02-IEEE8021-EVB-MIB | 106.41 KB |
ieee8021BridgeEvbSysNumExternalPorts
ieee8021BridgeEvbSysEvbLldpTxEnable
ieee8021BridgeEvbSysEvbLldpManual
ieee8021BridgeEvbSysEvbLldpGidCapable
ieee8021BridgeEvbSysEcpAckTimer
ieee8021BridgeEvbSysEcpMaxRetries
ieee8021BridgeEvbSysVdpDfltRsrcWaitDelay
ieee8021BridgeEvbSysVdpDfltReinitKeepAlive
ieee8021BridgeEvbVSIDBMacTable
ieee8021BridgeEvbUAPConfigTable
ieee8021BridgeEvbCAPConfigTable
IEEE8021-EVB-MIB
About this MIB
This MIB is defined by IEEE P802.1Qbg/D2.2 to control access to and manage EVB system information, ECP running information, S-channels, and VSI interfaces. This MIB is applicable to both EVB bridge and EVB station. However, we use this MIB only to configure a EVB bridge.
MIB file name
ieee8021-evb.mib
Root object
iso(1).org(3).ieee(111).standards-association-numbered-series-standards(2).lan-man-stds(802).ieee802dot1(1).ieee802dot1mibs(1).ieee8021BridgeEvbMib(24)
Tabular objects
Scalar objects
ieee8021BridgeEvbSysType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021BridgeEvbSysType (1.3.111.2.802.1.1.24.1.1.1) |
read-only |
INTEGER |
evbBridge (1), evbStation (2) |
EVB role. |
The value is always evbBridge(1). |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021BridgeEvbSysNumExternalPorts (1.3.111.2.802.1.1.24.1.1.2) |
read-only |
Unsigned32 |
Unsigned32 (1..4095) |
Number of externally accessible ports. |
Maximum number of EVB ports supported by the system. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021BridgeEvbSysEvbLldpTxEnable (1.3.111.2.802.1.1.24.1.1.3) |
read-write |
TruthValue |
true(1), false(2) |
Whether to advertise EVB information through LLDP. |
Supports only the read operation. The value is always true. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021BridgeEvbSysEvbLldpManual (1.3.111.2.802.1.1.24.1.1.4) |
read-write |
TruthValue |
true(1), false(2) |
Whether the effective EVB settings are from manual configuration. |
Supports only the read operation. The value is always false. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021BridgeEvbSysEvbLldpGidCapable (1.3.111.2.802.1.1.24.1.1.5) |
read-write |
TruthValue |
true(1), false(2) |
Support for Group ID. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021BridgeEvbSysEcpAckTimer (1.3.111.2.802.1.1.24.1.1.6) |
read-write |
Integer32 |
Standard MIB values. |
ECP retransmission exponent. |
Supports only the read operation. The value is fixed at 16. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021BridgeEvbSysEcpMaxRetries(1.3.111.2.802.1.1.24.1.1.7) |
read-write |
Integer32 |
Integer32 (0..7) |
Maximum number of times to retransmit an ECP packet. |
Supports only the read operation. The value is fixed at 3. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021BridgeEvbSysVdpDfltRsrcWaitDelay(1.3.111.2.802.1.1.24.1.1.8) |
read-write |
Integer32 |
VDP resource-wait-delay exponent. |
Supports only the read operation. The value is fixed at 20. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021BridgeEvbSysVdpDfltReinitKeepAlive (1.3.111.2.802.1.1.24.1.1.9) |
read-write |
Integer32 |
VDP keepalive exponent. |
As per the MIB. |
Tabular objects
ieee8021BridgeEvbSbpTable
About this table
