03-HH3C-MULTICAST-SNOOPING-MIB | 91.53 KB |
About this MIB
Multicast snooping runs on a Layer 2 device as a multicast constraining mechanism to improve multicast forwarding efficiency. It creates Layer 2 multicast forwarding entries from IGMP or MLD packets that are exchanged between the hosts and the Layer 3 device.
Use this MIB to manage IGMP snooping and MLD snooping.
MIB file name
hh3c-multicast-snooping.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMulticastSnoop(123)
Tabular objects
hh3cMcsGlobalConfigTable
About this table
This table contains the global configuration of IGMP or MLD snooping.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cMcsGlbSnoopingType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMcsGlbSnoopingType (1.3.6.1.4.1.25506.2.123.1.1.1.1) |
not-accessible |
InetAddressType |
IPv4: IGMP snooping IPv6: MLD snooping |
Type of the global configuration. |
As per the MIB. |
hh3cMcsGlbRowStatus (1.3.6.1.4.1.25506.2.123.1.1.1.2) |
read-create |
RowStatus |
active(1) createAndGo(4) destroy(6) |
Row status. |
Supports only the following values: active(1), createAndGo(4), and destroy(6). |
hh3cMcsGlbEntryLimit(1.3.6.1.4.1.25506.2.123.1.1.1.3) |
read-create |
Unsigned32 |
Standard MIB values. |
Global maximum number of IGMP or MLD snooping forwarding entries. |
As per the MIB. |
hh3cMcsGlbHostAgingTime(1.3.6.1.4.1.25506.2.123.1.1.1.4) |
read-create |
Unsigned32 |
Unsigned32 (1.. 8097894) |
Global aging time of the multicast group on ports. |
As per the MIB. |
hh3cMcsGlbMaxResponseTime(1.3.6.1.4.1.25506.2.123.1.1.1.5) |
read-create |
Unsigned32 |
Unsigned32(1..3174) |
Global maximum query response time. |
As per the MIB. |
hh3cMcsGlbRouterAgingTime(1.3.6.1.4.1.25506.2.123.1.1.1.6) |
read-create |
Unsigned32 |
Global aging time of router ports. |
As per the MIB. |
hh3cMcsGlbLastMemQryInterval(1.3.6.1.4.1.25506.2.123.1.1.1.7) |
read-create |
Unsigned32 |
Unsigned32(1..25) |
Global last member query interval. |
As per the MIB. |
hh3cMcsGlbDropUnknownEnabled(1.3.6.1.4.1.25506.2.123.1.1.1.8) |
read-create |
TruthValue |
true(1), false(2) |
Whether the feature of dropping unknown packets is enabled globally. |
Implementation varies by product. Default: Disabled. |
hh3cMcsVirtualUnitConfigTable
About this table
This table contains IGMP or MLD snooping settings for a virtual unit (VLAN or VSI).
