08-VSRP commands | 196.45 KB |
display pppoe-server sync-session
vsrp-instance (L2TP group view)
vsrp-instance (DHCPv4/DHCPv6 address pool view)
VSRP commands
VSRP peer commands
display vsrp peer
Use display vsrp peer to display VSRP group information.
display vsrp peer [ peer-name ]
peer-name: Specifies a VSRP group by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSRP group, this command displays information about all VSRP groups.
# Display information about VSRP group pname.
<Sysname> display vsrp peer pname
VSRP peer name: pname
TCP status: Connected
Peer IP: 11.0.0.3
Local IP: 10.0.0.3
Port: 6000
Track ID: 5
Track status: Positive
# Display information about all VSRP groups.
VSRP peer name: pname1
Peer IP: 11.0.0.3
Local IP: 10.0.0.3
Port: 6000
Track ID: 5
VSRP peer name: pname2
TCP status: Disconnected
Peer IP: 10.0.0.2
Local IP: 11.0.0.2
Port: 5000
Track ID: 5
Track status: Negative
VSRP peer name |
Name of a VSRP group. |
TCP status |
TCP control channel state: Connected or Disconnected. |
Peer IP |
Peer IP address for VSRP channels. |
Local IP |
Local IP address for VSRP channels. |
Port |
Port number for the TCP control channel. |
Track ID |
ID of the track entry associated with the VSRP group. |
Track status |
Track entry state: · Positive. · NotReady. · Negative. |
peer
Use peer to configure the IPv4 TCP parameters for establishing VSRP channels to the peer.
Use undo peer to restore the default.
peer peer-ip-address local local-ip-address [ port port-id ]
undo peer
No IPv4 VSRP channels are established to the peer.
VSRP peer view
peer-ip-address: Specifies the IPv4 address of the peer.
local local-ip-address: Specifies the IPv4 address of the local device.
port port-id: Specifies the TCP port number for establishing the control channel. The value range is 1024 to 65535 and the default is 60032. The specified port number cannot be one that is in use.
You must specify different unicast IPv4 addresses for the peer device and the local device in a VSRP group. The IPv4 addresses cannot be all zeros or loopback addresses.
If you have multiple VSRP groups, make sure their IP address pairs are unique.
To change the TCP parameters for VSRP channel establishment, first execute the undo form of the command to remove the existing IPv4 VSRP channels.
# Specify channel establishment parameters for VSRP group pname. Set the local IPv4 address to 11.0.0.2, the peer IPv4 address to 10.0.0.1, and the TCP port number for the control channel to 7000.
[Sysname] vsrp peer pname
[Sysname-vsrp-peer-pname] peer 10.0.0.1 local 11.0.0.2 port 7000
peer ipv6
Use peer ipv6 to configure the IPv6 TCP parameters for establishing VSRP channels to the peer.
Use undo peer ipv6 to restore the default.
peer ipv6 peer-ipv6-address local local-ipv6-address [ port port-id ]
undo peer ipv6
No IPv6 VSRP channels are established to the peer.
VSRP peer view
peer-ipv6-address: Specifies the IPv6 address of the peer.
local local-ipv6-address: Specifies the IPv6 address of the local device.
You must specify different IPv6 unicast addresses for the peer device and the local device in a VSRP group. The IPv6 addresses cannot be all zeros or loopback addresses.
The specified IP addresses are also used to establish data channels. You can specify TCP ports for establishing data channels by service type in system view.
# Specify the channel establishment parameters for VSRP group pname. Set the local IPv6 address to 1::1, the peer IPv6 address to 2::2, and the TCP port number for the control channel to 7000.
[Sysname-vsrp-peer-pname] peer ipv6 2::2 local 1::1 port 7000
track
Use track to associate a VSRP group with a track entry.
Use undo track to restore the default.
track track-entry-number
undo track
A VSRP group is not associated with any track entry.
VSRP peer view
track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
By default, a VSRP group can detect the state of the failover link based only on the state of the TCP control channel.
You can associate a VSRP group with a track entry to identify the state of the failover link.
· When the track entry is in Positive or NotReady state, a device in the VSRP group attempts to establish a TCP control channel to the peer.
· When the track entry changes to Negative state, the device terminates the TCP control channel.
A VSRP group takes effect only when a TCP control channel is established.
For more information about track entries, see High Availability Configuration Guide.
# Associate VSRP group pname with track entry 10.
[Sysname-vsrp-peer-pname] track 10
vsrp peer
Use vsrp peer to create a VSRP group and enter VSRP peer view, or enter the VSRP peer view of an existing VSRP group.
Use undo vsrp peer to remove a VSRP group.
vsrp peer peer-name
undo vsrp peer peer-name
No VSRP groups exist.
You can create a maximum of 64 VSRP groups on the device.
If a VSRP instance exists on a VSRP group, you must use the undo backup id command to remove that VSRP instance before you can remove the VSRP group.
# Create a VSRP group named pname and enter VSRP peer view.
VSRP instance commands
backup id
Use backup id to specify a backup ID for a VSRP instance.
Use undo backup id to restore the default.
backup id backup-id peer peer-name
undo backup id
A VSRP instance has no backup ID.
VSRP instance view
backup-id: Specifies a VSRP instance by its backup ID in the range of 1 to 1024.
