H3Care Total Implementation
15-11-2019H3C provides the Total Implementation to fulfill network construction, expansion and reconstruction. For the Total Implementation, H3C will designate a project manager and senior engineers to guide the first-line work.
(1)Major contents:
Project management | Hardware installation |
> Human resources management > Implementation progress management > Project management plan > Project coordination meeting | > Project survey for installation sites > Hardware environment check for installation sites > Hardware installation scheme > Onsite hardware installation |
Software debugging | Project document |
> Joint debugging solution making > Software version provision > Parameter configuration > Cutover solution | Project Information Table H3C Project Quality Check Standard Technical Implementation Summary Report H3C Routine Equipment Maintenance Proposal |
Project acceptance | |
> Acceptance plan making > Technical specification provision > Project acceptance solution > Project acceptance implementation |
(2)Implementation process:
