14-High Availability Command References
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers Command References-R6749-6W10014-High Availability Command References
02-CFD commands
02-CFD commands 257.24 KB
CFD commands
cfd ais enable
Use cfd ais enable to enable AIS.
Use undo cfd ais enable to disable AIS.
cfd ais enable
undo cfd ais enable
AIS is disabled.
# Enable AIS.
[Sysname] cfd ais enable
cfd ais level
cfd ais period
cfd ais level
Use cfd ais level to configure the AIS frame transmission level.
Use undo cfd ais level to remove the AIS frame transmission level.
cfd ais level level-value service-instance instance-id
undo cfd ais level level-value service-instance instance-id
The AIS frame transmission level is not configured.
level level-value: Specifies the AIS frame transmission level in the range of 1 to 7.
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767.
If no AIS frame transmission level is configured for a service instance, the MEPs in the service instance cannot send AIS frames.
# Configure the AIS frame transmission level as 3 in service instance 1.
[Sysname] cfd ais level 3 service-instance 1
cfd ais enable
cfd ais period
cfd ais period
Use cfd ais period to configure the AIS frame transmission period.
Use undo cfd ais period to remove the AIS frame transmission period.
cfd ais period period-value service-instance instance-id
undo cfd ais period period-value service-instance instance-id
The AIS frame transmission period is 1 second.
period period-value: Specifies the AIS frame transmission period in the range of 1 to 60 seconds.
# Configure the AIS frame transmission period as 60 seconds in service instance 1.
[Sysname] cfd ais period 60 service-instance 1
cfd ais enable
cfd ais level
cfd cc enable
Use cfd cc enable to enable CCM sending on a specified MEP.
Use undo cfd cc enable to disable CCM sending on a specified MEP.
cfd cc service-instance instance-id mep mep-id enable
undo cfd cc service-instance instance-id mep mep-id enable
The CCM sending feature is disabled.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191.
# On GigabitEthernet 1/0/1, enable CCM sending on MEP 3 in service instance 5.
[Sysname-GigabitEthernet1/0/1] cfd cc service-instance 5 mep 3 enable
# On GigabitEthernet 1/0/1.1, enable CCM sending on MEP 3 in service instance 5.
[Sysname] interface gigabitethernet 1/0/1.1
[Sysname-GigabitEthernet1/0/1.1] cfd cc service-instance 5 mep 3 enable
cfd cc interval
cfd cc interval
Use cfd cc interval to set the value of the interval field in the CCM messages.
Use undo cfd cc interval to remove the value of the interval field in the CCM messages.
cfd cc interval interval-value service-instance instance-id
undo cfd cc interval [ interval-value ] service-instance instance-id
The value of this field is 4 for all CCM messages sent.
interval interval-value: Specifies the value of the interval field in CCM messages. The value range for the interval field is 1 to 7. Values 1 and 2 are not supported in the current software version.
When setting the CCM interval, use the settings described in Table 1.
Table 1 CCM interval field encoding
CCM interval field
Transmission interval
Maximum CCM lifetime
1
10/3 milliseconds
35/3 milliseconds
2
10 milliseconds
35 milliseconds
3
100 milliseconds
350 milliseconds
4
1 second
3.5 seconds
5
10 seconds
35 seconds
6
60 seconds
210 seconds
7
600 seconds
2100 seconds
# Set the value of the interval field to 3 in CCM messages sent by MEPs in service instance 2.
[Sysname] cfd cc interval 3 service-instance 2
cfd cc enable
cfd dm one-way
Use cfd dm one-way to enable one-way delay measurement (DM).
cfd dm one-way service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ number number ]
mep mep-id: Specifies the source MEP by its ID in the range of 1 to 8191.
target-mac mac-address: Specifies the target MEP by its bridge MAC address in the format of H-H-H.
target-mep target-mep-id: Specifies the target MEP by its ID in the range of 1 to 8191.
number number: Specifies the number of 1DM frames sent. The value range for the number argument is 2 to 10, and the default is 5.
The one-way DM function measures the one-way frame delay between the source and target MEPs by using 1DM frames.
To view the bridge MAC address of a target MEP, use the display lacp system-id command on the target MEP.
To view the one-way delay test result, use the display cfd dm one-way history command on the target MEP.
# Enable the one-way DM function to test the one-way frame delay from source MEP 1101 to target MEP 1003 in service instance 1.
<Sysname> cfd dm one-way service-instance 1 mep 1101 target-mep 1003
5 1DMs have been sent. Please check the result on the remote device.
reset cfd dm one-way history
cfd dm two-way
Use cfd dm two-way to configure short-period two-way DM.
cfd dm two-way service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ dot1p dot1p-value ] [ number number ] [ interval interval ]
dot1p dot1p-value: Specifies an 802.1p priority for DMM frames. The value range for the dot1p-value argument is 0 to 7. The default value is 7.
number number: Specifies the number of DMM frames to be sent. The value range for the number argument is 2 to 10, and the default is 5.
interval interval: Specifies the DMM frame sending interval, in seconds. The value takes 1 or 10. The default value is 1.
Short-period two-way DM sends a configurable number of DMM frames at a configuration interval. It measures the two-way frame delay between the source and target MEPs after receiving DMR frames.
Short-period and continual two-way DM cannot be configured at the same time for one source MEP. If you have configured continual two-way DM, you can configure short-period two-way DM only after you disable continual two-way DM. If you have configured short-period two-way DM, you can configure continual two-way DM only after the short-period two-way DM ends.
# Configure short-period DM to test the two-way frame delay between source MEP 1101 and target MEP 2001 in service instance 1.
<Sysname> cfd dm two-way service-instance 1 mep 1101 target-mep 2001
Frame delay:
Reply from 0010-fc00-6512: 10us
Reply from 0010-fc00-6512: 9us
Reply from 0010-fc00-6512: 11us
Reply from 0010-fc00-6512: 5us
Average: 8us
Frame delay variation: 1us 2us 6us 0us
Average: 2us
Packet statistics:
Sent DMMs: 5        Received: 5        Lost: 0
Delay of the DMR frames returned from the MEP with MAC address 0010-FC00-6512.
Average
Average frame delay or average frame delay variation.
Sent DMMs
Number of sent DMM frames .
Received
Number of received DMR frames.
Lost
Number of lost DMM frames.
cfd dm two-way continual
Use cfd dm two-way continual to configure continual two-way DM.
