H3C S12500 Switch Series Troubleshooting Guide-R1825P01-6W100
HomeSupportSwitchesH3C S12500 Switch SeriesDiagnose & MaintainTroubleshootingH3C S12500 Switch Series Troubleshooting Guide-R1825P01-6W100
H3C S12500 Switch Series (R1825P01) Troubleshooting Guide
H3C_彩色.emf
General troubleshooting procedures 1
Obtaining information· 1
Obtaining log information· 1
Obtaining other information· 3
Troubleshooting procedure· 3
Troubleshooting flowchart 3
Problem types 5
Problem locations and possible results 6
Common service recovering and troubleshooting methods 7
Troubleshooting hardware· 8
Card failure· 8
Symptom·· 8
Solution· 10
Power supply failure· 13
Symptom·· 13
Solution· 13
Fan failure· 16
Symptom·· 16
Solution· 16
Temperature alarm·· 18
Symptom·· 18
Solution· 18
Related commands 19
Troubleshooting links and ports 19
Error packets on a port 19
Symptom·· 19
Solution· 21
A port fails to go up· 22
Symptom·· 22
Solution· 22
A port in up state goes down· 23
Symptom·· 23
Solution· 23
A port frequently goes up and down· 24
Symptom·· 24
Solution· 24
Transceiver module failures 24
Symptom·· 24
Solution· 25
Related commands 26
Troubleshooting hardware forwarding· 27
Forwarding path problem·· 27
Symptom·· 27
Solution· 27
Online hardware diagnostic and failure protection· 28
Related commands 29
Troubleshooting packet forwarding failure· 30
Ping failure or packet loss 30
Symptom·· 30
Solution· 30
Layer 2 forwarding failure· 31
Symptom·· 31
Solution· 31
Layer 3 forwarding failure· 34
Symptom·· 34
Solution· 35
MPLS forwarding failure· 36
Symptom·· 36
Solution· 36
Related commands 39
Troubleshooting IRF· 41
IRF fabric establishment failure· 41
Symptom·· 41
Solution· 41
IRF split 43
Symptom·· 43
Solution· 43
Related commands 44
Troubleshooting system management 45
High CPU usage· 45
Symptom·· 45
Solution· 46
Insufficient resources 49
Symptom·· 49
Solution· 49
Related commands 52
H3C recommends that you enable the information center by using the info-center enable command for fast troubleshooting. By default, the information center is enabled.
Log information includes operation information in log files, and state information in diag files. The system stores these files in the CF card (cfa0 or cfa 1).
You can export the log and diag files through FTP, TFTP, or USB. To identify the files exported from different MPUs, save them in a specific order, for example, in different folders named chassisXslotY.
Table 1 Log information classification
Category
File name
Content
log
logfileX.log
Command executions, traps, and operational logs.
diag
default.diag
Device state, CPU state, memory state, configuration state, software entries, and hardware entries.
Follow these restrictions and guidelines to obtain log information:
·     Record the displayed information during operations for future analysis.
·     Understand the impact of each operation so that the configuration can be restored upon operation failures.
·     Make sure the current configuration is consistent with the saved configuration. Do not save the configuration during IRF split, card faults, and card reboot.
·     After you perform an operation, wait for a while before you verify the results.
·     Before you replace an MPU with a new MPU, make sure the new MPU has the same software version as the old MPU.
Obtaining log files
Use the logfile save command to save logs from the log buffer to the CF card on one of the following:
·     The active and standby MPUs of a standalone device.
·     The IRF master and subordinate devices.
<Sysname>logfile save
Saved the log file buffer to file cfa0:/logfile/logfile7.log successfully.
Display log files on the active MPU.
<Sysname>dir
Directory of cfa0:/logfile/
   0     -rw-   5209069  Apr 23 2013 22:06:56   logfile1.log
   1     -rw-   5200061  May 04 2013 02:36:44   logfile2.log
   2     -rw-   5205918  May 09 2013 02:41:10   logfile3.log
1021808 KB total (790736 KB free)
File system type of cfa0: FAT16
Display log files on the standby MPU.
<Sysname>dir
Directory of slot1#cfa0:/logfile/
   0     -rw-   5221735  Apr 10 2013 17:53:14   logfile1.log
   1     -rw-   5227102  Apr 10 2013 18:54:34   logfile2.log
   2     -rw-   3352896  May 16 2013 20:15:44   logfile3.log
1020068 KB total (643264 KB free)
File system type of slot1#cfa0: FAT32
Display log files on the active MPU of an IRF subordinate device. If the IRF fabric has more than one subordinate device, execute this command on each subordinate device.
<Sysname>dir
Directory of chassis2#slot0#cfa0:/logfile/
   0     -rw-   5223211  May 15 2013 12:38:44   logfile1.log
   1     -rw-   2639526  May 15 2013 20:01:14   logfile2.log
   2     -rw-   5223207  May 15 2013 11:22:24   logfile3.log
1021808 KB total (773424 KB free)
File system type of chassis2#slot0#cfa0: FAT16
Obtaining diag files
Execute the display diagnostic-information command, and enter "y" at the prompt to save the diag file to the CF card. If you select "n", not all the diagnostic information can be saved to the CF card. The more cards the device has, the more time the saving operation consumes. During the saving operation, do not execute any command.
<Sysname>display diagnostic-information
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.diag)[cfa0:/default.diag]:20130517.diag
Diagnostic information is outputting to cfa0:/20130517.diag.
Please wait...
Save successfully.
<Sysname>dir cfa0:/
Directory of cfa0:/
   17     -rw-   5151331  May 17 2013 17:38:32   20130517.diag
1020068 KB total (735536 KB free)
File system type of cfa0: FAT32
You can also view the diagnostic information by executing the following commands, but H3C recommends that you not use this method. The screen-length disable command is used to avoid interruption of information output.
<Sysname>screen-length disable
% Screen-length configuration is disabled for current user.
  ===============running CPU usage information===============
===== Current CPU usage info =====
CPU Usage Stat. Cycle: 19 (Second)
CPU Usage            : 5%
CPU Usage Stat. Time : 2013-05-21  10:06:25
CPU Usage Stat. Tick : 0x19aa(CPU Tick High) 0xa57f44e1(CPU Tick Low)
Actual Stat. Cycle   : 0x0(CPU Tick High) 0x39fb1e03(CPU Tick Low)
You also need to obtain other operational information. The following lists some relevant information:
·     Problem symptom, time, topology, configuration information, measures, and results of the measures.
·     Operation logs, captured packet information, debug information, and information output from the console port during continual MPU and switching fabric card reboots.
·     Alarms of cards, power supply, and fans. For example, you can take pictures to record alarm information.
When the switch has a problem, do the following:
1.     Obtain operation information.
2.     Use the troubleshooting flowchart provided in "Troubleshooting flowchart" to determine the problem type.
3.     Use the solution for the problem type to troubleshoot the switch.
If you cannot determine the problem, contact H3C Support.
Use the troubleshooting flowchart shown in Figure 1 to determine the problem type.
Figure 1 Troubleshooting flowchart
The following are commonly used troubleshooting methods:
·     Collecting packet statistics on ports.
·     Mirroring packets.
·     Capturing packets.
·     Configuring QoS policies to collect statistics.
·     Enabling debugging functions.
·     Replacing the suspicious hardware or installing the suspicious hardware in another slot.
For example, if a transceiver might have a problem, do one of the following:
?     Replace the transceiver with a transceiver that can operate correctly.
?     Install the transceiver in another slot.
If the card in a slot might have a problem, do one of the following:
?     Replace the card with a card that can operate correctly.
?     Install the card in another slot.
Problem types
Card failure
A card failure might result in the following symptoms:
·     A card cannot start up.
·     A card reboots unexpectedly.
·     A card reboots again and again.
·     A card is not in the correct state.
To troubleshoot a card failure, see "Card failure."
Power failure
A power failure might result in the following symptoms:
·     Power LEDs are not in the correct states.
·     Power alarm messages are displayed continuously.
To troubleshoot a power failure, see "Power supply failure."
Fan failure
A fan failure might result in the following symptoms:
·     Fans do not operate.
·     Fan LEDs are not in the correct states.
·     Fan alarm messages are displayed continuously.
To troubleshoot a fan failure, see "Fan failure."
Temperature problem
If temperature alarm messages are displayed, the device might have a temperature problem. To troubleshoot a temperature problem, see "Temperature alarm."
Port failure
A port failure might result in the following symptoms:
·     A port cannot come up.
·     A port goes down and comes up frequently.
·     The counts of packet errors on the port are not zero.
To troubleshoot a port failure, see "Troubleshooting links and ports."
Hardware forwarding failure
If the log messages such as "Forwarding fault" or "Board fault: chassis X slot Y, please check it" are displayed, the device might have a hardware forwarding failure.
To troubleshoot a hardware forwarding failure, see "Troubleshooting hardware forwarding."
Packet forwarding failure
A packet forwarding failure might result in the following symptoms:
·     Some ping packets are lost, or the ping operation fails.
·     Some tracert packets are lost, or the tracert operation fails.
·     Layer 2 frames are lost, or the Layer 2 link is down.
·     Layer 3 frames are lost, or the Layer 3 connection is down.
·     The MPLS service is not running correctly.
To troubleshoot a packet forwarding failure, see "Troubleshooting hardware forwarding."
IRF failure
An IRF failure might result in the following symptoms:
·     The IRF fabric cannot be formed.
·     An IRF split occurs.
To troubleshoot a packet forwarding failure, see "Troubleshooting IRF."
Overuse of CPU
If the switch uses too much memory, see "High CPU usage."
If the "No enough resource" message is displayed, see "Insufficient resources."
Figure 2 shows a typical network model and the possible problem locations. For higher availability and quick switchover and restoration in response to failures, the network uses two upstream links and two core switches. Table 2 shows the possible symptoms and results of different problem locations.
Figure 2 Typical network model and the possible problem locations
Table 2 Problem locations and possible symptoms and results
Problem location
Possible symptoms
Possible results
1 (including transceivers)
A port is down.
A service switchover occurs.
Counts of packet errors are increased.
All services on the link are affected.
2
A card fails.
A chip on a card fails while the card is operating correctly.
Services on the chip are affected.
If a switching fabric module failure occurs, the whole device is affected.
A software error occurs.
The device reboots and a service switchover occurs.
If a protocol module has a problem, the service is usually affected.
3
Same as problem location 1.