A VSRP instance can be associated with only one VSRP group. The backup ID uniquely identifies a VSRP instance in a VSRP group.
You must specify the same backup ID for a VSRP instance on both devices in a VSRP group.
When you specify a backup ID for a VSRP instance, make sure the following conditions are met:
· The associated VSRP group already exists.
· The backup ID is unique in the VSRP group.
To specify a new backup ID for a VSRP instance, first execute the undo form of the command to remove the existing backup ID setting.
# Specify the backup ID of VSRP instance aaa as 5 in VSRP group pname.
[Sysname] vsrp instance aaa
[Sysname-vsrp-instance-aaa] backup id 5 peer pname
backup mode
Use backup mode to set the backup mode for a VSRP instance.
Use undo backup mode to restore the default.
backup mode { hot | warm }
undo backup mode
A VSRP instance operates in hot backup mode.
VSRP instance view
hot: Specifies hot backup mode.
warm: Specifies warm backup mode.
In hot backup mode, the backup device issues backup information to the data plane immediately upon receiving the information from the master. This allows the VSRP instance to perform a fast master and backup switchover to enable the backup to forward packets when the master fails.
In warm backup mode, the backup device does not issue received backup information to the data plane immediately. When the master fails and a switchover occurs, the backup begins to set backup information to the data plane. As a result, the switchover takes longer in warm backup mode than in hot backup mode.
# Set VSRP instance aaa to operate in warm backup mode.
[Sysname-vsrp-instance-aaa] backup mode warm
bind vrrp ipv6 vrid
Use bind vrrp ipv6 vrid to bind a VSRP instance to an IPv6 VRRP group.
Use undo bind vrrp ipv6 to restore the default.
bind vrrp ipv6 vrid virtual-router-id interface interface-type interface-number
undo bind vrrp ipv6
A VSRP instance is not bound to any IPv6 VRRP group.
VSRP instance view
virtual-router-id: Specifies an IPv6 VRRP group by its virtual router ID in the range of 1 to 255.
A VSRP instance is bound to an IPv6 VRRP group to determine the device role (master or backup) in a VSRP group.
You can bind a VSRP instance to only one IPv6 VRRP group. The IPv6 VRRP group can be on any interface.
# Bind VSRP instance aaa to IPv6 VRRP group 2 on GigabitEthernet 1/0/1.
[Sysname-vsrp-instance-aaa] bind vrrp ipv6 vrid 2 interface gigabitethernet 1/0/1
bind vrrp vrid
Use bind vrrp vrid to bind a VSRP instance to an IPv4 VRRP group.
Use undo bind vrrp to restore the default.
bind vrrp vrid virtual-router-id interface interface-type interface-number
undo bind vrrp
A VSRP instance is not bound to any IPv4 VRRP group.
VSRP instance view
virtual-router-id: Specifies an IPv4 VRRP group by its virtual router ID in the range of 1 to 255.
A VSRP instance is bound to an IPv4 VRRP group to determine the device role (master or backup) in a VSRP group.
You can bind a VSRP instance to only one IPv4 VRRP group. The IPv4 VRRP group can be on any interface.
# Bind VSRP instance aaa to IPv4 VRRP group 2 on GigabitEthernet 1/0/1.
[Sysname-vsrp-instance-aaa] bind vrrp vrid 2 interface gigabitethernet 1/0/1
display vsrp instance
Use display vsrp instance to display VSRP instance information.
display vsrp instance [ instance-name ]
instance-name: Specifies a VSRP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSRP instance, this command displays information about all VSRP instances.
# Display information about VSRP instance aaa.
<Sysname> display vsrp instance aaa
VSRP instance name: aaa
Backup ID: 10
Bound VRID: VRRP VRID 1 interface GigabitEthernet1/0/1
Instance status: Master
Local status: Master
Peer status: Backup
Backup mode: Warm
Traffic backup interval: 10(minutes)
Traffic backup threshold: 50(MB)
NAS IP: 10.0.0.1
NAS port: GigabitEthernet1/0/2
NAS ID: h3c
# Display information about all VSRP instances.
Backup ID: 10
Instance status : Master
Peer status: Backup
Backup mode: Warm
NAS IP: 10.0.0.1
NAS ID: h3c
VSRP instance name: bbb
Backup ID: 10
Bound VRID: VRRP VRID 2 interface GigabitEthernet1/0/3
Peer status: Backup
Backup mode: Warm
Traffic backup interval: 5(minutes)
Traffic backup threshold: 100(MB)
NAS IP: 10.0.0.2
NAS port: GigabitEthernet1/0/4
NAS ID: h3c
VSRP peer name |
Name of a VSRP group associated with the VSRP instance. |
Bound VRID |
Number of the VRRP group bound to the VSRP instance. |
Instance status |
VSRP instance state: · Master—The device acts as the master in the VSRP instance. · Backup—The device acts as the backup in the VSRP instance. · Down—The device is not running in the VSRP instance. |
Local status |
Local device state: · Master—The local device is acting as the master. · Backup—The local device is acting as the backup. · Init—The local device is in initialized state. · Down—The state of the local device is unknown. |
Peer status |
Peer state: · Master—The peer is acting as the master. · Backup—The peer is acting as the backup. · Init—The peer is in initialized state. · Down—The state of the peer is unknown. |
Backup mode |
VSRP instance backup mode: Hot or Warm. |
Traffic backup threshold |
Traffic threshold that triggers a traffic backup. |
NAS IP |
Logical NAS IP address. |
NAS port |
Logical NAS port. |
NAS ID |
Logical host name. |
nas
Use nas to configure NAS parameters.
