H3C WA6622 New Generation Access Point
H3C WA6622 series access points are the latest generation wireless access points developed based on 802.11ax standard. They are designed with dual-radio 802.11ax technology standard, and provide a transmission speed at least 2 times faster than 802.11ac products. This makes the series suitable for high-density access scenarios, such as hotel, stadium, and enterprise campus, and e-schoolbag applications.
With built-in antennas, WA6622 supports dual radio and multi-rate uplink ports with the max speed of 5Gbps or 10Gbps. WA6622 is compact in appearance and supports both wall mounting and ceiling mounting.
The following contents are complex, and it is recommended to browse on PC.
Enter c.h3c.com.cn on the PC browser and operate according to the page to synchronize to the PC and continue browsing.
Continue by mobile