Use undo cfd dm two-way continual to disable continual two-way DM.
cfd dm two-way continual service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ dot1p dot1p-value ] [ interval interval ]
undo cfd dm two-way continual service-instance instance-id mep mep-id
Continual two-way DM is not configured.
target-mac mac-address: Specifies the target MEP by its bridge MAC address in the format of H-H-H. The MAC address cannot be a MAC address of a local MEP or a non-unicast MAC address.
dot1p dot1p-value: Specifies the 802.1p priority of DMM frames to be sent. The value range for the dot1p-value argument is 0 to 7, and the default is 7. The larger the value, the higher the priority.
interval interval: Specifies the interval for sending DMM frames, in seconds. The value for the interval argument can be 1 or 10, and the default is 1.
Continual two-way DM continually sends DMM frames at a configurable interval. It measures the two-way frame delay between the source and target MEPs after receiving the returned DMR frames.
To modify continual two-way DM settings for a source MEP, disable continual two-way DM and then reconfigure the function for the source MEP.
Short-period two-way DM and continual two-way DM cannot be configured at the same time for one source MEP. If you have configured continual two-way DM, you can configure short-period two-way DM only after you disable continual two-way DM. If you have configured short-period two-way DM, you can configure continual two-way DM only after the short-period two-way DM ends.
To display the continual two-way DM result, use the display cfd dm two-way history command on the device where the source MEP resides.
# Configure continual two-way DM to test the two-way frame delay between source MEP 1101 and target MEP 2001 in service instance 1.
[Sysname] cfd dm two-way continual service-instance 1 mep 1101 target-mep 2001
cfd dm two-way
cfd dm two-way threshold
Use cfd dm two-way threshold to configure the lower limit and upper limit for continual two-way DM.
Use undo cfd dm two-way threshold to restore the default.
cfd dm two-way threshold service-instance instance-id mep mep-id { lower-limit lower-limit | upper-limit upper-limit } *
undo cfd dm two-way threshold service-instance instance-id mep mep-id [ lower-limit | upper-limit ]
The lower limit and upper limit for continual two-way DM are 0 and 4294967295 microseconds, respectively.
lower-limit lower-limit: Specifies the lower limit in the range of 0 to 4294967295 microseconds. The lower limit must be smaller than the upper limit.
upper-limit upper-limit: Specifies the upper limit in the range of 0 to 4294967295 microseconds.
This command takes effect only after you configure continual two-way DM.
If the cfd port-trigger dm action { block | shutdown } command is configured, the following rules apply:
·     If the delay time reaches or exceeds the upper limit for three consecutive times, the port is blocked or shut down.
·     If the delay time reaches or falls below the lower limit for three consecutive times, the port is unblocked or brought up.
# Configure the continual two-way DM lower limit and upper limit as 10000 and 5000000 microseconds, respectively, for source MEP 1101 in service instance 1.
[Sysname] cfd dm two-way threshold service-instance 1 mep 1101 lower-limit 10000 upper-limit 5000000
cfd port-trigger
cfd enable
Use cfd enable to enable CFD.
Use undo cfd enable to disable CFD.
cfd enable
undo cfd enable
CFD is disabled.
# Enable CFD.
[Sysname] cfd enable
cfd linktrace
Use cfd linktrace to identify the path between the source MEP and target MP.
cfd linktrace service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ ttl ttl-value ]
target-map target-mep-id: Specifies the destination MEP by its ID in the range of 1 to 8191.
ttl ttl-value: Specifies the TTL value in the range of 1 to 255. The default value is 64.
This command identifies the path between the source MEP and target MP by using LTMs and LTRs.
# Identify the path between source MEP 1101 and target MEP 2001 in service instance 1.
<Sysname> cfd linktrace service-instance 1 mep 1101 target-mep 2001
Linktrace to MEP 2001 with the sequence number 1101-43361:
MAC address               TTL     Last MAC         Relay action
0010-fc00-6512            63      0010-fc00-6500   Hit
Linktrace to target MEP 2001 with the sequence number 1101-43361.
MAC address
Source MAC address in the LTRs.
TTL
TTL of the LTM when it passes the device.
Last MAC
MAC address of the last-hop device the LTM passes.
Relay action
Indicates whether the forwarding device found the destination MAC address in its MAC address table.
When the standard version (IEEE 802.1ag) of CFD is used:
·     Hit—The current device is the destination device.
·     FDB—The forwarding device found the destination MAC address.
·     MPDB—The destination MAC address is not found, or the destination MAC address is found in the MEP database.
cfd linktrace auto-detection
display cfd linktrace-reply
Use cfd linktrace auto-detection to enable automatic sending of LTMs.
Use undo cfd linktrace auto-detection to disable automatic sending of LTMs.
cfd linktrace auto-detection [ size size-value ]
Automatic sending of LTMs is disabled.
size size-value: Specifies the size of the buffer used to store the auto-detection result, in the range of 1 to 100 (in terms of auto-detection times). The default value is 5, which means the buffer stores the results of the recent five auto-detections.
This command enables the source MEP to send LTMs when it fails to receive CCMs from the target MEP within 3.5 times the sending interval. The destination of the LTMs is the target MEP, and the TTL field value is 255. Based on the returned LTRs, the fault source can be located on the faulty link.
If you disable automatic LTM sending, the content stored in the buffer will be removed.
# Enable automatic LTM sending, and set the size of the buffer used to store the auto-detection result to 100 (in terms of auto-detection times).
[Sysname] cfd linktrace auto-detection size 100
cfd linktrace
display cfd linktrace-reply auto-detection
cfd loopback
Use cfd loopback to enable loopback (LB).
cfd loopback service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ number number ]
number number: Specifies the number of the sent LBMs packets. The value is in the range of 1 to 10. The default value is 5.
The LB function verifies link connectivity between the source MEP and the target MP by using LBMs and LBRs.
# Enable LB for the link between MEP 1101 and MEP 2001 in service instance 1 (assume that the link status is normal).
<Sysname> cfd loopback service-instance 1 mep 1101 target-mep 2001
Loopback to MEP 2001 with the sequence number start from 1101-43404:
Reply from 0010-fc00-6512: sequence number=1101-43404 Time=5ms
Reply from 0010-fc00-6512: sequence number=1101-43405 Time=5ms
Reply from 0010-fc00-6512: sequence number=1101-43406 Time=5ms
Reply from 0010-fc00-6512: sequence number=1101-43407 Time=5ms
Reply from 0010-fc00-6512: sequence number=1101-43408 Time=5ms
Sent: 5        Received: 5        Lost: 0
# Enable LB for the link between MEP 1101 and MEP 2001 in service instance 1 (assume that the link status is abnormal).
Sent: 5        Received: 0        Lost: 5
Sends LBMs to remote MEP 2001 with the sequence number starting with 1101-43404.
Reply from the MP with the MAC address 0010-FC00-6512.
sequence number
Sequence number in the LBR messages.