Services on the access switch are affected. The scope of affected services is smaller than a problem at problem location 1.
4
The device is down.
Services on the device are affected.
A chip on a card fails.
Some ports or all services on the device are affected.
The device reboots and all services on the device are affected.
5
Server services on the link are affected.
6
The network is operating correctly but a service is not.
The service on the server is affected.
Table 3 Common service recovering and troubleshooting methods
Failure category
Service recovering methods
Troubleshooting methods
Hardware
·     Isolate the failed card.
·     Isolate the failed device by adjusting service traffic forwarding paths. For example, adjust the preferences for routes so traffic is switched to other paths.
Complete required tests on the backup hardware, and replace the failed hardware.
Software
·     Reboot the protocols on the failed device.
·     Upgrade the software or install patches.
·     Adjust the network topology, or modify the configuration to remove the failures.
Link
Isolate the failed link by adjusting service traffic forwarding paths.
Remove link errors.
Others
·     Correct configuration errors.
·     Connect the ports of the devices correctly.
·     Isolate the failed link by adjusting service traffic forwarding paths.
·     Repair the power and air conditioner systems for the devices.
Card failure
Symptom
·     A card runs into an abnormal state: Absent, Fault, Off, Offline, or Illegal.
·     A card fails to boot, or it reboots unexpectedly or repeatedly.
If the switch outputs log messages, such as "Forwarding fault," "Board fault: chassis X slot Y," or "please check it," see "Troubleshooting hardware forwarding."
How to identify a card state
A card can operate in Normal, Master, Slave, Absent, Fault, Off, Offline, or Illegal state:
·     Normal—The card is operating correctly.
·     Master—The card is an active MPU.
·     Slave—The card is a standby MPU.
·     If the card is in Fault, Off, Offline, or Illegal state, or the slot in which the card is installed is in Absent state, the card might be faulty. See "Solution" to rectify the fault.
You can execute the display device command and check the Brd Status field for the card states. The following is a sample command output.
<Sysname>display device
Slot No.   Brd Type        Brd Status   Software Version
1/0       LST1MRPNC1       Master       S12500-CMW520-R1728P02
1/1       LST1MRPNC1       Slave        S12500-CMW520-R1728P02
1/2       LST1XP16LEC1     Normal       S12500-CMW520-R1728P02
1/3       LST1XP16LEC1     Normal       S12500-CMW520-R1728P02
1/4       LST1XP16LEC1     Normal       S12500-CMW520-R1728P02
1/5       NONE             Absent       NONE
1/6       NONE             Absent       NONE
1/7       NONE             Absent       NONE
1/8       NONE             Absent       NONE
1/9       LST1GP48LEC1     Normal       S12500-CMW520-R1728P02
1/10      LST2SF08C1       Normal       S12500-CMW520-R1728P02
1/11      LST2SF08C1       Normal       S12500-CMW520-R1728P02
1/12      LST2SF08C1       Normal       S12500-CMW520-R1728P02
1/13      LST2SF08C1       Normal       S12500-CMW520-R1728P02
1/14      LST2SF08C1       Normal       S12500-CMW520-R1728P02
1/15      LST2SF08C1       Normal       S12500-CMW520-R1728P02
1/16      LST2SF08C1       Normal       S12500-CMW520-R1728P02
1/17      LST2SF08C1       Normal       S12500-CMW520-R1728P02
1/18      LST2SF08C1       Normal       S12500-CMW520-R1728P02
How to confirm a card reboot
Use the display version command or display the card running time through log files to confirm whether a card rebooted. If the card uptime is obviously less than other cards, the card rebooted. See "Solution" to resolve the problem.
<Sysname>display version
H3C Comware Platform Software
Comware Software, Version 5.20, Release 1825P01
Copyright (c) 2004-2013 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C S12504 uptime is 0 week, 0 day, 1 hour, 48 minutes
Last reboot reason : User reboot
LST1MRPNC1 1/0:  uptime is 0 week, 0 day, 1 hour, 48 minutes
3456    Mbytes SDRAM
1024    Kbytes NVRAM Memory
Type     : LST1MRPNC1
BootRom  : 1.22
Software : S12500-CMW520-R1825P01
Patch    : NONE
PCB      : Ver.B
Board Cpu:
  Number of Cpld: 2
  Cpld 0:
    SoftWare  : 005
  Cpld 1:
    SoftWare  : 005
PowChipA  : 004
CpuCard
  Type      : LSR1CPA
  PCB       : Ver.C
  Number of Cpld: 1
  Cpld 0:
    SoftWare  : 001
  BootRom   : 1.13
Mbus card
  Type      : LSR1MBCB
  Software  : 115
  PCB       : Ver.B
Solution
In Absent state
To resolve the problem:
1.     Reinstall the card to make sure the card is installed securely.
2.     Do the following:
?     Install this card into another slot.
?     Install another card that runs correctly on the chassis into this slot to determine whether the card is faulty.
3.     Verify that the LEDs on the card panel and inside the card do not indicate any fault.
4.     If the card is an MPU or switching fabric module, connect the card to a terminal through a serial cable to verify that the card can boot correctly.
5.     If the card is confirmed to be faulty, replace the card and contact H3C Support.
In Off state
Determine whether a user powered off the card by using the power-supply off command.
?     If they did, power on the card by using the power-supply on command.
?     If they did not, the power supply of the card is faulty. Replace the card and contact H3C Support.
In Fault state
1.     Wait a period of time and determine whether the card remains in Fault state or reboots after becoming Normal. If the card reboots after becoming Normal, contact H3C Support.
2.     Verify that the card boots correctly.
?     For an MPU or switching fabric module, connect the card to a terminal through a serial cable to verify that the card boots correctly. If a DRAM test fails, causing repeated reboots (as shown in the following), verify that the DRAM is installed securely.
readed value is 55555555 , expected value is aaaaaaaa
DRAM test fails at: 080ffff8
Fatal error! Please reboot the board.
?     For an LPU, verify that the system working mode supports the card type.
Use the display system working mode command to display the system operating mode:
[Sysname]display system working mode
Current system working mode      : Routee
Working mode after system restart: Routee
Notice: Changing working mode will take effect only after system restart.
If the current system operating mode does not support the card, the switch generates related information as shown in the following example:
%Apr 18 10:08:11:525 2013 H3C SYSM/1/DRV_SYSM:
slot  2 is an EB type board, and it supports Standard working mode only.
%Apr 18 10:08:11:661 2013 H3C SYSM/1/DRV_SYSM:
ERROR!!! slot  2 doesn't support the current system working mode, board rebooting!
%Apr 18 10:08:11:802 2013 H3C SYSM/1/DRV_SYSM:
This is not hardware fault, please change mode by command 'system working mode' in system view.
The output shows that the EB card is not supported in Routee mode.
If you determine that the current system operating mode does not support the card, use the system working mode command to modify the system operating mode. Then save the configuration. The new operating mode takes effect after the switch reboots.
[Sysname]system working mode standard
Standard mode has been set. It needs to be saved and will take effect after system restart.
[Sysname]save
Please input the file name(*.cfg)[flash:/config.cfg]
flash:/config.cfg exists, overwrite? [Y/N]:y
Validating file. Please wait........................................
The current configuration is saved to the active main board successfully.
Configuration is saved to device successfully.
3.     Install the card into another slot to determine whether the card is faulty.
4.     If the card is confirmed to be faulty, replace the card and contact H3C Support.
In Offline state
1.     Determine whether a user isolated the card from the system by using the board-offline command. If the card is isolated due to this operation, use the undo board-offline command to remove the configuration. A card is also isolated from the system when POST is performed.
2.     If an LPU is isolated from the system, a fault might be detected on the LPU by the online diagnostic module. You can execute the display hardware-failure-detection command and check for the records at the time when the card was isolated. If the LPU is faulty, replace the LPU and contact H3C Support.
<Sysname>display hardware-failure-detection
Current level:
chip       : isolate
board      : isolate
forwarding : isolate
----------------------------Slot  4 records:-------------------------------
Slot  0:
1. 2011-06-09, 04:34:14 rebooted by board detection.
Slot  4:
1. 2011-06-09, 11:16:39 rebooted by forwarding detection.
Slot  6:
1. 2011-06-09, 11:13:37 some auto-down ports on this slot are down by
2. 2010-06-09, 11:13:16 some auto-down ports on this slot are down by
3.     If switching fabric modules are isolated from the system, forwarding-plane failures might be detected, and the system generates log messages such as "Forwarding fault," "Board fault: chassis X slot Y," and "please check it." Verify that the failure is removed after the switching fabric modules are isolated from the system. You can execute the display hardware-failure-detection command to display hardware failure detection and fix information.
?     If one switching fabric module is isolated from the system and the forwarding-plane failure is removed after the switching fabric module is isolated, the switching fabric module is faulty. Replace the switching fabric module and contact H3C Support. If the forwarding-plane failure persists after the switching fabric module is isolated, the switching fabric module is not faulty, because the switching fabric module does not participate in traffic forwarding after being isolated. (The online diagnostic module is not intelligent enough, and misjudgment might occur at multiple points of failures.) You can use the undo board-offline command to get the switching fabric module online. See "Troubleshooting hardware forwarding" to resolve the problem, and contact H3C Support.
?     If multiple switching fabric modules are isolated, the LPUs might be faulty. See "Troubleshooting hardware forwarding" to resolve the problem, and contact H3C Support.
In Illegal state
1.     Verify that the switch supports the card.
2.     Verify that the switch software version supports the card. New cards cannot boot on an earlier software version. Upgrade the software version to support the new cards.
3.     Insert the card into another slot to determine whether the card is faulty.
4.     If the card remains in Illegal state in another slot, replace the card and contact H3C Support.
Unexpected reboot
Unexpected reboot means that a card has rebooted unexpectedly while its current state is Normal.
1.     View the log messages, or execute the display version command to determine the period during which the card rebooted. Then determine whether a user rebooted the card by using the reboot command or by powering off and then powering on the card during the period.
2.     On a switch running 18XX or a later version, the reason for the last reboot is displayed in the display version command output. You can check the Last reboot reason field for the event that caused the last reboot. As shown in the following example, the event that caused the last reboot was a power-on operation.
3456    Mbytes SDRAM
Type     : LST1MRPNC1
3.     If all cards rebooted simultaneously, verify that the following:
?     The power supplies operate correctly.
?     The power source is not powered off.
?     The power cables are connected securely.