Use undo nas to remove the NAS parameters.
nas { id host-name | ip ip-address | port interface-type interface-number }
undo nas [ id | ip | port ]
No NAS parameters are configured.
VSRP instance view
id host-name: Specifies a logical host name, a case-insensitive string of 1 to 127 characters.
ip ip-address: Specifies a logical unicast IP address. The IP address cannot be all zeros or a loopback address.
port interface-type interface-number: Specifies a logical interface by its type and number. It can be a Layer 3 Ethernet interface or a Layer 3 aggregate interface. The logical interface can be an interface that does not belong to the device. Make sure the logical interface number contains three segments in interface-type A/B/C format.
This command specifies NAS parameters for outgoing packets. This command enables devices in a VSRP group to share parameters when the devices have the following settings:
· The same NAS-IP-address, NAS-Port, and host name in packets sent to the RADIUS server.
· The same Option 82 in packets sent to the DHCP server.
In this way, the VSRP group is not required to be authenticated again after a master and backup switchover.
# Specify the logical IP address as 2.2.2.2.
[Sysname-vsrp-instance-aaa] nas ip 2.2.2.2
# Specify the logical interface as GigabitEthernet 1/0/1.
[Sysname-vsrp-instance-aaa] nas port gigabitethernet 1/0/1
# Specify the logical host name as bbb.
[Sysname-vsrp-instance-aaa] nas id bbb
traffic backup
Use traffic backup to set a traffic backup interval or a traffic threshold that triggers a traffic backup.
Use undo traffic backup to remove the specified traffic backup interval or traffic threshold settings.
traffic backup { interval interval-value | threshold threshold-value } *
undo traffic backup [ interval | threshold ]
A VSRP instance backs up traffic at an interval of 10 minutes or when the traffic reaches 50 MB.
VSRP instance view
interval interval-value: Specifies a traffic backup interval in the range of 0 to 1440 minutes.
threshold threshold-value: Specifies a traffic threshold that triggers a traffic backup. The value range for the threshold-value argument is 0 to 100000 MB.
A VSRP instance backs up service data at the specified interval or when the specified traffic threshold is reached.
If traffic is not required to be backed up, set both the interval-value argument and the threshold-value argument to 0.
# Configure VSRP instance aaa to back up traffic every 50 minutes.
[Sysname-vsrp-instance-aaa] traffic backup interval 50
# Configure VSRP instance aaa to back up traffic when the traffic reaches 200 MB.
[Sysname-vsrp-instance-aaa] traffic backup threshold 200
# Set the traffic backup interval and the traffic threshold to the default value for VSRP instance aaa.
[Sysname-vsrp-instance-aaa] undo traffic backup
vsrp instance (system view)
Use vsrp instance to create a VSRP instance and enter its view, or enter the view of an existing VSRP instance.
Use undo vsrp instance to remove a VSRP instance.
vsrp instance instance-name
undo vsrp instance instance-name
No VSRP instances exist.
A VSRP instance is associated with a service module. To enable a VSRP instance to function, you must configure the following items for the VSRP instance:
· A VSRP group.
· A bound VRRP group.
· The backup mode.
· The traffic backup interval or traffic threshold.
The device supports a maximum of 1024 VSRP instances.
# Create a VSRP instance named aaa, and enter VSRP instance view.
IPv6 virtual address commands
ipv6 virtual-address
Use ipv6 virtual-address to specify a virtual IPv6 address for an interface that is associated with a VSRP instance.
Use undo ipv6 virtual-address to restore the default.
ipv6 virtual-address ipv6-address vsrp vsrp-instance
No virtual IPv6 address is configured.
Layer 3 Ethernet interface/subinterface view
Layer 3 aggregate interface/subinterface view
Layer 3 RPR logical interface view
VLAN interface view
ipv6-address: Specifies a virtual IPv6 address. The virtual IPv6 address must be a link local address that can be used as the gateway address by hosts in a LAN.
vsrp vsrp-instance: Specifies a VSRP instance by its name, a case-sensitive string of 1 to 31 characters.
Use this command when you enable VSRP for IPv6 IPoE or DHCPv6 services on an interface. For VSRP to operate correctly, specify the same VSRP instance in this command and in the ipv6 subscriber vsrp-instance or the ipv6 dhcp vsrp-instance command. If different VSRP instances are specified, the hosts in the LAN cannot access the Internet after a master and backup switchover.
For the original link local address of the device to take effect, do not use this command when VSRP is disabled for IPv6 IPoE or DHCPv6 on the interface.
To enable VSRP to operate correctly, do not use this command on the same interface where a VRRP group is configured.
# Specify virtual IPv6 address fe80::10 for GigabitEthernet 1/0/1 that is associated with VSRP instance aaa.
[Sysname-GigabitEthernet1/0/1] ipv6 virtual-address fe80::10 vsrp aaa
IPoE VSRP commands
ip subscriber vsrp-instance
Use ip subscriber vsrp-instance to associate an IPv4 IPoE-enabled interface with a VSRP instance.
