03-HH3C-DLDP2-MIB | 78.79 KB |
HH3C-DLDP2-MIB
About this MIB
HH3C-DLDP2-MIB is a private MIB used to implement network management on the DLDP feature. Use this MIB to enable DLDP globally or on a port, and obtain port running state information, link state information, and DLDP neighbor information.
MIB file name
hh3c-dldp2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).h3cCommon(2).hh3cDldp2(117)
Scalar objects
hh3cDldp2GlobalEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDldp2GlobalEnable (1.3.6.1.4.1.25506.2.117.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Whether DLDP is enabled globally. |
As per the MIB. |
hh3cDldp2Interval
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDldp2Interval (1.3.6.1.4.1.25506.2.117.1.2) |
read-write |
Integer32 |
Integer32(1..100) |
Advertisement packet sending interval. |
As per the MIB. |
hh3cDldp2AuthMode
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDldp2AuthMode (1.3.6.1.4.1.25506.2.117.1.3) |
read-write |
INTEGER |
unknown(1), none(2), simple(3), md5(4) |
Authentication mode. |
As per the MIB. |
hh3cDldp2AuthPassword
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDldp2AuthPassword (1.3.6.1.4.1.25506.2.117.1.4) |
read-write |
OCTET STRING |
OCTET STRING (0..16) |
Authentication password. |
As per the MIB. |
hh3cDldp2UniShutdown
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDldp2UniShutdown (1.3.6.1.4.1.25506.2.117.1.5) |
read-write |
INTEGER |
unknown(1), auto(2), manual(3) |
Port shutdown mode on detecting a unidirectional link. |
As per the MIB. |
Tabular objects
hh3cDldp2PortConfigTable
About this table
Use this table to enable DLDP on a port and obtain DLDP port configuration information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDldp2PortEnable (1.3.6.1.4.1.25506.2.117.2.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Whether DLDP is enabled on the port. |
As per the MIB. |
hh3cDldp2PortStatusTable
About this table
Use this table to obtain DLDP port state and link state information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDldp2PortOperStatus (1.3.6.1.4.1.25506.2.117.2.2.1.1) |
read-only |
INTEGER |
unknown(1), initial(2), inactive(3), unidirectional(4), bidirectional(5) |
Port state. |
As per the MIB. |
hh3cDldp2PortLinkStatus (1.3.6.1.4.1.25506.2.117.2.2.1.2) |
read-only |
INTEGER |
unknown(1), down(2), up(3) |
Link state. |
As per the MIB. |
hh3cDldp2NeighborTable
About this table
Use this table to obtain neighbor information about a port.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ifIndex, hh3cDldp2NeighborBridgeMac, and hh3cDldp2NeighborPortIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDldp2NeighborBridgeMac (1.3.6.1.4.1.25506.2.117.2.3.1.1) |
not-accessible |
MacAddress |
OCTET STRING (6) |
Bridge MAC address of the neighbor. |
As per the MIB. |
hh3cDldp2NeighborPortIndex(1.3.6.1.4.1.25506.2.117.2.3.1.2) |
not-accessible |
Integer32 |
Integer32(1..2147483647) |
Port index of the neighbor. |
As per the MIB. |
hh3cDldp2NeighborStatus (1.3.6.1.4.1.25506.2.117.2.3.1.3) |
read-only |
INTEGER |
unknown(1), unconfirmed(2), confirmed(3) |
State of the neighbor. |
As per the MIB. |
hh3cDldp2NeighborAgingTime (1.3.6.1.4.1.25506.2.117.2.3.1.4) |
read-only |
Integer32 |
Standard MIB values. |
Aging time of the neighbor. |
As per the MIB. |
Notifications
This section contains trap notifications.
hh3cDldp2TrapUniLink
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.117.4.0.1 |
This notification is generated when DLDP detects unidirectional links. |
Failure |
Major |
ON |
A notification sent when DLDP detects unidirectional links.
Status control
The notification cannot be disabled.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.2.2.1.1 (ifIndex) |
Interface index. |
Y |
InterfaceIndex |
1..2147483647 |
1.3.6.1.2.1.2.2.1.2 (ifDescr) |
Interface description. |
N |
DisplayString |
OCTET STRING (SIZE (0..255)) |
Recommended action
Disable the interface, and restore the unidirectional links. If the issue cannot be resolved, contact H3C Support.
hh3cDldp2TrapBidLink
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.117.4.0.2 |
This notification is generated when DLDP detects bidirectional links. |
Failure recovery |
ON |
A notification sent when DLDP detects bidirectional links.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Y |
InterfaceIndex |
1..2147483647 |
N |
DisplayString |
Recommended action
No action is required.