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cMcsVUType, hh3cMcsVUID, and hh3cMcsVUSnoopingType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMcsVUType (1.3.6.1.4.1.25506.2.123.1.2.1.1) |
not-accessible |
Hh3cVirtualUnitType |
INTEGER{ vlan(1), vsi(2) } |
Type of a virtual unit. |
As per the MIB. |
hh3cMcsVUID (1.3.6.1.4.1.25506.2.123.1.2.1.2) |
not-accessible |
Unsigned32, |
VLAN ID or VSI Index. |
As per the MIB. |
hh3cMcsVUSnoopingType(1.3.6.1.4.1.25506.2.123.1.2.1.3) |
not-accessible |
InetAddressType |
IPv4: igmp snooping IPv6: mld snooping |
Type of the snooping configuration. |
As per the MIB. |
hh3cMcsVURowStatus (1.3.6.1.4.1.25506.2.123.1.2.1.4) |
read-create |
RowStatus |
Row status. |
hh3cMcsVUHostAgingTime(1.3.6.1.4.1.25506.2.123.1.2.1.5) |
read-create |
Unsigned32 |
Unsigned32 (0.. 8097894) |
Aging time of the multicast group on ports in the VLAN or VSI. |
As per the MIB. |
hh3cMcsVUMaxResponseTime(1.3.6.1.4.1.25506.2.123.1.2.1.6) |
read-create |
Unsigned32 |
Unsigned32(0..3174) |
Maximum query response time in the VLAN or VSI. |
As per the MIB. |
hh3cMcsVURouterAgingTime(1.3.6.1.4.1.25506.2.123.1.2.1.7) |
read-create |
Unsigned32 |
Aging time of the router port in the VLAN or VSI. |
As per the MIB. |
hh3cMcsVULastMemQryInterval(1.3.6.1.4.1.25506.2.123.1.2.1.8) |
read-create |
Unsigned32 |
Unsigned32(0..25) |
Last member query interval in the VLAN or VSI. |
As per the MIB. |
hh3cMcsVUDropUnknownEnabled(1.3.6.1.4.1.25506.2.123.1.2.1.9) |
read-create |
TruthValue |
true(1), false(2) |
Whether the feature of dropping unknown packets is enabled in the VLAN or VSI. |
As per the MIB. |
hh3cMcsVUPimSnoopingEnabled(1.3.6.1.4.1.25506.2.123.1.2.1.10) |
read-create |
TruthValue |
true(1), false(2) |
Whether PIM snooping is enabled in the VLAN or VSI. |
As per the MIB. |
hh3cMcsVUVersion(1.3.6.1.4.1.25506.2.123.1.2.1.11) |
read-create |
Unsigned32 |
2|3 |
Version of IGMP or MLD snooping that is running on the VLAN or VSI. |
As per the MIB. · 2—IGMPv2 snooping or MLDV1 snooping. · 3—IGMPv3 snooping or MLDv2 snooping. |
hh3cMcsVUQuerierEnabled(1.3.6.1.4.1.25506.2.123.1.2.1.12) |
read-create |
TruthValue |
true(1), false(2) |
Whether the querier feature is enabled in the VLAN or VSI. |
As per the MIB. |
hh3cMcsVUQuerierInterval (1.3.6.1.4.1.25506.2.123.1.2.1.13) |
read-create |
Unsigned32 |
Unsigned32(2..31744) |
General query interval in the VLAN or VSI. |
As per the MIB. |
hh3cMcsVUGeneQuerierSourceAddress(1.3.6.1.4.1.25506.2.123.1.2.1.14) |
read-create |
InetAddress |
OCTET STRING (0..255) |
Source IP address of IGMP or MLD general query packets. |
As per the MIB. |
hh3cMcsVUSpecQuerierSourceAddress(1.3.6.1.4.1.25506.2.123.1.2.1.15) |
read-create |
InetAddress |
Source IP address of IGMP or MLD group-specific query packets. |
As per the MIB. |
hh3cMcsVULeaveSourceAddress(1.3.6.1.4.1.25506.2.123.1.2.1.16) |
read-create |
InetAddress |
Source IP address of IGMP or MLD leave packets. |
As per the MIB. |
hh3cMcsVUReportSourceAddress(1.3.6.1.4.1.25506.2.123.1.2.1.17) |
read-create |
InetAddress |
Source IP address of IGMP or MLD report packets. |
As per the MIB. |
hh3cMcsVUProxyEnabled(1.3.6.1.4.1.25506.2.123.1.2.1.18) |
read-create |
