- 04-Layer 2—LAN Switching Command References
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-Port isolation commands
- 04-VLAN commands
- 05-QinQ commands
- 06-Loop detection commands
- 07-Spanning tree commands
- 08-LLDP commands
- 09-Layer 2 forwarding commands
- 10-VLAN termination commands
04-VLAN commands | 236.38 KB |
display interface vlan-interface
reset counters interface vlan-interface
display voice-vlan mac-address
VLAN commands
The following matrix shows the compatibility of hardware and VLAN:
Hardware |
Remarks |
· Fixed Layer 2 Ethernet ports on the following routers: ¡ MSR610 ¡ MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI ¡ MSR810-LMS, MSR810-LUS ¡ MSR810-SI, MSR810-LM-SI ¡ MSR810-LMS-EA, MSR810-LME ¡ MSR1004S-5G, MSR1004S-5G-CN ¡ MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN ¡ MSR2600-6-X1, MSR2600-15-X1, MSR2600-15-X1-T ¡ MSR2600-10-X1 ¡ MSR3600-28, MSR3600-51, MSR3600-28-SI, MSR3600-51-SI ¡ MSR3600-28-X1, MSR3600-28-X1-DP, MSR3600-51-X1, MSR3600-51-X1-DP ¡ MSR3600-28-G-DP, MSR3600-51-G-DP ¡ MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG ¡ MSR810-W-WiNet, MSR810-LM-WiNet ¡ MSR830-4LM-WiNet ¡ MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet ¡ MSR830-6BHI-WiNet, MSR830-10BHI-WiNet ¡ MSR2600-6-WiNet ¡ MSR2600-10-X1-WiNet ¡ MSR3600-28-WiNet · Layer 2 interface modules installed on routers. |
For information about the support of the routers for Layer 2 interface modules, see H3C MSR Router Series Comware 7 Interface Module Guide. |
Basic VLAN commands
bandwidth
Use bandwidth to set the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
VLAN interface view
# Set the expected bandwidth to 10000 kbps for VLAN-interface 1.
[Sysname-Vlan-interface1] bandwidth 10000
default
Use default to restore the default settings for a VLAN interface.
default
VLAN interface view
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for VLAN-interface 1.
[Sysname-Vlan-interface1] default
description
Use description to configure the description of a VLAN or VLAN interface.
For a VLAN, the description is VLAN vlan-id. The vlan-id argument specifies the VLAN ID in a four-digit format. If the VLAN ID has fewer than four digits, leading zeros are added. For example, the default description of VLAN 100 is VLAN 0100.
For a VLAN interface, the description is the name of the interface. For example, Vlan-interface1 Interface.
VLAN view
VLAN interface view
To manage VLANs and VLAN interfaces efficiently, configure descriptions for them based on their functions or connections.
# Configure the description of VLAN 2 as sales-private.
[Sysname] vlan 2
[Sysname-vlan2] description sales-private
# Configure the description of VLAN-interface 2 as linktoPC56.
[Sysname] vlan 2
[Sysname-vlan2] quit
[Sysname-Vlan-interface2] description linktoPC56
display vlan
Use display interface vlan-interface to display VLAN interface information.
display interface [ vlan-interface [ interface-number ] ] [ brief [ description | down ] ]
vlan-interface interface-number: Specifies a VLAN interface number. If you do not specify this option, the command displays information about all interfaces except VA interfaces. If you specify the vlan-interface keyword without specifying an interface, the command displays information about all VLAN interfaces. For more information about VA interfaces, see PPP in Layer 2—WAN Access Configuration Guide.
down: Displays VLAN interfaces in down state and their down causes. If you do not specify this keyword, the command displays information about VLAN interfaces in all states.
# Display information about VLAN-interface 2.
<Sysname> display interface vlan-interface 2
Vlan-interface2
Current state: DOWN
Line protocol state: DOWN
Description: Vlan-interface2 Interface
Bandwidth: 100000 kbps
Internet protocol processing : Disabled
IP packet frame type: Ethernet II, hardware address: 000f-e249-8050
IPv6 packet frame type: Ethernet II, hardware address: 000f-e249-8050
Output queue - Urgent queuing: Size/Length/Discards 0/1024/0
IPv4 traffic statistics:
Last 300 seconds input rate: 0 packets/sec, 0 bytes/sec
Last 300 seconds output rate: 0 packets/sec, 0 bytes/sec
IPv6 traffic statistics:
# Display brief information about VLAN-interface 2.
<Sysname> display interface vlan-interface 2 brief
Protocol: (s) - spoofing
Vlan2 DOWN DOWN --
Vlan-interface2 |
VLAN interface name. |
Current state |
Physical link state of the VLAN interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down. The VLAN of this VLAN interface does not contain any physical ports in up state. The ports might not be connected correctly or the links might have failed. · UP—The interface is both administratively and physically up. |
Line protocol state |
Data link layer state of the VLAN interface: · DOWN—The link layer protocol state of the interface is down. · UP—The link layer protocol state of the interface is up. |
Description of the VLAN interface. |
Bandwidth |
Expected bandwidth of the VLAN interface. |
Maximum transmission unit |
MTU of the VLAN interface. |
Internet protocol processing : Disabled |
The VLAN interface is not assigned an IP address and cannot process IP packets. |
IP packet frame type |
IPv4 packet framing format. |
hardware address |
MAC address of the VLAN interface. |
IPv6 packet frame type |
IPv6 packet framing format. |
Output queue - Urgent queuing: Size/Length/Discards 0/1024/0 Output queue - Protocol queuing: Size/Length/Discards 0/500/0 Output queue - FIFO queuing: Size/Length/Discards 0/75/0 |
Information about the urgent, protocol, and FIFO output queues: · Size—Number of packets in the queue. · Length—Maximum number of packets that the queue can contain. · Discards—Number of dropped packets. |
Last clearing of counters |
The most recent time that the reset counters interface vlan-interface command was executed. This field displays Never if you have never executed this command. |
Last 300 seconds input rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Last 300 seconds output rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec |
Average rates of input packets and output packets in the last 300 seconds (in Bps, bps, and pps). |
Input: 0 packets, 0 bytes, 0 drops |
Total number and size (in bytes) of the received packets of the interface and the number of the dropped packets. |
Output: 0 packets, 0 bytes, 0 drops |
Total number and size (in bytes) of the sent packets of the interface and the number of the dropped packets. |
Brief information on interfaces in route mode |
Brief information about Layer 3 interfaces. |
Abbreviated interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol state of the interface is up. · DOWN—The data link layer protocol state of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. |
Primary IP |
Primary IP address of the interface. |
display vlan
Use display vlan to display VLAN information.
display vlan [ vlan-id1 [ to vlan-id2 ] | all | dynamic | static ]
vlan-id1: Specifies a VLAN by its ID in the range of 1 to 4094.
vlan-id1 to vlan-id2: Specifies a VLAN ID range. Both the vlan-id1 and the vlan-id2 arguments are in the range of 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
all: Specifies all VLANs except the reserved VLANs.
dynamic: Specifies dynamic VLANs. If you specify this keyword, the command displays the total number of dynamic VLANs and each dynamic VLAN ID. Dynamic VLANs are generated through MVRP or assigned by a RADIUS server.
static: Specifies static VLANs. If you specify this keyword, the command displays the total number of static VLANs and each static VLAN ID. Static VLANs are manually created.
# Display information about VLAN 2.
<Sysname> display vlan 2
VLAN ID: 2
VLAN type: Static
Description: VLAN 0002
Tagged ports: None
Untagged ports:
GigabitEthernet1/0/1 GigabitEthernet1/0/2 GigabitEthernet1/0/3
# Display information about VLAN 3.
<Sysname> display vlan 3
VLAN ID: 3
VLAN type: static
Route interface: Configured
IPv4 address: 1.1.1.1
IPv4 subnet mask: 255.255.255.0
Description: VLAN 0003
Tagged ports: None
Untagged ports: None
VLAN type |
VLAN type, static or dynamic. |
Route interface |
Whether the VLAN interface is configured for the VLAN. · Not configured. · Configured. |
Description of the VLAN. |
Name |
VLAN name. |
IP address |
Primary IPv4 address of the VLAN interface. This field is displayed only when an IPv4 address is configured for the VLAN interface. When the VLAN interface is also configured with secondary IPv4 addresses, you can view them by using one of the following commands: · display interface vlan-interface. · display this (VLAN interface view). |
Subnet mask |
Subnet mask of the primary IP address. This field is available only when an IP address is configured for the VLAN interface. |
Tagged ports |
Tagged members of the VLAN. |
Untagged ports |
Untagged members of the VLAN. |
display vlan brief
Use display vlan brief to display brief VLAN information.
display vlan brief
# Display brief VLAN information.
<Sysname> display vlan brief
Brief information about all VLANs:
Supported Minimum VLAN ID: 1
Supported Maximum VLAN ID: 4094
Default VLAN ID: 1
VLAN ID Name Port
1 VLAN 0001 GE1/0/1 GE1/0/2 GE1/0/3 GE1/0/4
GE1/0/5 GE1/0/6
2 VLAN 0002
3 VLAN 0003
Default VLAN ID |
System default VLAN ID. |
Name |
VLAN name. |
Port |
Ports that allow packets from the VLAN to pass through. |
Use interface vlan-interface to create a VLAN interface and enter its view, or enter the view of an existing VLAN interface.
Use undo interface vlan-interface to delete a VLAN interface.
undo interface vlan-interface interface-number
No VLAN interfaces exist.
interface-number: Specifies a VLAN interface number in the range of 1 to 4094.
Create the VLAN before you create the VLAN interface for a VLAN.
# Create VLAN-interface 2, and enter its view.
[Sysname] vlan 2
mac-address
Use mac-address to assign a MAC address to a VLAN interface.
Use undo mac-address to restore the default.
mac-address mac-address
undo mac-address
The following compatibility matrixes show the support of hardware platforms for this command:
Hardware |
Command compatibility |
MSR610 |
Yes |
Yes |
MSR810-LMS, MSR810-LUS |
Yes |
MSR810-SI, MSR810-LM-SI |
Yes |
MSR810-LMS-EA, MSR810-LME |
Yes |
MSR1004S-5G, MSR1004S-5G-CN |
Yes |
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
MSR3600-28, MSR3600-51 |
Yes |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
MSR3610-G, MSR3620-G |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
No |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
MSR2600-10-X1-WiNet |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
No |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
Yes |
The default varies by device model. All VLAN interfaces created have the same MAC address.
