H3C LSWM124XGT2Q Interface Card User Manual-6PW105
HomeSupportInstall & UpgradeInstallation GuidesH3C LSWM124XGT2Q Interface Card User Manual-6PW105
Download Book
  • Released At: 04-12-2020
  • Page Views:
  • Downloads:
Table of Contents
Related Documents
H3C LSWM124XGT2Q interface card user manual-6PW105
▌About the LSWM124XGT2Q interface card
Important information
The LSWM124XGT2Q interface card is applicable to multiple H3C switch models. For the interface card compatibility with switches, contact H3C Support or marketing staff.
Front panel
The LSWM124XGT2Q interface card provides 24 10GBASE-T ports and two QSFP+ ports.
Figure 1 LSWM124XGT2Q interface card front panel
(1) 10GBASE-T port LED
(2) QSFP+ port LED
(3) QSFP+ port
(4) 10GBASE-T port
▌Ports
·     As a best practice, use H3C transceiver modules and cables for the interface cards.
·     The transceiver module and cable types supported by the LSWM124XGT2Q interface card vary by device model. For more information, see the installation guide or hardware reference for the device, or contact H3C Support or marketing staff.
·     The restrictions and guidelines for using the LSWM124XGT2Q interface card vary by device model. For more information, see the installation guide or hardware reference for the device.
·     For more information about H3C transceiver modules and cables, see H3C Transceiver Modules User Guide at www.h3c.com.
10GBase-T ports
Table 1 10GBase-T port specifications
Item
Specification
Connector type
RJ-45
Port standard
1/10 Gbps full duplex, MDI/MDI-X auto-sensing
Transmission medium and max transmission distance
·     Category-6 unshielded twisted pair cable: 55 m (180.45 ft)
·     Category-6 shielded twisted pair cable: 100 m (328.08 ft)
·     Category-6A or above twisted pair cable: 100 m (328.08 ft)
Compliance standard
·     IEEE 802.3an
·     IEEE 802.3ab
QSFP+ ports
You can install the following transceiver modules and cables in the QSFP+ ports on an LSWM124XGT2Q interface card:
·     QSFP+ transceiver modules in Table 2 and Table 3.
·     QSFP+ DAC cables in Table 4.
·     QSFP+ to SFP+ DAC cables in Table 5.
·     QSFP+ fiber cables in Table 6.
Table 2 QSFP+ transceiver modules available for the QSFP+ ports (1)
Central wavelength (nm)
Connector
QSFP-40G-SR4-MM850
850
MPO
QSFP-40G-CSR4-MM850
850
MPO
QSFP-40G-LR4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
QSFP-40G-LR4L-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Table 3 QSFP+ transceiver modules available for the QSFP+ ports (2)
Cable/fiber diameter (µm)
Modal bandwidth (MHz × km)
Max transmission distance
QSFP-40G-SR4-MM850
Multi-mode, 50/125
2000
100 m (328.08 ft)
4700
150 m (492.12 ft)
QSFP-40G-CSR4-MM850
Multi-mode, 50/125
2000
300 m (984.25 ft)
4700
400 m (1312.33 ft)
Single-mode, 9/125
N/A
10 km (6.21 miles)
Single-mode, 9/125
N/A
2 km (1.24 miles)
Table 4 QSFP+ DAC cables available for the QSFP+ ports
QSFP+ DAC cable
Cable length
Data rate
LSWM1QSTK0
1 m (3.28 ft)
40 Gbps
LSWM1QSTK1
3 m (9.84 ft)
LSWM1QSTK2
5 m (16.40 ft)
Table 5 QSFP+ to SFP+ DAC cables available for the QSFP+ ports
Cable length
Data rate
LSWM1QSTK3
1 m (3.28 ft)
40 Gbps
LSWM1QSTK4
3 m (9.84 ft)
LSWM1QSTK5
5 m (16.40 ft)
Table 6 QSFP+ fiber cables available for the QSFP+ ports
QSFP+ fiber cable
Cable length
Data rate
QSFP-40G-D-AOC-7M
7 m (22.97 ft)
40 Gbps
QSFP-40G-D-AOC-10M
10 m (32.81 ft)
QSFP-40G-D-AOC-20M
20 m (65.62 ft)
▌LEDs
The indications of the LEDs on the LSWM124XGT2Q interface card vary by device model. For more information, see the installation guide or hardware reference for the device.
10GBASE-T port LEDs
Table 7 10GBase-T port LED description
LED status
Steady green
The port is operating at 10 Gbps, and a link is present on the port.
Flashing green
The port is sending or receiving data at 10 Gbps.
Steady yellow
The port is operating at 1 Gbps, and a link is present on the port.
Flashing yellow
The port is sending or receiving data at 1 Gbps.
Off
No link is present on the port.
QSFP+ port LEDS
Table 8 QSFP+ port LED description
LED status
Steady green
A transceiver module is installed in the port. The port is operating at 40 Gbps, and a link is present on the port.
Flashing green
The port is sending or receiving data at 40 Gbps.
Steady yellow
A transceiver module is installed in the port. The port is operating at 10 Gbps, and a link is present on the port.
Flashing yellow
Off
No transceiver module is installed in the port, or no link is present on the port.
▌Installing and removing an interface card
CAUTION-一纸通
CAUTION:
·     Before you install or remove an interface card, wear an ESD wrist strap and make sure the strap makes good skin contact and is reliably grounded.
·     To avoid device damage, do not use excessive force when you install or remove an interface card.
·     The LSWM124XGT2Q interface card is hot swappable. However, do not install or remove it during the startup of the switch.
Installing an interface card
Before you install an interface card, remove the filler panel (if any) from the target slot. Keep the removed filler panel secure for future use.
To install an interface card:
1.     Unpack the interface card.
Figure 2 LSWM124XGT2Q interface card
(1) Ejector lever
(2) Latch
2.     Press the latch on the interface card to release the ejector lever.
3.     As shown by callout 1 in Figure 3, insert the interface card slowly into the slot along the guide rails.
4.     Rotate inward the ejector lever as shown by callout 2 in Figure 3 until the latch locks the ejector lever in place.
Figure 3 Installing an LSWM124XGT2Q interface card
Removing an interface card
CAUTION-一纸通
CAUTION:
·     Before you remove an interface card, remove the cable from it to avoid cable damage.
·     After removing an interface card, if no new interface card is to be installed, install the filler panel as soon as possible to prevent dust and ensure good ventilation in the device.
To remove an interface card:
1.     Prepare an anti-static bag.
2.     Press the latch to release the ejector lever
3.     Rotate outward the ejector lever as shown by callout 1 in Figure 4.
4.     Pull out the interface card slowly out of the interface card slot, as shown by callout 2 in Figure 4.
5.     Place the removed interface card in the anti-static bag.
Figure 4 Removing an LSWM124XGT2Q interface card
Installing and removing QSFP+ transceiver modules and cables
For information about installing and removing QSFP+ transceiver modules and cables, see H3C Transceiver Modules and Network Cables Installation Guide at www.h3c.com.
Verifying the installation
After the installation is complete, identify whether the interface card is operating correctly.
If the interface card fails to operate correctly, perform the following steps:
1.     Reinstall it following the installation procedures described in this document.
2.     If the problem persists, contact H3C Support.
▌Technical support
New H3C Technologies Co., Ltd. provides customers with comprehensive technical support and service. If you purchase the products from the sales agent of New H3C Technologies Co., Ltd., please contact our sales agent or technical personnel.
Website: http://www.h3c.com
BOM: 3101A0HJ
