argument or to 0xFF by specifying the ff keyword.
Use the itf command to set the type of and the number of interframe filling tags on the CE1 interface. Two types of interframe filling tag are available: 0x7E and 0xFF.
Use the undo itf command to restore the default.
By default, interframe filling tag is 0x7E and the number of interframe filling tags is 4.
Interframe filling tags are sent when no service data is sent on the timeslots bundled into logical channels on the CE1 interface.
# Set the type of interframe filling tag to 0xFF on CE1 interface E1 2/0.
[Sysname-E1 2/0] itf type ff
# Set the number of interframe filling tags to five on CE1 interface E1 2/0.
[Sysname-E1 2/0] itf number 5
loopback (CE1 interface)
loopback { local | payload | remote }
undo loopback
View
CE1 interface view
Default Level
2: System level
local: Sets the interface in local loopback mode.
remote: Sets the interface in external loopback mode.
payload: Sets the interface in external payload loopback mode.
Use the loopback command to enable loopback and set the loopback mode.
Loopback is intended for checking the condition of interfaces or cables. Disable it otherwise.
You can bundle timeslots on the CE1 interface to form a serial interface and encapsulate it with PPP. After you enable loopback on this serial interface, it is normal that the state of the link layer protocol is reported down.
# Set interface E1 2/0 in internal loopback mode.
[Sysname-E1 2/0] loopback local
reset counters controller e1
reset counters controller e1 interface-number
View
Default Level
2: System level
Use the reset counters controller e1 command to clear the counter for a CE1 interface.
To display the information about the counter, use the display controller e1 command.
# Clear the counter for CE1 interface E1 2/0.
<Sysname> reset counters controller e1 2/0
shutdown
shutdown
View
CE1 interface view
Default Level
2: System level
None
Use the shutdown command to disable a CE1 interface.
Use the undo shutdown command to enable a CE1 interface.
By default, a CE1 interface is enabled.
# Disable E1 2/0.
[Sysname-E1 2/0] shutdown
using (CE1 interface)
using { ce1 | e1 }
undo using
View
CE1 interface view
Default Level
2: System level
ce1: Sets the interface to operate in CE1 mode.
e1: Sets the interface to operate in E1 mode.
Use the using command to configure the operating mode of the CE1 interface.
Use the undo using command to restore the default, that is, CE1 mode.
A CE1 interface can work in either E1 mode (non-channelized mode) or CE1 mode (channelized mode).
In E1 mode, the interface equals a 2.048 Mbps interface without timeslot division. Its logical features are the same like those of a synchronous serial interface. In CE1 mode, it is physically divided into 32 timeslots numbered 0 through 31, where timeslot 0 is used for FSC.
After you set the CE1 interface to work in E1 mode, the system automatically creates a serial interface numbered serial interface-number:0, where interface-number represents the number of the CE1 interface.
# Set CE1 interface E1 2/0 to work in E1 mode.
alarm (CT1 interface)
alarm detect rai
View
CT1 interface view
Default Level
2: System level
This command is applicable when the framing format used on the interface is ESF.
# Disable RAI detection on CT1 interface T1 2/0.
[Sysname] controller t1 2/0
[Sysname-T1 2/0] undo alarm detect rai
alarm-threshold
alarm-threshold { ais { level-1 | level-2 } | lfa { level-1 | level-2 | level-3 | level-4 } | los { pulse-detection | pulse-recovery } value }
undo alarm-threshold { ais | lfa | los { pulse-detection | pulse-recovery } }
View
CT1 interface view
Default Level
2: System level
ais: Sets the alarm threshold of alarm indication signal (AIS), which can be level-1 and level-2.
l The level-1 keyword specifies to generate an AIS alarm when the number of 0s in the bit stream of an SF or ESF frame is less than or equal to 2.
l The level-2 keyword specifies to generate an AIS alarm when the number of 0s is less than or equal to 3 in the bit stream of an SF frame or less than or equal to 5 in the bit stream of an ESP frame.
By default, level-1 AIS alarm threshold applies.
lfa: Sets the loss of frame align (LFA) alarm threshold, which can be level-1, level-2, level-3, and level-4.
l The level-1 keyword specifies to generate an LFA alarm when two of four frame alignment bits are lost.
l The level-2 keyword specifies to generate an LFA alarm when two of five frame alignment bits are lost.
l The level-3 keyword specifies to generate an LFA alarm when two of six frame alignment bits are lost.
l The level-4 keyword applies only to ESF frames. It specifies to generate an LFA alarm when errors are detected in four consecutive ESF frames.
By default, level-1 LFA alarm threshold applies.
los: Sets a loss of signal (LOS) alarm threshold, which can be pulse-detection (for the pulse detection duration threshold with LOS) and pulse-recovery (for the pulse threshold with LOS).
The threshold of pulse-detection, in units of pulse intervals, ranges from 16 to 4,096 and defaults to 176.
The threshold of pulse-recovery, ranges from 1 to 256 and defaults to 22.
If the number of the pulses detected during the total length of the specified pulse detection intervals is smaller than the pulse-recovery threshold, a LOS alarm occurs. For example, if the two thresholds take their defaults, a LOS alarm is created if the number of pulses detected within 176 pulse intervals is less than 22.
Use the alarm-threshold command to set LOS, AIS, or LFA alarm thresholds on the CT1 interface.
Use the undo alarm-threshold command to restore the defaults.
# Set the number of detection intervals to 300 for the pulse detection duration threshold.
[Sysname-T1 2/0] alarm-threshold los pulse-detection 300
bert (CT1 interface)
bert pattern { 2^15 | 2^20 } time minutes [ unframed ]
undo bert
View
CT1 interface view
Default Level
2: System level
pattern: Sets a bit error rate test (BERT) pattern, which could be 2^15 or 2^20.
2^15: Two to the fifteenth power, length of transmitted BERT pattern in bits.
2^20: Two to the twentieth power, length of transmitted BERT pattern in bits.
time minutes: Sets the duration (in minutes) of a BERT test. The minutes argument ranges from 1 to 1440.
unframed: Sets the test pattern to cover the overhead bits of the frame.
Use the bert command to start a BERT test on a CT1 interface.
Use the undo bert command to stop the BERT test running on the CT1 interface.
By default, no BERT test is performed.
ITU O.151, ITU O.153, and ANSI T1.403-1999 define many BERT patterns, among which, the CT1 interface supports only 2^15 and 2^20 at present.
When running a BERT test, the local end sends out a pattern, which is to be looped over somewhere on the line and back to the local end. The local end then checks the received pattern for bit error rate, and by so doing helps you identify the condition of the line. To this end, you must configure loopback to allow the transmitted pattern to loop back from somewhere on the line, for example, from the far-end interface by placing the interface in a far-end loopback.
You may view the state and result of the BERT test with the display controller t1 command.
# Run a 10-minute 2^20 BERT test on CT1 interface t1 2/0.
[Sysname-T1 2/0] bert pattern 2^20 time 10
cable (CT1 interface)
cable { long { 0db | -7.5db | -15db | -22.5db } | short { 133ft | 266ft | 399ft | 533ft | 655ft } }
undo cable
View
CT1 interface view
Default Level
2: System level
long: Matches 199.6-meter (655-feet) and longer cable length. The options for this parameter include 0db, -7.5db, -15db and -22.5db. The attenuation parameter is selected depending on the signal quality received at the receiving end. In this case, no external CSU is needed.
short: Matches a cable length shorter than 199.6 meters (655 feet). The options for this parameter include 133ft, 266ft, 399ft, 533ft and 655ft. The length parameter is selected depending on the actual transmission distance.
Use the cable command to set the cable attenuation and length on the CT1 interface.
Use the undo cable command to restore the default, that is, long 0db.
You may use this command to adapt signal waveform to different transmission conditions such as the quality of the signal received by the receiver. If the signal quality is good, you can use the default setting. In this case, the CT1 interface does not need an external CSU device.
# Set the cable length to 40.5 meter (133 feet) on CT1 interface T1 2/0.
[Sysname-T1 2/0] cable short 133ft
channel-set (CT1 interface)
channel-set set-number timeslot-list list [ speed { 56k | 64k } ]
View
CT1 interface view
Default Level
2: System level
set-number: Number of the channel set formed by timeslot bundling on the interface. It ranges from 0 to 23.
timeslot-list list: Specifies the timeslots to be bundled. The list argument can contain multiple timeslot numbers, each of which ranges from 1 to 24. You can specify a single timeslot by specifying a timeslot number, a range of timeslots by providing this argument in the form of { number1-number2 }, or multiple timeslots by providing this argument in the form of { number1, number2-number3 }.
speed { 56k | 64k }: Speed of the timeslot bundle (the channel set) in kbps. If 56k is selected, the timeslots are bundled into N × 56 kbps bundles. If 64k, the default, is selected, the timeslots are bundled into N × 64 kbps bundles.
Use the channel-set command to bundle timeslots on the CT1 interface into a channel set.
Use the undo channel-set command to remove a specified or all channel sets.
A CT1 interface is physically divided into 24 timeslots numbered 1 through 24. In actual applications, all the timeslots can be bundled into multiple channel sets. For each channel set, the system automatically creates a serial interface logically equivalent to a synchronous serial interface.
The serial interface is named in the form of serial interface-number:set-number, where interface-number starts from the maximum serial interface number plus 1, and set-number represents the number of the channel set.
# Bundle timeslots 1, 2, 5, 10 through 15, and 18 into channel set 0 on CT1 interface T1 2/0.
[Sysname-T1 2/0] channel-set 0 timeslot-list 1,2,5,10-15,18
clock (CT1 interface)
undo clock
View
CT1 interface view
Default Level
2: System level
Use the clock command to configure clock source for the CT1 interface.
When the CT1 interface is working as DCE, choose the internal clock for it. When it is working as DTE, choose the line clock for it.
Two CT1 interfaces directly connecting two routers must respectively work in line clock (that is, slave clock) mode and internal clock (that is, master) mode. If the CT1 interface on a router is connected to a switch, the switch will be the DCE device responsible for providing the clock and the CE1/PRI interface. In this case, the CT1 interface must work in the line clock (slave clock) mode.
# Use the internal clock as the clock source on CT1 interface T1 2/0.
[Sysname-T1 2/0] clock master
code (CT1 interface)
code { ami | b8zs }
undo code
View
CT1 interface view
Default Level
2: System level
ami: Adopts AMI line code format.
b8zs: Adopts bipolar with 8-zero substitution (B8ZS) line code format.
Use the code command to set the line code format for the CT1 interface.
Use the undo code command to restore the default, that is, B8ZS.
Keep the line code format of the interface in consistency with the one used on the remote device.
# Set the line code format of the interface T1 2/0 to AMI.
[Sysname-T1 2/0] code ami
controller t1
controller t1 number
View
Default Level
2: System level
number: CT1 interface number.
Use the controller t1 command to enter CT1 interface view.
# Enter the view of interface T1 2/0.
[Sysname-T1 2/0]
crc
undo crc
View
Default Level
2: System level
16: Adopts 16-bit CRC.
none: Disables CRC.
Use the crc command to configure CRC mode for a synchronous serial interface formed on a CT1 interface.
# Apply 32-bit CRC to a serial interface formed on interface CT1 interface 2/0.
[Sysname-T1 2/0] channel-set 1 timeslot-list 2-6
[Sysname-T1 2/0] quit
[Sysname] interface serial 2/0:1
[Sysname-Serial2/0:1] crc 32
data-coding (CT1 interface)
undo data-coding
View
CT1 interface view
Default Level
2: System level
Use the data-coding inverted command to enable user data inversion on the CT1 interface.
Use the data-coding normal command to disable user data inversion on the CT1 interface.
To prevent 7e in valid data from being taken for stuffing characters, HDLC inserts a zero after every five ones in the data stream. Then, HDLC inverts every one bit into a zero and every zero bit into a one. This ensures at least one out of every eight bits is a one. When AMI encoding is adopted on a T1 interface, the use of data inversion can eliminate the presence of multiple consecutive zeros.
On the CT1 interfaces at two ends of a T1 line, the same data inversion setting must be adopted.
# Enable user data inversion on CT1 interface T1 2/0.
[Sysname-T1 2/0] data-coding inverted
description (CT1 interface)
View
CT1 interface view
Default Level
2: System level
text: Description of an interface, a string of 1 to 80 characters.