Use undo ip subscriber vsrp-instance to restore the default.
ip subscriber vsrp-instance instance-name
An IPv4 IPoE-enabled interface is not associated with a VSRP instance.
After you execute this command, the associated VSRP instance backs up dynamic IPv4 IPoE sessions in real time through the data channel between the master and the backup.
When the master fails and a switchover occurs, the new master takes over the IPv4 IPoE service. The new master has the authorization and accounting information for the users. The original online dynamic IPv4 IPoE users can remain online.
# Associate IPv4 IPoE-enabled interface GigabitEthernet 1/0/1 with VSRP instance instance1.
[Sysname-GigabitEthernet1/0/1] ip subscriber vsrp-instance instance1
ip subscriber vsrp-port
Use ip subscriber vsrp-port to specify a TCP port number for VSRP to establish data channels for IPoE services.
Use undo ip subscriber vsrp-port to restore the default.
ip subscriber vsrp-port port-number
TCP port number 60033 is used to establish the data channels for IPoE sessions backup.
port-number: Specifies a TCP number in the range of 1 to 65535. The TCP port cannot be used by other services or be a well-known port.
To back up the dynamic IPoE sessions on an interface, the master must establish a TCP data channel with the backup. You can use this command to change the TCP port number for establishing the data channel.
# Specify TCP port 20000 for VSRP to establish data channels for IPoE services.
[Sysname] ip subscriber vsrp-port 20000
Use ipv6 subscriber vsrp-instance to associate an IPv6 IPoE-enabled interface with a VSRP instance.
Use undo ipv6 subscriber vsrp-instance to restore the default.
ipv6 subscriber vsrp-instance instance-name
An IPv6 IPoE-enabled interface is not associated with a VSRP instance.
After you execute this command, the associated VSRP instance backs up dynamic IPv6 IPoE sessions in real time through the data channel between the master and the backup.
When the master fails and a switchover occurs, the new master takes over the IPv6 IPoE service. The new master has the authorization and accounting information for the users. The original online IPv6 IPoE users can remain online.
# Associate IPv6 IPoE-enabled interface GigabitEthernet 1/0/1 with VSRP instance instance1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber vsrp-instance instance1
ipv6 subscriber vsrp-port
Use ipv6 subscriber vsrp-port to specify a TCP port number for establishing the data channel through which dynamic IPv6 IPoE sessions are backed up.
Use undo ipv6 subscriber vsrp-port to restore the default.
ipv6 subscriber vsrp-port port-number
The TCP port number 60040 is used for establishing the data channel through which dynamic IPv6 IPoE sessions are backed up.
To back up dynamic IPv6 IPoE sessions, the master must establish a TCP data channel with the backup. You can use this command to change the TCP port number for establishing the data channel.
# Specify the TCP port number 20000 for the data channel through which dynamic IPv6 IPoE sessions are backed up.
[Sysname] ipv6 subscriber vsrp-port 20000
PPPoE VSRP commands
display ppp sync-session
Use display ppp sync-session to display PPP sessions synchronized by VSRP instances.
display ppp sync-session [ vsrp-instance vsrp-instance-name ]
vsrp-instance vsrp-instance-name: Specifies a VSRP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays PPP sessions synchronized by all VSRP instances on the device.
When you specify a VSRP instance, this command displays the following PPP sessions:
· On the master—PPP sessions synchronized to the backup.
· On the backup—PPP sessions synchronized from the master.
# Display PPP sessions synchronized by all VSRP instances on the device.
<Sysname> display ppp sync-session
VSRP instance: vsrp1
VSRP instance state: Master
Total synchronized PPP sessions: 2
SID MAC address Interface IP address Username
1 00e0-1500-0410 GE1/0/1 2.2.2.2 user1@isp1
2 00e0-1500-0411 GE1/0/1 2.2.2.3 user1@isp1
VSRP instance: vsrp2
VSRP instance state: Backup
Total synchronized PPP sessions: 1
1 00e0-1500-0413 GE1/0/2 2.3.2.2 user1@isp1
VSRP instance: vsrp3
VSRP instance state: Down
Total synchronized PPP sessions: 0
VSRP instance |
VSRP instance name. |
VSRP instance state |
VSRP instance state: · Master—The device acts as the master in the VSRP instance. The command displays PPP sessions synchronized to the backup. · Backup—The device acts as the backup in the VSRP instance. The command displays PPP sessions synchronized from the master. · Down—The device is not running. The device has no PPP sessions synchronized by the VSRP instance. This field displays Down in either of the following situations: ¡ The associated VRRP group is in Initialize state. ¡ The VSRP instance does not exist or is not correctly configured on the device. |
SID |
PPP session ID. |
Use display pppoe-server sync-session to display PPPoE sessions synchronized by VSRP instances.
display pppoe-server sync-session [ vsrp-instance vsrp-instance-name ]
vsrp-instance vsrp-instance-name: Specifies a VSRP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays PPPoE sessions synchronized by all VSRP instances on the device.
When you specify a VSRP instance, this command displays the following PPPoE sessions:
· PPPoE sessions synchronized to the backup (on the master).