Use this table to obtain running parameter information about Station-facing Bridge Ports (SBPs), including the source of effective EVB settings, the effective RWD and RKA, and the VDP keepalive time.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ieee8021BridgeEvbSbpComponentID and ieee8021BridgeEvbSbpPortNumber.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021BridgeEvbSbpComponentID(1.3.111.2.802.1.1.24.1.1.10.1.1) |
not-accessible |
IEEE8021PbbComponentIdentifier |
Unsigned32 (1..4294967295) |
Component ID of an SBP. |
The value is fixed at 1. |
ieee8021BridgeEvbSbpPortNumber(1.3.111.2.802.1.1.24.1.1.10.1.2) |
not-accessible |
IEEE8021BridgePortNumber |
Unsigned32 (1..65535) |
SBP port number. |
As per the MIB. |
ieee8021BridgeEvbSbpLldpManual(1.3.111.2.802.1.1.24.1.1.10.1.3) |
read-write |
TruthValue |
true(1), false(2) |
ieee8021BridgeEvbSbpVdpOperRsrcWaitDelay(1.3.111.2.802.1.1.24.1.1.10.1.4) |
read-only |
Unsigned32 |
Effective RWD (VDP resource wait-delay exponent) on the SBP. |
Exponent type. No measurement unit. |
ieee8021BridgeEvbSbpVdpOperReinitKeepAlive(1.3.111.2.802.1.1.24.1.1.10.1.5) |
read-only |
Unsigned32 |
Effective RKA (VDP keepalive exponent) on the SBP. |
ieee8021BridgeEvbSbpVdpOperToutKeepAlive(1.3.111.2.802.1.1.24.1.1.10.1.6) |
read-only |
Unsigned32 |
VDP keepalive time on the SBP. |
As per the MIB. |
ieee8021BridgeEvbVSIDBTable
About this table
Use this table to obtain running information about VSI interfaces, including the creation time, association operation type, filter format, filter count, and VDP packet statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ieee8021BridgeEvbVSIComponentID, ieee8021BridgeEvbVSIPortNumber, ieee8021BridgeEvbVSIIDType, and ieee8021BridgeEvbVSIID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021BridgeEvbVSIComponentID(1.3.111.2.802.1.1.24.1.2.1.1.1) |
not-accessible |
Component ID of a VSI interface. |
ieee8021BridgeEvbVSIPortNumber(1.3.111.2.802.1.1.24.1.2.1.1.2) |
not-accessible |
Port number of the SBP or URP to which a VSI interface belongs. |
As per the MIB. |
ieee8021BridgeEvbVSIIDType(1.3.111.2.802.1.1.24.1.2.1.1.3) |
not-accessible |
INTEGER |
vsiidIpv4 (1), vsiidIpv6 (2), vsiidMAC (3), vsiidLocal (4), vsiidUUID (5) |
VSI interface ID type. |
As per the MIB. |
ieee8021BridgeEvbVSIID(1.3.111.2.802.1.1.24.1.2.1.1.4) |
not-accessible |
OCTET STRING |
OCTET STRING(16) |
VSI interface ID. |
As per the MIB. |
ieee8021BridgeEvbVSITimeSinceCreate(1.3.111.2.802.1.1.24.1.2.1.1.5) |
read-only |
Unsigned32 |
Time since VSI interface creation. |
As per the MIB. |
ieee8021BridgeEvbVsiVdpOperCmd(1.3.111.2.802.1.1.24.1.2.1.1.6) |
read-only |
INTEGER |
preAssociate (1), preAssociateWithRsrcReservation (2), associate (3), deAssociate (4) |
VDP association operation type. |
An EVB bridge supports only associate and preAssociate for VSI interfaces. |
ieee8021BridgeEvbVsiOperRevert(1.3.111.2.802.1.1.24.1.2.1.1.7) |
read-only |
TruthValue |
true(1), false(2) |
Whether the VSI interface has received the most recent value of the KEEP indicator from the VDP protocol exchange. |
As per the MIB. |
ieee8021BridgeEvbVsiOperHard(1.3.111.2.802.1.1.24.1.2.1.1.8) |
read-only |
TruthValue |
true(1) false(2) |
Whether the VSI interface has received the most recent value of the HARD indicator from the VDP protocol exchange. |
As per the MIB. |
ieee8021BridgeEvbVsiOperReason(1.3.111.2.802.1.1.24.1.2.1.1.9) |
read-only |
BITS |