Use the description command to configure the description of the current CT1 interface.
By default, the description of a CT1 interface is the interface name followed by the interface string, T1 2/0 Interface for example.
# Configure the description of T1 2/0 as T1-interface.
[Sysname-t1 2/0] description T1-interface
display controller t1 [ interface-number ]
View
Default Level
2: System level
interface-number: Interface number. In conjunction with the t1 keyword, it specifies a CT1 interface.
Use the display controller t1 command to display information about one specified or all CT1 interfaces.
# Display information about interface T1 2/0.
<Sysname> display controller t1 2/0
T1 2/0 current state :DOWN
Description : T1 2/0 Interface
Work mode is T1 framed, Cable type is 100 Ohm balanced.
Frame-format is esf, fdl is none, Line code is b8zs.
Source clock is slave, Data-coding is normal.
Idle code is ff, Itf type is ff, Itf number is 2.
Alarm State:
Receiver alarm state is Loss-of-Signal.
Transmitter is sending remote alarm.
Pulse density violation detected.
SendLoopCode History:
inband-llb-up:0 times, inband-llb-down:0 times.
fdl-ansi-llb-up:0 times, fdl-ansi-llb-down:0 times.
fdl-ansi-plb-up:0 times, fdl-ansi-plb-down:0 times.
BERT state:(stopped, not completed)
Test pattern: 2^15, Status: Not Sync, Sync Detected: 0
Time: 0 minute(s), Time past: 0 minute(s)
Bit Errors (since test started): 0 bits
Bits Received (since test started): 0 Kbits
Bit Errors (since latest sync): 0 bits
Bits Received (since latest sync): 0 Kbits
Data in current interval (285 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Ais Alarm Secs, 286 Los Alarm Secs
7 Slip Secs, 286 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 286 Unavail Secs
Data in Interval 1:
0 Ais Alarm Secs, 901 Los Alarm Secs
22 Slip Secs, 901 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 901 Unavail Secs
Data in Interval 2:
0 Ais Alarm Secs, 900 Los Alarm Secs
23 Slip Secs, 900 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 900 Unavail Secs
Total Data (last 2 15 minute intervals):
0 Ais Alarm Secs, 2087 Los Alarm Secs
52 Slip Secs, 2087 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 2087 Unavail Secs
Table 1-3 display controller t1 command output description
T1 2/0 current state |
Physical state of the interface: up or down |
Description about the T1 interface |
Basic Configuration |
Basic configurations of the interface |
Work mode |
Operating mode of the T1 interface, T1 framed in this example |
Cable type |
Cable type of the T1 interface, 100 ohm balanced in this example |
Frame-format |
Frame format configured on the T1 interface: ESF or SF |
fdl |
FDL format: ANSI, ATT, or none |
Line code |
Line code: AMI or B8ZS |
Source clock |
Source clock used by the interface: master for the internal clock or slave for the line clock |
Data-coding |
Normal or inverted |
Idle code |
0x7E or 0xFF |
Itf type |
Type of interframe filling tag: 0x7E or 0xFF |
Itf number |
Number of interframe filling tags |
Loop back |
Loopback setting on the interface: local, payload, remote, or not set |
Alarm State |
Alarm state |
Receiver alarm state |
Type of received alarm: none, LOS, LOF, RAI, or AIS |
Transmitter is sending remote alarm. |
Type of transmitted alarm: RAI, or none |
Pulse density violation detected |
The detected pulse density is incompliant with the specification |
SendLoopCode History: inband-llb-up:0 times, inband-llb-down:0 times. fdl-ansi-llb-up:0 times, fdl-ansi-llb-down:0 times. fdl-ansi-plb-up:0 times, fdl-ansi-plb-down:0 times |
History of loopback code sending to the far-end, including the number of transmissions for each type of code, and the type of the last sent code. (See the sendloopcode command.) |
BERT state:(stopped, not completed) |
BERT state: completed, stopped (not completed), or running. |
Test pattern: 2^15, Status: Not Sync, Sync Detected: 0 |
Test pattern in use (2^20 or 2^15), 2^15 in this example; synchronization state, and the number of detected synchronizations |
Time: 0 minute(s), Time past: 0 minute(s) |
The duration of the BERT test and the time that has elapsed |
Bit Errors (since test started) |
Number of bit errors received since the start of the BERT test |
Bits Received (since test started) |
Number of bits received since the start of the BERT test |
Bit Errors (since latest sync) |
Number of bit errors received since the last synchronization |
Bits Received (since latest sync) |
Number of bits received since last synchronization |
Historical Statistics: |
Historical statistics |
Counter clearing records |
Data in current interval (285 seconds elapsed): 0 Line Code Violations, 0 Path Code Violations 0 Ais Alarm Secs, 286 Los Alarm Secs 7 Slip Secs, 286 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins 0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 286 Unavail Secs |
Statistics spanning the current interval. The statistical items, such as AIS alarm, LOS signal, and LFA, are provided according to the T1 specifications for the physical layer. For details, refer to ANSI T1.403 and AT&T TR 54016. |
Data in Interval 1: 0 Line Code Violations, 0 Path Code Violations 0 Ais Alarm Secs, 901 Los Alarm Secs 22 Slip Secs, 901 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins 0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 901 Unavail Secs |
Statistics spanning the first interval. The statistical items are the same as those provided by the statistics spanning the current interval. |
Data in Interval 2: 0 Line Code Violations, 0 Path Code Violations 0 Ais Alarm Secs, 900 Los Alarm Secs 23 Slip Secs, 900 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins 0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 900 Unavail Secs |
Statistics spanning the second interval. The statistical items are the same as those provided by the statistics spanning the current interval. |
Total Data (last 2 15 minute intervals): 0 Line Code Violations, 0 Path Code Violations 0 Ais Alarm Secs, 2087 Los Alarm Secs 52 Slip Secs, 2087 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins 0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 2087 Unavail Secs |
Statistics spanning the last two intervals. The statistical items are the same as those provided by the statistics spanning the current interval. |
fdl
fdl { ansi | att | both | none }
undo fdl
View
CT1 interface view
Default Level
2: System level
ansi: Adopts ANSI T1.403 for facilities data link (FDL).
att: Adopts AT&T TR 54016 for FDL.
both: Adopts both ANSI T1.403 and AT&T TR 54016 for FDL.
none: Disables FDL.
Use the fdl command to set the behavior of the CT1 interface on the FDL in ESF framing.
Use the undo fdl command to restore the default.
By default, FDL is disabled (none).
FDL is an embedded 4 kbps overhead channel within the ESF format for transmitting performance statistics or loopback code.
# Implement AT&T TR 54016 FDL on interface T1 2/0.
[Sysname-T1 2/0] fdl att
frame-format (CT1 interface)
frame-format { esf | sf }
undo frame-format
View
CT1 interface view
Default Level
2: System level
esf: Sets the framing format to extended super frame (ESF).
sf: Sets the framing format to super frame (SF).
Use the frame-format command to set the framing format on the CT1 interface.
Use the undo frame-format command to restore the default, that is, esf.
CT1 interfaces support two framing formats, that is, SF and ESF. In SF format, multiple frames can share the same FSC and signaling information, so that more significant bits are available for transmitting user data. The use of ESF allows you to test the system without affecting the ongoing service.
# Set the framing format of interface T1 2/0 to SF.
[Sysname-T1 2/0] frame-format sf
idlecode (CT1 interface)
undo idlecode
View
CT1 interface view
Default Level
2: System level
7e: Sets the line idle code to 0x7E.
ff: Sets the line idle code to 0xFF.
Use the idlecode command to set the line idle code on the CT1 interface. Two types of line idle code are available: 0x7E and 0xFF.
The line idle code is sent in the timeslots that are not bundled into the logical channels on the interface.
# Set the line idle code to 0x7E on CT1 interface T1 2/0.
[Sysname-T1 2/0] idlecode 7e
itf (CT1 interface)
View
CT1 interface view
Default Level
2: System level
number number: Sets the number of interframe filling tags (an interframe filling tag is one byte in length). The number argument ranges from 0 to 14.
type { 7e | ff }: Sets the interframe filling tag to 0x7E by specifying the 7e keyword or to 0xFF by specifying the ff keyword. On CT1 interfaces, the default interframe filling tag is 0x7E.
Use the itf command to set the type and the number of interframe filling tags on the CT1 interface. Two types of interframe filling tag are available: 0x7E and 0xFF.
By default, the interframe filling tag is 0x7E, the number of interframe filling tags is 4.
Interframe filling tags are sent when no service data is sent on the timeslots bundled into logical channels on a CT1 interface.
# Set the interframe filling tag to 0xFF on CT1 interface T1 2/0.
[Sysname-T1 2/0] itf type ff
# Set the number of interframe filling tags to five on CT1 interface T1 2/0.
[Sysname-T1 2/0] itf number 5
loopback (CT1 interface)
undo loopback
View
CT1 interface view
Default Level
2: System level
local: Enables the CT1 interface to perform local loopback.
payload: Enables the interface to perform external payload loopback.
remote: Enables the interface to perform remote loopback.
Use the loopback command to enable local, remote, or external payload loopback on the CT1 interface.
You can bundle timeslots on a CT1 interface to form a serial interface and encapsulate it with PPP. After you enable loopback on this serial interface, it is normal that the state of the link layer protocol is reported down.
# Enabled remote loopback on interface T1 2/0.
[Sysname-T1 2/0] loopback remote
reset counters controller t1
reset counters controller t1 interface-number
View
Default Level
2: System level
Use the reset counters controller t1 command to clear the controller counter for a CT1 interface.
To display the value of the controller counter, use the display controller t1 command.
The reset counters interface command clears the counters of all interfaces. To clear the controller counter of individual CT1 interfaces, use the reset counters controller t1 command.
# Clear the controller counter for CT1 interface T1 2/0.
<Sysname> reset counters controller t1 2/0
sendloopcode
sendloopcode { fdl-ansi-llb-down | fdl-ansi-llb-up | fdl-ansi-plb-down | fdl-ansi-plb-up | fdl-att-plb-down | fdl-att-plb-up | inband-llb-down | inband-llb-up }
View
CT1 interface view
Default Level
2: System level
fdl-ansi-llb-down: Sends ANSI-compliant LLB deactivation request code in the FDL to remove loopback.
fdl-ansi-llb-up: Sends ANSI-compliant line loopback (LLB) activation request code in the FDL to start remote loopback.
fdl-ansi-plb-down: Sends ANSI-compliant PLB deactivation request code in the FDL to remove loopback.
fdl-ansi-plb-up: Sends ANSI-compliant payload loopback (PLB) activation request code in the FDL to start remote loopback.
fdl-att-plb-down: Sends AT&T-complaint PLB deactivation request code in the FDL to remove loopback.
fdl-att-plb-up: Sends AT&T-complaint PLB activation request code in the FDL to start remote loopback.
inband-llb-down: Sends in-band LLB deactivation request code compliant with the ANSI or AT&T implementation to remove loopback.
inband-llb-up: Sends in-band line loopback (LLB) activation request code compliant with the ANSI and AT&T implementation to start remote loopback.
Use the sendloopcode command to send remote loopback control code.
By default, no remote loopback control code is sent.
You may configure loopback on the far-end CT1 interface by sending loopback request code.
In LLB mode, all 193 bits (one synchronization bit and 192 effective bandwidth bits) in a T1 PCM frame are looped back. In PLB mode, however, only 192 effective bandwidth bits are looped back.
The format of loopback code can be compliant with ANSI T1.403 or AT&T TR 54016.
In SF framing, LLB code is sent using the effective bandwidth. In ESF framing, both LLB code and PLB code are sent and received in the FDL.
Use this command in conjunction with the far-end T1 device. The far-end device must be able to set loopback mode depending on the detected loopback code. The sending of remote loopback control code lasts five minutes without affecting the operation of other interfaces.
# Send in-band LLB activation request code.
[Sysname-T1 2/0] sendloopcode inband-llb-up
shutdown (CT1 interface)
shutdown
View
CT1 interface view
Default Level
2: System level
None
Use the shutdown command to shut down the current CT1 interface.