· PPPoE sessions synchronized from the master (on the backup).
# Display PPPoE sessions synchronized by all VSRP instances on the device.
<Sysname> display pppoe-server sync-session
Total synchronized PPPoE sessions: 2
SID Service VLAN Customer VLAN MAC address Interface
1 1 1 00e0-1500-0410 GE1/0/1
2 1 1 00e0-1500-0411 GE1/0/1
Total synchronized PPPoE sessions: 1
1 1 2 00e0-1500-0413 GE1/0/2
Total synchronized PPPoE sessions: 0
VSRP instance |
VSRP instance state: · Master—The device acts as the master in the VSRP instance. The command displays PPPoE sessions synchronized to the backup. · Backup—The device acts as the backup in the VSRP instance. The command displays PPPoE sessions synchronized from the master. · Down—The device is not running. The device has no PPPoE sessions synchronized by the VSRP instance. This field displays Down in either of the following situations: ¡ The associated VRRP group is in Initialize state. ¡ The VSRP instance does not exist or is not correctly configured on the device. |
SID |
PPPoE session ID. |
Service VLAN |
Service provider network VLAN. |
Customer VLAN |
Customer network VLAN. |
ppp vsrp-port
Use ppp vsrp-port to specify a TCP port number for VSRP to establish data channels for PPPoE services.
Use undo ppp vsrp-port to restore the default.
ppp vsrp-port port-number
undo ppp vsrp-port
TCP port 60035 is used to establish the data channels for PPP and PPPoE session backup.
port-number: Specifies a TCP port number in the range of 1 to 65535. The TCP port cannot be used by other services or be a well-known port.
To back up PPP or PPPoE sessions on an interface, the master must establish a TCP data channel with the backup. You can use this command to change the TCP port number for establishing the data channel.
You must specify the same port number on the master and the backup in a VSRP instance. Otherwise, the data channel cannot be established.
# Specify the TCP port number 20000 for VSRP to establish data channels for PPPoE services.
[Sysname] ppp vsrp-port 20000
pppoe-server vsrp-instance
Use pppoe-server vsrp-instance to associate a PPPoE server-enabled interface with a VSRP instance.
Use undo pppoe-server vsrp-instance to remove the association.
pppoe-server vsrp-instance vsrp-instance-name
A PPPoE server-enabled interface is not associated with a VSRP instance.
EFM interface/subinterface view
You must remove all online PPPoE clients on the interface before you execute this command.
After you execute this command, the associated VSRP instance backs up PPPoE and PPP sessions in real time through the data channel between the master and the backup.
You can specify a nonexistent VSRP instance in this command, but this command takes effect only when the specified VSRP instance exists.
An interface can be associated with only one VSRP instance.
You cannot associate different interfaces on a device with the same VSRP instance. However, you can associate subinterfaces of an interface with the same VSRP instance.
To associate an interface with a VSRP instance that has been associated with another interface, remove the original association of the VSRP instance first.
# Associate PPPoE server-enabled interface GigabitEthernet 1/0/1 with VSRP instance vsrp1.
[Sysname-GigabitEthernet1/0/1] pppoe-server vsrp-instance vsrp1
pppoe-server vsrp-port
Use pppoe-server vsrp-port to specify a TCP port number for establishing the data channel through which PPPoE sessions are backed up.
Use undo pppoe-server vsrp-port to restore the default.
pppoe-server vsrp-port port-number
The TCP port number 60034 is used for establishing the data channel through which PPPoE sessions are backed up.
To back up PPPoE sessions, the master must establish a TCP data channel with the backup. You can use this command to change the TCP port number for establishing the data channel.
For the data channel to be successfully established, you must specify the same port number on the master and the backup in a VSRP instance.
# Specify the TCP port number 30000 for establishing the data channel through which PPPoE sessions are backed up.
[Sysname] pppoe-server vsrp-port 30000
L2TP VSRP commands
display l2tp session vsrp
Use display l2tp session vsrp to display L2TP sessions backed up by VSRP instances.
display l2tp session vsrp [ vsrp-instance-name ]
vsrp-instance-name: Specifies a VSRP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSRP instance, this command displays L2TP sessions backed up by all VSRP instances on the device.
# Display information about the L2TP sessions backed up by VSRP instance abc.
<Sysname> display l2tp session vsrp abc
Local session ID: 1
Remote session ID: 1
Local tunnel ID: 1
State: Established
User ID: 00e0fc112233000300000004
Interface: Virtual-Access0
Table 5 Command output
VSRP instance name |
Name of the VSRP instance that backs up the L2TP session. |
State |
Session state: · Idle. · Wait-tunnel—Waits for the tunnel to be established. · Wait-reply—Waits for an Incoming-Call-Reply (ICRP) message indicating the call is accepted. · Established. |
VA interface on the LAC. |
display l2tp tunnel vsrp
Use display l2tp tunnel vsrp to display information about the L2TP tunnels backed up by VSRP instances.
display l2tp tunnel vsrp [ vsrp-instance-name ]
vsrp-instance-name: Specifies a VSRP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSRP instance, this command displays L2TP tunnel information backed up by all VSRP instances.
