01-HH3C-EVB-MIB | 87.62 KB |
HH3C-EVB-MIB
About this MIB
Use this private MIB to manage EVB features extended based on the standard EVB MIB, for example, the default VSI manager configuration and manual creation of S-channels and VSI interfaces.
MIB file name
hh3c-evb.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506). h3cCommon(2).hh3cEvb(134)
Scalar objects
hh3cEvbSetResult
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cEvbSetResult(1.3.6.1.4.1.25506.2.134.1.1) |
read-only |
INTEGER |
unknown(1), processing(2), success(3), failed(4) |
EVB set operation result. |
As per the MIB. |
Tabular objects
hh3cEvbDefaultManagerTable
About this table
Use this table to configure or obtain information about the default VSI manager.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
· You must specify the hh3cEvbManagerType object when creating the default VSI manager. · If the value of the hh3cEvbManagerType object is local, you must delete the hh3cEvbManagerID and hh3cEvbManagerPort objects when creating the default VSI manager. · If the value of the hh3cEvbManagerType object is ipv4 or ipv6, you must specify the hh3cEvbManagerID object when creating the default VSI manager. The value of the hh3cEvbManagerID object is the IPv4 or IPv6 address of the default VSI manager. · If the value of the hh3cEvbManagerType object is name, you must specify the hh3cEvbManagerID object when creating the default VSI manager. The value of the hh3cEvbManagerID object is a string of 1 to 127 characters, which represents the name of the default VSI manager. |
· The restrictions for modifying the hh3cEvbManagerType object are the same as those for creating the default VSI manager. · If you change the value of the hh3cEvbManagerType object to ipv4, ipv6, or name, you must specify the hh3cEvbManagerID object. The hh3cEvbManagerPort object is optional. If you do not specify the hh3cEvbManagerPort object, the object automatically uses the default value. · If you change the value of the hh3cEvbManagerType object to local, the values of the hh3cEvbManagerID and hh3cEvbManagerPort objects automatically change to a zero-length string and zero, respectively. The new values are invalid values. · When the value of the hh3cEvbManagerType object is set to local, you cannot modify the hh3cEvbManagerID or hh3cEvbManagerPort object. |
Supported |
Supported |
Columns
The table index is hh3cSystemDiagInfoIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cEvbManagerIndex(1.3.6.1.4.1.25506.2.134.1.2.1.1) |
not-accessible |
Unsigned32 |
Standard MIB values. |
Index value. |
The value is fixed at 1. |
hh3cEvbManagerType(1.3.6.1.4.1.25506.2.134.1.2.1.2) |
read-create |
INTEGER |
ipv4 (1), ipv6 (2), name (3), local (4) |
Type of the default VSI manager. |
As per the MIB. |
hh3cEvbManagerID(1.3.6.1.4.1.25506.2.134.1.2.1.3) |
read-create |
OCTET STRING |
OCTET STRING (0..127) |
ID of the default VSI manager. |
The value is a zero-length string when the default VSI manager type is local. |
hh3cEvbManagerPort(1.3.6.1.4.1.25506.2.134.1.2.1.4) |
read-create |
Unsigned32 |
Unsigned32 (0..65535) |
Port number of the default VSI manager. |
If the default VSI manager type is local, the return value is zero. |
hh3cEvbManagerRowStatus (1.3.6.1.4.1.25506.2.134.1.2.1.5) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
As per the MIB. |
hh3cEvbPortConfigTable
About this table
Use this table to manage the VDP keepalive exponent and the VDP resource-wait-delay exponent.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is hh3cEvbPortNumber.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cEvbPortNumber(1.3.6.1.4.1.25506.2.134.2.1.1.1) |
not-accessible |
IEEE8021BridgePortNumber |
Unsigned32 (1..65535) |
Port number. |
As per the MIB. |
hh3cEvbRWD(1.3.6.1.4.1.25506.2.134.2.1.1.2) |
read- write |
Unsigned32 |
Unsigned32 (15..31) |
VDP resource-wait-delay exponent. |
As per the MIB. |
hh3cEvbRKA(1.3.6.1.4.1.25506.2.134.2.1.1.3) |
read- write |
Unsigned32 |
Unsigned32 (14..31) |
VDP keepalive exponent. |
As per the MIB. |
hh3cEvbSchannelConfigTable
About this table
Use this table to create S-channels and enable or disable MAC address learning and RR mode for S-channels.