VLAN interface view
mac-address: Specifies a MAC address in the format of H-H-H.
# Assign MAC address 0001-0001-0001 to VLAN-interface 2.
[Sysname-Vlan-interface2] mac-address 1-1-1
mtu
Use mtu to set the MTU for a VLAN interface.
mtu size
undo mtu
The MTU of a VLAN interface is 1500 bytes.
VLAN interface view
size: Sets the MTU in bytes, in the range of 46 to 1500.
If you execute both the mtu and ip mtu commands on a VLAN interface, the MTU set by the ip mtu command is used for fragmentation. For more information about the ip mtu command, see Layer 3—IP Services Command Reference.
# Set the MTU to 1492 bytes for VLAN-interface 1.
[Sysname-Vlan-interface1] mtu 1492
name
Use name to assign a name to a VLAN.
Use undo name to restore the default.
name text
undo name
The name of a VLAN is VLAN vlan-id. The vlan-id argument specifies the VLAN ID in a four-digit format. If the VLAN ID has fewer than four digits, leading zeros are added. For example, the name of VLAN 100 is VLAN 0100.
VLAN view
text: Specifies a VLAN name, a case-sensitive string of 1 to 32 characters.
For 802.1X or MAC authentication, you can specify authorization VLANs by their names or IDs. If a large number of VLANs are configured, use VLAN names to identify them.
# Assign the name test vlan to VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] name test vlan
Use reset counters interface vlan-interface to clear statistics on a VLAN interface.
reset counters interface [ vlan-interface [ interface-number ] ]
vlan-interface interface-number: Specifies a VLAN interface by its number. If you do not specify this option, this command clears statistics on all interfaces except VA interfaces. If you specify the vlan-interface keyword without specifying an interface, this command clears statistics on all VLAN interfaces.
Use this command to clear the history statistics before you collect statistics within a time period.
# Clear statistics on VLAN-interface 2.
<Sysname> reset counters interface vlan-interface 2
service
Use service to specify a primary traffic processing slot for a VLAN interface.
Use undo service to restore the default.
service slot slot-number
undo service slot
Hardware |
MSR610 |
No |
No |
No |
No |
No |
No |
No |
Yes |
MSR2600-10-X1 |
No |
MSR 2630 |
Yes |
Yes |
No |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
MSR2600-6-WiNet |
Yes |
No |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
No |
MSR860-6HI-XS |
No |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
No primary traffic processing slot is specified for a VLAN interface.
VLAN interface view
slot slot-number: Specifies an IRF member device by its member ID.
This command is supported only in IRF mode.
Specify a traffic processing slot for a VLAN interface if all traffic on the VLAN interface must be processed on the same slot.
For high availability, you can specify one primary and one backup traffic processing slot by using the service command and the service standby command, respectively.
To avoid processing slot switchover, specify the primary slot before specifying the backup slot. If you specify the backup slot before specifying the primary slot, traffic is switched over to the primary slot immediately after you specify the primary slot.
If you specify both primary and backup slots for an interface, traffic on that interface is processed as follows:
· The backup slot takes over when the primary slot becomes unavailable. The backup slot continues to process traffic for the interface after the primary slot becomes available again. The switchover will not occur until the backup slot becomes unavailable.
· When no specified traffic processing slots are available, the traffic is processed on the slot at which it arrives. Then, the processing slot that first becomes available again takes over.
If you do not specify a primary or a backup traffic processing slot for an interface, traffic on that interface is processed on the slot at which the traffic arrives.
# Specify a primary traffic processing slot for VLAN-interface 2.
[Sysname] vlan 2
[Sysname-Vlan-interface2] service slot 2
service standby
service standby
Use service standby to specify a backup traffic processing slot for an interface.
Use undo service standby to restore the default.
service standby slot slot-number
undo service standby slot
Hardware |
MSR610 |
No |
No |
No |
No |
No |
No |
No |
Yes |
MSR2600-10-X1 |
No |
MSR 2630 |
Yes |
Yes |
No |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
MSR2600-6-WiNet |
Yes |
No |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
No |
MSR860-6HI-XS |
No |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
No backup traffic processing slot is specified for an interface.
VLAN interface view
# Specify a primary and a backup traffic processing slot for VLAN-interface 2.
[Sysname] vlan 2
[Sysname-Vlan-interface2] service standby slot 3
service
shutdown
Use shutdown to shut down a VLAN interface.
Use undo shutdown to bring up a VLAN interface.
shutdown
A VLAN interface is not manually shut down.
VLAN interface view
CAUTION: Executing the shutdown command on a VLAN interface will disconnect the link of the VLAN interface and interrupt communication. Use this command with caution. |
When a VLAN interface is not manually shut down, the following guidelines apply to the interface state:
· The VLAN interface is down if all ports in the VLAN are down.
· The VLAN interface is up if one or more ports in the VLAN are up.
When you use this command to shut down a VLAN interface, the VLAN interface remains in DOWN (Administratively) state. In this case, the VLAN interface state is not affected by the state of the ports in the VLAN.
