04-HH3C-ERPS-MIB | 60.64 KB |
HH3C-ERPS-MIB
About this MIB
HH3C-ERPS-MIB is a private MIB used to implement network management for ERPS. Use this MIB to bind a ring port to an ERPS ring or obtain port state information.
MIB file name
hh3c-erps.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).h3cCommon(2).hh3cErps(225)
Notifications
hh3cErpsPortStateForwarding
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.223.1.0.1 |
The ERPS ring port transitions to forwarding state. |
Informational |
Warning |
N/A |
ON |
A notification sent when the ERPS ring port state becomes forwarding.
Status control
The notification cannot be disabled.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.223.1.1.1 (hh3cErpsRingID) |
ID of the ERPS ring. |
N |
Integer32 |
Integer32 (1..255) |
1.3.6.1.2.1.2.2.1.1 (ifIndex) |
Index of the interface |
N |
Integer32 |
Integer32 (1..2147483647) |
1.3.6.1.2.1.2.2.1.2 (ifDescr) |
Name of the interface. |
N |
OCTET STRING |
OCTET STRING (0..255) |
Recommended action
1. Examine the link attached to the blocked port.
2. If the issue persists, contact H3C Support.
hh3cErpsPortStateDiscarding
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.223.1.0.2 |
The ERPS ring port transitions to blocked state. |
Informational |
N/A |
1.3.6.1.4.1.25506.2.223.1.0.1 (hh3cErpsPortStateForwarding) |
ON |
A notification sent when the ERPS ring port state becomes blocked.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
N |
Integer32 |
N |
Integer32 |
N |
OCTET STRING |
Recommended action
