Title | Size | Downloads |
02 IRF Configuration Guide-book.pdf | 626.55 KB |
Preface
The H3C S3600V2 documentation set includes 10 configuration guides, which describe the software features for the H3C S3600V2 Switch Series Release 2108, and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply software features to different network scenarios.
The IRF Configuration Guide describes how to use multiple S3600V2 switches to create an IRF fabric based on the IRF technology. It covers planning the switch roles in the IRF fabric, connecting the IRF link, and detecting and maintaining the IRF fabric.
This preface includes:
· Audience
· About the H3C S3600V2 documentation set
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the S3600V2 series
Added and modified features
None
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Convention |
Button names are inside angle brackets. For example, click <OK>. |
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window. |
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder]. |
Symbols
Convention |
NOTE |
Network topology icons
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
The H3C S3600V2 documentation set includes:
Category |
Documents |
Purposes |
Product description and specifications |
Marketing brochure |
Describe product specifications and benefits. |
Technology white papers |
Provide an in-depth description of software features and technologies. |
Hardware specifications and installation |
Compliance and safety manuals CE DOCs |
Provide regulatory information and the safety instructions that must be followed during installation. |
Installation quick starts |
Guides you through initial installation and setup procedures to help you quickly set up your device. |
Installation guides |
Provides a complete guide to switch installation and specifications. |
RPS Ordering Information for H3C Low-End Ethernet Switches |
Helps you order RPSs for switches that can work with an RPS. |
User manuals for RPSs |
Describe the specifications, installation, and replacement of RPSs. |
H3C Low End Series Ethernet Switches Pluggable Modules Manual |
Describes the specifications of pluggable transceiver modules. |
Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide |
Describe the installation, and replacement of SFP/SFP+/XFP transceiver modules. |
Software configuration |
Configuration guides |
Describe software features and configuration procedures. |
Command references |
Provide a quick reference to all available commands. |
Operations and maintenance |
Release notes |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Obtaining documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
http://www.h3c.com
Documentation feedback
We appreciate your comments.