success(0), invalidFormat(1), insufficientResources(2), otherfailure(3) |
Outcome of the most recent request. |
An EVB bridge supports only success and insufficientResources for VSI interfaces. |
ieee8021BridgeEvbVSIMgrID(1.3.111.2.802.1.1.24.1.2.1.1.10) |
read-only |
OCTET STRING |
OCTET STRING(1) |
ID of the VSI manager. |
One byte is not enough for the address of the VSI manager. The object returns 0 to indicate that the function of this object cannot be realized. |
ieee8021BridgeEvbVSIType(1.3.111.2.802.1.1.24.1.2.1.1.11) |
read-only |
Integer32 |
VSI interface type. |
As per the MIB. |
ieee8021BridgeEvbVSITypeVersion(1.3.111.2.802.1.1.24.1.2.1.1.12) |
read-only |
OCTET STRING |
OCTET STRING(1) |
Version of the VSI interface type. |
As per the MIB. |
ieee8021BridgeEvbVSIMvFormat(1.3.111.2.802.1.1.24.1.2.1.1.13) |
read-only |
INTEGER |
basic(1), partial(2), vlanOnly(3) |
VSI filter MAC/VLAN format. |
For basic MAC/VLAN format, this object returns basic(1). For VLAN-only MAC/VLAN format, this object returns vlanOnly(3). For partial MAC/VLAN format, this object returns partial(2). |
ieee8021BridgeEvbVSINumMACs(1.3.111.2.802.1.1.24.1.2.1.1.14) |
Integer32 |
Number of MAC address/VLAN ID pairs contained in the repeated portion of the MAC/VLANs field in the VDP TLV. |
As per the MIB. |
ieee8021BridgeEvbVDPMachineState(1.3.111.2.802.1.1.24.1.2.1.1.15) |
read-only |
INTEGER |
preAssociate(1), preAssociateWithRsrcReservation(2), associate(3), deAssociate(4) |
VDP state machine. |
ieee8021BridgeEvbVDPCommandsSucceeded(1.3.111.2.802.1.1.24.1.2.1.1.16) |
read-only |
Counter32 |
Number of successful VDP commands since creation. |
As per the MIB. |
ieee8021BridgeEvbVDPCommandsFailed(1.3.111.2.802.1.1.24.1.2.1.1.17) |
read-only |
Counter32 |
Number of failed VDP commands since creation. |
As per the MIB. |
ieee8021BridgeEvbVDPCommandReverts(1.3.111.2.802.1.1.24.1.2.1.1.18) |
read-only |
Counter32 |
Number of VDP command reverts since creation. |
As per the MIB. |
ieee8021BridgeEvbVDPCounterDiscontinuity(1.3.111.2.802.1.1.24.1.2.1.1.19) |
read-only |
TimeTicks |
The time since the last counter discontinuity. |
As per the MIB. |
About this table
Use this table to obtain filter information on active VSI interfaces, including the MAC and VLAN information for the filters.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ieee8021BridgeEvbVSIComponentID, ieee8021BridgeEvbVSIPortNumber, ieee8021BridgeEvbVSIIDType, ieee8021BridgeEvbVSIID, ieee8021BridgeEvbGroupID, ieee8021BridgeEvbVSIMac, and ieee8021BridgeEvbVSIVlanId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021BridgeEvbGroupID (1.3.111.2.802.1.1.24.1.2.2.1.1) |
not-accessible |
Unsigned32 |
Group ID contained in a VSI filter. |
The group ID used by the VSI filter to filter traffic. A group ID and a VLAN ID together identify a VLAN. The value of 0 indicates that the VSI filter does not contain a group ID. |
ieee8021BridgeEvbVSIMac (1.3.111.2.802.1.1.24.1.2.2.1.2) |
not-accessible |
MacAddress |
OCTET STRING(6) |
MAC address contained in the VSI filter. |
The MAC address used by the VSI filter to filter traffic. The value of 00:00:00:00:00:00 indicates that the VSI filter does not contain a MAC address. |
ieee8021BridgeEvbVSIVlanId (1.3.111.2.802.1.1.24.1.2.2.1.3) |
read-only |
VlanIndex |
Unsigned32(0..4294967295) |
VLAN ID in the VSI filter. |