Before you configure parameters for a VLAN interface, use this command to shut it down to prevent the configuration from affecting the network. After you complete the VLAN interface configuration, use the undo shutdown command to make the settings take effect.
To troubleshoot a failed VLAN interface, you can use the shutdown command and then the undo shutdown command on the interface to see whether it recovers.
In a VLAN, the state of each Ethernet port is independent of the state of the VLAN interface.
# Shut down VLAN-interface 2, and then bring it up.
[Sysname-Vlan-interface2] shutdown
[Sysname-Vlan-interface2] undo shutdown
vlan
Use vlan vlan-id to create a VLAN and enter its view, or enter the view of an existing VLAN.
Use vlan vlan-id1 to vlan-id2 to create VLANs vlan-id1 through vlan-id2, except reserved VLANs.
Use vlan all to create VLANs 1 through 4094.
Use undo vlan to delete the specified VLANs.
vlan { vlan-id1 [ to vlan-id2 ] | all }
undo vlan { vlan-id1 [ to vlan-id2 ] | all }
VLAN 1 (system default VLAN) exists.
vlan-id1: Specifies a VLAN ID in the range of 1 to 4094.
vlan-id1 to vlan-id2: Specifies a VLAN range. The vlan-id1 and vlan-id2 arguments specify VLAN IDs. The value range for each of the two arguments is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
all: Specifies all VLANs except reserved VLANs. The keyword is not supported when the maximum number of VLANs that can be created on a device is less than 4094.
You cannot create or delete the system default VLAN (VLAN 1) or reserved VLANs.
Before you delete a dynamic VLAN or a VLAN locked by an application, you must first remove the configuration from the VLAN.
# Create VLAN 2 and enter its view.
[Sysname] vlan 2
[Sysname-vlan2]
# Create VLANs 4 through 100.
[Sysname] vlan 4 to 100
display vlan
Port-based VLAN commands
display port
Use display port to display information about hybrid or trunk ports.
hybrid: Specifies hybrid ports.
trunk: Specifies trunk ports.
# Display information about hybrid ports.
<Sysname> display port hybrid
Interface PVID VLAN Passing
GE1/0/1 100 Tagged: 1000, 1002, 1500, 1600-1611, 2000,
2555-2558, 3000, 4000
Untagged:1, 10, 15, 18, 20-30, 44, 55, 67, 100,
150-160, 200, 255, 286, 300-302
# Display information about trunk ports.
<Sysname> display port trunk
GE1/0/2 2 1-4, 6-100, 145, 177, 189-200, 244, 289, 400,
555, 600-611, 1000, 2006-2008
Interface name. |
PVID |
Port VLAN ID. |
VLAN Passing |
Existing VLANs allowed on the port. |
Tagged |
VLANs from which the port sends packets without removing VLAN tags. |
Untagged |
VLANs from which the port sends packets after removing VLAN tags. |
port
Use port to assign the specified access ports to a VLAN.
Use undo port to remove the specified access ports from a VLAN.
port interface-list
undo port interface-list
All ports are in VLAN 1.
VLAN view
interface-list: Specifies a space-separated list of up to 10 Ethernet interface items. Each item specifies an Ethernet interface or a range of Ethernet interfaces in the form of interface-type interface-number1 to interface-type interface-number2. The value for the interface-number2 argument must be equal to or greater than the value for the interface-number1 argument.
This command is applicable only to access ports. This command cannot assign access ports to or remove access ports from VLAN 1.
By default, all ports are access ports. You can manually configure the port link type. For more information, see "port link-type."
# Assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/2 to VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] port gigabitethernet 1/0/1 to gigabitethernet 1/0/2
display vlan
port access vlan
Use port access vlan to assign an access port to the specified VLAN.
Use undo port access vlan to restore the default.
port access vlan vlan-id
All access ports belong to VLAN 1.
vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
By default, all access ports belong to VLAN 1. Therefore, this command cannot be used to assign access ports to VLAN 1. To move an access port to VLAN 1, execute the undo port access vlan command on the access port.
Before assigning an access port to a VLAN, make sure the VLAN has been created.
# Assign GigabitEthernet 1/0/1 to VLAN 3.
[Sysname] vlan 3
[Sysname-vlan3] quit
[Sysname-GigabitEthernet1/0/1] port access vlan 3
port hybrid pvid
Use port hybrid pvid to set the PVID of a hybrid port.
Use undo port hybrid pvid to set the PVID of a hybrid port to 1.
port hybrid pvid vlan vlan-id
The PVID of a hybrid port is the ID of the VLAN to which the port belongs when its link type is access.
You can use a nonexistent VLAN as the PVID of a hybrid port. When you delete the PVID of a hybrid port by using the undo vlan command, the PVID setting of the port does not change.
For correct packet transmission, set the same PVID for a local hybrid port and its peer.
To enable a hybrid port to transmit packets from its PVID, you must assign the hybrid port to the PVID by using the port hybrid vlan command.
# Configure GigabitEthernet 1/0/1 as a hybrid port, set its PVID to VLAN 100, and assign it to VLAN 100 as an untagged member.
[Sysname] vlan 100
[Sysname-vlan100] quit
[Sysname-GigabitEthernet1/0/1] port link-type hybrid
[Sysname-GigabitEthernet1/0/1] port hybrid pvid vlan 100
[Sysname-GigabitEthernet1/0/1] port hybrid vlan 100 untagged
port hybrid vlan
port link-type
port hybrid vlan
Use port hybrid vlan to assign a hybrid port to the specified VLANs.