Use the undo shutdown command to bring up the current CT1 interface.
# Shut down T1 2/0.
[Sysname-T1 2/0] shutdown
E1-F Interface Configuration Commands
crc
undo crc
View
Default Level
2: System level
none: Disables CRC.
Use the crc command to configure CRC mode for an E1-F interface.
# Adopt 32-bit CRC on E1-F interface Serial 2/0.
display fe1
display fe1 [ serial interface-number ]
View
Default Level
1: Monitor level
serial interface-number: Specifies a serial interface by its number. If no interface is specified, information about all the E1-F interfaces is displayed.
Use the display fe1 serial command to display the configuration and state information about the specified or all E1-F interfaces.
If the specified interface is a common serial interface rather than an E1-F interface, the system will display the prompt.
# Display the information about an E1-F interface.
<Sysname> display fe1 serial 2/0
Serial2/0
E1 FRAMED
Physical type is FE1 - 75 OHM unbalanced
Frame-format is NONE,Line Code is HDB3,Source Clock is SLAVE
Alarm State:
Data in current interval (19349 seconds elapsed):
129 Loss Frame Alignment Secs, 0 Framing Error Secs,
0 CRC Error Secs, 0 Alarm Indication Secs, 129 Loss-of-signals Secs,
Table 1-4 display fe1 serial command output description
E1 FRAMED |
Operating mode, framed or unframed. In this sample output, it is framed |
Physical type |
Interface type (75-ohm unbalanced/120-ohm balanced) |
Frame-format |
Framing format (CRC4/no-CRC4) |
Line Code |
Line code format: AMI or HDB3. |
Source Clock |
Source clock: master for internal clock and slave for line clock |
Alarm State |
Alarm information |
fe1 alarm
fe1 alarm detect rai
undo fe1 alarm detect rai
View
E1-F interface view
Default Level
2: System level
detect: Enables periodical detection on an interface.
Use the fe1 alarm command to enable RAI detection on the interface.
Use the undo fe1 alarm command to disable RAI detection on the interface.
By default, RAI detection is disabled on an interface.
This command is applicable when the interface operates in framed mode.
# Disable RAI detection on interface Serial 2/0.
[Sysname-Serial2/0] undo fe1 alarm detect rai
fe1 cable
fe1 cable { long | short }
undo fe1 cable
View
E1-F interface view
Default Level
2: System level
long: Supports long cables.
short: Supports short cables.
Use the fe1 cable command to set the cable length for an E1-F interface.
Use the undo fe1 cable command to restore the default.
# Set the cable length type on E1-F interface Serial 2/0 to short.
[Sysname-Serial2/0] fe1 cable short
fe1 clock
fe1 clock { master | slave }
undo fe1 clock
View
E1-F interface view
Default Level
2: System level
Use the fe1 clock command to configure clock source for the E1-F interface.
Use the undo fe1 clock command to restore the default, that is, line clock.
When the E1-F interface is working as DCE, choose the internal clock (master) for it. When it is working as DTE, choose the line clock for it.
# Use the internal clock as the clock source on E1-F interface Serial 2/0.
[Sysname-Serial2/0] fe1 clock master
fe1 code
fe1 code { ami | hdb3 }
undo fe1 code
View
E1-F interface view
Default Level
2: System level
hdb3: Adopts HDB3 line code format.
Use the fe1 code command to set the line code format for the E1-F interface.
Use the undo fe1 code command to restore the default, that is, HDB3.
# Set the line code format of E1-F interface Serial 2/0 to AMI.
[Sysname-Serial2/0] fe1 code ami
fe1 data-coding
fe1 data-coding { inverted | normal }
undo fe1 data-coding
View
E1-F interface view
Default Level
2: System level
Use the fe1 data-coding normal command to disable user data inversion for a E1-F interface.
Use the fe1 data-coding inverted command to enable user data inversion for a E1-F interface.
Use the undo fe1 data-coding command to restore the default.
To prevent 7e in valid data from being taken for stuffing characters, HDLC inserts a zero after every five ones in the data stream. Then, HDLC inverts every one bit into a zero and every zero bit into a one. This ensures at least at least one out of every eight bits is a one. When AMI encoding is adopted on an E1-F interface, the use of data inversion can eliminate presence of multiple consecutive zeros.
At the two ends of an E1-F line, the same data inversion setting must be adopted.
# Enable user data inversion on E1-F interface Serial 2/0.
[Sysname-Serial2/0] fe1 data-coding inverted
fe1 detect-ais
fe1 detect-ais
undo fe1 detect-ais
View
E1-F interface view
Default Level
2: System level
None
Use the fe1 detect-ais command to enable AIS test on an interface.
Use the undo fe1 detect-ais command to disable AIS test.
# Enable AIS test on E1-F 2/0 interface.
[Sysname-Serial2/0] fe1 detect-ais
fe1 frame-format
fe1 frame-format { crc4 | no-crc4 }
undo fe1 frame-format
View
E1-F interface view
Default Level
2: System level
crc4: Sets the framing format to CRC4.
no-crc4: Sets the framing format to no-CRC4.
Use the fe1 frame-format command to configure the framing format of the E1-F interface.
Use the undo fe1 frame-format command to restore the default, that is, no-CRC4.
An E1-F interface in framed mode supports both CRC4 and no-CRC4 framing formats, where CRC4 supports four-bit CRC on physical frames while no-CRC4 does not.
# Set the framing format of E1-F interface Serial 2/0 to CRC4.
[Sysname-Serial2/0] fe1 frame-format crc4
fe1 idlecode
fe1 idlecode { 7e | ff }
undo fe1 idlecode
View
E1-F interface view
Default Level
2: System level
Use the fe1 idlecode command to set the line idle code on the E1-F interface. Two types of line idle code are available: 0x7E and 0xFF.
Use the undo fe1 idlecode command to restore the default, that is, 0x7E.
# Set the line idle code to 0x7E on E1-F interface Serial 2/0.
[Sysname-Serial2/0] fe1 idlecode 7e
fe1 itf
fe1 itf { number number | type { 7e | ff } }
undo fe1 itf { number | type }
View
E1-F interface view
Default Level
2: System level
type { 7e | ff }: Sets the type of interframe filling tag to 0x7E by specifying the 7e keyword or to 0xFF by specifying the ff keyword. The default is 0x7E.
Use the fe1 itf command to set the type of and the number of interframe filling tags on the E1-F interface. Two types of interframe filling tag are available: 0x7E and 0xFF.
Use the undo fe1 itf command to restore the default.
By default, the interframe filling tag is 0x7E and the number of interframe filling tags is 4.
Interframe filling tags are sent when no service data is sent on the timeslots bundled into the logical channel on the E1-F interface.
# Set the type of interframe filling tag to 0xFF on E1-F interface Serial 2/0.
[Sysname-Serial2/0] fe1 itf type ff
# Set the number of interframe filling tags to five on E1-F interface Serial 2/0.
[Sysname-Serial2/0] fe1 itf number 5
fe1 loopback
fe1 loopback { local | payload | remote }
undo fe1 loopback
View
E1-F interface view
Default Level
2: System level
local: Sets the interface in internal loopback mode.
Use the fe1 loopback command to set the E1-F interface in a loopback mode.
Use the undo fe1 loopback command to restore the default.
The three loopback modes cannot be used at the same time on an E1-F interface.
# Set E1-F interface Serial 2/0 in internal loopback mode.
[Sysname-Serial2/0] fe1 loopback local
fe1 timeslot-list
fe1 timeslot-list list
undo fe1 timeslot-list
View
E1-F interface view
Default Level
2: System level
list: Specifies timeslots to be bundled. They are numbered 1 through 31. You may specify a single timeslot by specifying its number, a range of timeslots by specifying a range in the form of number1-number2, or several discrete timeslots by specifying number1, number2-number3.
Use the fe1 timeslot-list command to bundle timeslots on the E1-F interface.
Use the undo fe1 timeslot-list command to restore the default.
By default, all the timeslots on the E1-F interface are bundled to form a 1984 kbps interface.
Timeslot bundling results in interface rate change. For example, after you bundle timeslots 1 through 10 on the interface, the interface rate becomes 10 × 64 kbps.
Only one channel set can be created on an E1-F interface, and this channel set is associated with the current synchronous serial interface. On a CE1 interface, however, you may create multiple channel sets; for each of them, the system automatically creates a synchronous serial interface.
Timeslot 0 on E1-F interfaces is used for synchronization. Therefore, a bundling operation only involves timeslots 1 through 31.
When the E1-F interface is working in unframed mode, the fe1 timeslot-list command is invalid.
Related commands: fe1 unframed.
# Bundle timeslots 1, 2, 5, 10 through 15, and 18 on E1-F interface Serial 2/0.
[Sysname-Serial2/0] fe1 timeslot-list 1,2,5,10-15,18
fe1 unframed
fe1 unframed
undo fe1 unframed
View
E1-F interface view
Default Level
2: System level
None
Use the fe1 unframed command to configure the E1-F interface to work in unframed mode.
Use the undo fe1 unframed command to configure the E1-F interface to work in framed mode.
By default, the E1-F interface works in framed mode.
When the E1-F interface is working in unframed mode, it is a 2048 kbps interface without timeslot division and is logically equivalent to a synchronous serial interface.
When it works in framed mode, it is physically divided into 32 timeslots numbered 0 through 31, where timeslot 0 is used for synchronization.
Related commands: fe1 timeslot-list.
# Set E1-F interface Serial 2/0 to work in unframed mode.
[Sysname-Serial2/0] fe1 unframed
T1-F Interface Configuration Commands
ft1 alarm
ft1 alarm detect rai
undo ft1 alarm detect rai
View
T1-F interface view
Default Level
2: System level
Use the ft1 alarm command to enable RAI detection on the interface.
Use the undo ft1 alarm command to disable RAI detection on the interface.
This command is applicable when the framing format on the interface is ESF.
[Sysname-Serial2/0] undo ft1 alarm detect rai
crc
crc { 16 | 32 | none }
undo crc
View
Default Level
2: System level
none: Disables CRC.
Use the crc command to configure CRC mode for an T1-F interface.
# Adopt 32-bit CRC on T1-F interface Serial 2/0.
[Sysname-Serial2/0] crc 32
display ft1
display ft1 [ serial interface-number ]
View
Default Level
1: Monitor level
serial interface-number: Specifies a serial interface by its number. If no interface is specified, the information on all the T1-F interfaces is displayed.
Use the display ft1 command to display the configuration and state information about a T1-F interface.
If the specified interface is a common serial interface rather than a T1-F interface, the system will display the prompt.
# Display information about T1-F interface Serial 2/0.
<Sysname> display ft1 serial 2/0
Serial2/0
Input: 0 packets, 0 bytes
0 broadcasts, 0 multicasts
0 errors, 0 runts, 0 giants
0 CRC, 0 align errors, 0 overruns
0 dribbles, 0 aborts, 0 no buffers
0 frame errors
Output:0 packets, 0 bytes
0 errors, 0 underruns, 0 collisions
0 deferred
Alarm State:
Data in Interval 1:
Data in Interval 2:
Table 1-5 display ft1 serial command output description
Serial2/0 |
Interface type and number |
Basic configurations for the interface |
Input Output |
Statistics about the input and output |
Work mode |
T1 interface operating mode, T1 framed in this sample output |
Cable type |
Cable type of the interface, 100 ohm balanced in this sample output |
Frame-format |
Frame format configured on the interface: ESF or SF |
fdl |
Line code |
AMI or B8ZS |
Source Clock |
Data-coding |
Idle code |
Idle code, 0x7E or 0xFF |
Itf type |
Type of inter-frame filling tags: 0x7E or 0xFF |
Itf number |
Number of inter-frame filling tags |
Loop back |
Alarm State |
Alarm state |
History of loopback code sending to the far-end, including the number of transmissions for each type of code, and the type of the last sent code. (See the ft1 sendloopcode command.) |
BERT state: completed, stopped (administratively stopped), or running. |
Test pattern in use, 2^15 in this sample output; synchronization state, and the number of detected synchronizations |
Last clearing of counters: Never |
ft1 alarm-threshold
ft1 alarm-threshold { ais { level-1 | level-2 } | lfa { level-1 | level-2 | level-3 | level-4 } | los { pulse-detection | pulse-recovery } value }
undo ft1 alarm-threshold { ais | lfa | los { pulse-detection | pulse-recovery } }
View
T1-F interface view
Default Level
2: System level
Use the ft1 alarm-threshold command to set LOS, AIS, or LFA alarm thresholds on the T1-F interface.