Time=5ms
The interval between the sending of LBMs and receiving of LBRs is 5 milliseconds.
Sent
Number of sent LBMs.
Received
Number of received LBRs.
Lost
Number of lost LBRs.
cfd md
Use cfd md to create an MD.
Use undo cfd md to delete an MD.
cfd md md-name [ index index-value ] level level-value [ md-id { dns dns-name | mac mac-address subnumber | none } ]
undo cfd md md-name
No MDs exist.
md md-name: Specifies the name of an MD, which is a string of 1 to 43 characters that can contain letters, numbers, and special characters such as grave accent (`), tilde (~), exclamation mark (!), at sign (@), number sign (#), dollar sign ($), percent (%), caret (^), ampersand (&), asterisk (*), brackets ({ }, ( ),[ ], < >), hyphen (-), underscore (_), plus (+), equal sign (=), vertical bar (|), colon (:), semicolon (;), quotation mark ('), comma (,), period (.), and slash (/).
index index-value: Specifies an MD index in the range of 1 to 4294967295. If you do not specify this option, the system automatically assigns the smallest index number that is not in use. As a best practice, use the index automatically assigned by the system.
level level-value: Specifies an MD level in the range of 0 to 7.
md-id: Specifies the MD name carried by packets sent by the MEP. If you do not provide this keyword, the MD name is represented by md-name.
dns dns-name: Specifies an MD name in the format of DNS name, where dns-name represents the DNS name.
mac mac-address subnumber: Specifies an MD name containing the MAC address and an integer. The mac-address argument represents the MAC address of the MD, and the subnumber argument is in the range of 0 to 65535.
none: Specifies that no MD name is carried in the packets sent by the MEP.
An MD name must be in compliant with the specifications in IEEE802.1ag-2007.
You can create only one MD with a specific level. MD cannot be created if you enter an invalid MD name or an existing MD name or the MD index is in use.
When deleting an MD, you will also delete the configurations related to that MD.
# Create an MD named test_md1, with its level being 3.
[Sysname] cfd md test_md1 level 3
# Create an MD named test_md2, and the MD name carried in the packet sent by the MEP comprises the MAC address 1-1-1 and integer 1.
[Sysname] cfd md test_md2 level 5 md-id mac 1-1-1 1
cfd mep
Use cfd mep to create a MEP.
Use undo cfd mep to delete a MEP.
cfd mep mep-id service-instance instance-id outbound
undo cfd mep mep-id service-instance instance-id
No MEPs exist.
mep mep-id: Specifies the MEP ID, in the range of 1 to 8191.
outbound: Creates an outward-facing MEP.
In creating a MEP, the service instance you specified defines the MD and MA to which the MEP belongs.
You cannot create a MEP if the MEP ID is not included in the MEP list of the relevant service instance.
# Configure a MEP list in service instance 5, and create inward-facing MEP 3 in service instance 5 on GigabitEthernet 1/0/1.
[Sysname] cfd md test_md level 3
[Sysname] cfd service-instance 5 ma-id vlan-based md test_md vlan 100
[Sysname] cfd meplist 3 service-instance 5
[Sysname-GigabitEthernet1/0/1] cfd mep 3 service-instance 5 outbound
cfd meplist
cfd meplist
Use cfd meplist to create a MEP list.
Use undo cfd meplist to delete a MEP list.
cfd meplist mep-list service-instance instance-id
undo cfd meplist mep-list service-instance instance-id
No MEP list is created.
meplist mep-list: Specifies a space-separated list of up to 10 MEP items. Each item specifies a MEP ID or a range of MEP IDs in the form of mep-id 1 to mep-id 2. The value range for the MEP ID is 1 to 8191. The mep-id 2 must be equal to or greater than mep-id 1.
A MEP list is a collection of local MEPs allowed to be configured and the remote MEPs to be monitored in the same MA.
Before creating a MEP list, create the relevant MD and service instance.
After you delete a MEP list, all local MEP configurations based on this list are deleted.
# Create a MEP list that includes MEP 9 through MEP 15 in service instance 5.
[Sysname] cfd meplist 9 to 15 service-instance 5
cfd md
cfd port-trigger
Use cfd port-trigger to specify the triggering event and triggered action for port collaboration.
Use undo cfd port-trigger to cancel the triggering event and triggered action for port collaboration.
cfd port-trigger { cc-expire | dm | rdi | slm | tst } action { block | shutdown }
undo cfd port-trigger { cc-expire | dm | rdi | slm | tst } action
The following compatibility matrixes show the support of hardware platforms for this command:
Hardware
Command compatibility
MSR610
No
MSR 810, MSR 810-W, MSR 810-W-DB, MSR 810-LM, MSR 810-W-LM, MSR 810-10-PoE, MSR 810-LM-HK, MSR 810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI
No
MSR 810-LMS, MSR 810-LUS
No
MSR810-SI, MSR810-LM-SI
No
MSR810-LMS-EA, MSR810-LME
No
MSR1004S-5G, MSR1004S-5G-CN
No
MSR1104S-W, MSR1104S-W-CAT, MSR1104S-5G-CN, MSR1104S-W-5G-CN
No
MSR 2600-6-X1, MSR2600-15-X1, MSR2600-15-X1-T
Yes
MSR 2600-10-X1
Yes
MSR 2630
Yes
MSR 3600-28, MSR 3600-51
Yes
MSR 3600-28-SI, MSR 3600-51-SI
Yes
MSR 3600-28-X1, MSR 3600-28-X1-DP, MSR 3600-51-X1, MSR 3600-51-X1-DP
Yes
MSR3600-28-G-DP, MSR3600-51-G-DP
Yes
MSR 3610-I-DP, MSR 3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
Yes
MSR 3610-X1, MSR 3610-X1-DP, MSR 3610-X1-DC, MSR 3610-X1-DP-DC, MSR3620-X1, MSR3640-X1
Yes
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
Yes
MSR 3610-G, MSR 3620-G
Yes
MSR3640-G
Yes
MSR3640-X1-HI
Yes
Hardware
MSR810-W-WiNet, MSR810-LM-WiNet
No
MSR830-4LM-WiNet
No
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
No
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
No
MSR2600-6-WiNet
Yes
MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
Yes
Hardware
MSR860-6EI-XS
No
MSR860-6HI-XS
No
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
Yes
Hardware
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
Yes
The triggering event and triggered action are not specified for port collaboration.
cc-expire: Triggers port collaboration when continuity check expires.
dm: Triggers port collaboration when the link transmission delay in continual two-way DM reaches or exceeds the upper limit, or reaches or falls below the lower limit.
rdi: Triggers port collaboration when the CCMs with the RDI flag bit set are received.
slm: Triggers port collaboration when the packet loss ratio in continual LM reaches or exceeds the upper limit, or reaches or falls below the lower limit.
tst: Triggers port collaboration when the bit error ratio in continual TST reaches or exceeds the upper limit, or reaches or falls below the lower limit.
block: Blocks the port by changing its link layer protocol state to DOWN (CFD). The port cannot send or receive any data packets.
shutdown: Shuts down the port by changing its physical state to CFD DOWN. The port cannot send or receive any data packets or protocol packets.