# Display information about the L2TP tunnels backed up by VSRP instance abc.
<Sysname> display l2tp tunnel vsrp abc
VSRP instance name: abc
Local tunnel ID: 1
Remote tunnel ID: 1
State: Established
Sessions: 1
Remote address: 20.1.1.2
Remote port: 1701
Remote name: lns
Local address: 2.2.2.2
Sequence number sent (Ns): 2
Sequence number expected (Nr): 3
Table 6 Command output
Name of the VSRP instance that backs up the L2TP tunnel. |
State |
Tunnel state: · Idle. · Wait-reply—Waits for a Start-Control-Connection-Reply (SCCRP) message. · Established. · Stopping—The tunnel is being disconnected. |
Sessions |
Number of sessions within the tunnel. |
Remote address |
IP address of the peer. |
Remote port |
UDP port number of the peer. |
Remote name |
Name of the tunnel peer. |
Local address |
IP address of the local device. |
Sequence number sent (Ns) |
Sequence number for the control message sent. |
Sequence number expected (Nr) |
Sequence number expected in the next control message to be received. |
reset l2tp tunnel (Layer 2—WAN Access Command Reference)
display l2tp vsrp
Use display l2tp vsrp to display information about the VSRP instance that backs up L2TP services.
display l2tp vsrp [ vsrp-instance-name ]
vsrp-instance-name: Specifies a VSRP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSRP instance, this command displays information about all VSRP instances that back up L2TP services.
# Display information about VSRP instance abc, which backs up L2TP services.
<Sysname> display l2tp vsrp abc
VSRP mode: Hot
VSRP status: Switched
Local VSRP state: Master/Up
Remote VSRP state: Backup
VSRP channel state: Synced
Sent messages: 13005
Received messages: 23
Discarded sent messages: 22
Discarded received messages: 13
Sent tunnel add messages: 8000
Received tunnel add messages: 0
Sent tunnel delete messages: 5500
Received tunnel delete messages: 0
Sent session add messages: 20000
Received session add messages: 0
Sent session delete messages: 10000
Received session delete messages: 0
Current tunnels: 2500
Current sessions: 10000
Added tunnels: 8000
Deleted tunnels: 5500
Added sessions: 20000
Deleted sessions: 10000
Table 7 Command output
VSRP mode |
VSRP backup mode: · Hot. · Warm. |
VSRP status |
State of the master and backup switchover: · Switching. · Switched. |
Local VSRP state |
VSRP group state on the local device: · Master/Up—The device is acting as the master and the VSRP group is operating correctly. · Backup/Up—The device is acting as the backup and the VSRP group is operating correctly. · Master/Down—The device is acting as the master and the VSRP group is operating incorrectly. · Backup/Down—The device is acting as the backup and the VSRP group is operating incorrectly. |
Remote VSRP state |
VSRP group state on the peer: · Master—The peer is acting as the master. · Backup—The peer is acting as the backup. |
VSRP channel state |
The data channel state: · Disconnected. · Syncing—Data is being synchronized. · Synced—Data has been synchronized. |
Sent messages |
Number of backup messages sent by the device. |
Received messages |
Number of backup messages received by the device. |
Discarded sent messages |
Number of outgoing messages discarded by the device. |
Discarded received messages |
Number of incoming messages discarded by the device. |
Sent tunnel add messages |
Number of tunnel adding messages sent by the device. |
Received tunnel add messages |
Number of tunnel adding messages received by the device. |
Sent tunnel delete messages |
Number of tunnel deleting messages sent by the device. |
Received tunnel delete messages |
Number of tunnel deleting messages received by the device. |
Sent session add messages |
Number of session adding messages sent by the device. |
Received session add messages |
Number of session adding messages received by the device. |
Sent session delete messages |
Number of session deleting messages sent by the device. |
Received session delete messages |
Number of session deleting messages received by the device. |
Current tunnels |
Number of tunnels in the VSRP instance. |
Current sessions |
Number of L2TP sessions in the VSRP instance. |
Added tunnels |
Number of L2TP tunnels established in a VSRP instance. |
Deleted tunnels |
Number of L2TP tunnels deleted in a VSRP instance. |
Added sessions |
Number of L2TP sessions established in a VSRP instance. |
Deleted sessions |
Number of L2TP sessions deleted in a VSRP instance. |
l2tp tunnel-id
Use l2tp tunnel-id to specify an L2TP tunnel ID range.
Use undo l2tp tunnel-id to restore the default.
l2tp tunnel-id low-id high-id
undo l2tp tunnel-id
The L2TP tunnel ID is in the range of 1 to 65535.
low-id: Specifies the lower limit of the L2TP tunnel ID. The value range is 1 to 65535.
high-id: Specifies the upper limit of the L2TP tunnel ID. The value range is 1 to 65535. The upper limit must be greater than or equal to the lower limit.
To avoid tunnel ID conflicts after a master/backup switchover, you must specify different L2TP tunnel ID ranges on the peer LACs in the following scenario:
You cannot change the L2TP tunnel ID range for an LAC when it has an L2TP tunnel.
# Specify a L2TP tunnel ID range from 20 to 100 on the LAC.
[Sysname] l2tp tunnel-id 20 100
l2tp vsrp-port
Use l2tp vsrp-port to specify a TCP port number for VSRP to establish data channels for L2TP services.