Use the undo ft1 alarm-threshold command to restore the defaults.
[Sysname-Serial2/0] ft1 alarm-threshold los pulse-detection 300
ft1 bert
ft1 bert pattern { 2^15 | 2^20 } time minutes [ unframed ]
undo ft1 bert
View
T1-F interface view
Default Level
2: System level
time minutes: Sets the duration (in minutes) of a BERT test. The minute argument is up to 1,440.
Use the ft1 bert command to start a BERT test on a T1-F interface.
Use the undo ft1 bert command to stop the BERT test running on the T1-F interface.
ITU O.151, ITU O.153, and ANSI T1.403-1999 define many BERT patterns, among which, the T1-F interface supports only 2^15 and 2^20 at present.
You may view the state and result of the BERT test with the display ft1 serial command.
# Run a 10-minute 2^20 BERT test on T1-F interface Serial 2/0.
[Sysname-Serial2/0] ft1 bert pattern 2^20 time 10
ft1 cable
ft1 cable { long decibel | short length }
undo ft1 cable
View
T1-F interface view
Default Level
2: System level
long decibel: Matches 199.6-meter (655-feet) and longer cable length. The argument decibel can take 0db, -7.5db, -15db, or -22.5db, depending on the signal quality at the receiving end. In this case, no external CSU is required.
short length: Matches a cable length shorter than 199.6 meters (655 feet). The argument length can take 133ft, 266ft, 399ft, 533ft, or 655ft, depending on the actual transmission distance.
Use the ft1 cable command to set the cable attenuation and length on the T1-F interface.
Use the undo ft1 cable command to restore the default, that is, long 0db.
You may use this command to adapt signal waveform to different transmission conditions such as the quality of the signal received by the receiver. If the signal quality is good, you can just use the default setting.
# Set the cable length to 40.5 meters (133 feet) on T1-F interface Serial 2/0.
[Sysname-Serial2/0]ft1 cable short 133ft
ft1 clock
ft1 clock { master | slave }
undo ft1 clock
View
T1-F interface view
Default Level
2: System level
Use the ft1 clock command to configure the clock source for the T1-F interface.
Use the undo ft1 clock command to restore the default, that is, line clock.
When the T1-F interface is working as DCE, choose the internal clock for it. When it is working as DTE, choose the line clock for it.
When the T1-F interfaces on two routers are directly connected, one interface must work in master clock mode to provide the clock source while the other in slave clock mode to accept.
When the T1-F interface on your router is connected to an exchange, it is working as DTE and therefore must be configured with the slave clock mode to accept the line clock provided by the exchange working as DCE.
# Use the internal clock as the clock source on T1-F interface Serial 2/0.
[Sysname-Serial2/0] ft1 clock master
ft1 code
ft1 code { ami | b8zs }
undo ft1 code
View
T1-F interface view
Default Level
2: System level
b8zs: Adopts B8ZS line code format.
Use the ft1 code command to set the line code format for the T1-F interface.
Use the undo ft1 code command to restore the default, that is, B8ZS.
# Set the line code format of T1-F interface Serial 2/0 to AMI.
[Sysname-Serial2/0] ft1 code ami
ft1 data-coding
ft1 data-coding { inverted | normal }
undo ft1 data-coding
View
T1-F interface view
Default Level
2: System level
Use the ft1 data-coding normal command to disable user data inversion for a T1-F interface.
Use the ft1 data-coding inverted command to enable user data inversion for a T1-F interface.
Use the undo ft1 data-coding command to restore the default.
To prevent 7e in valid data from being taken for stuffing characters, HDLC inserts a zero after every five ones in the data stream. Then, HDLC inverts every one bit into a zero and every zero bit into a one. This ensures at least at least one out of every eight bits is a one. When AMI encoding is adopted on a T1-F interface, the use of data inversion can eliminate presence of multiple consecutive zeros.
At the two ends of a T1-F line, the same data inversion setting must be adopted.
# Enable user data inversion on T1-F interface Serial 2/0.
[Sysname-Serial2/0] ft1 data-coding inverted
ft1 fdl
ft1 fdl { ansi | att | both | none }
undo ft1 fdl
View
T1-F interface view
Default Level
2: System level
ansi: Adopts ANSI T1.403 for FDL.
none: Disables FDL.
Use the ft1 fdl command to set the behavior of the T1-F interface on the FDL in ESF framing.
Use the undo ft1 fdl command to restore the default.
By default, FDL is disabled.
You can however change the setting depending on the setting at the far end.
# Implement ANSI T1.403 FDL on T1-F interface Serial 2/0.
[Sysname-Serial2/0] ft1 fdl ansi
ft1 frame-format
ft1 frame-format { esf | sf }
undo ft1 frame-format
View
T1-F interface view
Default Level
2: System level
esf: Sets the framing format on the T1-F interface to ESF.
sf: Sets the framing format on the T1-F interface to SF.
Use the ft1 frame-format command to set the framing format on the T1-F interface.
Use the undo ft1 frame-format command to restore the default, that is, esf.
T1-F interfaces support two framing formats, that is, SF and ESF. In SF format, multiple frames can share the same FSC and signaling information, so that more significant bits are available for transmitting user data. The use of ESF allows you to test the system without affecting the ongoing service.
# Set the framing format of T1-F interface Serial 2/0 to SF.
[Sysname-Serial2/0] ft1 frame-format sf
ft1 idlecode
ft1 idlecode { 7e | ff }
undo ft1 idlecode
View
T1-F interface view
Default Level
2: System level
Use the ft1 idlecode command to set the line idle code on the T1-F interface. Two types of line idle code are available: 0x7E and 0xFF.
Use the undo ft1 idlecode command to restore the default, that is, 0x7E.
# Set the line idle code to 0x7E on T1-F interface Serial 2/0.
[Sysname-Serial2/0] ft1 idlecode 7e
ft1 itf
ft1 itf { number number | type { 7e | ff } }
undo ft1 itf { type | number }
View
T1-F interface view
Default Level
2: System level
number number: Sets the number of interframe filling tags (a interframe filling tag is one byte in length). The number argument ranges from 0 to 14.
type { 7e | ff }: Sets the interframe filling tag to 0x7E by specifying the 7e keyword or to 0xFF by specifying the ff keyword. On a T1-F interface, the default interframe filling tag is 0x7E.
Use the ft1 itf command to set the type and the number of interframe filling tags on the T1-F interface. Two types of interframe filling tag are available: 0x7E and 0xFF.
Use the undo ft1 itf command to restore the default.
By default, the interframe filling tag is 0x7E, and the number of interframe filling tags is four.
Interframe filling tags are sent when no service data is sent on the timeslots bundled into logical channels on a T1-F interface.
Do not use the ft1 itf type ff command if both the ft1 code ami command and the ft1 data-coding inverted command are configured so that the T1-F interface can function normally.
# Set the interframe filling tag to 0xFF on T1-F interface Serial 2/0.
[Sysname-Serial2/0] ft1 itf type ff
# Set the number of interframe filling tags to five on T1-F interface Serial 2/0.
[Sysname-Serial2/0] ft1 itf number 5
ft1 loopback
ft1 loopback { local | payload | remote }
undo ft1 loopback
View
T1-F interface view
Default Level
2: System level
Use the ft1 loopback command to set the T1-F interface in a loopback mode.
Use the undo ft1 loopback command to restore the default.
By default, loopback is disabled.
The three loopback modes cannot be used at the same time on a T1-F interface.
# Set T1-F interface Serial 2/0 in local loopback mode.
[Sysname-Serial2/0] ft1 loopback local
ft1 sendloopcode
ft1 sendloopcode { fdl-ansi-llb-down | fdl-ansi-llb-up | fdl-ansi-plb-down | fdl-ansi-plb-up | fdl-att-plb-down | fdl-att-plb-up | inband-llb-down | inband-llb-up }
View
T1-F interface view
Default Level
2: System level
fdl-ansi-llb-down: Sends ANSI-compliant LLB deactivation request code in the FDL to removes loopback.
inband-llb-up: Sends in-band line loopback (LLB) activation request code compliant with the ANSI or AT&T implementation to start remote loopback.
Use the ft1 sendloopcode command to send remote loopback control code.
You may configure loopback on the far-end T1-F interface by sending loopback request code.
In SF framing, LLB code is sent using the effective bandwidth (slots 1 through 24). In ESF framing, both LLB code and PLB code are sent/received in the FDL in ESF frames.
You can use this command only when the far-end CT1 interface can automatically detect loopback request code from the network.
[Sysname-Serial2/0] ft1 sendloopcode inband-llb-up
ft1 timeslot-list
ft1 timeslot-list list [ speed { 56k | 64k } ]
undo ft1 timeslot-list
View
T1-F interface view
Default Level
2: System level
speed { 56k | 64k }: Time slot bundling speed in kbps. If 56k applies, timeslots are bundled into an N × 56 kbps bundle. If 64k (the default) applies, timeslots are bundled into an N × 64 kbps bundle.
Use the ft1 timeslot-list command to bundle timeslots on a T1-F interface.
Use the undo ft1 timeslot-list command to restore the default.
By default, all the timeslots on the T1-F interface are bundled to form a 1536 kbps interface.
Timeslot bundling results in interface rate change. For example, after you bundle timeslots 1 through 10 on the interface, the interface rate becomes 10 × 64 kbps or 10 × 56 kbps.
Only one channel set can be created on a T1-F interface, and this channel set is associated with the current synchronous serial interface. On a CT1 interface, however, you may create multiple channel sets; for each of them, the system automatically creates a synchronous serial interface.
# Bundle timeslots 1, 2, 5, 10 through 15, and 18 on T1-F interface Serial 2/0.
[Sysname-Serial2/0] ft1 timeslot-list 1,2,5,10-15,18
Basic CE3 Interface Configuration Commands
bert (CE3 interface)
bert pattern { 2^7 | 2^11 | 2^15 | qrss } time number [ unframed ]
undo bert
View
CE3 interface view
Default Level
2: System level
pattern: Specifies BERT test mode, which can be 2^7, 2^11, 2^15, and QRSS.
2^7: Specifies the code stream transmitted is the 7th power of 2 bits in length.
2^11: Specifies the code stream transmitted is the 11th power of 2 bits in length.
2^15: Specifies the code stream transmitted is the 15th power of 2 bits in length.
qrss: Specifies the code stream transmitted is the 20th power of 2 bits in length and the number of successive 0s in the code stream is no more than 14.
time number: Sets the duration (in minutes) of a BERT teat. The number argument is in the range 1 to 1,440.
unframed: Sets the overhead bits of the padding frames for BERT test.
Use the bert command to enable BERT test.
Use the undo bert command to disable BERT test.
Multiple BERT test modes exist, as defined in ITU O.151, ITU O.153, and ANSI T1.403-1999. Currently, 2^7, 2^11, 2^15, and QRSS are available on a CE3 interface.
To perform a BERT test, the local end transmits test data stream, which is returned after reaching specific nodes. The local end then checks for the bit error rate by comparing the returned data stream with the original, through which the state of the link can be determined. BERT test requires that data stream can be looped back on specific nodes. You can achieve this by enabling remote loop back on the peer.
You can use the bert command to set the test mode and the test duration. During the process of a BERT test, you can check the state and the result of the test. For more information, refer to the command used for displaying the information about a CE3 interface.
# Perform BERT test in QRSS mode on CE3 2/0 interface, setting the duration to ten minutes.
[Sysname] interface e3 2/0
[Sysname-E3 2/0] bert pattern qrss time 10
clock (CE3 interface)
undo clock
View
CE3 interface view
Default Level
2: System level
master: Adopts the internal clock as the clock source.
slave: Adopts the line clock as the clock source.
Use the clock command to configure clock source for the CE3 interface.
Use the undo clock command to restore the default, that is, line clock.
The clock source is selected depending on the connected remote device. If connected to a transmission device, the local end uses the line clock. If connected to a CE3 interface on another router, the local end can use whichever clock so long as it is different from the one adopted at the remote end.