Use undo port hybrid vlan to remove a hybrid port from the specified VLANs.
undo port hybrid vlan vlan-id-list
A hybrid port is an untagged member of the VLAN to which the port belongs when its link type is access.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument. The specified VLANs must already exist on the device.
tagged: Configures the port as a tagged member of the specified VLANs. A tagged member of a VLAN sends packets from the VLAN without removing VLAN tags.
untagged: Configures the port as an untagged member of the specified VLANs. An untagged member of a VLAN sends packets from the VLAN after removing VLAN tags.
A hybrid port can allow multiple VLANs. If you execute this command multiple times on a hybrid port, the hybrid port allows all the specified VLANs.
# Configure GigabitEthernet 1/0/1 as a hybrid port, and assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100 as a tagged member.
[Sysname-GigabitEthernet1/0/1] port hybrid vlan 2 4 50 to 100 tagged
port link-type
port link-type
Use port link-type to set the link type of a port.
Use undo port link-type to restore the default link type of a port.
undo port link-type
Each port is an access port.
access: Sets the port link type to access.
hybrid: Sets the port link type to hybrid.
trunk: Sets the port link type to trunk.
To change the link type of a port from trunk to hybrid or vice versa, first set the link type to access.
# Configure GigabitEthernet 1/0/1 as a trunk port.
port trunk permit vlan
Use port trunk permit vlan to assign a trunk port to the specified VLANs.
Use undo port trunk permit vlan to remove a trunk port from the specified VLANs.
undo port trunk permit vlan { vlan-id-list | all }
A trunk port allows packets only from VLAN 1 to pass through.
all: Specifies all VLANs. To prevent unauthorized VLAN users from accessing restricted resources through the port, use the port trunk permit vlan all command with caution.
A trunk port can allow multiple VLANs. If you execute this command multiple times on a trunk port, the trunk port allows all the specified VLANs.
On a trunk port, packets only from the PVID can pass through untagged.
# Configure GigabitEthernet 1/0/1 as a trunk port, and assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100.
[Sysname-GigabitEthernet1/0/1] port trunk permit vlan 2 4 50 to 100
port link-type
port trunk pvid
Use port trunk pvid to set the PVID for a trunk port.
Use undo port trunk pvid to restore the default.
port trunk pvid vlan vlan-id
The PVID of a trunk port is VLAN 1.
You can use a nonexistent VLAN as the PVID for a trunk port. When you delete the PVID of a trunk port by using the undo vlan command, the PVID setting of the port does not change.
For correct packet transmission, set the same PVID for a local trunk port and its peer.
To enable a trunk port to transmit packets from its PVID, you must assign the trunk port to the PVID by using the port trunk permit vlan command.
# Configure GigabitEthernet 1/0/1 as a trunk, set its PVID to VLAN 100, and assign it to VLAN 100.
[Sysname-GigabitEthernet1/0/1] port trunk pvid vlan 100
[Sysname-GigabitEthernet1/0/1] port trunk permit vlan 100
port link-type
VLAN group commands
display vlan-group
Use display vlan-group to display VLAN group information.
display vlan-group [ group-name ]
group-name: Specifies a VLAN group by its name, a case-sensitive string of 1 to 31 characters. The first character must be an alphabetical character. If you do not specify this argument, the command displays information about all VLAN groups.
# Display information about VLAN group test001.
<Sysname> display vlan-group test001
VLAN group: test001
VLAN list: 2-4 100 200
# Display information about all VLAN groups.
VLAN group: rnd
VLAN list: Null
VLAN group: test001
Table 5 Command output
VLAN group |
Name of the VLAN group. |
VLAN list |
VLAN list in the VLAN group. |
vlan-group
vlan-list
vlan-group
Use vlan-group to create a VLAN group and enter its view, or enter the view of an existing VLAN group.
Use undo vlan-group to delete a VLAN group.
vlan-group group-name
undo vlan-group group-name
No VLAN groups exist.
A VLAN group includes a set of VLANs. You can add multiple VLAN lists to a VLAN group.
# Create a VLAN group named test001 and enter VLAN group view.
[Sysname] vlan-group test001
[Sysname-vlan-group-test001]
vlan-list
vlan-list
Use vlan-list to add VLANs to a VLAN group.
Use undo vlan-list to remove VLANs from a VLAN group.
vlan-list vlan-id-list
undo vlan-list vlan-id-list
No VLANs exist in a VLAN group.
