04 Layer 3 - IP Services Configuration Guide
HomeSupportSwitchesH3C S5500 Switch SeriesConfigure & DeployConfiguration GuidesH3C S5500-HI Configuration Guides-Release 52xx-6W10204 Layer 3 - IP Services Configuration Guide
Download Book
Preface
The H3C S5500-HI documentation set includes 11 configuration guides, which describe the software features for the H3C S5500-HI Switch Series and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply software features to different network scenarios.
The Layer 3IP Services Configuration Guide describes how to configure IP addressing, DHCP, IP performance optimization, ARP, DNS, UDP helper, IRDP, IPv6 basics, DHCPv6 and IPv4-IPv6 transitional technologies.
This preface includes:
·     Audience
·     Added and modified features
·     Conventions
·     About the H3C S5500-HI documentation set
·     Obtaining documentation
·     Technical support
·     Documentation feedback
Audience
·     Network planners
·     Field technical support and servicing engineers
·     Network administrators working with the S5500-HI series
This documentation set is for Release 52xx. The following describes the feature changes between releases:
·     Release 5206 has the following feature changes over Release 5203:
Configuration guide
ARP
N/A
IP addressing
Modified feature: The description keyword was added to the display interface brief command
DHCP
N/A
DNS
N/A
IRDP
N/A
N/A
UDP helper
N/A
IPv6 basics
Added feature:Multicast ND
DHCPv6
N/A
IPv6 DNS
N/A
Tunneling
N/A
GRE
N/A
·     Release 5203 has the following feature changes over Release 5101:
Configuration guide
ARP
Added feature: enabling IP conflict notification
IP addressing
Added feature: supporting a subnet mask of 31 bits long.
DHCP
Added features:
·     Enabling client offline detection
·     Setting the DSCP value for DHCP protocol packets sent by the DHCP server, DHCP relay agent, and DHCP client.
DNS
Added features:
·     Setting the DSCP value for DNS protocol packets transmitted.
·     Specifying the source interface for DNS packets.
IRDP
N/A
N/A
UDP helper
Added feature: specifying a destination server for a private network.
IPv6 basics
N/A
DHCPv6
Added features:
·     Setting the DSCP value for DHCPv6 protocol packets sent by the DHCPv6 server DHCPv6 relay agent, and DHCPv6 client.
·     Configuring DHCPv6 snooping to support Option 18 and Option 37.
IPv6 DNS
Added feature: setting the DSCP value for IPv6 DNS protocol packets.
Tunneling
N/A
GRE
N/A
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
TIP TIP
Network topology icons
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
The H3C S5500-HI documentation set includes:
Category
Documents
Purposes
Product description and specifications
Marketing brochure
Describe product specifications and benefits.
Technology white papers
Provide an in-depth description of software features and technologies.
Hardware specifications and installation
Compliance and safety manual
CE DOCs
Provide regulatory information and the safety instructions that must be followed during installation.
Installation quick start
Guides you through initial installation and setup procedures to help you quickly set up your device.
Installation guide
Provides a complete guide to switch installation and specifications.
LSPM1FAN and LSPM1FANB Installation Manual
Describes the appearances, specifications, installation, and removal of the pluggable fan modules available for the products.
User manuals for power modules
Describe the specifications, installation, and replacement of hot swappable power modules.
RPS Ordering Information for H3C Low-End Ethernet Switches
Helps you order RPSs for switches that can work with an RPS.
User manuals for RPSs
Describe the specifications, installation, and replacement of RPSs.
User manuals for interface cards
Describe the specifications, installation, and replacement of expansion interface cards.
H3C Low End Series Ethernet Switches Pluggable Modules Manual
Describes the specifications of pluggable transceiver modules.
Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide
Describe the installation, and replacement of SFP/SFP+/XFP transceiver modules.
Software configuration
Configuration guides
Describe software features and configuration procedures.
Command references
Provide a quick reference to all available commands.
Operations and maintenance
Release notes
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading.
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
[email protected]
http://www.h3c.com
We appreciate your comments.