If a port is blocked by CFD, it can automatically come up when the link recovers, except that the block action is triggered by continual LM. To bring up the port blocked in continual LM, execute the undo cfd port-trigger slm action or cfd slm port-trigger up-delay command.
If a port is shut down by CFD, it cannot automatically come up when the link recovers. To bring up the port, you must execute the undo shutdown or undo cfd port-trigger command.
You can specify multiple triggering events for an interface. All the triggering events can take effect. When you specify multiple triggered actions for a triggering event on an interface, the most recent configuration takes effect.
The command takes effect only on the ports with outward-facing MEPs configured.
Configurations in Ethernet interface view take effect only on the current interface.
Configurations in aggregate interface view take effect only on the current aggregate interface.
If the MEP belongs to an MA that does not carry the VLAN attribute, configurations on a member port of an aggregation group take effect only on the current member port.
If the MEP belongs to an MA that carries the VLAN attribute, configurations on a member port of an aggregation group take effect only when the member port leaves the aggregation group.
# Specify the triggering event as cc-expire and the triggered action as block for port collaboration on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] cfd port-trigger cc-expire action block
# Specify the triggering event as cc-expire and the triggered action as shutdown for port collaboration on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] cfd port-trigger cc-expire action shutdown
cfd cc enable
cfd mep
cfd slm continual
cfd slm threshold
cfd tst continual
cfd tst threshold
Use cfd service-instance to create a service instance.
Use undo cfd service-instance to remove a service instance.
cfd service-instance instance-id ma-id { icc-based ma-name | integer ma-num | string ma-name | vlan-based [ vlan-id ] } [ ma-index index-value ] md md-name [ vlan vlan-id ]
undo cfd service-instance instance-id
No service instances exist.
service-instance instance-id: Specifies the service instance ID in the range of 1 to 32767.
ma-id: Creates an MA.
icc-based ma-name: Specifies that an MA is identified by an ICC. The ma-name argument is a string of 1 to 13 characters. An MD name must be compliant with the specifications in IEEE802.1ag-2007.
integer ma-num: Specifies that an MA is identified by an integer, where the ma-num argument is in the range of 0 to 65535.
string ma-name: Specifies that an MA is identified by a string, where the ma-name argument is string of 1 to 45 characters that can contain letters, numbers, and special characters such as grave accent (`), tilde (~), exclamation mark (!), at sign (@), number sign (#), dollar sign ($), percent (%), caret (^), ampersand (&), asterisk (*), brackets ({ }, ( ),[ ], < >), hyphen (-), underscore (_), plus (+), equal sign (=), vertical bar (|), colon (:), semicolon (;), quotation mark ('), comma (,), period (.), and slash (/).
vlan-based [ vlan-id ]: Specifies that an MA is identified by a VLAN ID, where the vlan-id argument is in the range of 1 to 4094. If you do not provide the vlan-id argument, the VLAN ID specified by vlan vlan-id is used. If the vlan vlan-id option is not provided, you must specify the vlan-id argument for the vlan-based [ vlan-id ] option.
ma-index index-value: Specifies an MA index in the range of 1 to 4294967295. If you do not specify this option, the system automatically assigns the smallest index number that is not in use. As a best practice, use the index automatically assigned by the system.
md md-name: Specifies the name of an MD. The md-name argument is a string of 1 to 43 characters that can contain letters, numbers, and special characters such as grave accent (`), tilde (~), exclamation mark (!), at sign (@), number sign (#), dollar sign ($), percent (%), caret (^), ampersand (&), asterisk (*), brackets ({ }, ( ),[ ], < >), hyphen (-), underscore (_), plus (+), equal sign (=), vertical bar (|), colon (:), semicolon (;), quotation mark (’), comma (,), period (.), and slash (/).
vlan vlan-id: Specifies the VLAN that the MA serves. The value range for the vlan-id argument is 1 to 4094.
You must create the relevant MD before creating a service instance with the MD name.
Deleting a service instance also deletes the configurations related to that service instance.
Deleting a service instance not only removes the connection between the service instance and the relevant MA, but also deletes the MA.
When you create a service instance, follow these restrictions and guidelines:
·     A service instance is indicated by an integer to represent an MA in an MD. An MA index uniquely identifies a specific MA in an MD. An MA index can be used in different MDs.
·     With the vlan-based [ vlan-id ] or vlan vlan-id option, the command creates an MA carrying the VLAN attribute. If you do not specify the option, the command creates an MA carrying no VLAN attribute.
# Create a level-3 MD named test_md and create service instance 5, in which the MA is identified by a VLAN and serves VLAN 100.
cfd md
cfd slm
Use cfd slm to configure short-period loss measurement (LM).
cfd slm service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ dot1p dot1p-value ] [ number number ] [ interval interval ]
dot1p dot1p-value: Specifies an 802.1p priority for LMM frames. The value range for the dot1p-value argument is 0 to 7. The default value is 7.
number number: Specifies the number of LMM frames to be sent. The value range for the number argument is 2 to 10, and the default is 5.
interval interval: Specifies the LMM frame sending interval, in seconds. The value takes 1 or 10. The default value is 1.
Short-period LM sends a configurable number of LMM frames at a configuration interval. It measures the frame loss between the source and target MEPs after receiving LMR frames.
Short-period LM and continual LM cannot be configured at the same time for one source MEP. If you have configured continual LM, you can configure short-period LM only after you disable continual LM. If you have configured short-period LM, you can configure continual LM only after the short-period LM ends.
# Configure short-period LM to measure the frame loss between source MEP 1101 and target MEP 2001 in service instance 1.
<Sysname> cfd slm service-instance 1 mep 1101 target-mep 2001
Far-end frame loss: 10    Near-end frame loss: 20
Far-end frame loss: 40    Near-end frame loss: 40
Far-end frame loss: 0     Near-end frame loss: 10
Far-end frame loss: 30    Near-end frame loss: 30
Average
Far-end frame loss: 20    Near-end frame loss: 25
Far-end frame loss rate: 25.00%      Near-end frame loss rate: 32.00%
Sent LMMs: 5    Received: 5    Lost: 0
Table 5 Command output
LMR frames returned from the target MEP with MAC address 0010-FC00-6512.