# Use the internal clock as the clock source on CE3 interface E3 2/0.
[Sysname] controller e3 2/0
[Sysname-E3 2/0] clock master
controller e3
controller e3 interface-number
View
Default Level
2: System level
interface-number: CE3 interface number.
Use the controller e3 command to enter CE3 interface view.
Related commands: display controller e3.
# Enter the view of interface E3 2/0.
[Sysname-E3 2/0]
crc
undo crc
View
Synchronous serial interface view
Default Level
2: System level
32: Adopts 32-bit CRC.
none: Adopts no CRC.
Use the crc command to configure CRC mode for a synchronous serial interface formed by CE3 interfaces.
Use the undo crc command to restore the default, that is, 16-bit CRC.
Related commands: e1 channel-set, e1 unframed, using.
# Apply 32-bit CRC to a serial interface formed on interface E3 2/0 in unchannelized mode.
[Sysname-E3 2/0] using e3
[Sysname-E3 2/0] quit
[Sysname] interface serial 2/0/0:0
[Sysname-Serial2/0/0:0] crc 32
# Apply 16-bit CRC to a serial interface formed on interface E3 2/0 in unchannelized mode.
[Sysname-E3 2/0] e1 3 channel-set 5 timeslot-list 1-20
[Sysname] interface serial 2/0/3:5
[Sysname-Serial2/0/3:5] crc 16
description (CE3 interface)
View
CE3 interface view
Default Level
2: System level
text: Description of the current interface, a string of 1 to 80 characters.
Use the description command to configure the description of the current CE3 interface.
Use the undo description command to restore the default.
By default, the description of a CE3 interface is the interface name followed by the interface string, E3 2/0 Interface for example.
# Configure the description of E3 2/0 as E3-interface.
[Sysname-E3 2/0] description E3-interface
display controller e3 [ interface-number ]
View
Default Level
1: Monitor level
interface-number: CE3 interface number. In conjunction with the e3 keyword, it specifies a CE3 interface.
Use the display controller e3 command to display state information about one specified or all CE3 interfaces.
In addition to the state information of the CE3 interface, the command displays information about each E1 line on the CE3 interface if the interface is working in CE3 mode.
# Display information about interface E3 2/0.
<Sysname> display controller e3 2/0
E3 2/0 is up
Description : E3 2/0 Interface
Applique type is CE3 - 75 OHM unbalanced Frame-format G751, line code HDB3, clock slave, national-bit 1,loopback not set
Alarm: none
ERROR: 0 BPV, 0 EXZ, 0 FrmErr, 0 FEBE
E3-0 CE1 1 is up
Frame-format NO-CRC4, clock master, loopback not set
E3-0 CE1 2 is up
Frame-format NO-CRC4, clock slave, loopback local
E3-0 CE1 3 is up
Frame-format NO-CRC4, clock slave, loopback remote
E3-0 CE1 4 is up
Frame-format CRC4, clock slave, loopback not set
E3-0 CE1 5 is up
Frame-format NO-CRC4, clock slave, loopback not set
E3-0 CE1 6 is up
E3-0 CE1 7 is up
E3-0 CE1 8 is up
E3-0 CE1 9 is up
E3-0 CE1 10 is up
E3-0 CE1 11 is up
E3-0 CE1 12 is up
E3-0 CE1 13 is up
E3-0 CE1 14 is up
E3-0 CE1 15 is up
E3-0 CE1 16 is up
e1 bert
e1 line-number bert pattern { 2^11 | 2^15 | 2^20 | 2^23 | qrss } time number [ unframed ]
undo e1 line-number bert
View
CE3 interface view
Default Level
2: System level
line-number: E1 channel number, in the range 1 to 28.
pattern: Specifies BERT test mode, which can be 2^11, 2^15, 2^20, 2^23, and QRSS.
2^20: Specifies the code stream transmitted is the 20th power of 2 bits in length.
2^23: Specifies the code stream transmitted is the 23th power of 2 bits in length.
Use the e1 bert command to enable BERT test for an E1 channel created on a CE3 interface.
Use the undo e1 bert command to disable BERT test.
Multiple BERT test modes exist, as defined in ITU O.151, ITU O.153, and ANSI T1.403-1999. Currently, 2^11, 2^15, 2^20, 2^23, and QRSS are available on E1 channels created on CE3 interfaces.
# Perform BERT test in QRSS mode on E1 channel 1 created on CE3 2/0 interface, setting the duration to ten minutes.
[Sysname-E3 2/0] e1 1 bert pattern qrss time 10
e1 channel-set
e1 line-number channel-set set-number timeslot-list list
undo e1 line-number channel-set set-number
View
CE3 interface view
Default Level
2: System level
line-number: E1 line number in the range 1 to 16.
set-number: Number of the channel set formed by a timeslot bundle on the E1 line. It ranges from 0 to 30.
timeslot-list list: Specifies the timeslots to be bundled. The list argument can contain multiple timeslot numbers, each of which ranges from 1 to 31. You can specify a single timeslot by specifying a timeslot number, a range of timeslots by providing this argument in the form of { number1-number2 }, or multiple timeslots by providing this argument in the form of { number1, number2-number3 }.
Use the e1 channel-set command to bundle timeslots on an E1 line.
Use the undo e1 channel-set command to remove a timeslot bundle.
By default, no timeslots are bundled into channel sets.
A CE3 interface can be channelized into 64 kbps lines and the timeslots on each E1 line can be bundled into up to 31 channels.
When an E1 line operates in framed (CE1) mode, you can bundle timeslots on it into channel sets. For each channel set, the system automatically creates a serial interface numbered serial number/line-number:set-number. For example, the serial interface formed by channel set 0 on the first E1 line on E3 1/0 is numbered 1/0/1:0. This interface can operate at N × 64 kbps and is logically equivalent to a synchronous serial interface on which you can make other configurations.
Related commands: e1 unframed.
# Create a 128 kbps serial interface on the first E1 channel on interface E3 2/0.
[Sysname-E3 2/0] e1 1 channel-set 1 timeslot-list 1,2
e1 set clock
e1 line-number set clock { master | slave }
undo e1 line-number set clock
View
CE3 interface view
Default Level
2: System level
Use the e1 set clock command to configure clock source for an E1 line on the CE3 interface.
Use the undo e1 set clock command to restore the default, that is, line clock.
When the CE3 interface is working in channelized mode, you can set separate clock for each E1 line on it.
# Use the internal clock as the clock source on the first E1 line on interface E3 2/0.
[Sysname-E3 2/0] e1 1 set clock slave
e1 set frame-format
e1 line-number set frame-format { crc4 | no-crc4 }
undo e1 line-number set frame-format
View
CE3 interface view
Default Level
2: System level
crc4: Sets the frame format to CRC4.
no-crc4: Sets the frame format to no-CRC4.
Use the e1 set frame-format command to set framing format for an E1 line.
Use the undo e1 set frame-format command to restore the default, that is, no-CRC4.
Configure this command only when the specified E1 line is working in framed format (which can be set using the undo e1 unframed command).
# Set the framing format to CRC4 for the first E1 line on interface E3 2/0.
[Sysname-E3 2/0] e1 1 set frame-format crc4
e1 set loopback
e1 line-number set loopback { local | payload | remote }
undo e1 line-number set loopback
View
CE3 interface view
Default Level
2: System level
local: Sets the E1 line in internal loopback mode.
payload: Sets the E1 line in payload loopback mode.
remote: Sets the E1 line in external loopback mode.
Use the e1 set loopback command to set an E1 line in a loopback mode on the E3 interface.
Use the undo e1 set loopback command to restore the default.
By default, loopback is disabled on E1 lines.
If an E1 line encapsulated with PPP is in loopback mode, it is normal that the state of the link layer protocol is reported down.
# Set the first E1 line on interface E3 2/0 in internal loopback mode.
[Sysname-E3 2/0] e1 1 set loopback local
e1 shutdown
e1 line-number shutdown
undo e1 line-number shutdown
View
CE3 interface view
Default Level
2: System level
Use the e1 shutdown command to shut down an E1 line on the CE3 interface.
Use the undo e1 shutdown command to restore the default.
By default, E1 lines are up.
This command affects not only the specified E1 line but also the serial interfaces formed by E1 line bundling. Performing the e1 shutdown command on the specified E1 line shuts down all these serial interfaces. Data transmission and receiving stop as a result. Likewise, performing the undo e1 shutdown command restarts all these serial interfaces.
# Shut down the first E1 line on interface E3 2/0.
[Sysname-E3 2/0] e1 1 shutdown
e1 unframed
e1 line-number unframed
undo e1 line-number unframed
View
CE3 interface view
Default Level
2: System level
Use the e1 unframed command to set an E1 line on the CE3 interface to work in unframed mode (E1 mode).
Use the undo e1 unframed command to restore the default.
By default, an E1 line operates in framed mode (CE1 mode).
An E1 line in unframed mode does not contain the frame control information; it cannot be divided into timeslots. The system automatically creates a serial interface numbered serial number/line-number:0 for it. This interface operates at 2048 kbps and is logically equivalent to a synchronous serial interface on which you can make other configurations.
Related commands: e1 channel-set.
# Set the first E1 line on interface E3 2/0 to operate in unframed mode.
[Sysname-E3 2/0] e1 1 unframed
fe3
fe3 { dsu-mode { 0 | 1 } | subrate number }
undo fe3 { dsu-mode | subrate }
View
CE3 interface (in FE3 mode) view
Default Level
2: System level
dsu-mode: Specifies the FE3 (Fractional E3) DSU mode for a CE3 interface operating in FE3 mode. This keyword can be followed by 0 or 1, as described below:
0, meaning the Digital Link mode, where the subrate is a multiple of 358 kbps and ranges from 358 to 34010 kbps (that is, up to 95 rate levels are available).
1, meaning the Kentrox mode, where the subrate is a multiple of 500 kbps and ranges from 500 to 24500 kbps. In this mode, the subrate can also be 34010 kbps (making a total of 50 rate levels).
subrate number: Specifies the subrate for the CE3 interface. The number argument ranges from 1 to 34010 (in kbps).
Use the fe3 command to configure a CE3 interface to operate in the FE3 mode and set the DSU mode or the subrate.
Use the undo fe3 command to restore the default.
By default, DSU mode 1 (the Kentrox mode) is adopted, and the subrate is 34010 kbps.
FE3 mode is a non-standard E3 application mode. In this mode, the subrate level setting varies with vendors. You can use the fe3 command to make the device to be compatible with devices of other vendors operating in specific FE3 DSU modes.
Note that:
l This command is only applicable to CE3 boards that support FE3.
l This command is only available in CE3 mode.
l As for the fe3 subrate command, the actual subrate usually is not exactly the one set by the command. That is, after you set the subrate by using the fe3 subrate command, the CE3 interface searches the subrate levels corresponding to the DSU mode it is operating in and selects the one that is closest to that set by the command as its subrate. The device then adjusts the hardware to allow for the subrate.
l You can use the display interface serial interface-number:0 command to check the DSU mode setting, the subrate, the actual rate, and the baudrate of a CE3 interface. Note that the actual rate does not count in the overhead bits, and the baudrate is the actual E3 line rate (that is, 34368 kbps), with the overhead bits counted in.
# Configure E3 2/0 interface to operate in the FE3 mode, setting the DSU mode to 1 and the subrate to 3000 kbps.
[Sysname-E3 2/0] fe3 dsu-mode 1
[Sysname-E3 2/0] fe3 subrate 3000
loopback (CE3 interface)
undo loopback
View
CE3 interface view
Default Level
2: System level
local: Enables internal loopback on the CE3 interface.
payload: Enables external payload loopback on the CE3 interface.
remote: Enables external loopback on the CE3 interface.
Use the loopback command to configure the loopback mode of the CE3 interface.
Use the undo loopback command to restore the default.
By default, loopback is disabled on the CE3 interface.
Loopback is intended for test use. Disable it otherwise.
If a CE3 interface encapsulated with PPP is placed in a loopback, it is normal that the state of the link layer protocol is reported down.
# Enable internal loopback on interface E3 2/0.
[Sysname-E3 2/0] loopback local
national-bit
national-bit { 0 | 1 }
undo national-bit
View
CE3 interface view
Default Level
2: System level
0: Sets the national bit to 0 for national communication.