As per the MIB. |
About this table
Use this table to obtain information about UAP configuration parameters, including the port number, interface index, CDCP running status, and CDCP running role information. A UAP is an EVB-enabled port. Creating a row enables EVB on a port.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is ieee8021BridgePhyPort.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021BridgeEvbUAPComponentId(1.3.111.2.802.1.1.24.1.3.1.1.1) |
read-only |
Component ID of a UAP. |
ieee8021BridgeEvbUAPPort(1.3.111.2.802.1.1.24.1.3.1.1.2) |
read-only |
Port number of the UAP. |
As per the MIB. |
ieee8021BridgeEvbUapConfigIfIndex(1.3.111.2.802.1.1.24.1.3.1.1.3) |
read-only |
InterfaceIndexOrZero |
Integer32 (0..2147483647) |
Interface index of the UAP. |
As per the MIB. |
ieee8021BridgeEvbUAPSchCdcpAdminEnable(1.3.111.2.802.1.1.24.1.3.1.1.4) |
read-create |
INTEGER |
enable (1), disable (2) |
Administrative status of CDCP on the UAP. |
Supports only the read operation. The value is always enable(1). |
ieee8021BridgeEvbUAPSchAdminCDCPRole(1.3.111.2.802.1.1.24.1.3.1.1.5) |
read-create |
INTEGER |
cdcpRoleB(1), cdcpRoleS (2) |
Administratively configured value for the UAP's role parameter. The cdcpRoleB value represents the EVB bridge role and the cdcpRoleS value represents the EVB station role. |
Supports only the read operation. The value is always cdcdRoleB(1). |
ieee8021BridgeEvbUAPSchAdminCDCPChanCap(1.3.111.2.802.1.1.24.1.3.1.1.6) |
read-create |
Integer32 |
Integer32(1 .. 167) |
Administratively configured value for the maximum number of S-channels supported by the UAP. |
Supports only the read operation. The value is fixed at 167. |
ieee8021BridgeEvbUAPSchOperCDCPChanCap(1.3.111.2.802.1.1.24.1.3.1.1.7) |
read-only |
Integer32 |
Operational value for the maximum number of S-channels supported by the UAP. |
ieee8021BridgeEvbUAPSchAdminCDCPSVIDPoolLow(1.3.111.2.802.1.1.24.1.3.1.1.8) |
read-create |
VlanIndex |
Lowest S-VLAN ID that can be assigned to S-channels by CDCP. |
Supports only the read operation. The value is fixed at 2. |
ieee8021BridgeEvbUAPSchAdminCDCPSVIDPoolHigh(1.3.111.2.802.1.1.24.1.3.1.1.9) |
read-create |
VlanIndex |
Highest S-VLAN ID that can be assigned to S-channels by CDCP. |
Supports only the read operation. The value is fixed at 4094. |
ieee8021BridgeEvbUAPSchOperState(1.3.111.2.802.1.1.24.1.3.1.1.10) |
read-only |
INTEGER |
running (1), notRunning (2) |
Local CDCP running state. |
The value is always running(1). |
ieee8021BridgeEvbSchCdcpRemoteEnabled(1.3.111.2.802.1.1.24.1.3.1.1.11) |
read-only |
INTEGERS |
Remote CDCP state. |
As per the MIB. |
ieee8021BridgeEvbSchCdcpRemoteRole(1.3.111.2.802.1.1.24.1.3.1.1.12) |
read-only |
INTEGER |
Remote CDCP running role. The cdcpRoleB value represents the EVB bridge role. The cdcpRoleS value represents the EVB station role. |
The value is always cdcpRoleS(2). |
ieee8021BridgeEvbUAPConfigStorageType(1.3.111.2.802.1.1.24.1.3.1.1.13) |
read-create |
StorageType |
INTEGER {other(1), volatile(2), nonVolatile(3), permanent(4), readOnly(5)} |
Whether to store the configuration permanently. |
Supports only the read operation. The value is always volatile. |
ieee8021BridgeEvbUAPConfigRowStatus(1.3.111.2.802.1.1.24.1.3.1.1.14) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