4.     Verify that log messages such as "Slot X need to be rebooted automatically!" are not generated during the card reboot. If a message like that is displayed, replace the card and contact H3C Support.
5.     Verify that the message "Hardware error" is not displayed. If the message is displayed, view the error code:
?     If the error code is 0 through 31 or no smaller than 100, the power supply of the card is faulty. Replace the card and contact H3C Support.
?     For other error codes, contact H3C Support.
%@437307%May 15 22:03:02:122 2013 H3C DIAG/3/ERROR: Hardware error! chassis=1, slot=7, code=0
%@437308%May 15 22:03:02:122 2013 H3C DIAG/3/ERROR: Hardware error! chassis=1, slot=7, code=1
%@437309%May 15 22:03:02:122 2013 H3C DIAG/3/ERROR: Hardware error! chassis=1, slot=7, code=2
6.     Execute the display hardware-failure-detection command. Verify that there is no card reboot record in the determined reboot period in the command output. If there is a card reboot record in the determined period, contact H3C Support.
7.     If the problem persists, contact H3C Support.
Symptom
The power LED on the switch indicates a failure. An alarm is generated, indicating that a power supply or power monitoring unit (PMU) is faulty, as shown in the following example:
%Sep 22 20:38:32:947 2009 H3C DEVD/3/PMU STATUS: Chassis 1: No.1 power monitor: absent.
%Sep 22 20:38:32:947 2009 H3C DEVD/4/PSU CHANGED: Chassis 1: PSU ID may be changed, please check it!
Solution
1.     Verify that the power supply or PMU is securely installed and that the power supply or PMU LEDs do not indicate any failure. If LEDs of the power supply or PMU indicate any failure, remove and reinstall the power supply or PMU to make sure the module is installed securely. You can also determine whether the power supply or PMU is faulty by exchanging it with another one that runs correctly.
2.     Execute the display power-supply command to display the power supply information.
?     If the power supply and PMU are installed securely but the power supply status field is empty or Absent, a failure occurs. The fault cause is displayed following the status field:
-     If the cause is Under-vol, the power supply might not connect to the power cord, or the external power supply might have a bad contact.
-     For other causes, remove and reinstall the power supply to make sure the power supply is installed securely. You can also determine whether the power supply is faulty by exchanging it with another one that runs correctly.
?     Verify that the PMU information (System power monitoring unit in the command output) is displayed correctly. If the PMU information fails to be displayed, remove and reinstall the PMU, and determine whether the PMU is faulty by exchanging it with another one that runs correctly.
3.     Verify that the card power states are On. For a card that is installed securely in a slot, do one of the following, depending on the state of the card :
?     In Absent state—See "In Absent state" to remove the failure.
?     In Wait state—The system power is insufficient, and the card is waiting to be powered on. Verify that the power source and the power supplies run correctly.
?     In Off state—The card powers off automatically due to user operation, over-temperature protection, or power supply failure, and it will not power on automatically. See "In Offline state" to resolve the problem.
4.     If a power supply or PMU is faulty, replace the module. If the problem persists, contact H3C Support.
The following is a sample output of the display power-supply command:
<Sysname>display power-supply
Power info on chassis 0:
PSU 1/1    state: Normal
PSU 1/2    state: Normal
PSU 1/3    state: Normal
PSU 1/4    state: Normal
PSU 1/5    state: Normal
PSU 1/6    state: Normal
PSU 2/1    state: Normal
PSU 2/2    state: Normal
PSU 2/3    state: Normal
PSU 2/4    state: Normal
PSU 2/5    state: Normal
PSU 2/6    state: Normal
<Sysname>display power-supply verbose
System power-supply policy: enable
System power-module redundant(configured): 1
System power usable: 22000 Watts
System power redundant(actual): 2000 Watts
System power allocated: 7350 Watts
System power available: 14650 Watts
SYSTEM POWER USED(CURRENT): 4959.21 Watts
System power monitoring unit 1:
        Software version: 107
System power monitoring unit 2:
Type        In/Out  Rated-Vol(V)  Existing  Usable  Redundant(actual)
PSE9000-A   AC/DC   220(default)  12        11      1
DC output voltage information:
Tray Value(V)  Upper-Threshold(V)  Lower-Threshold(V)  Status
  1  50.08     51.00               49.00               Normal
  2  50.10     51.00               49.00               Normal
DC output current information:
Total current(A): 99.00
Branch   Value(A)
 1/1      9.20
 1/2      8.00
 1/3      8.40
 1/4      7.40
 1/5      9.00
 1/6      7.60
 2/1      7.60
 2/2      9.00
 2/3      7.60
 2/4      7.60
 2/5      9.00
 2/6      8.60
PSU Status:
ID  Status  Input-Err   Output-Err High-Temperature Fan-Err Closed Current-Limit
1/1 Normal
1/2 Normal
1/3 Normal
1/4 Normal
1/5 Normal
1/6 Normal
2/1 Normal
2/2 Normal
2/3 Normal
2/4 Normal
2/5 Normal
2/6 Normal
Line-card power status:
Slot  Board-Type       Watts  Status
 2    LST1XP8LEB1      280    On
 3    LST1XP8LEB1      280    On
 4    LST1XP8LEB1      280    On
 5    LST1XP8LEB1      280    On
 6    LST1XP8LEB1      280    On
 7    LST1XP8LEB1      280    On
 8    LST1XP8LEB1      280    On
 9    LST1XP8LEB1      280    On
10    LST1XP8LEB1      280    On
11    LST1XP8LEB1      280    On
12    LST1XP8LEB1      240    On
13    LST1XP8LEB1      280    On
14    LST1XP8LEB1      240    On
15    LST1XP8LEB1      240    On
16    LST1XP8LEB1      280    On
17    LST1XP8LEB1      280    On
18    LST1XP8LEB1      280    On
19    LST1XP8LEB1      280    On
Fan failure
Symptom
The fan tray LEDs indicate a failure. A fan error message is displayed on the switch, as shown in the following example:
%Sep 22 20:38:32:947 2009 H3C DEVD/3/ FAN CHANGE: Chassis 1: Fan communication state changed: Fan 1 changed to fault.
Solution
1.     Put your hand at the air outlet to verify that there is air being exhausted from the air outlet. If no air is being exhausted from the outlet, the fans are faulty.
2.     Verify that the airflow is not blocked at the air inlet and outlet.
3.     Verify that the fan tray is securely installed. You can remove and reinstall the fan tray to make sure that the fan tray is securely installed.
4.     Verify that the status of each fan is normal and that the speed difference between the fans does not exceed 50%. Execute the display fan verbose command to display detailed information about the fans. If there is an abnormality, verify that the fan tray is not faulty by exchanging it with another one that runs correctly.
5.     If the problem persists, replace the fan tray. If there is no new fan tray, power off the switch to avoid damage caused by high temperatures. The switch can be used temporarily if there are cooling measures to maintain the switch operating temperature below 50°C (122°F).
<Sysname>display fan verbose
Fan-tray verbose state on chassis 0:
Fan-tray 1:
Software version: 108
Hardware version: Ver.A
CPLD version: 002
Fan number: 12
Temperature: 27 C
High temperature alarm threshold: 60 C
Low speed alarm threshold: 1450 rpm
Fan  Status      Speed(rpm)
 1   normal      3780
 2   normal      3780
 3   normal      3720
 4   normal      3840
 5   normal      3900
 6   normal      3660
 7   normal      3780
 8   normal      3840
 9   normal      3660
10   normal      2940
11   normal      2940
12   normal      2880
Fan-tray 2:
CPLD version: 002
Fan number: 12
Temperature: 21 C
 1   normal      3720
 2   normal      3720
 3   normal      3780
 4   normal      3660
 5   normal      3660
 6   normal      3720
 7   normal      3660
 8   normal      3660
 9   normal      3660
10   normal      2820
11   normal      2820
12   normal      2760
Temperature alarm
Symptom
A temperature over-low or over-high alarm is generated on the switch, as shown in the following example:
%Sep 22 20:38:32:947 2009 H3C DEVM/4/BOARD_TEMPERATURE_TOOHIGH: Board temperature is too high on Chassis 1 Slot 5, type is LST1GP48LEB1.
Solution
1.     Verify that the ambient temperature is in the compliant range. If the temperature is too high, find the cause. The possible cause might be that the equipment room has bad ventilation or the air conditioning is faulty.
2.     Verify that the current temperature of the switch does not exceed the upper and lower warning and alarm thresholds. The card might be damaged when operating continuously at a high temperature. You can feel the card by hand, or execute the display environment command to display temperature information.
?     If the temperature is too high, see "Fan failure" to determine whether fan failure causes the problem.
?     If the Temperature field displays error or a value out of the ordinary, the switch might fail to access the card temperature sensor through the I2C bus. The switch accesses the transceiver modules through the same I2C bus. You can view whether the transceiver module information is displayed correctly. If the switch can access the transceiver modules, use the temperature-limit command to reconfigure the temperature thresholds. Then use the display environment command to view whether the setting takes effect.
[Sysname]temperature-limit chassis 2 slot 0 hotspot 1 -20 85 90
<Sysname>display environment
System temperature information (degree centigrade):
Slot  Sensor    Temperature  LowerLimit  WarningLimit  AlarmLimit ShutdownLimit
2/0   inflow  1       35         -25           70           85          N/A
2/0   outflow 1       40         -20           80           85          N/A
2/0   hotspot 1       43         -20           85           90          N/A
2/2   inflow  1       39         -20           70           85          N/A
2/2   outflow 1       40         -10           80           90          N/A
2/2   hotspot 1       41         -10           80           90          N/A
2/3   inflow  1       41         -20           70           85          N/A
2/3   outflow 1       57          15           80           85          N/A
2/3   hotspot 1       41         -20           75           80          N/A
2/3   hotspot 2       50           0           75           80          N/A
2/4   inflow  1       43         -20           70           85          N/A
2/4   outflow 1       60          15           80           85          N/A
2/4   hotspot 1       43         -20           75           80          N/A
2/4   hotspot 2       54           0           75           80          N/A
3.     If the problem persists, contact H3C Support.
This section lists the commands that you might use for troubleshooting hardware.
display device
Displays device information, including the card states.
display environment
Displays the temperature statistics of the device, including the current temperature and temperature thresholds.
display fan
Displays the operating states of fans.
Displays hardware failure detection and rectification information, including the rectification actions for each failure and historic information about the last ten fault rectifications on each card.