Far-end frame loss
Number of lost frames on the target MEP.
Near-end frame loss
Number of lost frames on the source MEP.
Frame loss ratio on the target MEP.
Frame loss ratio on the source MEP.
Average
Average number of lost frames.
Sent LMMs
Number of sent LMM frames.
Received
Number of received LMR frames.
Lost
Number of lost LMR frames.
cfd frame-count mode
cfd slm continual
Use cfd slm continual to configure continual LM.
Use undo slm continual to disable continual LM.
cfd slm continual service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ dot1p dot1p-value ] [ interval interval ]
undo cfd slm continual service-instance instance-id mep mep-id
Continual LM is not configured.
dot1p dot1p-value: Specifies the 802.1p priority of LMM frames to be sent. The value range for the dot1p-value argument is 0 to 7, and the default is 7. The larger the value, the higher the priority.
interval interval: Specifies the interval for sending LMM frames, in seconds. The value for the interval argument can be 1 or 10, and the default is 1 second.
Continual LM continually sends LMM frames at a configurable interval. It measures the frame loss between the source and target MEPs after receiving LMR frames.
To modify continual LM settings for a source MEP, disable continual LM and then reconfigure the function for the source MEP.
To display the continual LM result, use the display cfd slm history command on the device where the source MEP resides.
# Configure continual LM to measure the frame loss between source MEP 1101 and target MEP 2001 in service instance 1.
[Sysname] cfd slm continual service-instance 1 mep 1101 target-mep 2001
cfd slm
cfd slm threshold
Use cfd slm port-trigger up-delay to enable automatic port recovery for continual LM and set the delay time for automatic recovery.
Use undo slm port-trigger up-delay to restore the default.
cfd slm port-trigger up-delay delay
undo cfd slm port-trigger up-delay
Hardware
MSR610
No
No
No
No
No
No
No
Yes
MSR 2600-10-X1
Yes
MSR 2630
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
MSR3640-G
Yes
MSR3640-X1-HI
Yes
Hardware
No
MSR830-4LM-WiNet
No
No
No
MSR2600-6-WiNet
Yes
MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
Yes
Hardware
MSR860-6EI-XS
No
MSR860-6HI-XS
No
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
Yes
Hardware
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
Yes
A port blocked in continual LM cannot come up automatically. The undo cfd port-trigger slm action command is required to bring up the port.
delay: Specifies the delay time for automatic recovery, in the range of 10 to 300 minutes.
After this command is configured, continual LM stops when port collaboration blocks a port. The port automatically comes up after the specified delay time, and continues with continual LM.
# Enable automatic port recovery for continual LM and set the delay time for automatic recovery to 10 minutes.
[Sysname] cfd slm port-trigger up-delay 10
cfd port-trigger
cfd slm continual
cfd slm threshold
cfd slm threshold
Use cfd slm threshold to configure the lower limit and upper limit for continual LM.
Use undo cfd slm threshold to restore the default.
cfd slm { far-end | near-end } threshold service-instance instance-id mep mep-id { lower-limit lower-limit | upper-limit upper-limit } *
undo cfd slm { far-end | near-end } threshold service-instance instance-id mep mep-id [ lower-limit | upper-limit ]
The lower limit and upper limit for continual LM are 0 and 100%, respectively, for both the source and target MEPs.
far-end: Configures the lower limit and upper limit for the target MEP.
near-end: Configures the lower limit and upper limit for the source MEP.
lower-limit lower-limit: Specifies the lower limit in percentage, in the range of 0 to 100. It can contain a maximum of 8 digits, including the dot (.), for example, 1.000001. The lower limit must be smaller than the upper limit.
upper-limit upper-limit: Specifies the upper limit in percentage, in the range of 0 to 100. It can contain a maximum of 8 digits, including the dot (.), for example, 1.000001.
This command takes effect only after you configure continual LM.
If the cfd port-trigger slm action { block | shutdown } command is configured, the following rules apply:
·     If the packet loss ratio for the source MEP or target MEP reaches or exceeds the upper limit for three consecutive times, the port is blocked or shut down.
To bring up the port when the link recovers, execute the undo cfd port-trigger slm action command.
·     If the packet loss ratios for both the source MEP and target MEP reach or fall below the lower limit for three consecutive times, the port remains in up state.
# Configure the continual LM lower limit and upper limit as 0.2% and 0.8%, respectively, for source MEP 1101 in service instance 1.
[Sysname] cfd slm near-end threshold service-instance 1 mep 1101 lower-limit 0.2 upper-limit 0.8
cfd port-trigger
cfd slm continual
cfd tst
Use cfd tst to configure short-period test (TST).
cfd tst service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ number number ] [ length-of-test length ] [ pattern-of-test { all-zero | prbs } [ with-crc ] ]
number number: Specifies the number of sent TST frames. The value range for the number argument is 1 to 10, and the default is 5.
length-of-test length: Specifies the length of the Test TLV (Type/Length/Value) in the TST frame. The value range for the length argument is 4 to 1400, in bytes. The default value is 64.
pattern-of-test { all-zero | prbs } [ with-crc ]: Specifies the pattern of the Test TLV in the TST frame:
·     all-zero (all-zero value without CRC-32), which is the default pattern.
·     prbs (pseudo random bit sequence without CRC-32).
·     all-zero with-crc (all-zero value with CRC-32).
·     prbs with-crc (pseudo random bit sequence with CRC-32).
Short-period TST detects bit errors between the source and target MEPs by sending a configurable number of TST frames.
To view the TST test result, use the display cfd tst history command on the target MEP.
Short-period TST and continual TST cannot be configured at the same time for one source MEP. If you have configured continual TST, you can configure short-period TST only after you disable continual TST. If you have configured short-period TST, you can configure continual TST only after the short-period TST ends.
# Configure short-period TST to test the bit errors between source MEP 1101 and target MEP 1003 in service instance 1.
<Sysname> cfd tst service-instance 1 mep 1101 target-mep 1003
5 TSTs have been sent. Please check the result on the remote device.
reset cfd tst
cfd tst continual
Use cfd tst continual to configure continual TST.
Use undo cfd tst continual to disable continual TST.
cfd tst continual service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ length-of-test length ] [ pattern-of-test { all-zero | prbs } [ with-crc ] ] [ interval interval ]
undo cfd tst continual service-instance instance-id mep mep-id
Continual TST is not configured.
length-of-test length: Specifies the length of the Test TLV (Type/Length/Value) in the TST frame. The value range for the length argument is 4 to 1400 bytes, and the default is 64.
interval interval: Specifies the interval for sending TST frames, in milliseconds. The value for the interval argument can be 100 or 1000, and the default is 1000.