TruthValue |
true(1), false(2) |
Whether the proxy feature is enabled in the VLAN or VSI. |
As per the MIB. |
hh3cMcsVUQuerierElection(1.3.6.1.4.1.25506.2.123.1.2.1.19) |
read-create |
TruthValue |
true(1), false(2) |
Whether the querier election feature is enabled in the VLAN or VSI. |
As per the MIB. |
hh3cMcsL2EntryTable
About this table
This table containing a list of Layer 2 multicast group entries in a VLAN or VSI.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cMcsL2EntryVUType, hh3cMcsL2EntryVUID, hh3cMcsL2EntryAddressType, hh3cMcsL2EntryGroupAddress, hh3cMcsL2EntrySourceAddress, and hh3cMcsL2EntryIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMcsL2EntryVUType (1.3.6.1.4.1.25506.2.123.1.3.1.1) |
not-accessible |
As per the MIB. |
hh3cMcsL2EntryVUID (1.3.6.1.4.1.25506.2.123.1.3.1.2) |
not-accessible |
Unsigned32, |
VLAN ID or VSI index. |
As per the MIB. |
hh3cMcsL2EntryAddressType(1.3.6.1.4.1.25506.2.123.1.3.1.3) |
not-accessible |
InetAddressType |
Type of the multicast group address. |
As per the MIB. |
hh3cMcsL2EntryGroupAddress(1.3.6.1.4.1.25506.2.123.1.3.1.4) |
not-accessible |
InetAddress |
Address of the multicast group which the port joined. |
As per the MIB. |
hh3cMcsL2EntrySourceAddress(1.3.6.1.4.1.25506.2.123.1.3.1.5) |
not-accessible |
InetAddress |
IP address of the unicast source which the port joined. |
As per the MIB. |
hh3cMcsL2EntryIfIndex(1.3.6.1.4.1.25506.2.123.1.3.1.6) |
not-accessible |
InterfaceIndex |
Integer32(1..2147483647) |
Index of an outgoing interface. |
As per the MIB. |
hh3cMcsL2EntryPortType (1.3.6.1.4.1.25506.2.123.1.3.1.7) |
read-only |
INTEGER |
interface(1), ac(2), npw(3), upw(4), trill(5), tunnel(6), mtunnel(7) |
Type of the outgoing interface. |
As per the MIB. |
hh3cMcsL2EntryPorAttribute (1.3.6.1.4.1.25506.2.123.1.3.1.8) |
read-only |
BITS |
BITS { d(0), s(1), p(2), k(3), r(4), w(5), b(6), e(7), de(8), ee(9), suc(10), f(11) } |
Attributes of the outgoing interface. |
As per the MIB. |
hh3cMcsPacketStatisticsTable
About this table
This table contains IGMP or MLD packets statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cMcsStatisticsSnoopingType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMcsStatisticsSnoopingType(1.3.6.1.4.1.25506.2.123.1.4.1.1) |
not-accessible |
InetAddressType |
IPv4: IGMP Snooping IPv6: MLD Snooping |
As per the MIB. |
hh3cMcsRxGeneryQueryNum(1.3.6.1.4.1.25506.2.123.1.4.1.2) |
read-only |
Counter64 |
INTEGER(0..18446744073709551615) |
Number of IGMP or MLD general query packets received on the device. |
As per the MIB. |
hh3cMcsRxV2SpecificQueryNum(1.3.6.1.4.1.25506.2.123.1.4.1.3) |
read-only |
Counter64 |
Number of IGMPv2 or MLDv1 group-specific query packets received on the device. |
As per the MIB. |
hh3cMcsRxV3SpecificQueryNum(1.3.6.1.4.1.25506.2.123.1.4.1.4) |
read-only |
Counter64 |
Number of IGMPv3 or MLDv2 group-specific query packets received on the device. |
As per the MIB. |
hh3cMcsRxV1ReportNum (1.3.6.1.4.1.25506.2.123.1.4.1.5) |
read-only |
Counter64 |
Number of IGMPv1 report packets received on the device. |
As per the MIB. |
hh3cMcsRxV2ReportNum (1.3.6.1.4.1.25506.2.123.1.4.1.6) |
read-only |
Counter64 |
