- 01-Fundamentals Command Reference
- About the WX Series Access Controllers Command References
- H3C WX Series Access Controllers Documentation Navigator-6W100
- H3C WX Series Access Controllers Getting Started Guide-6W100
- H3C WX3000 Series Unified Switches Switching Engine Configuration Guide-6W103
- H3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
Preface
The H3C WX Series Access Controllers Web-Based Configuration Guide describes the web functions of the WX series, such as quick start, web overview, wireless service configuration, security and authentication related configurations, QoS configuration, and advanced settings.
This preface includes:
l Audience
l About the H3C WX Sereis Documentation Set
Audience
l Network planners
l Field technical support and servicing engineers
l Network administrators working with the WX series
Conventions
This section describes the conventions used in this documentation set.
GUI conventions
Convention | Description |
Boldface | Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
> | Multi-level menus are separated by angle brackets. For example, File > Create > Folder. |
Symbols
Means reader be extremely careful. Improper operation may cause bodily injury. | |
Means reader be careful. Improper operation may cause data loss or damage to equipment. | |
Means an action or information that needs special attention to ensure successful configuration or good performance. | |
Means a complementary description. | |
Means techniques helpful for you to make configuration with ease. |
Network topology icons
Represents a generic network device, such as a router, switch, or firewall. | |
Represents a routing-capable device, such as a router or Layer 3 switch. | |
Represents a generic switch, such as a Layer 2 or Layer 3 switch, or a router that supports Layer 2 forwarding and other Layer 2 features. | |
Represents an access controller, an access controller module, or a switching engine on a unified switch. | |
Represents an access point. | |
Represents a mesh access point. | |
Represents omnidirectional signals. | |
The H3C WX Series documentation set includes:
Category | Documents | Purposes |
Product description and specifications | Describe product specifications and benefits. | |
Hardware specifications and installation | Provide the hardware specifications of the cards, and describe how to install and remove the cards. | |
Guide you through hardware specifications and installation methods to help you install your AC. | ||
Software configuration | Guide you through the main functions of your AC, and describes how to install and log in to your AC, perform basic configurations, maintain software, and troubleshoot your AC. | |
Describe software features and configuration procedures. | ||
Provide a quick reference to all available commands. | ||
Describes configuration procedures through the web interface. | ||
Operations and maintenance | Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. | |
Obtaining Documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, getting started, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical Support
http://www.h3c.com
Documentation Feedback
We appreciate your comments.
l The H3C WX series access controller products include H3C access controllers, access controller modules, and H3C WX series unified switches' access controller engines. Support of the H3C WX series access controllers for features and commands may vary by device model. For more information, see "Feature Matrixes" in Compatibility Matrixes.
l The WX3000 series includes the WX3024, WX3010, and WX3008 unified switches.
l The WX5000 series includes the WX5002, WX5002V2, and WX5004 access controllers, and the LS8M1WCMA0, LSWM1WCM10, and LSWM1WCM20 access controller modules.
l The WX6000 series includes the WX6103 access controllers, and the LSQM1WCMB0, LSBM1WCM2A0, and LSRM1WCM2A1 access controller modules.
l The models listed in this manual are not applicable to all regions. Please consult your local sales office for the models applicable to your region.