Continual TST detects bit errors between the source and target MEPs by sending TST frames continuously.
To modify continual TST settings for a source MEP, you must disable continual TST and then reconfigure the function  for the source MEP.
To display the continual TST result, use the display cfd tst history command on the device where the source MEP resides.
# Configure continual TST to test the bit errors between source MEP 1101 and target MEP 2001 in service instance 1.
[Sysname] cfd tst continual service-instance 1 mep 1101 target-mep 2001
cfd tst
cfd tst threshold
cfd tst threshold
Use cfd tst threshold to configure the lower limit and upper limit for continual TST.
Use undo cfd tst threshold to restore the default.
cfd tst threshold service-instance instance-id mep mep-id { lower-limit lower-limit | upper-limit upper-limit } *
undo cfd tst threshold service-instance instance-id mep mep-id [ lower-limit | upper-limit ]
The lower limit and upper limit for continual TST are 0 and 100%, respectively.
lower-limit lower-limit: Specifies the lower limit in percentage, in the range of 0 to 100. It can contain a maximum of 8 digits, including the dot (.), for example, 1.000001.The lower limit must be smaller than the upper limit.
This command takes effect only after you configure continual TST.
If the cfd port-trigger tst action { block | shutdown } command is configured, the following rules apply:
·     If the bit error ratio reaches or exceeds the upper limit for three consecutive times, the port is blocked or shut down.
·     If the bit error ratio reaches or falls below the lower limit for three consecutive times, the port is unblocked or brought up.
# Configure the continual TST lower limit and upper limit as 4.5% and 80.7%, respectively, for source MEP 1101 in service instance 1.
[Sysname] cfd tst threshold service-instance 1 mep 1101 lower-limit 4.5 upper-limit 80.7
cfd port-trigger
cfd tst continual
display cfd ais
Use display cfd ais to display the AIS configuration and information on the specified MEP or all MEPs.
display cfd ais [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the AIS configuration and information for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the AIS configuration and information for all MEPs.
# Display the AIS configuration and information for all the MEPs in all service instances.
<Sysname> display cfd ais
Service instance: 5
AIS level: 4    AIS period: 1s
MEP ID: 1
AIS condition: yes   Time to enter the condition: 2013/01/22 10:43:57
AIS state machine: Previous state: NO_RECEIVE
                   Current state: RECEIVE
MEP ID: 2
Service instance: 20
AIS level: 3    AIS period: 60s
MEP ID: 10
Service instance: 100
AIS level: 6    AIS period: 1s
MEP ID: 20
AIS condition: no    Time to enter the condition: 2013/01/22 11:40:01
AIS state machine: Previous state: IDLE
                   Current state: NO_RECEIVE
MEP ID: 50
AIS condition: no    Time to enter the condition: -
Table 6 Command output
Service instance
Service instance of the MEP.
AIS level
AIS period
AIS condition
AIS status:
·     yes—AIS is running.
·     no—AIS is not running.
Time when the AIS status began. (- means AIS is enabled but the MEP does not receive any AIS frame.)
AIS state machine
AIS frame receiving state machine.
Previous state
Previous state:
·     IDLE—Not activated.
·     NO_RECEIVE—Activated.
·     RECEIVE—AIS frames are received.
Current state
Current state:
Use display cfd dm one-way history to display the one-way DM result.
display cfd dm one-way history [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the one-way DM results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the one-way DM results for all MEPs.
# Display the one-way DM results for all the MEPs in all service instances.
<Sysname> display cfd dm one-way history
Service instance: 1
MEP ID: 1003
Sent 1DM total number: 0
Received 1DM total number: 5
Frame delay: 10ms 9ms 11ms 5ms 5ms
Delay average: 8ms
Frame delay variation: 5ms 4ms 6ms 0ms 0ms
Variation average: 3ms
MEP ID: 1004
Delay average: 8ms
Service instance: 2
No MEP exists in the service instance.
Service instance: 3
MEP ID: 1023
Sent 1DM total number: 5
Received 1DM total number: 10
Frame delay: 20ms 9ms 8ms 7ms 1ms 5ms 13ms 17ms 9ms 10ms
Delay average: 9ms
Frame delay variation: 19ms 8ms 7ms 6ms 0ms 4ms 12ms 16ms 8ms 9ms
Variation average: 8ms
Service instance: 4
MEP ID: 1023
Sent 1DM total number: 77
Received 1DM total number: 0
Table 7 Command output
Service instance
Number of sent 1DM frames.
Number of received 1DM frames.
Delay average
Average frame delay.
Variation average
Average frame delay variation.
cfd dm one-way
Use display cfd dm two-way history to display the two-way DM result.
display cfd dm two-way history [ service-instance instance-id [ mep mep-id ] ] [ number number ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the two-way DM results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the two-way DM results for all MEPs.
number number: Specifies the number of most recent two-way DM result entries to be displayed, in the range of 1 to 64. The default is 5.
# Display the two-way DM results for all the MEPs in all service instances.
<Sysname> display cfd dm two-way history
Service instance: 1
MEP ID: 1003
Send status: Testing
Frame delay:
Average: 8us
Average: 2us
Packet statistics:
MEP ID: 1004
Send status: Init
Frame delay:
Average: 8us
Average: 2us
Packet statistics:
Service instance: 2
Table 8 Command output
Send status
Two-way DM test status:
·     Testing—A two-way DM test is in progress.
·     Init—A two-way DM test is in initialization state and is about to start.
·     Stop—A two-way DM test stopped.
If a two-way DM test has never been performed on a source MEP, this field displays a hyphen (-).
DMR frames returned from the target MEP with MAC address 0010-FC00-6512.
Average
Sent DMMs
Number of sent DMM frames.
Received
Lost
Number of lost DMR frames.
cfd dm two-way
Use display cfd linktrace-reply to display information about the LTRs received by a MEP.
display cfd linktrace-reply [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the LTR information for all service instances.
mep mep-id: Specifies the ID of a MEP, in the range of 1 to 8191. If you do not specify this option, the command displays the LTR information for all MEPs.
This command displays only information about LTRs received by execution of the cfd linktrace command.
# Display the LTR information saved on all the MEPs in every service instance.
[Sysname] display cfd linktrace-reply
Service instance: 1       MEP ID: 1003
0000-fc00-6505            63      0000-fc00-6504    MPDB
000f-e269-a852            62      0000-fc00-6505    FDB
0000-fc00-6508            61      000f-e269-a852    Hit
Service instance: 2       MEP ID: 1023
Table 9 Command output
Service instance
Service instance to which the MEPs that send LTMs belong.
MEP ID
ID of the MEP that sends LTMs.