Create |
Edit/Modify |
Delete |
Read |
· When you create an S-channel on a port, make sure the ieee8021BridgeEvbUAPConfigTable table already has a row with the port number as the index. The hh3cEvbPortNumber objects represents the port number. · When you create an S-channel on a port, the supported values for the hh3cEvbSchannelID object are 2 to 167 and 4094. The ID of the default S-channel is 1. You cannot create the default S-channel, but you can change the enabling status of MAC address learning and RR mode for the default S-channel. · When you create an S-channel on a port, the supported values for the hh3cEvbSchannelSVLAN object are 0 and 2 to 4094. The value of 0 indicates that no S-VLAN ID (SVID) is specified for the S-channel. The system automatically assigns an SVID to the S-channel. · To ensure successful creation, make sure the value specified for the hh3cEvbSchannelSVLAN object has not been used by other S-channels on the same port. · When you create an S-channel on a port, you must delete the hh3cEvbMacLearningStatus and hh3cEvbRRStatus objects. You can change them after S-channel creation. |
You cannot modify the hh3cEvbSchannelSVLAN object. |
Supported |
You cannot delete the default S-channel whose S-channel ID (hh3cEvbSchannelID) is 1. |
Columns
The table indexes are hh3cEvbPortNumber and hh3cEvbSchannelID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cEvbSchannelID(1.3.6.1.4.1.25506.2.134.2.2.1.1) |
not-accessible |
Unsigned32 |
S-channel ID (SCID). |
Value range: 1 to 167 and 4094. |
hh3cEvbSchannelSVLAN(1.3.6.1.4.1.25506.2.134.2.2.1.2) |
read-create |
Unsigned32 |
Unsigned32 (0..4094) |
S-VLAN ID (SVID) of the S-channel. |
The value of 0 indicates that no SVID is specified for the S-channel. The system automatically assigns an SVID to the S-channel. |
hh3cEvbMacLearningStatus(1.3.6.1.4.1.25506.2.134.2.2.1.3) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of MAC address learning. |
As per the MIB. |
hh3cEvbRRStatus(1.3.6.1.4.1.25506.2.134.2.2.1.4) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of the RR mode. |
As per the MIB. |
hh3cEvbSchannelRowStatus(1.3.6.1.4.1.25506.2.134.2.2.1.5) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cEvbVSIConfigTable
About this table
Use this table to create VSI interfaces and activate VSI interfaces.
Create |
Edit/Modify |
Delete |
Read |
· The value of the hh3cEvbVSILocalID object must be in the range of 0 to 1023. · When creating a VSI interface, you must specify the hh3cEvbVSICommand object. This object supports only preAssociate and associate. · When creating a VSI interface, you cannot specify the hh3cEvbVSIIsActive object. This object can be modified after VSI creation. |
· You can change the value of the hh3cEvbVSIIsActive object to true for a VSI interface only when the VSI interface has filter information. · You can set the value of the hh3cEvbVSICommand object only to preAssociate or associate. |
Supported |
Supported |
Columns
The table indexes are hh3cEvbSBPPortNumber and hh3cEvbVSILocalID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cEvbSBPPortNumber(1.3.6.1.4.1.25506.2.134.2.3.1.1) |
not-accessible |
Port number of a Station-facing Bridge Port (SBP). |
As per the MIB. |
hh3cEvbVSILocalID(1.3.6.1.4.1.25506.2.134.2.3.1.2) |
not-accessible |
Unsigned32 |
Local ID of a VSI interface. |
Value range: 0 to 1023. |
hh3cEvbVSICommand(1.3.6.1.4.1.25506.2.134.2.3.1.3) |
read-create |
INTEGER
preAssociate(1), preAssociateWithRsrcReservation (2), associate (3), deAssociate (4) |
Association property of the VSI interface. |
Supports only preAssociate(1) and associate(3). |
hh3cEvbVSIIfIndex(1.3.6.1.4.1.25506.2.134.2.3.1.4) |
read-only |
InterfaceIndexOrZero |
Integer32 (0..2147483647) |
VSI interface index. |
As per the MIB. |
hh3cEvbVSIIsActive(1.3.6.1.4.1.25506.2.134.2.3.1.5) |
read-write |
TruthValue |
true(1), false(2) |
Whether the VSI interface is activated. |
As per the MIB. |
hh3cEvbVSIRowStatus(1.3.6.1.4.1.25506.2.134.2.3.1.6) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cEvbVSIFilterConfigTable
About this table
Use this table to create VSI filters on a VSI interface or obtain VSI filter information.