1: Sets the national bit to 1 for international communication.
Use the national-bit command to configure the national bit on the CE3 interface.
Use the undo national-bit command to restore the default, that is, 1.
You need to set the national bit to 0 on an E3 interface only in some special circumstances.
Related commands: controller e3.
# Set the national bit to 0 on interface E3 2/0.
[Sysname-E3 2/0] national-bit 0
reset counters controller e3
reset counters controller e3 interface-number
View
Default Level
2: System level
Use the reset counters controller e3 command to clear the controller counter of a CE3 interface.
You can use the display controller e3 command to display the statistics collected by the controller counters of CE3 interfaces.
The reset counters interface command clears the counters of all interfaces. To clear the controller counter of individual CE3 interfaces, use the reset counters controller e3 command.
# Clear the controller counter of the CE3 interface E3 2/0.
<Sysname> reset counters controller e3 2/0
shutdown (CE3 interface)
shutdown
View
CE3 interface view
Default Level
2: System level
None
Use the shutdown command to shut down the current CE3 interface.
Use the undo shutdown command to bring up the current CE3 interface.
By default, a CE3 interface is enabled.
# Shut down E3 2/0.
[Sysname-E3 2/0] shutdown
using (CE3 interface)
undo using
View
CE3 interface view
Default Level
2: System level
ce3: Sets the CE3 interface to work in channelized mode.
e3: Sets the CE3 interface to work in unchannelized mode.
Use the using command to configure the operating mode of the CE3 interface.
Use the undo using command to restore the default, that is, channelized mode.
Only when the CE3 interface is working in channelized mode can you configure E1 lines.
When the CE3 interface is working in unchannelized mode, the system automatically creates a serial interface numbered serial number/0:0 for it. This interface operates at 34.368 Mbps and is logically equivalent to a synchronous serial interface on which you can make other configurations.
# Configure interface E3 2/0 to operate in unchannelized mode.
Basic CT3 Interface Configuration Commands
alarm (CT3 interface)
alarm { detect | generate { ais | febe | idle | rai } }
undo alarm { detect | generate { ais | febe | idle | rai } }
View
CT3 interface view
Default Level
2: System level
detect: Enables/disables periodical alarm signal detection. By default, periodical alarm detection is enabled.
generate: Sends alarm signals, which can be AIS, RAI, idle, or FEBE for line state test. By default, alarm signal sending is disabled.
ais: Alarm indication signal.
febe: Far end block error signal.
idle: Idle signal.
rai: Remote alarm indication signal.
Use the alarm command to enable the CT3 interface to detect/send alarm signals.
Use the undo alarm command to remove the alarm signal detection/sending setting.
At the startup of your device, periodical alarm signal detection is enabled on the CT3 interface. When detecting LOS, LOF, or AIS signals, the interface sends RAI signals to its peer. Alarm state report for the interface is real time; you may view that by performing the display controller t3 command.
The supported alarm signals, LOS, LOF, AIS, RAI, FEBE, and idle, are ANSI T1.107-1995 compliant.
You can only configure the CT3 interface to send a type of alarm signal. To have the interface send another type of signal, use the undo alarm command to remove the previous setting first. In addition, when the RAI signal generated upon detection of the LOS, LOF, or AIS signal is present, the CT3 interface cannot send another type of signal. To do that, use the undo alarm detect command to disable the CT3 interface to send the RAI signal generated after detecting an alarm first.
# Enable periodical alarm signal detection on CT3 interface T3 2/0.
[Sysname] controller t3 2/0
[Sysname-T3 2/0] alarm detect
# Enable CT3 interface T3 2/0 to send AIS alarm signals.
[Sysname-T3 2/0] alarm generate ais
bert (CT3 interface)
undo bert
View
CT3 interface view
Default Level
2: System level
pattern: Sets a bit error rate test (BERT) pattern, which could be 2^7, 2^11, 2^15, or QRSS.
2^7: Two to the seventh power, length of the transmitted BERT pattern in bits.
2^11: Two to the eleventh power, length of the transmitted BERT pattern in bits.
2^15: Two to the fifteenth power, length of the transmitted BERT pattern in bits.
qrss: Two to the twentieth power, length of the transmitted BERT pattern in bits. In this pattern, the presence of 14 consecutive zeros is not allowed.
time number: Sets the duration of a BERT test, in the range 1 to 1440 minutes.
unframed: Sets the test pattern to cover the overhead bits of the frame.
Use the bert command to start a BERT test on the CT3 interface.
Use the undo bert command to stop the BERT test running on the CT3 interface.
By default, no BERT test is performed.
ITU O.151, ITU O.153, and ANSI T1.403-1999 define many BERT patterns, among which, the CT3 interface supports only 2^7, 2^11, 2^15, and QRSS at present.
When running a BERT test, the local end sends out a pattern, which is to be looped over somewhere on the line and back to the local end. The local end then checks the received pattern for bit error rate, and by so doing helps you identify whether the condition of the line is good. To this end, you must configure loopback to allow the transmitted pattern to loop back from somewhere on the line, for example, from the far-end interface by placing the interface in far-end loopback.
You may view the state and result of the BERT test with the display controller t3 command.
# Run a 10-minute QRSS BERT test on CT3 interface T3 2/0.
[Sysname-T3 2/0] bert pattern qrss time 10
cable (CT3 interface)
cable feet
undo cable
View
CT3 interface view
Default Level
2: System level
feet: Cable length in the range 0 to 450 feet (0 to 137.2 meters).
Use the cable command to configure the cable length on the CT3 interface.
Use the undo cable command to restore the default, that is, 49 feet (14.9 meters).
The cable length in this command refers to the distance between the router and the cable distribution rack.
# Set the cable length to 50 feet (15.2 meters) on interface T3 2/0.
[Sysname-T3 2/0] cable 50
clock (CT3 interface)
undo clock
View
CT3 interface view
Default Level
2: System level
Use the clock command to configure clock source for the CT3 interface.
The clock source is selected depending on the connected remote device. If connected to a transmission device, the local end uses the line clock. If connected to a CT3 interface on another router, the local end can use whichever clock so long as it is different from the one adopted at the remote end.
# Use the internal clock as the clock source on CT3 interface T3 2/0.
[Sysname-T3 2/0] clock master
controller t3
controller t3 interface-number
View
Default Level
2: System level
interface-number: CT3 interface number.
Use the controller t3 command to enter CT3 interface view.
Related commands: display controller t3.
# Enter the view of interface T3 2/0.
[Sysname-T3 2/0]
crc
undo crc
View
Default Level
2: System level
16: Adopts 16-bit CRC.
Use the crc command to configure CRC mode for the serial interface formed on CT3 interfaces.
Related commands: t1 channel-set, t1 unframed, using.
# Apply 32-bit CRC to a serial interface formed on interface T3 2/0 in unchannelized mode.
[Sysname-T3 2/0] using t3
[Sysname-T3 2/0] quit
# Apply 16-bit CRC to a serial interface formed on interface CT3 2/0 in channelized mode.
[Sysname-T3 2/0] t1 2 channel-set 4 timeslot-list 5-11
[Sysname] interface serial 2/0/2:4
[Sysname-Serial2/0/2:4] crc 16
description (CT3 interface)
View
CT3 interface view
Default Level
2: System level
Use the description command to configure the description of the current CT3 interface.
By default, the description of a CT3 interface is the interface name followed by the interface string, T3 2/0 Interface for example.
# Configure the description of T3 2/0 as T3-interface.
[Sysname-T3 2/0] description T3-interface
display controller t3 [ interface-number ]
View
Default Level
1: Monitor level
interface-number: CT3 interface number. In conjunction with the t3 keyword, it specifies a CT3 interface.
Use the display controller t3 command to display state information about one specified or all CT3 interfaces.
In addition to the state information about the CT3 interface, the command displays information about each T1 line on the CT3 interface if the interface is working in CT3 mode.
# Display information about interface T3 2/0.
<Sysname> display controller t3 2/0
T3 2/0 current state :UP
Description : T3 2/0 Interface
sic Configuration:
Work mode is CT3, cable length is 49 feet.
Frame-format is C-BIT Parity, line code is B3ZS.
Source clock is slave, loopback is not set.
Alarm state:
Receiver alarm state is none.
MDL state:
No message is sent now.
Message data elements:
EIC: line, LIC: line, FIC: line, UNIT: line
FI: line, PORT_NO: line, GEN_NO: line
Periodical detection is disabled.
FEAC state:
No code is sent now.
Periodical detection is enabled, no code received now.
Test pattern: 2^7, Status: Not Sync, Sync Detected: 0
Bit errors (since test started): 0 bits
Bits received (since test started): 0 Mbits
Bit errors (since latest sync): 0 bits
Bits received (since latest sync): 0 Mbits
Last clearing of counters: 14:39:02 UTC Sat 06/25/2005
Data in current interval (22 seconds elapsed):
0 Line Code Violations, 0 Far End Block Error
0 C-Bit Coding Violation, 0 P-bit Coding Violation
0 Framing Bit Err, 0 Severely Err Framing Secs
0 C-bit Err Secs, 0 C-bit Severely Err Secs
0 P-bit Err Secs, 0 P-bit Severely Err Secs
0 Unavailable Secs, 0 Line Err Secs
T3 2/0 CT1 1 is up
Frame-format ESF, clock slave, loopback not set
FDL Performance Report is disabled
Transmitter is sending none
Line loop back deactivate code using inband signal last sent
Test pattern: 2^11, Status: Not Sync, Sync Detected: 0
Bits received (since test started): 0 Kbits
Bits received (since latest sync): 0 Kbits
Table 1-6 display controller t3 command output description
T3 2/0 current state |
Physical state of the interface: up or down |
Description : T3 2/0 Interface |
Description about the interface |
Basic Configuration |
Basic configurations of the interface |
Work mode |
Operating mode of the interface, CT3 or T3. |
cable length |
Cable length supported by the interface |
Frame-format |
Frame format: C-bit parity or M23 |
line code |
In this output sample, line code is B3ZS. |
Source clock |
Clock source used by the interface: master for the internal clock or slave for the line clock |
loopback |
Loopback setting on the interface: local, remote, payload, or not set |
Alarm State |
Alarm state |
Receiver alarm state |
Type of the received alarm: none, LOS, LOF, RAI, or AIS. If a LOS, LOF, AIS was received, RAI would be sent and the screen displayed “Transmitter is sending RAI” instead. |
MDL state |
MDL state |
No message is sent now. |
No MDL message is being sent. If an MDL message, path or idle-signal for example, was being sent, the screen would display “Message sent now: path. idle signal.” |
Message data elements |
MDL data elements |
EIC: line, LIC: line, FIC: line, UNIT: line |
EIC, LIC, FIC, and UNIT are four elements present in all types of MDL messages. Their values are user configurable and default to line. |
FI: line, PORT_NO: line, GEN_NO: line |
FI is found in MDL path messages, PORT_NO in MDL idle signal messages, and GEN_NO in MDL test signal messages. Their values are user configurable and default to line. |
Periodical detection |
State of periodical detection of MDL, disabled by default at the startup of the router. When the function is enabled, the screen displays: Periodical detection is enabled. No message was received. When MDL messages are detected, the screen displays: Message received now: path.idle signal. EIC: line, LIC: line, FIC: line, UNIT: line path/FI: line idle Signal/PORT_NO: line |
FEAC state |
FEAC state |
No code is sent now. DS3 Line Loop Back Deactivate was last sent. |
No FEAC signal is sent. The FEAC signal sent last time is DS3 Line Loop Back Deactivate. |
Periodical detection is enabled, no code received now. |
Periodical detection of FEAC is enabled. This is the default applied at the startup of the router. No FEAC signal is received now. |
DS3 Line Loop Back Deactivate last received. |
The FEAC signal received last time is DS3 Line Loop Back Deactivate. |
BERT state:(stopped, not completed) |
BERT state: completed, stopped (not completed), or running. |
Test pattern: 2^7, Status: Not Sync, Sync Detected: 0 |
Test pattern in use (such as 2^7, 2^11, 2^15, and QRSS), 2^7 in this sample output; synchronization state, and the number of detected synchronizations |
Time: 0 minute(s), Time past: 0 minute(s) |
The duration of the BERT test and the time that has elapsed |
Bit errors (since test started): 0 bits |
Number of bit errors received since the start of the BERT test |
Bits received (since test started) |
Number of bits received since the start of the BERT test |
Bit errors (since latest sync) |
Number of bit errors received since last synchronization |
Bits received (since latest sync) |
Number of bits received since last synchronization |
Historical Statistics |
Historical statistics |
Last clearing of counters |
Time when last counter clearing is performed, for example, 14:39:02 UTC Sat 06/25/2005. If no clearing is performed, “Never” is displayed. |
Data in current interval: Line Code Violations Far End Block Error C-Bit Coding Violation P-bit Coding Violation Framing Bit Err Severely Err Framing Secs C-bit Err Secs C-bit Severely Err Secs P-bit Err Secs P-bit Severely Err Secs Unavailable Secs Line Err Secs |
Statistics spanning the current 15-minute interval, coving the counts of these items: Line code violations: BPV, or EXZ Far-end block error C-bit coding violation P-bit coding violation Framing bit error C-bit erroneous second C-bit severely erroneous second, that is, the second during which 44 C-bit errors occur P-bit erroneous second P-bit severely erroneous second, that is, the second during which 44 P-bit errors occur Service unavailable second Line erroneous second, during which LOS, BPV, EXZ, C-bit, P-bit, and other errors occur |
Data in Interval 1 |
Data in interval 1 |
Total Data (last 17 15 minute intervals) |
Total data spanning the last 17 intervals |
T3 2/0 CT1 1 is up |
State of T1 line on the CT3 interface: up or down. In this output sample, T1 line 1 is up. |
Frame-format ESF, clock slave, loopback not set |
Information about the T1 line: Framing format—ESF or SF Clock source—slave for the line clock and master for the internal clock Loopback—Local, remote, payload, or not set |
FDL Performance Report is disabled |
Transmission of PPR in the FDL is disabled. You may enable that with the t1 set fdl ansi command. |
Transmitter is sending RAI |
The transmitter of the T1 line is sending RAI signals. When the T1 line receives LOS, LOF, or AIS signals, it sends RAI signals. |
Receiver alarm state is LOF |
The type of alarm signal that the T1 line can receive: LOS, LOF, AIS, or RAI |
Line loop back activate code using inband signal last sent |
The loopback code sent last time is in-band LLB activation request code. |
BERT state |
BERT test state: running, complete, or stopped (not completed) |
Test pattern Status Sync Detected |
Test pattern in use, 2^11 in this sample output; synchronization state, and the number of detected synchronizations |
Time Time past |
Bit errors (since test started) |
Number of bit errors received since the last synchronization |
Number of bits received since the last synchronization |
feac
feac { detect | generate { ds3-los | ds3-ais | ds3-oof | ds3-idle | ds3-eqptfail | loopback { ds3-line | ds3-payload } } }
undo feac { detect | generate { ds3-los | ds3-ais | ds3-oof | ds3-idle | ds3-eqptfail | loopback { ds3-line | ds3-payload } } }
View
CT3 interface view
Default Level
2: System level
detect: Enables periodical far end and control signal (FEAC) channel signal detection. By default, periodical FEAC channel signal detection is enabled.