MAC address
Source MAC address in the LTR.
TTL
Last MAC
Relay action
cfd linktrace
Use display cfd linktrace-reply auto-detection to display information about the LTRs received as responses to the automatically sent LTMs.
display cfd linktrace-reply auto-detection [ size size-value ]
size size-value: Specifies the times of recent auto-detections, in the range of 1 to 100. If you do not specify this option, the command displays all information in the buffer.
This command displays only information about LTRs received by execution of the cfd linktrace auto-detection command.
# Display the contents of the LTRs received as responses to the LTMs automatically sent.
<Sysname> display cfd linktrace-reply auto-detection
Service instance: 1       MEP ID: 1003    Time: 2013/05/22 10:43:57
Target MEP ID: 2005       TTL: 64
Service instance: 2       MEP ID: 1023    Time: 2013/05/22 10:44:06
Target MEP ID: 2025       TTL: 64
Table 10 Command output
Service instance
Service instance to which the MEPs that sent LTMs belong.
MEP ID
Time
Time of the LTMs automatically sent.
Target MEP ID
ID of the target MEP.
TTL
Initial TTL of the automatically sent LTMs.
MAC address
TTL
Last MAC
Relay action
display cfd md
Use display cfd md to display the MD configuration information.
display cfd md
# Display the MD configuration information.
<Sysname> display cfd md
CFD is enabled.
Maintenance domains configured: 4 in total
Level  Index      Maintenance domain                          MD format  MD ID
0      1          md_0                                        CHARSTRING md_0
1      2          md_1                                        DNS        dns1
2      3          md_2                                        MAC        0001-00
01-0001-1
3      4          md_3                                        NONE       Without
 ID
Table 11 Command output
Number of MDs configured.
Level
Level of MD.
Index
MD index.
Maintenance domain
Name of MD.
MD format
MD name format:
·     CHARSTRING—Character string.
·     DNS—DNS name.
·     MAC—MAC address and an integer.
·     NONE—No MD name is carried.
MD ID
MD ID value:
·     A character string if the MD format is CHARSTRING.
·     A DNS name if the MD format is DNS.
·     A MAC address-subnumber if the MD format is MAC.
·     No ID if the MD format is NONE.
display cfd mep
Use display cfd mep to display the attribute and operating information for a MEP.
display cfd mep mep-id service-instance instance-id
# Display the attribute and operating information for MEP 50 in service instance 1.
<Sysname> display cfd mep 50 service-instance 1
Maintenance domain: md_0
Maintenance domain index: 1
Maintenance association: ma_0
Maintenance association index: 1
Level: 0        VLAN: 1         Direction: Outbound
Current state: Active          CCM send: Enabled
FNG state: FNG_DEFECT_REPORTED
CCM:
Current state: CCI_WAITING
Interval: 1s        SendCCM: 12018     ReceiveCCM: 18019
Loopback:
NextSeqNumber: 8877
SendLBR: 0          ReceiveInOrderLBR: 0          ReceiveOutOrderLBR: 0
Linktrace:
NextSeqNumber: 8877
SendLTR: 0          ReceiveLTM: 0
No CCM received from some remote MEPs.
One or more streams of error CCMs is received. The last received CCM:
Maintenance domain: (Without ID)
Maintenance association: matest1
MEP ID: 5      Sequence Number:0x50A
MAC Address: 0011-2233-4402
Received Time: 2013/03/06 13:01:34
One or more streams of cross-connect CCMs is received. The last received CCM:
Maintenance domain: mdtest1
Maintenance association:matest1
MEP ID: 6      Sequence Number:0x63A
MAC Address: 0011-2233-4401
Some other MEPs are transmitting the RDI bit.
Table 12 Command output
Interface on which the MEP is configured.
Maintenance domain
MD to which the MEP belongs. (If the MD does not have a name, this field is displayed as Without ID.)
Index of the MD to which the MEP belongs..
Index of the MA to which the MEP belongs.
Level
Level of the MD.
VLAN
VLAN to which the MA belongs.
Direction
Direction of the MEPs.
Current state
State of MEP:
·     Active.
·     Inactive.
CCM send
Whether the MEP sends CCM.
FNG state
State of FNG (Fault Notification Generator):
·     FNG_RESET—A fault has been cleared.
·     FNG_DEFECT—A fault has been detected.
·     FNG_REPORT_DEFECT—Report a fault.
·     FNG_DEFECT_REPORTED—A fault has been reported.
·     FNG_DEFECT_CLEARING—A fault is being cleared.
If this field is not supported, a hyphen (-) is displayed.
CCM
Information related to CCM.
Current state
State of CCMs sent:
·     CCI_IDLE—Initial state.
·     CCI_WAITING—Sending state.
Interval
Interval to send CCM. Not supported means the MEP does not support CCM sending.
SendCCM
Number of CCMs that have been sent by the MEPs.
ReceiveCCM
Number of CCMs that have been received by the MEPs.
Loopback
Information related to Loopback.
NextSeqNumber
Sequence number of the next LBM to be sent.
SendLBR
Number of LBRs that have been sent. If the MEP is inward-facing, the number of LBRs will not be counted.
ReceiveInOrderLBR
Number of LBRs received in correct sequence.
ReceiveOutOrderLBR
Number of LBRs received out of order.
Linktrace
Information related to linktrace.
NextSeqNumber
Sequence number of the next LTM to be sent.
SendLTR
Number of LTRs sent. If the MEP is inward-facing, the number of LTRs will not be counted.
ReceiveLTM
Number of LTMs received.
Failure to receive CCMs from some remote MEPs. (This information is displayed only when some CCMs are lost.)
Display the content of the last error CCM when one or more error CCMs are received. (This information is displayed only when error CCMs are received.)
Maintenance domain
MD of the last error CCM.
MA of the last error CCM.
MEP
ID of the MEP that sent the last error CCM.
Sequence Number
Sequence number of the last error CCM.
Received Time
Time when the last error CCM is received.
Cross-connect CCMs are received, and the content of the last cross-connect CCM is displayed. (This information is displayed only when cross-connect CCMs are received.)
CCMs with the RDI flag bits set are received from other MEPs. (This information is displayed only when this type of CCMs are received.)
display cfd meplist
Use display cfd meplist to display the MEP list in a service instance.
display cfd meplist [ service-instance instance-id ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays MEP lists in all service instances.
# Display the MEP list in service instance 5.
<Sysname> display cfd meplist service-instance 5
Service instance: 5
MEP list: 1 to 20, 30, 50.
display cfd mp
Use display cfd mp to display the MP information.
display cfd mp [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays MP information for all interfaces.