Displays power supply information:
·     Enabled/disabled status of the power supply management function.
·     Power supply type, rated input voltage, and rated output power.
·     Number of redundant power supplies and the available, redundant, used, and remaining power of each power supply.
·     Status of the installed power supplies.
·     Power supply status of the LPUs.
Displays the current system operating mode.
display version
Displays system version information, card running time, and cause of the last reboot.
Save
Saves the running configuration to a specific configuration file.
system working mode
Sets the system operating mode to modify the hardware resources allocation. The command takes effect after the configuration is saved and the device reboots.
temperature-limit
Sets the temperature alarm thresholds for the device.
This section provides troubleshooting information for common problems with links and ports.
Symptom
Use the display interface command to display the traffic statistics about incoming packets and outgoing packets of a port. The error packet count is not 0.
<Sysname>display interface ten-gigabitethernet 1/2/0/6
Ten-GigabitEthernet1/2/0/6 current state: UP
 IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 80f6-2ec3-ac04
 Description: SH-B15A-0202-J20-H5800-L-01-te1/0/49
 Loopback is not set
 Media type is optical fiber, Port hardware type is 10G_BASE_SR_SFP
 10Gbps-speed mode, full-duplex mode
 Link speed type is force link, link duplex type is force link
 Flow-control is not enabled
 The Maximum Frame Length is 8168
 Broadcast MAX-ratio: 100%
 Unicast MAX-ratio: 100%
 Multicast MAX-ratio: 100%
 Allow jumbo frame to pass
 PVID: 1
 Link delay is 2(sec)
 Ethernet port mode: LAN
 Port link-type: trunk
  VLAN passing  : 1(default vlan), 10-28, 91-93, 106-108, 121-123, 184, 401, 999
  VLAN permitted: 1(default vlan), 2-4094
  Trunk port encapsulation: IEEE 802.1q
 Port priority: 2
 Last clearing of counters:  Never
 Peak value of input: 10070 bytes/sec, at 2013-05-14 19:11:30
 Peak value of output: 315310 bytes/sec, at 2013-05-14 19:56:27
 Last 300 seconds input:  0 packets/sec 90 bytes/sec 0%
 Last 300 seconds output:  0 packets/sec 530 bytes/sec 0%
 Input (total):  1617091 packets, 131185047 bytes
     1144855 unicasts, 79482 broadcasts, 392754 multicasts, - pauses
 Input (normal):  1617091 packets, 131185047 bytes
     1144855 unicasts, 79482 broadcasts, 392754 multicasts, 0 pauses
     - ignored, - parity errors
 Output (total): 7779022 packets, 862020306 bytes
     1138915 unicasts, 3567900 broadcasts, 3072207 multicasts, - pauses
 Output (normal): 7779022 packets, 862020306 bytes
     1138915 unicasts, 3567900 broadcasts, 3072207 multicasts, 0 pauses
     - lost carrier, - no carrier
Table 4 Error packet fields for incoming packets
input errors
Number of incoming error packets.
Runts
Number of incoming frames shorter than 64 bytes, in correct format, and containing valid CRCs.
Giants
Number of incoming frames larger than the maximum frame length configured on the interface.
CRC
Number of incoming frames that contained CRC errors.
frame
Number of incoming frames that contained CRC errors and a non-integer number of bytes.
Table 5 Error packets fields for outgoing packets
output errors
Number of outgoing error packets.
Aborts
Number of packets that failed to be transmitted.
Deferred
Number of frames that the interface failed to transmit when the delay exceeded two times the maximum packet transmission time because the medium was busy.
Collisions
Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission.
late collisions
Number of frames that the interface deferred to transmit after transmitting their first 512 bits because of detected collisions.
Solution
The number of incoming error packets of the CRC, frame, and throttle types keeps increasing on a port
1.     Use a tester to test the link, and verify that the link quality or fiber signal attenuation of the link is normal. If a link failure exists, replace the network cable or fiber.
A weak link quality or serious fiber signal attenuation will cause packet transmission errors.
2.     Verify that the transceiver module is operating correctly if a transceiver module is used.
For more information, see "Transceiver module failures."
3.     Use the network cable or fiber and transceiver module of the port to connect to another port that is operating correctly.
?     If error packets do not appear on the new port and error packets appear after the network cable or fiber and transceiver module is connected to the current port again, you can determine that the port fails. Use another port that is operating correctly, and contact H3C Support.
?     If error packets still appear on the new port, the peer device and intermediate transmission links might fail. Examine the peer device and intermediate transmission links.
4.     Verify that the peer device and intermediate devices are operating correctly.
5.     If the problem persists, contact H3C Support.
The number of incoming error packets of the overrun type keeps increasing on a port
The number of overrun packets keeps increasing on a port because the input rate exceeds the processing capability of the port, which causes congestion.
1.     Execute the display interface command multiple times when both of the following are true:
?     Only one port cannot correctly send and receive packets, or only the device attached to one port cannot transmit traffic.
?     The other ports on the same interface card are operating correctly.
2.     Perform one of the following tasks, depending on the error packet count trend:
?     If the number of input errors increases, but the number of overruns does not increase, examine the fiber, transceiver module, and the peer device.
?     If the number of input errors increases and the increment is the same as the increment of overruns, the interface card might be internally congested or blocked:
-     If the number of overruns increases, but the number of packets in the Input (normal) field does not increase, all incoming packets become overruns, which indicates that the port is blocked. To resolve the problem, contact H3C Support.
-     If the number of overruns increases, and the number of packets in the Input (normal) field also increases, some of the incoming packets become overruns, which indicates that the port is congested. To resolve the problem, contact H3C Support.
The incoming error packets of the jumbo type keeps increasing on a port
1.     Verify that the jumbo frame configurations are the same on both ends, including:
?     Whether jumbo frame support is enabled.
?     The default maximum jumbo frame size allowed.
?     The configured maximum jumbo frame size allowed.
2.     If the problem persists, contact H3C Support.
The number of outgoing error packets keeps increasing on a port
1.     Examine the duplex mode of the port. Configure the port to operate in full duplex mode if the port is operating in half duplex mode.
Symptom
A port cannot go up.
Solution
1.     Verify that the network cable or fiber link between ports is correct.
2.     Verify that the Rx end and the Tx end are correctly connected.
3.     Verify that the intermediate transmission link is correct by performing one of the following tasks:
?     Replace the network cable or fiber between ports.
?     Connect other ports that are operating correctly by using the network cable or fiber.
4.     Verify that the configurations of the local port and the peer port are correct, including whether the port is shut down, and its speed, duplex mode, negotiation mode, and MDI.
[Sysname]display current-configuration interface ten-gigabitethernet 1/6/0/1
interface Ten-GigabitEthernet1/6/0/1
 port link-mode bridge
 port link-type trunk
 port trunk permit vlan 1 3102
 port link-aggregation group 1
Return
Table 6 Support for duplex modes
Speed (right)
10 Gbps
1000 Mbps
100 Mbps
10 Mbps
Duplex mode (below)
Full
Supported
Supported
Supported
Supported
Half
No supported
No supported
No supported
No supported
5.     If the port has a transceiver module installed, verify that the transceiver modules at both ends of the link are consistent in the rate, wavelength, and single-mode or multi-mode status.
[Sysname]display transceiver interface ten-gigabitethernet 2/9/0/1
Ten-GigabitEthernet2/9/0/1 transceiver information:
  Transceiver Type              : 10G_BASE_LRM_SFP
  Connector Type                : LC
  Wavelength(nm)                : 1310
  Transfer Distance(m)          : 220(50um),220(62.5um),220(om3)
  Digital Diagnostic Monitoring : YES
  Vendor Name                   : H3C.
6.     Replace the transceiver module with a transceiver module that is operating correctly, and determine whether the transceiver modules fail.
7.     If the transceiver module fails, replace the transceiver module, and contact H3C Support.
Symptom
A port in up state goes down.
Solution
1.     Examine the logs of the local device and the peer device, and verify that a shutdown operation has not been performed.
2.     Examine the status of ports at both ends. Determine whether the port is shut down because of the protocol failures or because of the failures detected by the online diagnosis module.
3.     Contact H3C Support if Protect DOWN appears in the output for a port, for example, Ten-GigabitEthernet 2/8/0/1.
Protect DOWN means that the port goes down because the isolate keyword is specified for the hardware-failure-detection command. When the online diagnosis module detects port failures, the port will be shut down and isolated, so that the traffic can be switched to the backup link.
[Sysname]display interface ten-gigabitethernet 2/8/0/1
Ten-GigabitEthernet2/8/0/1 current state: DOWN ( Protect DOWN )
 IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 80f6-2ec3-ac05
 Description: SH-B15A-0202-V03-H5800-L-01-te1/0/50
 Loopback is not set
4.     Verify that the configurations of ports at both ends, network cables, transceiver modules, and fiber links are correct.
For more information, see "A port fails to go up."
Symptom
A port frequently goes up and down.
Solution
1.     For a fiber port, verify that the transceiver module is operating correctly.
2.     For a copper port, the port status might be unstable when the speed and duplex mode are autonegotiated. Manually configure the speed and duplex mode for the port.
3.     Verify that the link, peer device, and intermediate devices are operating correctly.
4.     If the problem persists, contact H3C Support.
Symptom
The interface with a transceiver module installed cannot go up, and alarms are present.
Solution
1.     Check the alarms on the transceiver module:
?     If TX faults exist in the alarms, the peer port, fiber, or intermediate transmission devices might fail.
?     If the RX faults or electrical current and voltage faults exist in the alarms, examine the local port.
<Sysname>display transceiver alarm interface GigabitEthernet 2/0/1
GigabitEthernet2/0/1 transceiver current alarm information:
  TX fault
  PCS receive local fault
  Laser temperature fault
Table 7 Alarms on transceiver modules
Alarms on SFP/SFP+ transceiver modules:
RX loss of signal
Received signals are lost.
RX power high
The received optical power is high.
RX power low
The received optical power is low.
TX fault
Transmission error.
TX bias high
The transmitted bias current is high.
TX bias low
The transmitted bias current is low.
TX power high
The transmitted optical power is high.
TX power low
The transmitted optical power is low.
Temp high
The temperature is high.
Temp low
The temperature is low.
Voltage high
The voltage is high.
Voltage low
The voltage is low.
Transceiver info I/O error
Transceiver information read/write error.
Transceiver info checksum error
Transceiver information checksum error.