generate: Sends FEAC signals. Specify ds3-los for DS3 LOS, ds3-ais for DS3 AIS, ds3-oof for DS3 out of frame (OOF), ds3-idle for DS3 idle, and ds3-eqptfail for DS3 equipment failure. By default, FEAC signal sending is disabled.
loopback: Sends loopback code for activating far-end line loopback with the ds3-line keyword or payload loopback with the ds3-payload keyword. By default, loopback code sending is disabled.
Use the feac command to enable FEAC channel signal detection and sending on the CT3 interface.
Use the undo feac command to remove the current FEAC settings.
FEAC is a channel formed by using the third C-bit in the first subframe in C-bit framing. It is used to transmit alarm state signals for line test purpose or to transmit loopback control code for activating or deactivating far-end loopback during a loopback test.
According to ANSI T1.107a, the frame format used by FEAC channels is bit oriented protocol (BOP).
At the startup of your router, FEAC channel signal detection is enabled on the CT3 interface with FEAC signal sending disabled.
After far-end loopback is activated with the feac generate loopback { ds3-line | ds3-payload } command, you may remove it with the undo form of the command.
Disable FEAC detection before you configure far-end loopback to prevent loopback deadlock, which may happen when the local end enables loopback after detecting the loopback code sent back by the far end.
You may view the transmitting/receiving state of the FEAC channel with the display controller t3 command.
# Enable FEAC channel signal detection on CT3 interface T3 2/0.
[Sysname-T3 2/0] feac detect
# Sends DS3 LOS signal on CT3 interface T3 2/0.
[Sysname-T3 2/0] feac generate ds3-los
# On CT3 interface T3 2/0, send loopback code to the far end to place the far end in a line loopback.
[Sysname-T3 2/0] feac generate loopback ds3-line
frame-format (CT3 interface)
frame-format { c-bit | m23 }
undo frame-format
View
CT3 interface view
Default Level
2: System level
c-bit: Sets the framing format to C-bit.
m23: Sets the framing format to m23.
Use the frame-format command to configure the framing format used by the CT3 interface.
Use the undo frame-format command to restore the default, that is, C-bit framing format.
# Set the framing format of interface T3 2/0 to m23.
[Sysname-T3 2/0] frame-format m23
ft3
ft3 { dsu-mode { 0 | 1 | 2 | 3 | 4 } | subrate number }
undo ft3 { dsu-mode | subrate }
View
CT3 interface (in FT3 mode) view
Default Level
2: System level
dsu-mode: Specifies the FT3 (Fractional T3) DSU mode for a CT3 interface operating in FT3 mode. This keyword can be followed by 0, 1, 2, 3, and 4, as described below:
0, meaning the Digital Link mode, where the subrate is a multiple of 300746 bps and ranges from 300 to 44210 kbps (that is, up to 147 rate levels are available).
1, meaning the Kentrox mode, where the subrate is a multiple of 1500000 bps and ranges from 1500 to 35000 kbps. In this mode, the subrate can also be 44210 kbps (making a total of 57 subrate levels).
2, meaning the Larscom mode, where the subrate is a multiple of 3157835 bps and ranges from 3100 to 44210 kbps (that is, up to 14 subrate levels are available).
3, meaning the Adtran mode, where the subrate is a multiple of 75187 bps and ranges from 75 to 44210 kbps (that is, up to 588 subrate levels are available).
4, meaning the Verilink mode, where the subrate is a multiple of 1578918 bps and ranges from 1500 to 44210 kbps (that is, up to 20 subrate levels are available).
subrate number: Specifies the subrate for the CT3 interface. The number argument ranges from 1 to 44210 (in kbps).
Use the ft3 command to configure a CT3 interface to operate in the FT3 mode and set the DSU mode or the subrate.
Use the undo ft3 command to restore the default.
By default, DSU mode 0 (the Digital Link mode) is adopted, and the subrate is 44210 kbps.
FT3 (Fractional T3 or Subrate T3) mode is a non-standard E3 application mode. In this mode, the subrate level setting varies with vendors. You can use the ft3 command to make the device to be compatible with devices of other vendors operating in specific FT3 DSU modes.
Note that:
l This command is only applicable to CT3 boards that support FT3.
l This command is only available in CT3 mode.
l As for the ft3 subrate command, the actual subrate usually is not exactly the one set by the command. That is, after you set the subrate by using the ft3 subrate command, the T3 interface searches the subrate levels corresponding to the DSU mode it is operating in and selects the one that is closest to that set by the command as its subrate. The device then adjusts the hardware to allow for the subrate.
l You can use the display interface serial interface-number:0 command to check the DSU mode setting, the subrate, the actual rate, and the baudrate of a CT3 interface. Note that the actual rate does not count in the overhead bits, and the baudrate is the actual T3 line rate (that is, 44736 kbps), with the overhead bits counted in.
# Configure T3 2/0 interface to operate in the FT3 mode, setting the DSU mode to 1 and the subrate to 3000 kbps.
[Sysname-T3 2/0] ft3 dsu-mode 1
[Sysname-T3 2/0] ft3 subrate 3000
loopback (CT3 interface)
undo loopback
View
CT3 interface view
Default Level
2: System level
local: Enables internal loopback on the CT3 interface.
payload: Enables external payload loopback on the CT3 interface.
remote: Enables external loopback on the CT3 interface.
Use the loopback command to configure the loopback mode for a CT3 interface.
Use the undo loopback command to disable loopback.
By default, loopback is disabled on CT3 interfaces.
If a CT3 interface encapsulated with PPP is placed in a loopback, it is normal that the state of the link layer protocol is reported down.
# Enable internal loopback on interface T3 2/0.
[Sysname-T3 2/0] loopback local
mdl (CT3 interface)
mdl { data { eic string | fic string | | gen-no string | lic string | pfi string | port-no string | unit string } | detect | generate { idle-signal | path | test-signal } }
undo mdl [ data [ eic | fic | gen-no | lic | pfi | port-no | unit ] | detect | generate [ idle-signal | path | test-signal ] ]
View
CT3 interface view
Default Level
2: System level
detect: Enables/disables periodical maintenance data link (MDL) message detection.
data: Specifies the information included in MDL messages. Among all types of information, EIC, LIC, FIC, and unit are defined for all types of MDL messages; PFI is only for path MDL messages; port number is only for idle signal messages; and generator number is only for test signal messages.
eic string: Specifies the equipment identification code, a string of 1 to 10 characters. The system default is line.
fic string: Specifies the frame identification code, a string of 1 to 10 characters. The system default is line.
gen-no string: Specifies the generator number, a string of 1 to 38 characters. The system default is line.
lic string: Specifies the location identification code, a string of 1 to 11 characters. The system default is line.
pfi string: Specifies the path facility identification, a string of 1 to 38 characters. The system default is line.
port-no string: Specifies the port number in idle signal message, a string of 1 to 38 characters. The system default is line.
unit string: Specifies the unit, a string of 1 to 6 characters. The system default is line.
generate: Sends specified information with MDL messages, which can be path, idle signal, and/or test signal regularly.
Use the mdl command to configure MDL message detection/sending on the CT3 interface.
Use the undo mdl command to remove the MDL settings.
Use the undo mdl detect command to disable the CT3 interface from detecting MDL messages.
Use the undo mdl generate command to disable the CT3 interface from sending MDL messages.
Use the undo mdl data command to restore the default.
MDL is a channel formed by using the three C-bits in the fifth subframe in C-bit framing. According to ANSI T1.107a, it is used to transmit three types of maintenance messages, path, idle signal, and test signal, and its data frame format is LAPD.
At the startup of your router, MDL message detection and sending are disabled on CT3 interfaces and the default MDL message information applies.
# Enable MDL detection on CT3 interface T3 2/0.
[Sysname-T3 2/0] mdl detect
# Set LIC to “hello” for CT3 interface T3 2/0.
[Sysname-T3 2/0] mdl data lic hello
# Send path messages on CT3 interface T3 2/0.
[Sysname-T3 2/0] mdl generate path
reset counters controller t3
reset counters controller t3 interface-number
View
Default Level
2: System level
interface-number: Interface number.
Use the reset counters controller t3 command to clear the controller counter of the specified CT3 interface.
You can use the display controller t3 command to display the statistics collected by the controller counters of CT3 interfaces.
The reset counters interface command clears the counters of all interfaces. To clear the controller counter of individual CT3 interfaces, use the reset counters controller t3 command.
# Clear the controller counter of the CT3 interface E3 2/0.
<Sysname> reset counters controller t3 2/0
shutdown (CT3 interface)
shutdown
View
CT3 interface view
Default Level
2: System level
None
Use the shutdown command to shut down the current CT3 interface.
Use the undo shutdown command to bring up the current CT3 interface.
By default, a CT3 interface is enabled.
# Shut down T3 2/0.
[Sysname-T3 2/0] shutdown
t1 alarm
t1 line-number alarm { detect | generate { ais | rai } }
undo t1 line-number alarm { detect | generate { ais | rai } }
View
CT3 interface view
Default Level
2: System level
line-number: T1 line number, in the range 1 to 28.
generate: Sends alarm signals, AIS or RAI, for line state test. By default, alarm signal sending is disabled.