# Display the MP information on all interfaces.
<Sysname> display cfd mp
Interface GigabitEthernet1/0/2   VLAN NONE
MEP ID: 1        Level: 3    Service instance: 1      Direction: Outbound
Maintenance domain: md_1
Maintenance domain index: 2
Maintenance association: ma_1
Maintenance association index: 2
Table 13 Command output
Configuration of the MP that does not serve any VLAN.
Level
MD level to which the MP belongs.
Service instance
Service instance to which the MP belongs.
Maintenance domain
MD to which the MP belongs.
Index of the MD to which the MP belongs.
MA to which the MP belongs.
Index of the MA to which the MP belongs.
Direction
Direction of the MEP, Outbound.
display cfd remote-mep
Use display cfd remote-mep to display information about a remote MEP.
display cfd remote-mep service-instance instance-id mep mep-id
# Display remote MEP information for MEP 10 in service instance 4.
<Sysname> display cfd remote-mep service-instance 4 mep 10
MEP ID   MAC address      State        Time                  MAC status
20       00e0-fc00-6565   OK           2013/03/06 02:36:38   UP
30       00e0-fc27-6502   OK           2013/03/06 02:36:38   DOWN
40       00e0-fc00-6510   FAILED       2013/03/06 02:36:39   DOWN
50       00e0-fc52-baa0   OK           2013/03/06 02:36:44   DOWN
60       0010-fc00-6502   OK           2013/03/06 02:36:42   DOWN
Table 14 Command output
MEP ID
ID of the remote MED.
MAC address
MAC address of the remote MEP device.
Running state of the remote MEP:
·     OK.
·     FAILED.
Time
Time when the remote MEP entered the FAILED or OK state for the last time.
MAC status
State of the interface indicated by the last CCM received from the remote MEP:
·     UP—The interface is ready to pass packets.
·     DOWN—The interface cannot pass packets.
·     TESTING—The interface is in some test mode.
·     UNKNOWN—The interface status cannot be determined.
·     DORMANT—The interface is not in a state to pass packets. Instead, it is in a pending state, waiting for some external event.
·     NOT-PRESENT—Some component of the interface is missing.
·     LLD—The interface is down due to state of the lower layer interfaces.
display cfd service-instance
Use display cfd service-instance to display the configuration information of service instances.
display cfd service-instance [ instance-id ]
instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this argument, the command displays configuration information for all service instances.
# Display the configuration information of all service instances.
Sysname> display cfd service-instance
Service instances configured (1 in total):
Service instance 5:
Maintenance domain: md_5
Maintenance domain index: 5
Maintenance association: ma_5
Maintenance association index: 5
Level: 5  VLAN: 5   MIP rule: NONE   CCM interval: 1s   Direction: Outbound
MEP ID: 730  Interface: GigabitEthernet1/0/1
Table 15 Command output
Service instances are configured.
Number of service instances configured.
Service instance
Service instance ID.
Maintenance domain
MD of the service instance. (If the MD does not have a name, this field displays Without ID.)
Index of the MD to which the service instance belong.
MA of the service instance.
Index of the MA to which the service instance belong.
Level
MD level.
VLAN
CCM interval
Interval to send CCMs.
Direction
Direction of the MEPs configured on the service instance.
MEP ID
ID of MEPs configured on the service instance.
Interface of the MEP configured on the service instance.
Use display cfd slm history to display the LM result.
display cfd slm history [ service-instance instance-id [ mep mep-id ] ] [ number number ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the LM results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the LM results for all MEPs.
number number: Specifies the number of most recent LM result entries to be displayed, in the range of 1 to 64. The default is 5.
# Display the LM results for MEP 1101 in service instance 1.
<Sysname> display cfd slm history service-instance 1 mep 1101
Service instance: 1
MEP ID: 1101
Average:
Packet statistics:
Sent LMMs: 100    Received: 100    Lost: 0
Table 16 Command output
Send status
LM test status:
·     Testing—An LM test is in progress.
·     Init—An LM test is in initialization state and is about to start.
·     Stop—An LM test stopped.
If an LM test has never been performed on a source MEP, this field displays a hyphen (-).
Far-end frame loss
Near-end frame loss
Average
Sent LMMs
Received
Lost
cfd slm
cfd slm continual
display cfd status
Use display cfd status to display the CFD and AIS status.
display cfd status
# Display the CFD and AIS status.
<Sysname> display cfd status
CFD is enabled.
AIS is disabled.
Use display cfd tst history to display the TST result.
display cfd tst history [ service-instance instance-id [ mep mep-id ] ] [ number number ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the TST results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the TST results for all MEPs.
number number: Specifies the number of most recent TST result entries to be displayed, in the range of 1 to 64. The default is 5.
# Display the TST results for all the MEPs in all service instances.
<Sysname> display cfd tst history
Service instance: 1
MEP ID: 1003
Received from 0010-fc00-6510, Bit True,  sequence number 0
Received from 0010-fc00-6510, Bit True,  sequence number 1
Received from 0010-fc00-6510, Bit True,  sequence number 2
Received from 0010-fc00-6510, Bit True,  sequence number 3
Received from 0010-fc00-6510, Bit True,  sequence number 4
Sent TST total number: 7
Received TST total number: 5
Received bit error TST number: 0
Percentage of error messages: 0.00%
MEP ID: 1004
Send status: Init
Sent TST total number: 5
Received TST total number: 0
Service instance: 2
Service instance: 3
MEP ID: 1023
Send status: Stop
Table 17 Command output
Service instance
Send status
TST test status:
·     Testing—A TST test is in progress.
·     Init—A TST test is in initialization state and is about to start.
·     Stop—A TST test stopped.
If a TST test has never been performed on the source MEP, this field displays a hyphen (-).
TST frame with sequence number 0 was received from the MEP with MAC address 0010-FC00-6510:
·     Bit True—No bit error occurred.
·     Bit False—Bit errors occurred.
Number of sent TST frames.
Number of received TST frames.
Number of received TST frames with bit errors.
Percentage of received TST frames with bit errors.
cfd tst
cfd tst continual
reset cfd tst
Use reset cfd dm one-way history to clear the one-way DM result.
reset cfd dm one-way history [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command clears the one-way DM results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command clears the one-way DM results for all MEPs.
# Clear the one-way DM results for all MEPs in all service instances.
<Sysname> reset cfd dm one-way history
cfd dm one-way
reset cfd tst
Use reset cfd tst to clear the TST result.
reset cfd tst [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command clears the TST results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command clears the TST results for all MEPs.
# Clear the TST results for all MEPs in all service instances.
<Sysname> reset cfd tst
cfd tst
display cfd tst
  • Become a Partner
  • Partner Resources