Transceiver type and port configuration mismatch
The type of the transceiver module does not match the port configuration.
Transceiver type not supported by port hardware
The port does not support this type of transceiver modules.
Alarms on XFP transceiver modules:
RX loss of signal
RX not ready
The receiving status is not ready
RX CDR loss of lock
Receiving CDR loss of lock.
RX power high
RX power low
TX not ready
The transmission status is ready.
TX fault
Transmission error.
TX CDR loss of lock
Transmission CDR loss of lock.
TX bias high
TX bias low
TX power high
TX power low
Module not ready
The module is not ready.
APD supply fault
Avalanche photo diode error.
TEC fault
Thermoelectric cooler error.
Wavelength unlocked
Wavelength loss of lock.
Temp high
Temp low
Voltage high
Voltage low
The voltage is low.
2.     Cross-verify the transceiver module that might fail:
a.     Install the transceiver module in another fiber port.
b.     Replace the current transceiver module with a transceiver module that is operating correctly.
3.     Determine whether the transceiver module fails or the neighboring devices and intermediate transmission links fail.
4.     If the transceiver module fails, use the display transceiver diagnosis command to display the digital diagnosis parameters on the transceiver module, and contact H3C Support.
You might fail to query the digital diagnosis parameters of a non-H3C transceiver module. H3C recommends that you use H3C transceiver modules. To query the vendor of a transceiver module, use the display transceiver manuinfo command. If the value of the Vendor Name field is H3C, the transceiver module is customized by H3C.
This section lists the commands that you might use for troubleshooting ports and links.
Displays the running configuration. With an interface specified, this command displays the running configuration of the interface.
display interface
Displays the incoming traffic statistics, outgoing traffic statistics, and status of a port. In the output from this command, you can view whether error packets exist and view the error packet statistics.
Displays alarms present on transceiver modules.
Displays the current values of the digital diagnosis parameters on transceiver modules.
Displays key parameters of the transceiver module in a specified interface to verify whether the transceiver modules at both ends are consistent in the rate, wavelength, and single-mode or multi-mode status.
Displays the electronic label information of a transceiver module to query the vendor of the transceiver module.
Symptom
When data forwarding path failure detection is enabled (it is enabled by default), the switch periodically sends test packets between LPUs to examine whether the forwarding chips on the LPUs are operating correctly.
[Sysname]forward-path check enable
If a forwarding problem occurs, the switch displays "Forwarding fault" or "Board fault" messages. For example:
%May 12 11:51:30:664 2013 H3C DIAG/3/ERROR: -Slot=12; Forwarding fault: slot 18 to slot 12
%May 12 11:51:30:664 2013 H3C DIAG/3/ERROR: -Slot=14; Forwarding fault: slot 18 to slot 14
%May 12 11:51:30:665 2013 H3C DIAG/3/ERROR: -Slot=13; Forwarding fault: slot 18 to slot 13
%May 12 11:51:30:665 2013 H3C DIAG/3/ERROR: -Slot=16; Forwarding fault: slot 18 to slot 16
%May 12 11:51:31:494 2013 H3C DIAG/3/ERROR: Board fault: chassis 0 slot 18,please check it
%May 12 11:51:31:702 2013 H3C DIAG/3/ERROR: Board fault: chassis 0 slot 18,please check it
Solution
The switch has MPUs, LPUs, and switching fabric modules. LPUs and switching fabric modules perform service traffic forwarding. Traffic is load balanced among the switching fabric modules. MPUs perform control and management. MPUs do not participate in service traffic forwarding.
To resolve the forwarding path problem:
·     If "Forwarding fault" messages show forwarding problems between multiple LPUs, it is likely that a switching fabric module has a problem. To locate the problem source, isolate switching fabric modules one by one. (An isolated switching fabric module does not participate in traffic forwarding. Isolating a switching fabric module does not result in packet loss.)
For example, do the following on an H3C S12508 switch in which slots 10 through 18 hold switching fabric modules:
a.     Isolate the switching fabric module in slot 10.
[Sysname] board-offline slot 10
Caution: This command is only for diagnostic purpose which will cause board normal service unusable. Continue? [Y/N]:y
Config successfully
b.     Observe for a while to see whether the problem disappears.
c.     If the problem disappears, the switching fabric module is likely to be the problem source. H3C recommends that you replace the module or install the module into another switch that is operating correctly to determine whether the module is really the problem source.
d.     If the problem persists, cancel the isolation.
[Sysname]undo board-offline slot 10
This command will reboot the specified board. Continue? [Y/N]:y
Config successfully
e.     After the switching fabric module in slot 10 starts up and operates correctly (in Normal state), isolate the switching fabric module in the next slot. Repeat the previous steps until you locate the failed switching fabric module and verify that other switching fabric modules are operating correctly.
·     If "Forwarding fault" messages show forwarding problems from the same LPU to multiple other LPUs, the LPU is likely to have a problem. If you are not sure whether the LPU has a problem, H3C recommends that you do the following to locate the problem source:
a.     Isolate switching fabric modules one by one, and observe whether the problem disappears.
b.     If the problem persists during the whole isolation process, the LPU might be the source of the problem. H3C recommends that you switch the services on the LPU to other LPUs and replace or isolate the LPU. If the problem is solved, the LPU is the source of the problem.
After you enable the hardware failure detection function, the switch automatically detects hardware failures on the following elements:
·     chip—Components.
·     board—Cards.
·     forwarding—Forwarding plane.
You can configure the switch to take the following actions in response to hardware failures:
·     off—Takes no action.
·     warningSends traps to notify you of the failures. (The default setting is warning.)
·     resetRestarts the relevant cards to recover from failures.
·     isolateShuts down the relevant ports, prohibits loading software for the relevant cards, isolates the relevant cards, or powers off the relevant cards to reduce impact from the failures.
If there are backup links, H3C recommends that you configure the switch to take the isolate action. This action isolates the failed element and helps recover services quickly. The following shows the configuration commands:
[Sysname]hardware-failure-detection chip isolate
Config successfully
[Sysname]hardware-failure-detection board isolate
Config successfully
[Sysname]hardware-failure-detection forwarding isolate
Config successfully
To display hardware failure detection and fix information, use the following command:
Current level:
    chip       : warning
    board      : warning
    forwarding : warning
---------------------Chassis 1, Slot  0 executed records:-------------------
                 There is no record.
---------------------Chassis 1, Slot  0 trapped records:--------------------
                 There is no record.
This section lists the commands that you might use for troubleshooting hardware forwarding.
board-offline
Isolate a card from the system.
Display hardware failure detection and fix information, including the following times:
·     Protection actions configured for hardware failures.
·     Most recent 10 fix records of each card.
Enable data forwarding path failure detection to examine whether data forwarding paths are operating correctly.
Configure hardware failure detection, and specify the actions to be taken in response to hardware failures. The purpose is to enable the device to automatically detect hardware failures and recover services.
Symptom
Packet loss and ping failure occurred.
<Sysname>ping 10.0.0.5
  PING 10.0.0.5: 56  data bytes, press CTRL_C to break
    Request time out
    Request time out
    Request time out
    Request time out
    Request time out
  --- 10.0.0.5 ping statistics ---
    5 packet(s) transmitted
    0 packet(s) received
    100.00% packet loss
Solution
Packet statistics collection
To resolve the problem, collect packet statistics by using packet capture tools or by configuring ACL rules. The following uses ACL rule as an example.
1.     Create an IPv4 advanced ACL rule to permit IP packets destined for 1.1.1.1.
[Sysname]acl number 3000
[Sysname-acl-adv-3000] rule 1 permit ip destination 1.1.1.1 0
2.     Define a traffic class and a traffic behavior.
[Sysname]traffic classifier statistic_1
[Sysname-classifier-static] if-match acl 3000
[Sysname] traffic behavior statistic_1
[Sysname-classifier-static] accounting packet
3.     Create a QoS policy, and associate traffic class statistic_1 with traffic behavior statistic_1 in the QoS policy.
[Sysname] qos policy statistic_1
[Sysname-classifier-static] classifier statistic_1 behavior statistic_1
4.     Apply the QoS policy to the incoming traffic of GigabitEthernet 8/0/1.
[Sysname] interface gigabitethernet 8/0/1
[Sysname-GigabitEthernet8/0/1] qos apply policy statistic_1 inbound
5.     Display information about the QoS policies applied to GigabitEthernet 8/0/1.
[Sysname] display qos policy interface g8/0/1
Interface: GigabitEthernet8/0/1
  Direction: Inbound
  Policy: statistic_1
   Classifier: statistic_1
     Operator: AND
     Rule(s) : If-match acl 3000
     Behavior: statistic_1
      Accounting Enable:
        1000 (Packets)
Packet count
If the device does not receive any ping packets, check the neighboring device on the uplink. If the number of ping packets sent by the device is correct, check the neighboring device on the downlink. If the number of ping packets sent is incorrect, see "Layer 2 forwarding failure, "Layer 3 forwarding failure," and "MPLS forwarding failure."
Symptom
Layer 2 packet loss or ping failure occurs between a switch and a device on the same network segment and in the same VLAN.
A switch can perform Layer 2 forwarding only when the destination MAC address of a packet is different from any MAC address of the switch. The switch has multiple MAC addresses in an address range. The following output shows the MAC addresses of a VLAN interface on a switch:
[Sysname]display interface vlan-interface 10
Vlan-interface10 current state: UP
Description: Vlan-interface10 Interface
The Maximum Transmit Unit is 1500
Internet Address is 10.0.0.1/24 Primary
IP Packet Frame Type: PKTFMT_ETHNT_2,  Hardware Address: 00e0-fc00-6503
IPv6 Packet Frame Type: PKTFMT_ETHNT_2,  Hardware Address: 00e0-fc00-6503
    0 packets input, 0 bytes, 0 drops
    0 packets output, 0 bytes, 0 drops
Solution
1.     Verify that the following Layer 2 configurations are correct:
?     VLAN and PVID.
?     Packet filtering.
?     Traffic redirection.
?     Traffic policing.
?     Generic traffic shaping (GTS).
?     Unknown unicast suppression/multicast suppression/broadcast suppression.
2.     Verify that the learned MAC addresses are correct. If they are not, determine whether loops occur. To quickly restore forwarding, you can configure static MAC address entries.