Supports only active, createAndGo, and destroy. |
About this table
Use this table to obtain information about S-channel Access Ports (CAPs), including the port number and interface index information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ieee8021BridgePhyPort and ieee8021BridgeEvbSchID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021BridgeEvbSchID(1.3.111.2.802.1.1.24.1.3.2.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (1..4094) |
S-VLAN ID of an EVB bridge or S-channel ID (SCID) of an EVB station. |
As per the MIB. |
ieee8021BridgeEvbCAPComponentId(1.3.111.2.802.1.1.24.1.3.2.1.2) |
read-only |
Component ID of a CAP. |
ieee8021BridgeEvbCapConfigIfIndex(1.3.111.2.802.1.1.24.1.3.2.1.3) |
read-only |
Interface index of the CAP. |
As per the MIB. |
ieee8021BridgeEvbCAPPort(1.3.111.2.802.1.1.24.1.3.2.1.4) |
read-only |
Port number of the CAP. |
As per the MIB. |
ieee8021BridgeEvbCAPSChannelID(1.3.111.2.802.1.1.24.1.3.2.1.5) |
read-only |
Unsigned32 |
SCID of the CAP. |
As per the MIB. |
ieee8021BridgeEvbCAPAssociateSBPOrURPCompID(1.3.111.2.802.1.1.24.1.3.2.1.6) |
read-write |
Component ID of the SBP or URP associated with the CAP. |
Supports only the read operation. The value is fixed at 1. |
ieee8021BridgeEvbCAPAssociateSBPOrURPPort(1.3.111.2.802.1.1.24.1.3.2.1.7) |
read-write |
Port number of the SBP or URP associated with the CAP. For an EVB bridge, this object represents the port number of the SBP. |
Supports only the read operation. |
ieee8021BridgeEvbCAPRowStatus(1.3.111.2.802.1.1.24.1.3.2.1.8) |
read-create |
RowStatus |
Row status. |
Supports only the read operation. The value is always active. |
ieee8021BridgeEvbEcpTable
About this table
Use this table to obtain information about Edge Control Protocol (ECP), including the following:
· The maximum number of retransmission times.
· The number of times ECP failed to successfully deliver a frame since ECP was instanciated.
· ECP packet statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ieee8021BridgeEvbEcpComponentId and ieee8021BridgeEvbEcpPort.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021BridgeEvbEcpComponentId(1.3.111.2.802.1.1.24.1.3.4.1.1) |
not-accessible |
Component ID. |
ieee8021BridgeEvbEcpPort(1.3.111.2.802.1.1.24.1.3.4.1.2) |
not-accessible |
Port number. |
As per the MIB. |
ieee8021BridgeEvbEcpOperAckTimerInit1.3.111.2.802.1.1.24.1.3.4.1.3) |
read-only |
Unsigned32 |
Initial value used to initialize ackTimer. The timer is calculated based on the RTE value after negotiation. |
As per the MIB. |
ieee8021BridgeEvbEcpOperMaxRetries(1.3.111.2.802.1.1.24.1.3.4.1.4) |
read-only |
Unsigned32 |
Maximum number of times to retransmit an ECP packet. (R value after negotiation.) |
As per the MIB. |
ieee8021BridgeEvbEcpTxFrameCount(1.3.111.2.802.1.1.24.1.3.4.1.5) |
read-only |
Counter32 |
Number of transmitted ECP frames. |
As per the MIB. |
ieee8021BridgeEvbEcpTxRetryCount(1.3.111.2.802.1.1.24.1.3.4.1.6) |
read-only |
Counter32 |
Number of retransmitted ECP frames. |
As per the MIB. |
ieee8021BridgeEvbEcpTxFailures(1.3.111.2.802.1.1.24.1.3.4.1.7) |
read-only |
Counter32 |
Number of ECP frames that the port failed to transmit. |
As per the MIB. |
ieee8021BridgeEvbEcpRxFrameCount(1.3.111.2.802.1.1.24.1.3.4.1.8) |
read-only |
Counter32 |
Number of received ECP frames. |
As per the MIB. |