Use undo l2tp vsrp-port to restore the default.
l2tp vsrp-port port-number
undo l2tp vsrp-port
TCP port 60036 is used to establish the data channels for L2TP service backup.
To back up a L2TP service, the master must establish a TCP data channel with the backup. You can use this command to change the TCP port number for establishing the data channel.
You must specify the same TCP port number on the master and the backup in a VSRP instance. Otherwise, the data channel cannot be established.
# Specify TCP port 20000 for VSRP to establish data channels for L2TP service backup.
[Sysname] l2tp vsrp-port 20000
tunnel vsrp source-ip
Use tunnel vsrp source-ip to specify a source address for an L2TP tunnel when VSRP is enabled for L2TP. This address is used as the source IP address of tunneled packets.
Use undo tunnel vsrp source-ip to restore the default.
tunnel vsrp source-ip ip-address
The L2TP tunnel source address is the IP address of the tunnel interface.
L2TP group view
ip-address: Specifies a source address for the L2TP tunnel when VSRP is enabled for L2TP. The tunnel source address can only be the loopback interface address with a 32-bit mask or an IP address that does not exist on the network.
You must use this command to specify the same L2TP tunnel source address on the master and backup LACs. The master LAC automatically generates a static route to the source address with the loopback interface as the output interface.
After a master and backup switchover, the original master deletes the static route and uses a dynamic routing protocol to advertise the route deletion. Meanwhile, the new master generates a static route to the tunnel source address and uses a dynamic routing protocol to advertise the route. In this way, the traffic from the LNS can be automatically switched to the new master LAC. The LNS considers that the original L2TP tunnel remains established.
When you specify the source address for an L2TP tunnel, follow these restrictions and guidelines:
· As a best practice, specify different L2TP tunnel source addresses for L2TP tunnels in different L2TP groups.
· To specify an L2TP tunnel source address, you must first associate the L2TP group with a VSRP instance.
· You cannot change or remove the specified tunnel source address for the existing L2TP tunnel in an L2TP group.
· When you enable VSRP for L2TP services, the tunnel source address specified by the tunnel vsrp source-ip command rather than that specified by the source-ip command takes effect. If you configure the source-ip command but not the tunnel vsrp source-ip command, VSRP for L2TP cannot operate correctly.
# Specify the source address for the L2TP tunnel in L2TP group 1 as 2.2.2.2.
[Sysname] l2tp-group 1 mode lac
[Sysname-l2tp1] tunnel vsrp source-ip 2.2.2.2
source-ip (Layer 2—WAN Access Command Reference)
Use vsrp-instance to associate an L2TP group with a VSRP instance.
Use undo vsrp-instance to remove the VSRP instance association.
undo vsrp-instance
An L2TP group is not associated with a VSRP instance.
L2TP group view
To back up L2TP services, you must associate an L2TP group with a VSRP instance. Then, the master LAC backs up information about the L2TP group to the backup LAC in real time over the VSRP data channel. In some situations, such as a device reboot, the backup LAC also requests L2TP group information from the master LAC over the VSRP data channel.
You must associate the peer L2TP groups on the master and backup LACs with the same VSRP instance.
Using this command removes the existing L2TP tunnel in the L2TP group.
You cannot change or remove the association between an L2TP group and a VSRP instance when an L2TP tunnel exists in the L2TP group.
# Associate L2TP group 1 in LAC mode with VSRP instance abc.
[Sysname-l2tp1] vsrp-instance abc
Portal VSRP commands
portal vsrp-instance
Use portal vsrp-instance to associate a portal-enabled interface with a VSRP instance.
Use undo portal vsrp-instance to restore the default.
portal vsrp-instance vsrp-instance-name
A portal-enabled interface is not associated with a VSRP instance.
Interface view
The master backs up portal services to the backup so that the backup can take over the portal services when the master or its link fails. This backup ensures that the online portal users remain online without re-authentication after a master/backup switchover, because the new master has obtained their accounting and authorization information.
You must associate the peer interfaces on the master and backup access devices with the same VSRP instance.
VSRP backup for a portal-enabled interface takes effect on all IPv4 and IPv6 portal users that use direct authentication on the interface.
If you configure VLAN termination on the subinterfaces on the master and backup access devices, make sure the peer subinterfaces terminate the same VLAN IDs.
You cannot associate different interfaces on a device with the same VSRP instance. However, you can associate subinterfaces of an interface with the same VSRP instance or different VSRP instances.
Any change to the VSRP instance that is associated with a portal-enabled interface can make portal users on the interface go offline.
# Associate portal-enabled interface GigabitEthernet 1/0/1 with VSRP instance aaa.
[Sysname-GigabitEthernet1/0/1] portal vsrp-instance aaa
display portal interface
portal vsrp-port
portal vsrp-port
Use portal vsrp-port to specify a TCP port number for VSRP to establish data channels for portal service backup.
Use undo portal vsrp-port to restore the default.
portal vsrp-port port-number
TCP port 60038 is used to establish data channels for portal service backup.
To back up a portal service, the master must establish a TCP data channel with the backup. You can use this command to change the TCP port number for establishing the data channel.
# Specify TCP port 20000 for VSRP to establish data channels for portal service backup.
[Sysname] portal vsrp-port 20000
DHCP VSRP commands
dhcp vsrp port
Use dhcp vsrp port to specify a TCP port number for VSRP to establish data channels for DHCPv4 server or relay agent service backup.