Use the t1 alarm command to enable the specified T1 line on the CT3 interface to detect/send alarm signals.
Use the undo t1 alarm command to remove the alarm signal detection/sending setting.
At the startup of the router, periodical alarm signal detection is enabled on all T1 lines on the CT3 interface. When a T1 line detects LOS, LOF, or AIS signals, it sends RAI signals to its peer. Alarm state report for the interface is real time; you may view that with the display controller t3 command.
The supported alarm signals, LOS, LOF, AIS, RAI, FEBE, and idle, are ANSI T1.403 compliant.
You can configure a T1 line to send only a type of alarm signal. To have the channel send another type of signal, use the undo t1 alarm command to remove the previous setting first. In addition, when the RAI signal generated upon detection of the LOS, LOF, or AIS signal is present, the T1 line cannot send another type of signal. To do that, use the undo t1 alarm detect command to disable the T1 line to send the RAI signal generated after detecting an alarm first.
# Enable periodical alarm signal detection on T1 line 1 on CT3 interface T3 2/0.
[Sysname-T3 2/0] t1 1 alarm detect
# Enable T1 line 1 on CT3 interface T3 2/0 to send AIS alarm signals.
[Sysname-T3 2/0] t1 1 alarm generate ais
t1 bert
t1 line-number bert pattern { 2^11 | 2^15 | 2^20 | 2^23 | qrss } time number [ unframed ]
undo t1 line-number bert
View
CT3 interface view
Default Level
2: System level
pattern: Sets a BERT pattern, which could be 2^11, 2^15, 2^20, 2^23, or QRSS.
2^20: Two to the twentieth power, length of the transmitted BERT pattern in bits.
2^23: Two to the twenty third power, length of the transmitted BERT pattern in bits.
qrss: Two to the twentieth power, length of the transmitted BERT pattern in bits. In this pattern, the presence of 14 or more consecutive zeros is not allowed.
time number: Sets the duration of a BERT test, in the range of 1 to 1440 minutes.
Use the t1 bert command to start a BERT test on the specified T1 line on the CT3 interface.
Use the undo t1 bert command to stop the BERT test running on the specified T1 line on the CT3 interface.
ITU O.151, ITU O.153, and ANSI T1.403-1999 define many BERT patterns, among which, T1 lines on CT3 interfaces support only 2^11, 2^15, 2^20, 2^23, and QRSS at present.
When running a BERT test, the local end sends out a pattern, which is to be looped over somewhere on the line and back to the local end. The local end then checks the received pattern for the bit error rate, and by so doing helps you determine whether the condition of the line is good. To this end, you must configure loopback to allow the transmitted pattern to loop back from somewhere on the line, for example, from the far-end interface by placing the interface in far-end loopback.
# Run a 10-minute QRSS BERT test on T1 line 1 on CT3 interface T3 2/0.
[Sysname-T3 2/0] t1 1 bert pattern qrss time 10
t1 channel-set
t1 line-number channel-set set-number timeslot-list list [ speed { 56k | 64k } ]
undo t1 line-number channel-set set-number
View
CT3 interface view
Default Level
2: System level
line-number: T1 line number in the range 1 to 28.
set-number: Number of a channel set formed from a timeslot bundle on the T1 line. It ranges from 0 to 23.
timeslot-list list: Specifies the timeslots to be bundled. The list argument can contain multiple timeslot numbers, each of which ranges from 1 to 24. You can specify a single timeslot by specifying a timeslot number, a range of timeslots by providing this argument in the form of { number1-number2 }, or multiple timeslots by providing this argument in the form of { number1, number2-number3 }.
speed { 56k | 64k }: Speed of the timeslot bundle (the channel set) in kbps. If 56k is selected, the timeslots is bundled into an N × 56 kbps bundle. If 64k, the default, is selected, the timeslots is bundled into an N × 64 kbps bundle.
Use the t1 channel-set command to bundle specified timeslots into a channel set on a T1 line.
Use the undo t1 channel-set command to remove the specified channel set.
By default, no channel set is created.
When a T1 line is operating in framed (CT1) mode, you can bundle timeslots on it. For each channel set thus formed, the system automatically creates a serial interface numbered serial number/line-number:set-number. This interface operates at N × 64 kbps (or N × 56 kbps) and is logically equivalent to a synchronous serial interface on which you can make other configurations.
Related commands: t1 unframed.
# Create a 128 kbps serial interface through timeslot bundling on the first T1 line on interface T3 2/0.
[Sysname-T3 2/0] t1 1 channel-set 1 timeslot-list 1,2
t1 sendloopcode
t1 line-number sendloopcode { fdl-ansi-line-up | fdl-ansi-payload-up | fdl-att-payload-up | inband-line-up }
undo t1 line-number sendloopcode { fdl-ansi-line-up | fdl-ansi-payload-up | fdl-att-payload-up | inband-line-up }
View
CT3 interface view
Default Level
2: System level
fdl-ansi-line-up: Sends ANSI-compliant LLB activation request code in the FDL to start remote loopback.
fdl-ansi-payload-up: Sends ANSI-compliant PLB activation request code in the FDL to start remote loopback.
fdl-att-payload-up: Sends AT&T-compliant PLB activation request code in the FDL to start remote loopback.
inband-line-up: Sends in-band LLB activation request code compliant with the ANSI and AT&T implementation to start remote loopback.
Use the t1 sendloopcode command to set the loopback mode of the specified far-end T1 line.
Use the undo t1 sendloopcode command to remove the corresponding setting.
Loopback is an effective way of diagnosis. You may place a far-end device into loopback mode either at command line on it or by sending loopback control code to it. The types and formats of loopback control code supported on T1 interfaces are compliant with ANSI T1.403.
Loopback can be divided into line loopback and payload loopback. They differ in the sense that the data stream is looped back at the framer with line loopback but not with payload loopback.
You may transmit loopback control code by using the in-band signal (the 192 effective bandwidth bits or all 193 bits of T1) or the FDL in ESF frames.
# Send the in-band signal on T1 line 1 on CT3 interface T3 2/0 to place the far-end T1 line in line loopback mode.
[Sysname-T3 2/0] t1 1 sendloopcode inband-line-up
t1 set clock
t1 line-number set clock { master | slave }
undo t1 line-number set clock
View
CT3 interface view
Default Level
2: System level
master: Adopts the internal clock as the clock source on the T1 line.
slave: Adopts the line clock as the clock source on the T1 line.
Use the t1 set clock command to configure clock source for a T1 line on the CT3 interface.
Use the undo t1 set clock command to restore the default, that is, line clock.
When a CT3 interface is working in channelized mode, its T1 lines may use separate clocks.
# Use the internal clock as the clock source on the first T1 line on interface T3 2/0.
[Sysname-T3 2/0] t1 1 set clock slave
t1 set frame-format
t1 line-number set frame-format { esf | sf }
undo t1 line-number set frame-format
View
CT3 interface view
Default Level
2: System level
esf: Set the T1 line to use the ESF format.
sf: Set the T1 line to use the SF format.
Use the t1 set frame-format command to configure the framing format of a T1 line.
Use the undo t1 set frame-format command to restore the default, that is, ESF.
You can configure this command only when the T1 line is working in framed format (which can be set by using the undo t1 unframed command).
# Set the framing format to SF for the first T1 line on interface T3 2/0.
[Sysname-T3 2/0] t1 1 set frame-format sf
t1 set loopback
t1 line-number set loopback { local | remote | payload }
undo t1 line-number set loopback
View
CT3 interface view
Default Level
2: System level
local: Sets the T1 line in internal loopback mode.
remote: Sets the T1 line in external loopback mode.
remote: Sets the T1 line in payload loopback mode.
Use the t1 set loopback command to set the loopback mode of a T1 line on the T3 interface.
Use the undo t1 set loopback command to disable the T1 line to loop back.
By default, loopback is disabled on T1 lines.
If a T1 line encapsulated with PPP is placed in loopback mode, it is normal that the state of the link layer protocol is reported down.
# Enable internal loopback on the first T1 line on interface T3 2/0.
[Sysname-T3 2/0] t1 1 set loopback local
t1 set fdl
t1 line-number set fdl { ansi | att | both | none}
undo t1 line-number set fdl
View
CT3 interface view
Default Level
2: System level
fdl: Sets the FDL format of T1.
att: Adopts AT&T TR 54016 for FDL.
both: Adopts both ANSI T1.403 and AT&T TR 54016 for FDL.
none: Disables the use of FDL on the T1 line.
Use the t1 set fdl command to set the behavior of the specified T1 line on the FDL in ESF framing.
Use the undo t1 set fdl command to disable FDL of T1.
FDL is an embedded 4 kbps overhead channel within the ESF format for transmitting periodical performance report (PPR) statistics or loopback code.
According to ANSI T1.403, the format of PPR is LAPD, and the format of loopback code is BOP.
The t1 set fdl command only starts PPR transmission. It cannot enable loopback code transmission or detection.
These two commands only apply to channelized T1 lines with their T1 frame format being ESF.
# Set the FDL to be ANSI T1.403 compliant for T1 line 1 on CT3 interface T3 2/0.
[Sysname-T3 2/0] t1 1 set fdl ansi
t1 show
t1 line-number show
View
CT3 interface view
Default Level
2: System level
show: Displays the physical line state of the specified T1 line.
Use the t1 show command to have a quick look at the line state of the specified T1 line on the CT3 interface.
# Display line state of T1 line 1 on CT3 interface T3 2/0.
[Sysname] interface t3 2/0
[Sysname-T3 2/0] t1 1 show
T3 2/0 CT1 1 is up
Table 1-7 t1 show command output description
The state of T1 line 1 on the CT3 interface: up or down |
Frame-format ESF |
Framing format of T1: ESF or SF |
clock slave |
Clock source used by the T1 line: slave for the line clock or master for the internal clock |
loopback not set |
Loopback state or mode: local, remote, payload, or not set. |
The type of alarm signal that the T1 line can receive: LOS, LOF, AIS, or RAI. |
BERT state |
Test pattern in use, 2^11 in this example; synchronization state, and the number of detected synchronizations |
Time Time past |
t1 shutdown
t1 line-number shutdown
undo t1 line-number shutdown
View
CT3 interface view
Default Level
2: System level
Use the t1 shutdown command to shut down a T1 line on the CT3 interface.
Use the undo t1 shutdown command to bring up a T1 line.
By default, T1 lines are up.
This command shuts down not only the specified T1 line but also the serial interfaces formed on it. Data transmission and receiving will stop as a result. Likewise, the undo t1 shutdown command can bring up all these serial interfaces.
# Shut down the first T1 line on interface T3 2/0.
[Sysname-T3 2/0] t1 1 shutdown
t1 unframed
t1 line-number unframed
undo t1 line-number unframed
View
CT3 interface view
Default Level
2: System level
Use the t1 unframed command to set a T1 line on the CT3 interface to work in unframed mode (T1 mode).
Use the undo t1 unframed command to set the T1 line on the CT3 interface to work in framed mode (CT1 mode).
By default, T1 lines are working in framed mode.
A T1 line in unframed mode does not contain the frame control information; it cannot be divided into timeslots. For it, the system automatically creates a serial interface numbered serial number/line-number:0. This interface operates at 1544 kbps and is logically equivalent to a synchronous serial interface on which you can make other configurations.
Related commands: t1 channel-set.
# Set the first T1 line on interface T3 2/0 to work in unframed mode.
[Sysname-T3 2/0] t1 1 unframed
using (CT3 interface)
using { ct3 | t3 }
View
CT3 interface view
Default Level
2: System level
ct3: Sets the CT3 interface to operate in channelized mode.
t3: Sets the CT3 interface to operate in unchannelized mode.
Use the using command to configure the operating mode of a CT3 interface.
You can configure T1 lines on CT3 interfaces operating in channelized mode only.
When a CT3 interface operates in unchannelized mode, the system automatically creates a serial interface numbered serial number/0:0 for it. This interface operates at 44.736 Mbps and is logically equivalent to a synchronous serial interface on which you can make other configurations.
# Configure interface T3 2/0 to operate in unchannelized mode.