Number of IGMPv2 or MLDv1 report packets received on the device. |
As per the MIB. |
hh3cMcsRxV3ReportNum (1.3.6.1.4.1.25506.2.123.1.4.1.7) |
read-only |
Counter64 |
Number of IGMPv3 or MLDv2 report packets received on the device. |
As per the MIB. |
hh3cMcsRxV3ErrCorReportNum(1.3.6.1.4.1.25506.2.123.1.4.1.8) |
read-only |
Counter64 |
Number of IGMPv3 or MLDv2 report packets with correct and incorrect records received on the device. |
As per the MIB. |
hh3cMcsRxLeaveNum (1.3.6.1.4.1.25506.2.123.1.4.1.9) |
read-only |
Counter64 |
Number of leave packets received on the device. |
As per the MIB. |
hh3cMcsRxPimHelloNum (1.3.6.1.4.1.25506.2.123.1.4.1.10) |
read-only |
Counter64 |
Number of PIM hello packets received on the device. |
As per the MIB. |
hh3cMcsRxErrorPacketNum (1.3.6.1.4.1.25506.2.123.1.4.1.11) |
read-only |
Counter64 |
Number of error IGMP or MLD packets received on the device. |
As per the MIB. |
hh3cMcsTxV2SpecificQueryNum(1.3.6.1.4.1.25506.2.123.1.4.1.12) |
read-only |
Counter64 |
Number of IGMPv2 or MLDv1 group-specific query packets sent from the device. |
As per the MIB. |
hh3cMcsTxV3SpecificQueryNum(1.3.6.1.4.1.25506.2.123.1.4.1.13) |
read-only |
Counter64 |
Number of IGMPv3 or MLDv2 group-specific query packets sent from the device. |
As per the MIB. |
hh3cMcsTxV3SpecificSGQueryNum(1.3.6.1.4.1.25506.2.123.1.4.1.14) |
read-only |
Counter64 |
Number of IGMPv3 or MLDv2 group-and-source-specific query packets sent from the device. |
As per the MIB. |
hh3cMcsPortJoinGroupConfigTable
About this table
This table contains settings of a port configured as a simulated member host for a multicast group.
Create |
Edit/Modify |
Delete |
Read |
Supported only when global IGMP or MLD snooping is enabled. |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cMcsPortJoinGroupIfIndex, hh3cMcsPortJoinGroupSnoopingType, hh3cMcsPortJoinGroupVlanID, hh3cMcsPortJoinGroupGroupAddress, and hh3cMcsPortJoinGroupSourceAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMcsPortJoinGroupIfIndex(1.3.6.1.4.1.25506.2.123.1.5.1.1) |
not-accessible |
InterfaceIndex |
Index of the port for which this entry contains information. |
As per the MIB. |
hh3cMcsPortJoinGroupSnoopingType(1.3.6.1.4.1.25506.2.123.1.5.1.2) |
not-accessible |
InetAddressType |
Type of snooping configuration, which also indicates the protocol type of addresses. |
As per the MIB. |
hh3cMcsPortJoinGroupVlanID(1.3.6.1.4.1.25506.2.123.1.5.1.3) |
not-accessible |
Unsigned32 |
Unsigned32(1..4094) |
VLAN ID. |
As per the MIB. |
hh3cMcsPortJoinGroupGroupAddress(1.3.6.1.4.1.25506.2.123.1.5.1.4) |
not-accessible |
InetAddress |
IP address of the group to which the host belongs. |
As per the MIB. |
hh3cMcsPortJoinGroupSourceAddress(1.3.6.1.4.1.25506.2.123.1.5.1.5) |
not-accessible |
InetAddress |
IP address of the source. |
As per the MIB. |
hh3cMcsPortJoinGroupStatus(1.3.6.1.4.1.25506.2.123.1.5.1.6) |
read-create |
RowStatus |
Row status. |
hh3cMcsPortStaticGroupConfigTable
About this table
This table contains static group membership entries on a port.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cMcsPortStaticGroupIfIndex, hh3cMcsPortStaticGroupSnoopingType, hh3cMcsPortStaticGroupVlanID, hh3cMcsPortStaticGroupGroupAddress, and hh3cMcsPortStaticGroupSourceAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMcsPortStaticGroupIfIndex(1.3.6.1.4.1.25506.2.123.1.6.1.1) |