<Sysname>display mac-address
MAC ADDR        VLAN ID   STATE            PORT INDEX              AGING TIME(s)
000f-e259-79c0    25      Learned          GigabitEthernet2/15/0/1      AGING
00e0-fc12-3456    25      Learned          GigabitEthernet2/15/0/1      AGING
0023-8956-7b00  3102      Learned          Ten-GigabitEthernet2/4/0/1   AGING
0023-8956-7b00  3202      Learned          Ten-GigabitEthernet2/4/0/8   AGING
  ---  4 mac address(es) found  ---
3.     Verify traffic statistics:
?     Execute the qos traffic-counter inbound command to collect statistics about the inbound traffic.
[Sysname]qos traffic-counter inbound counter0 slot 3 interface Gigabitethernet 3/0/1
?     Execute the display qos traffic-counter inbound multiple times to observe the discarded packet count in the inbound direction. If the count continuously increases, verify the port configurations according to Table 8. If the reasons for packet loss still cannot be determined, contact H3C Support.
[Sysname]display qos traffic-counter inbound counter0 slot 3
Slot 3 inbound counter0 mode:
 Interface: GigabitEthernet3/0/1
 VLAN: all
Traffic-counter summary:
 Bridge in frames: 0 packets
 Bridge local discarded: 0 packets
 Bridge vlan ingress filter discarded: 0 packets
 Bridge security filter discarded: 0 packets
Table 8 Command output
Bridge in frames
Number of incoming packets.
A packet might be dropped due to the following reasons:
·     Traffic suppression is performed.
·     The outgoing interface is the same as the incoming interface, according to the MAC address table lookup result.
·     STP sets the state of the interface to discarding.
·     The VLAN of the packet is different from the VLAN of the interface.
·     The VLAN of the packet hasn't been created.
·     The packet matches a blackhole MAC address entry. To display blackhole MAC address entries, execute the display mac-address blackhole command.
·     The packet fails the MAC authentication. To display MAC authentication settings and statistics, execute the display mac-authentication interface command.
·     The source MAC address of the packet is a multicast MAC address or broadcast MAC address.
·     The source MAC address of the packet is unknown to the interface.
?     Execute the qos traffic-counter outbound command to collect statistics about the outbound traffic.
[Sysname]qos traffic-counter outbound counter0 slot 4 interface Gigabitethernet 4/0/1
?     Execute the display qos traffic-counter outbound multiple times to observe the discarded packet count in the outbound direction. If the count continuously increases, verify the port configurations according to Table 9. If the reasons for packet loss still cannot be determined, contact H3C Support.
[Sysname]display qos traffic-counter outbound counter0 slot 4
Slot 4 outbound counter0 mode:
 Interface: GigabitEthernet4/0/1
 VLAN: all
 Local precedence: all
 Drop priority: all
 Unicast: 0 packets
 Multicast: 0 packets
 Broadcast: 0 packets
 Control packets: 0 packets
 Bridge egress filtered packets: 0 packets
 Tail drop packets: 0 packets
 Multicast Tail drop packets: 2 packets
 Forward restrictions packets: 0 packets
Table 9 Command output
Unicast/Multicast/Broadcast
Number of packets that are not dropped.
Control packets
Number of control packets sent by the CPU.
·     RRPP or Smart Link blocks the interface.
·     The outgoing interface is down.
Tail drop packets
·     The transmit queue is congested.
·     Traffic shaping is performed.
A multicast or broadcast packet might be dropped due to the following reasons:
·     No outgoing interface is configured for the packet.
·     STP blocks the interface.
Number of packets that are prevented from being forwarded.
Symptom
IP service failures, ping or tracert operation failures, or ping or tracert packet loss occurs.
A switch performs Layer 3 forwarding by using the driver IP forwarding table instead of the routing table. The route management module selects optimal routes through various protocols, and puts them into the FIB table. The FIB table synchronizes the routes to the driver IP forwarding table, which guides packet forwarding.
Figure 3 Relationship between the routing table and forwarding table
Solution
1.     Use the mirroring function or capture packets to verify that the destination MAC address of packets is the MAC address of the switch.
A switch can perform Layer 3 forwarding only when the destination MAC address of a packet is the MAC address of the switch. The switch has multiple MAC addresses in an address range. The following output shows the MAC addresses of VLAN interfaces on a switch:
2.     Verify that the route to the specific destination exists in the routing table. If it does not exist, examine the routing protocol configurations and protocol states.
[Sysname]display ip routing-table 1.1.1.0
Routing Table : Public
Summary Count : 1
1.1.1.0/24           Static 60   0             20.0.0.2        Vlan20
3.     Verify that the route to the specific destination exists in the FIB table. If a route exists but cannot be used to guide the packet forwarding, contact H3C Support.
[Sysname]display fib 1.1.1.0
Destination count: 1    FIB entry count: 1
Flag:
  U:Useable G:Gateway H:Host B:Blackhole   D:Dynamic   S:Static
  R:Relay
Destination/Mask Nexthop   Flag  OutInterface  InnerLabel Token
1.1.1.0/24        20.0.0.2  USG    Vlan20         Null        Invalid
4.     Verify that the interfaces in the learned ARP entries are correct. If they are not, execute the reset arp command to clear ARP entries so that the device can learn the correct ARP entries. You can also configure static ARP entries. If the problem persists, contact H3C Support.
[Sysname]display arp 20.0.0.2
                Type: S-Static    D-Dynamic    A-Authorized    M-Multiport
IP Address       MAC Address     VLAN ID  Interface              Aging Type
20.0.0.2         0000-0000-0001  20        GE2/0/1                N/A    S
Symptom
You might experience the following problems with MPLS forwarding:
·     Unreachable destination.
·     No routes.
·     Error message printed.
·     Unstable tunnels.
·     Packet sending or receiving failure.
Solution
VLL, VPLS, and L3VPN are implemented based on LSPs.
To resolve the common problems with MPLS, verify the LSP and route configurations on the LSRs.
Figure 4 MPLS network diagram
Troubleshooting MPLS LSPs
Perform the following configurations on the ingress node (PE 1 in Figure 4):
1.     Execute the display mpls lsp command to display LSP information.
[PE1]display mpls lsp
LSP Information: LDP LSP
FEC                In/Out Label  In/Out IF                       Vrf Name
4.4.4.4/32         NULL/3        -/Vlan103
90.0.0.0/24        NULL/3        -/Vlan103
1.1.1.1/32         3/NULL        -/InLoop0
50.0.0.0/24        NULL/3        -/Vlan103
70.0.0.0/24        NULL/3        -/Vlan103
3.3.3.3/32         NULL/1025     -/Vlan103
If the configured LSP does not exist, verify the MPLS LSP configuration on each LSR.
2.     Execute the display mpls ldp peer command to display the LDP peer and session information.
[PE1]display mpls ldp peer
         LDP Peer Information in Public network
 Total number of peers: 1
 Peer-ID                Transport-Address  Discovery-Source
 4.4.4.4:0              4.4.4.4            Vlan-interface103
If the configured LSP is not up, verify the MPLS LSP configuration on each LSR.
3.     Execute the display mpls ldp session command to display LDP session information.
[PE1]display mpls ldp session
               LDP Session(s) in Public Network
 Total number of sessions: 1
 Peer-ID            Status        LAM  SsnRole  FT   MD5  KA-Sent/Rcv
 4.4.4.4:0    Non Existent        ---  Passive  Off  Off  0/0
 LAM : Label Advertisement Mode         FT  : Fault Tolerance
If the session status is not Operational, an error might occur. Go to steps 4 and 5 to further determine the problem. If the session status is Operational, go to step 6.
4.     Execute the display current-configuration configuration mpls-ldp command to display the MD5 password configuration for MPLS LDP.
<PE1>display current-configuration configuration mpls-ldp
mpls ldp
 md5-password cipher 2.2.2.2 GXA^DW>%V=_Q=^Q`MAF4<1!!
return
Verify that the local LSR and the peer LSR have the same MD5 password.
5.     Execute the display mpls ldp interface command to display LDP interface information.
[PE1]display mpls ldp interface
     LDP Interface Information in Public Network
 IF-Name         Status       LAM   Transport-Address   Hello-Sent/Rcv
 Vlan103         Active       DU    1.1.1.1             469/608
 LAM: Label Advertisement Mode         IF-Name: Interface name
If the label advertisement mode does not exist, verify the MPLS configuration on each LSR.
6.     Execute the display current-configuration command to display local LSR information.
<PE1>display current-configuration | include lsr-id
 mpls lsr-id 2.2.2.2
<PE1>display ip interface brief
*down: administratively down
(s): spoofing  (l): loopback
Interface          Physical Protocol IP Address      Description
Loop0              up       up(s)    100.100.100.100 --
Loop2              up       up(s)    100.100.100.102 --
M-E0/0/0           up       up       192.168.147.7   --
Vlan10             down     down     192.168.10.1    --
If the LSR ID is not the IP address of a loopback interface, H3C recommends that you configure the IP address of a loopback interface as the LSR ID by executing the mpls lsr-id command.
<PE1>system-view
[PE1]mpls lsr-id 100.100.100.100
7.     Verify that the VLAN interface is enabled with MPLS and MPLS LDP.
[PE1]interface vlan-interface 103
[PE1-Vlan-interface103]display this
interface Vlan-interface103
 ip address 1.1.1.2 255.255.255.0
 mpls
 mpls ldp
return
Troubleshooting routes
1.     Execute the display ip routing-table command to display routing table information.
[PE1]display ip routing-table
Routing Tables: Public
         Destinations : 10       Routes : 10
1.1.1.1/32          Direct 0    0            127.0.0.1       InLoop0
3.3.3.3/32          OSPF   10   2            103.0.0.4       Vlan103
4.4.4.4/32          OSPF   10   1            103.0.0.4       Vlan103
50.0.0.0/24         OSPF   10   2            103.0.0.4       Vlan103
70.0.0.0/24         OSPF   10   2            103.0.0.4       Vlan103
90.0.0.0/24         OSPF   10   2            103.0.0.4       Vlan103
103.0.0.0/24        Direct 0    0            103.0.0.1       Vlan103
103.0.0.1/32        Direct 0    0            127.0.0.1       InLoop0
Verify that the route entries include IP addresses of the loopback interfaces on PE 1, P, and PE 2, and the IP address of the remote device's VLAN interface. Otherwise, verify the routing protocol configuration on each LSR.
2.     Verify that the routing protocol operates correctly. If it does not, verify the routing protocol configuration on each LSR.