VLAN group view
# Add VLAN 2 through VLAN 4, VLAN 100, and VLAN 200 to VLAN group test001.
[Sysname-vlan-group-test001] vlan-list 2 to 4 100 200
vlan-group
Super VLAN commands
The following matrix shows the compatibility of hardware and super VLAN:
Hardware |
Remarks |
· Fixed Layer 2 Ethernet ports on the following routers: ¡ MSR610 ¡ MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI ¡ MSR810-SI, MSR810-LM-SI ¡ MSR810-LMS-EA, MSR810-LME ¡ MSR1004S-5G, MSR1004S-5G-CN ¡ MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN ¡ MSR2600-6-X1, MSR2600-15-X1, MSR2600-15-X1-T ¡ MSR2600-10-X1 ¡ MSR3600-28, MSR3600-51, MSR3600-28-SI, MSR3600-51-SI ¡ MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG ¡ MSR810-W-WiNet, MSR810-LM-WiNet ¡ MSR830-4LM-WiNet ¡ MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet ¡ MSR830-6BHI-WiNet, MSR830-10BHI-WiNet ¡ MSR2600-6-WiNet ¡ MSR2600-10-X1-WiNet ¡ MSR3600-28-WiNet · Layer 2 interface modules installed on routers. |
display supervlan
Use display supervlan to display information about super VLANs and their associated sub-VLANs.
display supervlan [ supervlan-id ]
supervlan-id: Specifies a super VLAN ID in the range of 1 to 4094. If you do not specify a super VLAN ID, this command displays information about all super VLANs and their associated sub-VLANs.
# Display information about super VLAN 2 and its associated sub-VLANs.
<Sysname> display supervlan 2
Super VLAN ID: 2
Sub-VLAN ID: 3-5
VLAN ID: 2
VLAN type: Static
It is a super VLAN.
IPv4 address: 10.153.17.41
IPv4 subnet mask: 255.255.252.0
IPv6 global unicast addresses:
2001::1, subnet is 2001::/64 [TENTATIVE]
Tagged ports: None
VLAN ID: 3
VLAN type: Static
It is a sub VLAN.
Tagged ports: None
Untagged ports:
VLAN ID: 4
VLAN type: Static
It is a sub VLAN.
Description: VLAN 0004
Tagged ports: None
Untagged ports:
GigabitEthernet1/0/4
Table 6 Command output
VLAN type |
VLAN type, dynamic or static. |
Route interface |
Whether a VLAN interface is configured for the VLAN. |
IPv4 address |
IPv4 subnet mask |
Subnet mask for the primary IPv4 address of the VLAN interface. This field is displayed only when an IPv4 address is configured for the VLAN interface. |
IPv6 global unicast addresses |
Global unicast IPv6 address of the VLAN interface. This field is not displayed when no IPv6 address is configured for the VLAN interface. The IPv6 address states are as follows: · TENTATIVE—Initial state. DAD is being performed or is to be performed on the address. An address in this state cannot be used as the source address or destination address of packets. · DUPLICATE—DAD has been completed for the address. The address is not unique on the link and cannot be used. · PREFERRED—The address is preferred and can be used as the source or destination address of a packet. If an address is in this state, the command does not display the address state. · DEPRECATED—The address is beyond the preferred lifetime but within the valid lifetime. It is valid, but it cannot be used as the source address for a new connection. Packets destined to the address are processed correctly. |
VLAN description. |
Name |
VLAN name. |
Tagged ports |
Untagged ports |
subvlan
supervlan
subvlan
Use subvlan to associate a super VLAN with the specified sub-VLANs.
Use undo subvlan to dissociate sub-VLANs from a super VLAN.
subvlan vlan-id-list
undo subvlan [ vlan-id-list ]
A super VLAN is not associated with any sub-VLANs.
VLAN view
vlan-id-list: Specifies a space-separated list of up to 10 sub-VLAN items. Each item specifies a sub-VLAN ID or a range of sub-VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for sub-VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
Make sure sub-VLANs already exist before you associate them with a super VLAN.
You can add ports to and remove ports from a sub-VLAN that is already associated with a super VLAN.
When you use the undo subvlan command, follow these guidelines:
· If you do not specify the vlan-id-list argument, this command dissociates all sub-VLANs from the current super VLAN.
· If you specify the vlan-id-list argument, this command dissociates the specified sub-VLANs from the current super VLAN.
# Associate super VLAN 10 with sub-VLANs 3, 4, and 5.
[Sysname] vlan 3 to 5
[Sysname] vlan 10
[Sysname-vlan10] supervlan
[Sysname-vlan10] subvlan 3 to 5
display supervlan
supervlan
supervlan
Use supervlan to configure a VLAN as a super VLAN.
Use undo supervlan to restore the default.
supervlan
undo supervlan
A VLAN is not a super VLAN.
VLAN view
A VLAN cannot be configured as both a super VLAN and a guest VLAN, Auth-Fail VLAN, or critical VLAN. For more information about guest VLANs, Auth-Fail VLANs, and critical VLANs, see Security Configuration Guide.
As a best practice, do not configure VRRP for a super VLAN interface, because the configuration affects network performance.
Layer 2 multicast configuration for super VLANs does not take effect because they do not have physical ports.