not-accessible |
InterfaceIndex |
As per the MIB. |
hh3cMcsPortStaticGroupSnoopingType (1.3.6.1.4.1.25506.2.123.1.6.1.2) |
not-accessible |
InetAddressType |
As per the MIB. |
hh3cMcsPortStaticGroupVlanID(1.3.6.1.4.1.25506.2.123.1.6.1.3) |
not-accessible |
Unsigned32 |
VLAN ID. |
As per the MIB. |
hh3cMcsPortStaticGroupGroupAddress(1.3.6.1.4.1.25506.2.123.1.6.1.4) |
not-accessible |
InetAddress |
Address of the multicast group. |
As per the MIB. |
hh3cMcsPortStaticGroupSourceAddress(1.3.6.1.4.1.25506.2.123.1.6.1.5) |
not-accessible |
InetAddress |
As per the MIB. |
hh3cMcsPortStaticGroupStatus(1.3.6.1.4.1.25506.2.123.1.6.1.6) |
read-create |
RowStatus |
Row status. |
hh3cMcsRouterPortConfigEntry
About this table
This table contains static router port entries for a port.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cMcsRouterPortConfigIfIndex, hh3cMcsRouterPortConfigSnoopingType, and hh3cMcsRouterPortConfigVlanID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMcsRouterPortConfigIfIndex(1.3.6.1.4.1.25506.2.123.1.7.1.1) |
not-accessible |
InterfaceIndex |
As per the MIB. |
hh3cMcsRouterPortConfigSnoopingType(1.3.6.1.4.1.25506.2.123.1.7.1.2) |
not-accessible |
InetAddressType |
Type of snooping configuration. |
As per the MIB. |
hh3cMcsRouterPortConfigVlanID(1.3.6.1.4.1.25506.2.123.1.7.1.3) |
not-accessible |
Unsigned32 |
VLAN ID |
As per the MIB. |
hh3cMcsRouterPortConfigRowStatus(1.3.6.1.4.1.25506.2.123.1.7.1.4) |
read-create |
RowStatus |
Row status. |
hh3cMcsPortConfigTable
About this table
This table contains the fast-leaving status, group limit number, group policy parameters and overflow replacement status on a port.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cMcsPortConfigIfIndex, hh3cMcsPortConfigSnoopingType, and hh3cMcsPortConfigVlanID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMcsPortConfigIfIndex(1.3.6.1.4.1.25506.2.123.1.8.1.1) |
not-accessible |
InterfaceIndex |
As per the MIB. |
hh3cMcsPortConfigSnoopingType(1.3.6.1.4.1.25506.2.123.1.8.1.2) |
not-accessible |
InetAddressType |
As per the MIB. |
hh3cMcsPortConfigVlanID (1.3.6.1.4.1.25506.2.123.1.8.1.3) |
not-accessible |
Unsigned32 |
VLAN ID. |
As per the MIB. |
hh3cMcsPortConfigGroupLimitNumber(1.3.6.1.4.1.25506.2.123.1.8.1.4) |
read-create |
Unsigned32 |
Group limit number of the port. |
As per the MIB. |
hh3cMcsPortConfigFastLeaveStatus(1.3.6.1.4.1.25506.2.123.1.8.1.5) |
read-create |
TruthValue |
true(1), false(2) |
Fast-leaving status of the port. |
As per the MIB. |
hh3cMcsPortConfigGroupPolicyParameter(1.3.6.1.4.1.25506.2.123.1.8.1.6) |
read-create |
Unsigned32 |
Unsigned32(0|2000..3999) |
ACL number which is used as the group policy parameter of the port. |
As per the MIB. |
hh3cMcsPortConfigOverflowReplace(1.3.6.1.4.1.25506.2.123.1.8.1.7) |
read-create |
TruthValue |
true(1), false(2) |
Status of overflow replacement for the hh3cMcsPortConfigGroupLimitNumber object. |
As per the MIB. |
hh3cMcsPortConfigRowStatus(1.3.6.1.4.1.25506.2.123.1.8.1.8) |
read-create |
RowStatus |
Row status. |