[PE1]display ospf peer
                        Neighbor Brief Information
 Area: 0.0.0.0
 Router ID       Address         Pri Dead-Time Interface       State
 4.4.4.4         103.0.0.4       1   37        Vlan103         Full/BDR
3.     Verify that the loopback interface and the VLAN interface are advertised in the routing protocol.
[PE1-ospf-1]display this
ospf 1
 area 0.0.0.0
  network 103.0.0.0 0.0.0.255
  network 1.1.1.1 0.0.0.0
return
4.     Execute the debugging command to verify that routing protocol packets are sent and received correctly. If they are not, verify the routing protocol configurations on the local LSR and remote LSR.
<PE1>debugging ospf packet
*Mar  5 04:33:09:294 2022 H3C RM/6/RMDEBUG: OSPF 1: SEND Packet.
*Mar  5 04:33:09:365 2022 H3C RM/6/RMDEBUG: Source Address: 103.0.0.1
*Mar  5 04:33:09:446 2022 H3C RM/6/RMDEBUG: Destination Address: 224.0.0.5
*Mar  5 04:33:09:537 2022 H3C RM/6/RMDEBUG: Ver# 2, Type: 1, Length: 48.
*Mar  5 04:33:09:618 2022 H3C RM/6/RMDEBUG: Router: 1.1.1.1, Area: 0.0.0.0, Checksum: 9355.
*Mar  5 04:33:09:719 2022 H3C RM/6/RMDEBUG: AuType: 00, Key(ascii): 0 0 0 0 0 0 0 0.
*Mar  5 04:33:09:820 2022 H3C RM/6/RMDEBUG: Net Mask: 255.255.255.0, Hello Int: 10, Option: _E_.
*Mar  5 04:33:09:931 2022 H3C RM/6/RMDEBUG: Rtr Priority: 1, Dead Int: 40, DR: 103.0.0.1, BDR: 103.0.0.4.
*Mar  5 04:33:10:053 2022 H3C RM/6/RMDEBUG: Attached Neighbor: 4.4.4.4.
*Mar  5 04:33:10:437 2022 H3C RM/6/RMDEBUG: OSPF 1: RECV Packet.
*Mar  5 04:33:10:508 2022 H3C RM/6/RMDEBUG: Source Address: 103.0.0.4
*Mar  5 04:33:10:589 2022 H3C RM/6/RMDEBUG: Destination Address: 224.0.0.5
*Mar  5 04:33:10:680 2022 H3C RM/6/RMDEBUG: Ver# 2, Type: 1, Length: 48.
*Mar  5 04:33:10:761 2022 H3C RM/6/RMDEBUG: Router: 4.4.4.4, Area: 0.0.0.0, Checksum: 9355.
This section lists the commands that you might use for troubleshooting IP forwarding.
accounting packet
Configures a traffic accounting action in the traffic behavior database to count traffic in packets.
acl
Creates an ACL, and enters its view.
classifier behavior
Associates a traffic behavior with a traffic class in a QoS policy.
Enables OSPF packet debugging to examine whether OSPF packets can be correctly sent and received.
display arp
Displays ARP entries to check whether output interfaces can be correctly learned through ARP.
Displays the current MPLS LSR ID.
Displays information about MPLS LDP to verify the consistency of MD5 passwords.
display fib
Displays FIB entries to examine whether an entry matching a specific destination network exists in the FIB table.
display interface
Displays information about the specified interface.
Displays brief IP configuration information for the specified Layer 3 interface or all Layer 3 interfaces.
Displays brief information about active routes in the routing table to examine whether a route to the specified network exists in the routing table.
display mac-address
Displays MAC address entries to examine whether interfaces can be correctly learned.
Displays LDP interface information to examine whether the corresponding label advertisement mode exists.
Displays LDP peer information to examine whether the configured LSPs are up.
Displays LDP session information.
display mpls lsp
Displays information about LSPs.
display ospf peer
Displays information about OSPF neighbors.
Displays information about the QoS policy or policies applied to an interface.
Displays the traffic statistics collected by the specified counter, and displays the configuration of the counter.
display this
Displays the running configuration in the current view.
Enters interface view.
Rule
Creates an ACL rule.
traffic behavior
Creates a traffic behavior and enters traffic behavior view.
traffic classifier
Creates a class and enters class view.
qos apply policy
Applies a QoS policy to a port.
qos policy
Creates a QoS policy and enters QoS policy view.
qos traffic-counter
Enables the traffic accounting function, and specifies the type of traffic.
mpls lsr-id
Configures an LSR ID for the local LSR.
Ping
Examines whether the destination IP address is reachable, and displays related statistics.
Troubleshooting IRF
This section provides troubleshooting information for common problems with IRF.
IRF fabric establishment failure
Symptom
An H3C S12500 IRF fabric cannot be established.
Solution
1.     Verify that all member chassis run the same software version and use the same type of MPUs:
a.     Execute the display device command. Check the Brd Type and Software Version fields for the software version and MPU type.
<Sysname> display device
b.     If the member chassis run different software versions, upgrade the software to the same version. If they use different types of MPUs, replace MPUs.
2.     Verify that at least one IRF physical port is up for an IRF port:
An IRF port goes down only if all its physical ports are down.
a.     Execute the display interface command. Check the current state field for the status of an IRF physical port. For example:
<Sysname> display interface gigabitethernet 1/5/0/1
 GigabitEthernet1/5/0/1 current state: UP
 IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 0023-8956-7a04
 Description: GigabitEthernet1/5/0/1 Interface
 Media type is twisted pair, Port hardware type is 1000_BASE_T
b.     If all physical ports bound to an IRF port are down, bring them up. H3C recommends binding multiple physical ports to an IRF port for redundancy.
3.     Verify that all IRF physical ports are connected correctly:
IMPORTANT
IMPORTANT:
When you connect two neighboring IRF members, you must connect the physical ports of IRF-port 1 on one member to the physical ports of IRF-port 2 on the other.
a.     Execute the display irf configuration command. Check the IRF-Port1 and IRF-Port2 fields for IRF port bindings.
<Sysname> display irf configuration
 MemberID  NewID  IRF-Port1                        IRF-Port2
  1         1     Ten-GigabitEthernet1/8/0/1       disable
                  Ten-GigabitEthernet1/8/0/2
  2         2     disable                          Ten-GigabitEthernet2/12/0/1
                                                   Ten-GigabitEthernet2/12/0/2
b.     Verify that the physical IRF connections are consistent with the IRF port bindings. In this example, Ten-GigabitEthernet 1/8/0/1 and Ten-GigabitEthernet 1/8/0/2 on member chassis 1 must be connected to Ten-GigabitEthernet 2/12/0/1 and Ten-GigabitEthernet 2/12/0/2 on member chassis 2.
c.     If connection errors exist, reconnect the IRF physical ports.
4.     Verify that all member chassis use the same system operating mode:
a.     Execute the display system working mode command on each member chassis. Check the command output for mode inconsistency.
[Sysname] display system working mode
b.     If mode inconsistency exists, execute the system working mode command to change the system operating mode. The command setting takes effect after a system reboot.
5.     Verify that the configuration is the same across all chassis:
IMPORTANT
IMPORTANT:
The settings for the following commands must be the same across all chassis: acl ipv6, acl mode, irf mode enhanced, portal-roaming enable, and vpn popgo.
a.     Execute the display this command. Check the configuration on each member chassis for configuration inconsistency.
[Sysname] display this
 acl ipv6 disable
 undo vpn popgo
 system working mode routee
b.     If configuration inconsistency exists, modify the configuration.
6.     If the problem persists, contact H3C Support.
IRF split
Symptom
An IRF fabric splits.
Solution
1.     Use the system log to identify the IRF split time.
You can use this information to search the system log for events that might cause the split.
%Jan 13 19:31:22:476 2010 H3C STM/4/LINK STATUS CHANGE:
 IRF port 1 is down because heartbeat timed out.
%Jan 13 19:31:22:689 2010 H3C STM/4/LINK STATUS CHANGE:
 IRF port 1 is down.
2.     Verify that all interface cards that have IRF physical ports are in Normal state:
a.     Execute the display device command. Check the Brd Status field for the card state.
b.     If an interface card is not in Normal state, use the methods described in "Card failure" to resolve the problem.
3.     Verify that each IRF port has at least one physical port in up state:
a.     Execute the display interface command. Check the current state field for the state of an IRF physical port. For example:
b.     If any physical port bound to an IRF port is down, recover the link state and bring up the physical port (see "Troubleshooting links and ports").
4.     Remove hardware problems that might cause recurring IRF split events:
a.     Execute the display version command. Check the uptime of the member chassis, MPUs, and interface cards that have IRF links.
<Sysname> display version
3456    Mbytes SDRAM
Type     : LST1MRPNC1
BootRom  : 1.22
Patch    : NONE
PCB      : Ver.B
b.     Compare the uptime of chassis, MPUs, and interface cards to determine whether a member chassis, MPU, or interface card rebooted before the IRF split.
c.     If the IRF split is caused by a chassis or card reboot, identify the reboot cause:
-     If the reboot occurred because of a hardware problem, replace the faulty component.
-     If the reboot occurred because of power failure, use the methods described in "Power supply failure" to remove the power supply problems.
This section lists the commands that you might use for troubleshooting IRF.
display device
Displays device configuration.
Use this command to verify that all member chassis run the same software version and use the same type of MPUs.
display interface
Displays interface information.
Use this command to verify that each IRF port has at least one physical port in up state.
Displays IRF configuration on each member chassis.
Use this command to identify physical ports bound to IRF-port 1 and IRF-port 2 on each member chassis before you check IRF physical connections.
Displays system operating mode.
Use this command to verify that all member chassis are operating in the same mode.
display this
In system view, verify that the settings for the following commands are the same across all chassis: acl ipv6, acl mode, irf mode enhanced, portal-roaming enable, and vpn popgo.
display version
Displays the system version and uptime as well as the uptime of each card.
Use this command to identify the runtime of each member chassis, MPU, and interface card that has IRF physical ports. Compare their uptime to determine whether a member chassis, MPU, or interface card rebooted before an IRF split.
Troubleshooting system management
This section provides troubleshooting information for common problems with system management.
High CPU usage
Symptom
A CPU usage higher than 60% persists on a card.
<Sysname>display cpu-usage
Slot 0 CPU usage:
       0% in last 5 seconds
      61% in last 1 minute
       0% in last 5 minutes
Slot 0 CPU 1 CPU usage:
       0% in last 1 minute
Execute the display cpu-usage history command to display the CPU usage statistics within the last 60 minutes.