# Configure VLAN 2 as a super VLAN.
[Sysname] vlan 2
[Sysname-vlan2] supervlan
display supervlan
subvlan
Voice VLAN commands
The following matrix shows the compatibility of hardware and voice VLAN:
Hardware |
Remarks |
· Fixed Layer 2 Ethernet ports on the following routers: ¡ MSR610 ¡ MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI ¡ MSR810-SI, MSR810-LM-SI ¡ MSR810-LMS-EA, MSR810-LME ¡ MSR1004S-5G, MSR1004S-5G-CN ¡ MSR2600-6-X1, MSR2600-15-X1, MSR2600-15-X1-T ¡ MSR2600-10-X1 ¡ MSR3600-28, MSR3600-51, MSR3600-28-SI, MSR3600-51-SI ¡ MSR3600-28-X1, MSR3600-51-X1 ¡ MSR3600-28-G-DP, MSR3600-51-G-DP ¡ MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG ¡ MSR810-W-WiNet, MSR810-LM-WiNet ¡ MSR830-4LM-WiNet ¡ MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet ¡ MSR830-6BHI-WiNet, MSR830-10BHI-WiNet ¡ MSR2600-6-WiNet ¡ MSR2600-10-X1-WiNet ¡ MSR3600-28-WiNet · The following Layer 2 interface modules installed on routers: ¡ HMIM-24GSWP ¡ HMIM-8GSW ¡ HMIM-8GSWF ¡ SIC-4GSWP |
Use display voice-vlan mac-address to display the OUI addresses supported on the device.
# Display the OUI addresses supported on the device.
<Sysname> display voice-vlan mac-address
OUI Address Mask Description
0001-e300-0000 ffff-ff00-0000 Siemens phone
0003-6b00-0000 ffff-ff00-0000 Cisco phone
0004-0d00-0000 ffff-ff00-0000 Avaya phone
000f-e200-0000 ffff-ff00-0000 H3C Aolynk phone
0060-b900-0000 ffff-ff00-0000 Philips/NEC phone
00d0-1e00-0000 ffff-ff00-0000 Pingtel phone
00e0-7500-0000 ffff-ff00-0000 Polycom phone
00e0-bb00-0000 ffff-ff00-0000 3Com phone
Table 7 Command output
OUI Address |
OUI address allowed on the device. |
Mask |
Mask of the OUI address. |
Description of the OUI address. |
display voice-vlan state
Use display voice-vlan state to display voice VLAN information.
# Display voice VLAN information.
<Sysname> display voice-vlan state
Current voice VLANs: 1
Voice VLAN security mode: Security
Voice VLAN aging time: 1440 minutes
Voice VLAN enabled ports and their modes:
Port VLAN Mode CoS DSCP
GE1/0/1 111 Auto 6 46
Table 8 Command output
Current Voice VLANs |
Number of existing voice VLANs. |
Voice VLAN security mode |
Voice VLAN mode: · Security. · Normal. |
Voice VLAN aging time |
Voice VLAN aging timer. |
Voice VLAN enabled ports and their modes |
Voice VLAN-enabled ports and their voice VLAN assignment modes. |
Port |
Name of the voice VLAN-enabled port. |
VLAN |
ID of the voice VLAN enabled on the port. |
Mode |
Voice VLAN assignment mode of the port: · Manual. · Automatic. |
voice-vlan aging
voice-vlan enable
voice-vlan mode auto
voice-vlan security enable
voice-vlan aging
Use voice-vlan aging to set the voice VLAN aging timer.
Use undo voice-vlan aging to restore the default.
voice-vlan aging minutes
The voice VLAN aging timer is 1440 minutes (24 hours).
minutes: Sets the voice VLAN aging timer in the range of 5 to 43200 in minutes.
In automatic voice VLAN assignment mode, the device starts an aging timer for a voice VLAN when assigning a port to the voice VLAN. If no voice packets are received on the port before the timer expires, the device removes the port from the voice VLAN.
The aging timer of a voice VLAN starts only when the dynamic MAC address entry of the voice VLAN ages out. The aging period for the voice VLAN equals the sum of the voice VLAN aging timer and the aging timer for its dynamic MAC address entry. For more information about the aging timer for dynamic MAC address entries, see MAC address table configuration in Layer 2—LAN Switching Configuration Guide.
Set the voice VLAN aging timer only when the voice VLAN assignment mode is automatic.
# Set the voice VLAN aging timer to 100 minutes.
[Sysname] voice-vlan aging 100
voice-vlan enable
Use voice-vlan enable to enable the voice VLAN feature on a port.
Use undo voice-vlan enable to disable the voice VLAN feature on a port.
voice-vlan vlan-id enable
undo voice-vlan [ vlan-id ] enable
The voice VLAN feature is disabled on ports.
vlan-id: Specifies a voice VLAN ID in the range of 2 to 4094.
Use this command only on a hybrid or trunk port operating in automatic voice VLAN assignment mode.
Before you execute this command, make sure the specified VLAN already exists.
# Enable the voice VLAN feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] voice-vlan 2 enable
Use voice-vlan mac-address to configure the OUI address information for voice packet identification.
Use undo voice-vlan mac-address to delete an OUI address.
voice-vlan mac-address mac-address mask oui-mask [ description text ]
undo voice-vlan mac-address oui
System default OUI addresses exist.