Use undo dhcp vsrp port to restore the default.
dhcp vsrp port port-number
undo dhcp vsrp port
TCP port 60037 is used to establish data channels for DHCPv4 server or relay agent service backup.
To back up data for a DHCPv4 address pool, the master DHCPv4 server must establish a TCP data channel with the backup DHCPv4 server.
To back up DHCPv4 relay agent data for a client-side interface, the master DHCPv4 relay agent must establish a TCP data channel with the backup DHCPv4 relay agent.
# Specify TCP port 30000 for VSRP to establish data channels for DHCPv4 server or relay agent service backup.
[Sysname] dhcp vsrp port 30000
dhcp vsrp-instance
Use dhcp vsrp-instance to associate a client-side interface on the DHCPv4 server with a VSRP instance.
Use undo dhcp vsrp-instance to remove the VSRP instance association.
dhcp vsrp-instance vsrp-instance-name
The client-side interfaces on the DHCPv4 server are not associated with VSRP instances.
You can specify a nonexistent VSRP instance for this command, but this command takes effect only after the VSRP instance is created.
Use this command on the master and backup DHCPv4 servers to match their interfaces that connect to the same client.
You can associate an interface or subinterface with only one VSRP instance.
You can associate a VSRP instance with one interface or multiple subinterfaces on the same interface.
If a VSRP instance has been associated with one interface, you must remove the VSRP instance from that interface before you can specify it on another interface.
# Associate GigabitEthernet 1/0/1 with VSRP instance vsrp1.
[Sysname-GigabitEthernet1/0/1] dhcp vsrp-instance vsrp1
ipv6 dhcp vsrp port
Use ipv6 dhcp vsrp port to specify a TCP port number for VSRP to establish data channels for DHCPv6 server or relay agent service backup.
Use undo ipv6 dhcp vsrp port to restore the default.
ipv6 dhcp vsrp port port-number
TCP port 60039 is used to establish data channels for DHCPv6 server or relay agent service backup.
To back up data for a DHCPv6 address pool, the master DHCPv6 server must establish a TCP data channel with the backup DHCPv6 server.
To back up DHCPv6 relay agent data for a client-side interface, the master DHCPv6 relay agent must establish a TCP data channel with the backup DHCPv6 relay agent.
# Specify TCP port 30000 for VSRP to establish data channels for DHCPv6 server or relay agent service backup.
[Sysname] ipv6 dhcp vsrp port 30000
Use ipv6 dhcp vsrp-instance to associate a client-side interface on the DHCPv6 server with a VSRP instance.
Use undo ipv6 dhcp vsrp-instance to remove the VSRP instance association.
ipv6 dhcp vsrp-instance vsrp-instance-name
The client-side interfaces on the DHCPv6 server are not associated with VSRP instances.
Use this command on the master and backup DHCPv6 servers to match their interfaces that connect to the same client.
[Sysname-GigabitEthernet1/0/1] ipv6 dhcp vsrp-instance vsrp1
virtual-duid
Use virtual-duid to generate a virtual DUID for a DHCPv6 server.
Use undo virtual-duid to restore the default.
virtual-duid { enterprise-number enterprise-number identifier identifier | hardware-type hardware-type address address }
undo virtual-duid
No virtual DUID is generated for a DHCPv6 server.
enterprise-number enterprise-number: Specifies a registered private enterprise number. The value range for the enterprise-number argument is 0 to 4294967295.
identifier identifier: Specifies a device identifier in hexadecimal format. The number of hexadecimal digits must be an even number between 2 and 128.
hardware-type hardware-type: Specifies the hardware type, a number in the range of 0 to 65535.
address address: Specifies a link layer address in hexadecimal format. The number of hexadecimal digits must be an even number between 2 to 128.
By default, the master and backup DHCPv6 servers use their respective DUIDs for DHCP communication. For DHCPv6 clients to correctly renew leases or release IPv6 addresses after a switchover, use this command to generate the same virtual DUID for the master and the backup.
# Configure DHCPv6 address pool pool1 to use the virtual DUID generated based on enterprise number 1 and identifier 1234.
[Sysname] ipv6 dhcp pool pool1
[Sysname-dhcp6-pool-pool1] virtual-duid enterprise-number 1 identifier 1234
Use vsrp-instance to associate a DHCPv4 or DHCPv6 address pool with a VSRP instance.
undo vsrp-instance
A DHCPv4 or DHCPv6 address pool is not associated with a VSRP instance.
DHCPv4 or DHCPv6 address pool view
When you execute this command, the master and backup DHCPv4 or DHCPv6 servers establish a data channel to back up address pool data.
You can specify a nonexistent VSRP instance, but this command takes effect only when the specified VSRP instance exists.
# Associate DHCPv4 address pool p1 with VSRP instance vsrp1.
[Sysname] dhcp server ip-pool p1
[Sysname-dhcp-pool-p1] vsrp-instance vsrp1
# Associate DHCPv6 address pool p1 with VSRP instance vsrp1.
[Sysname] ipv6 dhcp pool p1
[Sysname-dhcp6-pool-p1] vsrp-instance vsrp1
