- 04-Layer 2—LAN Switching Command References
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-Port isolation commands
- 04-VLAN commands
- 05-QinQ commands
- 06-Loop detection commands
- 07-Spanning tree commands
- 08-LLDP commands
- 09-Layer 2 forwarding commands
- 10-VLAN termination commands
00-Preface | 100.04 KB |
Preface
This command reference covers the commands for configuring Layer 2 technologies and features in a LAN switched network.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