Table 9 System default OUI addresses
Number |
OUI address |
Vendor |
1 |
0001-e300-0000 |
Siemens phone |
2 |
0003-6b00-0000 |
Cisco phone |
3 |
0004-0d00-0000 |
Avaya phone |
4 |
000f-e200-0000 |
H3C Aolynk phone |
5 |
0060-b900-0000 |
Philips/NEC phone |
6 |
00d0-1e00-0000 |
Pingtel phone |
7 |
00e0-7500-0000 |
Polycom phone |
8 |
00e0-bb00-0000 |
3Com phone |
mac-address: Specifies a source MAC address of voice traffic, in the format of H-H-H. For example, 1234-1234-1234.
mask oui-mask: Specifies the valid length of the OUI address by using a mask in the format of H-H-H. The mask contains consecutive 1s and 0s. For example, ffff-0000-0000. To match the voice devices of a vendor, set the mask to ffff-ff00-0000.
description text: Specifies the OUI address description, a case-sensitive string of 1 to 30 characters.
oui: Specifies an OUI address to delete, in the format of H-H-H. For example, 1234-1200-0000. An OUI address is the logical AND result of the mac-address and oui-mask arguments. It cannot be a broadcast address, a multicast address, or an all-zero address.
You can manually delete or add the system default OUI addresses.
The maximum number of configurable OUI addresses depends on the device model.
# Add OUI address 1234-1200-0000 by specifying the MAC address as 1234-1234-1234 and the mask as fff-ff00-0000. Configure the OUI address description as PhoneA.
[Sysname] voice-vlan mac-address 1234-1234-1234 mask ffff-ff00-0000 description PhoneA
Use voice-vlan mode auto to configure a port to operate in automatic voice VLAN assignment mode.
Use undo voice-vlan mode auto to configure a port to operate in manual voice VLAN assignment mode.
A port operates in automatic voice VLAN assignment mode.
To make a voice VLAN take effect on a port operating in manual mode, you must manually assign the port to the voice VLAN.
# Configure GigabitEthernet 1/0/1 to operate in manual voice VLAN assignment mode.
[Sysname-GigabitEthernet1/0/1] undo voice-vlan mode auto
voice-vlan qos
Use voice-vlan qos to configure a port to modify the CoS and DSCP values for incoming voice VLAN packets.
Use undo voice-vlan qos to restore the default.
voice-vlan qos cos-value dscp-value
undo voice-vlan qos
Hardware |
MSR610 |
No |
No |
No |
No |
No |
No |
No |
No |
MSR2600-10-X1 |
No |
MSR 2630 |
No |
No |
No |
No |
Yes |
No |
No |
No |
No |
MSR3640-G |
No |
MSR3640-X1-HI |
Yes |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
MSR2600-6-WiNet |
No |
No |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
No |
No |
Hardware |
MSR860-6EI-XS |
No |
MSR860-6HI-XS |
No |
MSR2630-XS |
No |
MSR3600-28-XS |
No |
MSR3610-XS |
No |
MSR3620-XS |
No |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
No |
MSR3640-XS |
No |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
No |
MSR3600-28-SI-GL |
No |
A port modifies the CoS and DSCP values for incoming voice VLAN packets to 6 and 46, respectively.
cos-value: Specifies a CoS value in the range of 0 to 7. A bigger CoS value represents a higher priority.
dscp-value: Specifies a DSCP value in the range of 0 to 63. A bigger DSCP value represents a higher priority.
You cannot execute this command on a voice VLAN-enabled port. Before you execute this command on a port, you must disable the voice VLAN feature on it.
If you execute both the voice-vlan qos and voice-vlan qos trust commands multiple times, the most recent configuration takes effect.
# Configure GigabitEthernet 1/0/1 to modify the CoS and DSCP values for voice VLAN packets to 5 and 45, respectively.
[Sysname-GigabitEthernet1/0/1] voice-vlan qos 5 45
Use voice-vlan qos trust to configure a port to trust the priority settings in incoming voice VLAN packets.
undo voice-vlan qos
Hardware |
MSR610 |
No |
No |
No |
No |
No |
No |
No |
No |
MSR2600-10-X1 |
No |
MSR 2630 |
No |
No |
No |
No |
Yes |
No |
No |
No |
No |
MSR3640-G |
No |
MSR3640-X1-HI |
Yes |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
MSR2600-6-WiNet |
No |
No |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
No |
No |
Hardware |
MSR2630-XS |
No |
MSR3600-28-XS |
No |
MSR860-6EI-XS |
No |
MSR860-6HI-XS |
No |
MSR3610-XS |
No |
MSR3620-XS |
No |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
No |
MSR3640-XS |
No |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
No |
MSR3600-28-SI-GL |
No |
When a port trusts the QoS priority settings in incoming voice VLAN packets, the port does not modify their CoS and DSCP values.
# Configure GigabitEthernet 1/0/1 to trust the priority settings in incoming voice VLAN traffic.
[Sysname-GigabitEthernet1/0/1] voice-vlan qos trust
voice-vlan qos
Use voice-vlan security enable to enable the voice VLAN security mode.
Use undo voice-vlan security enable to disable the voice VLAN security mode.
The voice VLAN security mode is enabled.
In security mode, a voice VLAN transmits only voice packets whose source MAC addresses match the OUI addresses of the device.
In normal mode, a voice VLAN transmits voice packets and non-voice packets.
# Disable the voice VLAN security mode.
[Sysname] undo voice-vlan security enable
voice-vlan track lldp
Use voice-vlan track lldp to enable LLDP for automatic IP phone discovery.
Use undo voice-vlan track lldp to disable LLDP for automatic IP phone discovery.
LLDP for automatic IP phone discovery is disabled.
# Enable LLDP for automatic IP phone discovery.
[Sysname] voice-vlan track lldp