<Sysname>display cpu-usage history slot 0
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|                             #
 30%|                         #   #
 25%|                         #   #
 20%|           #             #   #                    #
 15%|          ##             #   #                   ##
 10%|          ##             #   #                   ##
  5%|############################################################
              10        20        30        40        50        60  (minutes)
              cpu-usage last 60 minutes(SYSTEM)
Solution
High CPU usage might occur because of the following issues:
·     Link loop.
·     Packet attack.
·     Route flapping.
·     Too many routing policies.
To resolve the problem:
1.     Execute the display cpu-usage number [verbose] [slot slot-number [cpu cpu-number] ] command to display tasks with high CPU usage.
<Sysname>display cpu-usage 5 verbose slot 0
===== CPU usage info (no:  0  idx: 31) =====
CPU Usage Stat. Cycle: 60 (Second)
CPU Usage            : 63%                        <--- CPU usage
CPU Usage Stat. Time : 2009-07-26  16:55:33       <--- Statistics collection time
CPU Usage Stat. Tick : 0x15(CPU Tick High) 0x429be6f6(CPU Tick Low)
Actual Stat. Cycle   : 0x0(CPU Tick High) 0xb2d2a975(CPU Tick Low)
TaskName        CPU        Runtime(CPU Tick High/CPU Tick Low)
VIDL            37%               0/77d02af4
TICK             0%               0/  469276
STMR             0%               0/   7d8c9
DIBC             0%               0/  3e1ecd
 BFD             0%               0/   463ad
MFIB             0%               0/   ae8a6
IGSP             0%               0/     431
ROUT             0%               0/  30a6ed
TNLM             0%               0/   37a26
IFNT             0%               0/    833f
 co0            61%               0/39012f2b
The output shows that the CPU usage of the VIDL and co0 is 37% and 61%, respectively. A high CPU usage for the VIDL task indicates that the device is idle more of the time, so it is co0 that causes high CPU usage. You need to determine which task causes the high CPU usage. For example, if it is the ROUT task that causes high CPU usage, the reason might be flapping route.
Table 10 Task description
VFS
Cross-card file system operation task.
VIDL
Idle task.
VMON
System monitoring task.
IPCB
IPC main task.
IPCD
IPC packet distribution task.
RPCQ
RPC packet sending timeout check task.
RPCD
RPC packet distribution task.
INFO
Information center task.
co0
Session task between a console user and the device.
au0
Session task between an AUX user and the device.
STM
STM main task.
STMH
STM hello packet sending task.
VLAN
VLAN task.
DDNS
Dynamic DNS task.
DNS
DNS task.
HTTP
HTTPD and HTTPS main task.
HDQx
Sub task for HTTP request processing.
MAC
MAC main task.
ARP
ARP task.
IP
IP task.
DHCP
DHCP task.
DHSE
DHCP snooping security entry processing task.
DHCC
DHCP client main task.
DHC6
DHCPv6 client task.
DHP6
DHCPv6 common task.
FIB6
IPv6 FIB task.
FIB
IPv4 FIB task.
ND
IPv6 ARP task.
LFIB
MPLS forwarding and FIB maintenance task.
L2V
MPLS L2 VPN task.
MACA
MAC authentication task.
ROUT
Routing management task.
BFD
Bidirectional forwarding detection task.
DLDP
DLDP task.
EOAM
Ethernet OAM task.
GARP
GVRP task.
LAGG
Link aggregation task.
LLDP
LLDP task.
LPDT
Loop detection task.
MAC
MAC address entry aging task.
MGRP
Port mirroring task.
MSTP
MSTP task.
MTLK
Monitor link task.
QINQ
QinQ task.
QOS
QoS task.
RRPP
RRPP task.
SMLK
Smart link.
DT1X
802.1X authentication task.
CF
CF card mounting/unmounting task.
L2AU
MAC AU message processing task.
L2HC
MAC check task.
2.     Execute the display route-policy command to display the configured routing policies to verify that the configured routing policies are reasonable.
<Sysname> display route-policy
Route-policy : policy1
  permit : 10
        if-match ip-prefix abc
        apply cost 120
3.     Execute the display interface command, and check for loop links.
<Sysname>display interface ten-gigabitethernet 2/3/0/1
 Ten-GigabitEthernet2/3/0/1 current state: UP
 IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000f-e20a-2005
 Description: Ten-GigabitEthernet2/3/0/1 Interface
 Peak value of input: 0 bytes/sec, at 2013-05-29 15:05:34
 Peak value of output: 1191343840 bytes/sec, at 2013-05-29 19:30:44
 Last 300 seconds input:  0 packets/sec 0 bytes/sec 0%
 Last 300 seconds output:  0 packets/sec 0 bytes/sec 0%
If any loop occurs, verify the following:
?     The link connections and port configuration are correct.
?     STP is enabled, and the configuration is correct.
?     The STP status of the neighboring device is normal.
?     If all the previous configurations are correct, the reason might be:
-      STP calculation error.
-     STP calculation is correct, but the driver does not block a port.
You can do all of the following:
?     Shut down the uplink port on the ring.
?     Remove and insert the transceiver module into the port to restart STP calculation.
?     Contact H3C Support.
Insufficient resources
Symptom
The system displays the following log and trap information when resources are insufficient:
%Oct 30 20:41:42:29 2011 LS-SHQ-9508 DRVL3/4/NO_RESOURCE:No enough resource: Insufficient system resources!
[hntjjS12508]mirroring-group 2 monitor-port g4/0/34
Error: Local mirroring-group number exceeds hardware capability.
Solution
ACL resources
The following features use ACL resources:
·     QoS.
·     Packet filter.
·     Priority mapping and trust.
·     Mirror.
·     Protocol packet to CPU.
·     Selective QinQ and VLAN mapping.
·     Port binding, PORTAL, and EAD.
·     Broadcast suppression.
·     MAC-BASED-VLAN, VOICE VLAN, RSPAN, and UDP-Helper.
The system displays the following information for insufficient resources:
%Sep  9 13:56:24:871 2011 H3C DRVQACL/5/LOG_NOTICE: PCL resources are not enough.
1.     Display the ACL usage on a card.
<Sysname>display acl resource chassis 2 slot 2
 Interface:
   GE2/2/0/1 to GE2/2/0/24
 Type          Total       Reserved    Configured  Remaining   Usage
 ACL rule      2048        0           89          1959        4%
 Inbound ACL   2048        0           3           1959        0%
 Outbound ACL  2048        0           86          1959        4%
 Interface:
   GE2/2/0/25 to GE2/2/0/48
2.     If most ACL resources are allocated, optimize ACL configuration. For example, delete or combine ACL rules. If the configuration cannot be optimized, contact H3C Support.
Multicast resources
1.     Display multicast statistics in the .diag file.
  ===============Display l3mc keyinfo slot 1===============
Resource Info:
 TCAM Resource: total 511 free 511
 Local DIT Resource: total 1003 free 871 usage list:
  L3MC: 132
  SUPERVLAN: 0
  VLL: 0
  VPLS: 0
  DIAG: 0
  BLG: 0
 Local VIDX Resource: total 2044 free 2040
2.     If most multicast resources are allocated, optimize multicast configuration. For example, delete multicast entries not in use. If the configuration cannot be optimized, contact H3C Support.
ARP resources
1.     Display ARP statistics in the .diag file.
  ===============Display arpnd index resourece slot 4===============
Resource distribution on master board:
Total Index number is 12287, ARP alloced 2724, ND alloced 8274.
    (   0 -    7):      2     0     0    10  6000    64   148   280
    (   8 -   15):     81  1000  3048   820     a  4520     0    80
Total Index number indicates the maximum number of ARP/ND resources. ARP alloced indicates allocated ARP resources. ND alloced indicates allocated ND resources.
2.     If most ARP/ND resources are allocated, H3C recommends that you do one of the following:
?     Optimize the network by reducing the number of gateways.
?     Replace the EB card with the EC card, and change the operating mode of the system to Routee.
FIB resources
1.     Display FIB information in the .diag file.
===============Display L3 fib information slot 3===============
 Ipv4 route prefix       : 12
 Ipv6 route prefix       : 1
 Allocated route entry   : 9
 Ipv4Uc allocated nexthop: 2   1    0   0   0   0   0  0
 Ipv6Uc allocated nexthop: 1   0    0   0   0   0   0  0
 Ipv4Mc allocated nexthop: 1
 Ipv6Mc allocated nexthop: 0
 Tunnel allocated nexthop: 0
 Max support vrf         : 4096
 Max support ipv4 prefix : 262144
 Max support ipv6 prefix : 131072
 Max support nexthop     : 65536
2.     If most FIB resources are allocated, contact H3C Support.
MAC resources
MAC resource insufficiency problems easily occur in large Layer 2 networks. There is a large amount of MAC addresses in these networks. New MAC addresses cannot be learned because old MAC addresses have not aged.
1.     Display MAC addresses that have been learned.
<Sysname>display mac-address count
 49 mac address(es) found
The output shows that the number of MAC addresses that have been learned is small.
2.     H3C recommends that you do the following:
?     Set a smaller MAC address aging time.
?     Create VLANs by service or by department, and connect VLANs at Layer 3.
MPLS LSP resources
The system displays the following information if the resources are insufficient:
%Jul 28 16:02:24:563 2011 H3C DRVMPLS/3/L3VPN_ERR: -Chassis=2-Slot=3; L3VPN ERR: No enough resource!
1.     Display MPLS LSP statistics.
<Sysname>display mpls lsp statistics
Lsp Type       Total     Ingress   Transit   Egress
STATIC LSP     0         0         0         0
STATIC CRLSP   0         0         0         0
LDP LSP        3         1         0         2
CRLDP CRLSP    0         0         0         0
RSVP CRLSP     0         0         0         0
BGP LSP        0         0         0         0
ASBR LSP       0         0         0         0
BGP IPV6 LSP   0         0         0         0
LSP            3         1         0         2
CRLSP          0         0         0         0
2.     If MPLS LSP resources are insufficient, contact H3C Support.
This section lists the commands that you might use for troubleshooting system management.
Remarks
Displays ACL resource information.
display cpu-usage
Displays CPU usage statistics and tasks with high CPU usage.
Displays the historical CPU usage statistics in charts.
display interface
Displays information about a specific interface.
display mac-address
Displays MAC address entries.
Displays MPLS LSP statistics.
