Title | Size | Downloads |
H3C WX Series Access Controllers Getting Started Guide-6W100-book(CHM).rar | 46.49 KB | |
H3C WX Series Access Controllers Getting Started Guide-6W100-book.pdf | 243.86 KB |
- 01-Fundamentals Command Reference
- About the WX Series Access Controllers Command References
- H3C WX Series Access Controllers Documentation Navigator-6W100
- H3C WX Series Access Controllers Web-Based Configuration Guide-6W105
- H3C WX3000 Series Unified Switches Switching Engine Configuration Guide-6W103
- H3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
Preface
The H3C WX Series Access Controllers Getting Started Guide describes the installation preparations, login, command line interface (CLI), basic configurations, software maintenance, and troubleshooting of the H3C WX series access controllers.
This preface includes:
l Audience
l About the H3C WX Series Documentation Set
Audience
l Network planners
l Field technical support and servicing engineers
l Network administrators working with the H3C WX series
Conventions
This section describes the conventions used in this documentation.
Command conventions
Convention | Description |
Boldface | Bold text represents commands and keywords that you enter literally as shown. |
italic | Italic text represents arguments that you replace with actual values. |
[ ] | Square brackets enclose syntax choices (keywords or arguments) that are optional. |
{ x | y | ... } | Braces enclose a set of required syntax choices separated by vertical bars, from which you select one. |
[ x | y | ... ] | Square brackets enclose a set of optional syntax choices separated by vertical bars, from which you select one or none. |
{ x | y | ... } * | Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * | Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you may select multiple choices or none. |
&<1-n> | The argument or keyword and argument combination before the ampersand (&) sign can be entered 1 to n times. |
# | A line that starts with a pound (#) sign is comments. |
GUI conventions
Boldface | Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
> | Multi-level menus are separated by angle brackets. For example, File > Create > Folder. |
< > | Button names are inside angle brackets. For example, click <OK>. |
[ ] | Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window. |
/ | Multi-level menus are separated by forward slashes. For example, [File/Create/Folder]. |
Symbols
Means reader be extremely careful. Improper operation may cause bodily injury. | |
Means reader be careful. Improper operation may cause data loss or damage to equipment. | |
Means an action or information that needs special attention to ensure successful configuration or good performance. | |
Means a complementary description. | |
Means techniques helpful for you to make configuration with ease. |
The H3C WX Series documentation set includes:
Category | Documents | Purposes |
Product description and specifications | Describe product specifications and benefits. | |
Hardware specifications and installation | Provide the hardware specifications of the cards, and describe how to install and remove the cards. | |
Guide you through hardware specifications and installation methods to help you install your AC. | ||
Software configuration | Guide you through the main functions of your AC, and describes how to install and log in to your AC, perform basic configurations, maintain software, and troubleshoot your AC. | |
Describe software features and configuration procedures. | ||
Provide a quick reference to all available commands. | ||
Describes configuration procedures through the web interface. | ||
Operations and maintenance | Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. | |
Obtaining Documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical Support
http://www.h3c.com
Documentation Feedback
We appreciate your comments.
