08-PIM-BSR-MIB | 75.13 KB |
PIM-BSR-MIB
About this MIB
Use this MIB to manage PIM BSR settings.
MIB file name
rfc5240-pim-bsr.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).pimBsrMIB(172)
Tabular objects
pimBsrCandidateRPTable
About this table
This table contains the IP multicast group for which the local router is to advertise itself as a Candidate-RP.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are pimBsrCandidateRPAddressType, pimBsrCandidateRPAddress, pimBsrCandidateRPGroupAddress, and pimBsrCandidateRPGroupPrefixLength.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pimBsrCandidateRPAddressType (1.3.6.1.2.1.172.1.1.1.1) |
not-accessible |
InetAddressType |
ipv4(1), ipv6(2), |
Address type of a C-RP. |
Supports only values ipv4(1) and ipv6(2). |
pimBsrCandidateRPAddress (1.3.6.1.2.1.172.1.1.1.2) |
not-accessible |
InetAddress |
OCTET STRING (4|16) |
IP address of the C-RP. |
As per the MIB. |
pimBsrCandidateRPGroupAddress (1.3.6.1.2.1.172.1.1.1.3) |
not-accessible |
InetAddress |
IP address of the multicast group for which the C-RP is advertised. |
Supports only multicast group addresses. |
pimBsrCandidateRPGroupPrefixLength (1.3.6.1.2.1.172.1.1.1.4) |
not-accessible |
InetAddressPrefixLength |
Unsigned32(4..128) |
Mask of the multicast group for which the C-RP is advertised. |
pimBsrCandidateRPBidir (1.3.6.1.2.1.172.1.1.1.5) |
read-create |
TruthValue |
true(1), false(2) |
PIM mode of the multicast group range for the RP, BIDIR-PIM or PIM-SM. |
Read-only. |
pimBsrCandidateRPAdvTimer (1.3.6.1.2.1.172.1.1.1.6) |
read-only |
TimeTicks |
Standard MIB values. |
Time remaining before the local router sends a Candidate-RP-Advertisement to the elected BSR for this zone. |
To disable this timer, set the value of this object to 0. |
pimBsrCandidateRPPriority (1.3.6.1.2.1.172.1.1.1.7) |
read-create |
Unsigned32 |
Unsigned32(0..255) |
Priority for the C-RP. |
Read-only. |
pimBsrCandidateRPAdvInterval (1.3.6.1.2.1.172.1.1.1.8) |
read-create |
Unsigned32 |
Unsigned32(1..26214) |
Time interval between two consecutive advertisements, in seconds. |
Read-only. |
pimBsrCandidateRPHoldtime (1.3.6.1.2.1.172.1.1.1.9) |
read-create |
Unsigned32 |
Unsigned32(0..65535) |
Holdtime for the C-RP. |
Read-only. Value table: 1:1..65535. |
pimBsrCandidateRPStatus (1.3.6.1.2.1.172.1.1.1.10) |
read-create |
RowStatus |
active(1) createAndGo(4) destroy(6) |
Row status. |
Read-only. Supports only the following values: active(1), createAndGo(4), and destroy(6). |
pimBsrCandidateRPStorageType (1.3.6.1.2.1.172.1.1.1.11) |
read-create |
StorageType |
other(1) |
Row storage type. |
Read-only. Supports only value other(1). |
pimBsrElectedBSRRPSetTable
About this table
This table contains BSR-specific information about PIM group mappings. It supports only the public network.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are pimBsrElectedBSRGrpMappingAddrType, pimBsrElectedBSRGrpMappingGrpAddr,
pimBsrElectedBSRGrpMappingGrpPrefixLen, and pimBsrElectedBSRGrpMappingRPAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pimBsrElectedBSRGrpMappingAddrType (1.3.6.1.2.1.172.1.2.1.2) |
not-accessible |
InetAddressType |
ipv4(1), ipv6(2) |
Address type of a multicast group. |
pimBsrElectedBSRGrpMappingGrpAddr (1.3.6.1.2.1.172.1.2.1.3) |
not-accessible |
InetAddress |
IP address of the multicast group. |
As per the MIB. |
pimBsrElectedBSRGrpMappingGrpPrefixLen (1.3.6.1.2.1.172.1.2.1.4) |
not-accessible |
Mask of the multicast group address. |
As per the MIB. |
pimBsrElectedBSRGrpMappingRPAddr (1.3.6.1.2.1.172.1.2.1.5) |
not-accessible |
InetAddress |
IP address of the RP to be used for the multicast group. |
As per the MIB. |
pimBsrElectedBSRRPSetPriority (1.3.6.1.2.1.172.1.2.1.6) |
read-only |
Unsigned32 |
Priority of the RP. |
As per the MIB. |
pimBsrElectedBSRRPSetHoldtime (1.3.6.1.2.1.172.1.2.1.7) |
read-only |
Unsigned32 |
Holdtime of the RP. |
As per the MIB. |
pimBsrElectedBSRRPSetExpiryTime (1.3.6.1.2.1.172.1.2.1.8) |
read-only |
TimeTicks |
Minimum time remaining before this entry will be aged out. |
Value zero indicates that the entry will age out immediately. |
pimBsrElectedBSRRPSetGrpBidir (1.3.6.1.2.1.172.1.2.1.9) |
read-only |
TruthValue |
true(1), false(2) |
PIM mode used for the multicast group, BIDIR-PIM or PIM-SM. |
As per the MIB. |
pimBsrCandidateBSRTable
About this table
This table contains C-BSR settings.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is pimBsrCandidateBSRZoneIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pimBsrCandidateBSRZoneIndex (1.3.6.1.2.1.172.1.3.1.1) |
not-accessible |
InetZoneIndex |
Unsigned32(1..4294967295) |
Index of the zone to which a C-BSR is attached. |
Supports only 0xFFFFFFFF 0X7FFFFFFF. |
pimBsrCandidateBSRAddressType (1.3.6.1.2.1.172.1.3.1.2) |
read-create |
InetAddressType |
ipv4(1), ipv6(2) |
Address type of the C-BSR. |
pimBsrCandidateBSRAddress (1.3.6.1.2.1.172.1.3.1.3) |
read-create |
InetAddress |
IP address of the C-BSR. |
As per the MIB. |
pimBsrCandidateBSRPriority (1.3.6.1.2.1.172.1.3.1.4) |
read-create |
Unsigned32 |
Priority of the C-BSR. |
Default: 1:64 (int). Value range: 1:0..255. |
pimBsrCandidateBSRHashMaskLength (1.3.6.1.2.1.172.1.3.1.5) |
read-create |
Unsigned32 |
Unsigned32(0..32) |
Mask length for the IP address of the C-BSR. |
Value range: 1:0..32. |
pimBsrCandidateBSRElectedBSR (1.3.6.1.2.1.172.1.3.1.6) |
read-only |
TruthValue |
true(1), false(2) |
Whether this router is a BSR. |
As per the MIB. |
pimBsrCandidateBSRBootstrapTimer (1.3.6.1.2.1.172.1.3.1.7) |
read-only |
TimeTicks |
Time remaining for this router to send the next BSR message. |
As per the MIB. |
pimBsrCandidateBSRStatus (1.3.6.1.2.1.172.1.3.1.8) |
read-create |
RowStatus |
Row status. |
pimBsrCandidateBSRStorageType (1.3.6.1.2.1.172.1.3.1.9) |
read-create |
StorageType |
other(1) |
Row storage type. |
pimBsrElectedBSRTable
About this table
This table contains BSR settings. It supports only the public network and does not support administratively-scoped zones.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported. Supports only index 0xffffffff. Supports only IPv4. |
Columns
The table index is pimBsrElectedBSRZoneIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pimBsrElectedBSRZoneIndex (1.3.6.1.2.1.172.1.4.1.1) |
not-accessible |
InetZoneIndex |
pimBsrElectedBSRAddressType (1.3.6.1.2.1.172.1.4.1.2) |
read-only |
InetAddressType |
ipv4(1), ipv6(2) |
Address type of a BSR. |
pimBsrElectedBSRAddress (1.3.6.1.2.1.172.1.4.1.3) |
read-only |
InetAddress |
IP address of the BSR. |
As per the MIB. |
pimBsrElectedBSRPriority (1.3.6.1.2.1.172.1.4.1.4) |
read-only |
Unsigned32 |
Priority of the BSR. |
As per the MIB. |
pimBsrElectedBSRHashMaskLength (1.3.6.1.2.1.172.1.4.1.5) |
read-only |
Unsigned32 |
Unsigned32(0..128) |
Mask length for the BSR's IP address. |
Value range: 1:0..128. |
pimBsrElectedBSRExpiryTime (1.3.6.1.2.1.172.1.4.1.6) |
read-only |
TimeTicks |
Time remaining before the BSR ages out. |
As per the MIB. |
Notifications
pimBsrElectedBSRLostElection
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.172.0.1 |
Lost BSR election to a new E-BSR |
Informational |
Warning |
N/A |
ON |
This notification is generated when the current E-BSR lost election to a new E-BSR. Only E-BSR will generate this notification.
Status control
ON
CLI: Use the snmp-agent trap enable { pim | pim6 } elected-bsr-lost-election command.
OFF
CLI: Use the undo snmp-agent trap enable { pim | pim6 } elected-bsr-lost-election command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.172.1.4.1.2 (pimBsrElectedBSRAddressType) |
No |
InetAddressType |
ipv4(1) ipv6(2) |
1.3.6.1.2.1.172.1.4.1.3 (pimBsrElectedBSRAddress) |
No |
InetAddress |
1.3.6.1.2.1.172.1.4.1.4 (pimBsrElectedBSRPriority) |
No |
Unsigned32 |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
To resolve the issue:
1. Verify that whether this notification is generated because of BSR or C-BSR configuration change.
2. Verify that other PIM routers are operating correclty.
3. Verify that the local router has sufficient memory.
4. Verify that the local router does not have link failures.
5. If the issue persists, contact H3C Support.
pimBsrCandidateBSRWinElection
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.172.0.2 |
Win of BSR election. |
Informational |
Warning |
N/A |
ON |
This notification is generated when a C-BSR was elected as the E-BSR. Only E-BSR will generate this notification.
Status control
ON
CLI: Use the snmp-agent trap enable { pim | pim6 } candidate-bsr-win-election command.
OFF
CLI: Use the undo snmp-agent trap enable { pim | pim6 } candidate-bsr-win-election command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.172.1.3.1.6 (pimBsrCandidateBSRElectedBSR) |
Whether this routeristhe E-BSR. |
No |
TruthValue |
true(1) false(2) |
Recommended action