Create |
Edit/Modify |
Delete |
Read |
When you create a VSI filter on a VSI interface, make sure the VSI interface is not activated. |
Not supported |
Before you delete a VSI filter on a VSI interface, change the value of the hh3cEvbVSIIsActive object to false in the hh3cEvbVSIConfigTable table. |
Supported |
Columns
The table indexes are hh3cEvbSBPPortNumber, hh3cEvbVSILocalID, hh3cEvbGroupID, hh3cEvbVSIMac, and hh3cEvbVSIVlanId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cEvbGroupID(1.3.6.1.4.1.25506.2.134.2.4.1.1) |
not-accessibl |
Unsigned32 |
Group ID contained in a VSI filter. |
The group ID used by the VSI filter to filter traffic. A group ID and a VLAN ID together identify a VLAN. |
hh3cEvbVSIMac(1.3.6.1.4.1.25506.2.134.2.4.1.2) |
not-accessibl |
MacAddress |
OCTET STRING (6) |
MAC address contained in the VSI filter. |
The MAC address used by the VSI filter to filter traffic. |
hh3cEvbVSIVlanId(1.3.6.1.4.1.25506.2.134.2.4.1.3) |
not-accessibl |
VlanIndex |
Unsigned32(0..4294967295) |
VLAN ID in the VSI filter. |
As per the MIB. The VLAN ID used by the VSI filter to filter traffic. |
hh3cEvbVSIRowStatus(1.3.6.1.4.1.25506.2.134.2.4.1.4) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cFlex10PortConfigTable
About this table
Use this table to enable or disable Flex10 on ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Flex10 and EVB cannot be both enabled on a port. |
Not supported |
Supported |
Columns
The table index is hh3cFlex10PortNumber.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFlex10PortNumber(1.3.6.1.4.1.25506.2.134.3.1.1.1) |
not-accessible |
Port number. |
As per the MIB. |
hh3cFlex10PortEnableStatus(1.3.6.1.4.1.25506.2.134.3.1.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of Flex10. |
As per the MIB. |
hh3cFlex10RemoteSchannelTable
About this table
Use this table to obtain remote S-channel information, including the remote S-channel description format, termination type, termination capability, traffic class, Committed Information Rate (CIR), Peak Information Rate (PIR), and connection instance ID.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cFlex10PortNumber and hh3cEvbSchannelID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFlex10RemSchDesFormat(1.3.6.1.4.1.25506.2.134.3.2.1.1) |
read-only |
BITS |
format0 (0), format1 (1) |
Description format of a remote S-channel. |
As per the MIB. |
hh3cFlex10RemSchTerminationType(1.3.6.1.4.1.25506.2.134.3.2.1.2) |
read-only |
Integer32 |
Termination type of the remote S-channel. |
As per the MIB. |
hh3cFlex10RemSchTerminationCap(1.3.6.1.4.1.25506.2.134.3.2.1.3) |
read-only |
BITS |
ethernet (0), fCoE(1), iSCSI(2), roCEE(3) |
Termination capability of the remote S-channel. |
As per the MIB. |
hh3cFlex10RemSchTrafficClass(1.3.6.1.4.1.25506.2.134.3.2.1.4) |
read-only |
BITS |
class0 (0), class1 (1), class2 (2), class3 (3), class4 (4), class5 (5), class6 (6), class7 (7) |
Traffic class of the remote S-channel. |
As per the MIB. |
hh3cFlex10RemSchCir(1.3.6.1.4.1.25506.2.134.3.2.1.5) |
read-only |
Integer32 |
CIR of the remote S-channel. |
As per the MIB. |
hh3cFlex10RemSchPir(1.3.6.1.4.1.25506.2.134.3.2.1.6) |
read-only |
Integer32 |
PIR of the remote S-channel. |
As per the MIB. |
hh3cFlex10RemSchConnectionID(1.3.6.1.4.1.25506.2.134.3.2.1.7) |
read-only |
OCTET STRING |
OCTET STRING (0..16) |
Connection instance ID of the remote S-channel. |
As per the MIB. |
hh3cFlex10SchannelLinkCtlTable
About this table
Use this table to obtain link status information about Flex10 S-channels.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFlex10SchannelSVID(1.3.6.1.4.1.25506.2.134.3.3.1.1) |
read-only |
Integer32 |
Integer32 (1..4094) |
S-VLAN ID of an S-channel |
As per the MIB. |
hh3cFlex10SchannelLocalStatus(1.3.6.1.4.1.25506.2.134.3.3.1.2) |
read-only |
Integer32 |
Integer32 { unknown(1), disabled (2), enabled (3) } |
Link status of the local end. |
As per the MIB. |
hh3cFlex10SchannelRemoteStatus(1.3.6.1.4.1.25506.2.134.3.3.1.3) |
read-only |
Integer32 |
Link status of the remote end. |
As per the MIB. |
